  4. JavaScript
  5. HowTo: Zusatz-Programme fuer jarvis v3
    1.0k
javascript
899 Beiträge 33 Kommentatoren 326.0k Aufrufe 36 Beobachtet
  • M MCU
    @uwe72 Passt,
    //console.log(arr[dp])
    		//let dp = Object.keys(arr[obj])[0]
    //		 console.log(dp)
    Die beiden console.log auch deaktivieren
    U Offline
    U Offline
    uwe72
    #797
    @mcu
    // stateListLabelChange v1.0.3
    // Copyright ©MCU
    // v1.0.1 - Korrektur Tabwechsel
    // v1.0.2 - für Device-Popup erweitert
    // v1.0.3 - Widget oder Device optional, Logging Test
    let widgetArr = [
    						dp: '0_userdata.0.DP.dp1',
    						deviceId: 'device_HG015',
    						deviceItem: 2
    let loggingSLLC = true;
    let valueSLLCObj = {}
    docReady(function() {
    	if (isConfig()){
    	}else{
    		console.log('%cStart stateListLabelChange.js','color:yellow;');
    		setTimeout(function(){
    			setSubscriptionDPs(widgetArr)
    		},100)
    		document.addEventListener("click", function (event) {
    			if (isConfig()){
    			}else{
    				console.log('%cKlick stateListLabelChange','color:orange');
    					for(let i=0;i<widgetArr.length;i++){
    						if(valueSLLCObj[widgetArr[i].dp]){
    							if(widgetArr[i].widgetId && widgetArr[i].item != undefined){
    								changeLabel(widgetArr[i].widgetId, widgetArr[i].item, valueSLLCObj[widgetArr[i].dp])
    								if(widgetArr[i].deviceId && widgetArr[i].deviceItem != undefined){
    									changeLabelPopup(widgetArr[i].deviceId, widgetArr[i].deviceItem, valueSLLCObj[widgetArr[i].dp] )
    							},500)
    				},100)
    function setSubscriptionDPs(arr){
    	for(let obj in arr){
    //		 console.log(dp)
    		window.Socket.subscribeState(arr[obj].dp, ({ err, state }) => {
    			valueSLLCObj[arr[obj].dp] = state.val;
    			if(arr[obj].widgetId && arr[obj].item!= undefined){
    				changeLabel(arr[obj].widgetId, arr[obj].item,state.val )
    			if(arr[obj].deviceId && arr[obj].deviceItem!= undefined){
    				changeLabelPopup(arr[obj].deviceId,arr[obj].deviceItem, state.val)
    function changeLabel(widgetId,item, txt){
    	console.log('WidgetId: '+widgetId + ' Item: '+item )
    	let doc = document.getElementsByClassName('jarvis-widget-'+widgetId);
    	let dpVal;
    	console.log('ChangeLabel')
    	if(doc.length>0){
    		let stateList = doc[0].getElementsByClassName('jarvis-StateList');
    		if(stateList.length > 0){
    			let slItems = stateList[0].getElementsByClassName('jarvis-StateListItem');
    			if(slItems.length >0){
    				let slBody = slItems[item].getElementsByClassName('jarvis-StateListItem-Body')
    				if(slBody.length > 0){
    					console.log('gefunden ')
    					let slLabel = slBody[0].getElementsByClassName('q-item__label')
    					console.log(slLabel)
    					slLabel[0].innerHTML = txt
    function changeLabelPopup(deviceId, deviceItem, txt){
    	console.log('ChangeLabelDevicePopup')
    	let doc = document.getElementsByClassName('jarvis-device-'+deviceId);
    	if(doc.length >0){
    		if(loggingSLLC) console.log('Device gefunden')
    		let popup = doc[0].getElementsByClassName('jarvis-popup')
    		if(popup.length>0){
    			if(loggingSLLC) console.log('Popup gefunden')
    			let deviceItems = popup[0].getElementsByClassName('jarvis-StateListItem-Popup')
    			if(loggingSLLC) console.log(deviceItems)
    			let device = deviceItems[deviceItem]
    			if(loggingSLLC) console.log(device)
    			let body = device.getElementsByClassName('jarvis-StateListItem-Body')
    			if(body.length >0){
    				if(loggingSLLC) console.log('Body gefunden')
    				let label = body[0].getElementsByClassName('q-item__label')
    				label[0].innerHTML = txt
    function isConfig(){
    	console.log(document.baseURI);
    	if (document.baseURI.indexOf('configuration') >=0){
    		console.log('Konfig aktiv');
    		return true;
    	}else{
    		console.log('Konfig nicht aktiv');
    		return false;
    function docReady(fn) {
        // see if DOM is already available
        if (document.readyState === "complete" || document.readyState === "interactive") {
            // call on next available tick
            setTimeout(fn, 1000);
        } else {
            document.addEventListener("DOMContentLoaded", fn);
    • U uwe72
      @mcu
      // Copyright ©MCU
      let widgetArr = [
      						deviceItem: 2
      	if (isConfig()){
      	}else{
      		},100)
      			if (isConfig()){
      			}else{
      							},500)
      				},100)
      //		 console.log(dp)
      	let dpVal;
      	if(doc.length>0){
      	if(doc.length >0){
      		if(popup.length>0){
      			if(body.length >0){
      		return true;
      	}else{
      		return false;
          } else {
      MCU
      #798
      @uwe72 Du muss Deinen dp eintragen
      deviceItem: 1
      U 1 Antwort Letzte Antwort
      • M MCU
        deviceItem: 1
        U Offline
        U Offline
        uwe72
        #799
        @mcu sorry, mein Fehler. hatte ich bei irgendeinem Update überschrieben. Funktioniert nun! D.h. deviceitem müssen die ausgeblendeten nicht mitgezählt werden!?
        • U uwe72
          MCU
          #800
          @uwe72 Prima, nur die zählen, die man sieht, ab 0.
          • M MCU
            U Offline
            U Offline
            uwe72
            #801
            @mcu said in HowTo: Zusatz-Programme fuer jarvis v3:
            Ganz großen und herzlichen DANK!!
            • U uwe72
              MCU
              #802
              @uwe72 Du kannst dann das Logging abschalten.
              let loggingSLLC = false;
              • I intruder7
                @mcu aber hab gerade gesehen, hätte dies diekt am Host umstellen müssen
                MCU
                #803
                @intruder7 Die ankommenden JSON -> qJSON werden ja jetzt gelogggt. Ich sehe zu den normalen keinen Unterschied. Kannst du mal die qJSON vor dem Fehler vergleichen, mit dem direkt vor dem Fehler. Wenn der Aufbau gleich ist, kann ich es nicht beeinflussen, dann muss irgendwo in influxdb ein Problem vorliegen.
                Laufen zu dem Zeitpunkt irgendwelche anderen Abfragen auf die Datenbank?
                I 1 Antwort Letzte Antwort
                • M MCU
                  I Online
                  I Online
                  intruder7
                  #804
                  @mcu verfolge gerade einen anderen Weg. Ich habe festgestellt dass es manchmal aus irgendwelchen Gründen zu etlichen Anfragen zum selben Widget (also auch DP) innerhalb von Millisekunden kommt. Dies führte zum "aufhängen" von InfluxDB. Ich habe gerade im Skript eChartsHistoryGetData eine Prüfung eingebaut die eine Abfrage an InfluxDb verhindert wenn es das selbe Widget ist und die Zeit zur letzten Abfrage weniger als eine Sekunde ist.
                  Das lasse ich jetzt mal laufen und will hoffen das es daran gelegen hat.
                  • I intruder7
                    MCU
                    #805
                    @intruder7 Zeig mal bitte, vielleicht baue ich mit ein.
                    • M MCU
                      I Online
                      I Online
                      intruder7
                      #806
                      @mcu
                      geht bestimmt eleganter ;-)
                      let getDataDP = historyAdaptDP + '.getData';
                      let lastTime = new Date()
                      let aktTime = new Date()
                      let lastWidget = ""
                      //createStateAsync(queryDPsDP,     {read: true, write: false, name: "Abfrage-DP", desc:"Abfrage-DP", type: "string", role: "", def: "" });
                      createStateAsync(queryJSONDP, { read: true, write: true, name: "Abfrage-JSON-DP", desc: '{dp:"",type:"",cnt:"",start:"",end:"",adapt:""}', type: "string", role: "text", def: JSON.stringify({}) });
                      createStateAsync(dataResultDP, { read: true, write: true, name: "Daten-Ergebnis", desc: "Abfrage-Ergebnis", type: "string", role: "", def: JSON.stringify([]) });
                      on({ id: queryJSONDP, change: "any" }, function (obj) {
                          let value = obj.state.val;
                          // console.log('Anfrage um: '+ formatDate(new Date(),'DD.MM.YYYY hh:mm:ss') +' für DP '+JSON.parse(value).dp )
                          let differenz = (aktTime.getTime() - lastTime.getTime())
                          var Seconds_from_T1_to_T2 = differenz / 1000;
                          var Seconds_Between_Dates = Math.abs(Seconds_from_T1_to_T2);
                          //console.log('aktTime: ' + aktTime)
                          //console.log('lastTime: ' + lastTime)
                          if (JSON.parse(value).widgetId == lastWidget && Seconds_Between_Dates <= 1) {
                              //console.log('gleiches widget und zu häufige Anfrage ')
                              //console.log('last widgetId: ' + lastWidget)
                              //console.log('akt widgetId: ' + JSON.parse(value).widgetId)
                              //console.log('dif: ' + Seconds_Between_Dates)
                          } else {
                              getHist(JSON.parse(value));
                              lastWidget = JSON.parse(value).widgetId
                      • I intruder7
                        @mcu
                        let lastWidget = ""
                            } else {
                        MCU
                        #807
                        @intruder7 Gut dann warten wir mal ab.
                        Ich würde es dann etwas anders mit einbauen. Entscheidend wäre hier der dp, da man von dem die Daten holt.
                        • M MCU
                          I Online
                          I Online
                          intruder7
                          #808
                          @mcu ja das Problem ist aber nicht der DP. Man kann den DP ja auch in z.B. 2 Widgets haben und deswegen hatte ich auf das Widget getestet.
                          • I intruder7
                            MCU
                            #809
                            @intruder7
                            stateListItemHistory v1.0.13
                            Bislang wurden nicht alle Widgets aktualisiert, aus unterschiedlichen Gründen.
                            Ich habe dort noch einige Anpassungen durchführen müssen.
                            Zu einem DP werden nun alle Einstellungen in ein Array gepackt, so dass man nun alle Widgets zum DP aktualisiert.
                            Es werden nun alle sichtbaren Widgets aktualisiert, die zu einem aktualisierten DP gehören.
                            D.h. man kann die Einschränkung im eChartsHistoryGetData nun auf DP setzen und nicht auf WidgetId.
                            Werde ich noch anpassen.
                            abwarten
                            • M MCU
                              @intruder7
                              abwarten
                              I Online
                              I Online
                              intruder7
                              schrieb am zuletzt editiert von intruder7
                              #810
                              @mcu hab zwar bisher keine Auffälligkeiten bzgl. influxdb. Aber das was du geschrieben hast dass manchmal nur der Graph in einem Widget angezeigt wird ist mir auch aufgefallen. Und wenn man die Seite initial mit F5 lädt steht in den widgets immer "History not found".
                              Erst wenn man auf eine andere Seite geht und dann wieder zurück werden sie richtig geladen.
                              • I intruder7
                                MCU
                                #811
                                @intruder7 mit Version v1.0.13?
                                • M MCU
                                  I Online
                                  I Online
                                  intruder7
                                  #812
                                  @mcu jap, vorher mit der alten und jetzt mit der 13 auch
                                  • I intruder7
                                    MCU
                                    #813
                                    @intruder7 Setz mal die betweentimefirst hoch auf 600 oder 1000
                                    I 2 Antworten Letzte Antwort
                                    • M MCU
                                      I Online
                                      I Online
                                      intruder7
                                      #814
                                      @mcu sieht besser aus :-)
                                      • M MCU
                                        I Online
                                        I Online
                                        intruder7
                                        #815
                                        @mcu kurze Frage zu einem anderen Thema. Wie kann man Bilder in einem Widget als Hintergrund anzeigen? Hintergrund, folgendes Widget ist eine View aus VIS und stelle ich in einem IFrame Widget dar. Ich würde das gerne nach Jarvis überführen.
                                        dies war meine Idee dazu.
                                        .jarvis-widget-7275f577-7aef-4b44-9b8b-fed11bb9b93e {
                                        	background-image: url("http://192.168.100.11:8082//vis.0/md_simple/images/Audi_vorne2.png");
                                        geht aber nicht
                                        • I intruder7
                                          geht aber nicht
                                          MCU
                                          #816
                                          @intruder7 F12 sehr wahrscheinlich muss es über Port 8400 laufen. Ist noch offenes Thema.
