  4. JavaScript
  5. E3DC Hauskraftwerk steuern
    apollon77A
3.6k Beiträge 74 Kommentatoren 2.5m Aufrufe 65 Beobachtet
  • A ArnoD
    @azzkikrboy
    Nein, aber hier wird das bereits diskutiert: Github evcc
    Eventuell findet da jemand eine Lösung.
    Nachtrag: Mit den normalen E3DC Einstellungen und über einen modbusproxy hast du es schon probiert?
    So sehen meine Einstellungen aus:
    network:
      schema: http
      host: 192.168.1.56
      port: 7070
    log: info
    levels:
      site: debug
      lp-1: debug
      cache: error
      db: error
      bmw: debug
    interval: 10s # control cycle interval.
    # trial token, valid until 2025-05-26
    sponsortoken: *************************************
    modbusproxy:
      - port: 502 # Port modbusproxy
        uri: ***.***.***.***:502 			# IP und Port Wallbox
        readonly: true # Schreibzugriffe blockieren
    meters:
      - name: e3dc-grid
        type: template
        template: e3dc-rscp
        usage: grid
        host: ***.***.***.*** 				#IP E3DC
        port: 5033
        user: *************** 				# User E3DC Portal
        password: ***********            	# Passwort E3DC Portal
        key: ****************              	# Passwort RSCP
      - name: e3dc-pv
        type: template
        template: e3dc-rscp
        usage: pv
        port: 5033
      - name: e3dc-battery
        type: template
        template: e3dc-rscp
        usage: battery
        port: 5033
    chargers:
      - name: EasyConnect
        type: template
        template: phoenix-ev-eth
        modbus: tcpip
        host: ***.***.***.*** 				# IP Wallbox
        port: 502
    # site describes the EVU connection, PV and home battery
    site:
      title: Home # display name for UI
      meters:
        grid: e3dc-grid # grid meter
        pv:
          - e3dc-pv # list of pv inverters/ meters
        battery:
          - e3dc-battery # list of battery meters
      residualPower: 100 # additional household usage margin
    # loadpoint describes the charger, charge meter and connected vehicle
    loadpoints:
      - title: Garage
        charger: EasyConnect
        mode: pv
        phases: 3
        mincurrent: 6
        maxcurrent: 20
        priority: 0 # relative priority for concurrent charging in PV mode with multiple loadpoints (higher values have higher priority)
        soc:
          poll:
            mode: charging
            interval: 60m
          estimate: true # set false to disable interpolating between api updates (not recommended)
        enable: # pv mode enable behavior
          delay: 1m # threshold must be exceeded for this long
          threshold: 0 # grid power threshold (in Watts, negative=export). If zero, export must exceed minimum charge power to enable
        disable: # pv mode disable behavior
          delay: 3m # threshold must be exceeded for this long
          threshold: 0 # maximum import power (W)
    # tariffs are the fixed or variable tariffs
    tariffs:
      currency: EUR # three letter ISO-4217 currency code (default EUR)
      grid:
        # either static grid price (or price zones)
        type: template
        template: tibber
        token: "****************************" # Access Token
      feedin:
        type: fixed
        price: 0.11 # EUR/kWh
      co2:
        # co2 tariff provides co2 intensity forecast and is for co2-optimized target charging if no variable grid tariff is specified
        # type: template
        # template: grünstromindex # GrünStromIndex (Germany only)
        # zip: <zip>
        # see: https://docs.evcc.io/en/docs/tariffs#co-forecast
      solar:
        - type: template
          template: solcast
          site: ****************
          token: ******************************** # Solcast API Token
          interval: 6h # optional
        - type: template
          template: solcast
    # mqtt message broker
    mqtt:
      # broker: localhost:1883
      # topic: evcc # root topic for publishing, set empty to disable
      # user:
      # password:
    messaging:
      events:
        start: # charge start event
          title: Charge started
          msg: Started charging in "${mode}" mode
        stop: # charge stop event
          title: Charge finished
          msg: Finished charging ${chargedEnergy:%.1fk}kWh in ${chargeDuration}.
        connect: # vehicle connect event
          title: Car connected
          msg: "Car connected at ${pvPower:%.1fk}kW PV"
        disconnect: # vehicle connected event
          title: Car disconnected
          msg: Car disconnected after ${connectedDuration}
        soc: # vehicle soc update event
          title: Soc updated
          msg: Battery charged to ${vehicleSoc:%.0f}%
        guest: # vehicle could not be identified
          title: Unknown vehicle
          msg: Unknown vehicle, guest connected?
      services:
      # - type: pushover
      #   app: # app id
      #   recipients:
      #   - # list of recipient ids
      # - type: telegram
      #   token: # bot id
      #   chats:
      #   - # list of chat ids
      # - type: email
      #   uri: smtp://<user>:<password>@<host>:<port>/?fromAddress=<from>&toAddresses=<to>
      # - type: ntfy
      #   uri: https://<host>/<topics>
      #   priority: <priority>
      #   tags: <tags>
    azzkikrboyA
    azzkikrboyA
    azzkikrboy
    #3357
    @arnod sagte in E3DC Hauskraftwerk steuern:
    Github evcc
    ja, den Thread habe ich auch schon gefunden, aber da geht es wohl nicht weiter. Ich klinke mich da mal mit ein.
    Ich habe es mal mit der EasyConnect config (identisch wie bei dir, incl. proxy) versucht und bekomme folgenden Fehler:
    status: modbus: exception '4' (server device failure), function '1'
    status: modbus: exception '4' (server device failure), function '4'
    • A
      A
      ArnoD
      #3358
      Neue Version TibberSkript auf GitHub hochgeladen.
      Version: 1.3.17
      Änderungen:
      • Durch Ändern der Objekt-ID 0_userdata.0.Charge_Control.History.PrognoseAuto_kWh auf String, ab der Charge-Control Version 1.5.17 muss auch das Tibber Skript angepasst werden.
      P 1 Antwort Letzte Antwort
      • A ArnoD
        Version: 1.3.17
        Änderungen:
        P
        P
        psrelax
        #3359
        @arnod
        Anscheinend wird immer um 00:00 Uhr für ca. 2 Minuten die Entladesperre gesetzt.
        Habe keine genauen Logs. Vielleicht kannst du auch bei dir mal schauen, ob das auch bei dir so ist.
        Wenn du detaillierte Logs brauchst, schalte ich sie ein.
        javascript.0
        2025-07-06 00:02:01.506	warn	script.js.E3DC_ChargeControl.Charge_Control: -==== ⚠️ Tibber output signal BatterieEntladesperre wurde in false geändert ====-
        javascript.0
        2025-07-06 00:00:02.778	warn	script.js.E3DC_ChargeControl.Charge_Control: -==== ⚠️ Tibber output signal BatterieEntladesperre wurde in true geändert ====-
        • P psrelax
          @arnod
          javascript.0
          javascript.0
          A
          A
          ArnoD
          #3360
          @psrelax
          Habe bei mir die LOG der letzten Tage geprüft und konnte bei mir nichts feststellen.
          Wenn es jeden Tag bzw. Nacht passiert, dann bitte mal LOG einschalten.
          • A ArnoD
            @psrelax
            P
            P
            psrelax
            #3361
            Hier bitte :-)
            2025-07-06 23:59:00.327  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ************************************************************************************
            2025-07-06 23:59:00.327  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerTarget = []
            2025-07-06 23:59:00.327  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerState = []
            2025-07-06 23:59:00.327  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerObjektID = []
            2025-07-06 23:59:00.327  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** minStrompreis_48h = 0.17
            2025-07-06 23:59:00.327  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** batterieKapazitaet_kWh = 17
            2025-07-06 23:59:00.327  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Batterie_SOC = 49
            2025-07-06 23:59:00.327  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Bat_W = -1041
            2025-07-06 23:59:00.327  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Grid = 7
            2025-07-06 23:59:00.327  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** prognoseLadezeitBatterie = 1
            2025-07-06 23:59:00.327  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** reichweiteBatterie = 6:53 h
            2025-07-06 23:59:00.327  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie angewählt = true
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Nettostrompreis Batterie = 0.1057
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie = 0.1201
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Aktueller Preis Tibber = 0.2948
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Preis Tibber mit Ladeverluste = 0.3505
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].endLocale = 8.7.2025, 00:00:00
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].startLocale = 7.7.2025, 17:00:00
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].Type = peak
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].endLocale = 7.7.2025, 17:00:00
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].startLocale = 7.7.2025, 14:00:00
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].Type = high
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.endLocale = 7.7.2025, 14:00:00
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.startLocale = 6.7.2025, 16:00:00
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.Type = peak
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert Spitzenstrompreis = 0.2386
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert hoher Strompreis = 0.21
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert niedriger Strompreis = 0.1057
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** schneeBedeckt = false
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung heute = 53.21 kWh
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung morgen = 44.31 kWh
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** pvLeistungAusreichend = false
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** bReichweiteSunrise = false
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** eAutoLaden = false
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieEntladenSperren = false
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieLaden = false
            2025-07-06 23:59:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** battSperrePrio = false
            2025-07-06 23:59:00.329  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Status = Aktuell Strompreis zu hoch, es wird nicht geladen (aktive Phase: peak)
            2025-07-06 23:59:00.329  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** ProgrammAblauf = 27,1,18,18/4,19,22,32,19,10,15,15/5,30,
            2025-07-06 23:59:00.329  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: *******************  Debug LOG Tibber Skript Version 1.3.17 *******************
            2025-07-06 23:59:03.020  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
            2025-07-06 23:59:03.020  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
            2025-07-06 23:59:03.020  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
            2025-07-06 23:59:03.020  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
            2025-07-06 23:59:03.020  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
            2025-07-06 23:59:03.020  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
            2025-07-06 23:59:03.020  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
            2025-07-06 23:59:03.020  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
            2025-07-06 23:59:03.020  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
            2025-07-06 23:59:03.021  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
            2025-07-06 23:59:03.021  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
            2025-07-06 23:59:03.021  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
            2025-07-06 23:59:03.021  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
            2025-07-06 23:59:03.021  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
            2025-07-06 23:59:03.021  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
            2025-07-06 23:59:03.082  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
            2025-07-06 23:59:03.131  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
            2025-07-06 23:59:03.151  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
            2025-07-06 23:59:03.160  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
            2025-07-06 23:59:03.167  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
            2025-07-06 23:59:03.176  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
            2025-07-06 23:59:03.203  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
            2025-07-06 23:59:03.241  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
            2025-07-06 23:59:03.254  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
            2025-07-06 23:59:03.255  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
            2025-07-06 23:59:03.257  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Sonntag: 942 Wh
            2025-07-06 23:59:03.259  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 942 Wh
            2025-07-06 23:59:03.318  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 1024W
            2025-07-06 23:59:03.322  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = -1035 W
            2025-07-06 23:59:03.343  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
            2025-07-06 23:59:03.343  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
            2025-07-06 23:59:03.405  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 49 %
            2025-07-06 23:59:03.405  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
            2025-07-06 23:59:03.405  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
            2025-07-06 23:59:03.405  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
            2025-07-06 23:59:03.406  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
            2025-07-06 23:59:03.483  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
            2025-07-06 23:59:03.484  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
            2025-07-06 23:59:03.484  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
            2025-07-06 23:59:03.484  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
            2025-07-06 23:59:03.484  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,7,10,
            2025-07-06 23:59:12.004  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
            2025-07-06 23:59:12.004  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
            2025-07-06 23:59:12.004  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
            2025-07-06 23:59:12.004  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
            2025-07-06 23:59:12.004  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
            2025-07-06 23:59:12.004  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
            2025-07-06 23:59:12.005  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
            2025-07-06 23:59:12.005  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
            2025-07-06 23:59:12.005  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
            2025-07-06 23:59:12.005  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
            2025-07-06 23:59:12.005  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
            2025-07-06 23:59:12.005  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
            2025-07-06 23:59:12.005  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
            2025-07-06 23:59:12.005  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
            2025-07-06 23:59:12.005  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
            2025-07-06 23:59:12.048  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
            2025-07-06 23:59:12.050  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
            2025-07-06 23:59:12.052  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
            2025-07-06 23:59:12.053  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
            2025-07-06 23:59:12.055  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
            2025-07-06 23:59:12.057  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
            2025-07-06 23:59:12.059  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
            2025-07-06 23:59:12.060  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
            2025-07-06 23:59:12.062  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
            2025-07-06 23:59:12.063  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
            2025-07-06 23:59:12.064  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Sonntag: 942 Wh
            2025-07-06 23:59:12.064  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 942 Wh
            2025-07-06 23:59:12.108  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 1047W
            2025-07-06 23:59:12.110  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = -1044 W
            2025-07-06 23:59:12.113  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
            2025-07-06 23:59:12.114  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
            2025-07-06 23:59:12.155  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 49 %
            2025-07-06 23:59:12.155  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
            2025-07-06 23:59:12.155  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
            2025-07-06 23:59:12.155  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
            2025-07-06 23:59:12.155  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
            2025-07-06 23:59:12.199  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
            2025-07-06 23:59:12.199  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
            2025-07-06 23:59:12.199  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
            2025-07-06 23:59:12.199  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
            2025-07-06 23:59:12.199  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,7,10,
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
            2025-07-06 23:59:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
            2025-07-06 23:59:18.087  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
            2025-07-06 23:59:18.088  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
            2025-07-06 23:59:18.090  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
            2025-07-06 23:59:18.091  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
            2025-07-06 23:59:18.092  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
            2025-07-06 23:59:18.093  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
            2025-07-06 23:59:18.094  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
            2025-07-06 23:59:18.095  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
            2025-07-06 23:59:18.097  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
            2025-07-06 23:59:18.098  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
            2025-07-06 23:59:18.099  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Sonntag: 942 Wh
            2025-07-06 23:59:18.099  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 942 Wh
            2025-07-06 23:59:18.141  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 1043W
            2025-07-06 23:59:18.142  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = -1041 W
            2025-07-06 23:59:18.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
            2025-07-06 23:59:18.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
            2025-07-06 23:59:18.187  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 49 %
            2025-07-06 23:59:18.187  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
            2025-07-06 23:59:18.187  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
            2025-07-06 23:59:18.187  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
            2025-07-06 23:59:18.187  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
            2025-07-06 23:59:18.229  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
            2025-07-06 23:59:18.229  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
            2025-07-06 23:59:18.229  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
            2025-07-06 23:59:18.229  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
            2025-07-06 23:59:18.229  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,7,10,
            2025-07-06 23:59:24.286  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
            2025-07-06 23:59:24.286  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
            2025-07-06 23:59:24.286  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
            2025-07-06 23:59:24.286  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
            2025-07-06 23:59:24.286  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
            2025-07-06 23:59:24.286  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
            2025-07-06 23:59:24.287  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
            2025-07-06 23:59:24.287  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
            2025-07-06 23:59:24.287  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
            2025-07-06 23:59:24.287  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
            2025-07-06 23:59:24.287  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
            2025-07-06 23:59:24.287  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
            2025-07-06 23:59:24.287  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
            2025-07-06 23:59:24.287  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
            2025-07-06 23:59:24.287  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
            2025-07-06 23:59:24.330  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
            2025-07-06 23:59:24.332  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
            2025-07-06 23:59:24.333  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
            2025-07-06 23:59:24.334  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
            2025-07-06 23:59:24.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
            2025-07-06 23:59:24.336  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
            2025-07-06 23:59:24.337  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
            2025-07-06 23:59:24.338  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
            2025-07-06 23:59:24.340  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
            2025-07-06 23:59:24.341  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
            2025-07-06 23:59:24.341  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Sonntag: 942 Wh
            2025-07-06 23:59:24.341  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 942 Wh
            2025-07-06 23:59:24.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 1043W
            2025-07-06 23:59:24.386  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = -1044 W
            2025-07-06 23:59:24.388  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
            2025-07-06 23:59:24.388  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
            2025-07-06 23:59:24.429  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 49 %
            2025-07-06 23:59:24.429  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
            2025-07-06 23:59:24.429  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
            2025-07-06 23:59:24.429  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
            2025-07-06 23:59:24.429  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
            2025-07-06 23:59:24.471  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
            2025-07-06 23:59:24.471  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
            2025-07-06 23:59:24.471  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
            2025-07-06 23:59:24.471  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
            2025-07-06 23:59:24.471  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,7,10,
            2025-07-06 23:59:33.153  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
            2025-07-06 23:59:33.153  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
            2025-07-06 23:59:33.153  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
            2025-07-06 23:59:33.153  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
            2025-07-06 23:59:33.153  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
            2025-07-06 23:59:33.153  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
            2025-07-06 23:59:33.153  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
            2025-07-06 23:59:33.153  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
            2025-07-06 23:59:33.153  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
            2025-07-06 23:59:33.153  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
            2025-07-06 23:59:33.154  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
            2025-07-06 23:59:33.154  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
            2025-07-06 23:59:33.154  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
            2025-07-06 23:59:33.154  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
            2025-07-06 23:59:33.154  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
            2025-07-06 23:59:33.264  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
            2025-07-06 23:59:33.468  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
            2025-07-06 23:59:33.909  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
            2025-07-06 23:59:34.222  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
            2025-07-06 23:59:34.263  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
            2025-07-06 23:59:34.265  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
            2025-07-06 23:59:34.266  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
            2025-07-06 23:59:34.267  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
            2025-07-06 23:59:34.268  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
            2025-07-06 23:59:34.269  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
            2025-07-06 23:59:34.270  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Sonntag: 942 Wh
            2025-07-06 23:59:34.270  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 942 Wh
            2025-07-06 23:59:34.312  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 1045W
            2025-07-06 23:59:34.313  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = -1044 W
            2025-07-06 23:59:34.315  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
            2025-07-06 23:59:34.315  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
            2025-07-06 23:59:34.356  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 49 %
            2025-07-06 23:59:34.356  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
            2025-07-06 23:59:34.356  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
            2025-07-06 23:59:34.356  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
            2025-07-06 23:59:34.356  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
            2025-07-06 23:59:34.398  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
            2025-07-06 23:59:34.398  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
            2025-07-06 23:59:34.398  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
            2025-07-06 23:59:34.398  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
            2025-07-06 23:59:34.398  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,7,10,
            2025-07-06 23:59:42.042  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
            2025-07-06 23:59:42.043  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
            2025-07-06 23:59:42.087  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
            2025-07-06 23:59:42.089  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
            2025-07-06 23:59:42.090  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
            2025-07-06 23:59:42.091  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
            2025-07-06 23:59:42.092  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
            2025-07-06 23:59:42.093  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
            2025-07-06 23:59:42.095  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
            2025-07-06 23:59:42.097  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
            2025-07-06 23:59:42.098  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
            2025-07-06 23:59:42.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
            2025-07-06 23:59:42.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Sonntag: 942 Wh
            2025-07-06 23:59:42.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 942 Wh
            2025-07-06 23:59:42.143  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 1046W
            2025-07-06 23:59:42.144  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = -1044 W
            2025-07-06 23:59:42.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
            2025-07-06 23:59:42.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
            2025-07-06 23:59:42.187  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 49 %
            2025-07-06 23:59:42.187  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
            2025-07-06 23:59:42.187  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
            2025-07-06 23:59:42.187  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
            2025-07-06 23:59:42.187  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
            2025-07-06 23:59:42.229  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
            2025-07-06 23:59:42.229  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
            2025-07-06 23:59:42.229  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
            2025-07-06 23:59:42.229  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
            2025-07-06 23:59:42.229  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,7,10,
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
            2025-07-06 23:59:48.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
            2025-07-06 23:59:48.087  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
            2025-07-06 23:59:48.088  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
            2025-07-06 23:59:48.091  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
            2025-07-06 23:59:48.092  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
            2025-07-06 23:59:48.093  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
            2025-07-06 23:59:48.094  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
            2025-07-06 23:59:48.096  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
            2025-07-06 23:59:48.097  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
            2025-07-06 23:59:48.098  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
            2025-07-06 23:59:48.101  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
            2025-07-06 23:59:48.101  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Sonntag: 942 Wh
            2025-07-06 23:59:48.101  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 942 Wh
            2025-07-06 23:59:48.144  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 1047W
            2025-07-06 23:59:48.145  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = -1050 W
            2025-07-06 23:59:48.153  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
            2025-07-06 23:59:48.153  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
            2025-07-06 23:59:48.194  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 49 %
            2025-07-06 23:59:48.194  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
            2025-07-06 23:59:48.194  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
            2025-07-06 23:59:48.195  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
            2025-07-06 23:59:48.195  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
            2025-07-06 23:59:48.236  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
            2025-07-06 23:59:48.236  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
            2025-07-06 23:59:48.236  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
            2025-07-06 23:59:48.236  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
            2025-07-06 23:59:48.236  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,7,10,
            2025-07-06 23:59:54.086  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
            2025-07-06 23:59:54.086  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
            2025-07-06 23:59:54.086  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
            2025-07-06 23:59:54.086  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
            2025-07-06 23:59:54.086  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
            2025-07-06 23:59:54.086  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
            2025-07-06 23:59:54.086  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
            2025-07-06 23:59:54.087  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
            2025-07-06 23:59:54.087  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
            2025-07-06 23:59:54.087  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
            2025-07-06 23:59:54.087  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
            2025-07-06 23:59:54.087  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
            2025-07-06 23:59:54.087  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
            2025-07-06 23:59:54.087  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
            2025-07-06 23:59:54.087  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
            2025-07-06 23:59:54.158  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
            2025-07-06 23:59:54.185  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
            2025-07-06 23:59:54.210  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
            2025-07-06 23:59:54.313  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
            2025-07-06 23:59:54.361  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
            2025-07-06 23:59:54.379  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
            2025-07-06 23:59:54.427  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
            2025-07-06 23:59:54.497  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
            2025-07-06 23:59:54.551  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
            2025-07-06 23:59:54.651  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
            2025-07-06 23:59:54.652  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Sonntag: 942 Wh
            2025-07-06 23:59:54.652  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 942 Wh
            2025-07-06 23:59:54.878  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 1031W
            2025-07-06 23:59:54.880  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = -1029 W
            2025-07-06 23:59:54.922  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
            2025-07-06 23:59:54.922  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
            2025-07-06 23:59:54.963  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 49 %
            2025-07-06 23:59:54.963  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
            2025-07-06 23:59:54.963  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
            2025-07-06 23:59:54.963  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
            2025-07-06 23:59:54.963  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
            2025-07-06 23:59:55.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
            2025-07-06 23:59:55.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
            2025-07-06 23:59:55.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
            2025-07-06 23:59:55.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
            2025-07-06 23:59:55.006  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,7,10,
            2025-07-07 00:00:00.135  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
            2025-07-07 00:00:00.139  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
            2025-07-07 00:00:00.139  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
            2025-07-07 00:00:00.139  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
            2025-07-07 00:00:00.139  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
            2025-07-07 00:00:00.139  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
            2025-07-07 00:00:00.139  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
            2025-07-07 00:00:00.139  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
            2025-07-07 00:00:00.140  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
            2025-07-07 00:00:00.140  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
            2025-07-07 00:00:00.140  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
            2025-07-07 00:00:00.140  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
            2025-07-07 00:00:00.140  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
            2025-07-07 00:00:00.140  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
            2025-07-07 00:00:00.140  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
            2025-07-07 00:00:00.224  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
            2025-07-07 00:00:00.268  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
            2025-07-07 00:00:00.316  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
            2025-07-07 00:00:00.320  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
            2025-07-07 00:00:00.328  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
            2025-07-07 00:00:00.369  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
            2025-07-07 00:00:00.371  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
            2025-07-07 00:00:00.375  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
            2025-07-07 00:00:00.416  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
            2025-07-07 00:00:00.419  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
            2025-07-07 00:00:00.420  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 954 Wh
            2025-07-07 00:00:00.420  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 954 Wh
            2025-07-07 00:00:00.484  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: -==== ?? Tibber output signal BatterieEntladesperre wurde in true geändert ====-
            2025-07-07 00:00:00.575  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ************************************************************************************
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerTarget = []
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerState = []
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerObjektID = []
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** minStrompreis_48h = 0.17
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** batterieKapazitaet_kWh = 17
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Batterie_SOC = 49
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Bat_W = -1023
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Grid = -7
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** prognoseLadezeitBatterie = 1
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** reichweiteBatterie = 6:53 h
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie angewählt = true
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Nettostrompreis Batterie = 0.1057
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie = 0.1201
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Aktueller Preis Tibber = null
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Preis Tibber mit Ladeverluste = 0.3505
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].endLocale = 8.7.2025, 00:00:00
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].startLocale = 7.7.2025, 17:00:00
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].Type = peak
            2025-07-07 00:00:00.576  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].endLocale = 7.7.2025, 17:00:00
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].startLocale = 7.7.2025, 14:00:00
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].Type = high
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.endLocale = 7.7.2025, 14:00:00
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.startLocale = 6.7.2025, 16:00:00
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.Type = peak
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert Spitzenstrompreis = 0.2386
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert hoher Strompreis = 0.21
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert niedriger Strompreis = 0.1057
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** schneeBedeckt = false
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung heute = 44.31 kWh
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung morgen = 32.54 kWh
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** pvLeistungAusreichend = false
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** bReichweiteSunrise = false
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** eAutoLaden = false
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieEntladenSperren = true
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieLaden = false
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** battSperrePrio = false
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Status = Aktuell Strompreis zu hoch, es wird nicht geladen (aktive Phase: peak)
            2025-07-07 00:00:00.577  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** ProgrammAblauf = 27,1,18,18/4,19,22,32,19,10,15,15/5,30,
            2025-07-07 00:00:00.577  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: *******************  Debug LOG Tibber Skript Version 1.3.17 *******************
            2025-07-07 00:00:30.295  - warn: javascript.0 (196) script.js.Tibber.Preis_Alexa_Abfrage_Erzeugung: ladescript2
            2025-07-07 00:01:00.245  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: -==== ?? Tibber output signal BatterieEntladesperre wurde in false geändert ====-
            2025-07-07 00:01:00.334  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ************************************************************************************
            2025-07-07 00:01:00.334  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerTarget = ["2025-07-06T23:00:00.000Z","2025-07-07T04:00:00.000Z"]
            2025-07-07 00:01:00.334  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerState = [true,false]
            2025-07-07 00:01:00.334  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerObjektID = ["Entladesperre","Entladesperre"]
            2025-07-07 00:01:00.334  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** minStrompreis_48h = 0.2233
            2025-07-07 00:01:00.334  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** batterieKapazitaet_kWh = 17
            2025-07-07 00:01:00.334  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Batterie_SOC = 49
            2025-07-07 00:01:00.334  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Bat_W = 0
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Grid = 738
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** prognoseLadezeitBatterie = 1
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** reichweiteBatterie = 6:26 h
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie angewählt = true
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Nettostrompreis Batterie = 0.1057
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie = 0.1201
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Aktueller Preis Tibber = 0.3044
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Preis Tibber mit Ladeverluste = 0.3459
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].endLocale = 7.7.2025, 13:00:00
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].startLocale = 7.7.2025, 10:00:00
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].Type = high
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].endLocale = 7.7.2025, 10:00:00
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].startLocale = 7.7.2025, 06:00:00
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].Type = peak
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.endLocale = 7.7.2025, 06:00:00
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.startLocale = 7.7.2025, 00:00:00
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.Type = high
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert Spitzenstrompreis = 0.3068
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert hoher Strompreis = 0.27
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert niedriger Strompreis = 0.1057
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** schneeBedeckt = false
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung heute = 44.31 kWh
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung morgen = 32.54 kWh
            2025-07-07 00:01:00.335  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** pvLeistungAusreichend = false
            2025-07-07 00:01:00.336  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** bReichweiteSunrise = false
            2025-07-07 00:01:00.336  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** eAutoLaden = false
            2025-07-07 00:01:00.336  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieEntladenSperren = false
            2025-07-07 00:01:00.336  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieLaden = false
            2025-07-07 00:01:00.336  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** battSperrePrio = false
            2025-07-07 00:01:00.336  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Status = Batterie sperre von 01:00 Uhr bis 06:00 Uhr um Peakphase zu überbrücken (aktive Phase: high)
            2025-07-07 00:01:00.336  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** ProgrammAblauf = 27,1,18,18/4,19,22,32,11,11/3,11/4,31,29,29/3,29,29/3,
            2025-07-07 00:01:00.336  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: *******************  Debug LOG Tibber Skript Version 1.3.17 *******************
            • P psrelax
              @arnod sagte in E3DC Hauskraftwerk steuern:
              Hier bitte :-)
              A
              A
              ArnoD
              #3362
              @psrelax
              Problem ist, dass um 0:00 Uhr die Daten nicht eingelesen werden können.
              Deswegen ist aktueller Preis Tibber = null und dann wird das Entladen der Batterie gesperrt.
              Ein Grund könnte sein, dass genau um diese Zeit die Werte vom Tibberlink Adapter aktualisiert werden und deswegen vom TibberSkript nicht abgerufen werden können.
              Da das TibberSkript jede Minute einmal durchlaufen wird, dauert es genau 1 min. bis die Werte wieder stimmen.
              Ich muss mir das mal ansehen, ob ich das abfangen kann.
              P 1 Antwort Letzte Antwort
              • A ArnoD
                @psrelax
                P
                P
                psrelax
                #3363
                @arnod
                Super, danke.
                Ich hätte noch eine Bitte. Wir hatten das Thema ja schon einmal glaub ich aber könntest du nicht vielleicht ein konfiguriertes Offset einbauen, damit die Entladesperre in der Nacht ein wenig korrigiert werden kann?
                Bei mir hält der Speicher immer locker durch aber das Script meint, es müsste eine Entladesperre setzen.
                Evtl. kann man den errechneten Verbrauch mit dem Offset hoch oder runter korrigieren.
                Vielen Dank schonmal.
                • P psrelax
                  @arnod
                  Super, danke.
                  A
                  A
                  ArnoD
                  #3364
                  @psrelax
                  Hast du da ein LOG File oder kannst du Debug Log beim CC Skript einschalten und das mal mir schicken?
                  Will nur sicher sein das, dass die Ursache ist.
                  • A
                    A
                    Abyss
                    #3365
                    @ArnoD
                    Ich habe mir jetzt auch mal EVCC installiert als Vorbereitung auf die Wallbox die in paar Wochen dazukommt bei mir.
                    Ich habe jetzt aber schon mal den AC-Elwa-2 Heizstab in EVCC eingebunden und teste das seit gestern.
                    Läuft bis jetzt ganz gut.
                    Falls das auch wer umsetzen will, ich bin über folgende Punkte gestolpert:
                    • Der Heizstab akzeptiert nur eine Modbus Verbindung, also entweder iobroker ODER Evcc.
                      --> Zur Steuerung über EVCC musste somit der iobroker getrennt werden.
                      Damit der iobroker trotzdem weiterhin die Werte vom Heizstab bekommt muss man in EVCC einen modbusproxy einrichten und den iorboker dann auf die ip+port des EVCC modbusproxy umstellen. Der EVCC reicht dann die Werte einfach 1:1 zum iobroker durch.
                    Anfangs hatte ich im EVCC noch "out of Sync" Meldungen bei der Ansteuerung des Heizstabs.
                    Diese habe ich aktuell durch folgende 2 Einstellungen am Heizstab wegbekommen:
                    • Zeitablauf Ansteuerung erhöht auf 60s (in einem Github-Issue war sogar die Rede von 600s, ich versuchs aktuell mal mit den 60s)
                    • Max. Temperatur Warmwasser habe ich höher gesetzt als ich EVCC regeln lasse, da sonst der Heizstab abgeschaltet hat bevor EVCC mit der Regelung gestoppt hat.
                    Jetzt hoffe ich mal, dass zeitnah die Wallbox Multiconnect 2 in EVCC unterstützt wird bis die bei mir kommt. ;)
                    Hier fehlt aktuell wohl noch ein passendes Template.
                    Deinen Hinweis mit dem Modbusproxy zu der Wallbox hatte ich nicht ganz verstanden. Der Modbusproxy dient ja nur dazu um ein mit EVCC Verbundenes Gerät über EVCC auszulesen, oder? Aber bei der Wallbox fehlt ja aktuell noch das passende Template um die in EVCC überhaupt einzubinden.
                    Evtl. versteh ich hier auch aktuell was falsch. ;)
                    • azzkikrboyA azzkikrboy
                      Das Wallbox Script wird hier auch nicht mehr weiter optimiert, da evcc das besser kann und ständig weiter entwickelt wird.
                      ich habe mir EVCC auch mal angeschaut. Sieht ganz gut aus.
                      Allerdings wird meine Wallbox (Multiconnect II) nicht direkt unterstützt. Zumindest finde ich nix dazu :-(
                      Hat das hier schon jemand am laufen?
                      A
                      A
                      Abyss
                      #3366
                      @azzkikrboy
                      Bist du mit der Multiconnect II bereits weitergekommen?
                      Im Github-Issue geht ja irgendwie auch nichts voran.
                      Und mal ne blöde Frage...hast du es evtl schon mal mit dem Template der Easy-Connect versucht, die ja von EVCC unterstützt wird?
                      Ich hab mir mal die ModBus_E3DC_Speichersysteme (DE)_V2.40_de-DE_20.05.2025.pdf Doku durchgeblättert...für mich als Laien sieht es ja so aus, als ob beide Wallboxen mit den gleichen Bits angesteuert werden. Evtl. funktioniert ja dann das Template der Easy-connect direkt?!
                      A azzkikrboyA 2 Antworten Letzte Antwort
                      • M
                        M
                        MaLei
                        #3367
                        Dann muss ich mich wohl noch nicht an die Installation von EVCC machen ... Nutze auch seit ein paar Tagen eine MultiConnect II. Bei mir wird nicht mal im RSCP-Adapter der SOC des Autos angezeigt. Ist das normal?
                        • A
                          A
                          ArnoD
                          #3368
                          Neue Version TibberSkript auf GitHub hochgeladen.
                          Version: 1.3.18
                          Änderungen:
                          • Diese Änderung behebt ein Problem, bei dem das Skript undefinierte Daten hatte, wenn JSON-Daten aus dem Tibberlink-Adapter (z. B. sID_PricesTodayJSON oder sID_PricesTomorrowJSON) zum Zeitpunkt der Aktualisierung leer, ungültig oder temporär nicht verfügbar waren.
                          • A Abyss
                            @ArnoD
                            A
                            A
                            ArnoD
                            #3369
                            @abyss sagte in E3DC Hauskraftwerk steuern:
                            War nur die Frage, ob es mit dem Standard Template und dem Modbusproxy bereits versucht wurde.
                            • A ArnoD
                              Version: 1.3.18
                              Änderungen:
                              A
                              A
                              ArnoD
                              #3370
                              @malei sagte in E3DC Hauskraftwerk steuern:
                              Der e3dc-rscp Adapter kann dir den SOC vom Auto nicht anzeigen, da dieser nicht übertragen wird bzw. auch keine Schnittstelle zum Auto vorhanden ist.
                              • A Abyss
                                @azzkikrboy
                                A
                                A
                                ArnoD
                                #3371
                                Genau das hatte ich gemeint :-)
                                Noch ein Hinweis, der mich fast zum Verzweifeln gebracht hat.
                                Bei mir funktionierte die Steuerung der Wallbox über evcc erst, nachdem ich bei der Wallbox den Dip-Schalter 7 auf off gestellt hatte.
                                • A ArnoD
                                  M
                                  M
                                  MaLei
                                  #3372
                                  @arnod
                                  Was zeigt e3dc-rscp.0.WB.WB_0.SOC ("Ladezustand") an?
                                  Kannst du mir sagen, wie ich über die VIS den Sonnenmodus aktivieren/deaktivieren kann?
                                  • A Abyss
                                    @azzkikrboy
                                    azzkikrboyA
                                    azzkikrboyA
                                    azzkikrboy
                                    schrieb am zuletzt editiert von azzkikrboy
                                    #3373
                                    @Abyss
                                    Nein, bin noch nicht weiter, habe aber schon Kontakt mit den Entwicklern aufgenommen. Die sind sehr hilfsbereit, aber auch nur 3, also hoffnungslos überlastet.
                                    Meine Idee war die WB über RSCP über das E3DC zu regeln ... Also nicht direkt die WB anzusprechen. Grundsätzlich wären die bereit das zu übernehmen, wenns dann einer "macht" ... ich versuche da mal im Urlaub weiter zu kommen.
                                    Ich habe es mit dem EasyConnect Template versucht ... (siehe Post vom 30.06. 20:03h).
                                    @ArnoD : Wallbox DIP 7: bei der EasyConnect oder MultiConnect II ???
                                    Mit den DIP Schaltern habe ich noch nicht "gespielt", da von EVCC keine Info vorhanden ist ...
                                      @Abyss
                                      A
                                      A
                                      ArnoD
                                      #3374
                                      @azzkikrboy sagte in E3DC Hauskraftwerk steuern:
                                      Ich habe die EasyConnect
                                      • A ArnoD
                                        @psrelax
                                        P
                                        P
                                        psrelax
                                        #3375
                                        Meinst du wegen der Entladesperre?
                                        Wenn ja, hier bitte:
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
                                        2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
                                        2025-07-07 00:59:54.494  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
                                        2025-07-07 00:59:54.536  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
                                        2025-07-07 00:59:54.538  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
                                        2025-07-07 00:59:54.539  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
                                        2025-07-07 00:59:54.540  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                                        2025-07-07 00:59:54.541  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
                                        2025-07-07 00:59:54.542  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                                        2025-07-07 00:59:54.543  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                                        2025-07-07 00:59:54.544  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
                                        2025-07-07 00:59:54.545  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
                                        2025-07-07 00:59:54.547  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
                                        2025-07-07 00:59:54.547  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
                                        2025-07-07 00:59:54.547  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
                                        2025-07-07 00:59:54.590  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 675W
                                        2025-07-07 00:59:54.591  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = -669 W
                                        2025-07-07 00:59:54.593  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
                                        2025-07-07 00:59:54.593  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
                                        2025-07-07 00:59:54.635  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
                                        2025-07-07 00:59:54.635  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                                        2025-07-07 00:59:54.635  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                                        2025-07-07 00:59:54.635  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
                                        2025-07-07 00:59:54.635  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
                                        2025-07-07 00:59:54.677  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                                        2025-07-07 00:59:54.677  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                                        2025-07-07 00:59:54.677  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                                        2025-07-07 00:59:54.677  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                                        2025-07-07 00:59:54.677  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,7,10,
                                        2025-07-07 01:00:00.007  - warn: javascript.0 (196) script.js.PV_Max_Watt.pv_max_watt_schreiben: Zeitplan ausgeführt Anfang
                                        2025-07-07 01:00:00.010  - warn: javascript.0 (196) script.js.PV_Max_Watt.pv_max_watt_schreiben: 12391
                                        2025-07-07 01:00:00.010  - warn: javascript.0 (196) script.js.PV_Max_Watt.pv_max_watt_schreiben: Zeitplan ausgeführt Ende
                                        2025-07-07 01:00:00.033  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: -==== ?? Tibber output signal BatterieEntladesperre wurde in true geändert ====-
                                        2025-07-07 01:00:00.035  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieEntladesperre wurde durch Timer um 01:00:00 auf true gesetzt.
                                        2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ************************************************************************************
                                        2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerTarget = ["2025-07-07T00:00:00.000Z","2025-07-07T04:00:00.000Z"]
                                        2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerState = [true,false]
                                        2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerObjektID = ["Entladesperre","Entladesperre"]
                                        2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** minStrompreis_48h = 0.2233
                                        2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** batterieKapazitaet_kWh = 17
                                        2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Batterie_SOC = 44
                                        2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Bat_W = -675
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Grid = -5
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** prognoseLadezeitBatterie = 2
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** reichweiteBatterie = 5:60 h
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie angewählt = true
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Nettostrompreis Batterie = 0.1057
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie = 0.1201
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Aktueller Preis Tibber = 0.2908
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Preis Tibber mit Ladeverluste = 0.3459
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].endLocale = 7.7.2025, 13:00:00
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].startLocale = 7.7.2025, 10:00:00
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].Type = high
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].endLocale = 7.7.2025, 10:00:00
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].startLocale = 7.7.2025, 06:00:00
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].Type = peak
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.endLocale = 7.7.2025, 06:00:00
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.startLocale = 7.7.2025, 00:00:00
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.Type = high
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert Spitzenstrompreis = 0.3068
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert hoher Strompreis = 0.27
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert niedriger Strompreis = 0.1057
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** schneeBedeckt = false
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung heute = 44.31 kWh
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung morgen = 32.54 kWh
                                        2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** pvLeistungAusreichend = false
                                        2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** bReichweiteSunrise = false
                                        2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** eAutoLaden = false
                                        2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieEntladenSperren = true
                                        2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieLaden = false
                                        2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** battSperrePrio = true
                                        2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Status = Batterie sperre von 02:00 Uhr bis 06:00 Uhr um Peakphase zu überbrücken (aktive Phase: high)
                                        2025-07-07 01:00:00.384  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** ProgrammAblauf = 27,1,18,18/4,19,22,32,11,11/3,11/4,31,29,29/3,29,29/3,
                                        2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: *******************  Debug LOG Tibber Skript Version 1.3.17 *******************
                                        2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                                        2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                                        2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                                        2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
                                        2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                                        2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                                        2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                                        2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
                                        2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                                        2025-07-07 01:00:03.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
                                        2025-07-07 01:00:03.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
                                        2025-07-07 01:00:03.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
                                        2025-07-07 01:00:03.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
                                        2025-07-07 01:00:03.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
                                        2025-07-07 01:00:03.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
                                        2025-07-07 01:00:03.088  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
                                        2025-07-07 01:00:03.090  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
                                        2025-07-07 01:00:03.091  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
                                        2025-07-07 01:00:03.092  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                                        2025-07-07 01:00:03.093  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
                                        2025-07-07 01:00:03.095  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                                        2025-07-07 01:00:03.096  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                                        2025-07-07 01:00:03.097  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
                                        2025-07-07 01:00:03.098  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
                                        2025-07-07 01:00:03.099  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
                                        2025-07-07 01:00:03.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
                                        2025-07-07 01:00:03.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
                                        2025-07-07 01:00:03.154  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 681W
                                        2025-07-07 01:00:03.166  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = -675 W
                                        2025-07-07 01:00:03.179  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
                                        2025-07-07 01:00:03.180  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
                                        2025-07-07 01:00:03.237  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
                                        2025-07-07 01:00:03.237  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                                        2025-07-07 01:00:03.237  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                                        2025-07-07 01:00:03.237  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
                                        2025-07-07 01:00:03.237  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
                                        2025-07-07 01:00:03.349  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                                        2025-07-07 01:00:03.349  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                                        2025-07-07 01:00:03.349  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                                        2025-07-07 01:00:03.349  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                                        2025-07-07 01:00:03.349  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,41,
                                        2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                                        2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                                        2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                                        2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
                                        2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                                        2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                                        2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                                        2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
                                        2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                                        2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
                                        2025-07-07 01:00:12.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
                                        2025-07-07 01:00:12.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
                                        2025-07-07 01:00:12.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
                                        2025-07-07 01:00:12.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
                                        2025-07-07 01:00:12.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
                                        2025-07-07 01:00:12.088  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
                                        2025-07-07 01:00:12.090  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
                                        2025-07-07 01:00:12.093  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
                                        2025-07-07 01:00:12.094  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                                        2025-07-07 01:00:12.096  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
                                        2025-07-07 01:00:12.097  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                                        2025-07-07 01:00:12.099  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                                        2025-07-07 01:00:12.102  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
                                        2025-07-07 01:00:12.103  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
                                        2025-07-07 01:00:12.104  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
                                        2025-07-07 01:00:12.105  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
                                        2025-07-07 01:00:12.105  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
                                        2025-07-07 01:00:12.148  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 386W
                                        2025-07-07 01:00:12.152  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
                                        2025-07-07 01:00:12.159  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
                                        2025-07-07 01:00:12.159  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
                                        2025-07-07 01:00:12.200  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
                                        2025-07-07 01:00:12.200  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                                        2025-07-07 01:00:12.200  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                                        2025-07-07 01:00:12.200  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
                                        2025-07-07 01:00:12.200  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
                                        2025-07-07 01:00:12.242  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                                        2025-07-07 01:00:12.242  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                                        2025-07-07 01:00:12.242  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                                        2025-07-07 01:00:12.242  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                                        2025-07-07 01:00:12.242  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
                                        2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
                                        2025-07-07 01:00:18.087  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
                                        2025-07-07 01:00:18.089  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
                                        2025-07-07 01:00:18.091  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
                                        2025-07-07 01:00:18.092  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                                        2025-07-07 01:00:18.093  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
                                        2025-07-07 01:00:18.095  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                                        2025-07-07 01:00:18.096  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                                        2025-07-07 01:00:18.097  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
                                        2025-07-07 01:00:18.098  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
                                        2025-07-07 01:00:18.099  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
                                        2025-07-07 01:00:18.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
                                        2025-07-07 01:00:18.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
                                        2025-07-07 01:00:18.156  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 459W
                                        2025-07-07 01:00:18.160  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
                                        2025-07-07 01:00:18.162  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
                                        2025-07-07 01:00:18.162  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
                                        2025-07-07 01:00:18.205  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
                                        2025-07-07 01:00:18.205  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                                        2025-07-07 01:00:18.205  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                                        2025-07-07 01:00:18.205  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
                                        2025-07-07 01:00:18.205  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
                                        2025-07-07 01:00:18.247  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                                        2025-07-07 01:00:18.247  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                                        2025-07-07 01:00:18.247  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                                        2025-07-07 01:00:18.247  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                                        2025-07-07 01:00:18.247  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,
                                        2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                                        2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                                        2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                                        2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
                                        2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                                        2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                                        2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                                        2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
                                        2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                                        2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
                                        2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
                                        2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
                                        2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
                                        2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
                                        2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
                                        2025-07-07 01:00:24.551  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
                                        2025-07-07 01:00:24.553  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
                                        2025-07-07 01:00:24.554  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
                                        2025-07-07 01:00:24.555  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                                        2025-07-07 01:00:24.557  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
                                        2025-07-07 01:00:24.558  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                                        2025-07-07 01:00:24.559  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                                        2025-07-07 01:00:24.560  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
                                        2025-07-07 01:00:24.561  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
                                        2025-07-07 01:00:24.562  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
                                        2025-07-07 01:00:24.563  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
                                        2025-07-07 01:00:24.563  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
                                        2025-07-07 01:00:24.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 405W
                                        2025-07-07 01:00:24.606  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
                                        2025-07-07 01:00:24.609  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
                                        2025-07-07 01:00:24.609  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
                                        2025-07-07 01:00:24.650  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
                                        2025-07-07 01:00:24.650  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                                        2025-07-07 01:00:24.650  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                                        2025-07-07 01:00:24.650  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
                                        2025-07-07 01:00:24.650  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
                                        2025-07-07 01:00:24.692  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                                        2025-07-07 01:00:24.692  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                                        2025-07-07 01:00:24.692  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                                        2025-07-07 01:00:24.692  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                                        2025-07-07 01:00:24.692  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,
                                        2025-07-07 01:00:33.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                                        2025-07-07 01:00:33.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                                        2025-07-07 01:00:33.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                                        2025-07-07 01:00:33.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
                                        2025-07-07 01:00:33.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                                        2025-07-07 01:00:33.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                                        2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                                        2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
                                        2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                                        2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
                                        2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
                                        2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
                                        2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
                                        2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
                                        2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
                                        2025-07-07 01:00:33.088  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
                                        2025-07-07 01:00:33.090  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
                                        2025-07-07 01:00:33.091  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
                                        2025-07-07 01:00:33.092  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                                        2025-07-07 01:00:33.094  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
                                        2025-07-07 01:00:33.095  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                                        2025-07-07 01:00:33.097  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                                        2025-07-07 01:00:33.098  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
                                        2025-07-07 01:00:33.099  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
                                        2025-07-07 01:00:33.101  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
                                        2025-07-07 01:00:33.102  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
                                        2025-07-07 01:00:33.102  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
                                        2025-07-07 01:00:33.154  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 1137W
                                        2025-07-07 01:00:33.162  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
                                        2025-07-07 01:00:33.176  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
                                        2025-07-07 01:00:33.177  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
                                        2025-07-07 01:00:33.238  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
                                        2025-07-07 01:00:33.239  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                                        2025-07-07 01:00:33.239  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                                        2025-07-07 01:00:33.239  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
                                        2025-07-07 01:00:33.239  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
                                        2025-07-07 01:00:33.351  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                                        2025-07-07 01:00:33.351  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                                        2025-07-07 01:00:33.351  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                                        2025-07-07 01:00:33.351  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                                        2025-07-07 01:00:33.351  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,41,
                                        2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                                        2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                                        2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                                        2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
                                        2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                                        2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                                        2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                                        2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
                                        2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                                        2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
                                        2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
                                        2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
                                        2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
                                        2025-07-07 01:00:39.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
                                        2025-07-07 01:00:39.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
                                        2025-07-07 01:00:39.088  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
                                        2025-07-07 01:00:39.090  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
                                        2025-07-07 01:00:39.091  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
                                        2025-07-07 01:00:39.092  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                                        2025-07-07 01:00:39.093  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
                                        2025-07-07 01:00:39.094  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                                        2025-07-07 01:00:39.096  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                                        2025-07-07 01:00:39.097  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
                                        2025-07-07 01:00:39.098  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
                                        2025-07-07 01:00:39.099  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
                                        2025-07-07 01:00:39.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
                                        2025-07-07 01:00:39.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
                                        2025-07-07 01:00:39.142  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 542W
                                        2025-07-07 01:00:39.143  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
                                        2025-07-07 01:00:39.145  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
                                        2025-07-07 01:00:39.145  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
                                        2025-07-07 01:00:39.186  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
                                        2025-07-07 01:00:39.186  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                                        2025-07-07 01:00:39.186  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                                        2025-07-07 01:00:39.186  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
                                        2025-07-07 01:00:39.186  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
                                        2025-07-07 01:00:39.228  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                                        2025-07-07 01:00:39.228  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                                        2025-07-07 01:00:39.229  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                                        2025-07-07 01:00:39.229  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                                        2025-07-07 01:00:39.229  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,41,
                                        2025-07-07 01:00:45.005  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
                                        2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
                                        2025-07-07 01:00:45.049  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
                                        2025-07-07 01:00:45.050  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
                                        2025-07-07 01:00:45.052  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
                                        2025-07-07 01:00:45.053  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                                        2025-07-07 01:00:45.054  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
                                        2025-07-07 01:00:45.055  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                                        2025-07-07 01:00:45.056  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                                        2025-07-07 01:00:45.057  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
                                        2025-07-07 01:00:45.058  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
                                        2025-07-07 01:00:45.060  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
                                        2025-07-07 01:00:45.060  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
                                        2025-07-07 01:00:45.060  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
                                        2025-07-07 01:00:45.102  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 539W
                                        2025-07-07 01:00:45.104  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
                                        2025-07-07 01:00:45.105  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
                                        2025-07-07 01:00:45.105  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
                                        2025-07-07 01:00:45.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
                                        2025-07-07 01:00:45.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                                        2025-07-07 01:00:45.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                                        2025-07-07 01:00:45.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
                                        2025-07-07 01:00:45.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
                                        2025-07-07 01:00:45.188  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                                        2025-07-07 01:00:45.188  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                                        2025-07-07 01:00:45.188  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                                        2025-07-07 01:00:45.188  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                                        2025-07-07 01:00:45.189  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,41,
                                        2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                                        2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                                        2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                                        2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
                                        2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                                        2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                                        2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                                        2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
                                        2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                                        2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
                                        2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
                                        2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
                                        2025-07-07 01:00:54.606  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
                                        2025-07-07 01:00:54.606  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
                                        2025-07-07 01:00:54.606  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
                                        2025-07-07 01:00:54.649  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
                                        2025-07-07 01:00:54.650  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
                                        2025-07-07 01:00:54.652  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
                                        2025-07-07 01:00:54.653  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                                        2025-07-07 01:00:54.654  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
                                        2025-07-07 01:00:54.656  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                                        2025-07-07 01:00:54.657  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                                        2025-07-07 01:00:54.659  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
                                        2025-07-07 01:00:54.661  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
                                        2025-07-07 01:00:54.662  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
                                        2025-07-07 01:00:54.662  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
                                        2025-07-07 01:00:54.662  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
                                        2025-07-07 01:00:54.705  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 887W
                                        2025-07-07 01:00:54.706  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
                                        2025-07-07 01:00:54.708  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
                                        2025-07-07 01:00:54.708  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
                                        2025-07-07 01:00:54.749  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
                                        2025-07-07 01:00:54.749  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                                        2025-07-07 01:00:54.749  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                                        2025-07-07 01:00:54.749  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
                                        2025-07-07 01:00:54.749  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
                                        2025-07-07 01:00:54.795  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                                        2025-07-07 01:00:54.795  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                                        2025-07-07 01:00:54.795  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                                        2025-07-07 01:00:54.795  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                                        2025-07-07 01:00:54.795  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,
                                        2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ************************************************************************************
                                        2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerTarget = ["2025-07-06T23:00:00.000Z","2025-07-07T04:00:00.000Z"]
                                        2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerState = [true,false]
                                        2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerObjektID = ["Entladesperre","Entladesperre"]
                                        2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** minStrompreis_48h = 0.2233
                                        2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** batterieKapazitaet_kWh = 17
                                        2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Batterie_SOC = 44
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Bat_W = 0
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Grid = 461
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** prognoseLadezeitBatterie = 2
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** reichweiteBatterie = 5:33 h
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie angewählt = true
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Nettostrompreis Batterie = 0.1057
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie = 0.1201
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Aktueller Preis Tibber = 0.2908
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Preis Tibber mit Ladeverluste = 0.3459
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].endLocale = 7.7.2025, 13:00:00
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].startLocale = 7.7.2025, 10:00:00
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].Type = high
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].endLocale = 7.7.2025, 10:00:00
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].startLocale = 7.7.2025, 06:00:00
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].Type = peak
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.endLocale = 7.7.2025, 06:00:00
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.startLocale = 7.7.2025, 00:00:00
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.Type = high
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert Spitzenstrompreis = 0.3068
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert hoher Strompreis = 0.27
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert niedriger Strompreis = 0.1057
                                        2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** schneeBedeckt = false
                                        2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung heute = 44.31 kWh
                                        2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung morgen = 32.54 kWh
                                        2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** pvLeistungAusreichend = false
                                        2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** bReichweiteSunrise = false
                                        2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** eAutoLaden = false
                                        2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieEntladenSperren = true
                                        2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieLaden = false
                                        2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** battSperrePrio = true
                                        2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Status = Batterie sperre von 01:00 Uhr bis 06:00 Uhr um Peakphase zu überbrücken (aktive Phase: high)
                                        2025-07-07 01:01:00.284  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** ProgrammAblauf = 27,1,18,18/4,19,22,32,11,11/3,11/4,31,29,29/3,29,29/3,
                                        P 1 Antwort Letzte Antwort
                                        • P psrelax
                                          @arnod sagte in E3DC Hauskraftwerk steuern:
                                          Hast du da ein LOG File oder kannst du Debug Log beim CC Skript einschalten und das mal mir schicken?
                                          Will nur sicher sein das, dass die Ursache ist.
                                          P
                                          P
                                          psrelax
                                          #3376
                                          @ArnoD
                                          War heut wieder der Fall.
                                          Genügen dir die Logs einen Post drüber?
                                          84.0k
