  4. Test Adapter Log Parser 2.4.x Latest
    1.0k
108 Beiträge 21 Kommentatoren 24.3k Aufrufe 28 Beobachtet
  • AFiA AFi
    Hallo Thomas,
    ich habe zuerst nicht verstanden, dass ich alle Befehle ausführen muss, morgen gehts weiter, ich sende Dir dann eine neue diag.
    Gruß Axel
    AFiA Offline
    AFiA Offline
    AFi
    #90
    Hallo Thomas,
    anbei diag:
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: NUCioBroker
           Icon name: computer-desktop
             Chassis: desktop 🖥️
              Kernel: Linux 6.1.0-31-amd64
        Architecture: x86-64
     Hardware Vendor: Intel_R_ Client Systems
      Hardware Model: NUC8i3BEH
    Firmware Version: BECFL357.86A.0077.2019.1127.1452
    OS is similar to:
    model name      : Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     07:58:07 up  9:39,  2 users,  load average: 0.62, 0.37, 0.26
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-03-02 07:58:07 CET
               Universal time: Sun 2025-03-02 06:58:07 UTC
                     RTC time: Sun 2025-03-02 06:58:07
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    afischer
    HOME=/home/afischer
    GROUPS=afischer cdrom floppy sudo audio dip video plugdev netdev lpadmin scanner
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout sudo audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:             16G        2.8G         12G        1.6M        1.8G         13G
    Swap:            17G          0B         17G
    Total:           33G        2.8G         29G
    Active iob-Instances:   24
            15863 M total memory
             2677 M used memory
              693 M active memory
             2996 M inactive memory
            11814 M free memory
              333 M buffer memory
             1363 M swap cache
            16253 M total swap
                0 M used swap
            16253 M free swap
    top - 07:58:07 up  9:39,  2 users,  load average: 0.65, 0.38, 0.26
    Tasks: 151 total,   1 running, 150 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15863.3 total,  11813.9 free,   2678.6 used,   1696.5 buff/cache
    MiB Swap:  16254.0 total,  16254.0 free,      0.0 used.  13184.6 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.8G     0  7.8G   0% /dev
    tmpfs          tmpfs     1.6G  924K  1.6G   1% /run
    /dev/nvme0n1p2 ext4      213G   18G  184G   9% /
    tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/nvme0n1p1 vfat      511M  5.9M  506M   2% /boot/efi
    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Sat Mar  1 22:18:45 2025] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Mar  1 22:18:46 2025] EXT4-fs (nvme0n1p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET      SOURCE         FSTYPE OPTIONS
    /           /dev/nvme0n1p2 ext4   rw,relatime,errors=remount-ro
    `-/boot/efi /dev/nvme0n1p1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    2.2G    /var/
    1.1G    /var/log/journal/d25f012e03a44a28958f2441a93e8860
    1.1G    /var/log
    842M    /var/lib
    Archived and active journals take up 92.5M in the file system.
    /opt/iobroker/backups:
    648M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    3.6G    /opt/iobroker/iobroker-data/
    2.0G    /opt/iobroker/iobroker-data/history
    1.3G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    31M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    25M     /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.3
    /usr/bin/node           v20.18.3
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.30.0
    nodejs:
      Installed: 20.18.3-1nodesource1
      Candidate: 20.18.3-1nodesource1
      Version table:
     *** 20.18.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    NUCioBroker         NUCioBroker (version: 7.0.6, hostname: NUCioBroker   , alive, uptime: 34758)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     1
    +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
    Adapter State
    + system.adapter.admin.0                  : admin                 : NUCioBroker                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.devices.0                : devices               : NUCioBroker                              -  enabled
    + system.adapter.discovery.0              : discovery             : NUCioBroker                              -  enabled
      system.adapter.dwd.0                    : dwd                   : NUCioBroker                              -  enabled
    + system.adapter.email.0                  : email                 : NUCioBroker                              -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : NUCioBroker                              -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : NUCioBroker                              - disabled
      system.adapter.feiertage.0              : feiertage             : NUCioBroker                              -  enabled
      system.adapter.flot.0                   : flot                  : NUCioBroker                              -  enabled
    + system.adapter.followthesun.0           : followthesun          : NUCioBroker                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : NUCioBroker                              -  enabled
    + system.adapter.history.0                : history               : NUCioBroker                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : NUCioBroker                              -  enabled
    + system.adapter.hm-rpc.1                 : hm-rpc                : NUCioBroker                              -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : NUCioBroker                              -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : NUCioBroker                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: NUCioBroker                              -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : NUCioBroker                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : NUCioBroker                              -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : NUCioBroker                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : NUCioBroker                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : NUCioBroker                              -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: NUCioBroker                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : NUCioBroker                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : NUCioBroker                              -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : NUCioBroker                              -  enabled
    + system.adapter.javascript.0             : javascript            : NUCioBroker                              -  enabled
      system.adapter.logparser.0              : logparser             : NUCioBroker                              - disabled
    + system.adapter.ping.0                   : ping                  : NUCioBroker                              -  enabled
    + system.adapter.plenticore.0             : plenticore            : NUCioBroker                              -  enabled, port: 80
      system.adapter.ring.0                   : ring                  : NUCioBroker                              - disabled
    + system.adapter.senec.0                  : senec                 : NUCioBroker                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : NUCioBroker                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : NUCioBroker                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sony-bravia.0            : sony-bravia           : NUCioBroker                              -  enabled
    + system.adapter.statistics.0             : statistics            : NUCioBroker                              -  enabled
    + system.adapter.velux.0                  : velux                 : NUCioBroker                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : NUCioBroker                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : NUCioBroker                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : NUCioBroker                              -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : NUCioBroker                              -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : NUCioBroker                              -  enabled
      system.adapter.vis-history.0            : vis-history           : NUCioBroker                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : NUCioBroker                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : NUCioBroker                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : NUCioBroker                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : NUCioBroker                              -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : NUCioBroker                              -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : NUCioBroker                              -  enabled
      system.adapter.vis-map.0                : vis-map               : NUCioBroker                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : NUCioBroker                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : NUCioBroker                              -  enabled
      system.adapter.vis-players.0            : vis-players           : NUCioBroker                              -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : NUCioBroker                              -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : NUCioBroker                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : NUCioBroker                              -  enabled
      system.adapter.vis-weather.0            : vis-weather           : NUCioBroker                              -  enabled
      system.adapter.vis.0                    : vis                   : NUCioBroker                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : NUCioBroker                              -  enabled
    + system.adapter.web.0                    : web                   : NUCioBroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wolf-smartset.0          : wolf-smartset         : NUCioBroker                              -  enabled
      system.adapter.worx.0                   : worx                  : NUCioBroker                              - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "cameras"      : 2.1.2    , installed 2.1.2
    Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "followthesun" : 0.5.1    , installed 0.5.1
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "heatingcontrol": 2.12.13 , installed 2.12.13
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
    Adapter    "ring"         : 6.3.0    , installed 6.3.0
    Adapter    "senec"        : 1.6.17   , installed 1.6.17
    Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "velux"        : 0.0.8    , installed 0.0.8
    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "wolf-smartset": 1.2.4    , installed 1.2.4
    Adapter    "worx"         : 3.1.1    , installed 3.1.1
    Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
    Objects and States
    Objects:        16834
    States:         14071
    Hit:1 http://ftp.debian.org/debian bookworm-backports InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://repos.influxdata.com/debian stable InRelease
    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 ................................:12001    0.0.0.0:*               LISTEN      1001       22772      905/io.hm-rpc.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       21552      689/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20583      689/iobroker.js-con
    tcp        0      0 .......................:42010    0.0.0.0:*               LISTEN      1001       19222      941/io.hm-rpc.2
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20498      592/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1322       1/init
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21131      1097/io.socketio.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23554      1143/io.simple-api.
    tcp6       0      0 :::8086                 :::*                    LISTEN      113        18777      561/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18864      738/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23025      1082/io.web.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      112        21589      688/grafana
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20500      592/sshd: /usr/sbin
    tcp6       0      0 :::80                   :::*                    LISTEN      0          20484      594/apache2
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1324       1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        13167      540/avahi-daemon: r
    udp        0      0 0.0.0.0:48151           0.0.0.0:*                           106        13169      540/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18578      520/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1323       1/init
    udp6       0      0 :::44674                :::*                                106        13170      540/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                106        13168      540/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          1325       1/init
    2025-03-02 07:56:49.438  - info: weatherunderground.0 (31989) Terminated (NO_ERROR): Without reason
    2025-03-02 07:56:49.940  - warn: weatherunderground.0 (31989) get state error: Connection is closed.
    2025-03-02 07:56:49.950  - info: host.NUCioBroker instance system.adapter.weatherunderground.0 having pid 31989 terminated with code 0 (NO_ERROR)
    2025-03-02 07:57:00.002  - info: javascript.0 (836) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
    2025-03-02 07:57:00.009  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 32027
    2025-03-02 07:57:00.021  - info: javascript.0 (836) script.js.common.Programme.RolloSonnenschutz: 17:30
    2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.9251164383561645
    2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.8597323287671232
    2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.45.35477667638539
    2025-03-02 07:57:00.046  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.13530643784915464
    2025-03-02 07:57:00.825  - info: ical.0 (32027) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
    2025-03-02 07:57:01.387  - info: ical.0 (32027) processing URL: calendar1 https://calendar.google.com/calendar/ical/..........................................
    2025-03-02 07:57:06.485  - info: ical.0 (32027) Terminated (NO_ERROR): Without reason
    2025-03-02 07:57:06.999  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 32027 terminated with code 0 (NO_ERROR)
    2025-03-02 07:58:00.002  - info: javascript.0 (836) script.js.common.Programme.SteckdosenSchalterKameras: In Schleife
    2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Gas: 0.9006497716894978
    2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom ohne Stromerzeugung: 0.8597323287671232
    2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten Misch-Strom fortl.45.356973533392654
    2025-03-02 07:58:00.008  - info: javascript.0 (836) script.js.common.Programme.Energiekosten: Kosten mit Strom mit Stromerzeugung: 0.13181142043582644
    2025-03-02 07:58:00.029  - info: host.NUCioBroker instance system.adapter.ical.0 in version "1.16.1" started with pid 32164
    2025-03-02 07:58:00.035  - info: javascript.0 (836) script.js.common.Programme.RolloSonnenschutz: 17:30
    2025-03-02 07:58:00.885  - info: ical.0 (32164) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
    2025-03-02 07:58:01.490  - info: ical.0 (32164) processing URL: calendar1 https://calendar.google.com/calendar/ical/.............................................................
    2025-03-02 07:58:06.605  - info: ical.0 (32164) Terminated (NO_ERROR): Without reason
    2025-03-02 07:58:07.132  - info: host.NUCioBroker instance system.adapter.ical.0 having pid 32164 terminated with code 0 (NO_ERROR)
    Der logparser geht leider immer noch nicht, die gleichen Fehler und er wird auch nicht grün.
    VG Axel
    AFi
    CCU3 (Homematic Komponenten iP und Funk, Schalter, Thermostate, Bewegungsmelder, Rollos etc.), Wemos D1 mini und ALEXA
    ioBroker auf NUC
    Mittelständler in ioBroker
    • AFiA AFi
      Hallo Thomas,
      anbei diag:
      Script v.2025-02-23
      *** BASE SYSTEM ***
               Chassis: desktop 🖥️
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      afischer
      HOME=/home/afischer
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            17G          0B         17G
      Total:           33G        2.8G         29G
               2677 M used memory
                693 M active memory
              11814 M free memory
                333 M buffer memory
               1363 M swap cache
              16253 M total swap
                  0 M used swap
              16253 M free swap
      *** FILESYSTEM ***
      /var:
      2.2G    /var/
      1.1G    /var/log
      842M    /var/lib
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.4.10
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        16834
      States:         14071
      Pending Updates: 0
      VG Axel
      #91
      @afi
      sudo usermod -a G adm,iobroker afischer
      Dann die Kiste neu starten, damit der afischer auch in den richtigen Gruppen ist.
      Und die Fehlermeldungen als Text hier rein.
      AFiA 1 Antwort Letzte Antwort
        @afi
        AFiA Offline
        AFiA Offline
        AFi
        #92
        @thomas-braun Alles ausgeführt, anbei Situation:
        843
        Log-Größe: 16.1 KB
        Zeit
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: Node.js v20.18.3
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: }
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: Require stack:
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: ^
        host.NUCioBroker
        	2025-03-02 08:54:39.794	error	Caught by controller[0]: throw err;
        host.NUCioBroker
        	2025-03-02 08:54:39.793	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: Node.js v20.18.3
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: }
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: Require stack:
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: ^
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: throw err;
        host.NUCioBroker
        	2025-03-02 08:54:28.381	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: Node.js v20.18.3
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: }
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: Require stack:
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: ^
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: throw err;
        host.NUCioBroker
        	2025-03-02 08:54:16.894	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
        host.NUCioBroker
        	2025-03-02 08:54:04.513	error	instance system.adapter.logparser.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.NUCioBroker
        	2025-03-02 08:54:04.513	error	Caught by controller[0]: Node.js v20.18.3
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: }
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.logparser/main.js' ]
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.logparser/main.js:4:18)
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.logparser/main.js
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: Require stack:
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: Error: Cannot find module 'node-schedule'
        host.NUCioBroker
        	2025-03-02 08:54:04.512	error	Caught by controller[0]: ^
        host.NUCioBroker
        	2025-03-02 08:54:04.511	error	Caught by controller[0]: throw err;
        host.NUCioBroker
        	2025-03-02 08:54:04.511	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
        VG Axel
        AFi
        ioBroker auf NUC
        • AFiA AFi
          843
          Log-Größe: 16.1 KB
          Zeit
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          host.NUCioBroker
          VG Axel
          mcm1957M Online
          mcm1957M Online
          mcm1957
          #93
          @afi
          Ich glaub ich kann das abkürzen.
          Beim Adapter logparser fehlt die dependency zu node-schedule. Ist ein Bug des Adapters.
          Ich werd im Laufe des Vormittags eine neue Release erstellen. Wenn du so lange warten willst ok, wenn nicht musst du das package node-schedule vorerst mal manuell installieren. Thomas kann da am besten sagen wie da maccht und dabie nicht allzuviel zerstörst :-).
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
          • mcm1957M mcm1957
            @afi
            #94
            @mcm1957 sagte in Test Adapter Log Parser 2.1.x Latest:
            Okay, hatte mich schon gewundert, bei meiner Testinstallation hab ich nämlich das Modul gar nicht als Dependency im tree gesehen.
            AFiA mcm1957M 2 Antworten Letzte Antwort
              AFiA Offline
              AFiA Offline
              AFi
              #95
              Hi zusammen,
              erst mal vielen Dank an Thomas für die Geduld, ich kann warten, er läuft ja schon ca. 1 Woche nicht mehr, ich hatte nur gestern die Zeit.
              VG Axel
              AFi
              ioBroker auf NUC
                mcm1957M Online
                mcm1957M Online
                mcm1957
                #96
                Wahrscheinlich verwenden das Modul zig andere Adapter. Und damit fällt der Fehler nur auf, wenn das System sehr wenige Adapter enthält.
                Egal - das such ich nicht.
                Fakt ist dass die Dependency im package.json nicht drinnen ist udn im Code geladen wird.
                Ergo ist da was faul was zu beheben ist.
                • mcm1957M mcm1957
                  #97
                  @mcm1957
                  Ja, das wird bei mir von zig anderen Adaptern verwendet. Deswegen hatte mich die Meldung, dass es nicht gefunden werden kann etwas verwundert. Aber wenn es im Bauplan des Adapters gar nicht erst drin ist kein Wunder.
                    @mcm1957
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #98
                    Bin noch dran - dauert noch ein wenig.
                    Aber wenigstens ist (mir) jetzt auch klar warum die Tests nicht schiefgegangen sind. node-schedule war als devDependency drinne. Damit gehts lokal am dev-server und auch die tests laden die dev-Dependencies (da sie ja den Test-Support brauchen)...
                    • mcm1957M mcm1957
                      AFiA Offline
                      AFiA Offline
                      AFi
                      #99
                      @mcm1957 Hi, mir ist aber nicht klar, warum es bis vor ca. 2 Wochen gelaufen ist und dann auf einmal nicht mehr. Der Log Parser lief mindestens 3 Jahre (hoffe ich hab mich in der Zeit nicht verhauen). VG Axel
                      AFi
                      ioBroker auf NUC
                      • AFiA AFi
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        #100
                        @afi
                        möglicherweise hast du zu dem Zeitpunkt etwas deinstalliert oder aktualosiert u npm hat das nicht referenzierte Paket da weggeräumt.
                        • AFiA AFi
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          #101
                          @afi
                          Release 2.3.0 wurde eben erstellt und sollte ab morgen im LATEST / BETA Repository verfügbar sein. Änderungen siehe Releasenotes in README.md bzw. 1. Beitrag.
                          Bitte mal testen obs damit besser geht.
                          • NashraN Offline
                            NashraN Offline
                            Nashra
                            Most Active Forum Testing
                            schrieb am zuletzt editiert von Nashra
                            #102
                            V 2.2.2
                            Jetzt habe ich wieder das leidige Thema mit Heute, Gestern, Uhrzeit.
                            Hatte die Tage 3 Adapter (Accuweather, Pegelalarm, Yr.no) deinstalliert
                            und danach fing es wieder an. Ok, installieren wir mal die neue Beta 2.3.0,
                            aber leider damit das selbe Problem 😞
                            Was können wir tun?
                            Gruß Ralf
                            • E Offline
                              eitljoerggmx.at
                              #103
                              Hallo!
                              Ich versuche Logeinträge in verschiedenen Farben dazustellen, schaffe es aber nicht, da ich keinen Weg finde.
                              Toll wäre, wenn bei Logeinträgen nach Begriffen gesucht werden könnte und dann die entsprechende Farbe für den gesamten Logeintrag anpassbar wäre.
                              Als Beispiel: Ein Logeintrag enthält den Begriff "Klimaanlage". Der gesamte Logtext wird dann in der gewählten Farbe ausgegeben.
                              Kennt da jemand einen Weg?
                              Liebe Grüße
                              • mcm1957M mcm1957
                                @afi
                                AFiA Offline
                                AFiA Offline
                                AFi
                                #104
                                @mcm1957 Hi, wann kommt den die Release 2.3....
                                AFi
                                ioBroker auf NUC
                                • AFiA AFi
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  #105
                                  @afi
                                  2.3.0 Ist seit 2.3.25 wie im ersten Post beschrieben im LATEST / BETA Repository verfügbar.
                                  • arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #106
                                    @nashra sagte in Test Adapter Log Parser 2.3.x Latest:
                                    sollte behoben sein .. bitte von GIT installieren
                                    https://github.com/iobroker-community-adapters/ioBroker.logparser/tarball/todayProblem
                                    hier mal lesen
                                    https://github.com/iobroker-community-adapters/ioBroker.logparser/issues/178#issuecomment-2953704381
                                    • arteckA arteck
                                      hier mal lesen
                                      NashraN Offline
                                      NashraN Offline
                                      Nashra
                                      #107
                                      @arteck
                                      ja, hatte ich schon gelesen da von github Benachrichtigung bekommen.
                                      Habs installiert, bis jetzt ok. Vielen Dank 👍
                                      Und das es am löschen Button gelegen hat wäre ich nie drauf gekommen
                                      und was haben wir alles vermutet, wahnsinn 😀
                                      Gruß Ralf
                                      • NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #108
                                        Hallo
                                        Seit gestern wird nichts von Alexa vom Logparser 2.4.0 geloggt.
                                        Einstellungen sind identisch wie vorher.
                                        Was kann da hängen?
                                         * JavaScript Adapter Script for Log-Parser-Adapter: https://github.com/Mic-M/ioBroker.logparser
                                         * Purpose: Get the history of all spoken Alexa commands into the log
                                         *          Required: Alexa adapter - https://github.com/Apollon77/ioBroker.alexa2
                                         * Source:  https://github.com/Mic-M/ioBroker.logparser
                                         * Autor:   Mic-M (Github) | Mic (ioBroker)
                                         * Change Log:
                                         *  1.0.0  ciddi89 * Added try/catch to fix error
                                         *  1.0.0  Mic-M   * Adoption to Log Parser Adapter
                                         *  0.1.0  Mic-M   * Initial release (for Log Script - https://github.com/Mic-M/iobroker.logfile-script).
                                         * Script Settings
                                        // **Capitalize First Letters**
                                        // The spoken command to Alexa is being returned in lowercase, like "turn on kitchen light".
                                        // With this option set to true, the output will be "Turn On Kitchen Light" (so capitalized first letter of each word)
                                        const g_capFirstLetters = true;
                                         * End of Script Settings. Please do not change anything below here.
                                        main();
                                        function main() {
                                        	// All Alexa adapter instances, so alexa2.0.History.json, alexa2.1.History.json, alexa2.2.History.json, etc.
                                        	on({ id: /^alexa2\.\d\.History\.json$/, change: 'any' }, function (obj) {
                                        		try {
                                        			// obj.state.val: JSON string of oject.
                                        			// Like: {"name":"Alexa Flur","serialNumber":"xxxxxxxxxx","summary":"Wohnlicht an","creationTime":1582843794820, ... }
                                        			let objHistory = JSON.parse(obj.state.val);
                                        			// ignore alexa keywords or empty value.
                                        			if (!['', 'alexa', 'echo', 'computer', 'ziggy'].includes(objHistory['summary'])) {
                                        				// ignore "sprich mir nach"
                                        				if (!objHistory['summary'].includes('sprich mir nach ')) {
                                        					log('[Alexa-Log-Script] ##{"message":"' + formatAlexaSummary(objHistory['summary']) + '", "from":"' + objHistory['name'] + '"}##');
                                        		} catch (error) {
                                        			log(error);
                                         * Formats the Alexa summary text accordingly.
                                         * @param {string} summaryText   The summary text
                                         * @return {string} the formatted summary
                                        function formatAlexaSummary(summaryText) {
                                        	if (g_capFirstLetters) summaryText = summaryText.replace(/(^|\s)\S/g, (l) => l.toUpperCase()); // Capitalize if set. https://stackoverflow.com/questions/2332811/
                                        	return summaryText;
                                        EDIT: komisch, nachdem ich den Adapter auf Debug und wieder retour auf Info stellte, gehts wieder
                                        ° Fixer ---> iob fix
