  4. Neuer Adapter ioBroker.evcc
    6.3k
277 Beiträge 44 Kommentatoren 71.6k Aufrufe 41 Beobachtet
  • ChrizC Chriz
    da taucht er tatsächlich auf:
    iobroker.inst@3.0.0 /opt/iobroker
    ├── @sentry/node@6.19.7
    ├── iobroker.admin@7.6.17
    ├── iobroker.alexa2@3.27.3
    ├── iobroker.backitup@3.3.5
    ├── iobroker.denon@1.15.12
    ├── iobroker.discovery@5.0.0
    ├── iobroker.homeconnect@1.4.3
    ├── iobroker.icons-mfd-svg@1.2.0
    ├── iobroker.influxdb@4.0.2
    ├── iobroker.iot@3.3.0
    ├── iobroker.javascript@8.9.2
    ├── iobroker.js-controller@7.0.6
    ├── iobroker.lgtv@2.4.0
    ├── iobroker.loxone@3.0.1
    ├── iobroker.luxtronik2@0.3.1 (git+ssh://git@github.com/UncleSamSwiss/ioBroker.luxtronik2.git#e507d3d188440a4e8cd394648a5b20d75ce9cbb0)
    ├── iobroker.mqtt@6.1.2
    ├── iobroker.nuki-extended@2.7.0
    ├── iobroker.octoprint@5.1.0
    ├── iobroker.ring@6.4.0
    ├── iobroker.sainlogic@0.11.6
    ├── iobroker.shelly@10.1.0
    ├── iobroker.signal-cmb@0.3.0
    ├── iobroker.simple-api@2.8.0
    ├── iobroker.smartmeter@3.4.0
    ├── iobroker.socketio@6.7.1
    ├── iobroker.tr-064@4.3.0
    ├── iobroker.tuya@3.16.0
    ├── iobroker.vis-history@1.0.0
    ├── iobroker.vis-hqwidgets@1.5.1
    ├── iobroker.vis-jqui-mfd@1.1.1
    ├── iobroker.vis-justgage@2.1.7
    ├── iobroker.vis-material-advanced@1.7.4
    ├── iobroker.vis-metro@1.2.0
    ├── iobroker.vis-timeandweather@1.2.2
    ├── iobroker.vis-weather@2.5.12
    ├── iobroker.vis@1.5.6
    ├── iobroker.vw-connect@0.0.67
    ├── iobroker.weatherunderground@3.7.0
    ├── iobroker.web@7.0.8
    ├── iobroker.ws@2.6.2
    ├── iobroker.zigbee@2.0.5
    └── luxtronik2@2.4.0
    #210
    @chriz sagte in Neuer Adapter ioBroker.evcc:
    Weil GUIs dich anlügen.
    iob del ring --debug
    ChrizC 1 Antwort Letzte Antwort
      ChrizC Offline
      ChrizC Offline
      Chriz
      schrieb am zuletzt editiert von Chriz
      #211
      @thomas-braun said in Neuer Adapter ioBroker.evcc:
      oh na das lief jetzt komplett durch.
      Delete adapter "ring"
      host.059ff1dc9fba Counted 1 meta of ring
      host.059ff1dc9fba Counted 1 adapter for ring
      host.059ff1dc9fba Counted 1 states (system.adapter.ring.*) from states
      host.059ff1dc9fba file ring.admin deleted
      host.059ff1dc9fba object ring deleted
      host.059ff1dc9fba object ring.admin deleted
      host.059ff1dc9fba Deleting 3 object(s).
      host.059ff1dc9fba Deleting 1 state(s).
      removed 139 packages in 9s
      153 packages are looking for funding
        run `npm fund` for details
      AUch in der Liste cd /opt/iobroker && npm ls taucht er nicht mehr auf.
      • ChrizC Chriz
        #212
        Ja, jetzt ist er ja auch sauber entfernt worden.
        Fummel da nicht grobschlächtig im Dateisystem mit irgendwelchen Löschaktionen herum.
        Sowas läuft unter Linux eigentlich immer über einen entsprechenden Paketmanager (z. B. dpkg, apt, pacman, npm etc.).
        Die tragen die Installationen dann auch richtig in den jeweiligen Datenbanken ein und auch wieder aus.
          ChrizC Offline
          ChrizC Offline
          Chriz
          #213
          okay ich werde es mir zu herzen nehmen ;)
          Meinst du ich kann jetzt nochmal versuchen den EVCC Adapter zu isntallieren oder sollte ich vorher noch was anderes machen?
          • ChrizC Chriz
            #214
            @chriz
            iob add evcc --debug
            mal versuchen. Sollte dann jetzt eigentlich durchlaufen.
              @chriz
              ChrizC Offline
              ChrizC Offline
              Chriz
              #215
              vielen lieben dank für die großartige Hilfe :)
              Nun funzt alles.
              • H Offline
                huzzel
                #216
                Mal ne Frage:
                Gibt es auch eine Tagesstatiskik?
                In evcc.0.status.statistics ist sie ja leider nicht enthalten.
                • H huzzel
                  Mal ne Frage:
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #217
                  @huzzel sagte in Neuer Adapter ioBroker.evcc:
                  gibt den die API von evcc diese aus ??
                  H oberfraggerO 2 Antworten Letzte Antwort
                  • arteckA arteck
                    huzzel
                    #218
                    @arteck unter Ladevorgänge gibt es zumindest für jeden Tag einen Balken. In wieweit das über die API zugänglich ist, habe ich keine Ahnung
                    • arteckA arteck
                      oberfraggerO Offline
                      oberfragger
                      #219
                      @huzzel Der Datenpunkt "evcc.0.loadpoint.1.status.sessionEnergy" ist ein Sessionzähler.
                      Jedes mal wenn du den Stecker abnimmst bzw. ransteckst, startet die Session neu. Das siehst du auch ganz gt auf den Daten.
                      Da gibts mehrere "0" Werte pro Tag. Halt immer wenn der Stecker abgesteckt wurde.
                      Die Tagesstatistik wird m.E. in der internen EVCC-Datenbank aggregiert. So eine Tagesstatistik hätte ich auch gern, da müsste ich mir dann per Script bauen. Sollte kein Hexenwerk sein.
                      Wenn man dieses in den Adapter integriert, müsste man natürlich den:
                      Tageswert pro Wallbox und den
                      Tageswert pro Auto darstellen.
                      Es gibt sicher Nutzer, die 2 Autos an der gleichen Wallbox laden.
                      arteckA H 2 Antworten Letzte Antwort
                      • oberfraggerO oberfragger
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #220
                        @oberfragger sagte in Neuer Adapter ioBroker.evcc:
                        es soll Leute geben die mehrere >2 Autos an der gleichen Wallbox laden.. :-)
                          huzzel
                          #221
                          @oberfragger Mir persönlich geht es nur um die PV-Energie, die in das/die Autos geht (ich habe aber nur eines ;) ) für meine Tagesstatistik, wo meine PV-Energie hingeht.
                          Aktuell habe ich mir mit der sessionEnergy was gebastelt, was erstmal funtkioniert, aber nicht alle Edge-Cases abfängt (die bei mir eigentlich auch nicht auftreten sollten). Aber ich habe halt gedacht, wenn es schon bei der Statiskik die Werte für die letzten 30 Tage, letztes Jahr und total gibt, sollte es für einen Tag keinen großen Aufwand machen.
                          • H huzzel
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #222
                            @huzzel muss ich mich angesprochen füllen ?? also machst du den PR dafür ?
                              Thias
                              #223
                              Hallo zusammen, gibt es eine Möglichkeit, die Ladung der Hausbatterie über das Netz mit dem Adapter zu steuern? Sehen kann ich die Einträge evcc.0.status.batteryGridChargeActive und evcc.0.status.batteryGridChargeLimit. Das sind, meines Wissens nach, nur Statusmeldungen und im Adapter nicht anpassbare Werte. Oder?
                              Vielen Dank!
                              • T Thias
                                Vielen Dank!
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #224
                                @thias sagte in Neuer Adapter ioBroker.evcc:
                                . Oder?
                                auf die Frage kannst du dir selber antworten... welches Icon steht davor ?? so einer 97c3a13b-c61f-4819-b88d-f7c3fe33fbec-grafik.png
                                • arteckA arteck
                                  . Oder?
                                  Thias
                                  #225
                                  @arteck Genau, aber die Frage bleibt ja: Gibt es einen Weg, über den Adapter das Laden der Hausbatterie über das Netz zu bearbeiten? Dank!
                                  arteckA B 2 Antworten Letzte Antwort
                                  • T Thias
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #226
                                    Hausbatterie
                                    das kannst du doch in evcc auch nicht..
                                    ahh doch..ist aber sert experimentell
                                    https://docs.evcc.io/docs/features/battery
                                    • oberfraggerO Offline
                                      oberfragger
                                      schrieb am zuletzt editiert von oberfragger
                                      #227
                                      Wenn ich in EVCC den Modus umstelle, dauert das ewig bis ich das in den Objekten des loadpoints sehe. Ist das so gewünscht? In MQTT wird das ja sofort angezeigt.
                                      Das hängt sicher hiermit zusammen:
                                      Vom Wording wird eine Suche nach einer evcc Instanz vermutet (zumindest bei mir). Der Text müsste dann ja eigentlich lauten:
                                      "evcc Updateintervall in Sekunden".
                                      Ist es hinderlich wenn ich das Updateintervall auf 1 Sekunde ändere oder warum wurden die 100s gewählt? Hintergrund: Ich habe Button und RFID an der Wallbox. Dieses möchte ich nutzen um den Modus umzustellen. Damit Kann ich mir dann instant Benachrichtigungen schicken lassen, wenn der Modus geändert wurde.
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #228
                                        das ist die automatische Übersetzung habs gerade auf GIT korrigiert..DANKE
                                        zu deinem Punkt .. 1 Sek ist schon arg kurz.. ich mach alle 10 Sek .. aber kannst ja versuchen.. passiert ja nix.. ausser du flutest dein Netzwerk mit dem Interwall
                                        • T Thias
                                          bakerman23
                                          #229
                                          @thias Hi. Hast du dazu eine Lösung gefunden?
                                          Es gibt zwar einen Datenpunkt als Status, der hat aber keine Steuerfunktion.
