lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 9.0m Aufrufe 260 Beobachtet
  • ArmilarA
    ArmilarA
    Armilar
    Most Active Forum Testing
    #7571
    @australien
    und mit Adv0?
    • ArmilarA Armilar
      @australien
      und mit Adv0?
      A
      A
      australien
      #7572
      @armilar
      das gleiche, hab übrigens gesehen die Fehlermeldung ist doch da.
      00:00:00.001 HDW: ESP32-D0WD-V3 v3.0
      00:00:00.017 UFS: FlashFS mounted with 288 kB free
      00:00:00.026 CFG: Loaded from File, Anzahl 1518
      00:00:00.035 QPC: Count 1
      00:00:00.035 CFG: CR 430/699, Busy 0
      00:00:00.041 TYA: Active=0
      00:00:00.045 ROT: Mode 1
      00:00:00.069 CFG: No '*.autoconf' file found
      00:00:00.073 BRY: Berry initialized, RAM used 3493 bytes
      00:00:00.079 BRY: No 'preinit.be'
      00:00:00.081 SRC: Restart
      00:00:00.085 Projekt tasmota - Tasmota Version 15.0.1(release-tasmota32)-3_1_3(2025.06.14 10:39:16)
      00:00:00.218 NXP: Initializing Driver
      00:00:00.220 BRY: Serial UART2
      00:00:00.223 BRY: Successfully loaded 'autoexec.be'
      00:00:00.310 WIF: Verbindungsversuch…
      00:00:00.948 WIF: verbinden mit AP1 FR@smart Channel 9 BSSId 7E:8A:20:51:6B:CA in Modus HT40 als NSPanel-1-5140...
      00:00:01.077 WIF: IPv4 10.68.0.179, mask 255.255.0.0, gateway 10.68.0.1
      00:00:03.476 WIF: IPv6 Local fe80::e2e2:e6ff:fe0c:1414%st1
      00:00:03.498 WIF: verbunden
      00:00:03.755 HTP: Web server active on NSPanel-1-5140 with IP address 10.68.0.179
      00:00:04.004 RTC: UTC 2025-09-12T14:50:15Z, DST 2025-03-30T02:00:00, STD 2025-10-26T03:00:00
      15:50:15.000 RTC: Synced by NTP
      15:50:15.745 MQT: Verbindungsversuch…
      15:50:15.761 MQT: verbunden
      15:50:15.764 MQT: SmartHome/NSPanel_1/tele/LWT = Online (beibehalten)
      15:50:15.765 MQT: SmartHome/NSPanel_1/cmnd/POWER =
      15:50:15.766 MQT: abonniere SmartHome/NSPanel_1/cmnd/#
      15:50:15.767 MQT: abonniere SmartHome/tasmotas/cmnd/#
      15:50:15.768 MQT: abonniere cmnd/NSPanel_1_fb/#
      15:50:15.770 MQT: SmartHome/NSPanel_1/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"15.0.1(release-tasmota32)","FallbackTopic":"cmnd/NSPanel_1_fb/","GroupTopic":"SmartHome/tasmotas/cmnd/"}}
      15:50:15.784 MQT: SmartHome/NSPanel_1/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-1-5140","IPAddress":"10.68.0.179","IP6Global":"","IP6Local":"fe80::e2e2:e6ff:fe0c:1414%st1"}}
      15:50:15.809 MQT: SmartHome/NSPanel_1/tele/INFO3 = {"Info3":{"RestartReason":"Vbat power on reset","BootCount":172}}
      15:50:15.813 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
      15:50:15.824 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
      15:50:15.826 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER2":"OFF"}
      15:50:15.827 MQT: SmartHome/NSPanel_1/stat/POWER2 = OFF
      15:50:16.050 SRC: MQTT
      15:50:16.050 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
      15:50:16.061 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
      15:50:16.065 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
      15:50:16.097 SRC: MQTT
      15:50:16.098 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
      15:50:16.100 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
      15:50:16.101 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
      15:50:16.148 SRC: MQTT
      15:50:16.149 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
      15:50:16.159 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
      15:50:16.163 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
      15:50:16.198 SRC: MQTT
      15:50:16.198 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
      15:50:16.202 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
      15:50:16.205 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
      15:50:16.248 SRC: MQTT
      15:50:16.249 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
      15:50:16.259 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
      15:50:16.263 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
      15:50:16.298 SRC: MQTT
      15:50:16.298 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
      15:50:16.302 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
      15:50:16.305 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
      15:50:17.799 SRC: MQTT
      15:50:17.800 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
      15:50:17.813 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
      15:50:17.817 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
      15:50:17.849 SRC: MQTT
      15:50:17.850 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
      15:50:17.852 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
      15:50:17.853 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
      15:50:17.956 QPC: Reset
      15:50:19.949 APP: Startvorgänge 172
      15:50:19.956 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2025-09-12T15:50:19","Uptime":"0T00:00:09","UptimeSec":9,"Heap":146,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":237,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":212},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FR@smart","BSSId":"7E:8A:20:51:6B:CA","Channel":9,"Mode":"HT40","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:04"}}
      15:50:20.001 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2025-09-12T15:50:19","ANALOG":{"Temperature1":28.5},"ESP32":{"Temperature":58.9},"TempUnit":"C"}
      15:50:20.424 CFG: Saved, Anzahl 1519, Bytes 4096
      15:50:20.441 CMD: FlashNextionAdv0 http://nspanel.de/nspanel-v5.0.0.tft
      15:50:20.442 SRC: WebConsole from 10.68.0.156
      15:50:20.442 CMD: Grp 0, Cmd 'FLASHNEXTIONADV', Idx 0, Len 36, Pld -99, Data 'http://nspanel.de/nspanel-v5.0.0.tft'
      15:50:20.449 MQT: SmartHome/NSPanel_1/stat/RESULT = {"FlashNextionAdv":"Done"}
      15:50:20.482 FLH: host: nspanel.de, port: 80, get: /nspanel-v5.0.0.tft
      15:50:20.539 FLH: Connected:true
      15:50:20.641 FLH: Retry 2
      15:50:20.854 FLH: HTTP Respose is 200 OK or 206 Partial Content
      15:50:20.855 FLH: Flash file size: 12197684
      15:50:20.856 SRC: Berry
      15:50:20.857 CMD: Grp 0, Cmd 'RULETIMER', Idx 3, Len 1, Pld 0, Data '0'
      15:50:20.863 MQT: SmartHome/NSPanel_1/stat/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
      15:50:20.868 SRC: Berry
      15:50:20.869 CMD: Grp 0, Cmd 'RULE', Idx 3, Len 1, Pld 0, Data '0'
      15:50:20.873 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
      15:50:20.888 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
      15:50:20.892 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
      15:50:20.894 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
      15:50:20.900 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
      15:50:22.280 FLH: Send (High Speed) flash start
      15:50:22.286 NXP: Nextion command sent = bytes('77686D692D777269732031323139373638342C3932313630302C72657330FFFF...')
      15:50:22.309 BRY: Serial UART2
      15:50:22.666 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "0", "time_elapsed": 0}}
      15:50:22.759 FLH: Read block - Writing: 4096 - Total: 4096 - Buffer size: 1395
      15:50:22.859 FLH: Waiting offset...
      15:50:27.659 FLH: Flash offset marker 0
      15:50:27.760 FLH: Read block - Writing: 4096 - Total: 8192 - Buffer size: 1395
      15:50:27.958 FLH: Read block - Writing: 4096 - Total: 12288 - Buffer size: 1395
      15:50:28.090 FLH: Read block - Writing: 4096 - Total: 16384 - Buffer size: 1395
      15:50:28.200 FLH: Read block - Writing: 4096 - Total: 20480 - Buffer size: 1395
      15:50:28.314 FLH: Read block - Writing: 4096 - Total: 24576 - Buffer size: 1395
      15:50:28.426 FLH: Read block - Writing: 4096 - Total: 28672 - Buffer size: 1395
      15:50:28.533 FLH: Read block - Writing: 4096 - Total: 32768 - Buffer size: 1395
      15:50:28.642 FLH: Read block - Writing: 4096 - Total: 36864 - Buffer size: 1395
      15:50:28.751 FLH: Read block - Writing: 4096 - Total: 40960 - Buffer size: 1395
      15:50:28.859 FLH: Read block - Writing: 4096 - Total: 45056 - Buffer size: 1395
      15:50:28.971 FLH: Read block - Writing: 4096 - Total: 49152 - Buffer size: 1395
      15:50:29.080 FLH: Read block - Writing: 4096 - Total: 53248 - Buffer size: 1395
      15:50:29.189 FLH: Read block - Writing: 4096 - Total: 57344 - Buffer size: 1395
      15:50:29.301 FLH: Read block - Writing: 4096 - Total: 61440 - Buffer size: 1395
      15:50:29.409 FLH: Read block - Writing: 4096 - Total: 65536 - Buffer size: 1395
      15:50:29.522 FLH: Read block - Writing: 4096 - Total: 69632 - Buffer size: 1395
      15:50:29.858 FLH: Read block - Writing: 4096 - Total: 73728 - Buffer size: 1395
      15:50:29.968 FLH: Read block - Writing: 4096 - Total: 77824 - Buffer size: 1395
      15:50:30.158 FLH: Read block - Writing: 4096 - Total: 81920 - Buffer size: 1395
      15:50:30.273 FLH: Read block - Writing: 4096 - Total: 86016 - Buffer size: 1395
      15:50:30.456 FLH: Read block - Writing: 4096 - Total: 90112 - Buffer size: 1395
      15:51:30.657 FLH: Read block - Writing: 4096 - Total: 1478656 - Buffer size: 1395
      15:51:30.858 FLH: Read block - Writing: 4096 - Total: 1482752 - Buffer size: 1395
      15:51:31.058 FLH: Read block - Writing: 4096 - Total: 1486848 - Buffer size: 1395
      15:51:31.168 FLH: Read block - Writing: 4096 - Total: 1490944 - Buffer size: 1395
      15:51:31.280 FLH: Read block - Writing: 4096 - Total: 1495040 - Buffer size: 1395
      15:51:31.458 FLH: Read block - Writing: 4096 - Total: 1499136 - Buffer size: 1395
      15:51:31.656 FLH: Read block - Writing: 4096 - Total: 1503232 - Buffer size: 1395
      15:51:31.858 FLH: Read block - Writing: 4096 - Total: 1507328 - Buffer size: 1395
      15:51:32.058 FLH: Read block - Writing: 4096 - Total: 1511424 - Buffer size: 1395
      15:51:32.263 FLH: Read block - Writing: 4096 - Total: 1515520 - Buffer size: 1395
      15:51:32.458 FLH: Read block - Writing: 4096 - Total: 1519616 - Buffer size: 1395
      15:51:32.657 FLH: Read block - Writing: 4096 - Total: 1523712 - Buffer size: 1395
      15:51:32.858 FLH: Read block - Writing: 4096 - Total: 1527808 - Buffer size: 1395
      15:51:32.970 FLH: Read block - Writing: 4096 - Total: 1531904 - Buffer size: 1395
      15:51:33.158 FLH: Read block - Writing: 4096 - Total: 1536000 - Buffer size: 1395
      15:51:33.275 FLH: Read block - Writing: 4096 - Total: 1540096 - Buffer size: 1395
      15:51:33.457 FLH: Read block - Writing: 4096 - Total: 1544192 - Buffer size: 1395
      15:51:33.658 FLH: Read block - Writing: 4096 - Total: 1548288 - Buffer size: 1395
      15:51:33.856 FLH: Read block - Writing: 4096 - Total: 1552384 - Buffer size: 1395
      15:51:33.969 FLH: Read block - Writing: 4096 - Total: 1556480 - Buffer size: 1395
      15:51:34.157 FLH: Read block - Writing: 4096 - Total: 1560576 - Buffer size: 1395
      15:51:34.271 FLH: Read block - Writing: 4096 - Total: 1564672 - Buffer size: 1395
      15:51:34.457 FLH: Read block - Writing: 4096 - Total: 1568768 - Buffer size: 1395
      15:51:34.657 FLH: Read block - Writing: 4096 - Total: 1572864 - Buffer size: 1395
      15:51:34.857 FLH: Read block - Writing: 4096 - Total: 1576960 - Buffer size: 1395
      15:51:35.058 FLH: Read block - Writing: 4096 - Total: 1581056 - Buffer size: 1395
      15:51:35.264 FLH: Read block - Writing: 4096 - Total: 1585152 - Buffer size: 1395
      15:51:35.456 FLH: Read block - Writing: 4096 - Total: 1589248 - Buffer size: 1395
      15:51:35.571 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "13", "time_elapsed": 73}}
      15:51:35.664 FLH: Read block - Writing: 4096 - Total: 1593344 - Buffer size: 1395
      15:51:35.858 FLH: Read block - Writing: 4096 - Total: 1597440 - Buffer size: 1395
      15:51:35.968 FLH: Read block - Writing: 4096 - Total: 1601536 - Buffer size: 1395
      15:51:36.158 FLH: Read block - Writing: 4096 - Total: 1605632 - Buffer size: 1395
      15:51:36.273 FLH: Read block - Writing: 4096 - Total: 1609728 - Buffer size: 1395
      15:51:36.456 FLH: Read block - Writing: 4096 - Total: 1613824 - Buffer size: 1395
      15:51:36.658 FLH: Read block - Writing: 4096 - Total: 1617920 - Buffer size: 1395
      15:51:36.858 FLH: Read block - Writing: 4096 - Total: 1622016 - Buffer size: 1395
      15:51:36.968 FLH: Read block - Writing: 4096 - Total: 1626112 - Buffer size: 1395
      15:51:37.158 FLH: Read block - Writing: 4096 - Total: 1630208 - Buffer size: 1395
      15:51:37.273 FLH: Read block - Writing: 4096 - Total: 1634304 - Buffer size: 1395
      15:51:37.457 FLH: Read block - Writing: 4096 - Total: 1638400 - Buffer size: 1395
      15:51:37.657 FLH: Read block - Writing: 4096 - Total: 1642496 - Buffer size: 1395
      15:51:37.858 FLH: Read block - Writing: 4096 - Total: 1646592 - Buffer size: 1395
      15:51:37.969 FLH: Read block - Writing: 4096 - Total: 1650688 - Buffer size: 1395
      15:51:38.157 FLH: Read block - Writing: 4096 - Total: 1654784 - Buffer size: 1395
      15:51:38.273 FLH: Read block - Writing: 4096 - Total: 1658880 - Buffer size: 1395
      15:51:38.456 FLH: Read block - Writing: 4096 - Total: 1662976 - Buffer size: 1395
      15:51:38.657 FLH: Read block - Writing: 4096 - Total: 1667072 - Buffer size: 1395
      15:51:38.857 FLH: Read block - Writing: 4096 - Total: 1671168 - Buffer size: 1395
      15:51:38.967 FLH: Read block - Writing: 4096 - Total: 1675264 - Buffer size: 311
      15:51:39.157 FLH: Read block - Writing: 4096 - Total: 1679360 - Buffer size: 311
      15:51:39.325 FLH: Read block - Writing: 4096 - Total: 1683456 - Buffer size: 1959
      15:51:39.439 FLH: Read block - Writing: 4096 - Total: 1687552 - Buffer size: 1959
      15:51:39.558 FLH: Read block - Writing: 4096 - Total: 1691648 - Buffer size: 1959
      15:51:39.758 FLH: Read block - Writing: 4096 - Total: 1695744 - Buffer size: 1959
      15:51:39.958 FLH: Read block - Writing: 4096 - Total: 1699840 - Buffer size: 1959
      15:51:40.158 FLH: Read block - Writing: 4096 - Total: 1703936 - Buffer size: 1959
      15:51:40.272 FLH: Read block - Writing: 4096 - Total: 1708032 - Buffer size: 1959
      15:51:40.472 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "14", "time_elapsed": 78}}
      15:51:40.565 FLH: Read block - Writing: 4096 - Total: 1712128 - Buffer size: 1959
      15:51:40.758 FLH: Read block - Writing: 4096 - Total: 1716224 - Buffer size: 1959
      15:51:40.958 FLH: Read block - Writing: 4096 - Total: 1720320 - Buffer size: 1959
      15:51:41.158 FLH: Read block - Writing: 4096 - Total: 1724416 - Buffer size: 1959
      15:51:41.273 FLH: Read block - Writing: 4096 - Total: 1728512 - Buffer size: 1959
      15:51:41.458 FLH: Read block - Writing: 4096 - Total: 1732608 - Buffer size: 1959
      15:51:41.657 FLH: Read block - Writing: 4096 - Total: 1736704 - Buffer size: 1959
      15:51:41.859 FLH: Read block - Writing: 4096 - Total: 1740800 - Buffer size: 1959
      15:51:41.971 FLH: Read block - Writing: 4096 - Total: 1744896 - Buffer size: 1959
      15:51:42.158 FLH: Read block - Writing: 4096 - Total: 1748992 - Buffer size: 1959
      15:51:42.275 FLH: Read block - Writing: 4096 - Total: 1753088 - Buffer size: 1959
      15:51:42.458 FLH: Read block - Writing: 4096 - Total: 1757184 - Buffer size: 1959
      15:51:42.660 FLH: Read block - Writing: 4096 - Total: 1761280 - Buffer size: 1959
      15:51:42.911 FLH: Read block - Writing: 4096 - Total: 1765376 - Buffer size: 1959
      15:51:43.023 FLH: Read block - Writing: 4096 - Total: 1769472 - Buffer size: 1959
      15:51:43.157 FLH: Read block - Writing: 4096 - Total: 1773568 - Buffer size: 1959
      15:51:43.458 FLH: Read block - Writing: 4096 - Total: 1777664 - Buffer size: 1959
      15:51:43.657 FLH: Read block - Writing: 4096 - Total: 1781760 - Buffer size: 1959
      15:51:43.857 FLH: Read block - Writing: 4096 - Total: 1785856 - Buffer size: 1959
      15:51:43.969 FLH: Read block - Writing: 4096 - Total: 1789952 - Buffer size: 1959
      15:51:44.157 FLH: Read block - Writing: 4096 - Total: 1794048 - Buffer size: 1959
      15:51:44.272 FLH: Read block - Writing: 4096 - Total: 1798144 - Buffer size: 1959
      15:51:44.457 FLH: Read block - Writing: 4096 - Total: 1802240 - Buffer size: 1959
      15:51:44.658 FLH: Read block - Writing: 4096 - Total: 1806336 - Buffer size: 1959
      15:51:44.858 FLH: Read block - Writing: 4096 - Total: 1810432 - Buffer size: 1959
      15:51:45.058 FLH: Read block - Writing: 4096 - Total: 1814528 - Buffer size: 1959
      15:51:45.263 FLH: Read block - Writing: 4096 - Total: 1818624 - Buffer size: 1959
      15:51:45.410 FLH: Read block - Writing: 4096 - Total: 1822720 - Buffer size: 1959
      15:51:45.559 FLH: Read block - Writing: 4096 - Total: 1826816 - Buffer size: 1959
      15:51:45.758 FLH: Read block - Writing: 4096 - Total: 1830912 - Buffer size: 1959
      15:51:45.872 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "15", "time_elapsed": 83}}
      15:51:45.965 FLH: Read block - Writing: 4096 - Total: 1835008 - Buffer size: 1959
      15:51:46.158 FLH: Read block - Writing: 4096 - Total: 1839104 - Buffer size: 1959
      15:51:46.360 FLH: Read block - Writing: 4096 - Total: 1843200 - Buffer size: 1959
      15:51:46.558 FLH: Read block - Writing: 4096 - Total: 1847296 - Buffer size: 1959
      15:51:46.758 FLH: Read block - Writing: 4096 - Total: 1851392 - Buffer size: 1959
      15:51:46.958 FLH: Read block - Writing: 4096 - Total: 1855488 - Buffer size: 1959
      15:51:47.158 FLH: Read block - Writing: 4096 - Total: 1859584 - Buffer size: 1959
      15:51:47.273 FLH: Read block - Writing: 4096 - Total: 1863680 - Buffer size: 1959
      15:51:47.458 FLH: Read block - Writing: 4096 - Total: 1867776 - Buffer size: 1959
      15:51:47.658 FLH: Read block - Writing: 4096 - Total: 1871872 - Buffer size: 1959
      15:51:47.857 FLH: Read block - Writing: 4096 - Total: 1875968 - Buffer size: 1959
      15:51:48.058 FLH: Read block - Writing: 4096 - Total: 1880064 - Buffer size: 1959
      15:51:48.264 FLH: Read block - Writing: 4096 - Total: 1884160 - Buffer size: 1959
      15:51:48.458 FLH: Read block - Writing: 4096 - Total: 1888256 - Buffer size: 1959
      15:51:48.658 FLH: Read block - Writing: 4096 - Total: 1892352 - Buffer size: 1959
      15:51:48.858 FLH: Read block - Writing: 4096 - Total: 1896448 - Buffer size: 1959
      15:51:49.057 FLH: Read block - Writing: 4096 - Total: 1900544 - Buffer size: 1959
      15:51:49.263 FLH: Read block - Writing: 4096 - Total: 1904640 - Buffer size: 1959
      15:51:49.458 FLH: Read block - Writing: 4096 - Total: 1908736 - Buffer size: 1959
      15:51:49.658 FLH: Read block - Writing: 4096 - Total: 1912832 - Buffer size: 1959
      15:51:49.858 FLH: Read block - Writing: 4096 - Total: 1916928 - Buffer size: 1959
      15:51:50.058 FLH: Read block - Writing: 4096 - Total: 1921024 - Buffer size: 1959
      15:51:50.264 FLH: Read block - Writing: 4096 - Total: 1925120 - Buffer size: 1959
      15:51:50.411 FLH: Read block - Writing: 4096 - Total: 1929216 - Buffer size: 1959
      15:51:50.558 FLH: Read block - Writing: 4096 - Total: 1933312 - Buffer size: 1959
      15:51:50.757 FLH: Read block - Writing: 4096 - Total: 1937408 - Buffer size: 1959
      15:51:50.956 FLH: Read block - Writing: 4096 - Total: 1941504 - Buffer size: 1959
      15:51:51.157 FLH: Read block - Writing: 4096 - Total: 1945600 - Buffer size: 1959
      15:51:51.273 FLH: Read block - Writing: 4096 - Total: 1949696 - Buffer size: 1959
      15:51:51.457 FLH: Read block - Writing: 4096 - Total: 1953792 - Buffer size: 1959
      15:51:51.570 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "16", "time_elapsed": 89}}
      15:51:51.662 FLH: Read block - Writing: 4096 - Total: 1957888 - Buffer size: 1959
      15:51:51.857 FLH: Read block - Writing: 4096 - Total: 1961984 - Buffer size: 1959
      15:51:51.970 FLH: Read block - Writing: 4096 - Total: 1966080 - Buffer size: 1959
      15:51:52.157 FLH: Read block - Writing: 4096 - Total: 1970176 - Buffer size: 1959
      15:51:52.359 FLH: Read block - Writing: 4096 - Total: 1974272 - Buffer size: 1959
      15:51:52.558 FLH: Read block - Writing: 4096 - Total: 1978368 - Buffer size: 1959
      15:51:52.757 FLH: Read block - Writing: 4096 - Total: 1982464 - Buffer size: 1959
      15:51:52.902 FLH: Read block - Writing: 4096 - Total: 1986560 - Buffer size: 1959
      15:51:53.016 FLH: Read block - Writing: 4096 - Total: 1990656 - Buffer size: 1959
      15:51:53.158 FLH: Read block - Writing: 4096 - Total: 1994752 - Buffer size: 1959
      15:51:53.272 FLH: Read block - Writing: 4096 - Total: 1998848 - Buffer size: 1959
      15:51:53.458 FLH: Read block - Writing: 4096 - Total: 2002944 - Buffer size: 1959
      15:51:53.658 FLH: Read block - Writing: 4096 - Total: 2007040 - Buffer size: 1959
      15:51:53.857 FLH: Read block - Writing: 4096 - Total: 2011136 - Buffer size: 1959
      15:51:53.969 FLH: Read block - Writing: 4096 - Total: 2015232 - Buffer size: 1959
      15:51:54.157 FLH: Read block - Writing: 4096 - Total: 2019328 - Buffer size: 1959
      15:51:54.272 FLH: Read block - Writing: 4096 - Total: 2023424 - Buffer size: 1959
      15:51:54.458 FLH: Read block - Writing: 4096 - Total: 2027520 - Buffer size: 1959
      15:51:54.658 FLH: Read block - Writing: 4096 - Total: 2031616 - Buffer size: 1959
      15:51:54.858 FLH: Read block - Writing: 4096 - Total: 2035712 - Buffer size: 1959
      15:51:55.058 FLH: Read block - Writing: 4096 - Total: 2039808 - Buffer size: 1959
      15:51:55.264 FLH: Read block - Writing: 4096 - Total: 2043904 - Buffer size: 1959
      15:51:55.458 FLH: Read block - Writing: 4096 - Total: 2048000 - Buffer size: 1959
      15:51:55.658 FLH: Read block - Writing: 4096 - Total: 2052096 - Buffer size: 1959
      15:51:55.858 FLH: Read block - Writing: 4096 - Total: 2056192 - Buffer size: 1959
      15:51:56.058 FLH: Read block - Writing: 4096 - Total: 2060288 - Buffer size: 1959
      15:51:56.264 FLH: Read block - Writing: 4096 - Total: 2064384 - Buffer size: 1959
      15:51:56.457 FLH: Read block - Writing: 4096 - Total: 2068480 - Buffer size: 1959
      15:51:56.658 FLH: Read block - Writing: 4096 - Total: 2072576 - Buffer size: 1959
      15:51:56.858 FLH: Read block - Writing: 4096 - Total: 2076672 - Buffer size: 1959
      15:51:56.971 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "17", "time_elapsed": 94}}
      15:51:57.064 FLH: Read block - Writing: 4096 - Total: 2080768 - Buffer size: 1959
      15:51:57.264 FLH: Read block - Writing: 4096 - Total: 2084864 - Buffer size: 1959
      15:51:57.458 FLH: Read block - Writing: 4096 - Total: 2088960 - Buffer size: 1959
      15:51:57.658 FLH: Read block - Writing: 4096 - Total: 2093056 - Buffer size: 1959
      15:51:57.857 FLH: Read block - Writing: 4096 - Total: 2097152 - Buffer size: 1959
      15:51:58.058 FLH: Read block - Writing: 4096 - Total: 2101248 - Buffer size: 1959
      15:51:58.263 FLH: Read block - Writing: 4096 - Total: 2105344 - Buffer size: 1959
      15:51:58.458 FLH: Read block - Writing: 4096 - Total: 2109440 - Buffer size: 1959
      15:51:58.657 FLH: Read block - Writing: 4096 - Total: 2113536 - Buffer size: 1959
      15:51:58.858 FLH: Read block - Writing: 4096 - Total: 2117632 - Buffer size: 1959
      15:51:58.970 FLH: Read block - Writing: 4096 - Total: 2121728 - Buffer size: 1959
      15:51:59.158 FLH: Read block - Writing: 4096 - Total: 2125824 - Buffer size: 1959
      15:51:59.276 FLH: Read block - Writing: 4096 - Total: 2129920 - Buffer size: 1959
      15:51:59.457 FLH: Read block - Writing: 4096 - Total: 2134016 - Buffer size: 1959
      15:51:59.658 FLH: Read block - Writing: 4096 - Total: 2138112 - Buffer size: 1959
      15:51:59.858 FLH: Read block - Writing: 4096 - Total: 2142208 - Buffer size: 1959
      15:52:00.058 FLH: Read block - Writing: 4096 - Total: 2146304 - Buffer size: 1959
      15:52:00.264 FLH: Read block - Writing: 4096 - Total: 2150400 - Buffer size: 1959
      15:52:00.457 FLH: Read block - Writing: 4096 - Total: 2154496 - Buffer size: 1959
      15:52:00.605 FLH: Read block - Writing: 4096 - Total: 2158592 - Buffer size: 1959
      15:52:00.757 FLH: Read block - Writing: 4096 - Total: 2162688 - Buffer size: 1959
      15:52:00.958 FLH: Read block - Writing: 4096 - Total: 2166784 - Buffer size: 1959
      15:52:01.156 FLH: Read block - Writing: 4096 - Total: 2170880 - Buffer size: 1959
      15:52:01.271 FLH: Read block - Writing: 4096 - Total: 2174976 - Buffer size: 1959
      15:52:01.455 FLH: Read block - Writing: 4096 - Total: 2179072 - Buffer size: 1959
      15:52:01.656 FLH: Read block - Writing: 4096 - Total: 2183168 - Buffer size: 1959
      15:52:01.856 FLH: Read block - Writing: 4096 - Total: 2187264 - Buffer size: 1959
      15:52:02.058 FLH: Read block - Writing: 4096 - Total: 2191360 - Buffer size: 1959
      15:52:02.264 FLH: Read block - Writing: 4096 - Total: 2195456 - Buffer size: 1959
      15:52:02.458 FLH: Read block - Writing: 4096 - Total: 2199552 - Buffer size: 1959
      15:52:02.571 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "18", "time_elapsed": 100}}
      15:52:02.664 FLH: Read block - Writing: 4096 - Total: 2203648 - Buffer size: 1959
      15:52:02.857 FLH: Read block - Writing: 4096 - Total: 2207744 - Buffer size: 1959
      15:52:03.058 FLH: Read block - Writing: 4096 - Total: 2211840 - Buffer size: 1959
      15:52:03.203 FLH: Read block - Writing: 4096 - Total: 2215936 - Buffer size: 1959
      15:52:03.320 FLH: Read block - Writing: 4096 - Total: 2220032 - Buffer size: 1959
      15:52:03.432 FLH: Read block - Writing: 4096 - Total: 2224128 - Buffer size: 1959
      15:52:03.560 FLH: Read block - Writing: 4096 - Total: 2228224 - Buffer size: 1959
      15:52:03.758 FLH: Read block - Writing: 4096 - Total: 2232320 - Buffer size: 1959
      15:52:03.957 FLH: Read block - Writing: 4096 - Total: 2236416 - Buffer size: 1959
      15:52:04.157 FLH: Read block - Writing: 4096 - Total: 2240512 - Buffer size: 1959
      15:52:04.274 FLH: Read block - Writing: 4096 - Total: 2244608 - Buffer size: 1959
      15:52:04.459 FLH: Read block - Writing: 4096 - Total: 2248704 - Buffer size: 1959
      15:52:04.658 FLH: Read block - Writing: 4096 - Total: 2252800 - Buffer size: 1959
      15:52:04.857 FLH: Read block - Writing: 4096 - Total: 2256896 - Buffer size: 1959
      15:52:05.058 FLH: Read block - Writing: 4096 - Total: 2260992 - Buffer size: 1959
      15:52:05.263 FLH: Read block - Writing: 4096 - Total: 2265088 - Buffer size: 1959
      15:52:05.457 FLH: Read block - Writing: 4096 - Total: 2269184 - Buffer size: 1959
      15:52:05.658 FLH: Read block - Writing: 4096 - Total: 2273280 - Buffer size: 1959
      15:52:05.807 FLH: Read block - Writing: 4096 - Total: 2277376 - Buffer size: 1959
      15:52:05.958 FLH: Read block - Writing: 4096 - Total: 2281472 - Buffer size: 1959
      15:52:06.158 FLH: Read block - Writing: 4096 - Total: 2285568 - Buffer size: 1959
      15:52:06.273 FLH: Read block - Writing: 4096 - Total: 2289664 - Buffer size: 1959
      15:52:06.457 FLH: Read block - Writing: 4096 - Total: 2293760 - Buffer size: 1959
      15:52:06.658 FLH: Read block - Writing: 4096 - Total: 2297856 - Buffer size: 1959
      15:52:06.858 FLH: Read block - Writing: 4096 - Total: 2301952 - Buffer size: 1959
      15:52:06.970 FLH: Read block - Writing: 4096 - Total: 2306048 - Buffer size: 1959
      15:52:07.157 FLH: Read block - Writing: 4096 - Total: 2310144 - Buffer size: 1959
      15:52:07.273 FLH: Read block - Writing: 4096 - Total: 2314240 - Buffer size: 1959
      15:52:07.456 FLH: Read block - Writing: 4096 - Total: 2318336 - Buffer size: 1959
      15:52:07.571 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "19", "time_elapsed": 105}}
      15:52:07.664 FLH: Read block - Writing: 4096 - Total: 2322432 - Buffer size: 1959
      15:52:07.858 FLH: Read block - Writing: 4096 - Total: 2326528 - Buffer size: 1959
      15:52:08.058 FLH: Read block - Writing: 4096 - Total: 2330624 - Buffer size: 1959
      15:52:08.264 FLH: Read block - Writing: 4096 - Total: 2334720 - Buffer size: 1959
      15:52:08.457 FLH: Read block - Writing: 4096 - Total: 2338816 - Buffer size: 1959
      15:52:08.658 FLH: Read block - Writing: 4096 - Total: 2342912 - Buffer size: 1959
      15:52:08.857 FLH: Read block - Writing: 4096 - Total: 2347008 - Buffer size: 1959
      15:52:09.058 FLH: Read block - Writing: 4096 - Total: 2351104 - Buffer size: 1959
      15:52:09.264 FLH: Read block - Writing: 4096 - Total: 2355200 - Buffer size: 1959
      15:52:09.457 FLH: Read block - Writing: 4096 - Total: 2359296 - Buffer size: 1959
      15:52:09.658 FLH: Read block - Writing: 4096 - Total: 2363392 - Buffer size: 1959
      15:52:09.857 FLH: Read block - Writing: 4096 - Total: 2367488 - Buffer size: 1959
      15:52:10.058 FLH: Read block - Writing: 4096 - Total: 2371584 - Buffer size: 1959
      15:52:10.263 FLH: Read block - Writing: 4096 - Total: 2375680 - Buffer size: 1959
      15:52:10.457 FLH: Read block - Writing: 4096 - Total: 2379776 - Buffer size: 1959
      15:52:10.658 FLH: Read block - Writing: 4096 - Total: 2383872 - Buffer size: 1959
      15:52:10.806 FLH: Read block - Writing: 4096 - Total: 2387968 - Buffer size: 1959
      15:52:10.958 FLH: Read block - Writing: 4096 - Total: 2392064 - Buffer size: 1959
      15:52:11.157 FLH: Read block - Writing: 4096 - Total: 2396160 - Buffer size: 1959
      15:52:11.272 FLH: Read block - Writing: 4096 - Total: 2400256 - Buffer size: 1959
      15:52:11.457 FLH: Read block - Writing: 4096 - Total: 2404352 - Buffer size: 1959
      15:52:11.658 FLH: Read block - Writing: 4096 - Total: 2408448 - Buffer size: 1959
      15:52:11.857 FLH: Read block - Writing: 4096 - Total: 2412544 - Buffer size: 1959
      15:52:12.058 FLH: Read block - Writing: 4096 - Total: 2416640 - Buffer size: 1959
      15:52:12.263 FLH: Read block - Writing: 4096 - Total: 2420736 - Buffer size: 1959
      15:52:12.458 FLH: Read block - Writing: 4096 - Total: 2424832 - Buffer size: 1959
      15:52:12.657 FLH: Read block - Writing: 4096 - Total: 2428928 - Buffer size: 1959
      15:52:12.858 FLH: Read block - Writing: 4096 - Total: 2433024 - Buffer size: 1959
      15:52:13.058 FLH: Read block - Writing: 4096 - Total: 2437120 - Buffer size: 1959
      15:52:13.264 FLH: Read block - Writing: 4096 - Total: 2441216 - Buffer size: 1959
      15:52:13.328 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "20", "time_elapsed": 111}}
      15:52:13.420 FLH: Read block - Writing: 4096 - Total: 2445312 - Buffer size: 1959
      15:52:13.558 FLH: Read block - Writing: 4096 - Total: 2449408 - Buffer size: 1959
      15:52:13.758 FLH: Read block - Writing: 4096 - Total: 2453504 - Buffer size: 1959
      15:52:13.957 FLH: Read block - Writing: 4096 - Total: 2457600 - Buffer size: 1959
      15:52:14.158 FLH: Read block - Writing: 4096 - Total: 2461696 - Buffer size: 1959
      15:52:14.273 FLH: Read block - Writing: 4096 - Total: 2465792 - Buffer size: 1959
      15:52:14.458 FLH: Read block - Writing: 4096 - Total: 2469888 - Buffer size: 1959
      15:52:14.657 FLH: Read block - Writing: 4096 - Total: 2473984 - Buffer size: 1959
      15:52:14.858 FLH: Read block - Writing: 4096 - Total: 2478080 - Buffer size: 1959
      15:52:15.058 FLH: Read block - Writing: 4096 - Total: 2482176 - Buffer size: 1959
      15:52:15.263 FLH: Read block - Writing: 4096 - Total: 2486272 - Buffer size: 1959
      15:52:15.457 FLH: Read block - Writing: 4096 - Total: 2490368 - Buffer size: 1959
      15:52:15.658 FLH: Read block - Writing: 4096 - Total: 2494464 - Buffer size: 1959
      15:52:15.858 FLH: Read block - Writing: 4096 - Total: 2498560 - Buffer size: 1959
      15:52:16.007 FLH: Read block - Writing: 4096 - Total: 2502656 - Buffer size: 1959
      15:52:16.157 FLH: Read block - Writing: 4096 - Total: 2506752 - Buffer size: 1959
      15:52:16.273 FLH: Read block - Writing: 4096 - Total: 2510848 - Buffer size: 1959
      15:52:16.457 FLH: Read block - Writing: 4096 - Total: 2514944 - Buffer size: 1959
      15:52:16.658 FLH: Read block - Writing: 4096 - Total: 2519040 - Buffer size: 1959
      15:52:16.857 FLH: Read block - Writing: 4096 - Total: 2523136 - Buffer size: 1959
      15:52:17.057 FLH: Read block - Writing: 4096 - Total: 2527232 - Buffer size: 1959
      15:52:17.266 FLH: Read block - Writing: 4096 - Total: 2531328 - Buffer size: 1959
      15:52:17.457 FLH: Read block - Writing: 4096 - Total: 2535424 - Buffer size: 1959
      15:52:17.659 FLH: Read block - Writing: 4096 - Total: 2539520 - Buffer size: 1959
      15:52:17.858 FLH: Read block - Writing: 4096 - Total: 2543616 - Buffer size: 1959
      15:52:18.057 FLH: Read block - Writing: 4096 - Total: 2547712 - Buffer size: 1959
      15:52:18.265 FLH: Read block - Writing: 4096 - Total: 2551808 - Buffer size: 1959
      15:52:18.377 FLH: Read block - Writing: 4096 - Total: 2555904 - Buffer size: 1959
      15:52:18.530 FLH: Read block - Writing: 4096 - Total: 2560000 - Buffer size: 1959
      15:52:18.758 FLH: Read block - Writing: 4096 - Total: 2564096 - Buffer size: 1959
      15:52:18.871 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "21", "time_elapsed": 116}}
      15:52:18.963 FLH: Read block - Writing: 4096 - Total: 2568192 - Buffer size: 1959
      15:52:19.158 FLH: Read block - Writing: 4096 - Total: 2572288 - Buffer size: 1959
      15:52:19.273 FLH: Read block - Writing: 4096 - Total: 2576384 - Buffer size: 1959
      15:52:19.458 FLH: Read block - Writing: 4096 - Total: 2580480 - Buffer size: 1959
      15:52:19.464 HTP: Werkzeuge
      15:52:19.639 FLH: Read block - Writing: 4096 - Total: 2584576 - Buffer size: 1959
      15:52:19.758 FLH: Read block - Writing: 4096 - Total: 2588672 - Buffer size: 1959
      15:52:19.958 FLH: Read block - Writing: 4096 - Total: 2592768 - Buffer size: 1959
      15:52:20.157 FLH: Read block - Writing: 4096 - Total: 2596864 - Buffer size: 1959
      15:52:20.272 FLH: Read block - Writing: 4096 - Total: 2600960 - Buffer size: 1959
      15:52:20.457 FLH: Read block - Writing: 4096 - Total: 2605056 - Buffer size: 1959
      15:52:20.657 FLH: Read block - Writing: 4096 - Total: 2609152 - Buffer size: 1959
      15:52:20.858 FLH: Read block - Writing: 4096 - Total: 2613248 - Buffer size: 1959
      15:52:20.970 FLH: Read block - Writing: 4096 - Total: 2617344 - Buffer size: 1959
      15:52:21.118 FLH: Read block - Writing: 4096 - Total: 2621440 - Buffer size: 1959
      15:52:21.127 HTP: Hauptmenü
      15:52:21.316 FLH: Read block - Writing: 4096 - Total: 2625536 - Buffer size: 1959
      15:52:21.558 FLH: Read block - Writing: 4096 - Total: 2629632 - Buffer size: 1959
      15:52:21.757 FLH: Read block - Writing: 4096 - Total: 2633728 - Buffer size: 1959
      15:52:21.957 FLH: Read block - Writing: 4096 - Total: 2637824 - Buffer size: 1959
      15:52:22.158 FLH: Read block - Writing: 4096 - Total: 2641920 - Buffer size: 1959
      15:52:22.274 FLH: Read block - Writing: 4096 - Total: 2646016 - Buffer size: 1959
      15:52:22.458 FLH: Read block - Writing: 4096 - Total: 2650112 - Buffer size: 1959
      15:52:22.657 FLH: Read block - Writing: 4096 - Total: 2654208 - Buffer size: 1959
      15:52:22.858 FLH: Read block - Writing: 4096 - Total: 2658304 - Buffer size: 1959
      15:52:23.058 FLH: Read block - Writing: 4096 - Total: 2662400 - Buffer size: 1959
      15:52:23.264 FLH: Read block - Writing: 4096 - Total: 2666496 - Buffer size: 1959
      15:52:23.458 FLH: Read block - Writing: 4096 - Total: 2670592 - Buffer size: 1959
      15:52:23.604 FLH: Read block - Writing: 4096 - Total: 2674688 - Buffer size: 1959
      15:52:23.757 FLH: Read block - Writing: 4096 - Total: 2678784 - Buffer size: 1959
      15:52:23.907 FLH: Read block - Writing: 4096 - Total: 2682880 - Buffer size: 1959
      15:52:24.057 FLH: Read block - Writing: 4096 - Total: 2686976 - Buffer size: 1959
      15:52:24.178 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "22", "time_elapsed": 121}}
      15:52:24.271 FLH: Read block - Writing: 4096 - Total: 2691072 - Buffer size: 1959
      15:52:24.457 FLH: Read block - Writing: 4096 - Total: 2695168 - Buffer size: 1959
      15:52:24.659 FLH: Read block - Writing: 4096 - Total: 2699264 - Buffer size: 1959
      15:52:24.859 FLH: Read block - Writing: 4096 - Total: 2703360 - Buffer size: 1959
      15:52:25.056 FLH: Read block - Writing: 4096 - Total: 2707456 - Buffer size: 1959
      15:52:25.265 FLH: Read block - Writing: 4096 - Total: 2711552 - Buffer size: 1959
      15:52:25.458 FLH: Read block - Writing: 4096 - Total: 2715648 - Buffer size: 1959
      15:52:25.658 FLH: Read block - Writing: 4096 - Total: 2719744 - Buffer size: 1959
      15:52:25.859 FLH: Read block - Writing: 4096 - Total: 2723840 - Buffer size: 1959
      15:52:26.012 FLH: Read block - Writing: 4096 - Total: 2727936 - Buffer size: 1959
      15:52:26.157 FLH: Read block - Writing: 4096 - Total: 2732032 - Buffer size: 1959
      15:52:26.274 FLH: Read block - Writing: 4096 - Total: 2736128 - Buffer size: 1959
      15:52:26.425 FLH: Read block - Writing: 4096 - Total: 2740224 - Buffer size: 1959
      15:52:26.558 FLH: Read block - Writing: 4096 - Total: 2744320 - Buffer size: 1959
      15:52:26.758 FLH: Read block - Writing: 4096 - Total: 2748416 - Buffer size: 1959
      15:52:26.958 FLH: Read block - Writing: 4096 - Total: 2752512 - Buffer size: 1959
      15:52:27.158 FLH: Read block - Writing: 4096 - Total: 2756608 - Buffer size: 1959
      15:52:27.359 FLH: Read block - Writing: 4096 - Total: 2760704 - Buffer size: 1959
      15:52:27.558 FLH: Read block - Writing: 4096 - Total: 2764800 - Buffer size: 1959
      15:52:27.757 FLH: Read block - Writing: 4096 - Total: 2768896 - Buffer size: 1959
      15:52:27.958 FLH: Read block - Writing: 4096 - Total: 2772992 - Buffer size: 1959
      15:52:28.158 FLH: Read block - Writing: 4096 - Total: 2777088 - Buffer size: 1959
      15:52:28.275 FLH: Read block - Writing: 4096 - Total: 2781184 - Buffer size: 1959
      15:52:28.458 FLH: Read block - Writing: 4096 - Total: 2785280 - Buffer size: 1959
      15:52:28.604 FLH: Read block - Writing: 4096 - Total: 2789376 - Buffer size: 1959
      15:52:28.757 FLH: Read block - Writing: 4096 - Total: 2793472 - Buffer size: 1959
      15:52:28.906 FLH: Read block - Writing: 4096 - Total: 2797568 - Buffer size: 1959
      15:52:29.058 FLH: Read block - Writing: 4096 - Total: 2801664 - Buffer size: 1959
      15:52:29.264 FLH: Read block - Writing: 4096 - Total: 2805760 - Buffer size: 1959
      15:52:29.371 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "23", "time_elapsed": 127}}
      15:52:29.464 FLH: Read block - Writing: 4096 - Total: 2809856 - Buffer size: 1959
      15:52:29.658 FLH: Read block - Writing: 4096 - Total: 2813952 - Buffer size: 1959
      15:52:29.858 FLH: Read block - Writing: 4096 - Total: 2818048 - Buffer size: 1959
      15:52:29.970 FLH: Read block - Writing: 4096 - Total: 2822144 - Buffer size: 1959
      15:52:30.264 FLH: Read block - Writing: 4096 - Total: 2826240 - Buffer size: 1959
      15:52:30.457 FLH: Read block - Writing: 4096 - Total: 2830336 - Buffer size: 1959
      15:52:30.658 FLH: Read block - Writing: 4096 - Total: 2834432 - Buffer size: 1959
      15:52:30.858 FLH: Read block - Writing: 4096 - Total: 2838528 - Buffer size: 1959
      15:52:31.057 FLH: Read block - Writing: 4096 - Total: 2842624 - Buffer size: 1959
      15:52:31.263 FLH: Read block - Writing: 4096 - Total: 2846720 - Buffer size: 1959
      15:52:31.458 FLH: Read block - Writing: 4096 - Total: 2850816 - Buffer size: 1959
      15:52:31.658 FLH: Read block - Writing: 4096 - Total: 2854912 - Buffer size: 1959
      15:52:31.858 FLH: Read block - Writing: 4096 - Total: 2859008 - Buffer size: 1959
      15:52:32.058 FLH: Read block - Writing: 4096 - Total: 2863104 - Buffer size: 1959
      15:52:32.264 FLH: Read block - Writing: 4096 - Total: 2867200 - Buffer size: 1959
      15:52:32.458 FLH: Read block - Writing: 4096 - Total: 2871296 - Buffer size: 1959
      15:52:32.657 FLH: Read block - Writing: 4096 - Total: 2875392 - Buffer size: 1959
      15:52:32.858 FLH: Read block - Writing: 4096 - Total: 2879488 - Buffer size: 1959
      15:52:33.057 FLH: Read block - Writing: 4096 - Total: 2883584 - Buffer size: 1959
      15:52:33.263 FLH: Read block - Writing: 4096 - Total: 2887680 - Buffer size: 1959
      15:52:33.457 FLH: Read block - Writing: 4096 - Total: 2891776 - Buffer size: 1959
      15:52:33.603 FLH: Read block - Writing: 4096 - Total: 2895872 - Buffer size: 1959
      15:52:33.757 FLH: Read block - Writing: 4096 - Total: 2899968 - Buffer size: 1959
      15:52:33.906 FLH: Read block - Writing: 4096 - Total: 2904064 - Buffer size: 1959
      15:52:34.058 FLH: Read block - Writing: 4096 - Total: 2908160 - Buffer size: 1959
      15:52:34.265 FLH: Read block - Writing: 4096 - Total: 2912256 - Buffer size: 1959
      15:52:34.458 FLH: Read block - Writing: 4096 - Total: 2916352 - Buffer size: 1959
      15:52:34.659 FLH: Read block - Writing: 4096 - Total: 2920448 - Buffer size: 1959
      15:52:34.859 FLH: Read block - Writing: 4096 - Total: 2924544 - Buffer size: 1959
      15:52:35.056 FLH: Read block - Writing: 4096 - Total: 2928640 - Buffer size: 1959
      15:52:35.178 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "24", "time_elapsed": 132}}
      15:52:35.270 FLH: Read block - Writing: 4096 - Total: 2932736 - Buffer size: 1959
      15:52:35.457 FLH: Read block - Writing: 4096 - Total: 2936832 - Buffer size: 1959
      15:52:35.658 FLH: Read block - Writing: 4096 - Total: 2940928 - Buffer size: 1959
      15:52:35.857 FLH: Read block - Writing: 4096 - Total: 2945024 - Buffer size: 1959
      15:52:35.969 FLH: Read block - Writing: 4096 - Total: 2949120 - Buffer size: 1959
      15:52:36.167 FLH: Read block - Writing: 4096 - Total: 2953216 - Buffer size: 1959
      15:52:36.358 FLH: Read block - Writing: 4096 - Total: 2957312 - Buffer size: 1959
      15:52:36.558 FLH: Read block - Writing: 4096 - Total: 2961408 - Buffer size: 1959
      15:52:36.758 FLH: Read block - Writing: 4096 - Total: 2965504 - Buffer size: 1959
      15:52:36.958 FLH: Read block - Writing: 4096 - Total: 2969600 - Buffer size: 1959
      15:52:37.158 FLH: Read block - Writing: 4096 - Total: 2973696 - Buffer size: 1959
      15:52:37.272 FLH: Read block - Writing: 4096 - Total: 2977792 - Buffer size: 1959
      15:52:37.458 FLH: Read block - Writing: 4096 - Total: 2981888 - Buffer size: 1959
      15:52:37.657 FLH: Read block - Writing: 4096 - Total: 2985984 - Buffer size: 1959
      15:52:37.858 FLH: Read block - Writing: 4096 - Total: 2990080 - Buffer size: 1959
      15:52:38.058 FLH: Read block - Writing: 4096 - Total: 2994176 - Buffer size: 1959
      15:52:38.263 FLH: Read block - Writing: 4096 - Total: 2998272 - Buffer size: 1959
      15:52:38.458 FLH: Read block - Writing: 4096 - Total: 3002368 - Buffer size: 1959
      15:52:38.606 FLH: Read block - Writing: 4096 - Total: 3006464 - Buffer size: 1959
      15:52:38.758 FLH: Read block - Writing: 4096 - Total: 3010560 - Buffer size: 1959
      15:52:38.957 FLH: Read block - Writing: 4096 - Total: 3014656 - Buffer size: 1959
      15:52:39.160 FLH: Read block - Writing: 4096 - Total: 3018752 - Buffer size: 1959
      15:52:39.359 FLH: Read block - Writing: 4096 - Total: 3022848 - Buffer size: 1959
      15:52:39.559 FLH: Read block - Writing: 4096 - Total: 3026944 - Buffer size: 1959
      15:52:39.757 FLH: Read block - Writing: 4096 - Total: 3031040 - Buffer size: 1959
      15:52:39.957 FLH: Read block - Writing: 4096 - Total: 3035136 - Buffer size: 1959
      15:52:40.157 FLH: Read block - Writing: 4096 - Total: 3039232 - Buffer size: 1959
      15:52:40.272 FLH: Read block - Writing: 4096 - Total: 3043328 - Buffer size: 1959
      15:52:40.457 FLH: Read block - Writing: 4096 - Total: 3047424 - Buffer size: 1959
      15:52:40.658 FLH: Read block - Writing: 4096 - Total: 3051520 - Buffer size: 1959
      15:52:40.772 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "25", "time_elapsed": 138}}
      15:52:40.865 FLH: Read block - Writing: 4096 - Total: 3055616 - Buffer size: 1959
      15:52:41.018 FLH: Read block - Writing: 4096 - Total: 3059712 - Buffer size: 1959
      15:52:41.170 FLH: Read block - Writing: 4096 - Total: 3063808 - Buffer size: 1959
      15:52:41.285 FLH: Read block - Writing: 4096 - Total: 3067904 - Buffer size: 1959
      15:52:41.458 FLH: Read block - Writing: 4096 - Total: 3072000 - Buffer size: 1959
      15:52:41.657 FLH: Read block - Writing: 4096 - Total: 3076096 - Buffer size: 1959
      15:52:41.858 FLH: Read block - Writing: 4096 - Total: 3080192 - Buffer size: 1959
      15:52:42.058 FLH: Read block - Writing: 4096 - Total: 3084288 - Buffer size: 1959
      15:52:42.264 FLH: Read block - Writing: 4096 - Total: 3088384 - Buffer size: 1959
      15:52:42.458 FLH: Read block - Writing: 4096 - Total: 3092480 - Buffer size: 1959
      15:52:42.657 FLH: Read block - Writing: 4096 - Total: 3096576 - Buffer size: 1959
      15:52:42.858 FLH: Read block - Writing: 4096 - Total: 3100672 - Buffer size: 1959
      15:52:42.970 FLH: Read block - Writing: 4096 - Total: 3104768 - Buffer size: 1959
      15:52:43.158 FLH: Read block - Writing: 4096 - Total: 3108864 - Buffer size: 1959
      15:52:43.274 FLH: Read block - Writing: 4096 - Total: 3112960 - Buffer size: 1959
      15:52:43.458 FLH: Read block - Writing: 4096 - Total: 3117056 - Buffer size: 1959
      15:52:43.603 FLH: Read block - Writing: 4096 - Total: 3121152 - Buffer size: 1959
      15:52:43.755 FLH: Read block - Writing: 4096 - Total: 3125248 - Buffer size: 1959
      15:52:43.958 FLH: Read block - Writing: 4096 - Total: 3129344 - Buffer size: 1959
      15:52:44.158 FLH: Read block - Writing: 4096 - Total: 3133440 - Buffer size: 1959
      15:52:44.273 FLH: Read block - Writing: 4096 - Total: 3137536 - Buffer size: 1959
      15:52:44.458 FLH: Read block - Writing: 4096 - Total: 3141632 - Buffer size: 1959
      15:52:44.658 FLH: Read block - Writing: 4096 - Total: 3145728 - Buffer size: 1959
      15:52:44.858 FLH: Read block - Writing: 4096 - Total: 3149824 - Buffer size: 1959
      15:52:45.057 FLH: Read block - Writing: 4096 - Total: 3153920 - Buffer size: 1959
      15:52:45.264 FLH: Read block - Writing: 4096 - Total: 3158016 - Buffer size: 1959
      15:52:45.458 FLH: Read block - Writing: 4096 - Total: 3162112 - Buffer size: 1959
      15:52:45.658 FLH: Read block - Writing: 4096 - Total: 3166208 - Buffer size: 1959
      15:52:45.858 FLH: Read block - Writing: 4096 - Total: 3170304 - Buffer size: 1959
      15:52:45.970 FLH: Read block - Writing: 4096 - Total: 3174400 - Buffer size: 1959
      15:52:46.072 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "26", "time_elapsed": 143}}
      15:52:46.165 FLH: Read block - Writing: 4096 - Total: 3178496 - Buffer size: 1959
      15:52:46.323 FLH: Read block - Writing: 4096 - Total: 3182592 - Buffer size: 1959
      15:52:46.435 FLH: Read block - Writing: 4096 - Total: 3186688 - Buffer size: 1959
      15:52:46.559 FLH: Read block - Writing: 4096 - Total: 3190784 - Buffer size: 1959
      15:52:46.758 FLH: Read block - Writing: 4096 - Total: 3194880 - Buffer size: 1959
      15:52:46.958 FLH: Read block - Writing: 4096 - Total: 3198976 - Buffer size: 1959
      15:52:47.158 FLH: Read block - Writing: 4096 - Total: 3203072 - Buffer size: 1959
      15:52:47.273 FLH: Read block - Writing: 4096 - Total: 3207168 - Buffer size: 1959
      15:52:47.458 FLH: Read block - Writing: 4096 - Total: 3211264 - Buffer size: 1959
      15:52:47.658 FLH: Read block - Writing: 4096 - Total: 3215360 - Buffer size: 1959
      15:52:47.858 FLH: Read block - Writing: 4096 - Total: 3219456 - Buffer size: 1959
      15:52:47.970 FLH: Read block - Writing: 4096 - Total: 3223552 - Buffer size: 1959
      15:52:48.082 FLH: Read block - Writing: 4096 - Total: 3227648 - Buffer size: 1959
      15:52:48.263 FLH: Read block - Writing: 4096 - Total: 3231744 - Buffer size: 1959
      15:52:48.457 FLH: Read block - Writing: 4096 - Total: 3235840 - Buffer size: 1959
      15:52:48.658 FLH: Read block - Writing: 4096 - Total: 3239936 - Buffer size: 1959
      15:52:48.807 FLH: Read block - Writing: 4096 - Total: 3244032 - Buffer size: 1959
      15:52:48.957 FLH: Read block - Writing: 4096 - Total: 3248128 - Buffer size: 1959
      15:52:49.070 FLH: Read block - Writing: 4096 - Total: 3252224 - Buffer size: 1959
      15:52:49.264 FLH: Read block - Writing: 4096 - Total: 3256320 - Buffer size: 1959
      15:52:49.458 FLH: Read block - Writing: 4096 - Total: 3260416 - Buffer size: 1959
      15:52:49.657 FLH: Read block - Writing: 4096 - Total: 3264512 - Buffer size: 1959
      15:52:49.858 FLH: Read block - Writing: 4096 - Total: 3268608 - Buffer size: 1959
      15:52:50.058 FLH: Read block - Writing: 4096 - Total: 3272704 - Buffer size: 1959
      15:52:50.169 FLH: Read block - Writing: 4096 - Total: 3276800 - Buffer size: 1959
      15:52:50.282 FLH: Read block - Writing: 4096 - Total: 3280896 - Buffer size: 1959
      15:52:50.558 FLH: Read block - Writing: 4096 - Total: 3284992 - Buffer size: 1959
      15:52:50.757 FLH: Read block - Writing: 4096 - Total: 3289088 - Buffer size: 1959
      15:52:50.958 FLH: Read block - Writing: 4096 - Total: 3293184 - Buffer size: 1959
      15:52:51.158 FLH: Read block - Writing: 4096 - Total: 3297280 - Buffer size: 1959
      15:52:51.226 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "27", "time_elapsed": 148}}
      15:52:51.318 FLH: Read block - Writing: 4096 - Total: 3301376 - Buffer size: 1959
      15:52:51.477 FLH: Read block - Writing: 4096 - Total: 3305472 - Buffer size: 1959
      15:52:51.659 FLH: Read block - Writing: 4096 - Total: 3309568 - Buffer size: 1959
      15:52:51.858 FLH: Read block - Writing: 4096 - Total: 3313664 - Buffer size: 1959
      15:52:51.970 FLH: Read block - Writing: 4096 - Total: 3317760 - Buffer size: 1959
      15:52:52.158 FLH: Read block - Writing: 4096 - Total: 3321856 - Buffer size: 1959
      15:52:52.275 FLH: Read block - Writing: 4096 - Total: 3325952 - Buffer size: 1959
      15:52:52.458 FLH: Read block - Writing: 4096 - Total: 3330048 - Buffer size: 1959
      15:52:52.658 FLH: Read block - Writing: 4096 - Total: 3334144 - Buffer size: 1959
      15:52:52.858 FLH: Read block - Writing: 4096 - Total: 3338240 - Buffer size: 1959
      15:52:53.058 FLH: Read block - Writing: 4096 - Total: 3342336 - Buffer size: 1959
      15:52:53.263 FLH: Read block - Writing: 4096 - Total: 3346432 - Buffer size: 1959
      15:52:53.458 FLH: Read block - Writing: 4096 - Total: 3350528 - Buffer size: 1959
      15:52:53.658 FLH: Read block - Writing: 4096 - Total: 3354624 - Buffer size: 1959
      15:52:53.874 FLH: Read block - Writing: 4096 - Total: 3358720 - Buffer size: 1959
      15:52:54.024 FLH: Read block - Writing: 4096 - Total: 3362816 - Buffer size: 1959
      15:52:54.158 FLH: Read block - Writing: 4096 - Total: 3366912 - Buffer size: 1959
      15:52:54.272 FLH: Read block - Writing: 4096 - Total: 3371008 - Buffer size: 1959
      15:52:54.457 FLH: Read block - Writing: 4096 - Total: 3375104 - Buffer size: 1959
      15:52:54.658 FLH: Read block - Writing: 4096 - Total: 3379200 - Buffer size: 1959
      15:52:54.858 FLH: Read block - Writing: 4096 - Total: 3383296 - Buffer size: 1959
      15:52:55.058 FLH: Read block - Writing: 4096 - Total: 3387392 - Buffer size: 1959
      15:52:55.264 FLH: Read block - Writing: 4096 - Total: 3391488 - Buffer size: 1959
      15:52:55.457 FLH: Read block - Writing: 4096 - Total: 3395584 - Buffer size: 1959
      15:52:55.658 FLH: Read block - Writing: 4096 - Total: 3399680 - Buffer size: 1959
      15:52:55.857 FLH: Read block - Writing: 4096 - Total: 3403776 - Buffer size: 1959
      15:52:55.970 FLH: Read block - Writing: 4096 - Total: 3407872 - Buffer size: 1959
      15:52:56.159 FLH: Read block - Writing: 4096 - Total: 3411968 - Buffer size: 1959
      15:52:56.359 FLH: Read block - Writing: 4096 - Total: 3416064 - Buffer size: 1959
      15:52:56.386 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "28", "time_elapsed": 154}}
      15:52:56.479 FLH: Read block - Writing: 4096 - Total: 3420160 - Buffer size: 1959
      15:52:56.626 FLH: Read block - Writing: 4096 - Total: 3424256 - Buffer size: 1959
      15:52:56.757 FLH: Read block - Writing: 4096 - Total: 3428352 - Buffer size: 1959
      15:52:56.958 FLH: Read block - Writing: 4096 - Total: 3432448 - Buffer size: 1959
      15:52:57.158 FLH: Read block - Writing: 4096 - Total: 3436544 - Buffer size: 1959
      15:52:57.274 FLH: Read block - Writing: 4096 - Total: 3440640 - Buffer size: 1959
      15:52:57.458 FLH: Read block - Writing: 4096 - Total: 3444736 - Buffer size: 1959
      15:52:57.658 FLH: Read block - Writing: 4096 - Total: 3448832 - Buffer size: 1959
      15:52:57.858 FLH: Read block - Writing: 4096 - Total: 3452928 - Buffer size: 1959
      15:52:58.056 FLH: Read block - Writing: 4096 - Total: 3457024 - Buffer size: 1959
      15:52:58.262 FLH: Read block - Writing: 4096 - Total: 3461120 - Buffer size: 1959
      15:52:58.457 FLH: Read block - Writing: 4096 - Total: 3465216 - Buffer size: 1959
      15:52:58.658 FLH: Read block - Writing: 4096 - Total: 3469312 - Buffer size: 1959
      15:52:58.810 FLH: Read block - Writing: 4096 - Total: 3473408 - Buffer size: 1959
      15:52:58.923 FLH: Read block - Writing: 4096 - Total: 3477504 - Buffer size: 1959
      15:52:59.265 FLH: Read block - Writing: 4096 - Total: 3481600 - Buffer size: 1959
      15:52:59.412 FLH: Read block - Writing: 4096 - Total: 3485696 - Buffer size: 1959
      15:52:59.559 FLH: Read block - Writing: 4096 - Total: 3489792 - Buffer size: 1959
      15:52:59.758 FLH: Read block - Writing: 4096 - Total: 3493888 - Buffer size: 1959
      15:52:59.958 FLH: Read block - Writing: 4096 - Total: 3497984 - Buffer size: 1959
      15:53:00.158 FLH: Read block - Writing: 4096 - Total: 3502080 - Buffer size: 1959
      15:53:00.275 FLH: Read block - Writing: 4096 - Total: 3506176 - Buffer size: 1959
      15:53:00.458 FLH: Read block - Writing: 4096 - Total: 3510272 - Buffer size: 1959
      15:53:00.658 FLH: Read block - Writing: 4096 - Total: 3514368 - Buffer size: 1959
      15:53:00.770 FLH: Read block - Writing: 4096 - Total: 3518464 - Buffer size: 1959
      15:53:00.958 FLH: Read block - Writing: 4096 - Total: 3522560 - Buffer size: 1959
      15:53:01.160 FLH: Read block - Writing: 4096 - Total: 3526656 - Buffer size: 1959
      15:53:01.320 FLH: Read block - Writing: 4096 - Total: 3530752 - Buffer size: 1959
      15:53:01.457 FLH: Read block - Writing: 4096 - Total: 3534848 - Buffer size: 1959
      15:53:01.657 FLH: Read block - Writing: 4096 - Total: 3538944 - Buffer size: 1959
      15:53:01.771 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "29", "time_elapsed": 159}}
      15:53:01.864 FLH: Read block - Writing: 4096 - Total: 3543040 - Buffer size: 1959
      15:53:02.057 FLH: Read block - Writing: 4096 - Total: 3547136 - Buffer size: 1959
      15:53:02.264 FLH: Read block - Writing: 4096 - Total: 3551232 - Buffer size: 1959
      15:53:02.458 FLH: Read block - Writing: 4096 - Total: 3555328 - Buffer size: 1959
      15:53:02.658 FLH: Read block - Writing: 4096 - Total: 3559424 - Buffer size: 1959
      15:53:02.858 FLH: Read block - Writing: 4096 - Total: 3563520 - Buffer size: 1959
      15:53:03.057 FLH: Read block - Writing: 4096 - Total: 3567616 - Buffer size: 1959
      15:53:03.264 FLH: Read block - Writing: 4096 - Total: 3571712 - Buffer size: 1959
      15:53:03.458 FLH: Read block - Writing: 4096 - Total: 3575808 - Buffer size: 1959
      15:53:03.660 FLH: Read block - Writing: 4096 - Total: 3579904 - Buffer size: 1959
      15:53:03.811 FLH: Read block - Writing: 4096 - Total: 3584000 - Buffer size: 1959
      15:53:03.924 FLH: Read block - Writing: 4096 - Total: 3588096 - Buffer size: 1959
      15:53:04.058 FLH: Read block - Writing: 4096 - Total: 3592192 - Buffer size: 1959
      15:53:04.263 FLH: Read block - Writing: 4096 - Total: 3596288 - Buffer size: 1959
      15:53:04.458 FLH: Read block - Writing: 4096 - Total: 3600384 - Buffer size: 1959
      15:53:04.658 FLH: Read block - Writing: 4096 - Total: 3604480 - Buffer size: 1959
      15:53:04.858 FLH: Read block - Writing: 4096 - Total: 3608576 - Buffer size: 1959
      15:53:05.058 FLH: Read block - Writing: 4096 - Total: 3612672 - Buffer size: 1959
      15:53:05.265 FLH: Read block - Writing: 4096 - Total: 3616768 - Buffer size: 1959
      15:53:05.457 FLH: Read block - Writing: 4096 - Total: 3620864 - Buffer size: 1959
      15:53:05.657 FLH: Read block - Writing: 4096 - Total: 3624960 - Buffer size: 1959
      15:53:05.857 FLH: Read block - Writing: 4096 - Total: 3629056 - Buffer size: 1959
      15:53:06.058 FLH: Read block - Writing: 4096 - Total: 3633152 - Buffer size: 1959
      15:53:06.211 FLH: Read block - Writing: 4096 - Total: 3637248 - Buffer size: 1959
      15:53:06.324 FLH: Read block - Writing: 4096 - Total: 3641344 - Buffer size: 1959
      15:53:06.436 FLH: Read block - Writing: 4096 - Total: 3645440 - Buffer size: 1959
      15:53:06.560 FLH: Read block - Writing: 4096 - Total: 3649536 - Buffer size: 1959
      15:53:06.760 FLH: Read block - Writing: 4096 - Total: 3653632 - Buffer size: 1959
      15:53:06.978 FLH: Read block - Writing: 4096 - Total: 3657728 - Buffer size: 1959
      15:53:07.160 FLH: Read block - Writing: 4096 - Total: 3661824 - Buffer size: 1959
      15:53:07.189 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "30", "time_elapsed": 164}}
      15:53:07.281 FLH: Read block - Writing: 4096 - Total: 3665920 - Buffer size: 1959
      15:53:07.460 FLH: Read block - Writing: 4096 - Total: 3670016 - Buffer size: 1959
      15:53:07.660 FLH: Read block - Writing: 4096 - Total: 3674112 - Buffer size: 1959
      15:53:07.859 FLH: Read block - Writing: 4096 - Total: 3678208 - Buffer size: 1959
      15:53:07.971 FLH: Read block - Writing: 4096 - Total: 3682304 - Buffer size: 1959
      15:53:08.160 FLH: Read block - Writing: 4096 - Total: 3686400 - Buffer size: 1959
      15:53:08.275 FLH: Read block - Writing: 4096 - Total: 3690496 - Buffer size: 1959
      15:53:08.460 FLH: Read block - Writing: 4096 - Total: 3694592 - Buffer size: 1959
      15:53:08.660 FLH: Read block - Writing: 4096 - Total: 3698688 - Buffer size: 1959
      15:53:08.860 FLH: Read block - Writing: 4096 - Total: 3702784 - Buffer size: 1959
      15:53:09.059 FLH: Read block - Writing: 4096 - Total: 3706880 - Buffer size: 1959
      15:53:09.265 FLH: Read block - Writing: 4096 - Total: 3710976 - Buffer size: 1959
      15:53:09.461 FLH: Read block - Writing: 4096 - Total: 3715072 - Buffer size: 1959
      15:53:09.609 FLH: Read block - Writing: 4096 - Total: 3719168 - Buffer size: 1959
      15:53:09.757 FLH: Read block - Writing: 4096 - Total: 3723264 - Buffer size: 1959
      15:53:09.958 FLH: Read block - Writing: 4096 - Total: 3727360 - Buffer size: 1959
      15:53:10.158 FLH: Read block - Writing: 4096 - Total: 3731456 - Buffer size: 1959
      15:53:10.275 FLH: Read block - Writing: 4096 - Total: 3735552 - Buffer size: 1959
      15:53:10.458 FLH: Read block - Writing: 4096 - Total: 3739648 - Buffer size: 1959
      15:53:10.658 FLH: Read block - Writing: 4096 - Total: 3743744 - Buffer size: 1959
      15:53:10.858 FLH: Read block - Writing: 4096 - Total: 3747840 - Buffer size: 1959
      15:53:11.057 FLH: Read block - Writing: 4096 - Total: 3751936 - Buffer size: 1959
      15:53:11.264 FLH: Read block - Writing: 4096 - Total: 3756032 - Buffer size: 1959
      15:53:11.458 FLH: Read block - Writing: 4096 - Total: 3760128 - Buffer size: 1959
      15:53:11.657 FLH: Read block - Writing: 4096 - Total: 3764224 - Buffer size: 1959
      15:53:11.858 FLH: Read block - Writing: 4096 - Total: 3768320 - Buffer size: 1959
      15:53:12.058 FLH: Read block - Writing: 4096 - Total: 3772416 - Buffer size: 1959
      15:53:12.199 FLH: Read block - Writing: 4096 - Total: 3776512 - Buffer size: 1959
      15:53:12.315 FLH: Read block - Writing: 4096 - Total: 3780608 - Buffer size: 1959
      15:53:12.430 FLH: Read block - Writing: 4096 - Total: 3784704 - Buffer size: 1959
      15:53:12.472 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "31", "time_elapsed": 170}}
      15:53:12.565 FLH: Read block - Writing: 4096 - Total: 3788800 - Buffer size: 1959
      15:53:12.758 FLH: Read block - Writing: 4096 - Total: 3792896 - Buffer size: 1959
      15:53:12.958 FLH: Read block - Writing: 4096 - Total: 3796992 - Buffer size: 1959
      15:53:13.158 FLH: Read block - Writing: 4096 - Total: 3801088 - Buffer size: 1959
      15:53:13.274 FLH: Read block - Writing: 4096 - Total: 3805184 - Buffer size: 1959
      15:53:13.559 FLH: Read block - Writing: 4096 - Total: 3809280 - Buffer size: 1959
      15:53:13.758 FLH: Read block - Writing: 4096 - Total: 3813376 - Buffer size: 1959
      15:53:13.958 FLH: Read block - Writing: 4096 - Total: 3817472 - Buffer size: 1959
      15:53:14.158 FLH: Read block - Writing: 4096 - Total: 3821568 - Buffer size: 1959
      15:53:14.274 FLH: Read block - Writing: 4096 - Total: 3825664 - Buffer size: 1959
      15:53:14.458 FLH: Read block - Writing: 4096 - Total: 3829760 - Buffer size: 1959
      15:53:14.609 FLH: Read block - Writing: 4096 - Total: 3833856 - Buffer size: 1959
      15:53:14.756 FLH: Read block - Writing: 4096 - Total: 3837952 - Buffer size: 1959
      15:53:14.957 FLH: Read block - Writing: 4096 - Total: 3842048 - Buffer size: 1959
      15:53:15.158 FLH: Read block - Writing: 4096 - Total: 3846144 - Buffer size: 1959
      15:53:15.273 FLH: Read block - Writing: 4096 - Total: 3850240 - Buffer size: 1959
      15:53:15.457 FLH: Read block - Writing: 4096 - Total: 3854336 - Buffer size: 1959
      15:53:15.657 FLH: Read block - Writing: 4096 - Total: 3858432 - Buffer size: 1959
      15:53:15.858 FLH: Read block - Writing: 4096 - Total: 3862528 - Buffer size: 1959
      15:53:16.057 FLH: Read block - Writing: 4096 - Total: 3866624 - Buffer size: 1959
      15:53:16.264 FLH: Read block - Writing: 4096 - Total: 3870720 - Buffer size: 1959
      15:53:16.458 FLH: Read block - Writing: 4096 - Total: 3874816 - Buffer size: 1959
      15:53:16.658 FLH: Read block - Writing: 4096 - Total: 3878912 - Buffer size: 1959
      15:53:16.858 FLH: Read block - Writing: 4096 - Total: 3883008 - Buffer size: 1959
      15:53:17.058 FLH: Read block - Writing: 4096 - Total: 3887104 - Buffer size: 1959
      15:53:17.206 FLH: Read block - Writing: 4096 - Total: 3891200 - Buffer size: 1959
      15:53:17.318 FLH: Read block - Writing: 4096 - Total: 3895296 - Buffer size: 1959
      15:53:17.430 FLH: Read block - Writing: 4096 - Total: 3899392 - Buffer size: 1959
      15:53:17.558 FLH: Read block - Writing: 4096 - Total: 3903488 - Buffer size: 1959
      15:53:17.671 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "32", "time_elapsed": 175}}
      15:53:17.764 FLH: Read block - Writing: 4096 - Total: 3907584 - Buffer size: 1959
      15:53:17.958 FLH: Read block - Writing: 4096 - Total: 3911680 - Buffer size: 1959
      15:53:18.158 FLH: Read block - Writing: 4096 - Total: 3915776 - Buffer size: 1959
      15:53:18.317 FLH: Read block - Writing: 4096 - Total: 3919872 - Buffer size: 1959
      15:53:18.457 FLH: Read block - Writing: 4096 - Total: 3923968 - Buffer size: 1959
      15:53:18.657 FLH: Read block - Writing: 4096 - Total: 3928064 - Buffer size: 1959
      15:53:18.857 FLH: Read block - Writing: 4096 - Total: 3932160 - Buffer size: 1959
      15:53:18.969 FLH: Read block - Writing: 4096 - Total: 3936256 - Buffer size: 1959
      15:53:19.264 FLH: Read block - Writing: 4096 - Total: 3940352 - Buffer size: 1959
      15:53:19.458 FLH: Read block - Writing: 4096 - Total: 3944448 - Buffer size: 1959
      15:53:19.658 FLH: Read block - Writing: 4096 - Total: 3948544 - Buffer size: 1959
      15:53:19.804 FLH: Read block - Writing: 4096 - Total: 3952640 - Buffer size: 1959
      15:53:19.957 FLH: Read block - Writing: 4096 - Total: 3956736 - Buffer size: 1959
      15:53:20.157 FLH: Read block - Writing: 4096 - Total: 3960832 - Buffer size: 1959
      15:53:20.273 FLH: Read block - Writing: 4096 - Total: 3964928 - Buffer size: 1959
      15:53:20.457 FLH: Read block - Writing: 4096 - Total: 3969024 - Buffer size: 1959
      15:53:20.659 FLH: Read block - Writing: 4096 - Total: 3973120 - Buffer size: 1959
      15:53:20.812 FLH: Read block - Writing: 4096 - Total: 3977216 - Buffer size: 1959
      15:53:20.925 FLH: Read block - Writing: 4096 - Total: 3981312 - Buffer size: 1959
      15:53:21.057 FLH: Read block - Writing: 4096 - Total: 3985408 - Buffer size: 1959
      15:53:21.264 FLH: Read block - Writing: 4096 - Total: 3989504 - Buffer size: 1959
      15:53:21.458 FLH: Read block - Writing: 4096 - Total: 3993600 - Buffer size: 1959
      15:53:21.658 FLH: Read block - Writing: 4096 - Total: 3997696 - Buffer size: 1959
      15:53:21.858 FLH: Read block - Writing: 4096 - Total: 4001792 - Buffer size: 1959
      15:53:22.058 FLH: Read block - Writing: 4096 - Total: 4005888 - Buffer size: 1959
      15:53:22.264 FLH: Read block - Writing: 4096 - Total: 4009984 - Buffer size: 1959
      15:53:22.410 FLH: Read block - Writing: 4096 - Total: 4014080 - Buffer size: 1959
      15:53:22.560 FLH: Read block - Writing: 4096 - Total: 4018176 - Buffer size: 1959
      15:53:22.760 FLH: Read block - Writing: 4096 - Total: 4022272 - Buffer size: 1959
      15:53:22.959 FLH: Read block - Writing: 4096 - Total: 4026368 - Buffer size: 1959
      15:53:23.076 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "33", "time_elapsed": 180}}
      15:53:23.168 FLH: Read block - Writing: 4096 - Total: 4030464 - Buffer size: 1959
      15:53:23.328 FLH: Read block - Writing: 4096 - Total: 4034560 - Buffer size: 1959
      15:53:23.440 FLH: Read block - Writing: 4096 - Total: 4038656 - Buffer size: 1959
      15:53:23.558 FLH: Read block - Writing: 4096 - Total: 4042752 - Buffer size: 1959
      15:53:23.758 FLH: Read block - Writing: 4096 - Total: 4046848 - Buffer size: 1959
      15:53:23.958 FLH: Read block - Writing: 4096 - Total: 4050944 - Buffer size: 1959
      15:53:24.158 FLH: Read block - Writing: 4096 - Total: 4055040 - Buffer size: 1959
      15:53:24.273 FLH: Read block - Writing: 4096 - Total: 4059136 - Buffer size: 1959
      15:53:24.458 FLH: Read block - Writing: 4096 - Total: 4063232 - Buffer size: 1959
      15:53:24.657 FLH: Read block - Writing: 4096 - Total: 4067328 - Buffer size: 1959
      15:53:24.857 FLH: Read block - Writing: 4096 - Total: 4071424 - Buffer size: 1959
      15:53:25.057 FLH: Read block - Writing: 4096 - Total: 4075520 - Buffer size: 1959
      15:53:25.263 FLH: Read block - Writing: 4096 - Total: 4079616 - Buffer size: 1959
      15:53:25.458 FLH: Read block - Writing: 4096 - Total: 4083712 - Buffer size: 1959
      15:53:25.658 FLH: Read block - Writing: 4096 - Total: 4087808 - Buffer size: 1959
      15:53:25.813 FLH: Read block - Writing: 4096 - Total: 4091904 - Buffer size: 1959
      15:53:25.925 FLH: Read block - Writing: 4096 - Total: 4096000 - Buffer size: 1959
      15:53:26.058 FLH: Read block - Writing: 4096 - Total: 4100096 - Buffer size: 1959
      15:53:26.264 FLH: Read block - Writing: 4096 - Total: 4104192 - Buffer size: 1959
      15:53:26.458 FLH: Read block - Writing: 4096 - Total: 4108288 - Buffer size: 1959
      15:53:26.658 FLH: Read block - Writing: 4096 - Total: 4112384 - Buffer size: 1959
      15:53:26.858 FLH: Read block - Writing: 4096 - Total: 4116480 - Buffer size: 1959
      15:53:26.970 FLH: Read block - Writing: 4096 - Total: 4120576 - Buffer size: 1959
      15:53:27.158 FLH: Read block - Writing: 4096 - Total: 4124672 - Buffer size: 1959
      15:53:27.275 FLH: Read block - Writing: 4096 - Total: 4128768 - Buffer size: 1959
      15:53:27.422 FLH: Read block - Writing: 4096 - Total: 4132864 - Buffer size: 1959
      15:53:28.057 FLH: Read block - Writing: 4096 - Total: 4136960 - Buffer size: 1959
      15:53:28.263 FLH: Read block - Writing: 4096 - Total: 4141056 - Buffer size: 1959
      15:53:28.458 FLH: Read block - Writing: 4096 - Total: 4145152 - Buffer size: 1959
      15:53:28.657 FLH: Read block - Writing: 4096 - Total: 4149248 - Buffer size: 1959
      15:53:28.771 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "34", "time_elapsed": 186}}
      15:53:28.864 FLH: Read block - Writing: 4096 - Total: 4153344 - Buffer size: 1959
      15:53:29.058 FLH: Read block - Writing: 4096 - Total: 4157440 - Buffer size: 1959
      15:53:29.263 FLH: Read block - Writing: 4096 - Total: 4161536 - Buffer size: 1959
      15:53:29.458 FLH: Read block - Writing: 4096 - Total: 4165632 - Buffer size: 1959
      15:53:29.658 FLH: Read block - Writing: 4096 - Total: 4169728 - Buffer size: 1959
      15:53:29.858 FLH: Read block - Writing: 4096 - Total: 4173824 - Buffer size: 1959
      15:53:30.000 FLH: Read block - Writing: 4096 - Total: 4177920 - Buffer size: 1959
      15:53:30.158 FLH: Read block - Writing: 4096 - Total: 4182016 - Buffer size: 1959
      15:53:30.273 FLH: Read block - Writing: 4096 - Total: 4186112 - Buffer size: 1959
      15:53:30.458 FLH: Read block - Writing: 4096 - Total: 4190208 - Buffer size: 1959
      15:53:30.658 FLH: Read block - Writing: 4096 - Total: 4194304 - Buffer size: 1959
      15:53:30.858 FLH: Read block - Writing: 4096 - Total: 4198400 - Buffer size: 1959
      15:53:31.458 FLH: Read block - Writing: 4096 - Total: 4202496 - Buffer size: 1959
      15:53:31.657 FLH: Read block - Writing: 4096 - Total: 4206592 - Buffer size: 1959
      15:53:31.857 FLH: Read block - Writing: 4096 - Total: 4210688 - Buffer size: 1959
      15:53:31.970 FLH: Read block - Writing: 4096 - Total: 4214784 - Buffer size: 1959
      15:53:32.158 FLH: Read block - Writing: 4096 - Total: 4218880 - Buffer size: 1959
      15:53:32.274 FLH: Read block - Writing: 4096 - Total: 4222976 - Buffer size: 1959
      15:53:32.416 FLH: Read block - Writing: 4096 - Total: 4227072 - Buffer size: 1959
      15:53:32.558 FLH: Read block - Writing: 4096 - Total: 4231168 - Buffer size: 1959
      15:53:32.757 FLH: Read block - Writing: 4096 - Total: 4235264 - Buffer size: 1959
      15:53:32.958 FLH: Read block - Writing: 4096 - Total: 4239360 - Buffer size: 1959
      15:53:33.110 FLH: Read block - Writing: 4096 - Total: 4243456 - Buffer size: 1959
      15:53:33.265 FLH: Read block - Writing: 4096 - Total: 4247552 - Buffer size: 1959
      15:53:33.460 FLH: Read block - Writing: 4096 - Total: 4251648 - Buffer size: 1959
      15:53:33.660 FLH: Read block - Writing: 4096 - Total: 4255744 - Buffer size: 1959
      15:53:33.860 FLH: Read block - Writing: 4096 - Total: 4259840 - Buffer size: 1959
      15:53:33.971 FLH: Read block - Writing: 4096 - Total: 4263936 - Buffer size: 1959
      15:53:34.760 FLH: Read block - Writing: 4096 - Total: 4268032 - Buffer size: 1959
      15:53:34.901 FLH: Read block - Writing: 4096 - Total: 4272128 - Buffer size: 1959
      15:53:34.928 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "35", "time_elapsed": 192}}
      15:53:35.021 FLH: Read block - Writing: 4096 - Total: 4276224 - Buffer size: 1959
      15:53:35.158 FLH: Read block - Writing: 4096 - Total: 4280320 - Buffer size: 1959
      15:53:35.274 FLH: Read block - Writing: 4096 - Total: 4284416 - Buffer size: 1959
      15:53:35.457 FLH: Read block - Writing: 4096 - Total: 4288512 - Buffer size: 1959
      15:53:35.609 FLH: Read block - Writing: 4096 - Total: 4292608 - Buffer size: 1959
      15:53:35.757 FLH: Read block - Writing: 4096 - Total: 4296704 - Buffer size: 1959
      15:53:35.958 FLH: Read block - Writing: 4096 - Total: 4300800 - Buffer size: 1959
      15:53:36.070 FLH: Read block - Writing: 4096 - Total: 4304896 - Buffer size: 1959
      15:53:36.265 FLH: Read block - Writing: 4096 - Total: 4308992 - Buffer size: 1959
      15:53:36.457 FLH: Read block - Writing: 4096 - Total: 4313088 - Buffer size: 1959
      15:53:36.658 FLH: Read block - Writing: 4096 - Total: 4317184 - Buffer size: 1959
      15:53:36.859 FLH: Read block - Writing: 4096 - Total: 4321280 - Buffer size: 1959
      15:53:37.057 FLH: Read block - Writing: 4096 - Total: 4325376 - Buffer size: 1959
      15:53:37.265 FLH: Read block - Writing: 4096 - Total: 4329472 - Buffer size: 1959
      15:53:37.962 FLH: Read block - Writing: 4096 - Total: 4333568 - Buffer size: 1959
      15:53:38.116 FLH: Read block - Writing: 4096 - Total: 4337664 - Buffer size: 1959
      15:53:38.263 FLH: Read block - Writing: 4096 - Total: 4341760 - Buffer size: 1959
      15:53:38.457 FLH: Read block - Writing: 4096 - Total: 4345856 - Buffer size: 1959
      15:53:38.658 FLH: Read block - Writing: 4096 - Total: 4349952 - Buffer size: 1959
      15:53:38.858 FLH: Read block - Writing: 4096 - Total: 4354048 - Buffer size: 1959
      15:53:39.058 FLH: Read block - Writing: 4096 - Total: 4358144 - Buffer size: 1959
      15:53:39.264 FLH: Read block - Writing: 4096 - Total: 4362240 - Buffer size: 1959
      15:53:39.458 FLH: Read block - Writing: 4096 - Total: 4366336 - Buffer size: 1959
      15:53:39.658 FLH: Read block - Writing: 4096 - Total: 4370432 - Buffer size: 1959
      15:53:39.857 FLH: Read block - Writing: 4096 - Total: 4374528 - Buffer size: 1959
      15:53:39.969 FLH: Read block - Writing: 4096 - Total: 4378624 - Buffer size: 1959
      15:53:40.110 FLH: Read block - Writing: 4096 - Total: 4382720 - Buffer size: 1959
      15:53:40.263 FLH: Read block - Writing: 4096 - Total: 4386816 - Buffer size: 1959
      15:53:40.459 FLH: Read block - Writing: 4096 - Total: 4390912 - Buffer size: 1959
      15:53:40.612 FLH: Read block - Writing: 4096 - Total: 4395008 - Buffer size: 1959
      15:53:41.177 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "36", "time_elapsed": 198}}
      15:53:41.269 FLH: Read block - Writing: 4096 - Total: 4399104 - Buffer size: 1959
      15:53:41.458 FLH: Read block - Writing: 4096 - Total: 4403200 - Buffer size: 1959
      15:53:41.658 FLH: Read block - Writing: 4096 - Total: 4407296 - Buffer size: 1959
      15:53:41.858 FLH: Read block - Writing: 4096 - Total: 4411392 - Buffer size: 1959
      15:53:42.058 FLH: Read block - Writing: 4096 - Total: 4415488 - Buffer size: 1959
      15:53:42.264 FLH: Read block - Writing: 4096 - Total: 4419584 - Buffer size: 1959
      15:53:42.458 FLH: Read block - Writing: 4096 - Total: 4423680 - Buffer size: 1959
      15:53:42.678 FLH: Read block - Writing: 4096 - Total: 4427776 - Buffer size: 1959
      15:53:42.858 FLH: Read block - Writing: 4096 - Total: 4431872 - Buffer size: 1959
      15:53:43.010 FLH: Read block - Writing: 4096 - Total: 4435968 - Buffer size: 1959
      15:53:43.160 FLH: Read block - Writing: 4096 - Total: 4440064 - Buffer size: 1959
      15:53:43.275 FLH: Read block - Writing: 4096 - Total: 4444160 - Buffer size: 1959
      15:53:43.460 FLH: Read block - Writing: 4096 - Total: 4448256 - Buffer size: 1959
      15:53:43.660 FLH: Read block - Writing: 4096 - Total: 4452352 - Buffer size: 1959
      15:53:43.859 FLH: Read block - Writing: 4096 - Total: 4456448 - Buffer size: 1959
      15:53:43.971 FLH: Read block - Writing: 4096 - Total: 4460544 - Buffer size: 1959
      15:53:44.760 FLH: Read block - Writing: 4096 - Total: 4464640 - Buffer size: 1959
      15:53:44.960 FLH: Read block - Writing: 4096 - Total: 4468736 - Buffer size: 1959
      15:53:45.106 FLH: Read block - Writing: 4096 - Total: 4472832 - Buffer size: 1959
      15:53:45.263 FLH: Read block - Writing: 4096 - Total: 4476928 - Buffer size: 1959
      15:53:45.418 FLH: Read block - Writing: 4096 - Total: 4481024 - Buffer size: 1959
      15:53:45.557 FLH: Read block - Writing: 4096 - Total: 4485120 - Buffer size: 1959
      15:53:45.758 FLH: Read block - Writing: 4096 - Total: 4489216 - Buffer size: 1959
      15:53:45.958 FLH: Read block - Writing: 4096 - Total: 4493312 - Buffer size: 1959
      15:53:46.158 FLH: Read block - Writing: 4096 - Total: 4497408 - Buffer size: 1959
      15:53:46.273 FLH: Read block - Writing: 4096 - Total: 4501504 - Buffer size: 1959
      15:53:46.458 FLH: Read block - Writing: 4096 - Total: 4505600 - Buffer size: 1959
      15:53:46.657 FLH: Read block - Writing: 4096 - Total: 4509696 - Buffer size: 1959
      15:53:46.858 FLH: Read block - Writing: 4096 - Total: 4513792 - Buffer size: 1959
      15:53:46.971 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "37", "time_elapsed": 204}}
      15:53:47.064 FLH: Read block - Writing: 4096 - Total: 4517888 - Buffer size: 1959
      15:53:47.264 FLH: Read block - Writing: 4096 - Total: 4521984 - Buffer size: 1959
      15:53:47.458 FLH: Read block - Writing: 4096 - Total: 4526080 - Buffer size: 1959
      15:53:48.158 FLH: Read block - Writing: 4096 - Total: 4530176 - Buffer size: 1959
      15:53:48.274 FLH: Read block - Writing: 4096 - Total: 4534272 - Buffer size: 1959
      15:53:48.457 FLH: Read block - Writing: 4096 - Total: 4538368 - Buffer size: 1959
      15:53:48.658 FLH: Read block - Writing: 4096 - Total: 4542464 - Buffer size: 1959
      15:53:48.859 FLH: Read block - Writing: 4096 - Total: 4546560 - Buffer size: 1959
      15:53:48.971 FLH: Read block - Writing: 4096 - Total: 4550656 - Buffer size: 1959
      15:53:49.158 FLH: Read block - Writing: 4096 - Total: 4554752 - Buffer size: 1959
      15:53:49.275 FLH: Read block - Writing: 4096 - Total: 4558848 - Buffer size: 1959
      15:53:49.458 FLH: Read block - Writing: 4096 - Total: 4562944 - Buffer size: 1959
      15:53:49.657 FLH: Read block - Writing: 4096 - Total: 4567040 - Buffer size: 1959
      15:53:49.858 FLH: Read block - Writing: 4096 - Total: 4571136 - Buffer size: 1959
      15:53:50.058 FLH: Read block - Writing: 4096 - Total: 4575232 - Buffer size: 1959
      15:53:50.217 FLH: Read block - Writing: 4096 - Total: 4579328 - Buffer size: 1959
      15:53:50.370 FLH: Read block - Writing: 4096 - Total: 4583424 - Buffer size: 1959
      15:53:50.482 FLH: Read block - Writing: 4096 - Total: 4587520 - Buffer size: 1959
      15:53:50.658 FLH: Read block - Writing: 4096 - Total: 4591616 - Buffer size: 1959
      15:53:51.358 FLH: Read block - Writing: 4096 - Total: 4595712 - Buffer size: 1959
      15:53:51.559 FLH: Read block - Writing: 4096 - Total: 4599808 - Buffer size: 1959
      15:53:51.758 FLH: Read block - Writing: 4096 - Total: 4603904 - Buffer size: 1959
      15:53:51.958 FLH: Read block - Writing: 4096 - Total: 4608000 - Buffer size: 1959
      15:53:52.158 FLH: Read block - Writing: 4096 - Total: 4612096 - Buffer size: 1959
      15:53:52.273 FLH: Read block - Writing: 4096 - Total: 4616192 - Buffer size: 1959
      15:53:52.458 FLH: Read block - Writing: 4096 - Total: 4620288 - Buffer size: 1959
      15:53:52.657 FLH: Read block - Writing: 4096 - Total: 4624384 - Buffer size: 1959
      15:53:52.858 FLH: Read block - Writing: 4096 - Total: 4628480 - Buffer size: 1959
      15:53:53.001 FLH: Read block - Writing: 4096 - Total: 4632576 - Buffer size: 1959
      15:53:53.159 FLH: Read block - Writing: 4096 - Total: 4636672 - Buffer size: 1959
      15:53:53.189 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "38", "time_elapsed": 210}}
      15:53:53.281 FLH: Read block - Writing: 4096 - Total: 4640768 - Buffer size: 1959
      15:53:53.459 FLH: Read block - Writing: 4096 - Total: 4644864 - Buffer size: 1959
      15:53:53.657 FLH: Read block - Writing: 4096 - Total: 4648960 - Buffer size: 1959
      15:53:53.857 FLH: Read block - Writing: 4096 - Total: 4653056 - Buffer size: 1959
      15:53:54.057 FLH: Read block - Writing: 4096 - Total: 4657152 - Buffer size: 1959
      15:53:54.758 FLH: Read block - Writing: 4096 - Total: 4661248 - Buffer size: 1959
      15:53:54.958 FLH: Read block - Writing: 4096 - Total: 4665344 - Buffer size: 1959
      15:53:55.111 FLH: Read block - Writing: 4096 - Total: 4669440 - Buffer size: 1959
      15:53:55.266 FLH: Read block - Writing: 4096 - Total: 4673536 - Buffer size: 1959
      15:53:55.407 FLH: Read block - Writing: 4096 - Total: 4677632 - Buffer size: 1959
      15:53:55.559 FLH: Read block - Writing: 4096 - Total: 4681728 - Buffer size: 1959
      15:53:55.758 FLH: Read block - Writing: 4096 - Total: 4685824 - Buffer size: 1959
      15:53:55.958 FLH: Read block - Writing: 4096 - Total: 4689920 - Buffer size: 1959
      15:53:56.158 FLH: Read block - Writing: 4096 - Total: 4694016 - Buffer size: 1959
      15:53:56.274 FLH: Read block - Writing: 4096 - Total: 4698112 - Buffer size: 1959
      15:53:56.458 FLH: Read block - Writing: 4096 - Total: 4702208 - Buffer size: 1959
      15:53:56.657 FLH: Read block - Writing: 4096 - Total: 4706304 - Buffer size: 1959
      15:53:56.858 FLH: Read block - Writing: 4096 - Total: 4710400 - Buffer size: 1959
      15:53:57.058 FLH: Read block - Writing: 4096 - Total: 4714496 - Buffer size: 1959
      15:53:57.264 FLH: Read block - Writing: 4096 - Total: 4718592 - Buffer size: 1959
      15:53:57.460 FLH: Read block - Writing: 4096 - Total: 4722688 - Buffer size: 1959
      15:53:58.160 FLH: Read block - Writing: 4096 - Total: 4726784 - Buffer size: 1959
      15:53:58.275 FLH: Read block - Writing: 4096 - Total: 4730880 - Buffer size: 1959
      15:53:58.459 FLH: Read block - Writing: 4096 - Total: 4734976 - Buffer size: 1959
      15:53:58.660 FLH: Read block - Writing: 4096 - Total: 4739072 - Buffer size: 1959
      15:53:58.859 FLH: Read block - Writing: 4096 - Total: 4743168 - Buffer size: 1959
      15:53:58.971 FLH: Read block - Writing: 4096 - Total: 4747264 - Buffer size: 1959
      15:53:59.160 FLH: Read block - Writing: 4096 - Total: 4751360 - Buffer size: 1959
      15:53:59.275 FLH: Read block - Writing: 4096 - Total: 4755456 - Buffer size: 1959
      15:53:59.459 FLH: Read block - Writing: 4096 - Total: 4759552 - Buffer size: 1959
      15:53:59.573 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "39", "time_elapsed": 217}}
      15:53:59.666 FLH: Read block - Writing: 4096 - Total: 4763648 - Buffer size: 1959
      15:53:59.860 FLH: Read block - Writing: 4096 - Total: 4767744 - Buffer size: 1959
      15:54:00.015 FLH: Read block - Writing: 4096 - Total: 4771840 - Buffer size: 1959
      15:54:00.158 FLH: Read block - Writing: 4096 - Total: 4775936 - Buffer size: 1959
      15:54:00.273 FLH: Read block - Writing: 4096 - Total: 4780032 - Buffer size: 1959
      15:54:00.458 FLH: Read block - Writing: 4096 - Total: 4784128 - Buffer size: 1959
      15:54:00.605 FLH: Read block - Writing: 4096 - Total: 4788224 - Buffer size: 1959
      • A australien
        @armilar
        das gleiche, hab übrigens gesehen die Fehlermeldung ist doch da.
        00:00:00.001 HDW: ESP32-D0WD-V3 v3.0
        00:00:00.017 UFS: FlashFS mounted with 288 kB free
        00:00:00.026 CFG: Loaded from File, Anzahl 1518
        00:00:00.035 QPC: Count 1
        00:00:00.035 CFG: CR 430/699, Busy 0
        00:00:00.041 TYA: Active=0
        00:00:00.045 ROT: Mode 1
        00:00:00.069 CFG: No '*.autoconf' file found
        00:00:00.073 BRY: Berry initialized, RAM used 3493 bytes
        00:00:00.079 BRY: No 'preinit.be'
        00:00:00.081 SRC: Restart
        00:00:00.085 Projekt tasmota - Tasmota Version 15.0.1(release-tasmota32)-3_1_3(2025.06.14 10:39:16)
        00:00:00.218 NXP: Initializing Driver
        00:00:00.220 BRY: Serial UART2
        00:00:00.223 BRY: Successfully loaded 'autoexec.be'
        00:00:00.310 WIF: Verbindungsversuch…
        00:00:00.948 WIF: verbinden mit AP1 FR@smart Channel 9 BSSId 7E:8A:20:51:6B:CA in Modus HT40 als NSPanel-1-5140...
        00:00:01.077 WIF: IPv4 10.68.0.179, mask 255.255.0.0, gateway 10.68.0.1
        00:00:03.476 WIF: IPv6 Local fe80::e2e2:e6ff:fe0c:1414%st1
        00:00:03.498 WIF: verbunden
        00:00:03.755 HTP: Web server active on NSPanel-1-5140 with IP address 10.68.0.179
        00:00:04.004 RTC: UTC 2025-09-12T14:50:15Z, DST 2025-03-30T02:00:00, STD 2025-10-26T03:00:00
        15:50:15.000 RTC: Synced by NTP
        15:50:15.745 MQT: Verbindungsversuch…
        15:50:15.761 MQT: verbunden
        15:50:15.764 MQT: SmartHome/NSPanel_1/tele/LWT = Online (beibehalten)
        15:50:15.765 MQT: SmartHome/NSPanel_1/cmnd/POWER =
        15:50:15.766 MQT: abonniere SmartHome/NSPanel_1/cmnd/#
        15:50:15.767 MQT: abonniere SmartHome/tasmotas/cmnd/#
        15:50:15.768 MQT: abonniere cmnd/NSPanel_1_fb/#
        15:50:15.770 MQT: SmartHome/NSPanel_1/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"15.0.1(release-tasmota32)","FallbackTopic":"cmnd/NSPanel_1_fb/","GroupTopic":"SmartHome/tasmotas/cmnd/"}}
        15:50:15.784 MQT: SmartHome/NSPanel_1/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-1-5140","IPAddress":"10.68.0.179","IP6Global":"","IP6Local":"fe80::e2e2:e6ff:fe0c:1414%st1"}}
        15:50:15.809 MQT: SmartHome/NSPanel_1/tele/INFO3 = {"Info3":{"RestartReason":"Vbat power on reset","BootCount":172}}
        15:50:15.813 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
        15:50:15.824 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
        15:50:15.826 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER2":"OFF"}
        15:50:15.827 MQT: SmartHome/NSPanel_1/stat/POWER2 = OFF
        15:50:16.050 SRC: MQTT
        15:50:16.050 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
        15:50:16.061 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
        15:50:16.065 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
        15:50:16.097 SRC: MQTT
        15:50:16.098 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
        15:50:16.100 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
        15:50:16.101 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
        15:50:16.148 SRC: MQTT
        15:50:16.149 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
        15:50:16.159 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
        15:50:16.163 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
        15:50:16.198 SRC: MQTT
        15:50:16.198 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
        15:50:16.202 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
        15:50:16.205 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
        15:50:16.248 SRC: MQTT
        15:50:16.249 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
        15:50:16.259 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
        15:50:16.263 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
        15:50:16.298 SRC: MQTT
        15:50:16.298 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
        15:50:16.302 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
        15:50:16.305 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
        15:50:17.799 SRC: MQTT
        15:50:17.800 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
        15:50:17.813 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
        15:50:17.817 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
        15:50:17.849 SRC: MQTT
        15:50:17.850 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
        15:50:17.852 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
        15:50:17.853 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
        15:50:17.956 QPC: Reset
        15:50:19.949 APP: Startvorgänge 172
        15:50:19.956 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2025-09-12T15:50:19","Uptime":"0T00:00:09","UptimeSec":9,"Heap":146,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":237,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":212},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FR@smart","BSSId":"7E:8A:20:51:6B:CA","Channel":9,"Mode":"HT40","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:04"}}
        15:50:20.001 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2025-09-12T15:50:19","ANALOG":{"Temperature1":28.5},"ESP32":{"Temperature":58.9},"TempUnit":"C"}
        15:50:20.424 CFG: Saved, Anzahl 1519, Bytes 4096
        15:50:20.441 CMD: FlashNextionAdv0 http://nspanel.de/nspanel-v5.0.0.tft
        15:50:20.442 SRC: WebConsole from 10.68.0.156
        15:50:20.442 CMD: Grp 0, Cmd 'FLASHNEXTIONADV', Idx 0, Len 36, Pld -99, Data 'http://nspanel.de/nspanel-v5.0.0.tft'
        15:50:20.449 MQT: SmartHome/NSPanel_1/stat/RESULT = {"FlashNextionAdv":"Done"}
        15:50:20.482 FLH: host: nspanel.de, port: 80, get: /nspanel-v5.0.0.tft
        15:50:20.539 FLH: Connected:true
        15:50:20.641 FLH: Retry 2
        15:50:20.854 FLH: HTTP Respose is 200 OK or 206 Partial Content
        15:50:20.855 FLH: Flash file size: 12197684
        15:50:20.856 SRC: Berry
        15:50:20.857 CMD: Grp 0, Cmd 'RULETIMER', Idx 3, Len 1, Pld 0, Data '0'
        15:50:20.863 MQT: SmartHome/NSPanel_1/stat/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
        15:50:20.868 SRC: Berry
        15:50:20.869 CMD: Grp 0, Cmd 'RULE', Idx 3, Len 1, Pld 0, Data '0'
        15:50:20.873 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
        15:50:20.888 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
        15:50:20.892 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
        15:50:20.894 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
        15:50:20.900 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
        15:50:22.280 FLH: Send (High Speed) flash start
        15:50:22.286 NXP: Nextion command sent = bytes('77686D692D777269732031323139373638342C3932313630302C72657330FFFF...')
        15:50:22.309 BRY: Serial UART2
        15:50:22.666 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "0", "time_elapsed": 0}}
        15:50:22.759 FLH: Read block - Writing: 4096 - Total: 4096 - Buffer size: 1395
        15:50:22.859 FLH: Waiting offset...
        15:50:27.659 FLH: Flash offset marker 0
        15:50:27.760 FLH: Read block - Writing: 4096 - Total: 8192 - Buffer size: 1395
        15:50:27.958 FLH: Read block - Writing: 4096 - Total: 12288 - Buffer size: 1395
        15:50:28.090 FLH: Read block - Writing: 4096 - Total: 16384 - Buffer size: 1395
        15:50:28.200 FLH: Read block - Writing: 4096 - Total: 20480 - Buffer size: 1395
        15:50:28.314 FLH: Read block - Writing: 4096 - Total: 24576 - Buffer size: 1395
        15:50:28.426 FLH: Read block - Writing: 4096 - Total: 28672 - Buffer size: 1395
        15:50:28.533 FLH: Read block - Writing: 4096 - Total: 32768 - Buffer size: 1395
        15:50:28.642 FLH: Read block - Writing: 4096 - Total: 36864 - Buffer size: 1395
        15:50:28.751 FLH: Read block - Writing: 4096 - Total: 40960 - Buffer size: 1395
        15:50:28.859 FLH: Read block - Writing: 4096 - Total: 45056 - Buffer size: 1395
        15:50:28.971 FLH: Read block - Writing: 4096 - Total: 49152 - Buffer size: 1395
        15:50:29.080 FLH: Read block - Writing: 4096 - Total: 53248 - Buffer size: 1395
        15:50:29.189 FLH: Read block - Writing: 4096 - Total: 57344 - Buffer size: 1395
        15:50:29.301 FLH: Read block - Writing: 4096 - Total: 61440 - Buffer size: 1395
        15:50:29.409 FLH: Read block - Writing: 4096 - Total: 65536 - Buffer size: 1395
        15:50:29.522 FLH: Read block - Writing: 4096 - Total: 69632 - Buffer size: 1395
        15:50:29.858 FLH: Read block - Writing: 4096 - Total: 73728 - Buffer size: 1395
        15:50:29.968 FLH: Read block - Writing: 4096 - Total: 77824 - Buffer size: 1395
        15:50:30.158 FLH: Read block - Writing: 4096 - Total: 81920 - Buffer size: 1395
        15:50:30.273 FLH: Read block - Writing: 4096 - Total: 86016 - Buffer size: 1395
        15:50:30.456 FLH: Read block - Writing: 4096 - Total: 90112 - Buffer size: 1395
        15:51:30.657 FLH: Read block - Writing: 4096 - Total: 1478656 - Buffer size: 1395
        15:51:30.858 FLH: Read block - Writing: 4096 - Total: 1482752 - Buffer size: 1395
        15:51:31.058 FLH: Read block - Writing: 4096 - Total: 1486848 - Buffer size: 1395
        15:51:31.168 FLH: Read block - Writing: 4096 - Total: 1490944 - Buffer size: 1395
        15:51:31.280 FLH: Read block - Writing: 4096 - Total: 1495040 - Buffer size: 1395
        15:51:31.458 FLH: Read block - Writing: 4096 - Total: 1499136 - Buffer size: 1395
        15:51:31.656 FLH: Read block - Writing: 4096 - Total: 1503232 - Buffer size: 1395
        15:51:31.858 FLH: Read block - Writing: 4096 - Total: 1507328 - Buffer size: 1395
        15:51:32.058 FLH: Read block - Writing: 4096 - Total: 1511424 - Buffer size: 1395
        15:51:32.263 FLH: Read block - Writing: 4096 - Total: 1515520 - Buffer size: 1395
        15:51:32.458 FLH: Read block - Writing: 4096 - Total: 1519616 - Buffer size: 1395
        15:51:32.657 FLH: Read block - Writing: 4096 - Total: 1523712 - Buffer size: 1395
        15:51:32.858 FLH: Read block - Writing: 4096 - Total: 1527808 - Buffer size: 1395
        15:51:32.970 FLH: Read block - Writing: 4096 - Total: 1531904 - Buffer size: 1395
        15:51:33.158 FLH: Read block - Writing: 4096 - Total: 1536000 - Buffer size: 1395
        15:51:33.275 FLH: Read block - Writing: 4096 - Total: 1540096 - Buffer size: 1395
        15:51:33.457 FLH: Read block - Writing: 4096 - Total: 1544192 - Buffer size: 1395
        15:51:33.658 FLH: Read block - Writing: 4096 - Total: 1548288 - Buffer size: 1395
        15:51:33.856 FLH: Read block - Writing: 4096 - Total: 1552384 - Buffer size: 1395
        15:51:33.969 FLH: Read block - Writing: 4096 - Total: 1556480 - Buffer size: 1395
        15:51:34.157 FLH: Read block - Writing: 4096 - Total: 1560576 - Buffer size: 1395
        15:51:34.271 FLH: Read block - Writing: 4096 - Total: 1564672 - Buffer size: 1395
        15:51:34.457 FLH: Read block - Writing: 4096 - Total: 1568768 - Buffer size: 1395
        15:51:34.657 FLH: Read block - Writing: 4096 - Total: 1572864 - Buffer size: 1395
        15:51:34.857 FLH: Read block - Writing: 4096 - Total: 1576960 - Buffer size: 1395
        15:51:35.058 FLH: Read block - Writing: 4096 - Total: 1581056 - Buffer size: 1395
        15:51:35.264 FLH: Read block - Writing: 4096 - Total: 1585152 - Buffer size: 1395
        15:51:35.456 FLH: Read block - Writing: 4096 - Total: 1589248 - Buffer size: 1395
        15:51:35.571 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "13", "time_elapsed": 73}}
        15:51:35.664 FLH: Read block - Writing: 4096 - Total: 1593344 - Buffer size: 1395
        15:51:35.858 FLH: Read block - Writing: 4096 - Total: 1597440 - Buffer size: 1395
        15:51:35.968 FLH: Read block - Writing: 4096 - Total: 1601536 - Buffer size: 1395
        15:51:36.158 FLH: Read block - Writing: 4096 - Total: 1605632 - Buffer size: 1395
        15:51:36.273 FLH: Read block - Writing: 4096 - Total: 1609728 - Buffer size: 1395
        15:51:36.456 FLH: Read block - Writing: 4096 - Total: 1613824 - Buffer size: 1395
        15:51:36.658 FLH: Read block - Writing: 4096 - Total: 1617920 - Buffer size: 1395
        15:51:36.858 FLH: Read block - Writing: 4096 - Total: 1622016 - Buffer size: 1395
        15:51:36.968 FLH: Read block - Writing: 4096 - Total: 1626112 - Buffer size: 1395
        15:51:37.158 FLH: Read block - Writing: 4096 - Total: 1630208 - Buffer size: 1395
        15:51:37.273 FLH: Read block - Writing: 4096 - Total: 1634304 - Buffer size: 1395
        15:51:37.457 FLH: Read block - Writing: 4096 - Total: 1638400 - Buffer size: 1395
        15:51:37.657 FLH: Read block - Writing: 4096 - Total: 1642496 - Buffer size: 1395
        15:51:37.858 FLH: Read block - Writing: 4096 - Total: 1646592 - Buffer size: 1395
        15:51:37.969 FLH: Read block - Writing: 4096 - Total: 1650688 - Buffer size: 1395
        15:51:38.157 FLH: Read block - Writing: 4096 - Total: 1654784 - Buffer size: 1395
        15:51:38.273 FLH: Read block - Writing: 4096 - Total: 1658880 - Buffer size: 1395
        15:51:38.456 FLH: Read block - Writing: 4096 - Total: 1662976 - Buffer size: 1395
        15:51:38.657 FLH: Read block - Writing: 4096 - Total: 1667072 - Buffer size: 1395
        15:51:38.857 FLH: Read block - Writing: 4096 - Total: 1671168 - Buffer size: 1395
        15:51:38.967 FLH: Read block - Writing: 4096 - Total: 1675264 - Buffer size: 311
        15:51:39.157 FLH: Read block - Writing: 4096 - Total: 1679360 - Buffer size: 311
        15:51:39.325 FLH: Read block - Writing: 4096 - Total: 1683456 - Buffer size: 1959
        15:51:39.439 FLH: Read block - Writing: 4096 - Total: 1687552 - Buffer size: 1959
        15:51:39.558 FLH: Read block - Writing: 4096 - Total: 1691648 - Buffer size: 1959
        15:51:39.758 FLH: Read block - Writing: 4096 - Total: 1695744 - Buffer size: 1959
        15:51:39.958 FLH: Read block - Writing: 4096 - Total: 1699840 - Buffer size: 1959
        15:51:40.158 FLH: Read block - Writing: 4096 - Total: 1703936 - Buffer size: 1959
        15:51:40.272 FLH: Read block - Writing: 4096 - Total: 1708032 - Buffer size: 1959
        15:51:40.472 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "14", "time_elapsed": 78}}
        15:51:40.565 FLH: Read block - Writing: 4096 - Total: 1712128 - Buffer size: 1959
        15:51:40.758 FLH: Read block - Writing: 4096 - Total: 1716224 - Buffer size: 1959
        15:51:40.958 FLH: Read block - Writing: 4096 - Total: 1720320 - Buffer size: 1959
        15:51:41.158 FLH: Read block - Writing: 4096 - Total: 1724416 - Buffer size: 1959
        15:51:41.273 FLH: Read block - Writing: 4096 - Total: 1728512 - Buffer size: 1959
        15:51:41.458 FLH: Read block - Writing: 4096 - Total: 1732608 - Buffer size: 1959
        15:51:41.657 FLH: Read block - Writing: 4096 - Total: 1736704 - Buffer size: 1959
        15:51:41.859 FLH: Read block - Writing: 4096 - Total: 1740800 - Buffer size: 1959
        15:51:41.971 FLH: Read block - Writing: 4096 - Total: 1744896 - Buffer size: 1959
        15:51:42.158 FLH: Read block - Writing: 4096 - Total: 1748992 - Buffer size: 1959
        15:51:42.275 FLH: Read block - Writing: 4096 - Total: 1753088 - Buffer size: 1959
        15:51:42.458 FLH: Read block - Writing: 4096 - Total: 1757184 - Buffer size: 1959
        15:51:42.660 FLH: Read block - Writing: 4096 - Total: 1761280 - Buffer size: 1959
        15:51:42.911 FLH: Read block - Writing: 4096 - Total: 1765376 - Buffer size: 1959
        15:51:43.023 FLH: Read block - Writing: 4096 - Total: 1769472 - Buffer size: 1959
        15:51:43.157 FLH: Read block - Writing: 4096 - Total: 1773568 - Buffer size: 1959
        15:51:43.458 FLH: Read block - Writing: 4096 - Total: 1777664 - Buffer size: 1959
        15:51:43.657 FLH: Read block - Writing: 4096 - Total: 1781760 - Buffer size: 1959
        15:51:43.857 FLH: Read block - Writing: 4096 - Total: 1785856 - Buffer size: 1959
        15:51:43.969 FLH: Read block - Writing: 4096 - Total: 1789952 - Buffer size: 1959
        15:51:44.157 FLH: Read block - Writing: 4096 - Total: 1794048 - Buffer size: 1959
        15:51:44.272 FLH: Read block - Writing: 4096 - Total: 1798144 - Buffer size: 1959
        15:51:44.457 FLH: Read block - Writing: 4096 - Total: 1802240 - Buffer size: 1959
        15:51:44.658 FLH: Read block - Writing: 4096 - Total: 1806336 - Buffer size: 1959
        15:51:44.858 FLH: Read block - Writing: 4096 - Total: 1810432 - Buffer size: 1959
        15:51:45.058 FLH: Read block - Writing: 4096 - Total: 1814528 - Buffer size: 1959
        15:51:45.263 FLH: Read block - Writing: 4096 - Total: 1818624 - Buffer size: 1959
        15:51:45.410 FLH: Read block - Writing: 4096 - Total: 1822720 - Buffer size: 1959
        15:51:45.559 FLH: Read block - Writing: 4096 - Total: 1826816 - Buffer size: 1959
        15:51:45.758 FLH: Read block - Writing: 4096 - Total: 1830912 - Buffer size: 1959
        15:51:45.872 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "15", "time_elapsed": 83}}
        15:51:45.965 FLH: Read block - Writing: 4096 - Total: 1835008 - Buffer size: 1959
        15:51:46.158 FLH: Read block - Writing: 4096 - Total: 1839104 - Buffer size: 1959
        15:51:46.360 FLH: Read block - Writing: 4096 - Total: 1843200 - Buffer size: 1959
        15:51:46.558 FLH: Read block - Writing: 4096 - Total: 1847296 - Buffer size: 1959
        15:51:46.758 FLH: Read block - Writing: 4096 - Total: 1851392 - Buffer size: 1959
        15:51:46.958 FLH: Read block - Writing: 4096 - Total: 1855488 - Buffer size: 1959
        15:51:47.158 FLH: Read block - Writing: 4096 - Total: 1859584 - Buffer size: 1959
        15:51:47.273 FLH: Read block - Writing: 4096 - Total: 1863680 - Buffer size: 1959
        15:51:47.458 FLH: Read block - Writing: 4096 - Total: 1867776 - Buffer size: 1959
        15:51:47.658 FLH: Read block - Writing: 4096 - Total: 1871872 - Buffer size: 1959
        15:51:47.857 FLH: Read block - Writing: 4096 - Total: 1875968 - Buffer size: 1959
        15:51:48.058 FLH: Read block - Writing: 4096 - Total: 1880064 - Buffer size: 1959
        15:51:48.264 FLH: Read block - Writing: 4096 - Total: 1884160 - Buffer size: 1959
        15:51:48.458 FLH: Read block - Writing: 4096 - Total: 1888256 - Buffer size: 1959
        15:51:48.658 FLH: Read block - Writing: 4096 - Total: 1892352 - Buffer size: 1959
        15:51:48.858 FLH: Read block - Writing: 4096 - Total: 1896448 - Buffer size: 1959
        15:51:49.057 FLH: Read block - Writing: 4096 - Total: 1900544 - Buffer size: 1959
        15:51:49.263 FLH: Read block - Writing: 4096 - Total: 1904640 - Buffer size: 1959
        15:51:49.458 FLH: Read block - Writing: 4096 - Total: 1908736 - Buffer size: 1959
        15:51:49.658 FLH: Read block - Writing: 4096 - Total: 1912832 - Buffer size: 1959
        15:51:49.858 FLH: Read block - Writing: 4096 - Total: 1916928 - Buffer size: 1959
        15:51:50.058 FLH: Read block - Writing: 4096 - Total: 1921024 - Buffer size: 1959
        15:51:50.264 FLH: Read block - Writing: 4096 - Total: 1925120 - Buffer size: 1959
        15:51:50.411 FLH: Read block - Writing: 4096 - Total: 1929216 - Buffer size: 1959
        15:51:50.558 FLH: Read block - Writing: 4096 - Total: 1933312 - Buffer size: 1959
        15:51:50.757 FLH: Read block - Writing: 4096 - Total: 1937408 - Buffer size: 1959
        15:51:50.956 FLH: Read block - Writing: 4096 - Total: 1941504 - Buffer size: 1959
        15:51:51.157 FLH: Read block - Writing: 4096 - Total: 1945600 - Buffer size: 1959
        15:51:51.273 FLH: Read block - Writing: 4096 - Total: 1949696 - Buffer size: 1959
        15:51:51.457 FLH: Read block - Writing: 4096 - Total: 1953792 - Buffer size: 1959
        15:51:51.570 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "16", "time_elapsed": 89}}
        15:51:51.662 FLH: Read block - Writing: 4096 - Total: 1957888 - Buffer size: 1959
        15:51:51.857 FLH: Read block - Writing: 4096 - Total: 1961984 - Buffer size: 1959
        15:51:51.970 FLH: Read block - Writing: 4096 - Total: 1966080 - Buffer size: 1959
        15:51:52.157 FLH: Read block - Writing: 4096 - Total: 1970176 - Buffer size: 1959
        15:51:52.359 FLH: Read block - Writing: 4096 - Total: 1974272 - Buffer size: 1959
        15:51:52.558 FLH: Read block - Writing: 4096 - Total: 1978368 - Buffer size: 1959
        15:51:52.757 FLH: Read block - Writing: 4096 - Total: 1982464 - Buffer size: 1959
        15:51:52.902 FLH: Read block - Writing: 4096 - Total: 1986560 - Buffer size: 1959
        15:51:53.016 FLH: Read block - Writing: 4096 - Total: 1990656 - Buffer size: 1959
        15:51:53.158 FLH: Read block - Writing: 4096 - Total: 1994752 - Buffer size: 1959
        15:51:53.272 FLH: Read block - Writing: 4096 - Total: 1998848 - Buffer size: 1959
        15:51:53.458 FLH: Read block - Writing: 4096 - Total: 2002944 - Buffer size: 1959
        15:51:53.658 FLH: Read block - Writing: 4096 - Total: 2007040 - Buffer size: 1959
        15:51:53.857 FLH: Read block - Writing: 4096 - Total: 2011136 - Buffer size: 1959
        15:51:53.969 FLH: Read block - Writing: 4096 - Total: 2015232 - Buffer size: 1959
        15:51:54.157 FLH: Read block - Writing: 4096 - Total: 2019328 - Buffer size: 1959
        15:51:54.272 FLH: Read block - Writing: 4096 - Total: 2023424 - Buffer size: 1959
        15:51:54.458 FLH: Read block - Writing: 4096 - Total: 2027520 - Buffer size: 1959
        15:51:54.658 FLH: Read block - Writing: 4096 - Total: 2031616 - Buffer size: 1959
        15:51:54.858 FLH: Read block - Writing: 4096 - Total: 2035712 - Buffer size: 1959
        15:51:55.058 FLH: Read block - Writing: 4096 - Total: 2039808 - Buffer size: 1959
        15:51:55.264 FLH: Read block - Writing: 4096 - Total: 2043904 - Buffer size: 1959
        15:51:55.458 FLH: Read block - Writing: 4096 - Total: 2048000 - Buffer size: 1959
        15:51:55.658 FLH: Read block - Writing: 4096 - Total: 2052096 - Buffer size: 1959
        15:51:55.858 FLH: Read block - Writing: 4096 - Total: 2056192 - Buffer size: 1959
        15:51:56.058 FLH: Read block - Writing: 4096 - Total: 2060288 - Buffer size: 1959
        15:51:56.264 FLH: Read block - Writing: 4096 - Total: 2064384 - Buffer size: 1959
        15:51:56.457 FLH: Read block - Writing: 4096 - Total: 2068480 - Buffer size: 1959
        15:51:56.658 FLH: Read block - Writing: 4096 - Total: 2072576 - Buffer size: 1959
        15:51:56.858 FLH: Read block - Writing: 4096 - Total: 2076672 - Buffer size: 1959
        15:51:56.971 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "17", "time_elapsed": 94}}
        15:51:57.064 FLH: Read block - Writing: 4096 - Total: 2080768 - Buffer size: 1959
        15:51:57.264 FLH: Read block - Writing: 4096 - Total: 2084864 - Buffer size: 1959
        15:51:57.458 FLH: Read block - Writing: 4096 - Total: 2088960 - Buffer size: 1959
        15:51:57.658 FLH: Read block - Writing: 4096 - Total: 2093056 - Buffer size: 1959
        15:51:57.857 FLH: Read block - Writing: 4096 - Total: 2097152 - Buffer size: 1959
        15:51:58.058 FLH: Read block - Writing: 4096 - Total: 2101248 - Buffer size: 1959
        15:51:58.263 FLH: Read block - Writing: 4096 - Total: 2105344 - Buffer size: 1959
        15:51:58.458 FLH: Read block - Writing: 4096 - Total: 2109440 - Buffer size: 1959
        15:51:58.657 FLH: Read block - Writing: 4096 - Total: 2113536 - Buffer size: 1959
        15:51:58.858 FLH: Read block - Writing: 4096 - Total: 2117632 - Buffer size: 1959
        15:51:58.970 FLH: Read block - Writing: 4096 - Total: 2121728 - Buffer size: 1959
        15:51:59.158 FLH: Read block - Writing: 4096 - Total: 2125824 - Buffer size: 1959
        15:51:59.276 FLH: Read block - Writing: 4096 - Total: 2129920 - Buffer size: 1959
        15:51:59.457 FLH: Read block - Writing: 4096 - Total: 2134016 - Buffer size: 1959
        15:51:59.658 FLH: Read block - Writing: 4096 - Total: 2138112 - Buffer size: 1959
        15:51:59.858 FLH: Read block - Writing: 4096 - Total: 2142208 - Buffer size: 1959
        15:52:00.058 FLH: Read block - Writing: 4096 - Total: 2146304 - Buffer size: 1959
        15:52:00.264 FLH: Read block - Writing: 4096 - Total: 2150400 - Buffer size: 1959
        15:52:00.457 FLH: Read block - Writing: 4096 - Total: 2154496 - Buffer size: 1959
        15:52:00.605 FLH: Read block - Writing: 4096 - Total: 2158592 - Buffer size: 1959
        15:52:00.757 FLH: Read block - Writing: 4096 - Total: 2162688 - Buffer size: 1959
        15:52:00.958 FLH: Read block - Writing: 4096 - Total: 2166784 - Buffer size: 1959
        15:52:01.156 FLH: Read block - Writing: 4096 - Total: 2170880 - Buffer size: 1959
        15:52:01.271 FLH: Read block - Writing: 4096 - Total: 2174976 - Buffer size: 1959
        15:52:01.455 FLH: Read block - Writing: 4096 - Total: 2179072 - Buffer size: 1959
        15:52:01.656 FLH: Read block - Writing: 4096 - Total: 2183168 - Buffer size: 1959
        15:52:01.856 FLH: Read block - Writing: 4096 - Total: 2187264 - Buffer size: 1959
        15:52:02.058 FLH: Read block - Writing: 4096 - Total: 2191360 - Buffer size: 1959
        15:52:02.264 FLH: Read block - Writing: 4096 - Total: 2195456 - Buffer size: 1959
        15:52:02.458 FLH: Read block - Writing: 4096 - Total: 2199552 - Buffer size: 1959
        15:52:02.571 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "18", "time_elapsed": 100}}
        15:52:02.664 FLH: Read block - Writing: 4096 - Total: 2203648 - Buffer size: 1959
        15:52:02.857 FLH: Read block - Writing: 4096 - Total: 2207744 - Buffer size: 1959
        15:52:03.058 FLH: Read block - Writing: 4096 - Total: 2211840 - Buffer size: 1959
        15:52:03.203 FLH: Read block - Writing: 4096 - Total: 2215936 - Buffer size: 1959
        15:52:03.320 FLH: Read block - Writing: 4096 - Total: 2220032 - Buffer size: 1959
        15:52:03.432 FLH: Read block - Writing: 4096 - Total: 2224128 - Buffer size: 1959
        15:52:03.560 FLH: Read block - Writing: 4096 - Total: 2228224 - Buffer size: 1959
        15:52:03.758 FLH: Read block - Writing: 4096 - Total: 2232320 - Buffer size: 1959
        15:52:03.957 FLH: Read block - Writing: 4096 - Total: 2236416 - Buffer size: 1959
        15:52:04.157 FLH: Read block - Writing: 4096 - Total: 2240512 - Buffer size: 1959
        15:52:04.274 FLH: Read block - Writing: 4096 - Total: 2244608 - Buffer size: 1959
        15:52:04.459 FLH: Read block - Writing: 4096 - Total: 2248704 - Buffer size: 1959
        15:52:04.658 FLH: Read block - Writing: 4096 - Total: 2252800 - Buffer size: 1959
        15:52:04.857 FLH: Read block - Writing: 4096 - Total: 2256896 - Buffer size: 1959
        15:52:05.058 FLH: Read block - Writing: 4096 - Total: 2260992 - Buffer size: 1959
        15:52:05.263 FLH: Read block - Writing: 4096 - Total: 2265088 - Buffer size: 1959
        15:52:05.457 FLH: Read block - Writing: 4096 - Total: 2269184 - Buffer size: 1959
        15:52:05.658 FLH: Read block - Writing: 4096 - Total: 2273280 - Buffer size: 1959
        15:52:05.807 FLH: Read block - Writing: 4096 - Total: 2277376 - Buffer size: 1959
        15:52:05.958 FLH: Read block - Writing: 4096 - Total: 2281472 - Buffer size: 1959
        15:52:06.158 FLH: Read block - Writing: 4096 - Total: 2285568 - Buffer size: 1959
        15:52:06.273 FLH: Read block - Writing: 4096 - Total: 2289664 - Buffer size: 1959
        15:52:06.457 FLH: Read block - Writing: 4096 - Total: 2293760 - Buffer size: 1959
        15:52:06.658 FLH: Read block - Writing: 4096 - Total: 2297856 - Buffer size: 1959
        15:52:06.858 FLH: Read block - Writing: 4096 - Total: 2301952 - Buffer size: 1959
        15:52:06.970 FLH: Read block - Writing: 4096 - Total: 2306048 - Buffer size: 1959
        15:52:07.157 FLH: Read block - Writing: 4096 - Total: 2310144 - Buffer size: 1959
        15:52:07.273 FLH: Read block - Writing: 4096 - Total: 2314240 - Buffer size: 1959
        15:52:07.456 FLH: Read block - Writing: 4096 - Total: 2318336 - Buffer size: 1959
        15:52:07.571 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "19", "time_elapsed": 105}}
        15:52:07.664 FLH: Read block - Writing: 4096 - Total: 2322432 - Buffer size: 1959
        15:52:07.858 FLH: Read block - Writing: 4096 - Total: 2326528 - Buffer size: 1959
        15:52:08.058 FLH: Read block - Writing: 4096 - Total: 2330624 - Buffer size: 1959
        15:52:08.264 FLH: Read block - Writing: 4096 - Total: 2334720 - Buffer size: 1959
        15:52:08.457 FLH: Read block - Writing: 4096 - Total: 2338816 - Buffer size: 1959
        15:52:08.658 FLH: Read block - Writing: 4096 - Total: 2342912 - Buffer size: 1959
        15:52:08.857 FLH: Read block - Writing: 4096 - Total: 2347008 - Buffer size: 1959
        15:52:09.058 FLH: Read block - Writing: 4096 - Total: 2351104 - Buffer size: 1959
        15:52:09.264 FLH: Read block - Writing: 4096 - Total: 2355200 - Buffer size: 1959
        15:52:09.457 FLH: Read block - Writing: 4096 - Total: 2359296 - Buffer size: 1959
        15:52:09.658 FLH: Read block - Writing: 4096 - Total: 2363392 - Buffer size: 1959
        15:52:09.857 FLH: Read block - Writing: 4096 - Total: 2367488 - Buffer size: 1959
        15:52:10.058 FLH: Read block - Writing: 4096 - Total: 2371584 - Buffer size: 1959
        15:52:10.263 FLH: Read block - Writing: 4096 - Total: 2375680 - Buffer size: 1959
        15:52:10.457 FLH: Read block - Writing: 4096 - Total: 2379776 - Buffer size: 1959
        15:52:10.658 FLH: Read block - Writing: 4096 - Total: 2383872 - Buffer size: 1959
        15:52:10.806 FLH: Read block - Writing: 4096 - Total: 2387968 - Buffer size: 1959
        15:52:10.958 FLH: Read block - Writing: 4096 - Total: 2392064 - Buffer size: 1959
        15:52:11.157 FLH: Read block - Writing: 4096 - Total: 2396160 - Buffer size: 1959
        15:52:11.272 FLH: Read block - Writing: 4096 - Total: 2400256 - Buffer size: 1959
        15:52:11.457 FLH: Read block - Writing: 4096 - Total: 2404352 - Buffer size: 1959
        15:52:11.658 FLH: Read block - Writing: 4096 - Total: 2408448 - Buffer size: 1959
        15:52:11.857 FLH: Read block - Writing: 4096 - Total: 2412544 - Buffer size: 1959
        15:52:12.058 FLH: Read block - Writing: 4096 - Total: 2416640 - Buffer size: 1959
        15:52:12.263 FLH: Read block - Writing: 4096 - Total: 2420736 - Buffer size: 1959
        15:52:12.458 FLH: Read block - Writing: 4096 - Total: 2424832 - Buffer size: 1959
        15:52:12.657 FLH: Read block - Writing: 4096 - Total: 2428928 - Buffer size: 1959
        15:52:12.858 FLH: Read block - Writing: 4096 - Total: 2433024 - Buffer size: 1959
        15:52:13.058 FLH: Read block - Writing: 4096 - Total: 2437120 - Buffer size: 1959
        15:52:13.264 FLH: Read block - Writing: 4096 - Total: 2441216 - Buffer size: 1959
        15:52:13.328 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "20", "time_elapsed": 111}}
        15:52:13.420 FLH: Read block - Writing: 4096 - Total: 2445312 - Buffer size: 1959
        15:52:13.558 FLH: Read block - Writing: 4096 - Total: 2449408 - Buffer size: 1959
        15:52:13.758 FLH: Read block - Writing: 4096 - Total: 2453504 - Buffer size: 1959
        15:52:13.957 FLH: Read block - Writing: 4096 - Total: 2457600 - Buffer size: 1959
        15:52:14.158 FLH: Read block - Writing: 4096 - Total: 2461696 - Buffer size: 1959
        15:52:14.273 FLH: Read block - Writing: 4096 - Total: 2465792 - Buffer size: 1959
        15:52:14.458 FLH: Read block - Writing: 4096 - Total: 2469888 - Buffer size: 1959
        15:52:14.657 FLH: Read block - Writing: 4096 - Total: 2473984 - Buffer size: 1959
        15:52:14.858 FLH: Read block - Writing: 4096 - Total: 2478080 - Buffer size: 1959
        15:52:15.058 FLH: Read block - Writing: 4096 - Total: 2482176 - Buffer size: 1959
        15:52:15.263 FLH: Read block - Writing: 4096 - Total: 2486272 - Buffer size: 1959
        15:52:15.457 FLH: Read block - Writing: 4096 - Total: 2490368 - Buffer size: 1959
        15:52:15.658 FLH: Read block - Writing: 4096 - Total: 2494464 - Buffer size: 1959
        15:52:15.858 FLH: Read block - Writing: 4096 - Total: 2498560 - Buffer size: 1959
        15:52:16.007 FLH: Read block - Writing: 4096 - Total: 2502656 - Buffer size: 1959
        15:52:16.157 FLH: Read block - Writing: 4096 - Total: 2506752 - Buffer size: 1959
        15:52:16.273 FLH: Read block - Writing: 4096 - Total: 2510848 - Buffer size: 1959
        15:52:16.457 FLH: Read block - Writing: 4096 - Total: 2514944 - Buffer size: 1959
        15:52:16.658 FLH: Read block - Writing: 4096 - Total: 2519040 - Buffer size: 1959
        15:52:16.857 FLH: Read block - Writing: 4096 - Total: 2523136 - Buffer size: 1959
        15:52:17.057 FLH: Read block - Writing: 4096 - Total: 2527232 - Buffer size: 1959
        15:52:17.266 FLH: Read block - Writing: 4096 - Total: 2531328 - Buffer size: 1959
        15:52:17.457 FLH: Read block - Writing: 4096 - Total: 2535424 - Buffer size: 1959
        15:52:17.659 FLH: Read block - Writing: 4096 - Total: 2539520 - Buffer size: 1959
        15:52:17.858 FLH: Read block - Writing: 4096 - Total: 2543616 - Buffer size: 1959
        15:52:18.057 FLH: Read block - Writing: 4096 - Total: 2547712 - Buffer size: 1959
        15:52:18.265 FLH: Read block - Writing: 4096 - Total: 2551808 - Buffer size: 1959
        15:52:18.377 FLH: Read block - Writing: 4096 - Total: 2555904 - Buffer size: 1959
        15:52:18.530 FLH: Read block - Writing: 4096 - Total: 2560000 - Buffer size: 1959
        15:52:18.758 FLH: Read block - Writing: 4096 - Total: 2564096 - Buffer size: 1959
        15:52:18.871 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "21", "time_elapsed": 116}}
        15:52:18.963 FLH: Read block - Writing: 4096 - Total: 2568192 - Buffer size: 1959
        15:52:19.158 FLH: Read block - Writing: 4096 - Total: 2572288 - Buffer size: 1959
        15:52:19.273 FLH: Read block - Writing: 4096 - Total: 2576384 - Buffer size: 1959
        15:52:19.458 FLH: Read block - Writing: 4096 - Total: 2580480 - Buffer size: 1959
        15:52:19.464 HTP: Werkzeuge
        15:52:19.639 FLH: Read block - Writing: 4096 - Total: 2584576 - Buffer size: 1959
        15:52:19.758 FLH: Read block - Writing: 4096 - Total: 2588672 - Buffer size: 1959
        15:52:19.958 FLH: Read block - Writing: 4096 - Total: 2592768 - Buffer size: 1959
        15:52:20.157 FLH: Read block - Writing: 4096 - Total: 2596864 - Buffer size: 1959
        15:52:20.272 FLH: Read block - Writing: 4096 - Total: 2600960 - Buffer size: 1959
        15:52:20.457 FLH: Read block - Writing: 4096 - Total: 2605056 - Buffer size: 1959
        15:52:20.657 FLH: Read block - Writing: 4096 - Total: 2609152 - Buffer size: 1959
        15:52:20.858 FLH: Read block - Writing: 4096 - Total: 2613248 - Buffer size: 1959
        15:52:20.970 FLH: Read block - Writing: 4096 - Total: 2617344 - Buffer size: 1959
        15:52:21.118 FLH: Read block - Writing: 4096 - Total: 2621440 - Buffer size: 1959
        15:52:21.127 HTP: Hauptmenü
        15:52:21.316 FLH: Read block - Writing: 4096 - Total: 2625536 - Buffer size: 1959
        15:52:21.558 FLH: Read block - Writing: 4096 - Total: 2629632 - Buffer size: 1959
        15:52:21.757 FLH: Read block - Writing: 4096 - Total: 2633728 - Buffer size: 1959
        15:52:21.957 FLH: Read block - Writing: 4096 - Total: 2637824 - Buffer size: 1959
        15:52:22.158 FLH: Read block - Writing: 4096 - Total: 2641920 - Buffer size: 1959
        15:52:22.274 FLH: Read block - Writing: 4096 - Total: 2646016 - Buffer size: 1959
        15:52:22.458 FLH: Read block - Writing: 4096 - Total: 2650112 - Buffer size: 1959
        15:52:22.657 FLH: Read block - Writing: 4096 - Total: 2654208 - Buffer size: 1959
        15:52:22.858 FLH: Read block - Writing: 4096 - Total: 2658304 - Buffer size: 1959
        15:52:23.058 FLH: Read block - Writing: 4096 - Total: 2662400 - Buffer size: 1959
        15:52:23.264 FLH: Read block - Writing: 4096 - Total: 2666496 - Buffer size: 1959
        15:52:23.458 FLH: Read block - Writing: 4096 - Total: 2670592 - Buffer size: 1959
        15:52:23.604 FLH: Read block - Writing: 4096 - Total: 2674688 - Buffer size: 1959
        15:52:23.757 FLH: Read block - Writing: 4096 - Total: 2678784 - Buffer size: 1959
        15:52:23.907 FLH: Read block - Writing: 4096 - Total: 2682880 - Buffer size: 1959
        15:52:24.057 FLH: Read block - Writing: 4096 - Total: 2686976 - Buffer size: 1959
        15:52:24.178 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "22", "time_elapsed": 121}}
        15:52:24.271 FLH: Read block - Writing: 4096 - Total: 2691072 - Buffer size: 1959
        15:52:24.457 FLH: Read block - Writing: 4096 - Total: 2695168 - Buffer size: 1959
        15:52:24.659 FLH: Read block - Writing: 4096 - Total: 2699264 - Buffer size: 1959
        15:52:24.859 FLH: Read block - Writing: 4096 - Total: 2703360 - Buffer size: 1959
        15:52:25.056 FLH: Read block - Writing: 4096 - Total: 2707456 - Buffer size: 1959
        15:52:25.265 FLH: Read block - Writing: 4096 - Total: 2711552 - Buffer size: 1959
        15:52:25.458 FLH: Read block - Writing: 4096 - Total: 2715648 - Buffer size: 1959
        15:52:25.658 FLH: Read block - Writing: 4096 - Total: 2719744 - Buffer size: 1959
        15:52:25.859 FLH: Read block - Writing: 4096 - Total: 2723840 - Buffer size: 1959
        15:52:26.012 FLH: Read block - Writing: 4096 - Total: 2727936 - Buffer size: 1959
        15:52:26.157 FLH: Read block - Writing: 4096 - Total: 2732032 - Buffer size: 1959
        15:52:26.274 FLH: Read block - Writing: 4096 - Total: 2736128 - Buffer size: 1959
        15:52:26.425 FLH: Read block - Writing: 4096 - Total: 2740224 - Buffer size: 1959
        15:52:26.558 FLH: Read block - Writing: 4096 - Total: 2744320 - Buffer size: 1959
        15:52:26.758 FLH: Read block - Writing: 4096 - Total: 2748416 - Buffer size: 1959
        15:52:26.958 FLH: Read block - Writing: 4096 - Total: 2752512 - Buffer size: 1959
        15:52:27.158 FLH: Read block - Writing: 4096 - Total: 2756608 - Buffer size: 1959
        15:52:27.359 FLH: Read block - Writing: 4096 - Total: 2760704 - Buffer size: 1959
        15:52:27.558 FLH: Read block - Writing: 4096 - Total: 2764800 - Buffer size: 1959
        15:52:27.757 FLH: Read block - Writing: 4096 - Total: 2768896 - Buffer size: 1959
        15:52:27.958 FLH: Read block - Writing: 4096 - Total: 2772992 - Buffer size: 1959
        15:52:28.158 FLH: Read block - Writing: 4096 - Total: 2777088 - Buffer size: 1959
        15:52:28.275 FLH: Read block - Writing: 4096 - Total: 2781184 - Buffer size: 1959
        15:52:28.458 FLH: Read block - Writing: 4096 - Total: 2785280 - Buffer size: 1959
        15:52:28.604 FLH: Read block - Writing: 4096 - Total: 2789376 - Buffer size: 1959
        15:52:28.757 FLH: Read block - Writing: 4096 - Total: 2793472 - Buffer size: 1959
        15:52:28.906 FLH: Read block - Writing: 4096 - Total: 2797568 - Buffer size: 1959
        15:52:29.058 FLH: Read block - Writing: 4096 - Total: 2801664 - Buffer size: 1959
        15:52:29.264 FLH: Read block - Writing: 4096 - Total: 2805760 - Buffer size: 1959
        15:52:29.371 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "23", "time_elapsed": 127}}
        15:52:29.464 FLH: Read block - Writing: 4096 - Total: 2809856 - Buffer size: 1959
        15:52:29.658 FLH: Read block - Writing: 4096 - Total: 2813952 - Buffer size: 1959
        15:52:29.858 FLH: Read block - Writing: 4096 - Total: 2818048 - Buffer size: 1959
        15:52:29.970 FLH: Read block - Writing: 4096 - Total: 2822144 - Buffer size: 1959
        15:52:30.264 FLH: Read block - Writing: 4096 - Total: 2826240 - Buffer size: 1959
        15:52:30.457 FLH: Read block - Writing: 4096 - Total: 2830336 - Buffer size: 1959
        15:52:30.658 FLH: Read block - Writing: 4096 - Total: 2834432 - Buffer size: 1959
        15:52:30.858 FLH: Read block - Writing: 4096 - Total: 2838528 - Buffer size: 1959
        15:52:31.057 FLH: Read block - Writing: 4096 - Total: 2842624 - Buffer size: 1959
        15:52:31.263 FLH: Read block - Writing: 4096 - Total: 2846720 - Buffer size: 1959
        15:52:31.458 FLH: Read block - Writing: 4096 - Total: 2850816 - Buffer size: 1959
        15:52:31.658 FLH: Read block - Writing: 4096 - Total: 2854912 - Buffer size: 1959
        15:52:31.858 FLH: Read block - Writing: 4096 - Total: 2859008 - Buffer size: 1959
        15:52:32.058 FLH: Read block - Writing: 4096 - Total: 2863104 - Buffer size: 1959
        15:52:32.264 FLH: Read block - Writing: 4096 - Total: 2867200 - Buffer size: 1959
        15:52:32.458 FLH: Read block - Writing: 4096 - Total: 2871296 - Buffer size: 1959
        15:52:32.657 FLH: Read block - Writing: 4096 - Total: 2875392 - Buffer size: 1959
        15:52:32.858 FLH: Read block - Writing: 4096 - Total: 2879488 - Buffer size: 1959
        15:52:33.057 FLH: Read block - Writing: 4096 - Total: 2883584 - Buffer size: 1959
        15:52:33.263 FLH: Read block - Writing: 4096 - Total: 2887680 - Buffer size: 1959
        15:52:33.457 FLH: Read block - Writing: 4096 - Total: 2891776 - Buffer size: 1959
        15:52:33.603 FLH: Read block - Writing: 4096 - Total: 2895872 - Buffer size: 1959
        15:52:33.757 FLH: Read block - Writing: 4096 - Total: 2899968 - Buffer size: 1959
        15:52:33.906 FLH: Read block - Writing: 4096 - Total: 2904064 - Buffer size: 1959
        15:52:34.058 FLH: Read block - Writing: 4096 - Total: 2908160 - Buffer size: 1959
        15:52:34.265 FLH: Read block - Writing: 4096 - Total: 2912256 - Buffer size: 1959
        15:52:34.458 FLH: Read block - Writing: 4096 - Total: 2916352 - Buffer size: 1959
        15:52:34.659 FLH: Read block - Writing: 4096 - Total: 2920448 - Buffer size: 1959
        15:52:34.859 FLH: Read block - Writing: 4096 - Total: 2924544 - Buffer size: 1959
        15:52:35.056 FLH: Read block - Writing: 4096 - Total: 2928640 - Buffer size: 1959
        15:52:35.178 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "24", "time_elapsed": 132}}
        15:52:35.270 FLH: Read block - Writing: 4096 - Total: 2932736 - Buffer size: 1959
        15:52:35.457 FLH: Read block - Writing: 4096 - Total: 2936832 - Buffer size: 1959
        15:52:35.658 FLH: Read block - Writing: 4096 - Total: 2940928 - Buffer size: 1959
        15:52:35.857 FLH: Read block - Writing: 4096 - Total: 2945024 - Buffer size: 1959
        15:52:35.969 FLH: Read block - Writing: 4096 - Total: 2949120 - Buffer size: 1959
        15:52:36.167 FLH: Read block - Writing: 4096 - Total: 2953216 - Buffer size: 1959
        15:52:36.358 FLH: Read block - Writing: 4096 - Total: 2957312 - Buffer size: 1959
        15:52:36.558 FLH: Read block - Writing: 4096 - Total: 2961408 - Buffer size: 1959
        15:52:36.758 FLH: Read block - Writing: 4096 - Total: 2965504 - Buffer size: 1959
        15:52:36.958 FLH: Read block - Writing: 4096 - Total: 2969600 - Buffer size: 1959
        15:52:37.158 FLH: Read block - Writing: 4096 - Total: 2973696 - Buffer size: 1959
        15:52:37.272 FLH: Read block - Writing: 4096 - Total: 2977792 - Buffer size: 1959
        15:52:37.458 FLH: Read block - Writing: 4096 - Total: 2981888 - Buffer size: 1959
        15:52:37.657 FLH: Read block - Writing: 4096 - Total: 2985984 - Buffer size: 1959
        15:52:37.858 FLH: Read block - Writing: 4096 - Total: 2990080 - Buffer size: 1959
        15:52:38.058 FLH: Read block - Writing: 4096 - Total: 2994176 - Buffer size: 1959
        15:52:38.263 FLH: Read block - Writing: 4096 - Total: 2998272 - Buffer size: 1959
        15:52:38.458 FLH: Read block - Writing: 4096 - Total: 3002368 - Buffer size: 1959
        15:52:38.606 FLH: Read block - Writing: 4096 - Total: 3006464 - Buffer size: 1959
        15:52:38.758 FLH: Read block - Writing: 4096 - Total: 3010560 - Buffer size: 1959
        15:52:38.957 FLH: Read block - Writing: 4096 - Total: 3014656 - Buffer size: 1959
        15:52:39.160 FLH: Read block - Writing: 4096 - Total: 3018752 - Buffer size: 1959
        15:52:39.359 FLH: Read block - Writing: 4096 - Total: 3022848 - Buffer size: 1959
        15:52:39.559 FLH: Read block - Writing: 4096 - Total: 3026944 - Buffer size: 1959
        15:52:39.757 FLH: Read block - Writing: 4096 - Total: 3031040 - Buffer size: 1959
        15:52:39.957 FLH: Read block - Writing: 4096 - Total: 3035136 - Buffer size: 1959
        15:52:40.157 FLH: Read block - Writing: 4096 - Total: 3039232 - Buffer size: 1959
        15:52:40.272 FLH: Read block - Writing: 4096 - Total: 3043328 - Buffer size: 1959
        15:52:40.457 FLH: Read block - Writing: 4096 - Total: 3047424 - Buffer size: 1959
        15:52:40.658 FLH: Read block - Writing: 4096 - Total: 3051520 - Buffer size: 1959
        15:52:40.772 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "25", "time_elapsed": 138}}
        15:52:40.865 FLH: Read block - Writing: 4096 - Total: 3055616 - Buffer size: 1959
        15:52:41.018 FLH: Read block - Writing: 4096 - Total: 3059712 - Buffer size: 1959
        15:52:41.170 FLH: Read block - Writing: 4096 - Total: 3063808 - Buffer size: 1959
        15:52:41.285 FLH: Read block - Writing: 4096 - Total: 3067904 - Buffer size: 1959
        15:52:41.458 FLH: Read block - Writing: 4096 - Total: 3072000 - Buffer size: 1959
        15:52:41.657 FLH: Read block - Writing: 4096 - Total: 3076096 - Buffer size: 1959
        15:52:41.858 FLH: Read block - Writing: 4096 - Total: 3080192 - Buffer size: 1959
        15:52:42.058 FLH: Read block - Writing: 4096 - Total: 3084288 - Buffer size: 1959
        15:52:42.264 FLH: Read block - Writing: 4096 - Total: 3088384 - Buffer size: 1959
        15:52:42.458 FLH: Read block - Writing: 4096 - Total: 3092480 - Buffer size: 1959
        15:52:42.657 FLH: Read block - Writing: 4096 - Total: 3096576 - Buffer size: 1959
        15:52:42.858 FLH: Read block - Writing: 4096 - Total: 3100672 - Buffer size: 1959
        15:52:42.970 FLH: Read block - Writing: 4096 - Total: 3104768 - Buffer size: 1959
        15:52:43.158 FLH: Read block - Writing: 4096 - Total: 3108864 - Buffer size: 1959
        15:52:43.274 FLH: Read block - Writing: 4096 - Total: 3112960 - Buffer size: 1959
        15:52:43.458 FLH: Read block - Writing: 4096 - Total: 3117056 - Buffer size: 1959
        15:52:43.603 FLH: Read block - Writing: 4096 - Total: 3121152 - Buffer size: 1959
        15:52:43.755 FLH: Read block - Writing: 4096 - Total: 3125248 - Buffer size: 1959
        15:52:43.958 FLH: Read block - Writing: 4096 - Total: 3129344 - Buffer size: 1959
        15:52:44.158 FLH: Read block - Writing: 4096 - Total: 3133440 - Buffer size: 1959
        15:52:44.273 FLH: Read block - Writing: 4096 - Total: 3137536 - Buffer size: 1959
        15:52:44.458 FLH: Read block - Writing: 4096 - Total: 3141632 - Buffer size: 1959
        15:52:44.658 FLH: Read block - Writing: 4096 - Total: 3145728 - Buffer size: 1959
        15:52:44.858 FLH: Read block - Writing: 4096 - Total: 3149824 - Buffer size: 1959
        15:52:45.057 FLH: Read block - Writing: 4096 - Total: 3153920 - Buffer size: 1959
        15:52:45.264 FLH: Read block - Writing: 4096 - Total: 3158016 - Buffer size: 1959
        15:52:45.458 FLH: Read block - Writing: 4096 - Total: 3162112 - Buffer size: 1959
        15:52:45.658 FLH: Read block - Writing: 4096 - Total: 3166208 - Buffer size: 1959
        15:52:45.858 FLH: Read block - Writing: 4096 - Total: 3170304 - Buffer size: 1959
        15:52:45.970 FLH: Read block - Writing: 4096 - Total: 3174400 - Buffer size: 1959
        15:52:46.072 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "26", "time_elapsed": 143}}
        15:52:46.165 FLH: Read block - Writing: 4096 - Total: 3178496 - Buffer size: 1959
        15:52:46.323 FLH: Read block - Writing: 4096 - Total: 3182592 - Buffer size: 1959
        15:52:46.435 FLH: Read block - Writing: 4096 - Total: 3186688 - Buffer size: 1959
        15:52:46.559 FLH: Read block - Writing: 4096 - Total: 3190784 - Buffer size: 1959
        15:52:46.758 FLH: Read block - Writing: 4096 - Total: 3194880 - Buffer size: 1959
        15:52:46.958 FLH: Read block - Writing: 4096 - Total: 3198976 - Buffer size: 1959
        15:52:47.158 FLH: Read block - Writing: 4096 - Total: 3203072 - Buffer size: 1959
        15:52:47.273 FLH: Read block - Writing: 4096 - Total: 3207168 - Buffer size: 1959
        15:52:47.458 FLH: Read block - Writing: 4096 - Total: 3211264 - Buffer size: 1959
        15:52:47.658 FLH: Read block - Writing: 4096 - Total: 3215360 - Buffer size: 1959
        15:52:47.858 FLH: Read block - Writing: 4096 - Total: 3219456 - Buffer size: 1959
        15:52:47.970 FLH: Read block - Writing: 4096 - Total: 3223552 - Buffer size: 1959
        15:52:48.082 FLH: Read block - Writing: 4096 - Total: 3227648 - Buffer size: 1959
        15:52:48.263 FLH: Read block - Writing: 4096 - Total: 3231744 - Buffer size: 1959
        15:52:48.457 FLH: Read block - Writing: 4096 - Total: 3235840 - Buffer size: 1959
        15:52:48.658 FLH: Read block - Writing: 4096 - Total: 3239936 - Buffer size: 1959
        15:52:48.807 FLH: Read block - Writing: 4096 - Total: 3244032 - Buffer size: 1959
        15:52:48.957 FLH: Read block - Writing: 4096 - Total: 3248128 - Buffer size: 1959
        15:52:49.070 FLH: Read block - Writing: 4096 - Total: 3252224 - Buffer size: 1959
        15:52:49.264 FLH: Read block - Writing: 4096 - Total: 3256320 - Buffer size: 1959
        15:52:49.458 FLH: Read block - Writing: 4096 - Total: 3260416 - Buffer size: 1959
        15:52:49.657 FLH: Read block - Writing: 4096 - Total: 3264512 - Buffer size: 1959
        15:52:49.858 FLH: Read block - Writing: 4096 - Total: 3268608 - Buffer size: 1959
        15:52:50.058 FLH: Read block - Writing: 4096 - Total: 3272704 - Buffer size: 1959
        15:52:50.169 FLH: Read block - Writing: 4096 - Total: 3276800 - Buffer size: 1959
        15:52:50.282 FLH: Read block - Writing: 4096 - Total: 3280896 - Buffer size: 1959
        15:52:50.558 FLH: Read block - Writing: 4096 - Total: 3284992 - Buffer size: 1959
        15:52:50.757 FLH: Read block - Writing: 4096 - Total: 3289088 - Buffer size: 1959
        15:52:50.958 FLH: Read block - Writing: 4096 - Total: 3293184 - Buffer size: 1959
        15:52:51.158 FLH: Read block - Writing: 4096 - Total: 3297280 - Buffer size: 1959
        15:52:51.226 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "27", "time_elapsed": 148}}
        15:52:51.318 FLH: Read block - Writing: 4096 - Total: 3301376 - Buffer size: 1959
        15:52:51.477 FLH: Read block - Writing: 4096 - Total: 3305472 - Buffer size: 1959
        15:52:51.659 FLH: Read block - Writing: 4096 - Total: 3309568 - Buffer size: 1959
        15:52:51.858 FLH: Read block - Writing: 4096 - Total: 3313664 - Buffer size: 1959
        15:52:51.970 FLH: Read block - Writing: 4096 - Total: 3317760 - Buffer size: 1959
        15:52:52.158 FLH: Read block - Writing: 4096 - Total: 3321856 - Buffer size: 1959
        15:52:52.275 FLH: Read block - Writing: 4096 - Total: 3325952 - Buffer size: 1959
        15:52:52.458 FLH: Read block - Writing: 4096 - Total: 3330048 - Buffer size: 1959
        15:52:52.658 FLH: Read block - Writing: 4096 - Total: 3334144 - Buffer size: 1959
        15:52:52.858 FLH: Read block - Writing: 4096 - Total: 3338240 - Buffer size: 1959
        15:52:53.058 FLH: Read block - Writing: 4096 - Total: 3342336 - Buffer size: 1959
        15:52:53.263 FLH: Read block - Writing: 4096 - Total: 3346432 - Buffer size: 1959
        15:52:53.458 FLH: Read block - Writing: 4096 - Total: 3350528 - Buffer size: 1959
        15:52:53.658 FLH: Read block - Writing: 4096 - Total: 3354624 - Buffer size: 1959
        15:52:53.874 FLH: Read block - Writing: 4096 - Total: 3358720 - Buffer size: 1959
        15:52:54.024 FLH: Read block - Writing: 4096 - Total: 3362816 - Buffer size: 1959
        15:52:54.158 FLH: Read block - Writing: 4096 - Total: 3366912 - Buffer size: 1959
        15:52:54.272 FLH: Read block - Writing: 4096 - Total: 3371008 - Buffer size: 1959
        15:52:54.457 FLH: Read block - Writing: 4096 - Total: 3375104 - Buffer size: 1959
        15:52:54.658 FLH: Read block - Writing: 4096 - Total: 3379200 - Buffer size: 1959
        15:52:54.858 FLH: Read block - Writing: 4096 - Total: 3383296 - Buffer size: 1959
        15:52:55.058 FLH: Read block - Writing: 4096 - Total: 3387392 - Buffer size: 1959
        15:52:55.264 FLH: Read block - Writing: 4096 - Total: 3391488 - Buffer size: 1959
        15:52:55.457 FLH: Read block - Writing: 4096 - Total: 3395584 - Buffer size: 1959
        15:52:55.658 FLH: Read block - Writing: 4096 - Total: 3399680 - Buffer size: 1959
        15:52:55.857 FLH: Read block - Writing: 4096 - Total: 3403776 - Buffer size: 1959
        15:52:55.970 FLH: Read block - Writing: 4096 - Total: 3407872 - Buffer size: 1959
        15:52:56.159 FLH: Read block - Writing: 4096 - Total: 3411968 - Buffer size: 1959
        15:52:56.359 FLH: Read block - Writing: 4096 - Total: 3416064 - Buffer size: 1959
        15:52:56.386 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "28", "time_elapsed": 154}}
        15:52:56.479 FLH: Read block - Writing: 4096 - Total: 3420160 - Buffer size: 1959
        15:52:56.626 FLH: Read block - Writing: 4096 - Total: 3424256 - Buffer size: 1959
        15:52:56.757 FLH: Read block - Writing: 4096 - Total: 3428352 - Buffer size: 1959
        15:52:56.958 FLH: Read block - Writing: 4096 - Total: 3432448 - Buffer size: 1959
        15:52:57.158 FLH: Read block - Writing: 4096 - Total: 3436544 - Buffer size: 1959
        15:52:57.274 FLH: Read block - Writing: 4096 - Total: 3440640 - Buffer size: 1959
        15:52:57.458 FLH: Read block - Writing: 4096 - Total: 3444736 - Buffer size: 1959
        15:52:57.658 FLH: Read block - Writing: 4096 - Total: 3448832 - Buffer size: 1959
        15:52:57.858 FLH: Read block - Writing: 4096 - Total: 3452928 - Buffer size: 1959
        15:52:58.056 FLH: Read block - Writing: 4096 - Total: 3457024 - Buffer size: 1959
        15:52:58.262 FLH: Read block - Writing: 4096 - Total: 3461120 - Buffer size: 1959
        15:52:58.457 FLH: Read block - Writing: 4096 - Total: 3465216 - Buffer size: 1959
        15:52:58.658 FLH: Read block - Writing: 4096 - Total: 3469312 - Buffer size: 1959
        15:52:58.810 FLH: Read block - Writing: 4096 - Total: 3473408 - Buffer size: 1959
        15:52:58.923 FLH: Read block - Writing: 4096 - Total: 3477504 - Buffer size: 1959
        15:52:59.265 FLH: Read block - Writing: 4096 - Total: 3481600 - Buffer size: 1959
        15:52:59.412 FLH: Read block - Writing: 4096 - Total: 3485696 - Buffer size: 1959
        15:52:59.559 FLH: Read block - Writing: 4096 - Total: 3489792 - Buffer size: 1959
        15:52:59.758 FLH: Read block - Writing: 4096 - Total: 3493888 - Buffer size: 1959
        15:52:59.958 FLH: Read block - Writing: 4096 - Total: 3497984 - Buffer size: 1959
        15:53:00.158 FLH: Read block - Writing: 4096 - Total: 3502080 - Buffer size: 1959
        15:53:00.275 FLH: Read block - Writing: 4096 - Total: 3506176 - Buffer size: 1959
        15:53:00.458 FLH: Read block - Writing: 4096 - Total: 3510272 - Buffer size: 1959
        15:53:00.658 FLH: Read block - Writing: 4096 - Total: 3514368 - Buffer size: 1959
        15:53:00.770 FLH: Read block - Writing: 4096 - Total: 3518464 - Buffer size: 1959
        15:53:00.958 FLH: Read block - Writing: 4096 - Total: 3522560 - Buffer size: 1959
        15:53:01.160 FLH: Read block - Writing: 4096 - Total: 3526656 - Buffer size: 1959
        15:53:01.320 FLH: Read block - Writing: 4096 - Total: 3530752 - Buffer size: 1959
        15:53:01.457 FLH: Read block - Writing: 4096 - Total: 3534848 - Buffer size: 1959
        15:53:01.657 FLH: Read block - Writing: 4096 - Total: 3538944 - Buffer size: 1959
        15:53:01.771 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "29", "time_elapsed": 159}}
        15:53:01.864 FLH: Read block - Writing: 4096 - Total: 3543040 - Buffer size: 1959
        15:53:02.057 FLH: Read block - Writing: 4096 - Total: 3547136 - Buffer size: 1959
        15:53:02.264 FLH: Read block - Writing: 4096 - Total: 3551232 - Buffer size: 1959
        15:53:02.458 FLH: Read block - Writing: 4096 - Total: 3555328 - Buffer size: 1959
        15:53:02.658 FLH: Read block - Writing: 4096 - Total: 3559424 - Buffer size: 1959
        15:53:02.858 FLH: Read block - Writing: 4096 - Total: 3563520 - Buffer size: 1959
        15:53:03.057 FLH: Read block - Writing: 4096 - Total: 3567616 - Buffer size: 1959
        15:53:03.264 FLH: Read block - Writing: 4096 - Total: 3571712 - Buffer size: 1959
        15:53:03.458 FLH: Read block - Writing: 4096 - Total: 3575808 - Buffer size: 1959
        15:53:03.660 FLH: Read block - Writing: 4096 - Total: 3579904 - Buffer size: 1959
        15:53:03.811 FLH: Read block - Writing: 4096 - Total: 3584000 - Buffer size: 1959
        15:53:03.924 FLH: Read block - Writing: 4096 - Total: 3588096 - Buffer size: 1959
        15:53:04.058 FLH: Read block - Writing: 4096 - Total: 3592192 - Buffer size: 1959
        15:53:04.263 FLH: Read block - Writing: 4096 - Total: 3596288 - Buffer size: 1959
        15:53:04.458 FLH: Read block - Writing: 4096 - Total: 3600384 - Buffer size: 1959
        15:53:04.658 FLH: Read block - Writing: 4096 - Total: 3604480 - Buffer size: 1959
        15:53:04.858 FLH: Read block - Writing: 4096 - Total: 3608576 - Buffer size: 1959
        15:53:05.058 FLH: Read block - Writing: 4096 - Total: 3612672 - Buffer size: 1959
        15:53:05.265 FLH: Read block - Writing: 4096 - Total: 3616768 - Buffer size: 1959
        15:53:05.457 FLH: Read block - Writing: 4096 - Total: 3620864 - Buffer size: 1959
        15:53:05.657 FLH: Read block - Writing: 4096 - Total: 3624960 - Buffer size: 1959
        15:53:05.857 FLH: Read block - Writing: 4096 - Total: 3629056 - Buffer size: 1959
        15:53:06.058 FLH: Read block - Writing: 4096 - Total: 3633152 - Buffer size: 1959
        15:53:06.211 FLH: Read block - Writing: 4096 - Total: 3637248 - Buffer size: 1959
        15:53:06.324 FLH: Read block - Writing: 4096 - Total: 3641344 - Buffer size: 1959
        15:53:06.436 FLH: Read block - Writing: 4096 - Total: 3645440 - Buffer size: 1959
        15:53:06.560 FLH: Read block - Writing: 4096 - Total: 3649536 - Buffer size: 1959
        15:53:06.760 FLH: Read block - Writing: 4096 - Total: 3653632 - Buffer size: 1959
        15:53:06.978 FLH: Read block - Writing: 4096 - Total: 3657728 - Buffer size: 1959
        15:53:07.160 FLH: Read block - Writing: 4096 - Total: 3661824 - Buffer size: 1959
        15:53:07.189 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "30", "time_elapsed": 164}}
        15:53:07.281 FLH: Read block - Writing: 4096 - Total: 3665920 - Buffer size: 1959
        15:53:07.460 FLH: Read block - Writing: 4096 - Total: 3670016 - Buffer size: 1959
        15:53:07.660 FLH: Read block - Writing: 4096 - Total: 3674112 - Buffer size: 1959
        15:53:07.859 FLH: Read block - Writing: 4096 - Total: 3678208 - Buffer size: 1959
        15:53:07.971 FLH: Read block - Writing: 4096 - Total: 3682304 - Buffer size: 1959
        15:53:08.160 FLH: Read block - Writing: 4096 - Total: 3686400 - Buffer size: 1959
        15:53:08.275 FLH: Read block - Writing: 4096 - Total: 3690496 - Buffer size: 1959
        15:53:08.460 FLH: Read block - Writing: 4096 - Total: 3694592 - Buffer size: 1959
        15:53:08.660 FLH: Read block - Writing: 4096 - Total: 3698688 - Buffer size: 1959
        15:53:08.860 FLH: Read block - Writing: 4096 - Total: 3702784 - Buffer size: 1959
        15:53:09.059 FLH: Read block - Writing: 4096 - Total: 3706880 - Buffer size: 1959
        15:53:09.265 FLH: Read block - Writing: 4096 - Total: 3710976 - Buffer size: 1959
        15:53:09.461 FLH: Read block - Writing: 4096 - Total: 3715072 - Buffer size: 1959
        15:53:09.609 FLH: Read block - Writing: 4096 - Total: 3719168 - Buffer size: 1959
        15:53:09.757 FLH: Read block - Writing: 4096 - Total: 3723264 - Buffer size: 1959
        15:53:09.958 FLH: Read block - Writing: 4096 - Total: 3727360 - Buffer size: 1959
        15:53:10.158 FLH: Read block - Writing: 4096 - Total: 3731456 - Buffer size: 1959
        15:53:10.275 FLH: Read block - Writing: 4096 - Total: 3735552 - Buffer size: 1959
        15:53:10.458 FLH: Read block - Writing: 4096 - Total: 3739648 - Buffer size: 1959
        15:53:10.658 FLH: Read block - Writing: 4096 - Total: 3743744 - Buffer size: 1959
        15:53:10.858 FLH: Read block - Writing: 4096 - Total: 3747840 - Buffer size: 1959
        15:53:11.057 FLH: Read block - Writing: 4096 - Total: 3751936 - Buffer size: 1959
        15:53:11.264 FLH: Read block - Writing: 4096 - Total: 3756032 - Buffer size: 1959
        15:53:11.458 FLH: Read block - Writing: 4096 - Total: 3760128 - Buffer size: 1959
        15:53:11.657 FLH: Read block - Writing: 4096 - Total: 3764224 - Buffer size: 1959
        15:53:11.858 FLH: Read block - Writing: 4096 - Total: 3768320 - Buffer size: 1959
        15:53:12.058 FLH: Read block - Writing: 4096 - Total: 3772416 - Buffer size: 1959
        15:53:12.199 FLH: Read block - Writing: 4096 - Total: 3776512 - Buffer size: 1959
        15:53:12.315 FLH: Read block - Writing: 4096 - Total: 3780608 - Buffer size: 1959
        15:53:12.430 FLH: Read block - Writing: 4096 - Total: 3784704 - Buffer size: 1959
        15:53:12.472 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "31", "time_elapsed": 170}}
        15:53:12.565 FLH: Read block - Writing: 4096 - Total: 3788800 - Buffer size: 1959
        15:53:12.758 FLH: Read block - Writing: 4096 - Total: 3792896 - Buffer size: 1959
        15:53:12.958 FLH: Read block - Writing: 4096 - Total: 3796992 - Buffer size: 1959
        15:53:13.158 FLH: Read block - Writing: 4096 - Total: 3801088 - Buffer size: 1959
        15:53:13.274 FLH: Read block - Writing: 4096 - Total: 3805184 - Buffer size: 1959
        15:53:13.559 FLH: Read block - Writing: 4096 - Total: 3809280 - Buffer size: 1959
        15:53:13.758 FLH: Read block - Writing: 4096 - Total: 3813376 - Buffer size: 1959
        15:53:13.958 FLH: Read block - Writing: 4096 - Total: 3817472 - Buffer size: 1959
        15:53:14.158 FLH: Read block - Writing: 4096 - Total: 3821568 - Buffer size: 1959
        15:53:14.274 FLH: Read block - Writing: 4096 - Total: 3825664 - Buffer size: 1959
        15:53:14.458 FLH: Read block - Writing: 4096 - Total: 3829760 - Buffer size: 1959
        15:53:14.609 FLH: Read block - Writing: 4096 - Total: 3833856 - Buffer size: 1959
        15:53:14.756 FLH: Read block - Writing: 4096 - Total: 3837952 - Buffer size: 1959
        15:53:14.957 FLH: Read block - Writing: 4096 - Total: 3842048 - Buffer size: 1959
        15:53:15.158 FLH: Read block - Writing: 4096 - Total: 3846144 - Buffer size: 1959
        15:53:15.273 FLH: Read block - Writing: 4096 - Total: 3850240 - Buffer size: 1959
        15:53:15.457 FLH: Read block - Writing: 4096 - Total: 3854336 - Buffer size: 1959
        15:53:15.657 FLH: Read block - Writing: 4096 - Total: 3858432 - Buffer size: 1959
        15:53:15.858 FLH: Read block - Writing: 4096 - Total: 3862528 - Buffer size: 1959
        15:53:16.057 FLH: Read block - Writing: 4096 - Total: 3866624 - Buffer size: 1959
        15:53:16.264 FLH: Read block - Writing: 4096 - Total: 3870720 - Buffer size: 1959
        15:53:16.458 FLH: Read block - Writing: 4096 - Total: 3874816 - Buffer size: 1959
        15:53:16.658 FLH: Read block - Writing: 4096 - Total: 3878912 - Buffer size: 1959
        15:53:16.858 FLH: Read block - Writing: 4096 - Total: 3883008 - Buffer size: 1959
        15:53:17.058 FLH: Read block - Writing: 4096 - Total: 3887104 - Buffer size: 1959
        15:53:17.206 FLH: Read block - Writing: 4096 - Total: 3891200 - Buffer size: 1959
        15:53:17.318 FLH: Read block - Writing: 4096 - Total: 3895296 - Buffer size: 1959
        15:53:17.430 FLH: Read block - Writing: 4096 - Total: 3899392 - Buffer size: 1959
        15:53:17.558 FLH: Read block - Writing: 4096 - Total: 3903488 - Buffer size: 1959
        15:53:17.671 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "32", "time_elapsed": 175}}
        15:53:17.764 FLH: Read block - Writing: 4096 - Total: 3907584 - Buffer size: 1959
        15:53:17.958 FLH: Read block - Writing: 4096 - Total: 3911680 - Buffer size: 1959
        15:53:18.158 FLH: Read block - Writing: 4096 - Total: 3915776 - Buffer size: 1959
        15:53:18.317 FLH: Read block - Writing: 4096 - Total: 3919872 - Buffer size: 1959
        15:53:18.457 FLH: Read block - Writing: 4096 - Total: 3923968 - Buffer size: 1959
        15:53:18.657 FLH: Read block - Writing: 4096 - Total: 3928064 - Buffer size: 1959
        15:53:18.857 FLH: Read block - Writing: 4096 - Total: 3932160 - Buffer size: 1959
        15:53:18.969 FLH: Read block - Writing: 4096 - Total: 3936256 - Buffer size: 1959
        15:53:19.264 FLH: Read block - Writing: 4096 - Total: 3940352 - Buffer size: 1959
        15:53:19.458 FLH: Read block - Writing: 4096 - Total: 3944448 - Buffer size: 1959
        15:53:19.658 FLH: Read block - Writing: 4096 - Total: 3948544 - Buffer size: 1959
        15:53:19.804 FLH: Read block - Writing: 4096 - Total: 3952640 - Buffer size: 1959
        15:53:19.957 FLH: Read block - Writing: 4096 - Total: 3956736 - Buffer size: 1959
        15:53:20.157 FLH: Read block - Writing: 4096 - Total: 3960832 - Buffer size: 1959
        15:53:20.273 FLH: Read block - Writing: 4096 - Total: 3964928 - Buffer size: 1959
        15:53:20.457 FLH: Read block - Writing: 4096 - Total: 3969024 - Buffer size: 1959
        15:53:20.659 FLH: Read block - Writing: 4096 - Total: 3973120 - Buffer size: 1959
        15:53:20.812 FLH: Read block - Writing: 4096 - Total: 3977216 - Buffer size: 1959
        15:53:20.925 FLH: Read block - Writing: 4096 - Total: 3981312 - Buffer size: 1959
        15:53:21.057 FLH: Read block - Writing: 4096 - Total: 3985408 - Buffer size: 1959
        15:53:21.264 FLH: Read block - Writing: 4096 - Total: 3989504 - Buffer size: 1959
        15:53:21.458 FLH: Read block - Writing: 4096 - Total: 3993600 - Buffer size: 1959
        15:53:21.658 FLH: Read block - Writing: 4096 - Total: 3997696 - Buffer size: 1959
        15:53:21.858 FLH: Read block - Writing: 4096 - Total: 4001792 - Buffer size: 1959
        15:53:22.058 FLH: Read block - Writing: 4096 - Total: 4005888 - Buffer size: 1959
        15:53:22.264 FLH: Read block - Writing: 4096 - Total: 4009984 - Buffer size: 1959
        15:53:22.410 FLH: Read block - Writing: 4096 - Total: 4014080 - Buffer size: 1959
        15:53:22.560 FLH: Read block - Writing: 4096 - Total: 4018176 - Buffer size: 1959
        15:53:22.760 FLH: Read block - Writing: 4096 - Total: 4022272 - Buffer size: 1959
        15:53:22.959 FLH: Read block - Writing: 4096 - Total: 4026368 - Buffer size: 1959
        15:53:23.076 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "33", "time_elapsed": 180}}
        15:53:23.168 FLH: Read block - Writing: 4096 - Total: 4030464 - Buffer size: 1959
        15:53:23.328 FLH: Read block - Writing: 4096 - Total: 4034560 - Buffer size: 1959
        15:53:23.440 FLH: Read block - Writing: 4096 - Total: 4038656 - Buffer size: 1959
        15:53:23.558 FLH: Read block - Writing: 4096 - Total: 4042752 - Buffer size: 1959
        15:53:23.758 FLH: Read block - Writing: 4096 - Total: 4046848 - Buffer size: 1959
        15:53:23.958 FLH: Read block - Writing: 4096 - Total: 4050944 - Buffer size: 1959
        15:53:24.158 FLH: Read block - Writing: 4096 - Total: 4055040 - Buffer size: 1959
        15:53:24.273 FLH: Read block - Writing: 4096 - Total: 4059136 - Buffer size: 1959
        15:53:24.458 FLH: Read block - Writing: 4096 - Total: 4063232 - Buffer size: 1959
        15:53:24.657 FLH: Read block - Writing: 4096 - Total: 4067328 - Buffer size: 1959
        15:53:24.857 FLH: Read block - Writing: 4096 - Total: 4071424 - Buffer size: 1959
        15:53:25.057 FLH: Read block - Writing: 4096 - Total: 4075520 - Buffer size: 1959
        15:53:25.263 FLH: Read block - Writing: 4096 - Total: 4079616 - Buffer size: 1959
        15:53:25.458 FLH: Read block - Writing: 4096 - Total: 4083712 - Buffer size: 1959
        15:53:25.658 FLH: Read block - Writing: 4096 - Total: 4087808 - Buffer size: 1959
        15:53:25.813 FLH: Read block - Writing: 4096 - Total: 4091904 - Buffer size: 1959
        15:53:25.925 FLH: Read block - Writing: 4096 - Total: 4096000 - Buffer size: 1959
        15:53:26.058 FLH: Read block - Writing: 4096 - Total: 4100096 - Buffer size: 1959
        15:53:26.264 FLH: Read block - Writing: 4096 - Total: 4104192 - Buffer size: 1959
        15:53:26.458 FLH: Read block - Writing: 4096 - Total: 4108288 - Buffer size: 1959
        15:53:26.658 FLH: Read block - Writing: 4096 - Total: 4112384 - Buffer size: 1959
        15:53:26.858 FLH: Read block - Writing: 4096 - Total: 4116480 - Buffer size: 1959
        15:53:26.970 FLH: Read block - Writing: 4096 - Total: 4120576 - Buffer size: 1959
        15:53:27.158 FLH: Read block - Writing: 4096 - Total: 4124672 - Buffer size: 1959
        15:53:27.275 FLH: Read block - Writing: 4096 - Total: 4128768 - Buffer size: 1959
        15:53:27.422 FLH: Read block - Writing: 4096 - Total: 4132864 - Buffer size: 1959
        15:53:28.057 FLH: Read block - Writing: 4096 - Total: 4136960 - Buffer size: 1959
        15:53:28.263 FLH: Read block - Writing: 4096 - Total: 4141056 - Buffer size: 1959
        15:53:28.458 FLH: Read block - Writing: 4096 - Total: 4145152 - Buffer size: 1959
        15:53:28.657 FLH: Read block - Writing: 4096 - Total: 4149248 - Buffer size: 1959
        15:53:28.771 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "34", "time_elapsed": 186}}
        15:53:28.864 FLH: Read block - Writing: 4096 - Total: 4153344 - Buffer size: 1959
        15:53:29.058 FLH: Read block - Writing: 4096 - Total: 4157440 - Buffer size: 1959
        15:53:29.263 FLH: Read block - Writing: 4096 - Total: 4161536 - Buffer size: 1959
        15:53:29.458 FLH: Read block - Writing: 4096 - Total: 4165632 - Buffer size: 1959
        15:53:29.658 FLH: Read block - Writing: 4096 - Total: 4169728 - Buffer size: 1959
        15:53:29.858 FLH: Read block - Writing: 4096 - Total: 4173824 - Buffer size: 1959
        15:53:30.000 FLH: Read block - Writing: 4096 - Total: 4177920 - Buffer size: 1959
        15:53:30.158 FLH: Read block - Writing: 4096 - Total: 4182016 - Buffer size: 1959
        15:53:30.273 FLH: Read block - Writing: 4096 - Total: 4186112 - Buffer size: 1959
        15:53:30.458 FLH: Read block - Writing: 4096 - Total: 4190208 - Buffer size: 1959
        15:53:30.658 FLH: Read block - Writing: 4096 - Total: 4194304 - Buffer size: 1959
        15:53:30.858 FLH: Read block - Writing: 4096 - Total: 4198400 - Buffer size: 1959
        15:53:31.458 FLH: Read block - Writing: 4096 - Total: 4202496 - Buffer size: 1959
        15:53:31.657 FLH: Read block - Writing: 4096 - Total: 4206592 - Buffer size: 1959
        15:53:31.857 FLH: Read block - Writing: 4096 - Total: 4210688 - Buffer size: 1959
        15:53:31.970 FLH: Read block - Writing: 4096 - Total: 4214784 - Buffer size: 1959
        15:53:32.158 FLH: Read block - Writing: 4096 - Total: 4218880 - Buffer size: 1959
        15:53:32.274 FLH: Read block - Writing: 4096 - Total: 4222976 - Buffer size: 1959
        15:53:32.416 FLH: Read block - Writing: 4096 - Total: 4227072 - Buffer size: 1959
        15:53:32.558 FLH: Read block - Writing: 4096 - Total: 4231168 - Buffer size: 1959
        15:53:32.757 FLH: Read block - Writing: 4096 - Total: 4235264 - Buffer size: 1959
        15:53:32.958 FLH: Read block - Writing: 4096 - Total: 4239360 - Buffer size: 1959
        15:53:33.110 FLH: Read block - Writing: 4096 - Total: 4243456 - Buffer size: 1959
        15:53:33.265 FLH: Read block - Writing: 4096 - Total: 4247552 - Buffer size: 1959
        15:53:33.460 FLH: Read block - Writing: 4096 - Total: 4251648 - Buffer size: 1959
        15:53:33.660 FLH: Read block - Writing: 4096 - Total: 4255744 - Buffer size: 1959
        15:53:33.860 FLH: Read block - Writing: 4096 - Total: 4259840 - Buffer size: 1959
        15:53:33.971 FLH: Read block - Writing: 4096 - Total: 4263936 - Buffer size: 1959
        15:53:34.760 FLH: Read block - Writing: 4096 - Total: 4268032 - Buffer size: 1959
        15:53:34.901 FLH: Read block - Writing: 4096 - Total: 4272128 - Buffer size: 1959
        15:53:34.928 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "35", "time_elapsed": 192}}
        15:53:35.021 FLH: Read block - Writing: 4096 - Total: 4276224 - Buffer size: 1959
        15:53:35.158 FLH: Read block - Writing: 4096 - Total: 4280320 - Buffer size: 1959
        15:53:35.274 FLH: Read block - Writing: 4096 - Total: 4284416 - Buffer size: 1959
        15:53:35.457 FLH: Read block - Writing: 4096 - Total: 4288512 - Buffer size: 1959
        15:53:35.609 FLH: Read block - Writing: 4096 - Total: 4292608 - Buffer size: 1959
        15:53:35.757 FLH: Read block - Writing: 4096 - Total: 4296704 - Buffer size: 1959
        15:53:35.958 FLH: Read block - Writing: 4096 - Total: 4300800 - Buffer size: 1959
        15:53:36.070 FLH: Read block - Writing: 4096 - Total: 4304896 - Buffer size: 1959
        15:53:36.265 FLH: Read block - Writing: 4096 - Total: 4308992 - Buffer size: 1959
        15:53:36.457 FLH: Read block - Writing: 4096 - Total: 4313088 - Buffer size: 1959
        15:53:36.658 FLH: Read block - Writing: 4096 - Total: 4317184 - Buffer size: 1959
        15:53:36.859 FLH: Read block - Writing: 4096 - Total: 4321280 - Buffer size: 1959
        15:53:37.057 FLH: Read block - Writing: 4096 - Total: 4325376 - Buffer size: 1959
        15:53:37.265 FLH: Read block - Writing: 4096 - Total: 4329472 - Buffer size: 1959
        15:53:37.962 FLH: Read block - Writing: 4096 - Total: 4333568 - Buffer size: 1959
        15:53:38.116 FLH: Read block - Writing: 4096 - Total: 4337664 - Buffer size: 1959
        15:53:38.263 FLH: Read block - Writing: 4096 - Total: 4341760 - Buffer size: 1959
        15:53:38.457 FLH: Read block - Writing: 4096 - Total: 4345856 - Buffer size: 1959
        15:53:38.658 FLH: Read block - Writing: 4096 - Total: 4349952 - Buffer size: 1959
        15:53:38.858 FLH: Read block - Writing: 4096 - Total: 4354048 - Buffer size: 1959
        15:53:39.058 FLH: Read block - Writing: 4096 - Total: 4358144 - Buffer size: 1959
        15:53:39.264 FLH: Read block - Writing: 4096 - Total: 4362240 - Buffer size: 1959
        15:53:39.458 FLH: Read block - Writing: 4096 - Total: 4366336 - Buffer size: 1959
        15:53:39.658 FLH: Read block - Writing: 4096 - Total: 4370432 - Buffer size: 1959
        15:53:39.857 FLH: Read block - Writing: 4096 - Total: 4374528 - Buffer size: 1959
        15:53:39.969 FLH: Read block - Writing: 4096 - Total: 4378624 - Buffer size: 1959
        15:53:40.110 FLH: Read block - Writing: 4096 - Total: 4382720 - Buffer size: 1959
        15:53:40.263 FLH: Read block - Writing: 4096 - Total: 4386816 - Buffer size: 1959
        15:53:40.459 FLH: Read block - Writing: 4096 - Total: 4390912 - Buffer size: 1959
        15:53:40.612 FLH: Read block - Writing: 4096 - Total: 4395008 - Buffer size: 1959
        15:53:41.177 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "36", "time_elapsed": 198}}
        15:53:41.269 FLH: Read block - Writing: 4096 - Total: 4399104 - Buffer size: 1959
        15:53:41.458 FLH: Read block - Writing: 4096 - Total: 4403200 - Buffer size: 1959
        15:53:41.658 FLH: Read block - Writing: 4096 - Total: 4407296 - Buffer size: 1959
        15:53:41.858 FLH: Read block - Writing: 4096 - Total: 4411392 - Buffer size: 1959
        15:53:42.058 FLH: Read block - Writing: 4096 - Total: 4415488 - Buffer size: 1959
        15:53:42.264 FLH: Read block - Writing: 4096 - Total: 4419584 - Buffer size: 1959
        15:53:42.458 FLH: Read block - Writing: 4096 - Total: 4423680 - Buffer size: 1959
        15:53:42.678 FLH: Read block - Writing: 4096 - Total: 4427776 - Buffer size: 1959
        15:53:42.858 FLH: Read block - Writing: 4096 - Total: 4431872 - Buffer size: 1959
        15:53:43.010 FLH: Read block - Writing: 4096 - Total: 4435968 - Buffer size: 1959
        15:53:43.160 FLH: Read block - Writing: 4096 - Total: 4440064 - Buffer size: 1959
        15:53:43.275 FLH: Read block - Writing: 4096 - Total: 4444160 - Buffer size: 1959
        15:53:43.460 FLH: Read block - Writing: 4096 - Total: 4448256 - Buffer size: 1959
        15:53:43.660 FLH: Read block - Writing: 4096 - Total: 4452352 - Buffer size: 1959
        15:53:43.859 FLH: Read block - Writing: 4096 - Total: 4456448 - Buffer size: 1959
        15:53:43.971 FLH: Read block - Writing: 4096 - Total: 4460544 - Buffer size: 1959
        15:53:44.760 FLH: Read block - Writing: 4096 - Total: 4464640 - Buffer size: 1959
        15:53:44.960 FLH: Read block - Writing: 4096 - Total: 4468736 - Buffer size: 1959
        15:53:45.106 FLH: Read block - Writing: 4096 - Total: 4472832 - Buffer size: 1959
        15:53:45.263 FLH: Read block - Writing: 4096 - Total: 4476928 - Buffer size: 1959
        15:53:45.418 FLH: Read block - Writing: 4096 - Total: 4481024 - Buffer size: 1959
        15:53:45.557 FLH: Read block - Writing: 4096 - Total: 4485120 - Buffer size: 1959
        15:53:45.758 FLH: Read block - Writing: 4096 - Total: 4489216 - Buffer size: 1959
        15:53:45.958 FLH: Read block - Writing: 4096 - Total: 4493312 - Buffer size: 1959
        15:53:46.158 FLH: Read block - Writing: 4096 - Total: 4497408 - Buffer size: 1959
        15:53:46.273 FLH: Read block - Writing: 4096 - Total: 4501504 - Buffer size: 1959
        15:53:46.458 FLH: Read block - Writing: 4096 - Total: 4505600 - Buffer size: 1959
        15:53:46.657 FLH: Read block - Writing: 4096 - Total: 4509696 - Buffer size: 1959
        15:53:46.858 FLH: Read block - Writing: 4096 - Total: 4513792 - Buffer size: 1959
        15:53:46.971 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "37", "time_elapsed": 204}}
        15:53:47.064 FLH: Read block - Writing: 4096 - Total: 4517888 - Buffer size: 1959
        15:53:47.264 FLH: Read block - Writing: 4096 - Total: 4521984 - Buffer size: 1959
        15:53:47.458 FLH: Read block - Writing: 4096 - Total: 4526080 - Buffer size: 1959
        15:53:48.158 FLH: Read block - Writing: 4096 - Total: 4530176 - Buffer size: 1959
        15:53:48.274 FLH: Read block - Writing: 4096 - Total: 4534272 - Buffer size: 1959
        15:53:48.457 FLH: Read block - Writing: 4096 - Total: 4538368 - Buffer size: 1959
        15:53:48.658 FLH: Read block - Writing: 4096 - Total: 4542464 - Buffer size: 1959
        15:53:48.859 FLH: Read block - Writing: 4096 - Total: 4546560 - Buffer size: 1959
        15:53:48.971 FLH: Read block - Writing: 4096 - Total: 4550656 - Buffer size: 1959
        15:53:49.158 FLH: Read block - Writing: 4096 - Total: 4554752 - Buffer size: 1959
        15:53:49.275 FLH: Read block - Writing: 4096 - Total: 4558848 - Buffer size: 1959
        15:53:49.458 FLH: Read block - Writing: 4096 - Total: 4562944 - Buffer size: 1959
        15:53:49.657 FLH: Read block - Writing: 4096 - Total: 4567040 - Buffer size: 1959
        15:53:49.858 FLH: Read block - Writing: 4096 - Total: 4571136 - Buffer size: 1959
        15:53:50.058 FLH: Read block - Writing: 4096 - Total: 4575232 - Buffer size: 1959
        15:53:50.217 FLH: Read block - Writing: 4096 - Total: 4579328 - Buffer size: 1959
        15:53:50.370 FLH: Read block - Writing: 4096 - Total: 4583424 - Buffer size: 1959
        15:53:50.482 FLH: Read block - Writing: 4096 - Total: 4587520 - Buffer size: 1959
        15:53:50.658 FLH: Read block - Writing: 4096 - Total: 4591616 - Buffer size: 1959
        15:53:51.358 FLH: Read block - Writing: 4096 - Total: 4595712 - Buffer size: 1959
        15:53:51.559 FLH: Read block - Writing: 4096 - Total: 4599808 - Buffer size: 1959
        15:53:51.758 FLH: Read block - Writing: 4096 - Total: 4603904 - Buffer size: 1959
        15:53:51.958 FLH: Read block - Writing: 4096 - Total: 4608000 - Buffer size: 1959
        15:53:52.158 FLH: Read block - Writing: 4096 - Total: 4612096 - Buffer size: 1959
        15:53:52.273 FLH: Read block - Writing: 4096 - Total: 4616192 - Buffer size: 1959
        15:53:52.458 FLH: Read block - Writing: 4096 - Total: 4620288 - Buffer size: 1959
        15:53:52.657 FLH: Read block - Writing: 4096 - Total: 4624384 - Buffer size: 1959
        15:53:52.858 FLH: Read block - Writing: 4096 - Total: 4628480 - Buffer size: 1959
        15:53:53.001 FLH: Read block - Writing: 4096 - Total: 4632576 - Buffer size: 1959
        15:53:53.159 FLH: Read block - Writing: 4096 - Total: 4636672 - Buffer size: 1959
        15:53:53.189 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "38", "time_elapsed": 210}}
        15:53:53.281 FLH: Read block - Writing: 4096 - Total: 4640768 - Buffer size: 1959
        15:53:53.459 FLH: Read block - Writing: 4096 - Total: 4644864 - Buffer size: 1959
        15:53:53.657 FLH: Read block - Writing: 4096 - Total: 4648960 - Buffer size: 1959
        15:53:53.857 FLH: Read block - Writing: 4096 - Total: 4653056 - Buffer size: 1959
        15:53:54.057 FLH: Read block - Writing: 4096 - Total: 4657152 - Buffer size: 1959
        15:53:54.758 FLH: Read block - Writing: 4096 - Total: 4661248 - Buffer size: 1959
        15:53:54.958 FLH: Read block - Writing: 4096 - Total: 4665344 - Buffer size: 1959
        15:53:55.111 FLH: Read block - Writing: 4096 - Total: 4669440 - Buffer size: 1959
        15:53:55.266 FLH: Read block - Writing: 4096 - Total: 4673536 - Buffer size: 1959
        15:53:55.407 FLH: Read block - Writing: 4096 - Total: 4677632 - Buffer size: 1959
        15:53:55.559 FLH: Read block - Writing: 4096 - Total: 4681728 - Buffer size: 1959
        15:53:55.758 FLH: Read block - Writing: 4096 - Total: 4685824 - Buffer size: 1959
        15:53:55.958 FLH: Read block - Writing: 4096 - Total: 4689920 - Buffer size: 1959
        15:53:56.158 FLH: Read block - Writing: 4096 - Total: 4694016 - Buffer size: 1959
        15:53:56.274 FLH: Read block - Writing: 4096 - Total: 4698112 - Buffer size: 1959
        15:53:56.458 FLH: Read block - Writing: 4096 - Total: 4702208 - Buffer size: 1959
        15:53:56.657 FLH: Read block - Writing: 4096 - Total: 4706304 - Buffer size: 1959
        15:53:56.858 FLH: Read block - Writing: 4096 - Total: 4710400 - Buffer size: 1959
        15:53:57.058 FLH: Read block - Writing: 4096 - Total: 4714496 - Buffer size: 1959
        15:53:57.264 FLH: Read block - Writing: 4096 - Total: 4718592 - Buffer size: 1959
        15:53:57.460 FLH: Read block - Writing: 4096 - Total: 4722688 - Buffer size: 1959
        15:53:58.160 FLH: Read block - Writing: 4096 - Total: 4726784 - Buffer size: 1959
        15:53:58.275 FLH: Read block - Writing: 4096 - Total: 4730880 - Buffer size: 1959
        15:53:58.459 FLH: Read block - Writing: 4096 - Total: 4734976 - Buffer size: 1959
        15:53:58.660 FLH: Read block - Writing: 4096 - Total: 4739072 - Buffer size: 1959
        15:53:58.859 FLH: Read block - Writing: 4096 - Total: 4743168 - Buffer size: 1959
        15:53:58.971 FLH: Read block - Writing: 4096 - Total: 4747264 - Buffer size: 1959
        15:53:59.160 FLH: Read block - Writing: 4096 - Total: 4751360 - Buffer size: 1959
        15:53:59.275 FLH: Read block - Writing: 4096 - Total: 4755456 - Buffer size: 1959
        15:53:59.459 FLH: Read block - Writing: 4096 - Total: 4759552 - Buffer size: 1959
        15:53:59.573 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "39", "time_elapsed": 217}}
        15:53:59.666 FLH: Read block - Writing: 4096 - Total: 4763648 - Buffer size: 1959
        15:53:59.860 FLH: Read block - Writing: 4096 - Total: 4767744 - Buffer size: 1959
        15:54:00.015 FLH: Read block - Writing: 4096 - Total: 4771840 - Buffer size: 1959
        15:54:00.158 FLH: Read block - Writing: 4096 - Total: 4775936 - Buffer size: 1959
        15:54:00.273 FLH: Read block - Writing: 4096 - Total: 4780032 - Buffer size: 1959
        15:54:00.458 FLH: Read block - Writing: 4096 - Total: 4784128 - Buffer size: 1959
        15:54:00.605 FLH: Read block - Writing: 4096 - Total: 4788224 - Buffer size: 1959
        ArmilarA
        ArmilarA
        Armilar
        Most Active Forum Testing
        #7573
        @australien
        versuche mal die
        FlashNextionAdv0 http://nspanel.de/nspanel-v0.0.0.tft
        EDIT: Ist ja irgendwie immer die gleiche Länge und Zeit und Länge... Gibt es bei dir irgend ein QoS, was da die Leitung einschränkt?
        A 2 Antworten Letzte Antwort
        • ArmilarA Armilar
          @australien
          versuche mal die
          A
          A
          australien
          schrieb am zuletzt editiert von australien
          #7574
          @armilar
          QOS oder ähnliches gibt es meines Wissens nicht, hatte bis jetzt auch alles funktioniert.
          genau das gleichen
          6:11:23.874 MQT: SmartHome/NSPanel_1/stat/RESULT = {"FlashNextionAdv":"Done"}
          16:11:23.902 FLH: host: nspanel.de, port: 80, get: /nspanel-v0.0.0.tft
          16:11:23.957 FLH: Connected:true
          16:11:24.060 FLH: Retry 2
          16:11:24.273 FLH: HTTP Respose is 200 OK or 206 Partial Content
          16:11:24.274 FLH: Flash file size: 12197684
          16:11:24.275 SRC: Berry
          16:11:24.276 CMD: Grp 0, Cmd 'RULETIMER', Idx 3, Len 1, Pld 0, Data '0'
          16:11:24.282 MQT: SmartHome/NSPanel_1/stat/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
          16:11:24.287 SRC: Berry
          16:11:24.288 CMD: Grp 0, Cmd 'RULE', Idx 3, Len 1, Pld 0, Data '0'
          16:11:24.292 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
          16:11:24.308 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
          16:11:24.311 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
          16:11:24.313 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
          16:11:24.319 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
          16:11:24.444 FLH: Send (High Speed) flash start
          16:11:24.450 NXP: Nextion command sent = bytes('77686D692D777269732031323139373638342C3932313630302C72657330FFFF...')
          16:11:24.473 BRY: Serial UART2
          16:11:24.825 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "0", "time_elapsed": 0}}
          16:11:24.918 FLH: Read block - Writing: 4096 - Total: 4096 - Buffer size: 1395
          16:11:25.019 FLH: Waiting offset...
          16:11:29.819 FLH: Flash offset marker 0
          16:11:29.919 FLH: Read block - Writing: 4096 - Total: 8192 - Buffer size: 1395
          16:11:30.118 FLH: Read block - Writing: 4096 - Total: 12288 - Buffer size: 1395
          16:11:30.224 FLH: Read block - Writing: 4096 - Total: 16384 - Buffer size: 1395
          16:11:30.341 FLH: Read block - Writing: 4096 - Total: 20480 - Buffer size: 1395```
          16:14:53.123 FLH: Read block - Writing: 4096 - Total: 4763648 - Buffer size: 1395
          16:14:53.324 FLH: Read block - Writing: 4096 - Total: 4767744 - Buffer size: 1395
          16:14:53.434 FLH: Read block - Writing: 4096 - Total: 4771840 - Buffer size: 1395
          16:14:53.619 FLH: Read block - Writing: 4096 - Total: 4775936 - Buffer size: 1395
          16:14:53.819 FLH: Read block - Writing: 4096 - Total: 4780032 - Buffer size: 1395
          16:14:53.969 FLH: Read block - Writing: 4096 - Total: 4784128 - Buffer size: 1395
          16:14:54.119 FLH: Read block - Writing: 4096 - Total: 4788224 - Buffer size: 1395
          Chris_71C 1 Antwort Letzte Antwort
          • A australien
            @armilar
            genau das gleichen
            Chris_71C
            Chris_71C
            Chris_71
            #7575
            @Armilar
            Beim Wechsel von AccuWeather auf OpenWeatherMap wird mir nun beim Screensaver unter dem Symbol für Sonnenaufgang keine Uhrzeit mehr angezeigt - sondern nur Zahlen zB 1757653.
            Config alt:
                    // bottomScreensaverEntity 1
                            ScreensaverEntity: 'accuweather.0.Daily.Day1.Sunrise',
                            ScreensaverEntityFactor: 1,
                            ScreensaverEntityDecimalPlaces: 0,
                            ScreensaverEntityDateFormat: { hour: '2-digit', minute: '2-digit' }, // Description at Wiki-Pages
                            ScreensaverEntityIconOn: 'weather-sunset-up',
                            ScreensaverEntityIconOff: null,
                            ScreensaverEntityText: 'Sonne',
                            ScreensaverEntityIconColor: MSYellow
            Config Neu:
                        ScreensaverEntity: 'openweathermap.0.forecast.current.sunrise',
            • Chris_71C Chris_71
              @Armilar
              Config alt:
              Config Neu:
              ArmilarA
              ArmilarA
              Armilar
              #7576
              @chris_71
              kannste entweder formatiert duch einen Alias ziehen oder nimmst einfach etwas, was ne richtige Zeit hat...
                              ScreensaverEntity: 'javascript.0.variables.astro.sunrise',
              • A australien
                @armilar said in SONOFF NSPanel mit Lovelace UI:
                FlashNextionAdv2 http://nspanel.de/nspanel-v5.0.0.tft
                Tasmota ist die letzte 15.0.1
                das log bei der Adv1 Version:
                00:00:00.002 HDW: ESP32-D0WD-V3 v3.0
                00:00:00.016 UFS: FlashFS mounted with 272 kB free
                00:00:00.023 CFG: Loaded from File, Anzahl 1506
                00:00:00.032 QPC: Count 1
                00:00:00.032 CFG: CR 430/699, Busy 0
                00:00:00.037 TYA: Active=0
                00:00:00.042 ROT: Mode 1
                00:00:00.065 CFG: No '*.autoconf' file found
                00:00:00.069 BRY: Berry initialized, RAM used 3493 bytes
                00:00:00.075 BRY: No 'preinit.be'
                00:00:00.077 SRC: Restart
                00:00:00.081 Projekt tasmota - Tasmota Version 15.0.1(release-tasmota32)-3_1_3(2025.06.14 10:39:16)
                00:00:00.202 NXP: Initializing Driver
                00:00:00.204 BRY: Serial UART2
                00:00:00.206 BRY: Successfully loaded 'autoexec.be'
                00:00:00.287 WIF: Verbindungsversuch…
                00:00:01.000 WIF: verbinden mit AP1 FR@smart Channel 9 BSSId 7E:8A:20:51:6B:CA in Modus HT40 als NSPanel-1-5140...
                00:00:03.456 WIF: IPv6 Local fe80::e2e2:e6ff:fe0c:1414%st1
                00:00:03.561 WIF: Verbindungsversuch…
                00:00:04.561 WIF: Verbindungsversuch…
                00:00:05.561 WIF: Verbindungsversuch…
                00:00:06.027 WIF: IPv4 10.68.0.179, mask 255.255.0.0, gateway 10.68.0.1
                00:00:06.561 WIF: verbunden
                00:00:06.818 HTP: Web server active on NSPanel-1-5140 with IP address 10.68.0.179
                00:00:06.996 RTC: UTC 2025-09-12T12:58:16Z, DST 2025-03-30T02:00:00, STD 2025-10-26T03:00:00
                13:58:16.000 RTC: Synced by NTP
                13:58:16.812 MQT: Verbindungsversuch…
                13:58:16.832 MQT: verbunden
                13:58:16.835 MQT: SmartHome/NSPanel_1/tele/LWT = Online (beibehalten)
                13:58:16.836 MQT: SmartHome/NSPanel_1/cmnd/POWER =
                13:58:16.837 MQT: abonniere SmartHome/NSPanel_1/cmnd/#
                13:58:16.838 MQT: abonniere SmartHome/tasmotas/cmnd/#
                13:58:16.839 MQT: abonniere cmnd/NSPanel_1_fb/#
                13:58:16.841 MQT: SmartHome/NSPanel_1/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"15.0.1(release-tasmota32)","FallbackTopic":"cmnd/NSPanel_1_fb/","GroupTopic":"SmartHome/tasmotas/cmnd/"}}
                13:58:16.855 MQT: SmartHome/NSPanel_1/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-1-5140","IPAddress":"10.68.0.179","IP6Global":"","IP6Local":"fe80::e2e2:e6ff:fe0c:1414%st1"}}
                13:58:16.879 MQT: SmartHome/NSPanel_1/tele/INFO3 = {"Info3":{"RestartReason":"Vbat power on reset","BootCount":163}}
                13:58:16.884 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                13:58:16.896 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                13:58:16.897 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER2":"OFF"}
                13:58:16.898 MQT: SmartHome/NSPanel_1/stat/POWER2 = OFF
                13:58:16.959 QPC: Reset
                13:58:17.093 SRC: MQTT
                13:58:17.094 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                13:58:17.105 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                13:58:17.109 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                13:58:17.143 SRC: MQTT
                13:58:17.144 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                13:58:17.145 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                13:58:17.147 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                13:58:17.193 SRC: MQTT
                13:58:17.194 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                13:58:17.206 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                13:58:17.210 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                13:58:17.243 SRC: MQTT
                13:58:17.244 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                13:58:17.247 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                13:58:17.250 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                13:58:17.293 SRC: MQTT
                13:58:17.294 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                13:58:17.305 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                13:58:17.309 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                13:58:17.343 SRC: MQTT
                13:58:17.344 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                13:58:17.347 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                13:58:17.350 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                13:58:18.844 SRC: MQTT
                13:58:18.844 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                13:58:18.858 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                13:58:18.862 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                13:58:18.893 SRC: MQTT
                13:58:18.894 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                13:58:18.896 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                13:58:18.897 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                13:58:18.952 APP: Startvorgänge 163
                13:58:19.480 CFG: Saved, Anzahl 1507, Bytes 4096
                13:58:21.226 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2025-09-12T13:58:21","Uptime":"0T00:00:12","UptimeSec":12,"Heap":148,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":368,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":212},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FR@smart","BSSId":"7E:8A:20:51:6B:CA","Channel":9,"Mode":"HT40","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:06"}}
                13:58:21.270 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2025-09-12T13:58:21","ANALOG":{"Temperature1":20.8},"ESP32":{"Temperature":46.1},"TempUnit":"C"}
                14:01:46.586 HTP: Hauptmenü
                14:01:49.089 HTP: Werkzeuge
                14:01:50.961 HTP: Konsole
                14:01:56.889 HTP: Werkzeuge
                14:01:58.377 HTP: Hauptmenü
                14:02:00.161 HTP: Werkzeuge
                14:02:01.057 HTP: Konsole
                14:02:07.622 CMD: FlashNextionAdv1 http://nspanel.de/nspanel-v5.0.0.tft
                14:02:07.623 SRC: WebConsole from 10.68.0.156
                14:02:07.624 CMD: Grp 0, Cmd 'FLASHNEXTIONADV', Idx 1, Len 36, Pld -99, Data 'http://nspanel.de/nspanel-v5.0.0.tft'
                14:02:07.632 MQT: SmartHome/NSPanel_1/stat/RESULT = {"FlashNextionAdv":"Done"}
                14:02:07.666 FLH: host: nspanel.de, port: 80, get: /nspanel-v5.0.0.tft
                14:02:07.811 FLH: Connected:true
                14:02:07.914 FLH: Retry 2
                14:02:08.127 FLH: HTTP Respose is 200 OK or 206 Partial Content
                14:02:08.128 FLH: Flash file size: 12197684
                14:02:08.129 SRC: Berry
                14:02:08.130 CMD: Grp 0, Cmd 'RULETIMER', Idx 3, Len 1, Pld 0, Data '0'
                14:02:08.135 MQT: SmartHome/NSPanel_1/stat/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
                14:02:08.140 SRC: Berry
                14:02:08.141 CMD: Grp 0, Cmd 'RULE', Idx 3, Len 1, Pld 0, Data '0'
                14:02:08.145 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
                14:02:08.161 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
                14:02:08.163 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
                14:02:08.165 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
                14:02:08.172 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
                14:02:08.297 FLH: Send (High Speed) flash start
                14:02:08.303 NXP: Nextion command sent = bytes('77686D692D7772692031323139373638342C3932313630302C72657330FFFFFF')
                14:02:08.326 BRY: Serial UART2
                14:02:08.679 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "0", "time_elapsed": 0}}
                14:02:08.771 FLH: Read block - Writing: 4096 - Total: 4096 - Buffer size: 1395
                14:02:09.279 FLH: Read block - Writing: 4096 - Total: 8192 - Buffer size: 1395
                14:02:09.392 FLH: Read block - Writing: 4096 - Total: 12288 - Buffer size: 1395
                14:02:09.501 FLH: Read block - Writing: 4096 - Total: 16384 - Buffer size: 1395
                14:02:09.611 FLH: Read block - Writing: 4096 - Total: 20480 - Buffer size: 1395
                14:02:09.770 FLH: Read block - Writing: 4096 - Total: 24576 - Buffer size: 1395
                14:02:09.881 FLH: Read block - Writing: 4096 - Total: 28672 - Buffer size: 1395
                14:02:10.073 FLH: Read block - Writing: 4096 - Total: 32768 - Buffer size: 1395
                14:02:10.317 FLH: Read block - Writing: 4096 - Total: 36864 - Buffer size: 1395
                14:02:10.427 FLH: Read block - Writing: 4096 - Total: 40960 - Buffer size: 1395
                14:02:10.536 FLH: Read block - Writing: 4096 - Total: 45056 - Buffer size: 1395
                14:02:10.645 FLH: Read block - Writing: 4096 - Total: 49152 - Buffer size: 1395
                14:02:10.752 FLH: Read block - Writing: 4096 - Total: 53248 - Buffer size: 1395
                14:02:10.863 FLH: Read block - Writing: 4096 - Total: 57344 - Buffer size: 1395
                14:02:11.074 FLH: Read block - Writing: 4096 - Total: 61440 - Buffer size: 1395
                14:02:11.180 FLH: Read block - Writing: 4096 - Total: 65536 - Buffer size: 1395
                14:02:11.293 FLH: Read block - Writing: 4096 - Total: 69632 - Buffer size: 1395
                14:02:11.574 FLH: Read block - Writing: 4096 - Total: 73728 - Buffer size: 1395
                14:02:11.770 FLH: Read block - Writing: 4096 - Total: 77824 - Buffer size: 1395
                14:02:11.971 FLH: Read block - Writing: 4096 - Total: 81920 - Buffer size: 1395
                14:02:12.083 FLH: Read block - Writing: 4096 - Total: 86016 - Buffer size: 1395
                14:02:12.275 FLH: Read block - Writing: 4096 - Total: 90112 - Buffer size: 1395
                14:02:12.471 FLH: Read block - Writing: 4096 - Total: 94208 - Buffer size: 1395
                14:02:12.583 FLH: Read block - Writing: 4096 - Total: 98304 - Buffer size: 1395
                14:02:12.770 FLH: Read block - Writing: 4096 - Total: 102400 - Buffer size: 1395
                14:02:12.885 FLH: Read block - Writing: 4096 - Total: 106496 - Buffer size: 1395
                14:02:13.032 FLH: Read block - Writing: 4096 - Total: 110592 - Buffer size: 1395
                14:02:13.143 FLH: Read block - Writing: 4096 - Total: 114688 - Buffer size: 1395
                14:02:13.254 FLH: Read block - Writing: 4096 - Total: 118784 - Buffer size: 1395
                14:02:13.371 FLH: Read block - Writing: 4096 - Total: 122880 - Buffer size: 1395
                14:02:13.486 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "1", "time_elapsed": 5}}
                14:02:13.578 FLH: Read block - Writing: 4096 - Total: 126976 - Buffer size: 1395
                14:02:13.771 FLH: Read block - Writing: 4096 - Total: 131072 - Buffer size: 1395
                14:02:13.971 FLH: Read block - Writing: 4096 - Total: 135168 - Buffer size: 1395
                14:02:14.170 FLH: Read block - Writing: 4096 - Total: 139264 - Buffer size: 1395
                14:02:14.283 FLH: Read block - Writing: 4096 - Total: 143360 - Buffer size: 1395
                14:02:14.470 FLH: Read block - Writing: 4096 - Total: 147456 - Buffer size: 1395
                14:02:14.670 FLH: Read block - Writing: 4096 - Total: 151552 - Buffer size: 1395
                14:02:14.870 FLH: Read block - Writing: 4096 - Total: 155648 - Buffer size: 1395
                14:02:15.074 FLH: Read block - Writing: 4096 - Total: 159744 - Buffer size: 1395
                14:02:15.275 FLH: Read block - Writing: 4096 - Total: 163840 - Buffer size: 1395
                14:02:15.471 FLH: Read block - Writing: 4096 - Total: 167936 - Buffer size: 1395
                14:02:15.620 FLH: Read block - Writing: 4096 - Total: 172032 - Buffer size: 1395
                14:02:15.770 FLH: Read block - Writing: 4096 - Total: 176128 - Buffer size: 1395
                14:02:15.882 FLH: Read block - Writing: 4096 - Total: 180224 - Buffer size: 1395
                14:02:16.074 FLH: Read block - Writing: 4096 - Total: 184320 - Buffer size: 1395
                14:02:16.276 FLH: Read block - Writing: 4096 - Total: 188416 - Buffer size: 1395
                14:02:16.470 FLH: Read block - Writing: 4096 - Total: 192512 - Buffer size: 1395
                14:02:16.671 FLH: Read block - Writing: 4096 - Total: 196608 - Buffer size: 1395
                14:02:16.869 FLH: Read block - Writing: 4096 - Total: 200704 - Buffer size: 1395
                14:02:17.074 FLH: Read block - Writing: 4096 - Total: 204800 - Buffer size: 1395
                14:02:17.276 FLH: Read block - Writing: 4096 - Total: 208896 - Buffer size: 1395
                14:02:17.387 FLH: Read block - Writing: 4096 - Total: 212992 - Buffer size: 1395
                14:02:17.574 FLH: Read block - Writing: 4096 - Total: 217088 - Buffer size: 1395
                14:02:17.771 FLH: Read block - Writing: 4096 - Total: 221184 - Buffer size: 1395
                14:02:17.883 FLH: Read block - Writing: 4096 - Total: 225280 - Buffer size: 1395
                14:02:18.029 FLH: Read block - Writing: 4096 - Total: 229376 - Buffer size: 1395
                14:02:18.177 FLH: Read block - Writing: 4096 - Total: 233472 - Buffer size: 1395
                14:02:18.370 FLH: Read block - Writing: 4096 - Total: 237568 - Buffer size: 1395
                14:02:18.573 FLH: Read block - Writing: 4096 - Total: 241664 - Buffer size: 1395
                14:02:18.771 FLH: Read block - Writing: 4096 - Total: 245760 - Buffer size: 1395
                14:02:18.795 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "2", "time_elapsed": 10}}
                14:02:18.888 FLH: Read block - Writing: 4096 - Total: 249856 - Buffer size: 1395
                14:02:19.073 FLH: Read block - Writing: 4096 - Total: 253952 - Buffer size: 1395
                14:02:19.277 FLH: Read block - Writing: 4096 - Total: 258048 - Buffer size: 1395
                14:02:19.388 FLH: Read block - Writing: 4096 - Total: 262144 - Buffer size: 1395
                14:02:19.574 FLH: Read block - Writing: 4096 - Total: 266240 - Buffer size: 1395
                14:02:19.771 FLH: Read block - Writing: 4096 - Total: 270336 - Buffer size: 1395
                14:02:19.881 FLH: Read block - Writing: 4096 - Total: 274432 - Buffer size: 1395
                14:02:20.074 FLH: Read block - Writing: 4096 - Total: 278528 - Buffer size: 1395
                14:02:20.276 FLH: Read block - Writing: 4096 - Total: 282624 - Buffer size: 1395
                14:02:20.386 FLH: Read block - Writing: 4096 - Total: 286720 - Buffer size: 1395
                14:02:20.592 FLH: Read block - Writing: 4096 - Total: 290816 - Buffer size: 1395
                14:02:20.771 FLH: Read block - Writing: 4096 - Total: 294912 - Buffer size: 1395
                14:02:20.881 FLH: Read block - Writing: 4096 - Total: 299008 - Buffer size: 1395
                14:02:21.074 FLH: Read block - Writing: 4096 - Total: 303104 - Buffer size: 1395
                14:02:21.277 FLH: Read block - Writing: 4096 - Total: 307200 - Buffer size: 1395
                14:02:21.386 FLH: Read block - Writing: 4096 - Total: 311296 - Buffer size: 1395
                14:02:21.574 FLH: Read block - Writing: 4096 - Total: 315392 - Buffer size: 1395
                14:02:21.772 FLH: Read block - Writing: 4096 - Total: 319488 - Buffer size: 1395
                14:02:21.882 FLH: Read block - Writing: 4096 - Total: 323584 - Buffer size: 1395
                14:02:22.074 FLH: Read block - Writing: 4096 - Total: 327680 - Buffer size: 1395
                14:02:22.277 FLH: Read block - Writing: 4096 - Total: 331776 - Buffer size: 1395
                14:02:22.470 FLH: Read block - Writing: 4096 - Total: 335872 - Buffer size: 1395
                14:02:22.670 FLH: Read block - Writing: 4096 - Total: 339968 - Buffer size: 1395
                14:02:22.871 FLH: Read block - Writing: 4096 - Total: 344064 - Buffer size: 1395
                14:02:23.073 FLH: Read block - Writing: 4096 - Total: 348160 - Buffer size: 1395
                14:02:23.218 FLH: Read block - Writing: 4096 - Total: 352256 - Buffer size: 1395
                14:02:23.334 FLH: Read block - Writing: 4096 - Total: 356352 - Buffer size: 1395
                14:02:23.469 FLH: Read block - Writing: 4096 - Total: 360448 - Buffer size: 1395
                14:02:23.670 FLH: Read block - Writing: 4096 - Total: 364544 - Buffer size: 1395
                14:02:23.870 FLH: Read block - Writing: 4096 - Total: 368640 - Buffer size: 1395
                14:02:23.986 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "3", "time_elapsed": 15}}
                14:02:24.078 FLH: Read block - Writing: 4096 - Total: 372736 - Buffer size: 1395
                14:02:24.276 FLH: Read block - Writing: 4096 - Total: 376832 - Buffer size: 1395
                14:02:24.388 FLH: Read block - Writing: 4096 - Total: 380928 - Buffer size: 1395
                14:02:24.573 FLH: Read block - Writing: 4096 - Total: 385024 - Buffer size: 1395
                14:02:24.770 FLH: Read block - Writing: 4096 - Total: 389120 - Buffer size: 1395
                14:02:24.970 FLH: Read block - Writing: 4096 - Total: 393216 - Buffer size: 1395
                14:02:25.082 FLH: Read block - Writing: 4096 - Total: 397312 - Buffer size: 1395
                14:02:25.372 FLH: Read block - Writing: 4096 - Total: 401408 - Buffer size: 1395
                14:02:25.574 FLH: Read block - Writing: 4096 - Total: 405504 - Buffer size: 1395
                14:02:25.769 FLH: Read block - Writing: 4096 - Total: 409600 - Buffer size: 1395
                14:02:25.971 FLH: Read block - Writing: 4096 - Total: 413696 - Buffer size: 1395
                14:02:26.085 FLH: Read block - Writing: 4096 - Total: 417792 - Buffer size: 1395
                14:02:26.275 FLH: Read block - Writing: 4096 - Total: 421888 - Buffer size: 1395
                14:02:26.471 FLH: Read block - Writing: 4096 - Total: 425984 - Buffer size: 1395
                14:02:26.671 FLH: Read block - Writing: 4096 - Total: 430080 - Buffer size: 1395
                14:02:26.870 FLH: Read block - Writing: 4096 - Total: 434176 - Buffer size: 1395
                14:02:27.074 FLH: Read block - Writing: 4096 - Total: 438272 - Buffer size: 1395
                14:02:27.276 FLH: Read block - Writing: 4096 - Total: 442368 - Buffer size: 1395
                14:02:27.387 FLH: Read block - Writing: 4096 - Total: 446464 - Buffer size: 1395
                14:02:27.573 FLH: Read block - Writing: 4096 - Total: 450560 - Buffer size: 1395
                14:02:27.771 FLH: Read block - Writing: 4096 - Total: 454656 - Buffer size: 1395
                14:02:27.881 FLH: Read block - Writing: 4096 - Total: 458752 - Buffer size: 1395
                14:02:28.074 FLH: Read block - Writing: 4096 - Total: 462848 - Buffer size: 1395
                14:02:28.277 FLH: Read block - Writing: 4096 - Total: 466944 - Buffer size: 1395
                14:02:28.427 FLH: Read block - Writing: 4096 - Total: 471040 - Buffer size: 1395
                14:02:28.576 FLH: Read block - Writing: 4096 - Total: 475136 - Buffer size: 1395
                14:02:28.770 FLH: Read block - Writing: 4096 - Total: 479232 - Buffer size: 1395
                14:02:28.881 FLH: Read block - Writing: 4096 - Total: 483328 - Buffer size: 1395
                14:02:29.074 FLH: Read block - Writing: 4096 - Total: 487424 - Buffer size: 1395
                14:02:29.277 FLH: Read block - Writing: 4096 - Total: 491520 - Buffer size: 1395
                14:02:29.300 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "4", "time_elapsed": 20}}
                14:02:29.393 FLH: Read block - Writing: 4096 - Total: 495616 - Buffer size: 1395
                14:02:29.574 FLH: Read block - Writing: 4096 - Total: 499712 - Buffer size: 1395
                14:02:29.770 FLH: Read block - Writing: 4096 - Total: 503808 - Buffer size: 1395
                14:02:29.881 FLH: Read block - Writing: 4096 - Total: 507904 - Buffer size: 1395
                14:02:30.073 FLH: Read block - Writing: 4096 - Total: 512000 - Buffer size: 1395
                14:02:30.277 FLH: Read block - Writing: 4096 - Total: 516096 - Buffer size: 1395
                14:02:30.387 FLH: Read block - Writing: 4096 - Total: 520192 - Buffer size: 1395
                14:02:30.574 FLH: Read block - Writing: 4096 - Total: 524288 - Buffer size: 1395
                14:02:30.771 FLH: Read block - Writing: 4096 - Total: 528384 - Buffer size: 1395
                14:02:30.984 FLH: Read block - Writing: 4096 - Total: 532480 - Buffer size: 1395
                14:02:31.171 FLH: Read block - Writing: 4096 - Total: 536576 - Buffer size: 1395
                14:02:31.288 FLH: Read block - Writing: 4096 - Total: 540672 - Buffer size: 1395
                14:02:31.398 FLH: Read block - Writing: 4096 - Total: 544768 - Buffer size: 1395
                14:02:31.573 FLH: Read block - Writing: 4096 - Total: 548864 - Buffer size: 1395
                14:02:31.771 FLH: Read block - Writing: 4096 - Total: 552960 - Buffer size: 1395
                14:02:31.881 FLH: Read block - Writing: 4096 - Total: 557056 - Buffer size: 1395
                14:02:32.073 FLH: Read block - Writing: 4096 - Total: 561152 - Buffer size: 1395
                14:02:32.277 FLH: Read block - Writing: 4096 - Total: 565248 - Buffer size: 1395
                14:02:32.388 FLH: Read block - Writing: 4096 - Total: 569344 - Buffer size: 1395
                14:02:32.574 FLH: Read block - Writing: 4096 - Total: 573440 - Buffer size: 1395
                14:02:32.771 FLH: Read block - Writing: 4096 - Total: 577536 - Buffer size: 1395
                14:02:32.881 FLH: Read block - Writing: 4096 - Total: 581632 - Buffer size: 1395
                14:02:33.074 FLH: Read block - Writing: 4096 - Total: 585728 - Buffer size: 1395
                14:02:33.276 FLH: Read block - Writing: 4096 - Total: 589824 - Buffer size: 1395
                14:02:33.427 FLH: Read block - Writing: 4096 - Total: 593920 - Buffer size: 1395
                14:02:33.671 FLH: Read block - Writing: 4096 - Total: 598016 - Buffer size: 1395
                14:02:33.871 FLH: Read block - Writing: 4096 - Total: 602112 - Buffer size: 1395
                14:02:34.073 FLH: Read block - Writing: 4096 - Total: 606208 - Buffer size: 1395
                14:02:34.276 FLH: Read block - Writing: 4096 - Total: 610304 - Buffer size: 1395
                14:02:34.301 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "5", "time_elapsed": 25}}
                14:02:34.394 FLH: Read block - Writing: 4096 - Total: 614400 - Buffer size: 1395
                14:02:34.573 FLH: Read block - Writing: 4096 - Total: 618496 - Buffer size: 1395
                14:02:34.770 FLH: Read block - Writing: 4096 - Total: 622592 - Buffer size: 1395
                14:02:34.971 FLH: Read block - Writing: 4096 - Total: 626688 - Buffer size: 1395
                14:02:35.082 FLH: Read block - Writing: 4096 - Total: 630784 - Buffer size: 1395
                14:02:35.277 FLH: Read block - Writing: 4096 - Total: 634880 - Buffer size: 1395
                14:02:35.390 FLH: Read block - Writing: 4096 - Total: 638976 - Buffer size: 1395
                14:02:35.573 FLH: Read block - Writing: 4096 - Total: 643072 - Buffer size: 1395
                14:02:35.770 FLH: Read block - Writing: 4096 - Total: 647168 - Buffer size: 1395
                14:02:35.988 FLH: Read block - Writing: 4096 - Total: 651264 - Buffer size: 1395
                14:02:36.101 FLH: Read block - Writing: 4096 - Total: 655360 - Buffer size: 1395
                14:02:36.276 FLH: Read block - Writing: 4096 - Total: 659456 - Buffer size: 1395
                14:02:36.471 FLH: Read block - Writing: 4096 - Total: 663552 - Buffer size: 1395
                14:02:36.580 FLH: Read block - Writing: 4096 - Total: 667648 - Buffer size: 1395
                14:02:36.770 FLH: Read block - Writing: 4096 - Total: 671744 - Buffer size: 1395
                14:02:36.970 FLH: Read block - Writing: 4096 - Total: 675840 - Buffer size: 1395
                14:02:37.081 FLH: Read block - Writing: 4096 - Total: 679936 - Buffer size: 1395
                14:02:37.277 FLH: Read block - Writing: 4096 - Total: 684032 - Buffer size: 1395
                14:02:37.388 FLH: Read block - Writing: 4096 - Total: 688128 - Buffer size: 1395
                14:02:37.573 FLH: Read block - Writing: 4096 - Total: 692224 - Buffer size: 1395
                14:02:37.771 FLH: Read block - Writing: 4096 - Total: 696320 - Buffer size: 1395
                14:02:37.970 FLH: Read block - Writing: 4096 - Total: 700416 - Buffer size: 1395
                14:02:38.081 FLH: Read block - Writing: 4096 - Total: 704512 - Buffer size: 1395
                14:02:38.276 FLH: Read block - Writing: 4096 - Total: 708608 - Buffer size: 1395
                14:02:38.471 FLH: Read block - Writing: 4096 - Total: 712704 - Buffer size: 1395
                14:02:38.619 FLH: Read block - Writing: 4096 - Total: 716800 - Buffer size: 1395
                14:02:38.770 FLH: Read block - Writing: 4096 - Total: 720896 - Buffer size: 1395
                14:02:38.970 FLH: Read block - Writing: 4096 - Total: 724992 - Buffer size: 1395
                14:02:39.169 FLH: Read block - Writing: 4096 - Total: 729088 - Buffer size: 1395
                14:02:39.283 FLH: Read block - Writing: 4096 - Total: 733184 - Buffer size: 1395
                14:02:39.385 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "6", "time_elapsed": 31}}
                14:02:39.477 FLH: Read block - Writing: 4096 - Total: 737280 - Buffer size: 1395
                14:02:39.670 FLH: Read block - Writing: 4096 - Total: 741376 - Buffer size: 1395
                14:02:39.871 FLH: Read block - Writing: 4096 - Total: 745472 - Buffer size: 1395
                14:02:40.074 FLH: Read block - Writing: 4096 - Total: 749568 - Buffer size: 1395
                14:02:40.275 FLH: Read block - Writing: 4096 - Total: 753664 - Buffer size: 1395
                14:02:40.470 FLH: Read block - Writing: 4096 - Total: 757760 - Buffer size: 1395
                14:02:40.671 FLH: Read block - Writing: 4096 - Total: 761856 - Buffer size: 1395
                14:02:40.870 FLH: Read block - Writing: 4096 - Total: 765952 - Buffer size: 1395
                14:02:41.074 FLH: Read block - Writing: 4096 - Total: 770048 - Buffer size: 1395
                14:02:41.221 FLH: Read block - Writing: 4096 - Total: 774144 - Buffer size: 1395
                14:02:41.335 FLH: Read block - Writing: 4096 - Total: 778240 - Buffer size: 1395
                14:02:41.469 FLH: Read block - Writing: 4096 - Total: 782336 - Buffer size: 1395
                14:02:41.671 FLH: Read block - Writing: 4096 - Total: 786432 - Buffer size: 1395
                14:02:41.870 FLH: Read block - Writing: 4096 - Total: 790528 - Buffer size: 1395
                14:02:42.074 FLH: Read block - Writing: 4096 - Total: 794624 - Buffer size: 1395
                14:02:42.277 FLH: Read block - Writing: 4096 - Total: 798720 - Buffer size: 1395
                14:02:42.387 FLH: Read block - Writing: 4096 - Total: 802816 - Buffer size: 1395
                14:02:42.574 FLH: Read block - Writing: 4096 - Total: 806912 - Buffer size: 1395
                14:02:42.770 FLH: Read block - Writing: 4096 - Total: 811008 - Buffer size: 1395
                14:02:42.883 FLH: Read block - Writing: 4096 - Total: 815104 - Buffer size: 1395
                14:02:43.074 FLH: Read block - Writing: 4096 - Total: 819200 - Buffer size: 1395
                14:02:43.277 FLH: Read block - Writing: 4096 - Total: 823296 - Buffer size: 1395
                14:02:43.387 FLH: Read block - Writing: 4096 - Total: 827392 - Buffer size: 1395
                14:02:43.574 FLH: Read block - Writing: 4096 - Total: 831488 - Buffer size: 1395
                14:02:43.720 FLH: Read block - Writing: 4096 - Total: 835584 - Buffer size: 1395
                14:02:43.830 FLH: Read block - Writing: 4096 - Total: 839680 - Buffer size: 1395
                14:02:43.971 FLH: Read block - Writing: 4096 - Total: 843776 - Buffer size: 1395
                14:02:44.084 FLH: Read block - Writing: 4096 - Total: 847872 - Buffer size: 1395
                14:02:44.277 FLH: Read block - Writing: 4096 - Total: 851968 - Buffer size: 1395
                14:02:44.390 FLH: Read block - Writing: 4096 - Total: 856064 - Buffer size: 1395
                14:02:44.584 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "7", "time_elapsed": 36}}
                14:02:44.676 FLH: Read block - Writing: 4096 - Total: 860160 - Buffer size: 1395
                14:02:44.868 FLH: Read block - Writing: 4096 - Total: 864256 - Buffer size: 1395
                14:02:45.070 FLH: Read block - Writing: 4096 - Total: 868352 - Buffer size: 1395
                14:02:45.278 FLH: Read block - Writing: 4096 - Total: 872448 - Buffer size: 1395
                14:02:45.388 FLH: Read block - Writing: 4096 - Total: 876544 - Buffer size: 1395
                14:02:45.574 FLH: Read block - Writing: 4096 - Total: 880640 - Buffer size: 1395
                14:02:45.770 FLH: Read block - Writing: 4096 - Total: 884736 - Buffer size: 1395
                14:02:45.881 FLH: Read block - Writing: 4096 - Total: 888832 - Buffer size: 1395
                14:02:46.069 FLH: Read block - Writing: 4096 - Total: 892928 - Buffer size: 1395
                14:02:46.282 FLH: Read block - Writing: 4096 - Total: 897024 - Buffer size: 1395
                14:02:46.392 FLH: Read block - Writing: 4096 - Total: 901120 - Buffer size: 1395
                14:02:46.573 FLH: Read block - Writing: 4096 - Total: 905216 - Buffer size: 1395
                14:02:46.772 FLH: Read block - Writing: 4096 - Total: 909312 - Buffer size: 1395
                14:02:46.971 FLH: Read block - Writing: 4096 - Total: 913408 - Buffer size: 1395
                14:02:47.084 FLH: Read block - Writing: 4096 - Total: 917504 - Buffer size: 1395
                14:02:47.277 FLH: Read block - Writing: 4096 - Total: 921600 - Buffer size: 1395
                14:02:47.468 FLH: Read block - Writing: 4096 - Total: 925696 - Buffer size: 1395
                14:02:47.672 FLH: Read block - Writing: 4096 - Total: 929792 - Buffer size: 1395
                14:02:47.870 FLH: Read block - Writing: 4096 - Total: 933888 - Buffer size: 1395
                14:02:48.069 FLH: Read block - Writing: 4096 - Total: 937984 - Buffer size: 1395
                14:02:48.275 FLH: Read block - Writing: 4096 - Total: 942080 - Buffer size: 1395
                14:02:48.472 FLH: Read block - Writing: 4096 - Total: 946176 - Buffer size: 1395
                14:02:48.582 FLH: Read block - Writing: 4096 - Total: 950272 - Buffer size: 1395
                14:02:48.769 FLH: Read block - Writing: 4096 - Total: 954368 - Buffer size: 1395
                14:02:48.919 FLH: Read block - Writing: 4096 - Total: 958464 - Buffer size: 1395
                14:02:49.072 FLH: Read block - Writing: 4096 - Total: 962560 - Buffer size: 1395
                14:02:49.277 FLH: Read block - Writing: 4096 - Total: 966656 - Buffer size: 1395
                14:02:49.471 FLH: Read block - Writing: 4096 - Total: 970752 - Buffer size: 1395
                14:02:49.582 FLH: Read block - Writing: 4096 - Total: 974848 - Buffer size: 1395
                14:02:49.769 FLH: Read block - Writing: 4096 - Total: 978944 - Buffer size: 1395
                14:02:49.884 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "8", "time_elapsed": 41}}
                14:02:49.975 FLH: Read block - Writing: 4096 - Total: 983040 - Buffer size: 1395
                14:02:50.170 FLH: Read block - Writing: 4096 - Total: 987136 - Buffer size: 1395
                14:02:50.372 FLH: Read block - Writing: 4096 - Total: 991232 - Buffer size: 1395
                14:02:50.574 FLH: Read block - Writing: 4096 - Total: 995328 - Buffer size: 1395
                14:02:50.770 FLH: Read block - Writing: 4096 - Total: 999424 - Buffer size: 1395
                14:02:50.881 FLH: Read block - Writing: 4096 - Total: 1003520 - Buffer size: 1395
                14:02:51.074 FLH: Read block - Writing: 4096 - Total: 1007616 - Buffer size: 1395
                14:02:51.275 FLH: Read block - Writing: 4096 - Total: 1011712 - Buffer size: 1395
                14:02:51.389 FLH: Read block - Writing: 4096 - Total: 1015808 - Buffer size: 1395
                14:02:51.535 FLH: Read block - Writing: 4096 - Total: 1019904 - Buffer size: 1395
                14:02:51.646 FLH: Read block - Writing: 4096 - Total: 1024000 - Buffer size: 1395
                14:02:51.770 FLH: Read block - Writing: 4096 - Total: 1028096 - Buffer size: 1395
                14:02:51.970 FLH: Read block - Writing: 4096 - Total: 1032192 - Buffer size: 1395
                14:02:52.081 FLH: Read block - Writing: 4096 - Total: 1036288 - Buffer size: 1395
                14:02:52.276 FLH: Read block - Writing: 4096 - Total: 1040384 - Buffer size: 1395
                14:02:52.389 FLH: Read block - Writing: 4096 - Total: 1044480 - Buffer size: 1395
                14:02:52.574 FLH: Read block - Writing: 4096 - Total: 1048576 - Buffer size: 1395
                14:02:52.771 FLH: Read block - Writing: 4096 - Total: 1052672 - Buffer size: 1395
                14:02:52.971 FLH: Read block - Writing: 4096 - Total: 1056768 - Buffer size: 1395
                14:02:53.083 FLH: Read block - Writing: 4096 - Total: 1060864 - Buffer size: 1395
                14:02:53.277 FLH: Read block - Writing: 4096 - Total: 1064960 - Buffer size: 1395
                14:02:53.390 FLH: Read block - Writing: 4096 - Total: 1069056 - Buffer size: 1395
                14:02:53.573 FLH: Read block - Writing: 4096 - Total: 1073152 - Buffer size: 1395
                14:02:53.771 FLH: Read block - Writing: 4096 - Total: 1077248 - Buffer size: 1395
                14:02:53.970 FLH: Read block - Writing: 4096 - Total: 1081344 - Buffer size: 1395
                14:02:54.081 FLH: Read block - Writing: 4096 - Total: 1085440 - Buffer size: 1395
                14:02:54.276 FLH: Read block - Writing: 4096 - Total: 1089536 - Buffer size: 1395
                14:02:54.471 FLH: Read block - Writing: 4096 - Total: 1093632 - Buffer size: 1395
                14:02:54.580 FLH: Read block - Writing: 4096 - Total: 1097728 - Buffer size: 1395
                14:02:54.770 FLH: Read block - Writing: 4096 - Total: 1101824 - Buffer size: 1395
                14:02:54.884 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "9", "time_elapsed": 46}}
                14:02:54.977 FLH: Read block - Writing: 4096 - Total: 1105920 - Buffer size: 1395
                14:02:55.170 FLH: Read block - Writing: 4096 - Total: 1110016 - Buffer size: 1395
                14:02:55.281 FLH: Read block - Writing: 4096 - Total: 1114112 - Buffer size: 1395
                14:02:55.394 FLH: Read block - Writing: 4096 - Total: 1118208 - Buffer size: 1395
                14:02:55.670 FLH: Read block - Writing: 4096 - Total: 1122304 - Buffer size: 1395
                14:02:55.871 FLH: Read block - Writing: 4096 - Total: 1126400 - Buffer size: 1395
                14:02:56.074 FLH: Read block - Writing: 4096 - Total: 1130496 - Buffer size: 1395
                14:02:56.275 FLH: Read block - Writing: 4096 - Total: 1134592 - Buffer size: 1395
                14:02:56.387 FLH: Read block - Writing: 4096 - Total: 1138688 - Buffer size: 1395
                14:02:56.533 FLH: Read block - Writing: 4096 - Total: 1142784 - Buffer size: 1395
                14:02:56.670 FLH: Read block - Writing: 4096 - Total: 1146880 - Buffer size: 1395
                14:02:56.872 FLH: Read block - Writing: 4096 - Total: 1150976 - Buffer size: 1395
                14:02:57.075 FLH: Read block - Writing: 4096 - Total: 1155072 - Buffer size: 1395
                14:02:57.276 FLH: Read block - Writing: 4096 - Total: 1159168 - Buffer size: 1395
                14:02:57.388 FLH: Read block - Writing: 4096 - Total: 1163264 - Buffer size: 1395
                14:02:57.574 FLH: Read block - Writing: 4096 - Total: 1167360 - Buffer size: 1395
                14:02:57.769 FLH: Read block - Writing: 4096 - Total: 1171456 - Buffer size: 1395
                14:02:57.881 FLH: Read block - Writing: 4096 - Total: 1175552 - Buffer size: 1395
                14:02:58.074 FLH: Read block - Writing: 4096 - Total: 1179648 - Buffer size: 1395
                14:02:58.275 FLH: Read block - Writing: 4096 - Total: 1183744 - Buffer size: 1395
                14:02:58.471 FLH: Read block - Writing: 4096 - Total: 1187840 - Buffer size: 1395
                14:02:58.671 FLH: Read block - Writing: 4096 - Total: 1191936 - Buffer size: 1395
                14:02:58.870 FLH: Read block - Writing: 4096 - Total: 1196032 - Buffer size: 1395
                14:02:59.098 FLH: Read block - Writing: 4096 - Total: 1200128 - Buffer size: 1395
                14:02:59.276 FLH: Read block - Writing: 4096 - Total: 1204224 - Buffer size: 1395
                14:02:59.387 FLH: Read block - Writing: 4096 - Total: 1208320 - Buffer size: 1395
                14:02:59.573 FLH: Read block - Writing: 4096 - Total: 1212416 - Buffer size: 1395
                14:02:59.771 FLH: Read block - Writing: 4096 - Total: 1216512 - Buffer size: 1395
                14:02:59.881 FLH: Read block - Writing: 4096 - Total: 1220608 - Buffer size: 1395
                14:02:59.987 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "10", "time_elapsed": 51}}
                14:03:00.080 FLH: Read block - Writing: 4096 - Total: 1224704 - Buffer size: 1395
                14:03:00.276 FLH: Read block - Writing: 4096 - Total: 1228800 - Buffer size: 1395
                14:03:00.386 FLH: Read block - Writing: 4096 - Total: 1232896 - Buffer size: 1395
                14:03:00.574 FLH: Read block - Writing: 4096 - Total: 1236992 - Buffer size: 1395
                14:03:00.771 FLH: Read block - Writing: 4096 - Total: 1241088 - Buffer size: 1395
                14:03:00.881 FLH: Read block - Writing: 4096 - Total: 1245184 - Buffer size: 1395
                14:03:01.074 FLH: Read block - Writing: 4096 - Total: 1249280 - Buffer size: 1395
                14:03:01.277 FLH: Read block - Writing: 4096 - Total: 1253376 - Buffer size: 1395
                14:03:01.388 FLH: Read block - Writing: 4096 - Total: 1257472 - Buffer size: 1395
                14:03:01.574 FLH: Read block - Writing: 4096 - Total: 1261568 - Buffer size: 1395
                14:03:01.723 FLH: Read block - Writing: 4096 - Total: 1265664 - Buffer size: 1395
                14:03:01.833 FLH: Read block - Writing: 4096 - Total: 1269760 - Buffer size: 1395
                14:03:01.970 FLH: Read block - Writing: 4096 - Total: 1273856 - Buffer size: 1395
                14:03:02.082 FLH: Read block - Writing: 4096 - Total: 1277952 - Buffer size: 1395
                14:03:02.275 FLH: Read block - Writing: 4096 - Total: 1282048 - Buffer size: 1395
                14:03:02.471 FLH: Read block - Writing: 4096 - Total: 1286144 - Buffer size: 1395
                14:03:02.671 FLH: Read block - Writing: 4096 - Total: 1290240 - Buffer size: 1395
                14:03:02.870 FLH: Read block - Writing: 4096 - Total: 1294336 - Buffer size: 1395
                14:03:03.073 FLH: Read block - Writing: 4096 - Total: 1298432 - Buffer size: 1395
                14:03:03.277 FLH: Read block - Writing: 4096 - Total: 1302528 - Buffer size: 1395
                14:03:03.387 FLH: Read block - Writing: 4096 - Total: 1306624 - Buffer size: 1395
                14:03:03.573 FLH: Read block - Writing: 4096 - Total: 1310720 - Buffer size: 1395
                14:03:03.771 FLH: Read block - Writing: 4096 - Total: 1314816 - Buffer size: 1395
                14:03:03.970 FLH: Read block - Writing: 4096 - Total: 1318912 - Buffer size: 1395
                14:03:04.171 FLH: Read block - Writing: 4096 - Total: 1323008 - Buffer size: 1395
                14:03:04.323 FLH: Read block - Writing: 4096 - Total: 1327104 - Buffer size: 1395
                14:03:04.434 FLH: Read block - Writing: 4096 - Total: 1331200 - Buffer size: 1395
                14:03:04.574 FLH: Read block - Writing: 4096 - Total: 1335296 - Buffer size: 1395
                14:03:04.770 FLH: Read block - Writing: 4096 - Total: 1339392 - Buffer size: 1395
                14:03:04.883 FLH: Read block - Writing: 4096 - Total: 1343488 - Buffer size: 1395
                14:03:04.987 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "11", "time_elapsed": 56}}
                14:03:05.080 FLH: Read block - Writing: 4096 - Total: 1347584 - Buffer size: 1395
                14:03:05.277 FLH: Read block - Writing: 4096 - Total: 1351680 - Buffer size: 1395
                14:03:05.387 FLH: Read block - Writing: 4096 - Total: 1355776 - Buffer size: 1395
                14:03:05.574 FLH: Read block - Writing: 4096 - Total: 1359872 - Buffer size: 1395
                14:03:05.770 FLH: Read block - Writing: 4096 - Total: 1363968 - Buffer size: 1395
                14:03:05.883 FLH: Read block - Writing: 4096 - Total: 1368064 - Buffer size: 1395
                14:03:06.074 FLH: Read block - Writing: 4096 - Total: 1372160 - Buffer size: 1395
                14:03:06.277 FLH: Read block - Writing: 4096 - Total: 1376256 - Buffer size: 1395
                14:03:06.389 FLH: Read block - Writing: 4096 - Total: 1380352 - Buffer size: 1395
                14:03:06.671 FLH: Read block - Writing: 4096 - Total: 1384448 - Buffer size: 1395
                14:03:06.881 FLH: Read block - Writing: 4096 - Total: 1388544 - Buffer size: 1395
                14:03:07.073 FLH: Read block - Writing: 4096 - Total: 1392640 - Buffer size: 1395
                14:03:07.276 FLH: Read block - Writing: 4096 - Total: 1396736 - Buffer size: 1395
                14:03:07.471 FLH: Read block - Writing: 4096 - Total: 1400832 - Buffer size: 1395
                14:03:07.670 FLH: Read block - Writing: 4096 - Total: 1404928 - Buffer size: 1395
                14:03:07.870 FLH: Read block - Writing: 4096 - Total: 1409024 - Buffer size: 1395
                14:03:08.074 FLH: Read block - Writing: 4096 - Total: 1413120 - Buffer size: 1395
                14:03:08.275 FLH: Read block - Writing: 4096 - Total: 1417216 - Buffer size: 1395
                14:03:08.386 FLH: Read block - Writing: 4096 - Total: 1421312 - Buffer size: 1395
                14:03:08.574 FLH: Read block - Writing: 4096 - Total: 1425408 - Buffer size: 1395
                14:03:08.770 FLH: Read block - Writing: 4096 - Total: 1429504 - Buffer size: 1395
                14:03:08.971 FLH: Read block - Writing: 4096 - Total: 1433600 - Buffer size: 1395
                14:03:09.083 FLH: Read block - Writing: 4096 - Total: 1437696 - Buffer size: 1395
                14:03:09.275 FLH: Read block - Writing: 4096 - Total: 1441792 - Buffer size: 1395
                14:03:09.390 FLH: Read block - Writing: 4096 - Total: 1445888 - Buffer size: 1395
                14:03:09.670 FLH: Read block - Writing: 4096 - Total: 1449984 - Buffer size: 1395
                14:03:09.870 FLH: Read block - Writing: 4096 - Total: 1454080 - Buffer size: 1395
                14:03:10.074 FLH: Read block - Writing: 4096 - Total: 1458176 - Buffer size: 1395
                14:03:10.277 FLH: Read block - Writing: 4096 - Total: 1462272 - Buffer size: 1395
                14:03:10.388 FLH: Read block - Writing: 4096 - Total: 1466368 - Buffer size: 1395
                14:03:10.488 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "12", "time_elapsed": 62}}
                14:03:10.581 FLH: Read block - Writing: 4096 - Total: 1470464 - Buffer size: 1395
                14:03:10.770 FLH: Read block - Writing: 4096 - Total: 1474560 - Buffer size: 1395
                14:03:10.881 FLH: Read block - Writing: 4096 - Total: 1478656 - Buffer size: 1395
                14:03:11.074 FLH: Read block - Writing: 4096 - Total: 1482752 - Buffer size: 1395
                14:03:11.277 FLH: Read block - Writing: 4096 - Total: 1486848 - Buffer size: 1395
                14:03:11.387 FLH: Read block - Writing: 4096 - Total: 1490944 - Buffer size: 1395
                14:03:11.574 FLH: Read block - Writing: 4096 - Total: 1495040 - Buffer size: 1395
                14:03:11.771 FLH: Read block - Writing: 4096 - Total: 1499136 - Buffer size: 1395
                14:03:11.880 FLH: Read block - Writing: 4096 - Total: 1503232 - Buffer size: 1395
                14:03:12.099 FLH: Read block - Writing: 4096 - Total: 1507328 - Buffer size: 1395
                14:03:12.277 FLH: Read block - Writing: 4096 - Total: 1511424 - Buffer size: 1395
                14:03:12.470 FLH: Read block - Writing: 4096 - Total: 1515520 - Buffer size: 1395
                14:03:12.670 FLH: Read block - Writing: 4096 - Total: 1519616 - Buffer size: 1395
                14:03:12.871 FLH: Read block - Writing: 4096 - Total: 1523712 - Buffer size: 1395
                14:03:13.073 FLH: Read block - Writing: 4096 - Total: 1527808 - Buffer size: 1395
                14:03:13.276 FLH: Read block - Writing: 4096 - Total: 1531904 - Buffer size: 1395
                14:03:13.471 FLH: Read block - Writing: 4096 - Total: 1536000 - Buffer size: 1395
                14:03:13.580 FLH: Read block - Writing: 4096 - Total: 1540096 - Buffer size: 1395
                14:03:13.770 FLH: Read block - Writing: 4096 - Total: 1544192 - Buffer size: 1395
                14:03:13.882 FLH: Read block - Writing: 4096 - Total: 1548288 - Buffer size: 1395
                14:03:14.073 FLH: Read block - Writing: 4096 - Total: 1552384 - Buffer size: 1395
                14:03:14.277 FLH: Read block - Writing: 4096 - Total: 1556480 - Buffer size: 1395
                14:03:14.502 FLH: Read block - Writing: 4096 - Total: 1560576 - Buffer size: 1395
                14:03:14.670 FLH: Read block - Writing: 4096 - Total: 1564672 - Buffer size: 1395
                14:03:14.871 FLH: Read block - Writing: 4096 - Total: 1568768 - Buffer size: 1395
                14:03:15.074 FLH: Read block - Writing: 4096 - Total: 1572864 - Buffer size: 1395
                14:03:15.276 FLH: Read block - Writing: 4096 - Total: 1576960 - Buffer size: 1395
                14:03:15.471 FLH: Read block - Writing: 4096 - Total: 1581056 - Buffer size: 1395
                14:03:15.671 FLH: Read block - Writing: 4096 - Total: 1585152 - Buffer size: 1395
                14:03:15.869 FLH: Read block - Writing: 4096 - Total: 1589248 - Buffer size: 1395
                14:03:15.987 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "13", "time_elapsed": 67}}
                14:03:16.080 FLH: Read block - Writing: 4096 - Total: 1593344 - Buffer size: 1395
                14:03:16.277 FLH: Read block - Writing: 4096 - Total: 1597440 - Buffer size: 1395
                14:03:16.387 FLH: Read block - Writing: 4096 - Total: 1601536 - Buffer size: 1395
                14:03:16.574 FLH: Read block - Writing: 4096 - Total: 1605632 - Buffer size: 1395
                14:03:16.771 FLH: Read block - Writing: 4096 - Total: 1609728 - Buffer size: 1395
                14:03:16.880 FLH: Read block - Writing: 4096 - Total: 1613824 - Buffer size: 1395
                14:03:17.073 FLH: Read block - Writing: 4096 - Total: 1617920 - Buffer size: 1395
                14:03:17.277 FLH: Read block - Writing: 4096 - Total: 1622016 - Buffer size: 1395
                14:03:17.387 FLH: Read block - Writing: 4096 - Total: 1626112 - Buffer size: 1395
                14:03:17.574 FLH: Read block - Writing: 4096 - Total: 1630208 - Buffer size: 1395
                14:03:17.771 FLH: Read block - Writing: 4096 - Total: 1634304 - Buffer size: 1395
                14:03:17.881 FLH: Read block - Writing: 4096 - Total: 1638400 - Buffer size: 1395
                14:03:18.073 FLH: Read block - Writing: 4096 - Total: 1642496 - Buffer size: 1395
                14:03:18.276 FLH: Read block - Writing: 4096 - Total: 1646592 - Buffer size: 1395
                14:03:18.387 FLH: Read block - Writing: 4096 - Total: 1650688 - Buffer size: 1395
                14:03:18.574 FLH: Read block - Writing: 4096 - Total: 1654784 - Buffer size: 1395
                14:03:18.771 FLH: Read block - Writing: 4096 - Total: 1658880 - Buffer size: 1395
                14:03:18.882 FLH: Read block - Writing: 4096 - Total: 1662976 - Buffer size: 1395
                14:03:19.075 FLH: Read block - Writing: 4096 - Total: 1667072 - Buffer size: 1395
                14:03:19.276 FLH: Read block - Writing: 4096 - Total: 1671168 - Buffer size: 1395
                14:03:19.388 FLH: Read block - Writing: 4096 - Total: 1675264 - Buffer size: 1395
                14:04:02.771 FLH: Read block - Writing: 4096 - Total: 2682880 - Buffer size: 1395
                14:04:02.882 FLH: Read block - Writing: 4096 - Total: 2686976 - Buffer size: 1395
                14:04:02.987 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "22", "time_elapsed": 114}}
                14:04:03.080 FLH: Read block - Writing: 4096 - Total: 2691072 - Buffer size: 1395
                14:04:03.277 FLH: Read block - Writing: 4096 - Total: 2695168 - Buffer size: 1395
                14:04:03.388 FLH: Read block - Writing: 4096 - Total: 2699264 - Buffer size: 1395
                14:04:03.573 FLH: Read block - Writing: 4096 - Total: 2703360 - Buffer size: 1395
                14:04:03.771 FLH: Read block - Writing: 4096 - Total: 2707456 - Buffer size: 1395
                14:04:03.881 FLH: Read block - Writing: 4096 - Total: 2711552 - Buffer size: 1395
                14:04:04.073 FLH: Read block - Writing: 4096 - Total: 2715648 - Buffer size: 1395
                14:04:04.276 FLH: Read block - Writing: 4096 - Total: 2719744 - Buffer size: 1395
                14:04:04.385 FLH: Read block - Writing: 4096 - Total: 2723840 - Buffer size: 1395
                14:04:04.572 FLH: Read block - Writing: 4096 - Total: 2727936 - Buffer size: 1395
                14:04:04.770 FLH: Read block - Writing: 4096 - Total: 2732032 - Buffer size: 1395
                14:04:04.880 FLH: Read block - Writing: 4096 - Total: 2736128 - Buffer size: 1395
                14:04:05.074 FLH: Read block - Writing: 4096 - Total: 2740224 - Buffer size: 1395
                14:04:05.276 FLH: Read block - Writing: 4096 - Total: 2744320 - Buffer size: 1395
                14:04:05.387 FLH: Read block - Writing: 4096 - Total: 2748416 - Buffer size: 1395
                14:04:05.573 FLH: Read block - Writing: 4096 - Total: 2752512 - Buffer size: 1395
                14:04:05.771 FLH: Read block - Writing: 4096 - Total: 2756608 - Buffer size: 1395
                14:04:05.970 FLH: Read block - Writing: 4096 - Total: 2760704 - Buffer size: 1395
                14:04:06.171 FLH: Read block - Writing: 4096 - Total: 2764800 - Buffer size: 1395
                14:04:06.284 FLH: Read block - Writing: 4096 - Total: 2768896 - Buffer size: 1395
                14:04:06.395 FLH: Read block - Writing: 4096 - Total: 2772992 - Buffer size: 1395
                14:04:06.574 FLH: Read block - Writing: 4096 - Total: 2777088 - Buffer size: 1395
                14:04:06.770 FLH: Read block - Writing: 4096 - Total: 2781184 - Buffer size: 1395
                14:04:06.881 FLH: Read block - Writing: 4096 - Total: 2785280 - Buffer size: 1395
                14:04:07.074 FLH: Read block - Writing: 4096 - Total: 2789376 - Buffer size: 1395
                14:04:07.277 FLH: Read block - Writing: 4096 - Total: 2793472 - Buffer size: 1395
                14:04:07.389 FLH: Read block - Writing: 4096 - Total: 2797568 - Buffer size: 1395
                14:04:07.575 FLH: Read block - Writing: 4096 - Total: 2801664 - Buffer size: 1395
                14:04:07.740 FLH: Read block - Writing: 4096 - Total: 2805760 - Buffer size: 1395
                14:04:07.782 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "23", "time_elapsed": 119}}
                14:04:07.875 FLH: Read block - Writing: 4096 - Total: 2809856 - Buffer size: 1395
                14:04:08.074 FLH: Read block - Writing: 4096 - Total: 2813952 - Buffer size: 1395
                14:04:08.276 FLH: Read block - Writing: 4096 - Total: 2818048 - Buffer size: 1395
                14:04:08.388 FLH: Read block - Writing: 4096 - Total: 2822144 - Buffer size: 1395
                14:04:08.671 FLH: Read block - Writing: 4096 - Total: 2826240 - Buffer size: 1395
                14:04:08.871 FLH: Read block - Writing: 4096 - Total: 2830336 - Buffer size: 1395
                14:04:09.073 FLH: Read block - Writing: 4096 - Total: 2834432 - Buffer size: 1395
                14:04:09.276 FLH: Read block - Writing: 4096 - Total: 2838528 - Buffer size: 1395
                14:04:09.471 FLH: Read block - Writing: 4096 - Total: 2842624 - Buffer size: 1395
                14:04:09.670 FLH: Read block - Writing: 4096 - Total: 2846720 - Buffer size: 1395
                14:04:09.870 FLH: Read block - Writing: 4096 - Total: 2850816 - Buffer size: 1395
                14:04:10.074 FLH: Read block - Writing: 4096 - Total: 2854912 - Buffer size: 1395
                14:04:10.276 FLH: Read block - Writing: 4096 - Total: 2859008 - Buffer size: 1395
                14:04:10.426 FLH: Read block - Writing: 4096 - Total: 2863104 - Buffer size: 1395
                14:04:10.576 FLH: Read block - Writing: 4096 - Total: 2867200 - Buffer size: 1395
                14:04:10.770 FLH: Read block - Writing: 4096 - Total: 2871296 - Buffer size: 1395
                14:04:10.971 FLH: Read block - Writing: 4096 - Total: 2875392 - Buffer size: 1395
                14:04:11.084 FLH: Read block - Writing: 4096 - Total: 2879488 - Buffer size: 1395
                14:04:11.275 FLH: Read block - Writing: 4096 - Total: 2883584 - Buffer size: 1395
                14:04:11.471 FLH: Read block - Writing: 4096 - Total: 2887680 - Buffer size: 1395
                14:04:11.671 FLH: Read block - Writing: 4096 - Total: 2891776 - Buffer size: 1395
                14:04:11.870 FLH: Read block - Writing: 4096 - Total: 2895872 - Buffer size: 1395
                14:04:12.074 FLH: Read block - Writing: 4096 - Total: 2899968 - Buffer size: 1395
                14:04:12.277 FLH: Read block - Writing: 4096 - Total: 2904064 - Buffer size: 1395
                14:04:12.388 FLH: Read block - Writing: 4096 - Total: 2908160 - Buffer size: 1395
                14:04:12.574 FLH: Read block - Writing: 4096 - Total: 2912256 - Buffer size: 1395
                14:04:12.771 FLH: Read block - Writing: 4096 - Total: 2916352 - Buffer size: 1395
                14:04:12.881 FLH: Read block - Writing: 4096 - Total: 2920448 - Buffer size: 1395
                14:04:13.029 FLH: Read block - Writing: 4096 - Total: 2924544 - Buffer size: 1395
                14:04:13.176 FLH: Read block - Writing: 4096 - Total: 2928640 - Buffer size: 1395
                14:04:13.283 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "24", "time_elapsed": 124}}
                14:04:13.376 FLH: Read block - Writing: 4096 - Total: 2932736 - Buffer size: 1395
                14:04:13.573 FLH: Read block - Writing: 4096 - Total: 2936832 - Buffer size: 1395
                14:04:13.771 FLH: Read block - Writing: 4096 - Total: 2940928 - Buffer size: 1395
                14:04:13.880 FLH: Read block - Writing: 4096 - Total: 2945024 - Buffer size: 1395
                14:04:14.072 FLH: Read block - Writing: 4096 - Total: 2949120 - Buffer size: 1395
                14:04:14.277 FLH: Read block - Writing: 4096 - Total: 2953216 - Buffer size: 1395
                14:04:14.470 FLH: Read block - Writing: 4096 - Total: 2957312 - Buffer size: 1395
                14:04:14.670 FLH: Read block - Writing: 4096 - Total: 2961408 - Buffer size: 1395
                14:04:14.871 FLH: Read block - Writing: 4096 - Total: 2965504 - Buffer size: 1395
                14:04:15.073 FLH: Read block - Writing: 4096 - Total: 2969600 - Buffer size: 1395
                14:04:15.276 FLH: Read block - Writing: 4096 - Total: 2973696 - Buffer size: 1395
                14:04:15.471 FLH: Read block - Writing: 4096 - Total: 2977792 - Buffer size: 1395
                14:04:15.582 FLH: Read block - Writing: 4096 - Total: 2981888 - Buffer size: 1395
                14:04:15.771 FLH: Read block - Writing: 4096 - Total: 2985984 - Buffer size: 1395
                14:04:15.971 FLH: Read block - Writing: 4096 - Total: 2990080 - Buffer size: 1395
                14:04:16.083 FLH: Read block - Writing: 4096 - Total: 2994176 - Buffer size: 1395
                14:04:16.277 FLH: Read block - Writing: 4096 - Total: 2998272 - Buffer size: 1395
                14:04:16.389 FLH: Read block - Writing: 4096 - Total: 3002368 - Buffer size: 1395
                14:04:16.573 FLH: Read block - Writing: 4096 - Total: 3006464 - Buffer size: 1395
                14:04:16.771 FLH: Read block - Writing: 4096 - Total: 3010560 - Buffer size: 1395
                14:04:16.971 FLH: Read block - Writing: 4096 - Total: 3014656 - Buffer size: 1395
                14:04:17.081 FLH: Read block - Writing: 4096 - Total: 3018752 - Buffer size: 1395
                14:04:17.372 FLH: Read block - Writing: 4096 - Total: 3022848 - Buffer size: 1395
                14:04:17.574 FLH: Read block - Writing: 4096 - Total: 3026944 - Buffer size: 1395
                14:04:17.769 FLH: Read block - Writing: 4096 - Total: 3031040 - Buffer size: 1395
                14:04:18.000 FLH: Read block - Writing: 4096 - Total: 3035136 - Buffer size: 1395
                14:04:18.177 FLH: Read block - Writing: 4096 - Total: 3039232 - Buffer size: 1395
                14:04:18.370 FLH: Read block - Writing: 4096 - Total: 3043328 - Buffer size: 1395
                14:04:18.573 FLH: Read block - Writing: 4096 - Total: 3047424 - Buffer size: 1395
                14:04:18.771 FLH: Read block - Writing: 4096 - Total: 3051520 - Buffer size: 1395
                14:04:18.883 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "25", "time_elapsed": 130}}
                14:04:18.976 FLH: Read block - Writing: 4096 - Total: 3055616 - Buffer size: 1395
                14:04:19.170 FLH: Read block - Writing: 4096 - Total: 3059712 - Buffer size: 1395
                14:04:19.284 FLH: Read block - Writing: 4096 - Total: 3063808 - Buffer size: 1395
                14:04:19.394 FLH: Read block - Writing: 4096 - Total: 3067904 - Buffer size: 1395
                14:04:19.574 FLH: Read block - Writing: 4096 - Total: 3072000 - Buffer size: 1395
                14:04:19.771 FLH: Read block - Writing: 4096 - Total: 3076096 - Buffer size: 1395
                14:04:19.970 FLH: Read block - Writing: 4096 - Total: 3080192 - Buffer size: 1395
                14:04:20.084 FLH: Read block - Writing: 4096 - Total: 3084288 - Buffer size: 1395
                14:04:20.372 FLH: Read block - Writing: 4096 - Total: 3088384 - Buffer size: 1395
                14:04:20.573 FLH: Read block - Writing: 4096 - Total: 3092480 - Buffer size: 1395
                14:04:20.771 FLH: Read block - Writing: 4096 - Total: 3096576 - Buffer size: 1395
                14:04:20.884 FLH: Read block - Writing: 4096 - Total: 3100672 - Buffer size: 1395
                14:04:21.073 FLH: Read block - Writing: 4096 - Total: 3104768 - Buffer size: 1395
                14:04:21.277 FLH: Read block - Writing: 4096 - Total: 3108864 - Buffer size: 1395
                14:04:21.470 FLH: Read block - Writing: 4096 - Total: 3112960 - Buffer size: 1395
                14:04:21.579 FLH: Read block - Writing: 4096 - Total: 3117056 - Buffer size: 1395
                14:04:21.770 FLH: Read block - Writing: 4096 - Total: 3121152 - Buffer size: 1395
                14:04:21.882 FLH: Read block - Writing: 4096 - Total: 3125248 - Buffer size: 1395
                14:04:22.073 FLH: Read block - Writing: 4096 - Total: 3129344 - Buffer size: 1395
                14:04:22.277 FLH: Read block - Writing: 4096 - Total: 3133440 - Buffer size: 1395
                14:04:22.388 FLH: Read block - Writing: 4096 - Total: 3137536 - Buffer size: 1395
                14:04:22.572 FLH: Read block - Writing: 4096 - Total: 3141632 - Buffer size: 1395
                14:04:22.770 FLH: Read block - Writing: 4096 - Total: 3145728 - Buffer size: 1395
                14:04:22.970 FLH: Read block - Writing: 4096 - Total: 3149824 - Buffer size: 1395
                14:04:23.170 FLH: Read block - Writing: 4096 - Total: 3153920 - Buffer size: 1395
                14:04:23.282 FLH: Read block - Writing: 4096 - Total: 3158016 - Buffer size: 1395
                14:04:23.471 FLH: Read block - Writing: 4096 - Total: 3162112 - Buffer size: 1395
                14:04:23.581 FLH: Read block - Writing: 4096 - Total: 3166208 - Buffer size: 1395
                14:04:23.770 FLH: Read block - Writing: 4096 - Total: 3170304 - Buffer size: 1395
                14:04:23.971 FLH: Read block - Writing: 4096 - Total: 3174400 - Buffer size: 1395
                14:04:23.996 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "26", "time_elapsed": 135}}
                14:04:24.088 FLH: Read block - Writing: 4096 - Total: 3178496 - Buffer size: 1395
                14:04:24.276 FLH: Read block - Writing: 4096 - Total: 3182592 - Buffer size: 1395
                14:04:24.388 FLH: Read block - Writing: 4096 - Total: 3186688 - Buffer size: 1395
                14:04:24.571 FLH: Read block - Writing: 4096 - Total: 3190784 - Buffer size: 1395
                14:04:24.770 FLH: Read block - Writing: 4096 - Total: 3194880 - Buffer size: 1395
                14:04:24.882 FLH: Read block - Writing: 4096 - Total: 3198976 - Buffer size: 1395
                14:04:25.074 FLH: Read block - Writing: 4096 - Total: 3203072 - Buffer size: 1395
                14:04:25.276 FLH: Read block - Writing: 4096 - Total: 3207168 - Buffer size: 1395
                14:04:25.429 FLH: Read block - Writing: 4096 - Total: 3211264 - Buffer size: 1395
                14:04:25.572 FLH: Read block - Writing: 4096 - Total: 3215360 - Buffer size: 1395
                14:04:25.870 FLH: Read block - Writing: 4096 - Total: 3219456 - Buffer size: 1395
                14:04:26.073 FLH: Read block - Writing: 4096 - Total: 3223552 - Buffer size: 1395
                14:04:26.276 FLH: Read block - Writing: 4096 - Total: 3227648 - Buffer size: 1395
                14:04:26.387 FLH: Read block - Writing: 4096 - Total: 3231744 - Buffer size: 1395
                14:04:26.574 FLH: Read block - Writing: 4096 - Total: 3235840 - Buffer size: 1395
                14:04:26.770 FLH: Read block - Writing: 4096 - Total: 3239936 - Buffer size: 1395
                14:04:26.971 FLH: Read block - Writing: 4096 - Total: 3244032 - Buffer size: 1395
                14:04:27.171 FLH: Read block - Writing: 4096 - Total: 3248128 - Buffer size: 1395
                14:04:27.282 FLH: Read block - Writing: 4096 - Total: 3252224 - Buffer size: 1395
                14:04:27.393 FLH: Read block - Writing: 4096 - Total: 3256320 - Buffer size: 1395
                14:04:27.574 FLH: Read block - Writing: 4096 - Total: 3260416 - Buffer size: 1395
                14:04:27.770 FLH: Read block - Writing: 4096 - Total: 3264512 - Buffer size: 1395
                14:04:27.919 FLH: Read block - Writing: 4096 - Total: 3268608 - Buffer size: 1395
                14:04:28.074 FLH: Read block - Writing: 4096 - Total: 3272704 - Buffer size: 1395
                14:04:28.275 FLH: Read block - Writing: 4096 - Total: 3276800 - Buffer size: 1395
                14:04:28.386 FLH: Read block - Writing: 4096 - Total: 3280896 - Buffer size: 1395
                14:04:28.671 FLH: Read block - Writing: 4096 - Total: 3284992 - Buffer size: 1395
                14:04:28.870 FLH: Read block - Writing: 4096 - Total: 3289088 - Buffer size: 1395
                14:04:29.074 FLH: Read block - Writing: 4096 - Total: 3293184 - Buffer size: 1395
                14:04:29.278 FLH: Read block - Writing: 4096 - Total: 3297280 - Buffer size: 1395
                14:04:29.303 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "27", "time_elapsed": 141}}
                14:05:21.573 FLH: Read block - Writing: 4096 - Total: 4468736 - Buffer size: 1395
                14:05:21.770 FLH: Read block - Writing: 4096 - Total: 4472832 - Buffer size: 1395
                14:05:21.884 FLH: Read block - Writing: 4096 - Total: 4476928 - Buffer size: 1395
                14:05:22.094 FLH: Read block - Writing: 4096 - Total: 4481024 - Buffer size: 1395
                14:05:22.276 FLH: Read block - Writing: 4096 - Total: 4485120 - Buffer size: 1395
                14:05:22.389 FLH: Read block - Writing: 4096 - Total: 4489216 - Buffer size: 1395
                14:05:22.573 FLH: Read block - Writing: 4096 - Total: 4493312 - Buffer size: 1395
                14:05:22.771 FLH: Read block - Writing: 4096 - Total: 4497408 - Buffer size: 1395
                14:05:22.882 FLH: Read block - Writing: 4096 - Total: 4501504 - Buffer size: 1395
                14:05:23.073 FLH: Read block - Writing: 4096 - Total: 4505600 - Buffer size: 1395
                14:05:23.276 FLH: Read block - Writing: 4096 - Total: 4509696 - Buffer size: 1395
                14:05:23.388 FLH: Read block - Writing: 4096 - Total: 4513792 - Buffer size: 1395
                14:05:23.486 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "37", "time_elapsed": 195}}
                14:05:23.578 FLH: Read block - Writing: 4096 - Total: 4517888 - Buffer size: 1395
                14:05:23.770 FLH: Read block - Writing: 4096 - Total: 4521984 - Buffer size: 1395
                14:05:23.970 FLH: Read block - Writing: 4096 - Total: 4526080 - Buffer size: 1395
                14:05:24.769 FLH: Read block - Writing: 4096 - Total: 4530176 - Buffer size: 1395
                14:05:24.971 FLH: Read block - Writing: 4096 - Total: 4534272 - Buffer size: 1395
                14:05:25.171 FLH: Read block - Writing: 4096 - Total: 4538368 - Buffer size: 1395
                14:05:25.282 FLH: Read block - Writing: 4096 - Total: 4542464 - Buffer size: 1395
                14:05:25.470 FLH: Read block - Writing: 4096 - Total: 4546560 - Buffer size: 1395
                14:05:25.671 FLH: Read block - Writing: 4096 - Total: 4550656 - Buffer size: 1395
                14:05:25.869 FLH: Read block - Writing: 4096 - Total: 4554752 - Buffer size: 1395
                14:05:26.074 FLH: Read block - Writing: 4096 - Total: 4558848 - Buffer size: 1395
                14:05:26.277 FLH: Read block - Writing: 4096 - Total: 4562944 - Buffer size: 1395
                14:05:26.388 FLH: Read block - Writing: 4096 - Total: 4567040 - Buffer size: 1395
                14:05:26.574 FLH: Read block - Writing: 4096 - Total: 4571136 - Buffer size: 1395
                14:05:26.771 FLH: Read block - Writing: 4096 - Total: 4575232 - Buffer size: 1395
                14:05:26.881 FLH: Read block - Writing: 4096 - Total: 4579328 - Buffer size: 1395
                14:05:27.073 FLH: Read block - Writing: 4096 - Total: 4583424 - Buffer size: 1395
                14:05:27.220 FLH: Read block - Writing: 4096 - Total: 4587520 - Buffer size: 1395
                14:05:27.334 FLH: Read block - Writing: 4096 - Total: 4591616 - Buffer size: 1395
                14:05:28.170 FLH: Read block - Writing: 4096 - Total: 4595712 - Buffer size: 1395
                14:05:28.282 FLH: Read block - Writing: 4096 - Total: 4599808 - Buffer size: 1395
                14:05:28.392 FLH: Read block - Writing: 4096 - Total: 4603904 - Buffer size: 1395
                14:05:28.570 FLH: Read block - Writing: 4096 - Total: 4608000 - Buffer size: 1395
                14:05:28.772 FLH: Read block - Writing: 4096 - Total: 4612096 - Buffer size: 1395
                14:05:28.882 FLH: Read block - Writing: 4096 - Total: 4616192 - Buffer size: 311
                14:05:29.074 FLH: Read block - Writing: 4096 - Total: 4620288 - Buffer size: 311
                14:05:29.276 FLH: Read block - Writing: 4096 - Total: 4624384 - Buffer size: 311
                14:05:29.387 FLH: Read block - Writing: 4096 - Total: 4628480 - Buffer size: 311
                14:05:29.573 FLH: Read block - Writing: 4096 - Total: 4632576 - Buffer size: 311
                14:05:29.771 FLH: Read block - Writing: 4096 - Total: 4636672 - Buffer size: 311
                14:05:29.884 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "38", "time_elapsed": 201}}
                14:05:29.976 FLH: Read block - Writing: 4096 - Total: 4640768 - Buffer size: 311
                14:05:30.088 FLH: Read block - Writing: 4096 - Total: 4644864 - Buffer size: 311
                14:05:30.275 FLH: Read block - Writing: 4096 - Total: 4648960 - Buffer size: 311
                14:05:30.470 FLH: Read block - Writing: 4096 - Total: 4653056 - Buffer size: 311
                14:05:30.670 FLH: Read block - Writing: 4096 - Total: 4657152 - Buffer size: 311
                14:05:31.470 FLH: Read block - Writing: 4096 - Total: 4661248 - Buffer size: 311
                14:05:31.670 FLH: Read block - Writing: 4096 - Total: 4665344 - Buffer size: 311
                14:05:31.869 FLH: Read block - Writing: 4096 - Total: 4669440 - Buffer size: 311
                14:05:32.071 FLH: Read block - Writing: 4096 - Total: 4673536 - Buffer size: 311
                14:05:32.275 FLH: Read block - Writing: 4096 - Total: 4677632 - Buffer size: 311
                14:05:32.386 FLH: Read block - Writing: 4096 - Total: 4681728 - Buffer size: 311
                14:05:32.573 FLH: Read block - Writing: 4096 - Total: 4685824 - Buffer size: 311
                14:05:32.769 FLH: Read block - Writing: 4096 - Total: 4689920 - Buffer size: 311
                14:05:32.969 FLH: Read block - Writing: 4096 - Total: 4694016 - Buffer size: 311
                14:05:33.080 FLH: Read block - Writing: 4096 - Total: 4698112 - Buffer size: 311
                14:05:33.275 FLH: Read block - Writing: 4096 - Total: 4702208 - Buffer size: 311
                14:05:33.469 FLH: Read block - Writing: 4096 - Total: 4706304 - Buffer size: 311
                14:05:33.670 FLH: Read block - Writing: 4096 - Total: 4710400 - Buffer size: 311
                14:05:33.870 FLH: Read block - Writing: 4096 - Total: 4714496 - Buffer size: 311
                14:05:34.072 FLH: Read block - Writing: 4096 - Total: 4718592 - Buffer size: 311
                14:05:34.276 FLH: Read block - Writing: 4096 - Total: 4722688 - Buffer size: 311
                14:05:35.074 FLH: Read block - Writing: 4096 - Total: 4726784 - Buffer size: 311
                14:05:35.276 FLH: Read block - Writing: 4096 - Total: 4730880 - Buffer size: 311
                14:05:35.388 FLH: Read block - Writing: 4096 - Total: 4734976 - Buffer size: 311
                14:05:35.573 FLH: Read block - Writing: 4096 - Total: 4739072 - Buffer size: 311
                14:05:35.769 FLH: Read block - Writing: 4096 - Total: 4743168 - Buffer size: 311
                14:05:35.970 FLH: Read block - Writing: 4096 - Total: 4747264 - Buffer size: 311
                14:05:36.170 FLH: Read block - Writing: 4096 - Total: 4751360 - Buffer size: 311
                14:05:36.281 FLH: Read block - Writing: 4096 - Total: 4755456 - Buffer size: 311
                14:05:36.392 FLH: Read block - Writing: 4096 - Total: 4759552 - Buffer size: 311
                14:05:36.486 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "39", "time_elapsed": 208}}
                14:05:36.579 FLH: Read block - Writing: 4096 - Total: 4763648 - Buffer size: 311
                14:05:36.769 FLH: Read block - Writing: 4096 - Total: 4767744 - Buffer size: 311
                14:05:36.970 FLH: Read block - Writing: 4096 - Total: 4771840 - Buffer size: 311
                14:05:37.487 FLH: Read block - Writing: 4096 - Total: 4775936 - Buffer size: 2607
                14:05:38.106 FLH: Read block - Writing: 4096 - Total: 4780032 - Buffer size: 2819
                14:05:38.218 FLH: Read block - Writing: 4096 - Total: 4784128 - Buffer size: 2819
                14:05:38.330 FLH: Read block - Writing: 4096 - Total: 4788224 - Buffer size: 2819
                mich macht diese Zeile unrund, die kommt immer:
                teletapiT
                teletapiT
                teletapi
                schrieb am zuletzt editiert von teletapi
                #7577
                @australien said in SONOFF NSPanel mit Lovelace UI:
                Die Zeile kenne ich nur zu gut aus meinem US_Panel. Ich hab das nie geflasht bekommen ausser per RX/TX direkt am Display dann funktionierte das in kürzester Zeit
                • Bass-TB
                  Bass-TB
                  Bass-T
                  schrieb am zuletzt editiert von Bass-T
                  #7578
                  Unschön ist die Lokale Temp Anzeige im US Panel. Werde aber vermutlich die Position von rechts nach links noch tauschen.
                  EDIT:
                  So kann ich die Panels schonmal einbauen, restliche config mach ich per Emulator ;)
                  Proxmox Cluster
                  • NUC7i5 ioBroker Server (Proxmox)
                  • HP Elitedesk 800 G4 SSF (Proxmox)
                  • HP Elitedesk 800 G2 DM (Proxmox)
                    mein Proxmox-Updater für euch
                  KNX / Broadlink / Tasmota ESPs / Zigbee
                  Vis: 15" Touchmonitor mit Raspi4 / 10" Tablet (Dauerstrom umbau) / Sonoff NSPanel (alle)
                  • ArmilarA Armilar
                    Wer noch auf AccuWeather ist, der wird ab jetzt kein aktuelles Wetter mehr sehen 😢
                    Ältere kostenlose Testkonten werden nicht mehr unterstützt.
                    Folgender Fehler ist dabei im Log zu beobachten:
                    Wie ihr wisst, haben wir uns auf diesen Moment vorbereitet und 2 Adapter ins Leben gerufen, die als Ersatz dienen:
                    • Pirate-Weather
                      https://github.com/ticaki/ioBroker.pirate-weather
                    • Bright Sky (Deutscher Wetterdienst - DWD)
                      https://github.com/ticaki/ioBroker.brightsky
                    Beide Adapter sind noch nicht im Stable (obwohl sie prima funktionieren - auch im NSPanel!!!) und müssten aktuell noch über die Adapter-Katze installiert werden. Dürften aber in ein paar Tagen ins Stable-Repository kommen.
                    Wer dennoch AccuWeather weiternutzen möchte, kann das allerdings noch mit dem kostenpflichtigen Starter-Account machen:
                    K
                    K
                    Kerschte_de
                    #7579
                    @armilar sagte in SONOFF NSPanel mit Lovelace UI:
                    • Pirate-Weather
                    Schönen guten Abend.
                    Wenn man sich für eine der beiden Alternativen entscheidet, muss dann im Script an welchen Stellen etwas angepasst werden? Gibt es dazu ein "how to..." ?
                    Viele Grüße
                    Kersten
                    icebearI T 2 Antworten Letzte Antwort
                    • Bass-TB
                      Bass-TB
                      Bass-T
                      #7580
                      @kerschte_de soweit mir bekannt ist, diesen part anpassen ;) (v5.0.0)
                      Proxmox Cluster
                      • K Kerschte_de
                        • Pirate-Weather
                        Viele Grüße
                        Kersten
                        icebearI
                        icebearI
                        icebear
                        #7581
                        @kerschte_de said in SONOFF NSPanel mit Lovelace UI:
                        ....muss dann im Script an welchen Stellen etwas angepasst werden?
                        Denk dran, das wenn du etwas in der Screensaverconfig drin hast das du das auch änderst !
                        • K Kerschte_de
                          • Pirate-Weather
                          Viele Grüße
                          Kersten
                          T
                          T
                          TT-Tom
                          #7582
                          @kerschte_de
                          welche Version vom Script nutzt du aktuell, min ist Version 5.0.0.
                          dann musst du diesen Abschnitt einstellen.
                          /***** 3. Weather adapter Config *****/
                          und wie schon geschrieben, im Screensaver die Datenpunkte ändern.
                          z.B.
                          // bottomScreensaverEntity 1
                                      ScreensaverEntity: 'openweathermap.0.forecast.current.pressure',
                                      ScreensaverEntityFactor: 1,
                                      ScreensaverEntityDecimalPlaces: 0,
                                      ScreensaverEntityIconOn: 'gauge',
                                      ScreensaverEntityIconOff: null,
                                      ScreensaverEntityText: 'Druck',
                                      ScreensaverEntityUnitText: 'hPa',
                                      ScreensaverEntityIconColor: {'val_min': 950, 'val_max': 1050, 'val_best': 1013}
                          Gruß Tom
                          Public Transport
                          NSPanel Adapter Wiki
                          • T TT-Tom
                            @kerschte_de
                            z.B.
                            K
                            K
                            Kerschte_de
                            #7583
                            @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
                            @kerschte_de
                            Moin zusammen.
                            @TT-Tom Ich hänge noch in der Script-Version 4.7.1.2
                            • K Kerschte_de
                              @kerschte_de
                              Moin zusammen.
                              T
                              T
                              TT-Tom
                              #7584
                              @kerschte_de
                              in deinem Fall hat sich da einiges geändert, es gibt einen neuen Berry Treiber und eine neue TFT version für das panel.
                              ich würde dir vorschlagen, nach dieser Anleitung dein update zu machen.
                              https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Starthilfe-FAQ#hilfe-bei-update--upgrade
                              nach Schritt 5 solltest du erstmal den Berry und die TFT aktualisieren. wenn du da Prrobleme bekommst hier einfach melden.
                              Gruß Tom
                              Public Transport
                              K lobomauL 2 Antworten Letzte Antwort
                              • T TT-Tom
                                @kerschte_de
                                K
                                K
                                Kerschte_de
                                #7585
                                @tt-tom Vielen Dank für den Hinweis. Dann gehe ich erstmal das grundsätzliche Update heute Abend an und melde mich danach.
                                Viele Grüße, K
                                • M
                                  M
                                  maxxlg
                                  #7586
                                  Ein "Hallo" an alle!
                                  Ich arbeite schon einige Zeit mit dem Sonoff NSPanel mit Lovelace UI. Das Projekt ist echt gut, mein NSPanel läuft sehr gut.
                                  Nach dem letzten Update auf die Firmware 58 / v4.9.5 und Berry Driver v10 funktioniert alles soweit gut. Jetzt gibt es allerdings ein Problem mit dem QR-Code für das GästeWlan. Das Problem liegt wohl ander Passwortlänge bzw. Anzahl der Zeichen für das Wlan-Passwort. Ich benutze aktuell eine Länge von 32 Zeichen, bekomme allerdings nur ein weisses QR-Code Feld ausgegeben. Kürze ich das Passwort auf 15 Zeichen wird ein QR-Code korrekt angezeigt. In der "alten" Version wurde problemlos das Passwort mit 32 Zeichen verarbeitet! Wie bzw. was muss verändert/konfiguriert werden, dass ich auch mit einer Passwortlänge von 32 Zeichen wieder arbeiten kann?
                                  Vielen Dank für Eure Mithilfe.
                                  • T TT-Tom
                                    @kerschte_de
                                    lobomauL
                                    lobomauL
                                    lobomau
                                    schrieb am zuletzt editiert von lobomau
                                    #7587
                                    Edit: Panel läuft aber trotzdem nach Scriptstart. Habe:
                                    Berry 9 und TFT 53 und viele Warnungen.... vermutlich wegen dieser alten Versionen!?
                                    @tt-tom ich versuche gerade abzudaten auf Script 5.0.0.1.
                                    Ich bekomme Fehler beim Versuch TFT Firmware upzugraden. Tasmota habe ich auf 15.0.1. gebracht. Welches ist der richtige Befehl? wie im Script?
                                    FlashNextionAdv0 http://nspanel.de/nspanel-v5.0.0.tft
                                    Oder ohne Adv0?
                                    FlashNextion http://nspanel.de/nspanel-v5.0.0.tft
                                    Host: NUC8i3 mit Proxmox:
                                    • Slave: Pi4
                                    • ArmilarA
                                      ArmilarA
                                      Armilar
                                      Most Active Forum Testing
                                      #7588
                                      @lobomau
                                      FlashNextionAdv0 wäre jetzt dauerhaft mit 921600 baud
                                      Du kannst aber auch mit
                                      FlashNextion (letzte Aktive Geschwindigkeit)
                                      oder
                                      FlashNextionAdv2 (115200 baud) flashen, falls 921600 zu schnell ist.
                                      Welcher Fehler kommt denn?
                                      • M maxxlg
                                        ArmilarA
                                        ArmilarA
                                        Armilar
                                        #7589
                                        @maxxlg
                                        geht bei mir mit Passwort-Länge 32...
                                        Sicher, dass nicht irgendwelche Sonderzeichen drin sind, die nicht verarbeitet werden können?
                                        • lobomauL lobomau
                                          Oder ohne Adv0?
                                          T
                                          T
                                          TT-Tom
                                          #7590
                                          @lobomau
                                          hast du auch schon Berry 10 drauf oder noch 9? bitte prüfen -> schau mal in Tasmota im Dateisystem welches Datum die autoexec.be hat
                                          Gruß Tom
                                          Public Transport
                                          83.8k
