  4. Test Adapter Bosch ebik connect / flow
    6.8k
208 Beiträge 41 Kommentatoren 59.1k Aufrufe 46 Beobachtet
  • ? Offline
    #138
    Hallo!
    Ich habe auch gerade versucht den Adapter zu installieren, bekomme aber diese Fehlermeldung bei der Installation. Jemand eine Idee woran das liegen kann?
    /home/iobroker/.cache/node-gyp/20.18.3/include/node/node_version.h:103: warning: "NAPI_VERSION" redefined 103 | #define NAPI_VERSION 9 | In file included from /home/iobroker/.cache/node-gyp/20.18.3/include/node/node_api.h:12, from ../node_modules/node-addon-api/napi.h:13, from ../src/CanvasError.h:4, from ../src/Image.h:6, from ../src/Image.cc:3:/home/iobroker/.cache/node-gyp/20.18.3/include/node/js_native_api.h:20: note: this is the location of the previous definition 20 | #define NAPI_VERSION 8 |
    ../src/Image.cc: In member function ‘cairo_status_t Image::loadSVGFromBuffer(uint8_t*, unsigned int)’:../src/Image.cc:1483:3: error: ‘rsvg_handle_get_intrinsic_size_in_pixels’ was not declared in this scope; did you mean ‘rsvg_handle_get_intrinsic_dimensions’?
    1483 | rsvg_handle_get_intrinsic_size_in_pixels(_rsvg, &d_width, &d_height); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ | rsvg_handle_get_intrinsic_dimensions
    make: *** [canvas.target.mk:162: Release/obj.target/canvas/src/Image.o] Error 1
    gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok
    up to date in 2m
    run `npm fund` for details
    upload [3] bosch-ebike.admin /opt/iobroker/node_modules/iobroker.bosch-ebike/admin/bosch-ebike.png bosch-ebike.png image/png
    Updating objects from io-package.json for adapter "bosch-ebike" with version "0.1.12"
    Process exited with code 0
    T Thomas BraunT 2 Antworten Letzte Antwort
      Hallo!
      up to date in 2m
      tombox
      #139
      @spectrum1981 das package canvas macht Probleme gibt es auch schon threads hie im forum
      ich würde probieren
      /opt/iobroker
      npm install canvas
        Hallo!
        up to date in 2m
        #140
        @spectrum1981 sagte in Test Adapter Bosch ebik connect / flow:
        Das kann daran liegen, dass canvas einen ganzen Schwung an -dev-Files benötigt. Sind die Voraussetzungen erfüllt?
        Ich meine ein
        iob fix
        spült die bei Bedarf auf das System. Hängt aber auch mit dem verwendeten Release zusammen. Bist du da mit 'bookworm' / Debian 12 unterwegs?
        • T tombox
          ich würde probieren
          /opt/iobroker
          npm install canvas
          #141
          @tombox
          Ok, jetzt wird es wild. Hier scheint mehr im Argen zu sein:
          pi@raspberrypi:~ $ cd /opt/iobroker
          pi@raspberrypi:/opt/iobroker $ npm install canvas
          npm error code 1
          npm error path /opt/iobroker/node_modules/canvas
          npm error command failed
          npm error command sh -c prebuild-install -r napi || node-gyp rebuild
          npm error make: Entering directory '/opt/iobroker/node_modules/canvas/build'
          npm error   SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
          npm error   COPY Release/canvas-postbuild.node
          npm error   CXX(target) Release/obj.target/canvas/src/backend/Backend.o
          npm error   CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
          npm error   CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
          npm error   CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
          npm error   CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
          npm error   CXX(target) Release/obj.target/canvas/src/Backends.o
          npm error   CXX(target) Release/obj.target/canvas/src/Canvas.o
          npm error   CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
          npm error   CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
          npm error   CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
          npm error   CXX(target) Release/obj.target/canvas/src/closure.o
          npm error   CXX(target) Release/obj.target/canvas/src/color.o
          npm error   CXX(target) Release/obj.target/canvas/src/Image.o
          npm error make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
          npm error prebuild-install warn install No prebuilt binaries found (target=7 runtime=napi arch=arm64 libc= platform=linux)
          npm error gyp info it worked if it ends with ok
          npm error gyp info using node-gyp@10.1.0
          npm error gyp info using node@20.18.3 | linux | arm64
          npm error gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
          npm error gyp info spawn /usr/bin/python3
          npm error gyp info spawn args [
          npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
          npm error gyp info spawn args 'binding.gyp',
          npm error gyp info spawn args '-f',
          npm error gyp info spawn args 'make',
          npm error gyp info spawn args '-I',
          npm error gyp info spawn args '/opt/iobroker/node_modules/canvas/build/config.gypi',
          npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
          npm error gyp info spawn args '/home/iobroker/.cache/node-gyp/20.18.3/include/node/common.gypi',
          npm error gyp info spawn args '-Dlibrary=shared_library',
          npm error gyp info spawn args '-Dvisibility=default',
          npm error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.18.3',
          npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
          npm error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.18.3/<(target_arch)/node.lib',
          npm error gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/canvas',
          npm error gyp info spawn args '-Dnode_engine=v8',
          npm error gyp info spawn args '--depth=.',
          npm error gyp info spawn args '--no-parallel',
          npm error gyp info spawn args '--generator-output',
          npm error gyp info spawn args 'build',
          npm error gyp info spawn args '-Goutput_dir=.'
          npm error gyp info spawn args ]
          npm error gyp info spawn make
          npm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
          npm error In file included from /home/iobroker/.cache/node-gyp/20.18.3/include/node/node.h:76,
          npm error                  from /home/iobroker/.cache/node-gyp/20.18.3/include/node/node_buffer.h:25,
          npm error                  from ../src/Canvas.cc:23:
          npm error /home/iobroker/.cache/node-gyp/20.18.3/include/node/node_version.h:103: warning: "NAPI_VERSION" redefined
          npm error   103 | #define NAPI_VERSION 9
          npm error       |
          npm error In file included from /home/iobroker/.cache/node-gyp/20.18.3/include/node/node_api.h:12,
          npm error                  from ../node_modules/node-addon-api/napi.h:13,
          npm error                  from ../src/backend/Backend.h:6,
          npm error                  from ../src/Canvas.h:7,
          npm error                  from ../src/Canvas.cc:3:
          npm error /home/iobroker/.cache/node-gyp/20.18.3/include/node/js_native_api.h:20: note: this is the location of the previous definition
          npm error    20 | #define NAPI_VERSION 8
          npm error       |
          npm error                  from ../src/Image.cc:11:
          npm error       |
          npm error                  from ../src/CanvasError.h:4,
          npm error                  from ../src/Image.h:6,
          npm error                  from ../src/Image.cc:3:
          npm error       |
          npm error ../src/Image.cc: In member function ‘cairo_status_t Image::loadSVGFromBuffer(uint8_t*, unsigned int)’:
          npm error ../src/Image.cc:1483:3: error: ‘rsvg_handle_get_intrinsic_size_in_pixels’ was not declared in this scope; did you mean ‘rsvg_handle_get_intrinsic_dimensions’?
          npm error  1483 |   rsvg_handle_get_intrinsic_size_in_pixels(_rsvg, &d_width, &d_height);
          npm error       |   ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
          npm error       |   rsvg_handle_get_intrinsic_dimensions
          npm error make: *** [canvas.target.mk:162: Release/obj.target/canvas/src/Image.o] Error 1
          npm error gyp ERR! build error
          npm error gyp ERR! stack Error: `make` failed with exit code: 2
          npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)
          npm error gyp ERR! System Linux 6.1.21-v8+
          npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          npm error gyp ERR! cwd /opt/iobroker/node_modules/canvas
          npm error gyp ERR! node -v v20.18.3
          npm error gyp ERR! node-gyp -v v10.1.0
          npm error gyp ERR! not ok
          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-03-04T18_49_02_174Z-debug-0.log
          pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/
          pi@raspberrypi:/opt/iobroker $ npm list canvas
          iobroker.inst@3.0.0 /opt/iobroker
          └── (empty)
            @tombox
            npm error code 1
            npm error       |
            npm error       |
            npm error       |
            npm error       |
            └── (empty)
            #142
            @spectrum1981
            Halb so wild, wenn alles korrekt installiert (und auf aktuellem Stand) ist:
            echad@chet:~ $ npm install canvas
            added 37 packages in 3m
            9 packages are looking for funding
            npm notice
            npm notice New major version of npm available! 10.8.2 -> 11.1.0
            npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.1.0
            npm notice To update run: npm install -g npm@11.1.0
            npm notice
            echad@chet:~ $ npm ls canvas
            echad@ /home/echad
            └── canvas@3.1.0
            Da stimmen also die Voraussetzungen nicht. Hast du den Fixer ausgeführt?
              @spectrum1981
              npm notice
              npm notice
              echad@ /home/echad
              └── canvas@3.1.0
              #143
              Ja,habe ich und auch schon neugestartet.
                #144
                @spectrum1981
                Dann zeig mal wie du da insgesamt unterwegs bist...
                iob diag
                in der Langfassung.
                  @spectrum1981
                  iob diag
                  in der Langfassung.
                  #145
                  Klar. Hier haste einiges zu lesen :)
                  Und schon mal jetzt vielen Dank für die Hilfe!
                  ```bash
                  Script v.2025-02-23
                  *** BASE SYSTEM ***
                     Static hostname: raspberrypi
                           Icon name: computer
                    Operating System: Debian GNU/Linux 11 (bullseye)
                              Kernel: Linux 6.1.21-v8+
                        Architecture: arm64
                  OS is similar to:
                  Model           : Raspberry Pi 4 Model B Rev 1.4
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   21:53:35 up  4:53,  2 users,  load average: 1.13, 0.72, 0.53
                  CPU threads: 4
                  *** LIFE CYCLE STATUS ***
                  Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** TIME AND TIMEZONES ***
                                 Local time: Tue 2025-03-04 21:53:35 CET
                             Universal time: Tue 2025-03-04 20:53:35 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  pi
                  HOME=/home/pi
                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev influxdb gpio i2c spi iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout sudo audio video plugdev bluetooth redis gpio i2c
                  *** DISPLAY-SERVER SETUP ***
                  Display-Server: false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            7.8G        3.1G        3.1G        0.0K        1.6G        4.6G
                  Swap:            99M          0B         99M
                  Total:          7.9G        3.1G        3.2G
                  Active iob-Instances:   25
                           7812 M total memory
                           3102 M used memory
                           3439 M active memory
                           1039 M inactive memory
                           3137 M free memory
                            122 M buffer memory
                           1449 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  top - 21:53:36 up  4:53,  2 users,  load average: 1.13, 0.72, 0.53
                  Tasks: 185 total,   2 running, 183 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 23.5 us,  8.8 sy,  0.0 ni, 67.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   7812.3 total,   3130.7 free,   3105.0 used,   1576.6 buff/cache
                  MiB Swap:    100.0 total,    100.0 free,      0.0 used.   4552.9 avail Mem
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  No critical errors detected
                  *** FILESYSTEM ***
                  /dev/root      ext4       58G   16G   40G  29% /
                  devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                  tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                  tmpfs          tmpfs     1.6G  892K  1.6G   1% /run
                  /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
                  tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                  [Tue Mar  4 17:00:27 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:D6:FF:DA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=43dc5f67-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Tue Mar  4 17:00:28 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Tue Mar  4 17:00:28 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Tue Mar  4 17:00:30 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  Show mounted filesystems:
                  TARGET  SOURCE         FSTYPE OPTIONS
                  /       /dev/mmcblk0p2 ext4   rw,noatime
                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                  /var:
                  5.5G    /var/
                  4.1G    /var/log
                  4.0G    /var/log/journal/fac7f0655ecd4193826bcb0a2d76a163
                  818M    /var/lib
                  Archived and active journals take up 3.9G in the file system.
                  /opt/iobroker/backups:
                  2.6G    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  129M    /opt/iobroker/iobroker-data/
                  104M    /opt/iobroker/iobroker-data/history
                  14M     /opt/iobroker/iobroker-data/files
                  13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                  9.8M    /opt/iobroker/iobroker-data/objects.jsonl
                  6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                  2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                  1.6M    /opt/iobroker/iobroker-data/states.jsonl
                  1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_08e8a16dac1aec11a7fc74e5f01c6278-if00-port0
                  /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0050-if00-port0
                  *** ZigBee Settings ***
                  HINT:
                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                  /dev/ttyUSB1
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.18.3
                  /usr/bin/node           v20.18.3
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.30.0
                  nodejs:
                    Installed: 20.18.3-1nodesource1
                    Candidate: 20.18.3-1nodesource1
                    Version table:
                   *** 20.18.3-1nodesource1 600
                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                       20.18.2-1nodesource1 600
                       20.18.1-1nodesource1 600
                       20.18.0-1nodesource1 600
                       20.17.0-1nodesource1 600
                       20.16.0-1nodesource1 600
                       20.15.1-1nodesource1 600
                       20.15.0-1nodesource1 600
                       20.14.0-1nodesource1 600
                       20.13.1-1nodesource1 600
                       20.13.0-1nodesource1 600
                       20.12.2-1nodesource1 600
                       20.12.1-1nodesource1 600
                       20.12.0-1nodesource1 600
                       20.11.1-1nodesource1 600
                       20.11.0-1nodesource1 600
                       20.10.0-1nodesource1 600
                       20.9.0-1nodesource1 600
                       20.8.1-1nodesource1 600
                       20.8.0-1nodesource1 600
                       20.7.0-1nodesource1 600
                       20.6.1-1nodesource1 600
                       20.6.0-1nodesource1 600
                       20.5.1-1nodesource1 600
                       20.5.0-1nodesource1 600
                       20.4.0-1nodesource1 600
                       20.3.1-1nodesource1 600
                       20.3.0-1nodesource1 600
                       20.2.0-1nodesource1 600
                       20.1.0-1nodesource1 600
                       20.0.0-1nodesource1 600
                       12.22.12~dfsg-1~deb11u6 500
                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                       12.22.12~dfsg-1~deb11u4 500
                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  At least one iobroker host is running.
                  Objects type: redis
                  States  type: redis
                  Hosts:
                  raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 17556)
                  Core adapters versions
                  js-controller:  7.0.6
                  admin:          7.4.10
                  javascript:     8.8.3
                  nodejs modules from github:     3
                  +-- iobroker.ankersolix2@1.1.0 (git+ssh://git@github.com/ronny130286/ioBroker.ankersolix2.git#b60ae2fdf9087fc1b27da425d483dec2e0cb0a6b)
                  +-- iobroker.bosch-ebike@0.1.12 (git+ssh://git@github.com/TA2k/ioBroker.bosch-ebike.git#71ad7a8139a8af772f671e9c37eddf2ad064c69e)
                  +-- iobroker.lovelace@4.1.11 (git+ssh://git@github.com/ioBroker/ioBroker.lovelace.git#0fbfd8694eb401357df1c47fa41dd0e7147e582d)
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              -  enabled
                  + system.adapter.ankersolix2.0            : ankersolix2           : raspberrypi                              -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                  + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                  + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
                  + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
                  + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                  + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 192.168.81.250, run as: admin
                  + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                  + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                  + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                  + system.adapter.roborock.0               : roborock              : raspberrypi                              -  enabled
                  + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
                  + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                  + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                  + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB1
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Upgrade policy: none
                  Installed ioBroker-Adapters
                  Used repository: stable
                  Adapter    "admin"        : 7.4.10   , installed 7.4.10
                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                  Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                  Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                  Adapter    "iot"          : 3.3.0    , installed 3.3.0
                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                  Controller "js-controller": 7.0.6    , installed 7.0.6
                  Adapter    "lovelace"     : 4.1.10   , installed 4.1.11
                  Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                  Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                  Adapter    "roborock"     : 0.6.18   , installed 0.6.18
                  Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
                  Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                  Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                  Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                  Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                  Adapter    "web"          : 6.2.5    , installed 6.2.5
                  Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
                  Objects and States
                  Objects:        7634
                  States:         6440
                  Hit:1 https://repos.influxdata.com/debian stable InRelease
                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                  Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       254603     8885/sshd: pi@pts/0
                  tcp        0      0 192.168.81.250:2001     0.0.0.0:*               LISTEN      1001       18662      1312/io.hm-rpc.0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17595      1124/io.sonoff.0
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17076      1297/io.shelly.0
                  tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        14235      525/redis-server 12
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1687       568/sshd: /usr/sbin
                  tcp        0      0 192.168.81.250:8091     0.0.0.0:*               LISTEN      1001       16135      1479/io.lovelace.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15604      937/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17334      1456/io.web.0
                  tcp6       0      0 :::8084                 :::*                    LISTEN      1001       16331      1556/io.socketio.0
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        15033      794/influxd
                  tcp6       0      0 :::7906                 :::*                    LISTEN      1001       15305      1016/io.roborock.0
                  tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       254602     8885/sshd: pi@pts/0
                  tcp6       0      0 :::3000                 :::*                    LISTEN      110        15550      904/grafana
                  tcp6       0      0 :::6824                 :::*                    LISTEN      1001       15304      1016/io.roborock.0
                  tcp6       0      0 :::1984                 :::*                    LISTEN      1000       12791      424/go2rtc_linux_ar
                  tcp6       0      0 ::1:6379                :::*                    LISTEN      109        14236      525/redis-server 12
                  tcp6       0      0 :::8555                 :::*                    LISTEN      1000       12794      424/go2rtc_linux_ar
                  tcp6       0      0 :::8554                 :::*                    LISTEN      1000       14542      424/go2rtc_linux_ar
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          1689       568/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17275      1430/io.mihome-vacu
                  udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       18954      1441/io.mihome-vacu
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1645       419/avahi-daemon: r
                  udp        0      0 0.0.0.0:55408           0.0.0.0:*                           108        1647       419/avahi-daemon: r
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12811      737/dhcpcd
                  udp6       0      0 :::546                  :::*                                0          1702       737/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        1646       419/avahi-daemon: r
                  udp6       0      0 :::35851                :::*                                108        1648       419/avahi-daemon: r
                  2025-03-04 21:50:14.330  - info: smartmeter.0 (1379) Received 22 values, 13 updated
                  2025-03-04 21:50:22.050  - info: javascript.0 (1070) script.js.fussbodenheizung.steuerung: Temperatur kleiner als: 19.89 Heizkreis Flur OG wird eingeschaltet
                  2025-03-04 21:50:25.349  - info: smartmeter.0 (1379) Received 22 values, 14 updated
                  2025-03-04 21:50:36.328  - info: smartmeter.0 (1379) Received 22 values, 11 updated
                  2025-03-04 21:50:47.319  - info: smartmeter.0 (1379) Received 22 values, 11 updated
                  2025-03-04 21:50:58.323  - info: smartmeter.0 (1379) Received 22 values, 12 updated
                  2025-03-04 21:51:09.318  - info: smartmeter.0 (1379) Received 22 values, 10 updated
                  2025-03-04 21:51:20.334  - info: smartmeter.0 (1379) Received 22 values, 10 updated
                  2025-03-04 21:51:31.327  - info: smartmeter.0 (1379) Received 22 values, 8 updated
                  2025-03-04 21:51:42.333  - info: smartmeter.0 (1379) Received 22 values, 8 updated
                  2025-03-04 21:51:53.373  - info: smartmeter.0 (1379) Received 22 values, 10 updated
                  2025-03-04 21:52:04.357  - info: smartmeter.0 (1379) Received 22 values, 13 updated
                  2025-03-04 21:52:15.324  - info: smartmeter.0 (1379) Received 22 values, 10 updated
                  2025-03-04 21:52:26.316  - info: smartmeter.0 (1379) Received 22 values, 9 updated
                  2025-03-04 21:52:28.508  - info: javascript.0 (1070) script.js.fussbodenheizung.steuerung: Temperatur größer als: 21.53 Heizkreis Kind wird ausgeschaltet
                  2025-03-04 21:52:37.342  - info: smartmeter.0 (1379) Received 22 values, 12 updated
                  2025-03-04 21:52:48.340  - info: smartmeter.0 (1379) Received 22 values, 13 updated
                  2025-03-04 21:52:59.328  - info: smartmeter.0 (1379) Received 22 values, 13 updated
                  2025-03-04 21:53:10.326  - info: smartmeter.0 (1379) Received 22 values, 9 updated
                  2025-03-04 21:53:21.350  - info: smartmeter.0 (1379) Received 22 values, 10 updated
                  2025-03-04 21:53:32.359  - info: smartmeter.0 (1379) Received 22 values, 11 updated
                  2025-03-04 21:53:43.328  - info: smartmeter.0 (1379) Received 22 values, 9 updated
                  2025-03-04 21:53:54.307  - info: smartmeter.0 (1379) Received 22 values, 7 updated
                  2025-03-04 21:54:05.349  - info: smartmeter.0 (1379) Received 22 values, 13 updated
                  2025-03-04 21:54:16.326  - info: smartmeter.0 (1379) Received 22 values, 12 updated
                  iob diag has finished.
                  Copy text starting here:
                                          v.2025-02-23
                           Icon name: computer
                        Architecture: arm64
                  Kernel:                 aarch64
                  Userland:               64 bit
                  Timezone:               Europe/Berlin (CET, +0100)
                  User-ID:                1000
                  Boot Target:            multi-user.target
                  Pending OS-Updates:     0
                  Pending iob updates:    0
                  Nodejs-Installation:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  Recommended versions are nodejs 20.18.3 and npm 10.8.2
                  nodeJS installation is correct
                  MEMORY:
                  Mem:            7.8G        3.1G        3.3G        0.0K        1.4G        4.6G
                  Swap:            99M          0B         99M
                  Total:          7.9G        3.1G        3.4G
                  ioBroker Core:          js-controller           7.0.6
                                          admin                   7.4.10
                  Objects type: redis
                  States  type: redis
                  Objects:                7634
                  States:                 6440
                  Size of iob-Database:
                  === Mark text until here for copying ===
                    ```bash
                    Script v.2025-02-23
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:            99M          0B         99M
                             7812 M total memory
                             3102 M used memory
                             3137 M free memory
                              122 M buffer memory
                             1449 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    *** FILESYSTEM ***
                    /var:
                    5.5G    /var/
                    4.1G    /var/log
                    818M    /var/lib
                    USB-Devices by-id:
                    HINT:
                    /dev/ttyUSB1
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: redis
                    States  type: redis
                    Hosts:
                    admin:          7.4.10
                    javascript:     8.8.3
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        7634
                    States:         6440
                    Pending Updates: 0
                                            v.2025-02-23
                             Icon name: computer
                          Architecture: arm64
                    Kernel:                 aarch64
                    Userland:               64 bit
                    User-ID:                1000
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    MEMORY:
                    Swap:            99M          0B         99M
                                            admin                   7.4.10
                    Objects type: redis
                    States  type: redis
                    Objects:                7634
                    States:                 6440
                    #146
                    Nee, muss ich nicht.
                    Bring das per NEUINSTALLATION auf Debian 12 'Bookworm'.
                    Danach schau ich mir das gegebenenfalls weiter an.
                      #147
                      Ok, das hier ist keine Option auch wenn nicht die Sauberste? Da ist leider noch mehr drauf wie der iobroker alleine :(
                      https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                        #148
                        @spectrum1981
                        Nicht wirklich.
                          @spectrum1981
                          Nicht wirklich.
                          #149
                          Ok, ich plane das mal und werde das angehen. Vielen Dank!
                            #150
                            @spectrum1981
                            Ein Backup-Konzept musste ja eh haben, egal wieviel Zeug auf der Kiste läuft.
                            Könnte ja auch sein, dass der Hobel aus anderen Gründen neuinstalliert werden muss.
                              schienw
                              #151
                              Hallo McLane,
                              eine Frage, was machst du mit den Daten der einzelnen Ausfahrten?
                              Ich würde mir gerne auch meine Fahrten, vor allem die unterschiedlichen Stufen, anzeigen lassen. Vielleicht sogar die map dazu. Hast du hierzu einen Ansatz wie die Daten zu visualisieren sind?
                              Da
                              nke
                              Schienw
                              M bahnuhrB 2 Antworten Letzte Antwort
                              • S schienw
                                Hallo McLane,
                                Da
                                nke
                                Schienw
                                McLane
                                schrieb am zuletzt editiert von McLane
                                #152
                                @schienw Da ich mit der Trennung der beiden Adapter nicht wirklich weiter gekommen bin, visualisiere ich im Moment nur meine gefahrenen Kilometer in einer Jahrestabelle. Letzte Woche wollte ich noch mal zum Vergleich den onebikeapp-ios Link von der Instanz 2 über die Konsole holen, und selbst das geht jetzt nicht mehr, weil die Browser alle melden, das Cookies nicht gefunden wurden. Ein entsprechender Link wurde nicht wieder angezeigt. Hoffe da irgendwann weiter zu kommen.
                                Was die einzelnen Werte in den "assistModeUsage" Spalten bedeuten, kann ich dir nicht sagen.
                                Hoffe du kommst weiter!
                                Jo
                                • S schienw
                                  Hallo McLane,
                                  Da
                                  nke
                                  Schienw
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #153
                                  @schienw sagte in Test Adapter Bosch ebik connect / flow:
                                  Suche benutzt ?
                                  z.B. hier:
                                  https://forum.iobroker.net/topic/55918/maps-mit-streckendarstellung/47?_=1741421233456
                                  Danke.
                                  • bahnuhrB bahnuhr
                                    Suche benutzt ?
                                    z.B. hier:
                                    schienw
                                    #154
                                    @bahnuhr
                                    anscheinend nicht erfolgreich, aber dank deiner Hilfe bin ich jetzt schon sehr weit gekommen.
                                    Ich kann mir in einer Tabelle alle Fahrten mit Datum und Fahrstrecke je Unterstützung anzeigen lassen. Zu den Touren werden in der zweiten Spalte auch alle Maps in klein angezeigt, Mittelpunkt ist Start der Tour.
                                    Als nächstes versuche ich nun noch das Höhenprofil als Grafik anzeigen zu lassen.
                                    Vielen Dank
                                    Schienw
                                    • S schienw
                                      @bahnuhr
                                      Vielen Dank
                                      Schienw
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      #155
                                      Na, dann stell doch deine Lösung mal hier ein.
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        schienw
                                        #156
                                        @bahnuhr
                                        Anbei mein Script:
                                        // Script um aus den DP vom Adapter "bosch-ebike" eine MAP zu erstellen und den Weg zu zeichnen
                                        // bahnuhr, 03_2024
                                        // Variablen
                                            var poly ="";       // hier werden die GPS gespeichert
                                           // var trip = "03";    // DP bei den Objekten der eingelesen werden soll: bosch-ebike.0.trips.xx.details
                                            var logging = true;
                                            var center_gps = "53.465, 11.71";    // Mittelpunkt der Karte
                                            var zoom = 17                       // Zoom der Karte
                                            var pfad = "route.html"             // Dateiname - wird in vis.0 gespeichert
                                        // GPS einlesen und der Variablen poly zuweisen
                                        // html erzeugen und speichern in /vis.0/xxx.html
                                            var string = '<!DOCTYPE html>\n<html>\n<head>\n<title>Simple Leaflet Map</title>\n<meta charset="utf-8" />\n'
                                            string = string + '<body>\n'
                                            string = string + '<table border=0>'
                                            string = string + '<tr>'
                                            const idsCO2 = $('bosch-ebike.0.trips.*.id');
                                            var f = 2
                                            var hilf = 0
                                            idsCO2.each(function(id, i) {
                                                var poly ="";
                                              var h= getState(id).val
                                              if (i < 9){
                                                  ii = i + 1
                                                hilf = "0" + ii
                                              else{
                                                ii =i + 1
                                                hilf = i + 1
                                             distance = 0
                                              var distance = getState("bosch-ebike.0.trips." + hilf + ".attributes.distance").val;
                                              var startTime = getState("bosch-ebike.0.trips." + hilf + ".attributes.startTime").val;
                                              var ModeUsage01_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage01.name").val;
                                              var ModeUsage01_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage01.assistModeUsage").val;
                                              var ModeUsage01_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage02.color").val;
                                              var ModeUsage02_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage02.name").val;
                                              var ModeUsage02_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage02.assistModeUsage").val;
                                              var ModeUsage02_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage03.color").val;
                                              var ModeUsage03_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage03.name").val;
                                              var ModeUsage03_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage03.assistModeUsage").val;
                                              var ModeUsage03_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage04.color").val;
                                              var ModeUsage04_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage04.name").val;
                                              var ModeUsage04_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage04.assistModeUsage").val;
                                              var ModeUsage04_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage05.color").val;
                                              var ModeUsage05_name = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage05.name").val;
                                              var ModeUsage05_assistModeUsage = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage05.assistModeUsage").val;
                                              var ModeUsage05_color = getState("bosch-ebike.0.trips." + hilf + ".attributes.assistModeUsage05.color").val;
                                              var date = formatDate(startTime, "TT.MM.JJJJ SS:mm")
                                              string = string + '<td>'
                                              string = string + date + ' ' + distance/1000 + " KM"
                                                  string = string + '<td bgcolor=yellow>'
                                                    string = string + ModeUsage01_name
                                                  string = string + '</td>'
                                                  string = string + '<td bgcolor=blue>'
                                                    string = string + ModeUsage02_name
                                                  string = string + '<td bgcolor=green>'
                                                    string = string + ModeUsage03_name
                                                  string = string + '<td bgcolor=orange>'
                                                    string = string + ModeUsage04_name
                                                  string = string + '<td bgcolor=red>'
                                                    string = string + ModeUsage05_name
                                                string = string + '</tr>'
                                                    string = string + ModeUsage01_assistModeUsage/1000
                                                    string = string + ModeUsage02_assistModeUsage/1000
                                                    string = string + ModeUsage03_assistModeUsage/1000
                                                    string = string + ModeUsage04_assistModeUsage/1000
                                                    string = string + ModeUsage05_assistModeUsage/1000
                                                var Prokm = distance /100
                                                    string = string + Math.round(ModeUsage01_assistModeUsage/Prokm) + ' %'
                                                    string = string + Math.round(ModeUsage02_assistModeUsage/Prokm) + ' %'
                                                    string = string + Math.round(ModeUsage03_assistModeUsage/Prokm) + ' %'
                                                    string = string + Math.round(ModeUsage04_assistModeUsage/Prokm) + ' %'
                                                    string = string + Math.round(ModeUsage05_assistModeUsage/Prokm) + ' %'
                                              string = string + '</table>'
                                                var poly ="";
                                                var string3 = "";
                                                var obj = JSON.parse(getState("bosch-ebike.0.trips." + hilf + ".details").val);
                                                var end = obj.activityData.length - 1;
                                                var center_gps = '"' + obj.activityData[30].lat + ', ' + obj.activityData[30].lon + '"';
                                            for (var x=0; x<=end; x++) {
                                                if (obj.activityData[x].lat != null)        {
                                                  poly = poly + "["+obj.activityData[x].lat+", "+obj.activityData[x].lon+"]"
                                                if (x < end) poly = poly + ","
                                                else      {
                                            if (logging) log (poly);
                                            var center_gps = "48.90376, 11.93504";    // Mittelpunkt der Karte
                                            var zoom = 11
                                            string = string + '<link rel="stylesheet" href="https://unpkg.com/leaflet@1.6.0/dist/leaflet.css"integrity="sha512-xwE/Az9zrjBIphAcBb3F6JVqxf46+CDLwfLMHloNu6KEQCAWi6HcDUbeOfBIptF7tcCzusKFjFw2yuvEpDL9wQ=="crossorigin=""/></head>\n'
                                            string = string + '<body>\n<div id="map' + hilf + '" style="width: 600px; height: 400px"></div>\n<script src="https://unpkg.com/leaflet@1.6.0/dist/leaflet.js"integrity="sha512-gZwIG9x3wUXg2hdXF6+rVkLF/0Vi9U8D2Ntg4Ga5I5BZpVkVxlJWbSQtXPSiUTtC0TjtGOmxa1AJPuV0CPthew=="crossorigin=""></script>\n<script>\n'
                                            string = string + "var map"+  hilf + " = L.map('map" + hilf + "').setView([" + center_gps + "], " + zoom + ");\n"
                                            string = string + "mapLink = '<a href=" + '"http://openstreetmap.org"' + ">OpenStreetMap</a>';\n"
                                            string = string + "L.tileLayer( 'http://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png', {attribution: '&copy; ' + mapLink + ' Contributors', maxZoom: 18,}).addTo(map" + hilf + ");\n"
                                            string = string + 'var polyline = L.polyline([ \n' + poly + '\n], { color: "blue", weight: 3, opacity: .7, lineJoin: "round" } ).addTo(map' + hilf + ');\n'
                                            string = string + '</script>\n'
                                            string = string + '</body>\n</html>'
                                            writeFile("vis.0", "/" + pfad, string, (error) => {
                                                if (logging) log('Datei "" gespeichert!');
                                        bahnuhrB ChaotC 2 Antworten Letzte Antwort
                                        • S schienw
                                          @bahnuhr
                                          Anbei mein Script:
                                          // bahnuhr, 03_2024
                                          // Variablen
                                              var logging = true;
                                              var f = 2
                                              var hilf = 0
                                                  var poly ="";
                                                if (i < 9){
                                                    ii = i + 1
                                                  hilf = "0" + ii
                                                else{
                                                  ii =i + 1
                                                  hilf = i + 1
                                               distance = 0
                                                  var poly ="";
                                                  var string3 = "";
                                                  else      {
                                              var zoom = 11
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          #157
                                          @schienw
                                          Super
                                          Und wenns funktioniert noch besser.
                                          Danke.
