  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
2.5k Beiträge 164 Kommentatoren 1.4m Aufrufe 151 Beobachtet
  • F fichte_112
    @arteck
    Hi, ich habe das bluelinky verzeichnis gelöscht, den Adapter V3.1.22 von git gezogen mit dem script den Refresh Token erstellt und als Passwort eingetragen. Jetzt kommen folgende Fehlermeldungen.
    host.Debian
    2025-10-16 17:41:40.511 error instance system.adapter.bluelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[1]: Node.js v22.20.0
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: }
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: requestPath: 'bluelinky'
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: path: '/opt/iobroker/node_modules/bluelinky/package.json',
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: at require (node:internal/modules/helpers:147:16) {
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1192:37)
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: at Function._resolveFilename (node:internal/modules/cjs/loader:1369:27)
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: at Function._findPath (node:internal/modules/cjs/loader:764:18)
    host.Debian
    2025-10-16 17:41:40.511 error Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:502:19)
    host.Debian
    2025-10-16 17:41:40.510 error Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/bluelinky/dist/index.cjs'. Please verify that the package.json has a valid "main" entry
    host.Debian
    2025-10-16 17:41:40.510 error Caught by controller[0]: ^
    host.Debian
    2025-10-16 17:41:40.510 error Caught by controller[0]: throw err;
    host.Debian
    2025-10-16 17:41:40.510 error Caught by controller[0]: node:internal/modules/cjs/loader:510
    arteckA
    arteckA
    arteck
    #2221
    @fichte_112 jo warte da ist was nicht mitgekommen ins GIT
    so jetzt lösch den nochmal
    rm -r /opt/iobroker/node_modules/bluelinky/
    und installier nochmal 3.1.23
    F 2 Antworten Letzte Antwort
    • U
      U
      ulfhro
      #2222
      Läuft!!! DANKE!!!
      • arteckA arteck
        F
        F
        fichte_112
        #2223
        @arteck funktioniert, vielen Dank 👍
        • arteckA arteck
          F
          F
          fichte_112
          #2224
          @arteck Der Adapter läuft wieder. Vielen Dank nochmals.
          Es fehlen aber noch einige Datenpunkte in den Objekten.
          Bei mir geht es um einen Hyundai Tucson PHEV.
          Fehlende Objekte, welche ich bisher genutzt habe:
          Plugin, Reichweite Benzin, Reichweite elektrisch, Reichweite gesamt, Ladezustand, Restzeit vom laden.
          • M
            M
            ManfredHi
            schrieb am zuletzt editiert von ManfredHi
            #2225
            Hallo. Ich komme einfach nicht weiter. Wenn chrome unter windows aufgeht, dann melde ich mich mit meinen Hyundai-Zugangsdaten an. Aber dann komme ich auf eine Polnische Hyundai Webseite "click to buy"....
            was mache ich falsch. Ich komme auch nicht weiter wenn ich das ganze über die konsole auf meiner iobroker-vm mache.
            beim start in der konsole kommt das:
            iobuser@iobroker:/tmp/kia$ python3 HyundaiFetchApiTokens.py
              File "/tmp/kia/HyundaiFetchApiTokens.py", line 124
                <title>ioBroker.bluelink/py/HyundaiFetchApiTokens.py at master · Newan/ioBroker.bluelink · GitHub</title>
            SyntaxError: invalid character '·' (U+00B7)
            • M
              M
              ManfredHi
              #2226
              sorry. funktoniert schon, hatte ein problem gehabt beim kopieren der py-Datei.
              DANKE.
              • F fichte_112
                arteckA
                arteckA
                arteck
                #2227
                @fichte_112 wenn die bisher da waren sollten die jetzt auch immer noch da sein
                • arteckA arteck
                  F
                  F
                  fichte_112
                  #2228
                  @arteck die Datenpunkte sind da. Sie werden aber nicht aktualisiert.
                  • arteckA arteck
                    @meute so einfach ist das nicht...
                    da die Anpassung an den hyundai Server in der 3.1.21 nicht da ist..
                    aber jetzt..3.1.22 ... neue Version von GIT laden.. der Fix ist nur für Hyundai also alle die KIA haben => ihr braucht das nicht da reicht die 3.1.21
                    was ist zu tun
                    https://github.com/Newan/ioBroker.bluelink/tree/master/py
                    M
                    M
                    Michi_Pi
                    #2229
                    @arteck läuft bei mir auch wieder, vielen Dank
                    • arteckA arteck
                      F
                      F
                      fichte_112
                      #2230
                      @arteck
                      ich habe den Adapter und alle Objekte gelöscht und neu installiert.
                      jetzt fehlen folgende von mir vorher genutzten Objekte:
                      bluelink.0.***************.vehicleStatus.battery.soc
                      bluelink.0.***************.vehicleStatusRaw.ccs2Status.state.Vehicle.Green.ChargingInformation.Charging.RemainTime
                      bluelink.0.***************.vehicleStatusRaw.ccs2Status.state.Vehicle.Green.ChargingInformation.ConnectorFastening.State
                      bluelink.0.***************.vehicleStatusRaw.vehicleStatus.fuelLevel
                      bluelink.0.***************.vehicleStatus.hoodOpen
                      bluelink.0.***************.vehicleStatusRaw.ccs2Status.state.Vehicle.Drivetrain.FuelSystem.DTE.Total
                      bluelink.0.***************.vehicleStatusRaw.ccs2Status.state.Vehicle.Drivetrain.FuelSystem.DTE.EV
                      bluelink.0.***************.vehicleStatusRaw.ccs2Status.state.Vehicle.Drivetrain.FuelSystem.DTE.ICE
                      Ich konnte aber alle Datenpunkte an anderer Stelle finden
                      • F fichte_112
                        @arteck
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        host.Debian
                        arteckA
                        arteckA
                        arteck
                        #2231
                        @fichte_112 ja das kann sein.. du hast kein ccs2 verbaut.. also bekommst du das auch nicht.. kann sein dass der mal angelegt worden ist.. hatte halt ein bug drin.
                        sollten da sein.. dein tucson ist baugleich mit meinem Sportage
                        F 1 Antwort Letzte Antwort
                        • R
                          R
                          RISSN
                          #2232
                          gibt es vielleicht eine bessere Beschreibung, wo man dieses Script einfügen muss? Irgendwie stehe ich auf dem Schlauch
                          • arteckA arteck
                            F
                            F
                            fichte_112
                            #2233
                            @arteck
                            der Ordner "vehicleStatus" wird bei mir nicht mehr angelegt. Ich habe die benötigten Daten punkte unter "vehicleStatusRaw" gefunden.
                            • R RISSN
                              F
                              F
                              fichte_112
                              #2234
                              @rissn
                              Wenn du Windows nutzt musst du "Python Releases for Windows" installieren.
                              Danach die Befehle in der Windows PowerShell abarbeiten
                              R 1 Antwort Letzte Antwort
                              • F fichte_112
                                @rissn
                                R
                                R
                                RISSN
                                #2235
                                @fichte_112 Danke
                                • arteckA arteck
                                  @ilovegym gut dass ich deine Daten noch habe
                                  guckmal PN
                                  F
                                  F
                                  Friedel
                                  #2236
                                  @arteck
                                  Hallo, ich habe das gleiche Problem, das ich auf eine franzoesiche Website komme.
                                  Wie ist denn hier der Lösungsschritt?
                                  • F Friedel
                                    @arteck
                                    T
                                    T
                                    Toni0570
                                    #2237
                                    @friedel
                                    Du hast vermutlich den Browser nicht umgestellt. Das hatte ich auch überlesen.
                                    Ich habe das Python Skript Gemini gegeben und mir erklären lassen. Damit ist mir dann klarer geworden, was ich da mache.
                                    Anton
                                    • T Toni0570
                                      @friedel
                                      Anton
                                      F
                                      F
                                      Friedel
                                      #2238
                                      @toni0570
                                      Hallo, also ich den umgestellt, kann natürlich sein das mir da ein Fehler unterlaufen ist.
                                      Hab das vorher auch noch nie gemacht bzw. benötigt.
                                      Hab es jetzt nochmals durchgeführt, aber immer noch das gleiche Problem.
                                      • F
                                        F
                                        Friedel
                                        #2239
                                        @friedel sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                        @toni0570
                                        Zur Info: Hatte nach der Änderung die Seite nicht aktualisiert bevor ich die URL aufgrufen habe.
                                        Jetzt läuft es. Danke für die Unterstützung.
                                        I 1 Antwort Letzte Antwort
                                        • F Friedel
                                          @toni0570
                                          I
                                          I
                                          Ingo 3
                                          #2240
                                          @friedel
                                          Hallo Friedel
                                          könntest du bitte genau erklären wie du den token für Hyundai bekommen hast?
                                          Bekomme es den ganzen Nachmittag nicht hin
                                          Grüße Ingo
                                          83.9k
