  4. JavaScript
  5. HowTo: Zusatz-Programme fuer jarvis v3
    1.0k
javascript
899 Beiträge 33 Kommentatoren 326.0k Aufrufe 36 Beobachtet
  • U uwe72
    @mcu
    ich starte nun mal so:
    // stateListLabelChange v1.0.3
    // Copyright ©MCU
    // v1.0.1 - Korrektur Tabwechsel
    // v1.0.2 - für Device-Popup erweitert
    // v1.0.3 - Widget oder Device optional, Logging Test
    let widgetArr = [
    						dp:'0_userdata.0.DP.dp1',
    						deviceId: 'device_HG015',
    						deviceItem: 2
    let loggingSLLC = true;
    let valueSLLCObj = {}
    docReady(function() {
    	if (isConfig()){
    	}else{
    		console.log('%cStart stateListLabelChange.js','color:yellow;');
    		setTimeout(function(){
    			setSubscriptionDPs(widgetArr)
    		},100)
    		document.addEventListener("click", function (event) {
    			if (isConfig()){
    			}else{
    				console.log('%cKlick stateListLabelChange','color:orange');
    					for(let i=0;i<widgetArr.length;i++){
    						if(valueSLLCObj[widgetArr[i].dp]){
    							if(widgetArr[i].widgetId && widgetArr[i].item != undefined){
    								changeLabel(widgetArr[i].widgetId, widgetArr[i].item, valueSLLCObj[widgetArr[i].dp])
    								if(widgetArr[i].deviceId && widgetArr[i].deviceItem != undefined){
    									changeLabelPopup(widgetArr[i].deviceId, widgetArr[i].deviceItem, valueSLLCObj[widgetArr[i].dp] )
    							},500)
    				},100)
    function setSubscriptionDPs(arr){
    	for(let obj in arr){
    		console.log(arr[dp])
    		//let dp = Object.keys(arr[obj])[0]
    		 console.log(dp)
    		window.Socket.subscribeState(arr[obj].dp, ({ err, state }) => {
    			valueSLLCObj[arr[obj].dp] = state.val;
    			if(arr[obj].widgetId && arr[obj].item!= undefined){
    				changeLabel(arr[obj].widgetId, arr[obj].item,state.val )
    			if(arr[obj].deviceId && arr[obj].deviceItem!= undefined){
    				changeLabelPopup(arr[obj].deviceId,arr[obj].deviceItem, state.val)
    function changeLabel(widgetId,item, txt){
    	console.log('WidgetId: '+widgetId + ' Item: '+item )
    	let doc = document.getElementsByClassName('jarvis-widget-'+widgetId);
    	let dpVal;
    	console.log('ChangeLabel')
    	if(doc.length>0){
    		let stateList = doc[0].getElementsByClassName('jarvis-StateList');
    		if(stateList.length > 0){
    			let slItems = stateList[0].getElementsByClassName('jarvis-StateListItem');
    			if(slItems.length >0){
    				let slBody = slItems[item].getElementsByClassName('jarvis-StateListItem-Body')
    				if(slBody.length > 0){
    					console.log('gefunden ')
    					let slLabel = slBody[0].getElementsByClassName('q-item__label')
    					console.log(slLabel)
    					slLabel[0].innerHTML = txt
    function changeLabelPopup(deviceId, deviceItem, txt){
    	console.log('ChangeLabelDevicePopup')
    	let doc = document.getElementsByClassName('jarvis-device-'+deviceId);
    	if(doc.length >0){
    		if(loggingSLLC) console.log('Device gefunden')
    		let popup = doc[0].getElementsByClassName('jarvis-popup')
    		if(popup.length>0){
    			if(loggingSLLC) console.log('Popup gefunden')
    			let deviceItems = popup[0].getElementsByClassName('jarvis-StateListItem-Popup')
    			if(loggingSLLC) console.log(deviceItems)
    			let device = deviceItems[deviceItem]
    			if(loggingSLLC) console.log(device)
    			let body = device.getElementsByClassName('jarvis-StateListItem-Body')
    			if(body.length >0){
    				if(loggingSLLC) console.log('Body gefunden')
    				let label = body[0].getElementsByClassName('q-item__label')
    				label[0].innerHTML = txt
    function isConfig(){
    	console.log(document.baseURI);
    	if (document.baseURI.indexOf('configuration') >=0){
    		console.log('Konfig aktiv');
    		return true;
    	}else{
    		console.log('Konfig nicht aktiv');
    		return false;
    function docReady(fn) {
        // see if DOM is already available
        if (document.readyState === "complete" || document.readyState === "interactive") {
            // call on next available tick
            setTimeout(fn, 1000);
        } else {
            document.addEventListener("DOMContentLoaded", fn);
    MCU
    #796
    @uwe72 Passt,
    //console.log(arr[dp])
    //		 console.log(dp)
    Die beiden console.log auch deaktivieren
    U 1 Antwort Letzte Antwort
    • M MCU
      @uwe72 Passt,
      //		 console.log(dp)
      U Offline
      U Offline
      uwe72
      #797
      @mcu
      // Copyright ©MCU
      let widgetArr = [
      						dp: '0_userdata.0.DP.dp1',
      						deviceItem: 2
      	if (isConfig()){
      	}else{
      		},100)
      			if (isConfig()){
      			}else{
      							},500)
      				},100)
      //		 console.log(dp)
      	let dpVal;
      	if(doc.length>0){
      	if(doc.length >0){
      		if(popup.length>0){
      			if(body.length >0){
      		return true;
      	}else{
      		return false;
          } else {
      • U uwe72
        @mcu
        // Copyright ©MCU
        let widgetArr = [
        						deviceItem: 2
        	if (isConfig()){
        	}else{
        		},100)
        			if (isConfig()){
        			}else{
        							},500)
        				},100)
        //		 console.log(dp)
        	let dpVal;
        	if(doc.length>0){
        	if(doc.length >0){
        		if(popup.length>0){
        			if(body.length >0){
        		return true;
        	}else{
        		return false;
            } else {
        MCU
        #798
        @uwe72 Du muss Deinen dp eintragen
        deviceItem: 1
        • M MCU
          deviceItem: 1
          U Offline
          U Offline
          uwe72
          #799
          @mcu sorry, mein Fehler. hatte ich bei irgendeinem Update überschrieben. Funktioniert nun! D.h. deviceitem müssen die ausgeblendeten nicht mitgezählt werden!?
          • U uwe72
            MCU
            #800
            @uwe72 Prima, nur die zählen, die man sieht, ab 0.
            • M MCU
              U Offline
              U Offline
              uwe72
              #801
              @mcu said in HowTo: Zusatz-Programme fuer jarvis v3:
              Ganz großen und herzlichen DANK!!
              • U uwe72
                MCU
                #802
                @uwe72 Du kannst dann das Logging abschalten.
                let loggingSLLC = false;
                • I intruder7
                  @mcu aber hab gerade gesehen, hätte dies diekt am Host umstellen müssen
                  MCU
                  #803
                  @intruder7 Die ankommenden JSON -> qJSON werden ja jetzt gelogggt. Ich sehe zu den normalen keinen Unterschied. Kannst du mal die qJSON vor dem Fehler vergleichen, mit dem direkt vor dem Fehler. Wenn der Aufbau gleich ist, kann ich es nicht beeinflussen, dann muss irgendwo in influxdb ein Problem vorliegen.
                  Laufen zu dem Zeitpunkt irgendwelche anderen Abfragen auf die Datenbank?
                  I 1 Antwort Letzte Antwort
                  • M MCU
                    I Online
                    I Online
                    intruder7
                    #804
                    @mcu verfolge gerade einen anderen Weg. Ich habe festgestellt dass es manchmal aus irgendwelchen Gründen zu etlichen Anfragen zum selben Widget (also auch DP) innerhalb von Millisekunden kommt. Dies führte zum "aufhängen" von InfluxDB. Ich habe gerade im Skript eChartsHistoryGetData eine Prüfung eingebaut die eine Abfrage an InfluxDb verhindert wenn es das selbe Widget ist und die Zeit zur letzten Abfrage weniger als eine Sekunde ist.
                    Das lasse ich jetzt mal laufen und will hoffen das es daran gelegen hat.
                    • I intruder7
                      MCU
                      #805
                      @intruder7 Zeig mal bitte, vielleicht baue ich mit ein.
                      • M MCU
                        I Online
                        I Online
                        intruder7
                        #806
                        @mcu
                        geht bestimmt eleganter ;-)
                        let getDataDP = historyAdaptDP + '.getData';
                        let lastTime = new Date()
                        let aktTime = new Date()
                        let lastWidget = ""
                        //createStateAsync(queryDPsDP,     {read: true, write: false, name: "Abfrage-DP", desc:"Abfrage-DP", type: "string", role: "", def: "" });
                        createStateAsync(queryJSONDP, { read: true, write: true, name: "Abfrage-JSON-DP", desc: '{dp:"",type:"",cnt:"",start:"",end:"",adapt:""}', type: "string", role: "text", def: JSON.stringify({}) });
                        createStateAsync(dataResultDP, { read: true, write: true, name: "Daten-Ergebnis", desc: "Abfrage-Ergebnis", type: "string", role: "", def: JSON.stringify([]) });
                        on({ id: queryJSONDP, change: "any" }, function (obj) {
                            let value = obj.state.val;
                            // console.log('Anfrage um: '+ formatDate(new Date(),'DD.MM.YYYY hh:mm:ss') +' für DP '+JSON.parse(value).dp )
                            let differenz = (aktTime.getTime() - lastTime.getTime())
                            var Seconds_from_T1_to_T2 = differenz / 1000;
                            var Seconds_Between_Dates = Math.abs(Seconds_from_T1_to_T2);
                            //console.log('aktTime: ' + aktTime)
                            //console.log('lastTime: ' + lastTime)
                            if (JSON.parse(value).widgetId == lastWidget && Seconds_Between_Dates <= 1) {
                                //console.log('gleiches widget und zu häufige Anfrage ')
                                //console.log('last widgetId: ' + lastWidget)
                                //console.log('akt widgetId: ' + JSON.parse(value).widgetId)
                                //console.log('dif: ' + Seconds_Between_Dates)
                            } else {
                                getHist(JSON.parse(value));
                                lastWidget = JSON.parse(value).widgetId
                        • I intruder7
                          @mcu
                          let lastWidget = ""
                              } else {
                          MCU
                          #807
                          @intruder7 Gut dann warten wir mal ab.
                          Ich würde es dann etwas anders mit einbauen. Entscheidend wäre hier der dp, da man von dem die Daten holt.
                          • M MCU
                            I Online
                            I Online
                            intruder7
                            #808
                            @mcu ja das Problem ist aber nicht der DP. Man kann den DP ja auch in z.B. 2 Widgets haben und deswegen hatte ich auf das Widget getestet.
                            • I intruder7
                              MCU
                              #809
                              @intruder7
                              stateListItemHistory v1.0.13
                              Bislang wurden nicht alle Widgets aktualisiert, aus unterschiedlichen Gründen.
                              Ich habe dort noch einige Anpassungen durchführen müssen.
                              Zu einem DP werden nun alle Einstellungen in ein Array gepackt, so dass man nun alle Widgets zum DP aktualisiert.
                              Es werden nun alle sichtbaren Widgets aktualisiert, die zu einem aktualisierten DP gehören.
                              D.h. man kann die Einschränkung im eChartsHistoryGetData nun auf DP setzen und nicht auf WidgetId.
                              Werde ich noch anpassen.
                              abwarten
                              • M MCU
                                @intruder7
                                abwarten
                                I Online
                                I Online
                                intruder7
                                schrieb am zuletzt editiert von intruder7
                                #810
                                @mcu hab zwar bisher keine Auffälligkeiten bzgl. influxdb. Aber das was du geschrieben hast dass manchmal nur der Graph in einem Widget angezeigt wird ist mir auch aufgefallen. Und wenn man die Seite initial mit F5 lädt steht in den widgets immer "History not found".
                                Erst wenn man auf eine andere Seite geht und dann wieder zurück werden sie richtig geladen.
                                • I intruder7
                                  MCU
                                  #811
                                  @intruder7 mit Version v1.0.13?
                                  • M MCU
                                    I Online
                                    I Online
                                    intruder7
                                    #812
                                    @mcu jap, vorher mit der alten und jetzt mit der 13 auch
                                    • I intruder7
                                      MCU
                                      #813
                                      @intruder7 Setz mal die betweentimefirst hoch auf 600 oder 1000
                                      I 2 Antworten Letzte Antwort
                                      • M MCU
                                        I Online
                                        I Online
                                        intruder7
                                        #814
                                        @mcu sieht besser aus :-)
                                        • M MCU
                                          I Online
                                          I Online
                                          intruder7
                                          #815
                                          @mcu kurze Frage zu einem anderen Thema. Wie kann man Bilder in einem Widget als Hintergrund anzeigen? Hintergrund, folgendes Widget ist eine View aus VIS und stelle ich in einem IFrame Widget dar. Ich würde das gerne nach Jarvis überführen.
                                          dies war meine Idee dazu.
                                          .jarvis-widget-7275f577-7aef-4b44-9b8b-fed11bb9b93e {
                                          	background-image: url("http://192.168.100.11:8082//vis.0/md_simple/images/Audi_vorne2.png");
                                          geht aber nicht
