  4. Tester wanted - Zigbee Adapter 3.1
testerzhczigbeezigbee 3.1
273 Beiträge 17 Kommentatoren 35.3k Aufrufe 16 Beobachtet
    @meisterq-0 sagte in Tester wanted - Zigbee Adapter 3.1:
    This is a problem related to network connectivity.npm error network In most cases you are behind a proxy or have bad network settings.
    npm error network If you are behind a proxy, please make sure that the 'proxy' config is set properly. See: 'npm help config'npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-28T15_20_44_636Z-debug-0.log
    MeisterQ 0
    schrieb am zuletzt editiert von MeisterQ 0
    #218
    @Homoran
    Mein Netzwerk läuft seit Wochen Stabil. Keine Errors, keine Veränderung. Von der URL hab ich schon öfter installiert.
    Nach 5 Versuchen ging es nun endlich.
    Aber trotzdem hat 3.1.5 die selbe Problematik wie 3.1.4. Ich bekomme den Adapter nur mit 3.1.2 zum laufen.
    zigbee.0
    	2025-09-28 17:38:03.704	error	Resolve entity error: Cannot read properties of undefined (reading 'model')
    zigbee.0
    	2025-09-28 17:38:03.703	warn	Resolve Entity did not manage to find a mapped device for 0xd44867fffe5b4c36 of type undefined
    zigbee.0
    	2025-09-28 17:38:03.692	info	zigbecontroller stopped successfully - ZH was not running
    zigbee.0
    	2025-09-28 17:38:03.689	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    	2025-09-28 17:38:03.689	info	terminating
    zigbee.0
    	2025-09-28 17:38:03.689	info	cleanup successful
    zigbee.0
    	2025-09-28 17:38:03.688	info	Saved local configuration data
    zigbee.0
    	2025-09-28 17:38:03.687	info	cleaning everything up
    zigbee.0
    	2025-09-28 17:38:03.687	info	Halting zigbee adapter. Restart delay is at least 30 seconds.
    zigbee.0
    	2025-09-28 17:38:03.671	error	Cannot read properties of undefined (reading 'options')
    zigbee.0
    	2025-09-28 17:38:03.671	error	TypeError: Cannot read properties of undefined (reading 'options') at DeviceEvent.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:15:77) at processTicksAndRejections (node:internal/process/task_queues:95:5) at async Promise.all (index 2)
    zigbee.0
    	2025-09-28 17:38:03.671	error	unhandled promise rejection: Cannot read properties of undefined (reading 'options')
    zigbee.0
    	2025-09-28 17:38:03.671	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2025-09-28 17:38:03.670	error	Resolve entity error: Cannot read properties of undefined (reading 'model')
    zigbee.0
    	2025-09-28 17:38:03.669	warn	Resolve Entity did not manage to find a mapped device for 0xd44867fffe5b4c36 of type undefined
    zigbee.0
    	2025-09-28 17:38:03.668	warn	DeviceEvent:calling onEvent for start on 0x0c4314fffe7a483d
    zigbee.0
    	2025-09-28 17:38:03.668	warn	DeviceEvent:calling onEvent for start on 0x588e81fffe3bc8a1
    zigbee.0
    	2025-09-28 17:38:03.666	warn	DeviceEvent:calling onEvent for start on 0xec1bbdfffe8eb47e
    zigbee.0
    	2025-09-28 17:38:03.665	warn	DeviceEvent:calling onEvent for start on 0x0cae5ffffeb46866
    zigbee.0
    	2025-09-28 17:38:03.664	warn	DeviceEvent:calling onEvent for start on 0x54ef441000c283e9
    zigbee.0
    	2025-09-28 17:38:03.664	warn	DeviceEvent:calling onEvent for start on 0x54ef441000c28823
    zigbee.0
    	2025-09-28 17:38:03.663	warn	DeviceEvent:calling onEvent for start on 0x282c02bfffed9110
    zigbee.0
    	2025-09-28 17:38:03.658	warn	DeviceEvent:calling onEvent for start on 0x282c02bfffed9354
    zigbee.0
    	2025-09-28 17:38:03.658	warn	DeviceEvent:calling onEvent for start on 0x000d6ffffe8e73b3
    zigbee.0
    	2025-09-28 17:38:03.657	warn	DeviceEvent:calling onEvent for start on 0x0cae5ffffeb4560f
    zigbee.0
    	2025-09-28 17:38:03.651	error	Resolve entity error: Cannot read properties of undefined (reading 'model')
    zigbee.0
    	2025-09-28 17:38:03.649	warn	Resolve Entity did not manage to find a mapped device for 0xd44867fffe5b4c36 of type undefined
    zigbee.0
    	2025-09-28 17:38:03.636	info	Zigbee started
    zigbee.0
    	2025-09-28 17:38:03.635	info	46 devices are part of the network
    zigbee.0
    	2025-09-28 17:38:03.635	error	Resolve entity error: Cannot read properties of undefined (reading 'model')
    zigbee.0
    	2025-09-28 17:38:03.628	warn	Resolve Entity did not manage to find a mapped device for 0xd44867fffe5b4c36 of type undefined
    • M MeisterQ 0
      @Homoran
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      #219
      Aber jetzt gibt's anscheinend zeitweise Probleme!
        MeisterQ 0
        #220
        @homoran Danke für die Information. Die Probleme mit dem Adapter sind aktuell wichtiger :)
        • D dimaiv
          @asgothian sagte in Tester wanted - Zigbee Adapter 3.1:
          @dimaiv sagte in Tester wanted - Zigbee Adapter 3.1:
          aber wird als idefined angezeigt :
          Violett markiert sieht auch nicht so richtig aus, seit 3.1.5
          das Undefined kann ein Überbleibsel aus dem unerfolgreichen Versuch es anzumelden sein.
          Loesung dafuer:
          Den Dialog zum 'Namen anpassen' öffnen, den vorgegebenen Namen löschen, nichts eintragen, abspeichern, Fettich.
          Unter 3.1.5 alpha.0 funktioniert es nicht, ich kann keine Namen ändern, ich kann nich die optionen hinzufügen oder löschen, also, da wird nix geschpeichert. Unter 3.1.4 funktioniert es wie beschrieben.
          Die Positionierung auf der Kachel kommt immer mal wieder vor - hat etwas mit dem Browser zoom zu tun. Mach den mal etwas kleiner oder etwas grósser, dann sollte das wieder passen.
          Es hat mehrere Jahre gut funktioniert unter egal welchem Browser, und erst ab 3.1.5 muss man mit zoom spielen.
          Da habe ich bisher keine saubere Lósung für gefunden.
          A.
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #221
          Das ist nicht Korrekt - das Problem gibt es seit diesem PR - Es betrifft nur bestimmte Installationen, Fenstergrössen, Browserfenster und OS Kombinationen. Offensichtlich ist die Berechnung beim Rendering betroffen.
          A.
          Nachtrag - bitte nochmal vom oben angegebenen Link installieren. Damit sollte auch das Rendering besser sein.
          ABER: Keine Garantie das das Problem weg ist - ich hab nur begrenzt testen können. Interessanter ist für mich:
          • lassen sich mit der Version Geräte anlernen / ablernen ? (Stabil - bei mir geht es)
          • lassen sich die Geräte wieder anlernen (auch das geht bei mir ohne Probleme)
          • lassen sich Geräte die das System nicht kennt neu anlernen (nicht kennen = nach Neustart des Adapters hat der Adapter keines der Geräte - dann anlernen. Genau das war die Situation wo der Fehler aufgetreten ist)
          • lassen sich die Optionen bei Geräten einstellen (die Optionen sind vom Edit Group zu Select Image gewechselt - der Dialog wurde zu voll
          • lassen sich Geräte zu Gruppen hinzufügen (das geht bei mir auch)
          A.
          • AsgothianA Asgothian
            @locito09 Frage - du schriebst der adapter bleibt dann rot. Ist das so, oder lässt sich der Adapter nach dem Pairing wieder (manuell) starten ?
            locito09
            #222
            @asgothian
            Bleibt rot
            • L locito09
              @asgothian
              Bleibt rot
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #223
              @locito09 sagte in Tester wanted - Zigbee Adapter 3.1:
              @asgothian
              Bleibt rot
              hast du die neue Version installiert ?
              Die richtige hat die Versionsnummer 3.1.5-alpha.1
              A.
              AsgothianA L 2 Antworten Letzte Antwort
                @asgothian
                Bleibt rot
                A.
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #224
                Ich hab auf dem ioBroker GitHub nochmal eine Version hoch geladen. Dabei sind noch 3 aktive Bugs aufgefallen:
                • Die Netzwerkkarte geht nur bei 'kleinen' Netzen. Bei grossen Netzen wird der Bereich in dem sie dargestellt werden kann sehr klein (noch nicht klar warum)
                • Beim hinzufügen und löschen von Geräten aus Gruppen gibt es Anzeige-Probleme. Hinzufügen geht aktuell nur über die Gerätekachel, Löschen aus der Gruppe nur über die Gruppenkachel
                • Es gibt immer noch warn Meldungen zum Koordinator.
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  #225
                  um bei den Events weiter zu kommen brauche ich Informationen dazu welche Gerätetypen für detail-Tests ggf. verfügbar sind. Deswegen melden die 3.1.x-alpha Versionen beim Start
                  Ich wäre Dankbar für eine Liste von Gerätetypen (idealerweise mit zigbee2mqtt Link für die entsprechenden Geräte. Dann kann ich mir die Konverter anschauen und ggf. dedizierte Tests anfragen um bei der Umsetzung der Optionen von Z2M vorwärts zu kommen.
                  Mein Problem ist das ich kaum eigene Geräte habe die diese Funktion nutzen.
                  A.
                  D 2 Antworten Letzte Antwort
                    A.
                    dimaiv
                    schrieb am zuletzt editiert von dimaiv
                    #226
                    @asgothian
                    Optionen sind weg:
                    adapter:3.1.5-alpha.1
                    installed from:ioBroker/ioBroker.zigbee
                    ZHC / ZH:25.31.0 / 6.1.3
                    P.S.: Dafür aber Zoom/Skalieren besser geworden.
                    ioBroker- NUC8i3 / Proxmox / VM
                    Node.js v22.21.0
                    NPM v10.9.4
                    JS controller 7.1.0
                    Admin 7.7.20
                    ZigBee Adapter 3.3.1alpha.0
                    Zigbee LAN Gateway CC2652P
                    Zigbee Firmware 20250321
                    • D dimaiv
                      @asgothian
                      Optionen sind weg:
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #227
                      Optionen sind weg:
                      Nein, die Optionen sind gewandert auf den Dialog wo auch das Gerätebild ausgewählt werden soll.
                      A.
                        @asgothian
                        Bleibt rot
                        A.
                        locito09
                        #228
                        @asgothian
                        Mit dieser version geht es
                        -1
                        • L locito09
                          @asgothian
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #229
                          @asgothian
                          Was ist "es" ? Ein Monster ? Ein Eintrag aus dieser Liste (in-Forum Link) ? Das eine Gerät welches nicht ging ?
                          A.
                            A.
                            dimaiv
                            #230
                            A.
                            Folgende Geräte habe ich mit onEvent (laut Adapter Start):
                            1. Smart thermostat
                            2. TRADFRI LED driver, 10 w
                            3. FYRTUR roller blind, block-out
                            4. 10A UK or 16A EU smart plug
                            5. TRADFRI remote control
                            6. TRADFRI LED driver, 30 w
                            7. SURTE door light panel, white spectrum
                            8. TRADFRI bulb E26/E27, white spectrum
                            9. TRADFRI bulb GU10, white
                            10. TRADFRI bulb E12/E14/E26/E27, color/white spectrum
                            11. TRADFRI bulb E26/E27, white spectrum
                            12. Zigbee smart water valve
                            13. Waterproof (IP65) sensor with screen and probe temperature detection
                            Node.js v22.21.0
                            NPM v10.9.4
                            JS controller 7.1.0
                            Admin 7.7.20
                            • D dimaiv
                              A.
                              1. Smart thermostat
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #231
                              Und wieder gibts eine neue alpha:
                              3.1.5-alpha.2
                              Sollte alle bekannten Fehler beheben:
                              • Kartendarstellung sollte passen
                              • Gruppen sollten wieder normal mit Mitgliedern versorgt oder von Mitgliedern befreit werden können
                              Zusätzlich gibts einen Anzeiger wenn der Adapter nicht mehr reagiert. Sieht so aus:
                              Das passiert wenn der Adapter im Hintergrund abstürzt oder nicht mehr reagiert und das Zigbee-Tab geöffnet ist (oder die Konfiguration)
                              Es kann in einzelnen Fällen auch auftauchen wenn der Adapter zu langsam reagiert - dann müsste ich das wissen.
                              Wichtig: dieses geht nicht auf den 'alive' DP aus dem Objektbaum, sondern verifiziert ob die Kommunikation zwischen oberfläche und Adapter schnell genug ist. Aktuell ist 'schnell genug' 500 ms.
                              Bitte testen. Wenn es keine Effekte gibt darf der dann als 3.1.5 ins Latest
                              A.
                              FabioF 1 Antwort Letzte Antwort
                                3.1.5-alpha.2
                                A.
                                FabioF Offline
                                FabioF Offline
                                Fabio
                                #232
                                @asgothian runtergeladen beide Instanzen laufen bis jetzt ohne Probleme.👍 👍
                                Herzliche Grüße und vielen Dank
                                Fabio
                                Iobroker:
                                • Matter over Thread Hilfe
                                • FabioF Fabio
                                  Fabio
                                  dimaiv
                                  #233
                                  @fabio
                                  Hi. Kannst du mal probieren etwas anzulernen, und nach Fehler im Log schauen?
                                  Node.js v22.21.0
                                  NPM v10.9.4
                                  JS controller 7.1.0
                                  Admin 7.7.20
                                  • D dimaiv
                                    @fabio
                                    FabioF Offline
                                    FabioF Offline
                                    Fabio
                                    schrieb am zuletzt editiert von Fabio
                                    #234
                                    @dimaiv das hab ich:
                                    zigbee.0
                                    2025-10-01 11:01:15.910	info	Opening zigbee Network for 90 seconds
                                    zigbee.0
                                    2025-10-01 11:01:06.294	info	Closing Zigbee network, 1 seconds remaining
                                    zigbee.0
                                    2025-10-01 11:00:14.570	info	Handled all devices Queued for configuration.
                                    zigbee.0
                                    2025-10-01 11:00:09.579	info	DeviceConfigure successful 0x04cf8cdf3c7c252d ZNCZ04LM
                                    zigbee.0
                                    2025-10-01 11:00:09.571	info	Configuring 0x04cf8cdf3c7c252d ZNCZ04LM
                                    zigbee.0
                                    2025-10-01 11:00:09.570	info	DeviceConfigureQueue configuring 0x04cf8cdf3c7c252d lumi.plug.mmeu01
                                    zigbee.0
                                    2025-10-01 11:00:04.570	info	Device '0x04cf8cdf3c7c252d' is supported, identified as: Xiaomi Mi smart plug EU (ZNCZ04LM)
                                    zigbee.0
                                    2025-10-01 11:00:04.570	info	Successfully interviewed '0x04cf8cdf3c7c252d', device has successfully been paired
                                    zigbee.0
                                    2025-10-01 11:00:04.434	info	message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"ID":185,"_endpoints":[{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1,"zclVersion":3,"appVersion":24,"stackVersion":2,"hwVersion":1,"dateCode":"01-23-2022"}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},{"_events":{},"_eventsCount":0,"inputClusters":[],"outputClusters":[],"ID":242,"clusters":{},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}}],"_ieeeAddr":"0x04cf8cdf3c7c252d","_interviewState":"IN_PROGRESS","_lastSeen":1759309204433,"_manufacturerID":4447,"_networkAddress":55739,"_type":"Router","_linkquality":47,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1,"zclVersion":3,"appVersion":24,"stackVersion":2,"hwVersion":1,"dateCode":"01-23-2022"}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},"data":{},"linkquality":47,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,209,1,0,64,134]},"zclTransactionSequenceNumber":209,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
                                    zigbee.0
                                    2025-10-01 11:00:04.380	info	message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"ID":185,"_endpoints":[{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1,"zclVersion":3,"appVersion":24,"stackVersion":2,"hwVersion":1,"dateCode":"01-23-2022"}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},{"_events":{},"_eventsCount":0,"inputClusters":[],"outputClusters":[],"ID":242,"clusters":{},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}}],"_ieeeAddr":"0x04cf8cdf3c7c252d","_interviewState":"IN_PROGRESS","_lastSeen":1759309204380,"_manufacturerID":4447,"_networkAddress":55739,"_type":"Router","_linkquality":54,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1,"zclVersion":3,"appVersion":24,"stackVersion":2,"hwVersion":1,"dateCode":"01-23-2022"}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},"data":{"dateCode":"01-23-2022"},"linkquality":54,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,208,1,6,0,0,66,10,48,49,45,50,51,45,50,48,50,50]},"zclTransactionSequenceNumber":208,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
                                    zigbee.0
                                    2025-10-01 11:00:04.332	info	message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"ID":185,"_endpoints":[{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1,"zclVersion":3,"appVersion":24,"stackVersion":2,"hwVersion":1}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},{"_events":{},"_eventsCount":0,"inputClusters":[],"outputClusters":[],"ID":242,"clusters":{},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}}],"_ieeeAddr":"0x04cf8cdf3c7c252d","_interviewState":"IN_PROGRESS","_lastSeen":1759309204332,"_manufacturerID":4447,"_networkAddress":55739,"_type":"Router","_linkquality":51,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1,"zclVersion":3,"appVersion":24,"stackVersion":2,"hwVersion":1}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},"data":{"hwVersion":1},"linkquality":51,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,207,1,3,0,0,32,1]},"zclTransactionSequenceNumber":207,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
                                    zigbee.0
                                    2025-10-01 11:00:04.283	info	message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"ID":185,"_endpoints":[{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1,"zclVersion":3,"appVersion":24,"stackVersion":2}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},{"_events":{},"_eventsCount":0,"inputClusters":[],"outputClusters":[],"ID":242,"clusters":{},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}}],"_ieeeAddr":"0x04cf8cdf3c7c252d","_interviewState":"IN_PROGRESS","_lastSeen":1759309204282,"_manufacturerID":4447,"_networkAddress":55739,"_type":"Router","_linkquality":51,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1,"zclVersion":3,"appVersion":24,"stackVersion":2}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},"data":{"stackVersion":2},"linkquality":51,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,206,1,2,0,0,32,2]},"zclTransactionSequenceNumber":206,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
                                    zigbee.0
                                    2025-10-01 11:00:04.235	info	message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"ID":185,"_endpoints":[{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1,"zclVersion":3,"appVersion":24}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},{"_events":{},"_eventsCount":0,"inputClusters":[],"outputClusters":[],"ID":242,"clusters":{},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}}],"_ieeeAddr":"0x04cf8cdf3c7c252d","_interviewState":"IN_PROGRESS","_lastSeen":1759309204234,"_manufacturerID":4447,"_networkAddress":55739,"_type":"Router","_linkquality":51,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1,"zclVersion":3,"appVersion":24}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},"data":{"appVersion":24},"linkquality":51,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,205,1,1,0,0,32,24]},"zclTransactionSequenceNumber":205,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
                                    zigbee.0
                                    2025-10-01 11:00:04.179	info	message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"ID":185,"_endpoints":[{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1,"zclVersion":3}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},{"_events":{},"_eventsCount":0,"inputClusters":[],"outputClusters":[],"ID":242,"clusters":{},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}}],"_ieeeAddr":"0x04cf8cdf3c7c252d","_interviewState":"IN_PROGRESS","_lastSeen":1759309204178,"_manufacturerID":4447,"_networkAddress":55739,"_type":"Router","_linkquality":51,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1,"zclVersion":3}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},"data":{"zclVersion":3},"linkquality":51,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,204,1,0,0,0,32,3]},"zclTransactionSequenceNumber":204,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
                                    zigbee.0
                                    2025-10-01 11:00:04.132	info	message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"ID":185,"_endpoints":[{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},{"_events":{},"_eventsCount":0,"inputClusters":[],"outputClusters":[],"ID":242,"clusters":{},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}}],"_ieeeAddr":"0x04cf8cdf3c7c252d","_interviewState":"IN_PROGRESS","_lastSeen":1759309204131,"_manufacturerID":4447,"_networkAddress":55739,"_type":"Router","_linkquality":51,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI","powerSource":1}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},"data":{"powerSource":1},"linkquality":51,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,203,1,7,0,0,48,1]},"zclTransactionSequenceNumber":203,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
                                    zigbee.0
                                    2025-10-01 11:00:04.060	info	message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"ID":185,"_endpoints":[{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI"}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},{"_events":{},"_eventsCount":0,"inputClusters":[],"outputClusters":[],"ID":242,"clusters":{},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}}],"_ieeeAddr":"0x04cf8cdf3c7c252d","_interviewState":"IN_PROGRESS","_lastSeen":1759309204059,"_manufacturerID":4447,"_networkAddress":55739,"_type":"Router","_linkquality":51,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01","manufacturerName":"LUMI"}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},"data":{"manufacturerName":"LUMI"},"linkquality":51,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,202,1,4,0,0,66,4,76,85,77,73]},"zclTransactionSequenceNumber":202,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
                                    zigbee.0
                                    2025-10-01 11:00:04.012	warn	Device 0x04cf8cdf3c7c252d "ZNCZ04LM" not found.
                                    zigbee.0
                                    2025-10-01 11:00:04.008	info	message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"ID":185,"_endpoints":[{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01"}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},{"_events":{},"_eventsCount":0,"inputClusters":[],"outputClusters":[],"ID":242,"clusters":{},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}}],"_ieeeAddr":"0x04cf8cdf3c7c252d","_interviewState":"IN_PROGRESS","_lastSeen":1759309204008,"_manufacturerID":4447,"_networkAddress":55739,"_type":"Router","_linkquality":47,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"deviceID":81,"inputClusters":[0,2,3,4,5,6,64704],"outputClusters":[10,25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.plug.mmeu01"}}},"deviceIeeeAddress":"0x04cf8cdf3c7c252d","deviceNetworkAddress":55739,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x04cf8cdf3c7c252d"}},"data":{"modelId":"lumi.plug.mmeu01"},"linkquality":47,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,201,1,5,0,0,66,16,108,117,109,105,46,112,108,117,103,46,109,109,101,117,48,49]},"zclTransactionSequenceNumber":201,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
                                    zigbee.0
                                    2025-10-01 11:00:03.471	error	Resolve entity error: Cannot read properties of undefined (reading 'model')
                                    zigbee.0
                                    2025-10-01 11:00:03.465	warn	Resolve Entity did not manage to find a mapped device for 0x04cf8cdf3c7c252d of type undefined
                                    zigbee.0
                                    2025-10-01 11:00:02.502	error	handleDeviceInterview: Cannot read properties of undefined (reading 'name')
                                    zigbee.0
                                    2025-10-01 11:00:02.500	error	Resolve entity error: Cannot read properties of undefined (reading 'model')
                                    zigbee.0
                                    2025-10-01 11:00:02.494	warn	Resolve Entity did not manage to find a mapped device for 0x04cf8cdf3c7c252d of type undefined
                                    zigbee.0
                                    2025-10-01 10:59:36.294	info	Opening zigbee Network for 90 seconds
                                    zigbee.0
                                    2025-10-01 10:59:33.714	warn	collectingData
                                    zigbee.0
                                    2025-10-01 10:59:33.679	warn	collectingData
                                    Errors
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    Iobroker:
                                    • FabioF Fabio
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      Errors
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      #235
                                      @fabio sagte in Tester wanted - Zigbee Adapter 3.1:
                                      Du hast diese Meldungen, aber das Pairing geht durch und der Adapter läuft auch durch ?
                                      A
                                        A
                                        FabioF Offline
                                        FabioF Offline
                                        Fabio
                                        #236
                                        @asgothian ja und die Steckdose ist da und wird auch gechalten etc.
                                        Iobroker:
                                        D AsgothianA 2 Antworten Letzte Antwort
                                        • FabioF Fabio
                                          dimaiv
                                          #237
                                          @fabio
                                          Danke.
                                          @Asgothian
                                          Bei mir läuft das Pairing genau so ab, egal, Strombetrieben oder ein Batteriegerät.
                                          Bei mir gibt's auch Probleme mit "Edit"button, wo man die Name ändern kann. Was ich nicht erklären kann, bei manchen funktioniert, bei anderen nicht (innerhalb von einer Instanz). Also, reagiert gar nicht auf Mausklick.
                                          Node.js v22.21.0
                                          NPM v10.9.4
                                          JS controller 7.1.0
                                          Admin 7.7.20
