  4. Test Adapter Bosch ebik connect / flow
208 Beiträge 41 Kommentatoren 59.1k Aufrufe 46 Beobachtet
    Ja,habe ich und auch schon neugestartet.
    #144
    @spectrum1981
    Dann zeig mal wie du da insgesamt unterwegs bist...
    iob diag
    in der Langfassung.
      @spectrum1981
      iob diag
      in der Langfassung.
      #145
      Klar. Hier haste einiges zu lesen :)
      Und schon mal jetzt vielen Dank für die Hilfe!
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       21:53:35 up  4:53,  2 users,  load average: 1.13, 0.72, 0.53
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2025-03-04 21:53:35 CET
                 Universal time: Tue 2025-03-04 20:53:35 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev influxdb gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout sudo audio video plugdev bluetooth redis gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        3.1G        3.1G        0.0K        1.6G        4.6G
      Swap:            99M          0B         99M
      Total:          7.9G        3.1G        3.2G
      Active iob-Instances:   25
               7812 M total memory
               3102 M used memory
               3439 M active memory
               1039 M inactive memory
               3137 M free memory
                122 M buffer memory
               1449 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 21:53:36 up  4:53,  2 users,  load average: 1.13, 0.72, 0.53
      Tasks: 185 total,   2 running, 183 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 23.5 us,  8.8 sy,  0.0 ni, 67.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7812.3 total,   3130.7 free,   3105.0 used,   1576.6 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   4552.9 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      /dev/root      ext4       58G   16G   40G  29% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  892K  1.6G   1% /run
      /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      [Tue Mar  4 17:00:27 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:D6:FF:DA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=43dc5f67-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue Mar  4 17:00:28 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Mar  4 17:00:28 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Tue Mar  4 17:00:30 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      5.5G    /var/
      4.1G    /var/log
      4.0G    /var/log/journal/fac7f0655ecd4193826bcb0a2d76a163
      818M    /var/lib
      Archived and active journals take up 3.9G in the file system.
      /opt/iobroker/backups:
      2.6G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      129M    /opt/iobroker/iobroker-data/
      104M    /opt/iobroker/iobroker-data/history
      14M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      9.8M    /opt/iobroker/iobroker-data/objects.jsonl
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/states.jsonl
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_08e8a16dac1aec11a7fc74e5f01c6278-if00-port0
      /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0050-if00-port0
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB1
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.3
      /usr/bin/node           v20.18.3
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.30.0
      nodejs:
        Installed: 20.18.3-1nodesource1
        Candidate: 20.18.3-1nodesource1
        Version table:
       *** 20.18.3-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           20.18.2-1nodesource1 600
           20.18.1-1nodesource1 600
           20.18.0-1nodesource1 600
           20.17.0-1nodesource1 600
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           12.22.12~dfsg-1~deb11u6 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 17556)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.10
      javascript:     8.8.3
      nodejs modules from github:     3
      +-- iobroker.ankersolix2@1.1.0 (git+ssh://git@github.com/ronny130286/ioBroker.ankersolix2.git#b60ae2fdf9087fc1b27da425d483dec2e0cb0a6b)
      +-- iobroker.bosch-ebike@0.1.12 (git+ssh://git@github.com/TA2k/ioBroker.bosch-ebike.git#71ad7a8139a8af772f671e9c37eddf2ad064c69e)
      +-- iobroker.lovelace@4.1.11 (git+ssh://git@github.com/ioBroker/ioBroker.lovelace.git#0fbfd8694eb401357df1c47fa41dd0e7147e582d)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              -  enabled
      + system.adapter.ankersolix2.0            : ankersolix2           : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 192.168.81.250, run as: admin
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
      + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
      + system.adapter.roborock.0               : roborock              : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
      + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB1
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.4.10   , installed 7.4.10
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "lovelace"     : 4.1.10   , installed 4.1.11
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "roborock"     : 0.6.18   , installed 0.6.18
      Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
      Adapter    "shelly"       : 8.5.1    , installed 8.5.1
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
      Objects and States
      Objects:        7634
      States:         6440
      Hit:1 https://repos.influxdata.com/debian stable InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:5 https://packages.grafana.com/oss/deb stable InRelease
      Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       254603     8885/sshd: pi@pts/0
      tcp        0      0 192.168.81.250:2001     0.0.0.0:*               LISTEN      1001       18662      1312/io.hm-rpc.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17595      1124/io.sonoff.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17076      1297/io.shelly.0
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        14235      525/redis-server 12
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1687       568/sshd: /usr/sbin
      tcp        0      0 192.168.81.250:8091     0.0.0.0:*               LISTEN      1001       16135      1479/io.lovelace.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15604      937/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17334      1456/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       16331      1556/io.socketio.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        15033      794/influxd
      tcp6       0      0 :::7906                 :::*                    LISTEN      1001       15305      1016/io.roborock.0
      tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       254602     8885/sshd: pi@pts/0
      tcp6       0      0 :::3000                 :::*                    LISTEN      110        15550      904/grafana
      tcp6       0      0 :::6824                 :::*                    LISTEN      1001       15304      1016/io.roborock.0
      tcp6       0      0 :::1984                 :::*                    LISTEN      1000       12791      424/go2rtc_linux_ar
      tcp6       0      0 ::1:6379                :::*                    LISTEN      109        14236      525/redis-server 12
      tcp6       0      0 :::8555                 :::*                    LISTEN      1000       12794      424/go2rtc_linux_ar
      tcp6       0      0 :::8554                 :::*                    LISTEN      1000       14542      424/go2rtc_linux_ar
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1689       568/sshd: /usr/sbin
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17275      1430/io.mihome-vacu
      udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       18954      1441/io.mihome-vacu
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1645       419/avahi-daemon: r
      udp        0      0 0.0.0.0:55408           0.0.0.0:*                           108        1647       419/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12811      737/dhcpcd
      udp6       0      0 :::546                  :::*                                0          1702       737/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        1646       419/avahi-daemon: r
      udp6       0      0 :::35851                :::*                                108        1648       419/avahi-daemon: r
      2025-03-04 21:50:14.330  - info: smartmeter.0 (1379) Received 22 values, 13 updated
      2025-03-04 21:50:22.050  - info: javascript.0 (1070) script.js.fussbodenheizung.steuerung: Temperatur kleiner als: 19.89 Heizkreis Flur OG wird eingeschaltet
      2025-03-04 21:50:25.349  - info: smartmeter.0 (1379) Received 22 values, 14 updated
      2025-03-04 21:50:36.328  - info: smartmeter.0 (1379) Received 22 values, 11 updated
      2025-03-04 21:50:47.319  - info: smartmeter.0 (1379) Received 22 values, 11 updated
      2025-03-04 21:50:58.323  - info: smartmeter.0 (1379) Received 22 values, 12 updated
      2025-03-04 21:51:09.318  - info: smartmeter.0 (1379) Received 22 values, 10 updated
      2025-03-04 21:51:20.334  - info: smartmeter.0 (1379) Received 22 values, 10 updated
      2025-03-04 21:51:31.327  - info: smartmeter.0 (1379) Received 22 values, 8 updated
      2025-03-04 21:51:42.333  - info: smartmeter.0 (1379) Received 22 values, 8 updated
      2025-03-04 21:51:53.373  - info: smartmeter.0 (1379) Received 22 values, 10 updated
      2025-03-04 21:52:04.357  - info: smartmeter.0 (1379) Received 22 values, 13 updated
      2025-03-04 21:52:15.324  - info: smartmeter.0 (1379) Received 22 values, 10 updated
      2025-03-04 21:52:26.316  - info: smartmeter.0 (1379) Received 22 values, 9 updated
      2025-03-04 21:52:28.508  - info: javascript.0 (1070) script.js.fussbodenheizung.steuerung: Temperatur größer als: 21.53 Heizkreis Kind wird ausgeschaltet
      2025-03-04 21:52:37.342  - info: smartmeter.0 (1379) Received 22 values, 12 updated
      2025-03-04 21:52:48.340  - info: smartmeter.0 (1379) Received 22 values, 13 updated
      2025-03-04 21:52:59.328  - info: smartmeter.0 (1379) Received 22 values, 13 updated
      2025-03-04 21:53:10.326  - info: smartmeter.0 (1379) Received 22 values, 9 updated
      2025-03-04 21:53:21.350  - info: smartmeter.0 (1379) Received 22 values, 10 updated
      2025-03-04 21:53:32.359  - info: smartmeter.0 (1379) Received 22 values, 11 updated
      2025-03-04 21:53:43.328  - info: smartmeter.0 (1379) Received 22 values, 9 updated
      2025-03-04 21:53:54.307  - info: smartmeter.0 (1379) Received 22 values, 7 updated
      2025-03-04 21:54:05.349  - info: smartmeter.0 (1379) Received 22 values, 13 updated
      2025-03-04 21:54:16.326  - info: smartmeter.0 (1379) Received 22 values, 12 updated
      iob diag has finished.
      Copy text starting here:
                              v.2025-02-23
               Icon name: computer
            Architecture: arm64
      Kernel:                 aarch64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      Recommended versions are nodejs 20.18.3 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            7.8G        3.1G        3.3G        0.0K        1.4G        4.6G
      Swap:            99M          0B         99M
      Total:          7.9G        3.1G        3.4G
      ioBroker Core:          js-controller           7.0.6
                              admin                   7.4.10
      Objects type: redis
      States  type: redis
      Objects:                7634
      States:                 6440
      Size of iob-Database:
      === Mark text until here for copying ===
        ```bash
        Script v.2025-02-23
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 7812 M total memory
                 3102 M used memory
                 3137 M free memory
                  122 M buffer memory
                 1449 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /var:
        5.5G    /var/
        4.1G    /var/log
        818M    /var/lib
        USB-Devices by-id:
        HINT:
        /dev/ttyUSB1
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: redis
        States  type: redis
        Hosts:
        admin:          7.4.10
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        7634
        States:         6440
        Pending Updates: 0
                                v.2025-02-23
                 Icon name: computer
              Architecture: arm64
        Kernel:                 aarch64
        Userland:               64 bit
        User-ID:                1000
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        MEMORY:
        Swap:            99M          0B         99M
                                admin                   7.4.10
        Objects type: redis
        States  type: redis
        Objects:                7634
        States:                 6440
        #146
        @spectrum1981 sagte in Test Adapter Bosch ebik connect / flow:
        Nee, muss ich nicht.
        Bring das per NEUINSTALLATION auf Debian 12 'Bookworm'.
        Danach schau ich mir das gegebenenfalls weiter an.
          #147
          Ok, das hier ist keine Option auch wenn nicht die Sauberste? Da ist leider noch mehr drauf wie der iobroker alleine :(
          https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
            #148
            @spectrum1981
            Nicht wirklich.
              @spectrum1981
              Nicht wirklich.
              #149
              Ok, ich plane das mal und werde das angehen. Vielen Dank!
                #150
                @spectrum1981
                Ein Backup-Konzept musste ja eh haben, egal wieviel Zeug auf der Kiste läuft.
                Könnte ja auch sein, dass der Hobel aus anderen Gründen neuinstalliert werden muss.
                  schienw
                  #151
                  Hallo McLane,
                  eine Frage, was machst du mit den Daten der einzelnen Ausfahrten?
                  Ich würde mir gerne auch meine Fahrten, vor allem die unterschiedlichen Stufen, anzeigen lassen. Vielleicht sogar die map dazu. Hast du hierzu einen Ansatz wie die Daten zu visualisieren sind?
                  Da
                  nke
                  Schienw
                  M bahnuhrB 2 Antworten Letzte Antwort
                  • S schienw
                    Hallo McLane,
                    Da
                    nke
                    Schienw
                    McLane
                    schrieb am zuletzt editiert von McLane
                    #152
                    @schienw Da ich mit der Trennung der beiden Adapter nicht wirklich weiter gekommen bin, visualisiere ich im Moment nur meine gefahrenen Kilometer in einer Jahrestabelle. Letzte Woche wollte ich noch mal zum Vergleich den onebikeapp-ios Link von der Instanz 2 über die Konsole holen, und selbst das geht jetzt nicht mehr, weil die Browser alle melden, das Cookies nicht gefunden wurden. Ein entsprechender Link wurde nicht wieder angezeigt. Hoffe da irgendwann weiter zu kommen.
                    Was die einzelnen Werte in den "assistModeUsage" Spalten bedeuten, kann ich dir nicht sagen.
                    Hoffe du kommst weiter!
                    Jo
                    • S schienw
                      Hallo McLane,
                      Da
                      nke
                      Schienw
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      #153
                      @schienw sagte in Test Adapter Bosch ebik connect / flow:
                      Suche benutzt ?
                      z.B. hier:
                      https://forum.iobroker.net/topic/55918/maps-mit-streckendarstellung/47?_=1741421233456
                      Danke.
                      • bahnuhrB bahnuhr
                        Suche benutzt ?
                        z.B. hier:
                        schienw
                        #154
                        @bahnuhr
                        anscheinend nicht erfolgreich, aber dank deiner Hilfe bin ich jetzt schon sehr weit gekommen.
                        Ich kann mir in einer Tabelle alle Fahrten mit Datum und Fahrstrecke je Unterstützung anzeigen lassen. Zu den Touren werden in der zweiten Spalte auch alle Maps in klein angezeigt, Mittelpunkt ist Start der Tour.
                        Als nächstes versuche ich nun noch das Höhenprofil als Grafik anzeigen zu lassen.
                        Vielen Dank
                        Schienw
                        • S schienw
                          @bahnuhr
                          Vielen Dank
                          Schienw
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          #155
                          Na, dann stell doch deine Lösung mal hier ein.
                          Danke.
                          • bahnuhrB bahnuhr
                            schienw
                            #156
                            @bahnuhr
                            Anbei mein Script:
                            // Script um aus den DP vom Adapter "bosch-ebike" eine MAP zu erstellen und den Weg zu zeichnen
                            // bahnuhr, 03_2024
                            // Variablen
                                var poly ="";       // hier werden die GPS gespeichert
                               // var trip = "03";    // DP bei den Objekten der eingelesen werden soll: bosch-ebike.0.trips.xx.details
                                var logging = true;
                                var center_gps = "53.465, 11.71";    // Mittelpunkt der Karte
                                var zoom = 17                       // Zoom der Karte
                                var pfad = "route.html"             // Dateiname - wird in vis.0 gespeichert
                            // GPS einlesen und der Variablen poly zuweisen
                            // html erzeugen und speichern in /vis.0/xxx.html
                                var string = '<!DOCTYPE html>\n<html>\n<head>\n<title>Simple Leaflet Map</title>\n<meta charset="utf-8" />\n'
                                string = string + '<body>\n'
                                string = string + '<table border=0>'
                                string = string + '<tr>'
                                const idsCO2 = $('bosch-ebike.0.trips.*.id');
                                var f = 2
                                var hilf = 0
                                idsCO2.each(function(id, i) {
                                    var poly ="";
                                  var h= getState(id).val
                                  if (i < 9){
                                      ii = i + 1
                                    hilf = "0" + ii
                                  else{
                                    ii =i + 1
                                    hilf = i + 1
                                 distance = 0
                                  var distance = getState("bosch-ebike.0.trips." + hilf + ".attributes.distance").val;
                                  var startTime = getState("bosch-ebike.0.trips." + hilf + ".attributes.startTime").val;
                                  var ModeUsage01_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage01.name").val;
                                  var ModeUsage01_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage01.assistModeUsage").val;
                                  var ModeUsage01_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage02.color").val;
                                  var ModeUsage02_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage02.name").val;
                                  var ModeUsage02_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage02.assistModeUsage").val;
                                  var ModeUsage02_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage03.color").val;
                                  var ModeUsage03_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage03.name").val;
                                  var ModeUsage03_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage03.assistModeUsage").val;
                                  var ModeUsage03_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage04.color").val;
                                  var ModeUsage04_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage04.name").val;
                                  var ModeUsage04_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage04.assistModeUsage").val;
                                  var ModeUsage04_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage05.color").val;
                                  var ModeUsage05_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage05.name").val;
                                  var ModeUsage05_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage05.assistModeUsage").val;
                                  var ModeUsage05_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage05.color").val;
                                  var date = formatDate(startTime, "TT.MM.JJJJ SS:mm")
                                  string = string + '<td>'
                                  string = string + date + ' ' + distance/1000 + " KM"
                                      string = string + '<td bgcolor=yellow>'
                                        string = string + ModeUsage01_name
                                      string = string + '</td>'
                                      string = string + '<td bgcolor=blue>'
                                        string = string + ModeUsage02_name
                                      string = string + '<td bgcolor=green>'
                                        string = string + ModeUsage03_name
                                      string = string + '<td bgcolor=orange>'
                                        string = string + ModeUsage04_name
                                      string = string + '<td bgcolor=red>'
                                        string = string + ModeUsage05_name
                                    string = string + '</tr>'
                                        string = string + ModeUsage01_assistModeUsage/1000
                                        string = string + ModeUsage02_assistModeUsage/1000
                                        string = string + ModeUsage03_assistModeUsage/1000
                                        string = string + ModeUsage04_assistModeUsage/1000
                                        string = string + ModeUsage05_assistModeUsage/1000
                                    var Prokm = distance /100
                                        string = string + Math.round(ModeUsage01_assistModeUsage/Prokm) + ' %'
                                        string = string + Math.round(ModeUsage02_assistModeUsage/Prokm) + ' %'
                                        string = string + Math.round(ModeUsage03_assistModeUsage/Prokm) + ' %'
                                        string = string + Math.round(ModeUsage04_assistModeUsage/Prokm) + ' %'
                                        string = string + Math.round(ModeUsage05_assistModeUsage/Prokm) + ' %'
                                  string = string + '</table>'
                                    var poly ="";
                                    var string3 = "";
                                    var obj = JSON.parse(getState("bosch-ebike.0.trips." + hilf + ".details").val);
                                    var end = obj.activityData.length - 1;
                                    var center_gps = '"' + obj.activityData[30].lat + ', ' + obj.activityData[30].lon + '"';
                                for (var x=0; x<=end; x++) {
                                    if (obj.activityData[x].lat != null)        {
                                      poly = poly + "["+obj.activityData[x].lat+", "+obj.activityData[x].lon+"]"
                                    if (x < end) poly = poly + ","
                                    else      {
                                if (logging) log (poly);
                                var center_gps = "48.90376, 11.93504";    // Mittelpunkt der Karte
                                var zoom = 11
                                string = string + '<link rel="stylesheet" href="https://unpkg.com/leaflet@1.6.0/dist/leaflet.css"integrity="sha512-xwE/Az9zrjBIphAcBb3F6JVqxf46+CDLwfLMHloNu6KEQCAWi6HcDUbeOfBIptF7tcCzusKFjFw2yuvEpDL9wQ=="crossorigin=""/></head>\n'
                                string = string + '<body>\n<div id="map' + hilf + '" style="width: 600px; height: 400px"></div>\n<script src="https://unpkg.com/leaflet@1.6.0/dist/leaflet.js"integrity="sha512-gZwIG9x3wUXg2hdXF6+rVkLF/0Vi9U8D2Ntg4Ga5I5BZpVkVxlJWbSQtXPSiUTtC0TjtGOmxa1AJPuV0CPthew=="crossorigin=""></script>\n<script>\n'
                                string = string + "var map"+  hilf + " = L.map('map" + hilf + "').setView([" + center_gps + "], " + zoom + ");\n"
                                string = string + "mapLink = '<a href=" + '"http://openstreetmap.org"' + ">OpenStreetMap</a>';\n"
                                string = string + "L.tileLayer( 'http://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png', {attribution: '&copy; ' + mapLink + ' Contributors', maxZoom: 18,}).addTo(map" + hilf + ");\n"
                                string = string + 'var polyline = L.polyline([ \n' + poly + '\n], { color: "blue", weight: 3, opacity: .7, lineJoin: "round" } ).addTo(map' + hilf + ');\n'
                                string = string + '</script>\n'
                                string = string + '</body>\n</html>'
                                writeFile("vis.0", "/" + pfad, string, (error) => {
                                    if (logging) log('Datei "" gespeichert!');
                            bahnuhrB ChaotC 2 Antworten Letzte Antwort
                            • S schienw
                              @bahnuhr
                              Anbei mein Script:
                              // bahnuhr, 03_2024
                              // Variablen
                                  var logging = true;
                                  var f = 2
                                  var hilf = 0
                                      var poly ="";
                                    if (i < 9){
                                        ii = i + 1
                                      hilf = "0" + ii
                                    else{
                                      ii =i + 1
                                      hilf = i + 1
                                   distance = 0
                                      var poly ="";
                                      var string3 = "";
                                      else      {
                                  var zoom = 11
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              #157
                              @schienw
                              Super
                              Und wenns funktioniert noch besser.
                              Danke.
                                ae55
                                schrieb am zuletzt editiert von ae55
                                #158
                                Habe gerade versucht, den Adapter einzurichten, jedoch kam keine onebikeapp-ios:// URL sondern nur ein Link, der mit "https://p9.authz.bosch.com/auth/realms/obc/broker/skid/endpoint" beginnt...
                                Ich habe die Flow App mit einem Kiox300 und einer LED Remote am E-Bike.
                                Samson71S T 2 Antworten Letzte Antwort
                                • A ae55
                                  Samson71S Offline
                                  Samson71S Offline
                                  Samson71
                                  #159
                                  @ae55
                                  Warum auf Englisch im deutschen Bereich und in einem deutschen Post? Der IP nach sollte Dir Deutsch nicht fremd sein.
                                  Markus
                                  Bitte beachten:
                                  • Samson71S Samson71
                                    @ae55
                                    ae55
                                    #160
                                    @samson71 Sorry, war es halt noch gewohnt vom Home Assistant-Forum alles auf Englisch zu schreiben :-)...
                                    • A ae55
                                      tombox
                                      #161
                                      @ae55 also ich würde vermuten der browser blockiert irgendwas wie cookies
                                      • T tombox
                                        ae55
                                        #162
                                        @tombox Ich habe in den Einstellungen von Chrome Drittanbieter-Cookies auf "immer erlaubt" gesetzt, dies hat das Problem nicht gelöst...
                                        Wie könnte ich es lösen?
                                        • A ae55
                                          Samson71S Offline
                                          Samson71S Offline
                                          Samson71
                                          #163
                                          @ae55
                                          Gerade davon und deswegen heben wir bzw. dieses Forum sich (bewusst) ab 😄
                                          Markus
                                          Bitte beachten:
