    apollon77A
lovelace uinspanelsonoff
8.1k Beiträge 281 Kommentatoren 9.7m Aufrufe 260 Beobachtet
  • ArmilarA Armilar
    @armilar
    Update v4.6.0.1
    Das Lights Update...
    https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs.ts
    Hierfür bitte den unteren Teil austauschen:
    Konfigurationsbeispiele aus den Abbildungen
    let Test_Color_Lights_1: PageType =
        type: 'cardEntities',
        useColor: true,
        heading: 'Test Color Lights 1',
        'items': [
                name: 'HUE (CT=Kelvin)', // HUE Channel - Philips WiZ GU10 über matter.0 - Color-Temperature in Kelvin
                icon: 'lightbulb-on',
                icon2: 'lightbulb-outline',
                offColor: Off,
                minValueColorTemp: 2203, // Kelvin = Warmweiß
                maxValueColorTemp: 6536, // Kelvin = Kaltweiß
                interpolateColor: true,
                modeList: ["Color", "Ocean", "Romantik", "Sonnenuntergang", "Party", "Kamin", "Gemütlich", "Wald", "Pastellfarben", "Aufwachen", "Schlafenszeit", "Warmweiß", "Tageslicht",
                           "Kaltweiß", "Nachtlicht", "Fokus", "Entspannen", "Echte Farben", "Fernsehzeit", "Pflanzenwachstum", "Frühling", "Sommer", "Herbst", "Tieftauchgang", "Dschungel",
                           "Mojito", "Club", "Weihnachten", "Halloween", "Kerzenlicht", "Goldenes Weiß", "Impuls", "Steampunk"],
                inSel_ChoiceState: true
                name: 'RGB Hex (CT=Mired)', // RGBsingle Channel - IKEA Tradfri GU10 über zigbee.0 - Color-Temperature in Mired
                offColor: Off,
                minValueColorTemp: 500, // Mired = Warmweiß = 1.000.000 / 2000 K = 500 Mired
                maxValueColorTemp: 153, // Mired = Kaltweiß = 1.000.000 / 6536 K = 153 Mired
                modeList: ["blink","breathe","okay","channel_change","finish_effect","stop_effect","colorloop","stop_colorloop"],
                name: 'RGB (CT=Mired)', // RGB Channel - E14 Livarno Home Color über zigbee.0 - Color-Temperature in Mired
                offColor: Off,
            { //Übersetzungsdatenpunkt für XY in 0_useedata schreibt in X, Y von zigbee.0
                name: 'CIE (CT=Mired)', // RGB Channel - E14 Livarno Home Color über zigbee.0 - Color-Temperature in Mired
                offColor: Off,
    let Test_CT_Lights_1: PageType =
        useColor: true,
        heading: 'Test CT Lights 1',
        'items': [
                name: 'Socket', // Socket Channel - Smart-Plug über sonoff.0
                onColor: MSGreen,
                offColor: HMIOff,
                icon: 'power-plug',
                icon2: 'power-plug-outline'
                name: 'Light', // Light Channel - Shelly 1L über shelly.0
                onColor: On,
                offColor: Off,
                name: 'Dimmer', // Dimmer Channel - IKEA Tradfri GU10 über zigbee.0
                name: 'CT (CT=Mired)', // CT Channel - Livarno Home GU10 über zigbee.0
                offColor: Off,
    NSPanelTS.ts
    • Der Alias-Channel CIE (XY) kann ebenfalls verwendet werden
    • Die Icons interpolieren jetzt Color mit Brightness und Color-Temperature mit Brightness
    • Alle Lampen verfügen jetzt über 2 Icons (icon, icon2)
    • Warmweiß ist default minValueColorTemp bei Kelvin (Achtung: bei Mired (insbesondere im Zigbee.0 vertreten), ist Warmweiß 500 und Kaltweiß 153)
    • diverse kleinere Bugs eliminiert
    • popupLightNew (Alternative Slider sind im Script entfernt)
    TFT
    • Es gab bei den TFT-Pictures Zuordnungsfehler die dazu geführt haben, dass Teile des popupLightNew zu sehen waren, wenn die Hintergrundfarbe Black anstelle von HMIDark gewählt wurde. Black sollte jetzt wieder normal funktionieren.
      FlashNextion http://nspanel.de/nspanel-v4.6.0.tft
    cardQR
    • Im unteren Teil der cardQR lässt sich mit einem neuen Parameter im pageItem die Entity2 (Passwort oder der Schalter) ausblenden.
           let WLAN: PageType =
               type: 'cardQR',
               heading: 'Gäste WLAN',
               subPage: true,
               parent: Subpages_1,
               items: [
                   { id: 'alias.0.NSPanel.GuestWifi',
                     hidePassword: true, // true = Switch; false = Password
                     hideEntity2: true   // true = Switch or Password is hide
    Und jetzt viel Spaß mit der Überarbeitung
    @TT-Tom , @ticaki und Armilar
    Chris_71C
    Chris_71C
    Chris_71
    #7073
    @armilar
    Hi, kann es sein das diese beiden links zum TFT Update für die US Version (noch) nicht funktionieren?
    TFT US-L STABLE Version: http://nspanel.de/nspanel-us-l-v4.6.0.tft
    TFT US-P STABLE Version: http://nspanel.de/nspanel-us-p-v4.6.0.tft
    • ArmilarA Armilar
      @etzeste13
      Sag bescheid, wenn etwas fehlt ;-)
      E
      E
      etzeste13
      schrieb am zuletzt editiert von etzeste13
      #7074
      @armilar
      Hi, also ich habe es jetzt auch Life probiert, und es funktioniert einwandfrei!! Vielen Dank nochmals!! Das wertet für mich die Funktionalität des NSPanel wesentlich auf!! 👍 👏
      • Chris_71C Chris_71
        @armilar
        ArmilarA
        ArmilarA
        Armilar
        Most Active Forum Testing
        #7075
        @chris_71
        Stimmt... habs nochmal geprüft... ich muss die beiden US-Versionen noch nachziehen. Wird dann die v4.7.1 werden. Hatte mich bei den Erweiterungen für den Adapter zunächst auf die eu-Versionen konzentriert...
        Welche Version setzt du ein? us-p oder us-l? Dann weiß ich womit ich beginnen kann ;-)
        • ArmilarA Armilar
          @chris_71
          ArmilarA
          ArmilarA
          Armilar
          #7076
          @armilar
          Update v4.7.1.2
          PanelTs.ts v4.7.1.2
          Unteren Teil ersetzen:
          TFT 56 / v4.7.1
          TFT EU STABLE Version:
          FlashNextion http://nspanel.de/nspanel-v4.7.1.tft
          FlashNextion http://nspanel.de/nspanel-us-l-v4.7.1.tft
          FlashNextion http://nspanel.de/nspanel-us-p-v4.7.1.tft
          Das Update beinhaltet:
          • den MPD-Player
            // Variable for "Music Player Daemon (MDP) Adapter Instance"
            // Please do not use "const" as the arrays are actively used
            let MPD: PageType =
                'type': 'cardMedia',
                'heading': 'MPD Client',
                'hiddenByTrigger': true,
                'items': [{
                            id: AliasPath + 'Media.PlayerMPD', // Path of the Media-Alias-Channel in alias.0.
                            adapterPlayerInstance: 'mpd.0.',   // Instance of the MDP-Server / MDP-Player
                            speakerList: [],                   // Do not Delete or Change
                            playList: [],                      // Do not Delete or Change
                            playerMediaIcon: 'logo-mpd',       // "logo-mpd" (Picture-Logo) or a Icon-Logo like "alpha-m-circle" (default)
                            colorMediaIcon: White,             // Color of the Player-Icon
                            colorMediaTitle: Yellow,           // Color of Text-Row for Title (Row 1)
                            colorMediaArtist: Yellow,          // Color of Text-Row for Artist (Row 2)
                            crossfade: true,                   // false = Seek; true = Crossfade in Logo of Player
                            alwaysOnDisplay: true,             // true = Always On Display (AOD); false = Dimmode and Screensaver-Timeout
                            autoCreateALias : true             // Create automatically required Media-Alias-Channel
          • Media Player mit Adapter-Logo (der Variable einfach unter items z.B. die Zeile playerMediaIcon: 'logo-alexa', hinzufügen)
            folgende Logos sind möglich
            • logo-alexa
            • logo-bose
            • logo-dlna (z.B. Squeezebox; Logitech)
            • logo-mpd
            • logo-sonos
            • logo-spotify
            • logo-volumio
          • Media Player mit Icon eigener Wahl (der Variable einfach unter items z.B. die Zeile playerMediaIcon: "alpha-a-circle", hinzufügen)
            weitere Icons wie immer unter: https://htmlpreview.github.io/?https://github.com/jobr99/Generate-HASP-Fonts/blob/master/cheatsheet.html
          SarlochinS 1 Antwort Letzte Antwort
          • ArmilarA Armilar
            @armilar
            Update v4.7.1.2
            PanelTs.ts v4.7.1.2
            TFT 56 / v4.7.1
            • den MPD-Player
              let MPD: PageType =
                  'items': [{
              • logo-alexa
              • logo-bose
              • logo-mpd
              • logo-sonos
              • logo-spotify
              • logo-volumio
            SarlochinS
            SarlochinS
            Sarlochin
            schrieb am zuletzt editiert von Sarlochin
            #7077
            erst einmal ein großes Dankeschön für dieses tolle Forum und all die hilfreichen Beiträge – ich konnte mir schon sehr viel Wissen aneignen!
            Aktuell habe ich jedoch ein Problem mit meinen beiden NSPanel-Skripten. Sie stürzen regelmäßig ab, sobald bestimmte Datenpunkte verwendet werden. Nach längerer Fehlersuche konnte ich das Problem scheinbar auf den Bereich mrIcon2ScreensaverEntity eingrenzen.
            Solange ich z. B. folgenden Eintrag verwende, funktioniert alles stabil:
            mrIcon2ScreensaverEntity: {
                ScreensaverEntity: NSPanel_Path + 'Relay.2',
                ScreensaverEntityIconOn: 'ceiling-light-multiple',
                ScreensaverEntityIconOff: null,
                ScreensaverEntityValue: null,
                ScreensaverEntityValueDecimalPlace: 0,
                ScreensaverEntityValueUnit: null,
                ScreensaverEntityOnColor: On,
                ScreensaverEntityOffColor: HMIOff
            Sobald ich aber ScreensaverEntity durch z. B. mqtt.0.wled.All.state oder mqtt.0.zigbee2mqtt.AllWindows.state ersetze, crasht das Skript sofort, sobald sich der Status des Datenpunkts ändert.
            Kurios: Beide Datenpunkte funktionieren einwandfrei unter mrIcon1ScreensaverEntity, aber eben nicht unter mrIcon2ScreensaverEntity.
            Fehlerbild:
            Nach Änderung des Status bricht das gesamte Skript (und alle weiteren) ab. Im ioBroker-Log erscheinen dann Meldungen wie:
            State "0_userdata.0.NSPanel.2.Relay." not found
            Es sieht so aus, als ob das Skript weiterhin versucht, auf Relay. zuzugreifen, obwohl dieser gar nicht mehr verwendet wird – oder durch die neue Quelle ein Wert erwartet wird, der nicht im erwarteten Format vorliegt?
            Logauszug (gekürzt):
            Caught by controller[1]: State "0_userdata.0.NSPanel.2.Relay." not found
            Terminated (UNCAUGHT_EXCEPTION)
            Unhandled promise rejection
            Ich vermute, dass entweder ein Fehler beim Wechsel der Datenquelle auftritt. Ich bin aber leider nicht fit genug in JS um den Fehler selber zurückzuverfolgen.
            Hat jemand eine Idee, woran das liegen könnte? Muss ich ggf. zusätzliche Abfragen einbauen oder das Format prüfen, bevor ich die Datenquelle eintrage?
            Bin für jeden Hinweis dankbar!
            Logs aus dem Skript sind jeweils identisch:
            14.4.2025, 11:30:52.930	[warn ]: javascript.0 (2143)     at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2924:47)
            14.4.2025, 11:30:52.931	[warn ]: javascript.0 (2143)     at step (script.js.NSPanel.nspanel_705674_PC:33:23)
            14.4.2025, 11:30:52.931	[warn ]: javascript.0 (2143)     at Object.next (script.js.NSPanel.nspanel_705674_PC:14:53)
            14.4.2025, 11:30:52.931	[warn ]: javascript.0 (2143)     at script.js.NSPanel.nspanel_705674_PC:8:71
            14.4.2025, 11:30:52.931	[warn ]: javascript.0 (2143)     at __awaiter (script.js.NSPanel.nspanel_705674_PC:4:12)
            14.4.2025, 11:30:52.931	[warn ]: javascript.0 (2143)     at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2917:32)
            14.4.2025, 11:30:52.933	[warn ]: javascript.0 (2143)     at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2925:62)
            14.4.2025, 11:30:52.933	[warn ]: javascript.0 (2143)     at step (script.js.NSPanel.nspanel_705674_PC:33:23)
            14.4.2025, 11:30:52.933	[warn ]: javascript.0 (2143)     at Object.next (script.js.NSPanel.nspanel_705674_PC:14:53)
            14.4.2025, 11:30:52.934	[warn ]: javascript.0 (2143)     at script.js.NSPanel.nspanel_705674_PC:8:71
            14.4.2025, 11:30:53.040	[info ]: javascript.0 (2143) Stopping script script.js.NSPanel.nspanel_705674_PC
            IOBROKER Logs sind:
            host.2b4bdf4ea464
            2025-04-14 11:30:53.730	warn	Do not restart adapter system.adapter.javascript.0 because restart loop detected
            host.2b4bdf4ea464
            2025-04-14 11:30:53.730	info	Restart adapter system.adapter.javascript.0 because enabled
            host.2b4bdf4ea464
            2025-04-14 11:30:53.729	error	instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            host.2b4bdf4ea464
            2025-04-14 11:30:53.729	error	Caught by controller[3]: State "0_userdata.0.NSPanel.1.Relay." not found
            host.2b4bdf4ea464
            2025-04-14 11:30:53.728	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            host.2b4bdf4ea464
            2025-04-14 11:30:53.728	error	Caught by controller[1]: State "0_userdata.0.NSPanel.2.Relay." not found
            host.2b4bdf4ea464
            2025-04-14 11:30:53.725	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            javascript.0
            2025-04-14 11:30:53.538	info	terminating
            mqtt.0
            2025-04-14 11:30:53.094	info	send2Server mqtt.0.TasmotaDevices.nspanel_0DBF90.cmnd.CustomSend[TasmotaDevices/nspanel_0DBF90/cmnd/CustomSend]
            mqtt.0
            2025-04-14 11:30:53.093	info	send2Server mqtt.0.TasmotaDevices.nspanel_0DBF90.cmnd.CustomSend[TasmotaDevices/nspanel_0DBF90/cmnd/CustomSend]
            mqtt.0
            2025-04-14 11:30:53.090	info	send2Server mqtt.0.TasmotaDevices.nspanel_0DBF90.cmnd.CustomSend[TasmotaDevices/nspanel_0DBF90/cmnd/CustomSend]
            mqtt.0
            2025-04-14 11:30:53.088	info	send2Server mqtt.0.TasmotaDevices.nspanel_705674.cmnd.CustomSend[TasmotaDevices/nspanel_705674/cmnd/CustomSend]
            mqtt.0
            2025-04-14 11:30:53.086	info	send2Server mqtt.0.TasmotaDevices.nspanel_705674.cmnd.CustomSend[TasmotaDevices/nspanel_705674/cmnd/CustomSend]
            mqtt.0
            2025-04-14 11:30:53.081	info	send2Server mqtt.0.TasmotaDevices.nspanel_705674.cmnd.CustomSend[TasmotaDevices/nspanel_705674/cmnd/CustomSend]
            javascript.0
            2025-04-14 11:30:53.059	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            javascript.0
            2025-04-14 11:30:53.058	info	terminating
            javascript.0
            2025-04-14 11:30:53.047	error	undefined
            javascript.0
            2025-04-14 11:30:53.046	error	unhandled promise rejection: undefined
            javascript.0
            2025-04-14 11:30:53.046	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            javascript.0
            2025-04-14 11:30:53.042	info	Stopping script script.js.NSPanel.nspanel_0DBF90_Door
            javascript.0
            2025-04-14 11:30:53.040	info	Stopping script script.js.NSPanel.nspanel_705674_PC
            javascript.0
            2025-04-14 11:30:53.038	info	Stopping script script.js.common.Weather.CheckRain
            javascript.0
            2025-04-14 11:30:52.952	error	undefined
            javascript.0
            2025-04-14 11:30:52.952	error	unhandled promise rejection: undefined
            javascript.0
            2025-04-14 11:30:52.951	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            javascript.0
            2025-04-14 11:30:52.944	warn	at new Promise (<anonymous>)
            javascript.0
            2025-04-14 11:30:52.944	warn	at script.js.NSPanel.nspanel_0DBF90_Door:8:71
            javascript.0
            2025-04-14 11:30:52.944	warn	at Object.next (script.js.NSPanel.nspanel_0DBF90_Door:14:53)
            javascript.0
            2025-04-14 11:30:52.944	warn	at step (script.js.NSPanel.nspanel_0DBF90_Door:33:23)
            javascript.0
            2025-04-14 11:30:52.944	warn	at Object.<anonymous> (script.js.NSPanel.nspanel_0DBF90_Door:2925:62)
            javascript.0
            2025-04-14 11:30:52.944	warn	at setStateAsync (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2276:20)
            javascript.0
            javascript.0
            2025-04-14 11:30:52.943	warn	at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2277:17
            javascript.0
            2025-04-14 11:30:52.943	warn	State "0_userdata.0.NSPanel.1.Relay." not found
            javascript.0
            2025-04-14 11:30:52.943	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            javascript.0
            2025-04-14 11:30:52.943	warn	at Object.<anonymous> (script.js.NSPanel.nspanel_0DBF90_Door:2917:32)
            javascript.0
            2025-04-14 11:30:52.943	warn	at __awaiter (script.js.NSPanel.nspanel_0DBF90_Door:4:12)
            javascript.0
            2025-04-14 11:30:52.943	warn	at new Promise (<anonymous>)
            javascript.0
            2025-04-14 11:30:52.943	warn	at script.js.NSPanel.nspanel_0DBF90_Door:8:71
            javascript.0
            2025-04-14 11:30:52.942	warn	at Object.next (script.js.NSPanel.nspanel_0DBF90_Door:14:53)
            javascript.0
            2025-04-14 11:30:52.942	warn	at step (script.js.NSPanel.nspanel_0DBF90_Door:33:23)
            javascript.0
            2025-04-14 11:30:52.942	warn	at Object.<anonymous> (script.js.NSPanel.nspanel_0DBF90_Door:2924:47)
            javascript.0
            2025-04-14 11:30:52.937	warn	getState "0_userdata.0.NSPanel.1.Relay." not found (3)
            javascript.0
            2025-04-14 11:30:52.934	warn	at new Promise (<anonymous>)
            javascript.0
            2025-04-14 11:30:52.934	warn	at script.js.NSPanel.nspanel_705674_PC:8:71
            javascript.0
            2025-04-14 11:30:52.933	warn	at Object.next (script.js.NSPanel.nspanel_705674_PC:14:53)
            javascript.0
            2025-04-14 11:30:52.933	warn	at step (script.js.NSPanel.nspanel_705674_PC:33:23)
            javascript.0
            2025-04-14 11:30:52.933	warn	at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2925:62)
            javascript.0
            2025-04-14 11:30:52.933	warn	at setStateAsync (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2276:20)
            javascript.0
            2025-04-14 11:30:52.933	warn	at new Promise (<anonymous>)
            javascript.0
            2025-04-14 11:30:52.933	warn	at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2277:17
            javascript.0
            2025-04-14 11:30:52.931	warn	State "0_userdata.0.NSPanel.2.Relay." not found
            javascript.0
            2025-04-14 11:30:52.931	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            javascript.0
            2025-04-14 11:30:52.931	warn	at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2917:32)
            javascript.0
            2025-04-14 11:30:52.931	warn	at __awaiter (script.js.NSPanel.nspanel_705674_PC:4:12)
            javascript.0
            2025-04-14 11:30:52.931	warn	at new Promise (<anonymous>)
            javascript.0
            2025-04-14 11:30:52.931	warn	at script.js.NSPanel.nspanel_705674_PC:8:71
            javascript.0
            2025-04-14 11:30:52.931	warn	at Object.next (script.js.NSPanel.nspanel_705674_PC:14:53)
            javascript.0
            2025-04-14 11:30:52.931	warn	at step (script.js.NSPanel.nspanel_705674_PC:33:23)
            javascript.0
            2025-04-14 11:30:52.930	warn	at Object.<anonymous> (script.js.NSPanel.nspanel_705674_PC:2924:47)
            javascript.0
            2025-04-14 11:30:52.916	warn	getState "0_userdata.0.NSPanel.2.Relay." not found (3)
            Samson71S ArmilarA T 4 Antworten Letzte Antwort
            • SarlochinS Sarlochin
              Fehlerbild:
              IOBROKER Logs sind:
              host.2b4bdf4ea464
              host.2b4bdf4ea464
              host.2b4bdf4ea464
              host.2b4bdf4ea464
              host.2b4bdf4ea464
              host.2b4bdf4ea464
              host.2b4bdf4ea464
              javascript.0
              mqtt.0
              mqtt.0
              mqtt.0
              mqtt.0
              mqtt.0
              mqtt.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              Samson71S
              Samson71S
              Samson71
              #7078
              @sarlochin
              Bitte benutze für die Lesbarkeit Code-Tags.
              Ich habe das bereits für die meisten Logs nachgeholt (was ich beim Überfliegen sehen konnte), mag aber nicht den ganzen Post zeilenweise durchsuchen.
              Markus
              Bitte beachten:
                Fehlerbild:
                IOBROKER Logs sind:
                host.2b4bdf4ea464
                host.2b4bdf4ea464
                host.2b4bdf4ea464
                host.2b4bdf4ea464
                host.2b4bdf4ea464
                host.2b4bdf4ea464
                host.2b4bdf4ea464
                javascript.0
                mqtt.0
                mqtt.0
                mqtt.0
                mqtt.0
                mqtt.0
                mqtt.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                javascript.0
                ArmilarA
                ArmilarA
                Armilar
                #7079
                @sarlochin sagte in SONOFF NSPanel mit Lovelace UI:
                Da passieren sehr merkwürdige Dinge... wie z.B.
                mqtt.0
                javascript.0
                javascript.0
                Könntest du mal die komplette Screensaver-Config aus dem Script posten, welche die gewünschte Konfiguration beinhaltet?
                Bitte in den Code-Tags aus der Menüleiste des Beitrags wie bereits von @Samson71 korrigiert. Ansonsten ist das sehr schlecht lesbar...
                  Fehlerbild:
                  IOBROKER Logs sind:
                  host.2b4bdf4ea464
                  host.2b4bdf4ea464
                  host.2b4bdf4ea464
                  host.2b4bdf4ea464
                  host.2b4bdf4ea464
                  host.2b4bdf4ea464
                  host.2b4bdf4ea464
                  javascript.0
                  mqtt.0
                  mqtt.0
                  mqtt.0
                  mqtt.0
                  mqtt.0
                  mqtt.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  javascript.0
                  T
                  T
                  ticaki
                  #7080
                  @sarlochin
                  Wir haben das Problem besprochen und mit dem aktuellen Skript sind Datenpunkte die mit mqtt beginnen bei mrIcons verboten. Entweder du verwendest aliase oder wartest auf ein bugfix :)
                  Spenden
                    Fehlerbild:
                    IOBROKER Logs sind:
                    host.2b4bdf4ea464
                    host.2b4bdf4ea464
                    host.2b4bdf4ea464
                    host.2b4bdf4ea464
                    host.2b4bdf4ea464
                    host.2b4bdf4ea464
                    host.2b4bdf4ea464
                    javascript.0
                    mqtt.0
                    mqtt.0
                    mqtt.0
                    mqtt.0
                    mqtt.0
                    mqtt.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    ArmilarA
                    ArmilarA
                    Armilar
                    #7081
                    @sarlochin
                    du kannst den unteren Teil aus dem DEV-Script verwenden... Ist ein Bugfix für das Problem...
                    https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/DEV/NSPanelTs.ts
                    Zum Hintergrund: Bislang wurden immer die Buttons aus stat.POWER1 und stat.POWER2 extrahiert und nur auf mqtt abgeprüft. Das heißt, alles was mit mqtt anfing waren für das Skript automatisch Buttons. Durch das aufsplitten deiner Datenpunkte wurden jedoch keine Buttons 1 oder 2 gefunden und somit war die Endung auf 0_userdata.0.NSPanel.1.Relay. . Also auf dem Punkt am Ende und das lässt den JS-Adapter abstürzen...
                    Viel Spaß mit dem Bugfix... und vielen Dank an @ticaki für die superschnelle Analyse und den schnellen Fix...
                    EDIT: Bitte, falls noch nicht geschehen, die TFT v4.7.1 flashen...
                    Die neueste US-P - Version ist auch verfügbar:
                    Mit Bezug auf:
                    https://github.com/joBr99/nspanel-lovelace-ui/issues/1323
                    Die TFT-Welt ist für Home Assistant stehen geblieben. Wir forken und entwickeln jedoch eine separate TFT-Version für das NSPanel unter ioBroker (Hat diverse Funktionalitäten mehr, ist jedoch auch abwärtskompatibel zu HA) ...
                    Daher die korrekte Aussage:
                    für HA: v4.4.0 (https://github.com/joBr99/nspanel-lovelace-ui/tree/main/HMI)
                    für ioBroker: v4.7.1 (https://github.com/ticaki/ioBroker.nspanel-lovelace-ui/tree/main/HMI)
                    • T
                      T
                      ticaki
                      #7082
                      Bugberichte zur ioBroker - TFT Version
                      Bitte hier eröffnen:
                      https://github.com/ticaki/ioBroker.nspanel-lovelace-ui/issues
                      Spenden
                      • TolkinT
                        TolkinT
                        Tolkin
                        #7083
                        Moin und frohe Ostern zusammen. Ich habe die Zeit jetzt mal genutzt und mein NS-Panel geflasht und das Skript eingebunden. Soweit funktioniert es auch schon. Jetzt möchte ich eine Seite "Garten" erstellen und einige Lampen als Übersicht darstellen. Das Skript habe ich so angepasst:
                        /******************************** End CONFIG Parameter ********************************/
                        //-- Anfang für eigene Seiten -- z.T. selbstdefinierte Aliase erforderlich ----------------
                        //-- Start for your own pages -- some self-defined aliases required ----------------
                        let Garten: PageType =
                            'type': 'cardEntities',
                            'heading': 'Garten',
                            'useColor': true,
                            'items': [
                              { id: 'alias.0.NSPanel1.Licht_Gartenhaus_.ON_ACTUAL', name: 'Licht Gartenhaus', icon: 'Licht', icon2: 'power',offColor: MSRed, onColor: MSGreen},
                        //-- https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Page-%E2%80%90-Typen_How-2_Beispiele
                        //-- ENDE für eigene Seiten -- z.T. selbstdefinierte Aliase erforderlich -------------------------
                        //-- END for your own pages -- some self-defined aliases required ------------------------
                        Aber das Panel zeigt mir keine Seite mit Garten an. Ich sehe nu die Startseite und wenn ich aufs Display drücke, erscheint das Service Menü. Was fehlt mir noch...?
                        Marc BergM T 2 Antworten Letzte Antwort
                        • TolkinT Tolkin
                              'useColor': true,
                              'items': [
                          Marc BergM
                          Marc BergM
                          Marc Berg
                          #7084
                          @tolkin sagte in SONOFF NSPanel mit Lovelace UI:
                          Vermutlich der Eintrag unter "Pages"/"Subpages".
                          • TolkinT Tolkin
                                'useColor': true,
                                'items': [
                            T
                            T
                            TT-Tom
                            #7085
                            @tolkin
                            du hast auch einen Fehler in der "id".
                            in der Page Config enden die Pfade immer auf den Channel. In deinem Fall also so.
                            Gruß Tom
                            Public Transport
                            NSPanel Adapter Wiki
                            • TolkinT
                              TolkinT
                              Tolkin
                              #7086
                              @tt-tom
                              Leider haben beide Anpassungen noch nicht zum Erfolg geführt. Ich bekomme beim Skript-Start auch immer noch diese Fehlermeldung.
                              script.js.common.Panel_1: Config-Parameter: << config.panelRecvTopic - mqtt.0.SmartHometele.nspanel_C3025C.RESULT >> does not refer to the prefix .tele. Please Check Parameters!
                              • TolkinT Tolkin
                                @tt-tom
                                ArmilarA
                                ArmilarA
                                Armilar
                                #7087
                                So wie es aussieht fehlt da ein Punkt zwischen SmartHome und tele
                                also korrekt wäre:
                                mqtt.0.SmartHome.tele.nspanel_C3025C.RESULT
                                • ArmilarA Armilar
                                  @sarlochin
                                  Mit Bezug auf:
                                  SarlochinS
                                  SarlochinS
                                  Sarlochin
                                  #7088
                                  @armilar
                                  ich möchte mich ganz herzlich bei euch allen bedanken – insbesondere bei @ticaki für den schnellen Bugfix! Auch ein großes Dankeschön an alle anderen Entwickler im Projekt! :D
                                  Gleichzeitig möchte ich mich auch für die anfänglich schlechte Formatierung meines Beitrags entschuldigen. Danke an @Samson71 fürs Nachformatieren – ich habe meinen Beitrag jetzt nochmal überarbeitet und hoffe, dass er nun besser lesbar ist.
                                  Außerdem sorry für meine späte Rückmeldung: Meine E-Mail-Benachrichtigungen waren nicht korrekt eingestellt, und ich habe fälschlicherweise darauf gewartet, dass eine Freigabebestätigung per Mail kommt. Dabei war der Beitrag längst online – und das Problem sogar schon gelöst. 🙈
                                  Ein großes Danke auch für die hilfreichen Infos zu den neuen TFT-Versionen. Mir war vorher gar nicht klar, wie viele unterschiedliche Teilbereiche (HA / ioBroker etc.) im Projekt zusammenspielen. Bislang hatte ich mit beidem kaum Berührungspunkte, da ich eigentlich bisher alles in Eigenentwicklung realisiere.
                                  Um künftig die aktuellste TFT-Version schnell im Blick zu haben, habe ich mir jetzt ein kleines Skript geschrieben, das den Server nach der neuesten Versionsnummer durchsucht. Damit sollte es bei mir keine Verwirrung mehr geben, bzw. inzwischen stehen ja auch die neuen Versionen direkt im TS.
                                  Beste Grüße!
                                    @armilar
                                    Beste Grüße!
                                    T
                                    T
                                    TT-Tom
                                    #7089
                                    @sarlochin
                                    wenn du Update Meldungen am Panel aktiv schaltest, bekommst du automatisch auf dem Panel eine Meldung wenn es neue Versionen zu Tasmota, berry oder TFT gibt. Zusätzlich kannst du auch die Autoupdate Funktion aktivieren, dann weir das Update automatisch installiert.
                                    Es wird im 12h Intervall automatisch nach Updates gesucht. Du bauchst da also kein eigenes Script.
                                    Gruß Tom
                                    Public Transport
                                    • D
                                      D
                                      danny_v1
                                      #7090
                                      findet sich die cardSchedule Page irgendwo im Wiki?
                                      • D danny_v1
                                        ArmilarA
                                        ArmilarA
                                        Armilar
                                        #7091
                                        @danny_v1
                                        Bislang noch nicht. Ist wegen der Fahrplan-Funktionen etwas vorgezogen worden und wird zusammen mit dem popupSlider (noch im Test) dann offiziell im Wiki erscheinen. ;-)
                                        Du kannst die cardSchedule wie eine cardEntities benutzen, mit der Ausnahme, das dort nur textorientierte Steuerelemente funktionieren (also Informationen wie info, temperatur, humidity, etc.). Statt der 4 Entitäten in der cardEntities sind jedoch 6 Entitäten wie im Beispiel unten in der cardSchedule möglich.
                                        let Schedule_1: PageType =
                                            type: 'cardSchedule',
                                            heading: 'Test cardSchedule',
                                            useColor: true,
                                            items: [
                                                { id: 'alias.0.Test.cardSchedule1', name: 'Text 1', icon: 'train'},
                                                { id: 'alias.0.Test.cardSchedule1', name: 'Text 2', icon: 'bus' , onColor: MSRed, offColor: MSRed},
                                                { id: 'alias.0.Test.cardSchedule1', name: 'Text 3', icon: 'train' , onColor: MSGreen, offColor: MSGreen},
                                                { id: 'alias.0.Test.cardSchedule1', name: 'Text 4', icon: 'bus' , onColor: MSYellow, offColor: MSYellow},
                                                { id: 'alias.0.Test.cardSchedule1', name: 'Text 5', icon: 'train' , onColor: colorSpotify, offColor: colorSpotify},
                                                { id: 'alias.0.Test.cardSchedule1', name: 'Text 6', icon: 'bus' , onColor: colorAlexa, offColor: colorAlexa},
                                        • D
                                          D
                                          danny_v1
                                          #7092
                                          @armilar
                                          Danke für die schnelle Antwort. Ok hatte mir da etwas anderes drunter vorgestellt :)
                                          Hätte gedacht ist irgendwie eine Art Kalender mit den 6 nächsten Einträgen oder so.
                                          84.0k
