  4. Tester wanted - Zigbee Adapter 3.1
testerzhczigbeezigbee 3.1
273 Beiträge 17 Kommentatoren 35.2k Aufrufe 16 Beobachtet
  • L locito09
    @asgothian
    log ist vom Paring versuch
    Opening zigbee Network for 220 seconds
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #210
    @locito09 Frage - du schriebst der adapter bleibt dann rot. Ist das so, oder lässt sich der Adapter nach dem Pairing wieder (manuell) starten ?
    D L 2 Antworten Letzte Antwort
    • AsgothianA Asgothian
      dimaiv
      schrieb am zuletzt editiert von dimaiv
      #211
      @asgothian
      Pairing Problemme kann ich bestätigen
      Adapter Start:
      2025-09-28 14:34:15.592 - info: zigbee.0 (2695) starting. Version 3.1.5-alpha.0 (non-npm: asgothian/ioBroker.zigbee#9957ceb2c838c0b1e6b23db3b5c528dc9ef49841) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.5, js-controller: 7.0.7
      2025-09-28 14:34:15.603 - info: zigbee.0 (2695) Adapter ready - starting subsystems. Adapter is running in info mode.
      2025-09-28 14:34:15.604 - info: zigbee.0 (2695) init localConfig
      2025-09-28 14:34:15.619 - info: zigbee.0 (2695) delete old Backup files. keep only last 10
      2025-09-28 14:34:15.620 - info: zigbee.0 (2695) --- creating device debug ---
      2025-09-28 14:34:15.620 - info: zigbee.0 (2695) Autostart Zigbee subsystem
      2025-09-28 14:34:15.620 - info: zigbee.0 (2695) Starting Adapter npm ...
      2025-09-28 14:34:15.628 - info: zigbee.0 (2695) Installed Version: asgothian/ioBroker.zigbee#9957ceb2c838c0b1e6b23db3b5c528dc9ef49841 (Converters 25.31.0 Herdsman 6.1.3)
      2025-09-28 14:34:15.628 - info: zigbee.0 (2695) configured transmit power :
      2025-09-28 14:34:15.628 - info: zigbee.0 (2695) Starting Zigbee-Herdsman
      2025-09-28 14:34:16.992 - info: zigbee.0 (2695) Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20240710 (2-1.2.7.1)
      2025-09-28 14:34:16.992 - info: zigbee.0 (2695) Unable to disable LED, unsupported function.
      2025-09-28 14:34:16.993 - info: zigbee.0 (2695) No devices
      2025-09-28 14:34:16.993 - info: zigbee.0 (2695) Zigbee started
      2025-09-28 14:34:35.350 - info: admin.0 (2458) ==> Connected system.user.admin from ::ffff:192.168.2.100
      2025-09-28 14:34:35.696 - warn: zigbee.0 (2695) Error Cannot read properties of undefined (reading 'model')building device info for {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[],"outputClusters":[],"profileID":260,"ID":1,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[],"outputClusters":[],"profileID":257,"ID":2,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":2,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[],"outputClusters":[],"profileID":260,"ID":3,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":3,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[],"outputClusters":[],"profileID":263,"ID":4,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":4,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[],"outputClusters":[],"profileID":264,"ID":5,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":5,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[],"outputClusters":[],"profileID":265,"ID":6,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":6,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[],"outputClusters":[],"profileID":260,"ID":8,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":8,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[],"outputClusters":[],"profileID":260,"ID":10,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":10,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":1024,"inputClusters":[1281,10],"outputClusters":[1280,1282],"profileID":260,"ID":11,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":11,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[],"outputClusters":[],"profileID":49246,"ID":12,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":12,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[25],"outputClusters":[],"profileID":260,"ID":13,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":13,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[],"outputClusters":[],"profileID":260,"ID":47,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":47,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[],"outputClusters":[],"profileID":260,"ID":110,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":110,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[],"outputClusters":[],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0x00124b002f8b3bfd"}}],"_ieeeAddr":"0x00124b002f8b3bfd","_interviewState":"SUCCESSFUL","_manufacturerID":7,"_networkAddress":0,"_type":"Coordinator","_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":5,"inputClusters":[],"outputClusters":[],"profileID":260,"ID":1,"clusters":{},"deviceIeeeAddress":"0x00124b002f8b3bfd","deviceNetworkAddress":0,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0x00124b002f8b3bfd"}},"name":"Coordinator"}
      2025-09-28 14:34:35.696 - warn: zigbee.0 (2695) collectingData
      2025-09-28 14:34:35.773 - warn: zigbee.0 (2695) collectingData
      2025-09-28 14:34:40.999 - info: zigbee.0 (2695) Collecting Map Data
      2025-09-28 14:34:41.020 - info: zigbee.0 (2695) Map data collection complete
      Pairing:
      2025-09-28 14:39:34.978 - info: zigbee.0 (2695) Opening zigbee Network for 120 seconds
      2025-09-28 14:39:50.532 - warn: zigbee.0 (2695) Resolve Entity did not manage to find a mapped device for 0xe0798dfffe746ae6 of type undefined
      2025-09-28 14:39:50.537 - error: zigbee.0 (2695) Resolve entity error: Cannot read properties of undefined (reading 'model')
      2025-09-28 14:39:50.538 - error: zigbee.0 (2695) handleDeviceInterview: Cannot read properties of undefined (reading 'name')
      2025-09-28 14:39:50.541 - warn: zigbee.0 (2695) Resolve Entity did not manage to find a mapped device for 0xe0798dfffe746ae6 of type undefined
      2025-09-28 14:39:50.542 - error: zigbee.0 (2695) Resolve entity error: Cannot read properties of undefined (reading 'model')
      2025-09-28 14:39:50.542 - error: zigbee.0 (2695) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-09-28 14:39:50.542 - error: zigbee.0 (2695) unhandled promise rejection: Cannot read properties of undefined (reading 'name')
      2025-09-28 14:39:50.543 - error: zigbee.0 (2695) TypeError: Cannot read properties of undefined (reading 'name')
      at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:879:37)
      at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2025-09-28 14:39:50.543 - error: zigbee.0 (2695) Cannot read properties of undefined (reading 'name')
      2025-09-28 14:39:50.550 - info: zigbee.0 (2695) Halting zigbee adapter. Restart delay is at least 30 seconds.
      2025-09-28 14:39:50.550 - info: zigbee.0 (2695) cleaning everything up
      2025-09-28 14:39:50.550 - info: zigbee.0 (2695) Saved local configuration data
      2025-09-28 14:39:50.550 - info: zigbee.0 (2695) cleanup successful
      2025-09-28 14:39:50.551 - info: zigbee.0 (2695) terminating
      2025-09-28 14:39:50.551 - warn: zigbee.0 (2695) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-09-28 14:39:50.551 - info: zigbee.0 (2695) zigbecontroller stopped successfully - ZH was not running
      2025-09-28 14:39:50.551 - warn: zigbee.0 (2695) Resolve Entity did not manage to find a mapped device for 0xe0798dfffe746ae6 of type undefined
      2025-09-28 14:39:50.551 - error: zigbee.0 (2695) Resolve entity error: Cannot read properties of undefined (reading 'model')
      2025-09-28 14:39:50.671 - info: zigbee.0 (2695) message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"inputClusters":[],"outputClusters":[],"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"TS0505A","manufacturerName":"_TZ3000_riwp3k79"}}},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":33944,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0xe0798dfffe746ae6"}}],"_ieeeAddr":"0xe0798dfffe746ae6","_interviewState":"IN_PROGRESS","_lastSeen":1759063190667,"_manufacturerID":4098,"_networkAddress":33944,"_type":"Router","_linkquality":40,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"_maxListeners":100,"inputClusters":[],"outputClusters":[],"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"TS0505A","manufacturerName":"_TZ3000_riwp3k79"}}},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":33944,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0xe0798dfffe746ae6"}},"data":{"modelId":"TS0505A","manufacturerName":"_TZ3000_riwp3k79"},"linkquality":40,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,1,1,5,0,0,66,7,84,83,48,53,48,53,65,4,0,0,66,16,95,84,90,51,48,48,48,95,114,105,119,112,51,107,55,57]},"zclTransactionSequenceNumber":1,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
      2025-09-28 14:39:50.674 - warn: zigbee.0 (2695) Device 0xe0798dfffe746ae6 "HG06104A" not found.
      2025-09-28 14:39:50.681 - info: zigbee.0 (2695) debug devices set to []
      2025-09-28 14:39:51.064 - error: host.Test-IoBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2025-09-28 14:39:51.064 - error: host.Test-IoBroker Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'name')
      2025-09-28 14:39:51.064 - error: host.Test-IoBroker Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:879:37)
      2025-09-28 14:39:51.064 - error: host.Test-IoBroker Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2025-09-28 14:39:51.064 - error: host.Test-IoBroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-09-28 14:39:51.064 - info: host.Test-IoBroker Restart adapter system.adapter.zigbee.0 because enabled
      Automatischer Restart:
      2025-09-28 14:40:21.282 - info: host.Test-IoBroker instance system.adapter.zigbee.0 in version "3.1.5-alpha.0" (non-npm: asgothian/ioBroker.zigbee#9957ceb2c838c0b1e6b23db3b5c528dc9ef49841) started with pid 2711
      2025-09-28 14:40:21.885 - info: zigbee.0 (2711) starting. Version 3.1.5-alpha.0 (non-npm: asgothian/ioBroker.zigbee#9957ceb2c838c0b1e6b23db3b5c528dc9ef49841) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.5, js-controller: 7.0.7
      2025-09-28 14:40:21.893 - info: zigbee.0 (2711) Adapter ready - starting subsystems. Adapter is running in info mode.
      2025-09-28 14:40:21.893 - info: zigbee.0 (2711) init localConfig
      2025-09-28 14:40:21.908 - info: zigbee.0 (2711) delete old Backup files. keep only last 10
      2025-09-28 14:40:21.909 - info: zigbee.0 (2711) --- creating device debug ---
      2025-09-28 14:40:21.909 - info: zigbee.0 (2711) Autostart Zigbee subsystem
      2025-09-28 14:40:21.910 - info: zigbee.0 (2711) Starting Adapter npm ...
      2025-09-28 14:40:21.916 - info: zigbee.0 (2711) Installed Version: asgothian/ioBroker.zigbee#9957ceb2c838c0b1e6b23db3b5c528dc9ef49841 (Converters 25.31.0 Herdsman 6.1.3)
      2025-09-28 14:40:21.917 - info: zigbee.0 (2711) configured transmit power :
      2025-09-28 14:40:21.917 - info: zigbee.0 (2711) Starting Zigbee-Herdsman
      2025-09-28 14:40:23.277 - info: zigbee.0 (2711) Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20240710 (2-1.2.7.1)
      2025-09-28 14:40:23.277 - info: zigbee.0 (2711) Unable to disable LED, unsupported function.
      2025-09-28 14:40:23.321 - warn: zigbee.0 (2711) Resolve Entity did not manage to find a mapped device for 0xe0798dfffe746ae6 of type undefined
      2025-09-28 14:40:23.325 - error: zigbee.0 (2711) Resolve entity error: Cannot read properties of undefined (reading 'model')
      2025-09-28 14:40:23.325 - info: zigbee.0 (2711) 1 devices are part of the network
      2025-09-28 14:40:23.325 - info: zigbee.0 (2711) Zigbee started
      2025-09-28 14:40:23.326 - warn: zigbee.0 (2711) Resolve Entity did not manage to find a mapped device for 0xe0798dfffe746ae6 of type undefined
      2025-09-28 14:40:23.327 - error: zigbee.0 (2711) Resolve entity error: Cannot read properties of undefined (reading 'model')
      2025-09-28 14:40:23.327 - error: zigbee.0 (2711) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-09-28 14:40:23.327 - error: zigbee.0 (2711) unhandled promise rejection: Cannot read properties of undefined (reading 'options')
      2025-09-28 14:40:23.328 - error: zigbee.0 (2711) TypeError: Cannot read properties of undefined (reading 'options')
      at DeviceEvent.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:15:77)
      at async Promise.all (index 2)
      2025-09-28 14:40:23.328 - error: zigbee.0 (2711) Cannot read properties of undefined (reading 'options')
      2025-09-28 14:40:23.334 - info: zigbee.0 (2711) Halting zigbee adapter. Restart delay is at least 30 seconds.
      2025-09-28 14:40:23.334 - info: zigbee.0 (2711) cleaning everything up
      2025-09-28 14:40:23.335 - info: zigbee.0 (2711) Saved local configuration data
      2025-09-28 14:40:23.335 - info: zigbee.0 (2711) cleanup successful
      2025-09-28 14:40:23.335 - info: zigbee.0 (2711) terminating
      2025-09-28 14:40:23.335 - warn: zigbee.0 (2711) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-09-28 14:40:23.335 - info: zigbee.0 (2711) zigbecontroller stopped successfully - ZH was not running
      2025-09-28 14:40:23.335 - warn: zigbee.0 (2711) Resolve Entity did not manage to find a mapped device for 0xe0798dfffe746ae6 of type undefined
      2025-09-28 14:40:23.336 - error: zigbee.0 (2711) Resolve entity error: Cannot read properties of undefined (reading 'model')
      2025-09-28 14:40:23.420 - warn: zigbee.0 (2711) Resolve Entity did not manage to find a mapped device for 0xe0798dfffe746ae6 of type undefined
      2025-09-28 14:40:23.421 - error: zigbee.0 (2711) Resolve entity error: Cannot read properties of undefined (reading 'model')
      2025-09-28 14:40:23.421 - warn: zigbee.0 (2711) resolveEntity returned no entity
      2025-09-28 14:40:23.848 - error: host.Test-IoBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2025-09-28 14:40:23.848 - error: host.Test-IoBroker Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'options')
      2025-09-28 14:40:23.848 - error: host.Test-IoBroker Caught by controller[1]: at DeviceEvent.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:15:77)
      2025-09-28 14:40:23.848 - error: host.Test-IoBroker Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2025-09-28 14:40:23.848 - error: host.Test-IoBroker Caught by controller[1]: at async Promise.all (index 2)
      2025-09-28 14:40:23.848 - error: host.Test-IoBroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-09-28 14:40:23.848 - info: host.Test-IoBroker Restart adapter system.adapter.zigbee.0 because enabled
      2025-09-28 14:40:37.031 - info: host.Test-IoBroker "system.adapter.zigbee.0" disabled
      2025-09-28 14:40:54.655 - error: zigbee.0 (2726) adapter disabled
      2025-09-28 14:40:54.658 - warn: zigbee.0 (2726) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
      2025-09-28 14:40:55.173 - error: host.Test-IoBroker instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
      2025-09-28 14:40:55.173 - info: host.Test-IoBroker Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
      Anschließend Stop von mir, weil es widerholt sich immer wieder.
      Folgende Gerät wurde versucht:
      LED von Lidl Lampe
      Dann muss man auf 3.1.2 gehen, damit der Adapter überhaupt startet. Da kann man dann einen undefined Gerät sehen und entfernen oder neu pairen.
      ioBroker- NUC8i3 / Proxmox / VM
      Node.js v22.21.0
      NPM v10.9.4
      JS controller 7.1.0
      Admin 7.7.20
      ZigBee Adapter 3.3.1alpha.0
      Zigbee LAN Gateway CC2652P
      Zigbee Firmware 20250321
      • D dimaiv
        @asgothian
        Adapter Start:
        Pairing:
        LED von Lidl Lampe
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #212
        @dimaiv sagte in Tester wanted - Zigbee Adapter 3.1:
        Bitte von hier installieren : https://github.com/asgothian/ioBroker.zigbee - schauen ob das das Problem löst. Scheint eine Race-Condition zu sein - auf meinem System tritt der Fehler auch ohne die Anpassung nicht auf.
          dimaiv
          #213
          @asgothian
          es geht jetzt :
          2025-09-28 15:36:49.005 - info: zigbee.0 (3153) Opening zigbee Network for 120 seconds
          2025-09-28 15:36:50.467 - info: zigbee.0 (3153) Starting interview of '0xe0798dfffe746ae6'
          2025-09-28 15:36:55.863 - warn: zigbee.0 (3153) Device '0xe0798dfffe746ae6' announced itself, trying to read its status
          2025-09-28 15:36:55.863 - info: zigbee.0 (3153) ignoring device announcement for TS0505A due to interview state IN_PROGRESS
          2025-09-28 15:37:17.171 - info: zigbee.0 (3153) message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":269,"inputClusters":[0,3,4,5,6,8,768,4096],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"TS0505A","manufacturerName":"_TZ3000_riwp3k79"}}},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":29470,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0xe0798dfffe746ae6"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":29470,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0xe0798dfffe746ae6"}}],"_ieeeAddr":"0xe0798dfffe746ae6","_interviewState":"IN_PROGRESS","_lastSeen":1759066637171,"_manufacturerID":4098,"_networkAddress":29470,"_type":"Router","_linkquality":65,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":269,"inputClusters":[0,3,4,5,6,8,768,4096],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"TS0505A","manufacturerName":"_TZ3000_riwp3k79"}}},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":29470,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0xe0798dfffe746ae6"}},"data":{"modelId":"TS0505A","manufacturerName":"_TZ3000_riwp3k79"},"linkquality":65,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,2,1,5,0,0,66,7,84,83,48,53,48,53,65,4,0,0,66,16,95,84,90,51,48,48,48,95,114,105,119,112,51,107,55,57]},"zclTransactionSequenceNumber":2,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
          2025-09-28 15:37:17.448 - info: zigbee.0 (3153) message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":269,"inputClusters":[0,3,4,5,6,8,768,4096],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"TS0505A","manufacturerName":"_TZ3000_riwp3k79","stackVersion":0}}},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":29470,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0xe0798dfffe746ae6"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":29470,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0xe0798dfffe746ae6"}}],"_ieeeAddr":"0xe0798dfffe746ae6","_interviewState":"IN_PROGRESS","_lastSeen":1759066637448,"_manufacturerID":4098,"_networkAddress":29470,"_type":"Router","_linkquality":65,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":269,"inputClusters":[0,3,4,5,6,8,768,4096],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"TS0505A","manufacturerName":"_TZ3000_riwp3k79","stackVersion":0}}},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":29470,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0xe0798dfffe746ae6"}},"data":{"stackVersion":0},"linkquality":65,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,3,1,2,0,0,32,0]},"zclTransactionSequenceNumber":3,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
          2025-09-28 15:37:17.546 - info: zigbee.0 (3153) message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":269,"inputClusters":[0,3,4,5,6,8,768,4096],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"TS0505A","manufacturerName":"_TZ3000_riwp3k79","stackVersion":0,"dateCode":""}}},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":29470,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0xe0798dfffe746ae6"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":29470,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0xe0798dfffe746ae6"}}],"_ieeeAddr":"0xe0798dfffe746ae6","_interviewState":"IN_PROGRESS","_lastSeen":1759066637546,"_manufacturerID":4098,"_networkAddress":29470,"_type":"Router","_linkquality":65,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":269,"inputClusters":[0,3,4,5,6,8,768,4096],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"TS0505A","manufacturerName":"_TZ3000_riwp3k79","stackVersion":0,"dateCode":""}}},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":29470,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0xe0798dfffe746ae6"}},"data":{"dateCode":""},"linkquality":65,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,4,1,6,0,0,66,0]},"zclTransactionSequenceNumber":4,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
          2025-09-28 15:37:17.639 - info: zigbee.0 (3153) message {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":269,"inputClusters":[0,3,4,5,6,8,768,4096],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"TS0505A","manufacturerName":"_TZ3000_riwp3k79","stackVersion":0,"dateCode":""}}},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":29470,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0xe0798dfffe746ae6"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":29470,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":242,"deviceIeeeAddress":"0xe0798dfffe746ae6"}}],"_ieeeAddr":"0xe0798dfffe746ae6","_interviewState":"IN_PROGRESS","_lastSeen":1759066637639,"_manufacturerID":4098,"_networkAddress":29470,"_type":"Router","_linkquality":61,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"endpoint":{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":269,"inputClusters":[0,3,4,5,6,8,768,4096],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"TS0505A","manufacturerName":"_TZ3000_riwp3k79","stackVersion":0,"dateCode":""}}},"deviceIeeeAddress":"0xe0798dfffe746ae6","deviceNetworkAddress":29470,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"id":1,"deviceIeeeAddress":"0xe0798dfffe746ae6"}},"data":{},"linkquality":61,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,5,1,0,64,134]},"zclTransactionSequenceNumber":5,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}} received during interview.
          2025-09-28 15:37:17.782 - info: zigbee.0 (3153) Successfully interviewed '0xe0798dfffe746ae6', device has successfully been paired
          2025-09-28 15:37:17.783 - info: zigbee.0 (3153) Device '0xe0798dfffe746ae6' is supported, identified as: Lidl Livarno Home RGB+CCT LED light strip 2m (HG06104A)
          2025-09-28 15:37:22.784 - info: zigbee.0 (3153) DeviceConfigureQueue configuring 0xe0798dfffe746ae6 TS0505A
          2025-09-28 15:37:22.784 - info: zigbee.0 (3153) Configuring 0xe0798dfffe746ae6 HG06104A
          2025-09-28 15:37:22.901 - info: zigbee.0 (3153) DeviceConfigure successful 0xe0798dfffe746ae6 HG06104A
          aber wird als idefined angezeigt :
          Violett markiert sieht auch nicht so richtig aus, seit 3.1.5
          Node.js v22.21.0
          NPM v10.9.4
          JS controller 7.1.0
          Admin 7.7.20
          • D dimaiv
            @asgothian
            es geht jetzt :
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #214
            das Undefined kann ein Überbleibsel aus dem unerfolgreichen Versuch es anzumelden sein.
            Loesung dafuer:
            Den Dialog zum 'Namen anpassen' öffnen, den vorgegebenen Namen löschen, nichts eintragen, abspeichern, Fettich.
            Die Positionierung auf der Kachel kommt immer mal wieder vor - hat etwas mit dem Browser zoom zu tun. Mach den mal etwas kleiner oder etwas grósser, dann sollte das wieder passen.
            Da habe ich bisher keine saubere Lósung für gefunden.
            A.
              MeisterQ 0
              schrieb am zuletzt editiert von MeisterQ 0
              #215
              @Asgothian ich hab dir auch mal im Discord geschrieben.
              3.1.4 Stürzt beim Starten schon ab. Downgrade auf 3.1.2 führt auch zu Problemen. Von deiner URL installieren ging auch nicht. Gab direkt beim Installieren Errors.
              $ iobroker url https://github.com/asgothian/ioBroker.zigbee --host iobroker --debug
              install asgothian/ioBroker.zigbee#dfadb41370017028ebb9def5cd8eadae1b1815ac
              NPM version: 10.8.2
              Installing asgothian/ioBroker.zigbee#dfadb41370017028ebb9def5cd8eadae1b1815ac... (System call)
              npm error code ETIMEDOUT
              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-28T15_20_44_636Z-debug-0.log
              npm error code ETIMEDOUTnpm error syscall readnpm error errno -110npm error network read ETIMEDOUTnpm error network This is a problem related to network connectivity.npm error network In most cases you are behind a proxy or have bad network settings.npm error networknpm error network If you are behind a proxy, please make sure that thenpm error network 'proxy' config is set properly. See: 'npm help config'npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-28T15_20_44_636Z-debug-0.log
              host.iobroker Cannot install asgothian/ioBroker.zigbee#dfadb41370017028ebb9def5cd8eadae1b1815ac: 146
              ERROR: Process exited with code 25
                Loesung dafuer:
                A.
                dimaiv
                #216
                @asgothian sagte in Tester wanted - Zigbee Adapter 3.1:
                Loesung dafuer:
                Unter 3.1.5 alpha.0 funktioniert es nicht, ich kann keine Namen ändern, ich kann nich die optionen hinzufügen oder löschen, also, da wird nix geschpeichert. Unter 3.1.4 funktioniert es wie beschrieben.
                Es hat mehrere Jahre gut funktioniert unter egal welchem Browser, und erst ab 3.1.5 muss man mit zoom spielen.
                A.
                Node.js v22.21.0
                NPM v10.9.4
                JS controller 7.1.0
                Admin 7.7.20
                • M MeisterQ 0
                  NPM version: 10.8.2
                  #217
                  @meisterq-0 sagte in Tester wanted - Zigbee Adapter 3.1:
                  npm error network If you are behind a proxy, please make sure that the 'proxy' config is set properly. See: 'npm help config'npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-28T15_20_44_636Z-debug-0.log
                    MeisterQ 0
                    #218
                    @Homoran
                    Mein Netzwerk läuft seit Wochen Stabil. Keine Errors, keine Veränderung. Von der URL hab ich schon öfter installiert.
                    Nach 5 Versuchen ging es nun endlich.
                    Aber trotzdem hat 3.1.5 die selbe Problematik wie 3.1.4. Ich bekomme den Adapter nur mit 3.1.2 zum laufen.
                    zigbee.0
                    	2025-09-28 17:38:03.704	error	Resolve entity error: Cannot read properties of undefined (reading 'model')
                    zigbee.0
                    	2025-09-28 17:38:03.703	warn	Resolve Entity did not manage to find a mapped device for 0xd44867fffe5b4c36 of type undefined
                    zigbee.0
                    	2025-09-28 17:38:03.692	info	zigbecontroller stopped successfully - ZH was not running
                    zigbee.0
                    	2025-09-28 17:38:03.689	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    zigbee.0
                    	2025-09-28 17:38:03.689	info	terminating
                    zigbee.0
                    	2025-09-28 17:38:03.689	info	cleanup successful
                    zigbee.0
                    	2025-09-28 17:38:03.688	info	Saved local configuration data
                    zigbee.0
                    	2025-09-28 17:38:03.687	info	cleaning everything up
                    zigbee.0
                    	2025-09-28 17:38:03.687	info	Halting zigbee adapter. Restart delay is at least 30 seconds.
                    zigbee.0
                    	2025-09-28 17:38:03.671	error	Cannot read properties of undefined (reading 'options')
                    zigbee.0
                    	2025-09-28 17:38:03.671	error	TypeError: Cannot read properties of undefined (reading 'options') at DeviceEvent.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:15:77) at processTicksAndRejections (node:internal/process/task_queues:95:5) at async Promise.all (index 2)
                    zigbee.0
                    	2025-09-28 17:38:03.671	error	unhandled promise rejection: Cannot read properties of undefined (reading 'options')
                    zigbee.0
                    	2025-09-28 17:38:03.671	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    zigbee.0
                    	2025-09-28 17:38:03.670	error	Resolve entity error: Cannot read properties of undefined (reading 'model')
                    zigbee.0
                    	2025-09-28 17:38:03.669	warn	Resolve Entity did not manage to find a mapped device for 0xd44867fffe5b4c36 of type undefined
                    zigbee.0
                    	2025-09-28 17:38:03.668	warn	DeviceEvent:calling onEvent for start on 0x0c4314fffe7a483d
                    zigbee.0
                    	2025-09-28 17:38:03.668	warn	DeviceEvent:calling onEvent for start on 0x588e81fffe3bc8a1
                    zigbee.0
                    	2025-09-28 17:38:03.666	warn	DeviceEvent:calling onEvent for start on 0xec1bbdfffe8eb47e
                    zigbee.0
                    	2025-09-28 17:38:03.665	warn	DeviceEvent:calling onEvent for start on 0x0cae5ffffeb46866
                    zigbee.0
                    	2025-09-28 17:38:03.664	warn	DeviceEvent:calling onEvent for start on 0x54ef441000c283e9
                    zigbee.0
                    	2025-09-28 17:38:03.664	warn	DeviceEvent:calling onEvent for start on 0x54ef441000c28823
                    zigbee.0
                    	2025-09-28 17:38:03.663	warn	DeviceEvent:calling onEvent for start on 0x282c02bfffed9110
                    zigbee.0
                    	2025-09-28 17:38:03.658	warn	DeviceEvent:calling onEvent for start on 0x282c02bfffed9354
                    zigbee.0
                    	2025-09-28 17:38:03.658	warn	DeviceEvent:calling onEvent for start on 0x000d6ffffe8e73b3
                    zigbee.0
                    	2025-09-28 17:38:03.657	warn	DeviceEvent:calling onEvent for start on 0x0cae5ffffeb4560f
                    zigbee.0
                    	2025-09-28 17:38:03.651	error	Resolve entity error: Cannot read properties of undefined (reading 'model')
                    zigbee.0
                    	2025-09-28 17:38:03.649	warn	Resolve Entity did not manage to find a mapped device for 0xd44867fffe5b4c36 of type undefined
                    zigbee.0
                    	2025-09-28 17:38:03.636	info	Zigbee started
                    zigbee.0
                    	2025-09-28 17:38:03.635	info	46 devices are part of the network
                    zigbee.0
                    	2025-09-28 17:38:03.635	error	Resolve entity error: Cannot read properties of undefined (reading 'model')
                    zigbee.0
                    	2025-09-28 17:38:03.628	warn	Resolve Entity did not manage to find a mapped device for 0xd44867fffe5b4c36 of type undefined
                    • M MeisterQ 0
                      @Homoran
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      #219
                      Aber jetzt gibt's anscheinend zeitweise Probleme!
                        MeisterQ 0
                        #220
                        @homoran Danke für die Information. Die Probleme mit dem Adapter sind aktuell wichtiger :)
                        • D dimaiv
                          Loesung dafuer:
                          A.
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #221
                          Das ist nicht Korrekt - das Problem gibt es seit diesem PR - Es betrifft nur bestimmte Installationen, Fenstergrössen, Browserfenster und OS Kombinationen. Offensichtlich ist die Berechnung beim Rendering betroffen.
                          A.
                          Nachtrag - bitte nochmal vom oben angegebenen Link installieren. Damit sollte auch das Rendering besser sein.
                          ABER: Keine Garantie das das Problem weg ist - ich hab nur begrenzt testen können. Interessanter ist für mich:
                          • lassen sich mit der Version Geräte anlernen / ablernen ? (Stabil - bei mir geht es)
                          • lassen sich die Geräte wieder anlernen (auch das geht bei mir ohne Probleme)
                          • lassen sich Geräte die das System nicht kennt neu anlernen (nicht kennen = nach Neustart des Adapters hat der Adapter keines der Geräte - dann anlernen. Genau das war die Situation wo der Fehler aufgetreten ist)
                          • lassen sich die Optionen bei Geräten einstellen (die Optionen sind vom Edit Group zu Select Image gewechselt - der Dialog wurde zu voll
                          • lassen sich Geräte zu Gruppen hinzufügen (das geht bei mir auch)
                          A.
                            locito09
                            #222
                            @asgothian
                            Bleibt rot
                            • L locito09
                              @asgothian
                              Bleibt rot
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #223
                              @locito09 sagte in Tester wanted - Zigbee Adapter 3.1:
                              @asgothian
                              Bleibt rot
                              hast du die neue Version installiert ?
                              Die richtige hat die Versionsnummer 3.1.5-alpha.1
                              A.
                              AsgothianA L 2 Antworten Letzte Antwort
                                @asgothian
                                Bleibt rot
                                A.
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #224
                                Ich hab auf dem ioBroker GitHub nochmal eine Version hoch geladen. Dabei sind noch 3 aktive Bugs aufgefallen:
                                • Die Netzwerkkarte geht nur bei 'kleinen' Netzen. Bei grossen Netzen wird der Bereich in dem sie dargestellt werden kann sehr klein (noch nicht klar warum)
                                • Beim hinzufügen und löschen von Geräten aus Gruppen gibt es Anzeige-Probleme. Hinzufügen geht aktuell nur über die Gerätekachel, Löschen aus der Gruppe nur über die Gruppenkachel
                                • Es gibt immer noch warn Meldungen zum Koordinator.
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  #225
                                  um bei den Events weiter zu kommen brauche ich Informationen dazu welche Gerätetypen für detail-Tests ggf. verfügbar sind. Deswegen melden die 3.1.x-alpha Versionen beim Start
                                  Ich wäre Dankbar für eine Liste von Gerätetypen (idealerweise mit zigbee2mqtt Link für die entsprechenden Geräte. Dann kann ich mir die Konverter anschauen und ggf. dedizierte Tests anfragen um bei der Umsetzung der Optionen von Z2M vorwärts zu kommen.
                                  Mein Problem ist das ich kaum eigene Geräte habe die diese Funktion nutzen.
                                  A.
                                  D 2 Antworten Letzte Antwort
                                    A.
                                    dimaiv
                                    #226
                                    @asgothian
                                    Optionen sind weg:
                                    adapter:3.1.5-alpha.1
                                    installed from:ioBroker/ioBroker.zigbee
                                    ZHC / ZH:25.31.0 / 6.1.3
                                    P.S.: Dafür aber Zoom/Skalieren besser geworden.
                                    Node.js v22.21.0
                                    NPM v10.9.4
                                    JS controller 7.1.0
                                    Admin 7.7.20
                                    • D dimaiv
                                      @asgothian
                                      Optionen sind weg:
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      #227
                                      Optionen sind weg:
                                      Nein, die Optionen sind gewandert auf den Dialog wo auch das Gerätebild ausgewählt werden soll.
                                      A.
                                        @asgothian
                                        Bleibt rot
                                        A.
                                        locito09
                                        #228
                                        @asgothian
                                        Mit dieser version geht es
                                        -1
                                        • L locito09
                                          @asgothian
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          #229
                                          @asgothian
                                          Was ist "es" ? Ein Monster ? Ein Eintrag aus dieser Liste (in-Forum Link) ? Das eine Gerät welches nicht ging ?
                                          A.
