  4. Neuer Adapter ioBroker.evcc
    6.3k
277 Beiträge 44 Kommentatoren 71.6k Aufrufe 41 Beobachtet
    @chriz
    Gib mal per Ausgabe von
    iob diag
    einen Überblick über die Kiste.
    das ist ja das komische, den Adapter habe ich schon seit Ewigkeiten nicht mehr installiert.
    Da isser doch...
    iobroker.inst@3.0.0 /opt/iobroker
    └─┬ iobroker.ring@6.3.0
      └── ring-client-api@13.1.0
    #202
    @thomas-braun sagte in Neuer Adapter ioBroker.evcc:
    Und
    iob diag
    ChrizC 1 Antwort Letzte Antwort
      Und
      iob diag
      ChrizC Offline
      ChrizC Offline
      Chriz
      schrieb am zuletzt editiert von Chriz
      #203
      diag:
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
      Hardware Vendor : To Be Filled By O.E.M.
      Kernel          : x86_64
      Userland        : 64 bit
      Docker          : v11.0.0
      Virtualization  : docker
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
      19:57:00 up 62 days,  9:32,  0 user,  load average: 6.89, 4.21, 2.91
      CPU threads: 8
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
      *** TIME AND TIMEZONES ***
      Wed Aug  6 17:57:00 UTC 2025
      Wed Aug  6 19:57:00 CEST 2025
      CEST +0200
      Etc/UTC
      *** Users and Groups ***
      User that called 'iob diag':
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/opt/iobroker
      GROUPS=users tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             12G        5.4G        862M        471M        7.2G        7.1G
      Swap:            10G        450M         10G
      Total:           23G        5.9G         11G
      Active iob-Instances:   24
             11910 M total memory
              5155 M used memory
              4395 M active memory
              4922 M inactive memory
               822 M free memory
                 0 M buffer memory
              6905 M swap cache
             10239 M total swap
               429 M used swap
              9810 M free swap
      top - 19:57:00 up 62 days,  9:32,  0 user,  load average: 6.89, 4.21, 2.91
      Tasks:  32 total,   1 running,  31 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  11910.8 total,    819.0 free,   5158.0 used,   6907.1 buff/cache
      MiB Swap:  10240.0 total,   9810.7 free,    429.3 used.   6752.8 avail Mem
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem     Type       Size  Used Avail Use% Mounted on
      /dev/loop2     btrfs       25G  7.7G   17G  32% /
      tmpfs          tmpfs       64M     0   64M   0% /dev
      shm            tmpfs       64M     0   64M   0% /dev/shm
      shfs           fuse.shfs  932G  528G  402G  57% /opt/iobroker
      /dev/loop2     btrfs       25G  7.7G   17G  32% /etc/hosts
      tmpfs          tmpfs      5.9G     0  5.9G   0% /proc/acpi
      tmpfs          tmpfs      5.9G     0  5.9G   0% /sys/firmware
      Show mounted filesystems:
      TARGET                  SOURCE        FSTYPE    OPTIONS
      /                       /dev/loop2[/btrfs/subvolumes/29b8ef038abf841abe4a11cce465461999a1f81ae4b20da4deb7d15633aafacf]       btrfs     rw,noatime,ssd,discard=async,space_cache=v2,subvolid=2501,subvol=/btrfs/subvolumes/29b8ef038abf841abe4a11cce465461999a1f81ae4b20da4deb7d15633aafacf
      |-/opt/iobroker         shfs[/appdata/iobroker/data]        fuse.shfs rw,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other
      |-/opt/userscripts      shfs[/appdata/iobroker/scripts]        fuse.shfs rw,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other
      |-/etc/resolv.conf      /dev/loop2[/containers/059ff1dc9fbaae111bbe6f890fece639920b55e5713336d396d04877daf2b22f/resolv.conf] btrfs     rw,noatime,ssd,discard=async,space_cache=v2,subvolid=5,subvol=/
      |-/etc/hostname         /dev/loop2[/containers/059ff1dc9fbaae111bbe6f890fece639920b55e5713336d396d04877daf2b22f/hostname]    btrfs     rw,noatime,ssd,discard=async,space_cache=v2,subvolid=5,subvol=/
      |-/etc/hosts            /dev/loop2[/containers/059ff1dc9fbaae111bbe6f890fece639920b55e5713336d396d04877daf2b22f/hosts]       btrfs     rw,noatime,ssd,discard=async,space_cache=v2,subvolid=5,subvol=/
      `-/usr/local/bin/influx shfs[/appdata/influx-cli/influx]        fuse.shfs ro,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other
      /var:
      35M     /var/
      33M     /var/lib
      19M     /var/lib/apt/lists
      19M     /var/lib/apt
      14M     /var/lib/dpkg
      /opt/iobroker/backups:
      12M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      393M    /opt/iobroker/iobroker-data/
      195M    /opt/iobroker/iobroker-data/files
      143M    /opt/iobroker/iobroker-data/backup-objects
      48M     /opt/iobroker/iobroker-data/files/iot.admin
      47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      18M     /opt/iobroker/iobroker-data/objects.jsonl
      13M     /opt/iobroker/iobroker-data/objects.json.migrated
      13M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_3a866a46ae89eb118f103dc07d11dc1e-if00-port0
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_de4ef275ea5fec118396325f25bfaa52-if00-port0
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.17.1
      /usr/bin/node           v22.17.1
      /usr/bin/npm            10.9.2
      /usr/bin/npx            10.9.2
      /usr/bin/corepack       0.33.0
      nodejs:
       Installed: 22.17.1-1nodesource1
       Candidate: 22.18.0-1nodesource1
       Version table:
          22.18.0-1nodesource1 1001
      *** 22.17.1-1nodesource1 1001
          22.17.0-1nodesource1 1001
          22.16.0-1nodesource1 1001
          22.15.1-1nodesource1 1001
          22.15.0-1nodesource1 1001
          22.14.0-1nodesource1 1001
          22.13.1-1nodesource1 1001
          22.13.0-1nodesource1 1001
          22.12.0-1nodesource1 1001
          22.11.0-1nodesource1 1001
          22.10.0-1nodesource1 1001
          22.9.0-1nodesource1 1001
          22.8.0-1nodesource1 1001
          22.7.0-1nodesource1 1001
          22.6.0-1nodesource1 1001
          22.5.1-1nodesource1 1001
          22.5.0-1nodesource1 1001
          22.4.1-1nodesource1 1001
          22.4.0-1nodesource1 1001
          22.3.0-1nodesource1 1001
          22.2.0-1nodesource1 1001
          22.1.0-1nodesource1 1001
          22.0.0-1nodesource1 1001
          18.19.0+dfsg-6~deb12u2 500
             500 http://deb.debian.org/debian bookworm/main amd64 Packages
          18.19.0+dfsg-6~deb12u1 500
             500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      059ff1dc9fba        059ff1dc9fba (version: 7.0.6, hostname: 059ff1dc9fba  , alive, uptime: 305)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     8.9.2
      nodejs modules from github:     1
      +-- iobroker.luxtronik2@0.3.1 (git+ssh://git@github.com/UncleSamSwiss/ioBroker.luxtronik2.git#e507d3d188440a4e8cd394648a5b20d75ce9cbb0)
      Adapter State
      + system.adapter.admin.0                  : admin                 : 059ff1dc9fba                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : 059ff1dc9fba                             -  enabled
      + system.adapter.backitup.0               : backitup              : 059ff1dc9fba                             -  enabled
      + system.adapter.denon.0                  : denon                 : 059ff1dc9fba                             -  enabled
      + system.adapter.discovery.0              : discovery             : 059ff1dc9fba                             -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : 059ff1dc9fba                             -  enabled
       system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : 059ff1dc9fba                             -  enabled
      + system.adapter.influxdb.0               : influxdb              : 059ff1dc9fba                             -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : 059ff1dc9fba                             -  enabled
      + system.adapter.javascript.0             : javascript            : 059ff1dc9fba                             -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : 059ff1dc9fba                             -  enabled
      + system.adapter.loxone.0                 : loxone                : 059ff1dc9fba                             -  enabled, port: 80
      + system.adapter.luxtronik2.0             : luxtronik2            : 059ff1dc9fba                             -  enabled, port: 8214
      + system.adapter.mqtt.0                   : mqtt                  : 059ff1dc9fba                             -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.nuki-extended.0          : nuki-extended         : 059ff1dc9fba                             -  enabled
      + system.adapter.sainlogic.0              : sainlogic             : 059ff1dc9fba                             -  enabled, port: 45000, bind: 0.0.0.0
      + system.adapter.shelly.0                 : shelly                : 059ff1dc9fba                             -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.signal-cmb.0             : signal-cmb            : 059ff1dc9fba                             -  enabled
      + system.adapter.simple-api.0             : simple-api            : 059ff1dc9fba                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : 059ff1dc9fba                             -  enabled
      + system.adapter.tr-064.0                 : tr-064                : 059ff1dc9fba                             -  enabled
       system.adapter.vis-history.0            : vis-history           : 059ff1dc9fba                             -  enabled
       system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : 059ff1dc9fba                             -  enabled
       system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : 059ff1dc9fba                             -  enabled
       system.adapter.vis-justgage.0           : vis-justgage          : 059ff1dc9fba                             -  enabled
       system.adapter.vis-material-advanced.0  : vis-material-advanced : 059ff1dc9fba                             -  enabled
       system.adapter.vis-metro.0              : vis-metro             : 059ff1dc9fba                             -  enabled
       system.adapter.vis-timeandweather.0     : vis-timeandweather    : 059ff1dc9fba                             -  enabled
       system.adapter.vis-weather.0            : vis-weather           : 059ff1dc9fba                             -  enabled
       system.adapter.vis.0                    : vis                   : 059ff1dc9fba                             -  enabled
      + system.adapter.vw-connect.1             : vw-connect            : 059ff1dc9fba                             -  enabled
       system.adapter.weatherunderground.0     : weatherunderground    : 059ff1dc9fba                             -  enabled
      + system.adapter.web.0                    : web                   : 059ff1dc9fba                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : 059ff1dc9fba                             -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_de4ef275ea5fec118396325f25bfaa52-if00-port0
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Upgrade policy: none
      Installed ioBroker-Adapters
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
      Adapter    "loxone"       : 3.0.1    , installed 3.0.1
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
      Adapter    "sainlogic"    : 0.11.6   , installed 0.11.6
      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
      Objects and States
      Objects:        9366
      States:         11370
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending Updates: 4
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      99         720595906  -
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      99         720594576  -
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      99         720611543  -
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      99         720606906  -
      tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      99         720615133  -
      tcp6       0      0 :::8087                 :::*                    LISTEN      99         720616825  -
      tcp6       0      0 :::8081                 :::*                    LISTEN      99         720590748  -
      tcp6       0      0 :::8082                 :::*                    LISTEN      99         720612076  -
      2025-08-06 19:54:03.173  - info: sainlogic.0 (666) starting. Version 0.11.6 in /opt/iobroker/node_modules/iobroker.sainlogic, node: v22.17.1, js-controller: 7.0.6
      2025-08-06 19:54:03.183  - info: sainlogic.0 (666) Starting Listener
      2025-08-06 19:54:05.162  - info: smartmeter.0 (365) Received 12 values, 7 updated
      2025-08-06 19:54:09.728  - info: shelly.0 (495) [MQTT] Device with client id "shellyplusplugs-e465b841db7c" connected from 192.168.84.88!
      2025-08-06 19:54:10.765  - info: shelly.0 (495) [MQTT] Device with client id "shellypro3em-34987a46f790" connected from 192.168.84.123!
      2025-08-06 19:54:12.351  - info: shelly.0 (495) [MQTT] Device with client id "shellyplus1pm-c82e189576ec" connected from 192.168.84.98!
      2025-08-06 19:54:15.739  - info: shelly.0 (495) [MQTT] Device with client id "shellyplus2pm-2cbcbb380fb4" connected from 192.168.84.130!
      2025-08-06 19:54:17.122  - info: alexa2.0 (272) Initialization Done ...
      2025-08-06 19:54:24.248  - info: shelly.0 (495) [MQTT] Device with client id "shellyplusplugs-e465b8b5e948" connected from 192.168.84.125!
      2025-08-06 19:54:36.159  - info: smartmeter.0 (365) Received 12 values, 7 updated
      2025-08-06 19:54:40.305  - info: luxtronik2.0 (423) State value to set for "luxtronik2.0.Informationen.Anlagenstatus.Betriebszustand" has to be type "number" but received type "string"
      2025-08-06 19:54:48.386  - info: luxtronik2.0 (423) State value to set for "luxtronik2.0.values.flowRate" has to be type "number" but received type "string"
      2025-08-06 19:55:03.995  - info: luxtronik2.0 (423) State value to set for "luxtronik2.0.values.flowRate" has to be type "number" but received type "string"
      2025-08-06 19:55:07.159  - info: smartmeter.0 (365) Received 12 values, 7 updated
      2025-08-06 19:55:38.162  - info: smartmeter.0 (365) Received 12 values, 8 updated
      2025-08-06 19:55:40.287  - info: luxtronik2.0 (423) State value to set for "luxtronik2.0.values.flowRate" has to be type "number" but received type "string"
      2025-08-06 19:55:50.704  - info: luxtronik2.0 (423) State value to set for "luxtronik2.0.values.flowRate" has to be type "number" but received type "string"
      2025-08-06 19:56:09.160  - info: smartmeter.0 (365) Received 12 values, 7 updated
      2025-08-06 19:56:40.157  - info: smartmeter.0 (365) Received 12 values, 7 updated
      2025-08-06 19:56:42.635  - info: luxtronik2.0 (423) State value to set for "luxtronik2.0.values.flowRate" has to be type "number" but received type "string"
      2025-08-06 19:56:58.231  - info: luxtronik2.0 (423) State value to set for "luxtronik2.0.values.flowRate" has to be type "number" but received type "string"
      2025-08-06 19:57:08.711  - info: luxtronik2.0 (423) State value to set for "luxtronik2.0.values.flowRate" has to be type "number" but received type "string"
      2025-08-06 19:57:11.160  - info: smartmeter.0 (365) Received 12 values, 7 updated
      2025-08-06 19:57:34.740  - info: luxtronik2.0 (423) State value to set for "luxtronik2.0.values.flowRate" has to be type "number" but received type "string"
      2025-08-06 19:57:42.157  - info: smartmeter.0 (365) Received 12 values, 7 updated
      iob del iobroker.ring --debug:
      Delete adapter "ring"
      host.059ff1dc9fba Counted 1 adapter for ring
      host.059ff1dc9fba Counted 1 states (system.adapter.ring.*) from states
      host.059ff1dc9fba file ring.admin deleted
      host.059ff1dc9fba object ring deleted
      host.059ff1dc9fba object ring.admin deleted
      host.059ff1dc9fba Deleting 2 object(s).
      host.059ff1dc9fba Deleting 1 state(s).
      Error deleting adapter ring from disk: Cannot find module 'iobroker.ring/io-package.json'
      Require stack:
      - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupInstall.js
      You might have to delete it yourself!
      cd /opt/iobroker && npm i --dry-run
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: ring-client-api@13.1.0
      npm error notsup Not compatible with your version of node/npm: ring-client-api@13.1.0
      npm error notsup Required: {"node":"^18 || ^20"}
      npm error notsup Actual:   {"npm":"10.9.2","node":"v22.17.1"}
      npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2025-08-06T18_01_08_129Z-debug-0.log
      • ChrizC Chriz
        diag:
        ```bash
        Script v.2025-03-08
        *** BASE SYSTEM ***
        Kernel          : x86_64
        Userland        : 64 bit
        Docker          : v11.0.0
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 8
        CEST +0200
        Etc/UTC
        root
        HOME=/root
        GROUPS=root
        iobroker
        HOME=/opt/iobroker
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:            10G        450M         10G
        Total:           23G        5.9G         11G
                5155 M used memory
                 822 M free memory
                   0 M buffer memory
                6905 M swap cache
               10239 M total swap
                 429 M used swap
                9810 M free swap
        *** FILESYSTEM ***
        /var:
        35M     /var/
        33M     /var/lib
        19M     /var/lib/apt
        14M     /var/lib/dpkg
        USB-Devices by-id:
        HINT:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.2
        /usr/bin/npx            10.9.2
        nodejs:
         Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.6.17
        javascript:     8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects:        9366
        States:         11370
        Pending Updates: 4
        Require stack:
        #204
        @chriz
        Installier mal (temporär) ring@6.4.0 auus dem Beta-Repo.
        Falls das sauber funktioniert kannste den dann direkt wieder deinstallieren.
          @chriz
          ChrizC Offline
          ChrizC Offline
          Chriz
          #205
          wie mach ich das? sorry bin für einige Dinge zu laienhaft unterwegs :(
          • ChrizC Chriz
            #206
            @chriz
              @chriz
              ChrizC Offline
              ChrizC Offline
              Chriz
              #207
              der adapter zeigt ein ähnliches Verhalten wie der erste Versuch das EVCC zu updaten.
              es kommt
              $ iobroker upload ring --debug
              upload [25] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/admin.d.ts admin.d.ts video/mp2t
              upload [20] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/de.json i18n/de.json application/json
              upload [19] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/en.json i18n/en.json application/json
              upload [18] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/es.json i18n/es.json application/json
              upload [17] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/fr.json i18n/fr.json application/json
              upload [16] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/it.json i18n/it.json application/json
              upload [15] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/nl.json i18n/nl.json application/json
              upload [14] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/pl.json i18n/pl.json application/json
              upload [13] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/pt.json i18n/pt.json application/json
              upload [12] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/ru.json i18n/ru.json application/json
              upload [11] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/uk.json i18n/uk.json application/json
              upload [10] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
              upload [9] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/index_m.html index_m.html text/html
              upload [8] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/jsonConfig.json jsonConfig.json application/json
              upload [7] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/preferences-desktop-notification-bell-3.png preferences-desktop-notification-bell-3.png image/png
              upload [6] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/preferences-system-login.png preferences-system-login.png image/png
              upload [5] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/ring.png ring.png image/png
              upload [4] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/style.css style.css text/css
              upload [3] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/tab_m.html tab_m.html text/html
              upload [2] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/tab_m.js tab_m.js application/javascript
              upload [1] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/tsconfig.json tsconfig.json application/json
              upload [0] ring.admin /opt/iobroker/node_modules/iobroker.ring/admin/words.js words.js application/javascript
              Updating objects from io-package.json for adapter "ring" with version "6.4.0"
              Process exited with code 0
              Aber er taucht nicht in meinen Adaptern auf.
              komischerweise wird mir nun auch angezeigt das ich EVCC noch installiert hätte.
              aber auch das ist nicht der Fall, taucht nicht bei Instanzen auf.
              • ChrizC Chriz
                es kommt
                #208
                @chriz
                cd /opt/iobroker && npm ls
                  @chriz
                  ChrizC Offline
                  ChrizC Offline
                  Chriz
                  #209
                  da taucht er tatsächlich auf:
                  ├── @sentry/node@6.19.7
                  ├── iobroker.admin@7.6.17
                  ├── iobroker.alexa2@3.27.3
                  ├── iobroker.backitup@3.3.5
                  ├── iobroker.denon@1.15.12
                  ├── iobroker.discovery@5.0.0
                  ├── iobroker.homeconnect@1.4.3
                  ├── iobroker.icons-mfd-svg@1.2.0
                  ├── iobroker.influxdb@4.0.2
                  ├── iobroker.iot@3.3.0
                  ├── iobroker.javascript@8.9.2
                  ├── iobroker.js-controller@7.0.6
                  ├── iobroker.lgtv@2.4.0
                  ├── iobroker.loxone@3.0.1
                  ├── iobroker.luxtronik2@0.3.1 (git+ssh://git@github.com/UncleSamSwiss/ioBroker.luxtronik2.git#e507d3d188440a4e8cd394648a5b20d75ce9cbb0)
                  ├── iobroker.mqtt@6.1.2
                  ├── iobroker.nuki-extended@2.7.0
                  ├── iobroker.octoprint@5.1.0
                  ├── iobroker.ring@6.4.0
                  ├── iobroker.sainlogic@0.11.6
                  ├── iobroker.shelly@10.1.0
                  ├── iobroker.signal-cmb@0.3.0
                  ├── iobroker.simple-api@2.8.0
                  ├── iobroker.smartmeter@3.4.0
                  ├── iobroker.socketio@6.7.1
                  ├── iobroker.tr-064@4.3.0
                  ├── iobroker.tuya@3.16.0
                  ├── iobroker.vis-history@1.0.0
                  ├── iobroker.vis-hqwidgets@1.5.1
                  ├── iobroker.vis-jqui-mfd@1.1.1
                  ├── iobroker.vis-justgage@2.1.7
                  ├── iobroker.vis-material-advanced@1.7.4
                  ├── iobroker.vis-metro@1.2.0
                  ├── iobroker.vis-timeandweather@1.2.2
                  ├── iobroker.vis-weather@2.5.12
                  ├── iobroker.vis@1.5.6
                  ├── iobroker.vw-connect@0.0.67
                  ├── iobroker.weatherunderground@3.7.0
                  ├── iobroker.web@7.0.8
                  ├── iobroker.ws@2.6.2
                  ├── iobroker.zigbee@2.0.5
                  └── luxtronik2@2.4.0
                  • ChrizC Chriz
                    #210
                    @chriz sagte in Neuer Adapter ioBroker.evcc:
                    Weil GUIs dich anlügen.
                    iob del ring --debug
                      ChrizC Offline
                      ChrizC Offline
                      Chriz
                      #211
                      @thomas-braun said in Neuer Adapter ioBroker.evcc:
                      oh na das lief jetzt komplett durch.
                      host.059ff1dc9fba Counted 1 meta of ring
                      host.059ff1dc9fba Deleting 3 object(s).
                      removed 139 packages in 9s
                      153 packages are looking for funding
                        run `npm fund` for details
                      AUch in der Liste cd /opt/iobroker && npm ls taucht er nicht mehr auf.
                      • ChrizC Chriz
                        #212
                        Ja, jetzt ist er ja auch sauber entfernt worden.
                        Fummel da nicht grobschlächtig im Dateisystem mit irgendwelchen Löschaktionen herum.
                        Sowas läuft unter Linux eigentlich immer über einen entsprechenden Paketmanager (z. B. dpkg, apt, pacman, npm etc.).
                        Die tragen die Installationen dann auch richtig in den jeweiligen Datenbanken ein und auch wieder aus.
                          ChrizC Offline
                          ChrizC Offline
                          Chriz
                          #213
                          okay ich werde es mir zu herzen nehmen ;)
                          Meinst du ich kann jetzt nochmal versuchen den EVCC Adapter zu isntallieren oder sollte ich vorher noch was anderes machen?
                          • ChrizC Chriz
                            #214
                            @chriz
                            iob add evcc --debug
                            mal versuchen. Sollte dann jetzt eigentlich durchlaufen.
                              @chriz
                              ChrizC Offline
                              ChrizC Offline
                              Chriz
                              #215
                              vielen lieben dank für die großartige Hilfe :)
                              Nun funzt alles.
                              • H Offline
                                huzzel
                                #216
                                Mal ne Frage:
                                Gibt es auch eine Tagesstatiskik?
                                In evcc.0.status.statistics ist sie ja leider nicht enthalten.
                                • H huzzel
                                  Mal ne Frage:
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #217
                                  @huzzel sagte in Neuer Adapter ioBroker.evcc:
                                  gibt den die API von evcc diese aus ??
                                  H oberfraggerO 2 Antworten Letzte Antwort
                                  • arteckA arteck
                                    huzzel
                                    #218
                                    @arteck unter Ladevorgänge gibt es zumindest für jeden Tag einen Balken. In wieweit das über die API zugänglich ist, habe ich keine Ahnung
                                    • arteckA arteck
                                      oberfraggerO Offline
                                      oberfragger
                                      #219
                                      @huzzel Der Datenpunkt "evcc.0.loadpoint.1.status.sessionEnergy" ist ein Sessionzähler.
                                      Jedes mal wenn du den Stecker abnimmst bzw. ransteckst, startet die Session neu. Das siehst du auch ganz gt auf den Daten.
                                      Da gibts mehrere "0" Werte pro Tag. Halt immer wenn der Stecker abgesteckt wurde.
                                      Die Tagesstatistik wird m.E. in der internen EVCC-Datenbank aggregiert. So eine Tagesstatistik hätte ich auch gern, da müsste ich mir dann per Script bauen. Sollte kein Hexenwerk sein.
                                      Wenn man dieses in den Adapter integriert, müsste man natürlich den:
                                      Tageswert pro Wallbox und den
                                      Tageswert pro Auto darstellen.
                                      Es gibt sicher Nutzer, die 2 Autos an der gleichen Wallbox laden.
                                      arteckA H 2 Antworten Letzte Antwort
                                      • oberfraggerO oberfragger
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #220
                                        @oberfragger sagte in Neuer Adapter ioBroker.evcc:
                                        es soll Leute geben die mehrere >2 Autos an der gleichen Wallbox laden.. :-)
                                          huzzel
                                          #221
                                          @oberfragger Mir persönlich geht es nur um die PV-Energie, die in das/die Autos geht (ich habe aber nur eines ;) ) für meine Tagesstatistik, wo meine PV-Energie hingeht.
                                          Aktuell habe ich mir mit der sessionEnergy was gebastelt, was erstmal funtkioniert, aber nicht alle Edge-Cases abfängt (die bei mir eigentlich auch nicht auftreten sollten). Aber ich habe halt gedacht, wenn es schon bei der Statiskik die Werte für die letzten 30 Tage, letztes Jahr und total gibt, sollte es für einen Tag keinen großen Aufwand machen.
