  4. IRobot Roomba Adapter
851 Beiträge 101 Kommentatoren 394.9k Aufrufe 65 Beobachtet
    @shakira1972
    /opt/iobroker/node_modules/iobroker.roomba/roomba.js
    Shakira1972
    schrieb am zuletzt editiert von Shakira1972
    #835
    @thomas-braun sagte in IRobot Roomba Adapter:
    @kusi Habe den Inhalt von roomba.js Link Text überschrieben, leider blieb der Adapter darauf rot.
    Hier die Fehlerprotokolle:
    host.raspberrypi
    	2025-08-10 18:39:56.325	error	instance system.adapter.roomba.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    	2025-08-10 18:39:56.325	error	Caught by controller[0]: Node.js v20.19.4
    host.raspberrypi
    	2025-08-10 18:39:56.325	error	Caught by controller[0]: }
    host.raspberrypi
    	2025-08-10 18:39:56.325	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.roomba/roomba.js' ]
    host.raspberrypi
    	2025-08-10 18:39:56.325	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.raspberrypi
    	2025-08-10 18:39:56.325	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:164:12) {
    host.raspberrypi
    	2025-08-10 18:39:56.325	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1096:12)
    host.raspberrypi
    	2025-08-10 18:39:56.324	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1275:32)
    host.raspberrypi
    	2025-08-10 18:39:56.324	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
    host.raspberrypi
    	2025-08-10 18:39:56.324	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1529:14)
    host.raspberrypi
    	2025-08-10 18:39:56.324	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.roomba/roomba.js:10:18)
    host.raspberrypi
    	2025-08-10 18:39:56.324	error	Caught by controller[0]: at require (node:internal/modules/helpers:182:18)
    host.raspberrypi
    	2025-08-10 18:39:56.324	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1298:19)
    host.raspberrypi
    	2025-08-10 18:39:56.324	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1043:27)
    host.raspberrypi
    	2025-08-10 18:39:56.324	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1212:15)
    host.raspberrypi
    	2025-08-10 18:39:56.323	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.roomba/roomba.js
    host.raspberrypi
    	2025-08-10 18:39:56.323	error	Caught by controller[0]: Require stack:
    host.raspberrypi
    	2025-08-10 18:39:56.323	error	Caught by controller[0]: Error: Cannot find module 'dorita980'
    host.raspberrypi
    	2025-08-10 18:39:56.323	error	Caught by controller[0]: ^
    host.raspberrypi
    	2025-08-10 18:39:56.323	error	Caught by controller[0]: throw err;
    host.raspberrypi
    	2025-08-10 18:39:56.323	error	Caught by controller[0]: node:internal/modules/cjs/loader:1215
    Habe darauf wieder den alten Inhalt eingefügt.
    Wenn ich einen Raum einschalten möchte, dann kommt folgende meldung im Protokoll:
    Ran command {"command":"start","ordered":1,"params":{"noAutoPasses":false,"twoPass":false},"pmap_id":"xlRw9cAVQ-ut2YRlxxxxxx","regions":[{ "region_id": "17", "type": " rid" }],"user_pmapv_id":"250613Txxxxxx"}!
    Ist das korrekt?
    Hat jemand eine Idee?
    • S Shakira1972
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      Ist das korrekt?
      #836
      @shakira1972 sagte in IRobot Roomba Adapter:
      Da fehlt was.
      cd /opt/iobroker && npm ls dorita980
      sagt?
        Da fehlt was.
        sagt?
        Shakira1972
        #837
        Dorita ist hier:
        zum Auslesen des Passwort hat es funktioniert,,
        Soll ich es dort cd /opt/iobroker nochmal installieren?
        • S Shakira1972
          Dorita ist hier:
          #838
          @shakira1972
          Du sollst aber keine Screenshots aus deinem Filemanager zeigen sondern aus Ausgabe von obigem Befehl in deinem Terminal. In /home/pi liegt das nämlich falsch...
            @shakira1972
            Shakira1972
            #839
            @thomas-braun Ok, entschuldige, kenne mich leider nicht so aus...
            pi@raspberrypi:~ $ cd /opt/iobroker && npm ls dorita980
            iobroker.inst@3.0.0 /opt/iobroker
            └── (empty)
            • S Shakira1972
              └── (empty)
              #840
              @shakira1972
              Verlink mir mal die Anleitung nach der du das machst.
                @shakira1972
                Shakira1972
                #841
                Erstellen Räume
                _runCommand Befehl roomba.js
                • S Shakira1972
                  Erstellen Räume
                  #842
                  @shakira1972
                  ls -l /opt/iobroker/node_modules/iobroker.roomba/roomba.js
                  sagt?
                    @shakira1972
                    sagt?
                    Shakira1972
                    #843
                    pi@raspberrypi:~ $ ls -l /opt/iobroker/node_modules/iobroker.roomba/roomba.js
                    -rw-rw-r--+ 1 iobroker iobroker 25763 Aug 10 20:16 /opt/iobroker/node_modules/iobroker.roomba/roomba.js
                    • S Shakira1972
                      #844
                      @shakira1972
                      Kann ich bei mir auch nicht nachbauen. Muss dir wer anders helfen.
                        @shakira1972
                        Shakira1972
                        #845
                        Habe versucht eine ältere Version zu installieren, Version 1.1.0.
                        romba.rs ausgetauscht, kam keine Fehlermeldung, aber der Start des Roboter funktionierte trotzdem nicht.
                        Nun wollte ich wieder zurück zur aktuellen Version, leider funktionierte dies auch nicht mehr:
                        host.raspberrypi
                        2025-08-11 07:17:06.262	error	iobroker host.raspberrypi Cannot install iobroker.roomba@1.3.0: 217
                        host.raspberrypi
                        2025-08-11 07:17:06.259	error	iobroker Could not handle ENOTEMPTY, because no deletable files were foundnpm error code ENOTEMPTYnpm error syscall renamenpm error path /opt/iobroker/node_modules/iobroker.roombanpm error dest /opt/iobroker/node_modules/.iobroker.roomba-PCJSWkounpm error errno -39npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.roomba' -> '/opt/iobroker/node_modules/.iobroker.roomba-PCJSWkou'npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-11T05_16_49_932Z-debug-0.log
                        dann wollte ich den Adapter Deinstallieren und Neu installieren, auch das funktioniert nicht mehr:
                        $ iobroker del roomba
                        Delete adapter "roomba"
                        host.raspberrypi Counted 1 states (io.roomba.*) from states
                        host.raspberrypi Counted 2 states (system.adapter.roomba.*) from states
                        host.raspberrypi object roomba deleted
                        host.raspberrypi object roomba.admin deleted
                        host.raspberrypi Deleting 1 object(s).
                        host.raspberrypi Deleting 3 state(s).
                        Error deleting adapter roomba from disk: host.raspberrypi: Cannot uninstall iobroker.roomba: 217
                        You might have to delete it yourself!
                        Process exited with code 0
                        Ok, wie kann ich nun den Adapter komplett löschen, damit ich Ihn Neu installieren kann?
                        • S Shakira1972
                          host.raspberrypi
                          host.raspberrypi
                          #846
                          @shakira1972
                          Versuch mal den Fixer:
                          iob stop
                          iob fix
                          iob start
                            @shakira1972
                            iob stop
                            iob fix
                            iob start
                            Shakira1972
                            #847
                            iob start
                            Danke für die schnelle Hilfe!
                            Habe es durchgeführt und das Update auf die Neueste Version hat wieder funktioniert!
                            Im Punkt 1/5 steht ich soll polkitd installieren? Wie?
                            library: loaded
                            Library version=2025-08-09
                                Welcome to the ioBroker installation fixer!
                                Script version: 2025-08-09
                                You might need to enter your password a couple of times.
                                Installing prerequisites (1/5)
                            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:2 http://deb.debian.org/debian bullseye InRelease
                            Hit:3 https://apt.grafana.com stable InRelease
                            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:5 https://repos.influxdata.com/debian stable InRelease
                            Hit:6 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                            Get:7 http://archive.raspberrypi.org/debian bullseye InRelease [39.0 kB]
                            Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Get:9 https://pkgs.tailscale.com/stable/debian bullseye InRelease
                            Get:10 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [330 kB]
                            Get:11 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [323 kB]
                            Fetched 699 kB in 3s (248 kB/s)
                            Reading package lists... Done
                             Processing triggers for man-db (2.9.4-2) ...1u1_arm64.deb ...stalled.)
                            Installed distro-info
                            E: Unable to locate package polkitd
                            Installed polkitd
                                Checking ioBroker user and directory permissions (2/5)
                                Check and cleanup npm temporary directories (3/5)
                            Done.
                                Database maintenance (4/5)
                            Checking for uncompressed JSONL databases... This might take a while!
                            Compressing /opt/iobroker/iobroker-data/states.jsonl
                            Compressing /opt/iobroker/iobroker-data/objects.jsonl
                            Compressed 2 JSONL files. Done
                                Checking autostart (5/5)
                            Enabling autostart...
                            Autostart enabled!
                                Your installation was fixed successfully
                                Run iobroker start to start ioBroker again!
                            • S Shakira1972
                              iob start
                              library: loaded
                              Installed polkitd
                              Done.
                              Autostart enabled!
                              #848
                              Installed polkitd
                              Das ist installiert worden. Kannste per
                              apt policy polkitd
                              nachprüfen.
                              Allerdings musst du dein Betriebssystem mal neuinstallieren.
                              Bullseye ist tot.
                                Installed polkitd
                                apt policy polkitd
                                nachprüfen.
                                Bullseye ist tot.
                                Shakira1972
                                #849
                                pi@raspberrypi:~ $ apt policy polkitd
                                N: Unable to locate package polkitd
                                Bullseye ist tot?
                                Kann ich das Betriebssystem Neu Installieren, einfach darüber, ohne das ich alles was installiert ist, verliere oder Neu installiert werden muss?
                                Wie heißt das Neue?
                                • S Shakira1972
                                  Bullseye ist tot?
                                  Wie heißt das Neue?
                                  #850
                                  @shakira1972
                                  Muss komplett neuinstalliert werden. Die Nachfolger heißen RaspberryOS 12 'Bookworm' und RaspberryOS 13 'Trixie'.
                                  Wobei RaspberryOS 13 'Trixie' erst in den kommenden Wochen offiziell veröffentlicht werden wird. Das würde ich wohl noch abwarten und dann direkt darauf gehen.
                                  • SKBS SKB
                                    Sollte jemand die konfortable Steuerung des iRobot über die Räume auch wünschen, so habe ich hier einmal eine Anleitung inklusive Skript erstellt, wie das "sogut, wie jeder"-Otto-Normalverbraucher hinbekommt ;)
                                    Benefits:
                                    • Steuerung des iRobot über Raum und Zonen-Namen
                                    • Anzeige gereinigter Quadratmeter (funktioniert mit dem Roomba Adapter nicht mehr)
                                    • Anzeige, welches Wischtuch im Braava installiert ist
                                    • Anzeige des Zustand des Wassertanks des Braava
                                    https://www.kreyenborg.koeln/irobot-steuerung-in-iobroker/
                                    Gruß,
                                    SKB
                                    Shakira1972
                                    #851
                                    @skb sagte in IRobot Roomba Adapter:
                                    Benefits:
                                    Gruß,
                                    SKB
                                    Guten Nachmittag,
                                    ich habe das tolle Skript bei mir installiert und damit auch eine Visualisierung gemacht.
                                    Funktionierte soweit vorerst alles sehr gut.
                                    Ich habe zwei Stöcke in meiner Wohnung,
                                    Anfangs habe ich nur einen Stock "Hauptgeschoss" mit den Skript aufgenommen, alles funktionierte wunderbar.
                                    Nun habe ich auch die Räume in zweiten Stock "Obergeschoss" aufgenommen.
                                    Unter Objekte javascript.0.iRobot.Roomba.Bereiche bildete sich ein zweiter Ordner und die Neuen Räume schienen dort auf.
                                    Ich gab Ihnen jeweils einen Namen ein und alles schien zu funktionieren.
                                    Am Tag danach startete ich eine Aufgabe "Badezimmer" im Hauptgeschoss.
                                    Der Romba saugte nicht nur das Badezimmer sondern das gesamte Hauptgeschoss und legte jeweils einen Neuen Raum in Obergeschoss mit den Räumen des Hauptgeschoss an.
                                    Also habe ich, in Ordner der Räume des Obergeschoss einfach die einzelnen Räume des Untergeschoss beschriftet und hoffte das dann alles funktionieren würde. Hat es aber leider nicht, Egal welchen Raum ich zu starten probierte, es wurde immer jeweils der gesamte Stock gereinigt.
                                    Ok, dann habe ich den Ordner des Obergeschoss gelöscht, darauf funktioniert alles wieder in Hauptgeschoss.
                                    Das nächste Problem ist nun, das jedes mal wenn ich das Obergeschoss Reinige, sich wieder Neue Räume anlegen, die ich dann wiederum löschen muss.
                                    Zur Info, ich habe darauf geachtet, das keiner der Räume, beider Stöcke die selben Namen hat.
                                    Was mir noch aufgefallen ist, ein Raum in Hauptgeschoss und ein Raum in Obergeschoss hatte jeweils "6".
                                    Vielleicht hat noch jemand das selbe Problem und kann mir Helfen?
                                    Shakira
