  3. Off Topic
  4. Proxmox
  5. Proxmox WebIf nicht erreichbar
    2.7k
    4.7k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
70 Beiträge 5 Kommentatoren 6.2k Aufrufe 4 Beobachtet
  • NegaleinN Negalein
    @crunchip
    nach einem reboot zeigt ip addr jetzt die passende IP.
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
        inet 127.0.0.1/8 scope host lo
           valid_lft forever preferred_lft forever
        inet6 ::1/128 scope host
    2: enp0s31f6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master vmbr0 state UP group default qlen 1000
        link/ether 6c:4b:90:43:c9:19 brd ff:ff:ff:ff:ff:ff
    3: vmbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
        inet 10.0.1.206/23 scope global vmbr0
        inet6 fe80::6e4b:90ff:fe43:c919/64 scope link
    aber https://10.0.1.206:8006/ geht trotzdem noch nicht. :(
    dann hab ich mit nano /etc/network/interfaces:auto vmbr0 ein neues File erstellt.
    iface vmbr0 inet static
    address 10.0.1.206/23
    gateway 10.0.1.1
    bridge-ports enp0s31f6
    bridge-stp off
    bridge-fd 0
    ● pveproxy.service - PVE API Proxy Server
         Loaded: loaded (/lib/systemd/system/pveproxy.service; enabled; vendor preset: enabled)
         Active: active (running) since Sun 2025-10-12 13:59:51 CEST; 3s ago
        Process: 1524 ExecStartPre=/usr/bin/pvecm updatecerts --silent (code=exited, status=111)
        Process: 1525 ExecStart=/usr/bin/pveproxy start (code=exited, status=0/SUCCESS)
       Main PID: 1527 (pveproxy)
          Tasks: 4 (limit: 18839)
         Memory: 132.7M
            CPU: 943ms
         CGroup: /system.slice/pveproxy.service
                 ├─1527 pveproxy
                 ├─1528 pveproxy worker
                 ├─1529 pveproxy worker
                 └─1530 pveproxy worker
    Oct 12 13:59:50 pve pvecm[1524]: Unable to load access control list: Connection refused
    Oct 12 13:59:51 pve pveproxy[1527]: starting server
    Oct 12 13:59:51 pve pveproxy[1527]: starting 3 worker(s)
    Oct 12 13:59:51 pve pveproxy[1527]: worker 1528 started
    Oct 12 13:59:51 pve pveproxy[1527]: worker 1529 started
    Oct 12 13:59:51 pve pveproxy[1527]: worker 1530 started
    Oct 12 13:59:51 pve pveproxy[1528]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
    Oct 12 13:59:51 pve systemd[1]: Started PVE API Proxy Server.
    Oct 12 13:59:51 pve pveproxy[1529]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
    Oct 12 13:59:51 pve pveproxy[1530]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
    funktioniert aber auch nicht
    crunchipC Abwesend
    crunchipC Abwesend
    @negalein sagte in Proxmox WebIf nicht erreichbar:
    Dann mal doch die etc/hosts anschauen
      ip addr & route -n zeiigt aber noch
      Weil du nur den proxy und nicht den Netzwerkdienst neu gestartet hast.
      Ist die 206 auch frei, oder Vllt schon anderweitig belegt?
      Gibt's im LOG etwas zu sehen? Ist die Fehlermeldung von oben noch vorhanden?
      Möglichkeit wäre noch testhalber von statisch auf DHCP stellen um eventuelle Fehler auszuschließen.
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      @crunchip sagte in Proxmox WebIf nicht erreichbar:
      ah, deshalb.
      Nach reboot hat er die richtige IP gehabt.
      Aber GUI geht nicht.
      Ja, definitiv frei
      wo find ich das?
      Ja
      in der /etc/network/interfaces:auto?
      iface vmbr0 inet DHCP
      gateway 10.0.1.1
      bridge-stp off
      bridge-fd 0
      so?
      etc/hosts
      127.0.0.1 localhost.localdomain localhost
      10.0.1.206 proxmox-3.fritz.box
      # The following lines are desirable for IPv6 capable hosts
      ::1     ip6-localhost ip6-loopback
      fe00::0 ip6-localnet
      ff00::0 ip6-mcastprefix
      ff02::1 ip6-allnodes
      ff02::2 ip6-allrouters
      ff02::3 ip6-allhosts
      ° Fixer ---> iob fix
        ah, deshalb.
        Ja, definitiv frei
        wo find ich das?
        Ja
        gateway 10.0.1.1
        bridge-stp off
        bridge-fd 0
        so?
        etc/hosts
        crunchipC Abwesend
        crunchipC Abwesend
        @negalein moment, ich geh gleich mal an den Rechner, vom Handy is das immer etwas umständlich.
        • crunchipC Abwesend
          crunchipC Abwesend
          wo find ich das
          wie üblich in var/log
          /var/log/: Enthält eine Vielzahl von Systemprotokollen, darunter:
          syslog: Allgemeine Systemmeldungen.
          auth.log: Authentifizierungsereignisse.
          syslog-ng: Protokolldateien von Syslog-ng (falls konfiguriert).
          apt/history.log: Zeigt die History von Paketinstallationen an.
          /var/log/pve/: Enthält Proxmox-spezifische Logs.
          /var/log/messages/: Enthält eine Auswahl von Systemmeldungen.
          allerdings seit proxmox v8(debian12)
          abruf mit
          z.b.
          journalctl -f
          speziell proxy
          journalctl -u pveproxy
          so?
          auto vmbr0
          iface vmbr0 inet dhcp
              bridge-stp off
              bridge-fd 0
          edit
          möglichkeit wäre noch
          GUI per CLI wieder aktivieren: Falls die Netzumstellungen zu Problemen geführt haben, kann per CLI ein Reset oder eine Reparatur versucht werden:
          systemctl restart pve-manager
          oder
          apt-get install --reinstall pve-manager
          und dann Logs auf Fehler kontrollieren.
          edit2
          SSL-Zertifikate defekt: Ein defektes Zertifikat kann die Weboberfläche blockieren. Prüfe Logs auf Fehler zu SSL oder Zertifikat.​
          Browser-Cache oder HTTPS erzwingen: Lösche den Browser-Cache oder teste mit einem anderen Browser.
          NegaleinN 2 Antworten Letzte Antwort
            wo find ich das
            abruf mit
            z.b.
            journalctl -f
            speziell proxy
            so?
            auto vmbr0
                bridge-stp off
                bridge-fd 0
            edit
            oder
            edit2
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            Failed to restart pve-manager.service: Operation refused, unit pve-guests.service may be requested by dependency only (it is configured to refuse manual start/stop).
            See system logs and 'systemctl status pve-manager.service' for details.
            ct 12 14:53:51 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
            Oct 12 14:53:51 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
            Oct 12 14:53:52 pve pveproxy[3628]: worker exit
            Oct 12 14:53:52 pve pveproxy[890]: worker 3628 finished
            Oct 12 14:53:52 pve pveproxy[890]: starting 1 worker(s)
            Oct 12 14:53:52 pve pveproxy[890]: worker 3632 started
            Oct 12 14:53:52 pve pveproxy[3629]: worker exit
            Oct 12 14:53:52 pve pveproxy[3630]: worker exit
            Oct 12 14:53:52 pve pveproxy[3632]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
            Oct 12 14:53:52 pve pveproxy[890]: worker 3629 finished
            Oct 12 14:53:52 pve pveproxy[890]: worker 3633 started
            Oct 12 14:53:52 pve pveproxy[890]: worker 3630 finished
            Oct 12 14:53:52 pve pveproxy[890]: worker 3634 started
            Oct 12 14:53:52 pve pveproxy[3633]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
            Oct 12 14:53:52 pve pveproxy[3634]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
            Oct 12 14:53:55 pve pmxcfs[3631]: [main] crit: Unable to get local IP address
            Oct 12 14:53:55 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
            Oct 12 14:53:55 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
            Oct 12 14:53:55 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
            Oct 12 14:53:55 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
            Oct 12 14:53:55 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 676.
            Oct 12 14:53:55 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
            Oct 12 14:53:55 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
            Oct 12 14:53:57 pve pveproxy[3632]: worker exit
            Oct 12 14:53:57 pve pveproxy[890]: worker 3632 finished
            Oct 12 14:53:57 pve pveproxy[890]: starting 1 worker(s)
            Oct 12 14:53:57 pve pveproxy[890]: worker 3641 started
            Oct 12 14:53:57 pve pveproxy[3633]: worker exit
            Oct 12 14:53:57 pve pveproxy[3634]: worker exit
            Oct 12 14:53:57 pve pveproxy[3641]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
            Oct 12 14:53:57 pve pveproxy[890]: worker 3633 finished
            Oct 12 14:53:57 pve pveproxy[890]: worker 3642 started
            Oct 12 14:53:57 pve pveproxy[890]: worker 3634 finished
            Oct 12 14:53:57 pve pveproxy[890]: worker 3643 started
            Oct 12 14:53:57 pve pveproxy[3642]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
            Oct 12 14:53:57 pve pveproxy[3643]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
            Oct 12 14:53:59 pve pmxcfs[3635]: [main] crit: Unable to get local IP address
            Oct 12 14:53:59 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
            Oct 12 14:53:59 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
            Oct 12 14:53:59 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
            Oct 12 14:53:59 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
            Oct 12 14:53:59 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 677.
            Oct 12 14:53:59 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
            Oct 12 14:53:59 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
            Oct 12 14:54:01 pve cron[843]: (*system*vzdump) CAN'T OPEN SYMLINK (/etc/cron.d/vzdump)
            Oct 12 14:54:02 pve pveproxy[3641]: worker exit
            Oct 12 14:54:02 pve pveproxy[890]: worker 3641 finished
            Oct 12 14:54:02 pve pveproxy[890]: starting 1 worker(s)
            Oct 12 14:54:02 pve pveproxy[890]: worker 3646 started
            Oct 12 14:54:02 pve pveproxy[3642]: worker exit
            Oct 12 14:54:02 pve pveproxy[3646]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
            Oct 12 14:54:02 pve pveproxy[3643]: worker exit
            Oct 12 14:54:02 pve pveproxy[890]: worker 3642 finished
            Oct 12 14:54:02 pve pveproxy[890]: worker 3647 started
            Oct 12 14:54:02 pve pveproxy[890]: worker 3643 finished
            Oct 12 14:54:02 pve pveproxy[890]: worker 3648 started
            Oct 12 14:54:02 pve pveproxy[3647]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
            Oct 12 14:54:02 pve pveproxy[3648]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
            Oct 12 14:54:03 pve pmxcfs[3644]: [main] crit: Unable to get local IP address
            Oct 12 14:54:03 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
            Oct 12 14:54:03 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
            Oct 12 14:54:03 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
            Oct 12 14:54:03 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
            Oct 12 14:54:04 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 678.
            Oct 12 14:54:04 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
            Oct 12 14:54:04 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
            Oct 12 14:54:07 pve pveproxy[3646]: worker exit
            Oct 12 14:54:07 pve pveproxy[890]: worker 3646 finished
            Oct 12 14:54:07 pve pveproxy[890]: starting 1 worker(s)
            Oct 12 14:54:07 pve pveproxy[890]: worker 3650 started
            Oct 12 14:54:07 pve pveproxy[3647]: worker exit
            Oct 12 14:54:07 pve pveproxy[3650]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
            Oct 12 14:54:07 pve pveproxy[3648]: worker exit
            Oct 12 14:54:07 pve pveproxy[890]: worker 3647 finished
            Oct 12 14:54:07 pve pveproxy[890]: worker 3651 started
            Oct 12 14:54:07 pve pveproxy[890]: worker 3648 finished
            Oct 12 14:54:07 pve pveproxy[890]: worker 3652 started
            Oct 12 14:54:07 pve pveproxy[3651]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
            Oct 12 14:54:07 pve pveproxy[3652]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
            Oct 12 14:54:08 pve pmxcfs[3649]: [main] crit: Unable to get local IP address
            Oct 12 14:54:08 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
            Oct 12 14:54:08 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
            Oct 12 14:54:08 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
            Oct 12 14:54:08 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
            Oct 12 14:54:08 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 679.
            Oct 12 14:54:08 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
            Oct 12 14:54:08 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
            Oct 12 14:54:12 pve pveproxy[3650]: worker exit
            Oct 12 14:54:12 pve
            ● pve-guests.service - PVE guests
                 Loaded: loaded (/lib/systemd/system/pve-guests.service; enabled; vendor preset: enabled)
                 Active: failed (Result: exit-code) since Sun 2025-10-12 14:04:14 CEST; 53min ago
                Process: 899 ExecStartPre=/usr/share/pve-manager/helpers/pve-startall-delay (code=exited, status=0/SUCCESS)
                Process: 900 ExecStart=/usr/bin/pvesh --nooutput create /nodes/localhost/startall (code=exited, status=111)
               Main PID: 900 (code=exited, status=111)
                    CPU: 747ms
            Oct 12 14:04:13 pve systemd[1]: Starting PVE guests...
            Oct 12 14:04:14 pve pvesh[900]: ipcc_send_rec[1] failed: Connection refused
            Oct 12 14:04:14 pve pvesh[900]: ipcc_send_rec[2] failed: Connection refused
            Oct 12 14:04:14 pve pvesh[900]: ipcc_send_rec[3] failed: Connection refused
            Oct 12 14:04:14 pve pvesh[900]: Unable to load access control list: Connection refused
            Oct 12 14:04:14 pve systemd[1]: pve-guests.service: Main process exited, code=exited, status=111/n/a
            Oct 12 14:04:14 pve systemd[1]: pve-guests.service: Failed with result 'exit-code'.
            Oct 12 14:04:14 pve systemd[1]: Failed to start PVE guests.
              wo find ich das
              abruf mit
              z.b.
              journalctl -f
              speziell proxy
              so?
              auto vmbr0
                  bridge-stp off
                  bridge-fd 0
              edit
              oder
              edit2
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              Reading package lists... Done
              Reinstallation of pve-manager is not possible, it cannot be downloaded.
              0 upgraded, 0 newly installed, 0 to remove and 161 not upgraded.
                Oct 12 14:54:12 pve
                        CPU: 747ms
                crunchipC Abwesend
                crunchipC Abwesend
                pve-ssl.key: failed
                dann mach mal
                pvecm updatecerts -f
                systemctl restart pveproxy
                Prüfe, ob die IP angezeigt wird mit hostname -I
                  Pfleg die Kiste. Da hängt einiges in der Pipeline.
                    pve-ssl.key: failed
                    dann mach mal
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    hostname -I
                    10.0.1.206
                    @thomas-braun sagte in Proxmox WebIf nicht erreichbar:
                    I know!
                    die lag monatelang in der Schublade.
                    Wird sofort erledigt, sobald wieder alles läuft.
                      hostname -I
                      10.0.1.206
                      I know!
                      Ich würde das ja andersherum angehen.
                      ZUERST die Basis klar kriegen und erst DANACH die darauf aufbauenden Dinge konfigurieren.
                      NegaleinN crunchipC 2 Antworten Letzte Antwort
                        hostname -I
                        10.0.1.206
                        I know!
                        crunchipC Abwesend
                        crunchipC Abwesend
                        ipcc_send_rec[1] failed: Connection refused ipcc_send_rec[2] failed: Connection refused ipcc_send_rec[3] failed: Connection refused Unable to load access control list: Connection refused
                        systemctl status pve-cluster
                        systemctl restart pve-cluster
                        journalctl -u pve-cluster -b --no-pager | tail -40
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          gerade dabei :)
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @thomas-braun wird aber schwierig ohne funktionierendes Netzwerk
                              Grundsätzlich scheint doch da was zu sein.
                              Sonst hätte apt-get ja nicht ausrechnen können, das 161 Pakete zum Update anstehen.
                              crunchipC uweklattU 2 Antworten Letzte Antwort
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @thomas-braun ja, aber gewisse Dinge können dann aber nicht umgesetzt werden bzw bestimmte Befehle nicht auf Proxmoxebene ausgeführt werden, solange der Proxmox Cluster-Dienst bzw. Corosync nicht laufen, deshalb greifen auch die obigen Befehle nicht
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  ● pve-cluster.service - The Proxmox VE cluster filesystem
                                       Loaded: loaded (/lib/systemd/system/pve-cluster.service; enabled; vendor preset: enabled)
                                       Active: activating (start) since Sun 2025-10-12 15:27:11 CEST; 1ms ago
                                  Cntrl PID: 930 (pmxcfs)
                                        Tasks: 1 (limit: 18839)
                                       Memory: 128.0K
                                          CPU: 199us
                                       CGroup: /system.slice/pve-cluster.service
                                               └─930 /usr/bin/pmxcfs
                                  Oct 12 15:27:11 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                                  Job for pve-cluster.service failed because the control process exited with error code.
                                  See "systemctl status pve-cluster.service" and "journalctl -xe" for details.
                                  journalctl -xe
                                  ░░ The job identifier is 8927 and the job result is done.
                                  Oct 12 15:30:03 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                                  ░░ Subject: A start job for unit pve-cluster.service has begun execution
                                  ░░ Defined-By: systemd
                                  ░░ Support: https://www.debian.org/support
                                  ░░ A start job for unit pve-cluster.service has begun execution.
                                  ░░ The job identifier is 8927.
                                  Oct 12 15:30:07 pve pmxcfs[1084]: [main] crit: Unable to get local IP address
                                  Oct 12 15:30:07 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
                                  ░░ Subject: Unit process exited
                                  ░░ An ExecStart= process belonging to unit pve-cluster.service has exited.
                                  ░░ The process' exit code is 'exited' and its exit status is 255.
                                  Oct 12 15:30:07 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
                                  ░░ Subject: Unit failed
                                  ░░ The unit pve-cluster.service has entered the 'failed' state with result 'exit-code'.
                                  Oct 12 15:30:07 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
                                  ░░ Subject: A start job for unit pve-cluster.service has failed
                                  ░░ A start job for unit pve-cluster.service has finished with a failure.
                                  ░░ The job identifier is 8927 and the job result is failed.
                                  Oct 12 15:30:07 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
                                  ░░ Subject: A start job for unit corosync.service has finished successfully
                                  ░░ A start job for unit corosync.service has finished successfully.
                                  ░░ The job identifier is 8930.
                                  Oct 12 15:30:07 pve pveproxy[1081]: worker exit
                                  Oct 12 15:30:07 pve pveproxy[1082]: worker exit
                                  Oct 12 15:30:07 pve pveproxy[889]: worker 1081 finished
                                  Oct 12 15:30:07 pve pveproxy[889]: starting 1 worker(s)
                                  Oct 12 15:30:07 pve pveproxy[889]: worker 1082 finished
                                  Oct 12 15:30:07 pve pveproxy[889]: worker 1085 started
                                  Oct 12 15:30:07 pve pveproxy[1083]: worker exit
                                  Oct 12 15:30:07 pve pveproxy[1085]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                                  Oct 12 15:30:07 pve pveproxy[889]: worker 1083 finished
                                  Oct 12 15:30:07 pve pveproxy[889]: starting 2 worker(s)
                                  Oct 12 15:30:07 pve pveproxy[889]: worker 1086 started
                                  Oct 12 15:30:07 pve pveproxy[889]: worker 1087 started
                                  Oct 12 15:30:07 pve pveproxy[1086]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                                  Oct 12 15:30:07 pve pveproxy[1087]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                                  Oct 12 15:30:08 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 22.
                                  ░░ Subject: Automatic restarting of a unit has been scheduled
                                  ░░ Automatic restarting of the unit pve-cluster.service has been scheduled, as the result for
                                  ░░ the configured Restart= setting for the unit.
                                  Oct 12 15:30:08 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
                                  ░░ Subject: A stop job for unit pve-cluster.service has finished
                                  ░░ A stop job for unit pve-cluster.service has finished.
                                  ░░ The job identifier is 9103 and the job result is done.
                                  Oct 12 15:30:08 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                                  ░░ The job identifier is 9103.
                                    uweklattU Offline
                                    uweklattU Offline
                                    uweklatt
                                    Wenn man die Netzwerkmaske ändert, sollte es bei allen Geräten im zugehörigen Netzwerk identisch eingestellt werden. Danach den Netzwerkstack neu starten (z.B. mit einem Reboot).
                                    Sind ALLE Beteiligten Geräte umgestellt?
                                    Tschau
                                    Uwe
                                    Intel i5/Proxmox/LXC/Docker/ioBroker
                                           Memory: 128.0K
                                              CPU: 199us
                                      journalctl -xe
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      @negalein zeig mal den Eintrag in /etc/pve/corosync.conf
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        die ist leer
                                        @uweklatt sagte in Proxmox WebIf nicht erreichbar:
                                        geht nur um dieses Gerät! Alle anderen (PC, Handy, ...) laufen schon monatelang unter neuer Konfig.
                                          die ist leer
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          die ist leer
                                          ok,also kein cluster sondern single node
