  4. Test Adapter flexcharts - Stapeldiagramme und mehr
chartchartsdiagrammeechartsvisualisierungvisualization
280 Beiträge 21 Kommentatoren 75.6k Aufrufe 24 Beobachtet
  • SMSS SMS
    @jrbwh Dann würde ich sagen funktioniert es nicht! Das hier steht im Skript:
    // Create chart for Tibber hourly data to be used with flexcharts
    const ID_TIBBER_HOURLY = '0_userdata.0.flexcharts.tibberLink.tibberHourly';       // State id containing tibber data (json format)
    const ID_CHART_HOURLY  = '0_userdata.0.flexcharts.tibberLink.chartHourly';        // State id containing template for chart data (json format)
    const TITLE_HOURLY     = 'Tibber hourly';
    evalTibberData(ID_TIBBER_HOURLY, ID_CHART_HOURLY, TITLE_HOURLY);    // Convert data on start of script
    on({id: ID_TIBBER_HOURLY, change: "any"}, function (obj) {
    function evalTibberData(idTibber, idChart, title) {
        const tibber = JSON.parse(getState(idTibber).val);  // Read tibber data
        const chart = JSON.parse(getState(idChart).val);    // Read chart template
        const xAxis  = [];
        const yAxis0 = [];
        const yAxis1 = [];
        for (const data of Object.values(tibber)) {
            const isHourly = (new Date(data.from).getHours() != new Date(data.to).getHours());  // Hourly data?
            const xValue = (isHourly ? new Date(data.from).toLocaleTimeString() : new Date(data.from).toLocaleDateString());
            xAxis.push(xValue);
            yAxis0.push((data.consumption ? data.consumption.toFixed(2) : 0));  // push 0 on null values
            yAxis1.push((data.cost ? data.cost.toFixed(2) : 0));                // push 0 on null values
        chart.title.text = title;           // Set chart title
        chart.xAxis[0].data  = xAxis;       // Set chart x-axis data
        chart.series[0].data = yAxis0;      // Set chart y-values consumption
        chart.series[1].data = yAxis1;      // Set chart y-values cost
        setState(idChart, JSON.stringify(chart), true); // Write changed chart data to state
        console.log('Evaluation of tibber hourly data done. Title: '+title);
    Das hier ist die ID vom tibberHourly:
    Und hier vom chartHourly:
    Muss noch irgendwo die ID von tibberlink rein?
    jrbwhJ Offline
    jrbwhJ Offline
    jrbwh
    #160
    @sms Was steht im Log? Und wie kommen die Daten von tibberLink.0.Homes.... nach 0_userdata.0.flexcharts.tibberHourly? Denke, Du solltest im Skript direkt die tibberLink.0.Homes...-ID verwenden.
    • L Offline
      legro
      schrieb am zuletzt editiert von legro
      #161
      @sms
      Aller Anfang ist schwer. Am Ende hilft jedoch nur, sich selbst in die Materie einzuarbeiten. Meine Leidens- und vor allem Erfolgsgeschichten kannst du hier in Teilen nachlesen. Dort findest du viele Ideen und Techniken, wie du dein Vorhaben weitestgehend selbst in die Tat umsetzen kannst.
      Nicht erschrecken! Aber ohne sich durch derartige Gedanken hindurch zu kämpfen, wirst du mit FlexCharts nicht glücklich. Aber sei versichert: Es lohnt sich.
      Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
      • jrbwhJ jrbwh
        @ullij Ich habe eine Version im Branch develop erstellt, kann im Moment aber nur eingeschränkt testen. Bei mir sieht's gut aus. Falls Du es ausprobieren möchtest:
        Im Expertenmodus im Adapter-Installationsdialog unter "Custom" folgende Adresse verwenden:
        https://github.com/MyHomeMyData/ioBroker.flexcharts/tree/develop
        U Offline
        U Offline
        UlliJ
        #162
        @jrbwh sagte in Test Adapter flexcharts - Stapeldiagramme und mehr:
        nach Neuinstallation sieht das so aus👍
        Proxmox auf iNuc, lxc für IoB, InfluxDB2, Grafana, u.a. *** Homematic & Homematic IP, Shellies, Zigbee etc
        jrbwhJ 1 Antwort Letzte Antwort
        • U UlliJ
          jrbwhJ Offline
          jrbwhJ Offline
          jrbwh
          #163
          @ullij Super. Danke fürs Testen!
          • SMSS SMS
            @jrbwh Einen Schreibfehler habe ich gefunden. Aber irgendwas passt immer noch nicht:
            const TITLE_HOURLY     = 'Tibber hourly';                                                             // Title of chart
                const xAxis  = [];
                const yAxis0 = [];
                const yAxis1 = [];
                    xAxis.push(new Date(data.from).toLocaleDateString());
                    yAxis0.push(data.consumption.toFixed(2));
                    yAxis1.push(data.cost.toFixed(2));
            Geändert habe ich weekly oder WEEKLY auf hourly oder HOURLY, also eigentlich genauso geschrieben (Groß- und Kleinbuchstaben). Da finde ich jetzt keinen Fehler mehr. Komischerweise hat es bei daily funktioniert. Außer das ich noch nicht weiß ob die Seite aktualisiert wird, da es heute morgen nicht geklappt hat.
            Jede Abfrage hat jetzt ein eigenes Skript.
            Kann es was mit der Uhrzeit zu tun haben?
            In chartHourly steht:
              "tooltip": {
                "trigger": "axis",
                "axisPointer": {
                  "type": "cross"
              "legend": {
                "show": true,
                "orient": "horizontal",
                "left": "center",
                "top": 25
              "title": {
                "left": "center",
                "text": "Tibber hourly"
              "grid": {
                "right": "20%"
              "toolbox": {
                "feature": {
                  "dataView": {
                    "show": true,
                    "readOnly": false
                  "restore": {
                    "show": true
                  "saveAsImage": {
                    "show": true
              "xAxis": [
                  "type": "category",
                  "axisTick": {
                    "alignWithLabel": true
                  "data": [
                    "14:00",
                    "15:00",
                    "16:00"
              "yAxis": [
                  "type": "value",
                  "position": "left",
                  "alignTicks": true,
                  "axisLine": {
                    "show": true,
                    "lineStyle": {
                      "color": "#5470C6"
                  "axisLabel": {
                    "formatter": "{value} kWh"
                  "type": "value",
                  "position": "right",
                  "alignTicks": true,
                  "axisLine": {
                    "show": true,
                    "lineStyle": {
                      "color": "#91CC75"
                  "axisLabel": {
                    "formatter": "{value} €"
              "series": [
                  "name": "Consumption",
                  "type": "bar",
                  "data": [
                    "0.081",
                    "0.096",
                    "0.086"
                  "name": "Cost",
                  "type": "bar",
                  "yAxisIndex": 1,
                  "data": [
                    "0.03",
                    "0.03",
                    "0.03"
            Wobei ich die Uhrzeiten selbst eingetragen habe.
            In tibberHourly steht:
                "from": "2025-01-29T09:00:00.000+01:00",
                "to": "2025-01-29T10:00:00.000+01:00",
                "cost": 0.029134056,
                "unitPrice": 0.3641757,
                "unitPriceVAT": 0.0581457,
                "consumption": 0.08,
                "consumptionUnit": "kWh",
                "totalCost": 0.02616991475,
                "unitCost": 0.029134056,
                "currency": "EUR"
                "from": "2025-01-29T10:00:00.000+01:00",
                "to": "2025-01-29T11:00:00.000+01:00",
                "cost": 0.0497585053,
                "unitPrice": 0.3339497,
                "unitPriceVAT": 0.0533197,
                "consumption": 0.149,
                "totalCost": 0.04679436405,
                "unitCost": 0.0497585053,
                "currency": "EUR"
                "from": "2025-01-29T11:00:00.000+01:00",
                "to": "2025-01-29T12:00:00.000+01:00",
                "cost": 0.0412843487,
                "unitPrice": 0.3151477,
                "unitPriceVAT": 0.0503177,
                "consumption": 0.131,
                "totalCost": 0.03832020745,
                "unitCost": 0.0412843487,
                "currency": "EUR"
                "from": "2025-01-29T12:00:00.000+01:00",
                "to": "2025-01-29T13:00:00.000+01:00",
                "cost": 0.021706314,
                "unitPrice": 0.3100902,
                "unitPriceVAT": 0.0495102,
                "consumption": 0.07,
                "totalCost": 0.01874217275,
                "unitCost": 0.021706314,
                "currency": "EUR"
                "from": "2025-01-29T13:00:00.000+01:00",
                "to": "2025-01-29T14:00:00.000+01:00",
                "cost": 0.0307613691,
                "unitPrice": 0.3107209,
                "unitPriceVAT": 0.0496109,
                "consumption": 0.099,
                "totalCost": 0.02779722785,
                "unitCost": 0.0307613691,
                "currency": "EUR"
                "from": "2025-01-29T14:00:00.000+01:00",
                "to": "2025-01-29T15:00:00.000+01:00",
                "cost": 0.0253746675,
                "unitPrice": 0.3132675,
                "unitPriceVAT": 0.0500175,
                "consumption": 0.081,
                "totalCost": 0.02241052625,
                "unitCost": 0.0253746675,
                "currency": "EUR"
                "from": "2025-01-29T15:00:00.000+01:00",
                "to": "2025-01-29T16:00:00.000+01:00",
                "cost": 0.0317964192,
                "unitPrice": 0.3312127,
                "unitPriceVAT": 0.0528827,
                "consumption": 0.096,
                "totalCost": 0.02883227795,
                "unitCost": 0.0317964192,
                "currency": "EUR"
                "from": "2025-01-29T16:00:00.000+01:00",
                "to": "2025-01-29T17:00:00.000+01:00",
                "cost": 0.0315452816,
                "unitPrice": 0.3668056,
                "unitPriceVAT": 0.0585656,
                "consumption": 0.086,
                "totalCost": 0.02858114035,
                "unitCost": 0.0315452816,
                "currency": "EUR"
                "from": "2025-01-29T17:00:00.000+01:00",
                "to": "2025-01-29T18:00:00.000+01:00",
                "cost": 0.0228287815,
                "unitPrice": 0.3869285,
                "unitPriceVAT": 0.0617785,
                "consumption": 0.059,
                "totalCost": 0.01986464025,
                "unitCost": 0.0228287815,
                "currency": "EUR"
                "from": "2025-01-29T18:00:00.000+01:00",
                "to": "2025-01-29T19:00:00.000+01:00",
                "cost": 0.0112388717,
                "unitPrice": 0.3875473,
                "unitPriceVAT": 0.0618773,
                "consumption": 0.029,
                "totalCost": 0.00827473045,
                "unitCost": 0.0112388717,
                "currency": "EUR"
                "from": "2025-01-29T19:00:00.000+01:00",
                "to": "2025-01-29T20:00:00.000+01:00",
                "cost": 0.007660744,
                "unitPrice": 0.3830372,
                "unitPriceVAT": 0.0611572,
                "consumption": 0.02,
                "totalCost": 0.00469660275,
                "unitCost": 0.007660744,
                "currency": "EUR"
                "from": "2025-01-29T20:00:00.000+01:00",
                "to": "2025-01-29T21:00:00.000+01:00",
                "cost": 0.0065872926,
                "unitPrice": 0.3659607,
                "unitPriceVAT": 0.0584307,
                "consumption": 0.018,
                "totalCost": 0.00362315135,
                "unitCost": 0.0065872926,
                "currency": "EUR"
                "from": "2025-01-29T21:00:00.000+01:00",
                "to": "2025-01-29T22:00:00.000+01:00",
                "cost": 0.0063238266,
                "unitPrice": 0.3513237,
                "unitPriceVAT": 0.0560937,
                "totalCost": 0.00335968535,
                "unitCost": 0.0063238266,
                "currency": "EUR"
                "from": "2025-01-29T22:00:00.000+01:00",
                "to": "2025-01-29T23:00:00.000+01:00",
                "cost": 0.0065019577,
                "unitPrice": 0.3422083,
                "unitPriceVAT": 0.0546383,
                "consumption": 0.019,
                "totalCost": 0.00353781645,
                "unitCost": 0.0065019577,
                "currency": "EUR"
                "from": "2025-01-29T23:00:00.000+01:00",
                "to": "2025-01-30T00:00:00.000+01:00",
                "cost": 1.1309330053,
                "unitPrice": 0.3271429,
                "unitPriceVAT": 0.0522329,
                "consumption": 3.457,
                "totalCost": 1.12796886405,
                "unitCost": 1.1309330053,
                "currency": "EUR"
                "from": "2025-01-30T00:00:00.000+01:00",
                "to": "2025-01-30T01:00:00.000+01:00",
                "cost": 0.1119367431,
                "unitPrice": 0.3189081,
                "unitPriceVAT": 0.0509181,
                "consumption": 0.351,
                "totalCost": 0.10897260185,
                "unitCost": 0.1119367431,
                "currency": "EUR"
                "from": "2025-01-30T01:00:00.000+01:00",
                "to": "2025-01-30T02:00:00.000+01:00",
                "cost": 0.1058853908,
                "unitPrice": 0.3189319,
                "unitPriceVAT": 0.0509219,
                "consumption": 0.332,
                "totalCost": 0.10292124955,
                "unitCost": 0.1058853908,
                "currency": "EUR"
                "from": "2025-01-30T02:00:00.000+01:00",
                "to": "2025-01-30T03:00:00.000+01:00",
                "cost": 0.0892808091,
                "unitPrice": 0.3200029,
                "unitPriceVAT": 0.0510929,
                "consumption": 0.279,
                "totalCost": 0.08631666785,
                "unitCost": 0.0892808091,
                "currency": "EUR"
                "from": "2025-01-30T03:00:00.000+01:00",
                "to": "2025-01-30T04:00:00.000+01:00",
                "cost": 0.089474196,
                "unitPrice": 0.3195507,
                "unitPriceVAT": 0.0510207,
                "consumption": 0.28,
                "totalCost": 0.08651005475,
                "unitCost": 0.089474196,
                "currency": "EUR"
                "from": "2025-01-30T04:00:00.000+01:00",
                "to": "2025-01-30T05:00:00.000+01:00",
                "cost": 0.1077989822,
                "consumption": 0.338,
                "totalCost": 0.10483484095,
                "unitCost": 0.1077989822,
                "currency": "EUR"
                "from": "2025-01-30T05:00:00.000+01:00",
                "to": "2025-01-30T06:00:00.000+01:00",
                "cost": 0.1200729635,
                "unitPrice": 0.3382337,
                "unitPriceVAT": 0.0540037,
                "consumption": 0.355,
                "totalCost": 0.11710882225,
                "unitCost": 0.1200729635,
                "currency": "EUR"
                "from": "2025-01-30T06:00:00.000+01:00",
                "to": "2025-01-30T07:00:00.000+01:00",
                "cost": 0.0240216256,
                "unitPrice": 0.3753379,
                "unitPriceVAT": 0.0599279,
                "consumption": 0.064,
                "totalCost": 0.02105748435,
                "unitCost": 0.0240216256,
                "currency": "EUR"
                "from": "2025-01-30T07:00:00.000+01:00",
                "to": "2025-01-30T08:00:00.000+01:00",
                "cost": 0.0121080358,
                "unitPrice": 0.3905818,
                "unitPriceVAT": 0.0623618,
                "consumption": 0.031,
                "totalCost": 0.00914389455,
                "unitCost": 0.0121080358,
                "currency": "EUR"
                "from": "2025-01-30T08:00:00.000+01:00",
                "to": "2025-01-30T09:00:00.000+01:00",
                "cost": null,
                "unitPrice": 0.3996972,
                "unitPriceVAT": 0.0638172,
                "consumption": null,
                "totalCost": null,
                "unitCost": null,
                "currency": "EUR"
            Bez. wenn ich auf den Stift gehe unter Objektdaten bei chartHourly:
              "common": {
                "name": "chartHourly",
                "desc": "Manuell erzeugt",
                "role": "state",
                "type": "json",
                "read": true,
                "write": true
              "type": "state",
              "native": {},
              "user": "system.user.admin",
              "ts": 1738172595401,
              "_id": "0_userdata.0.flexcharts.tibberLink.chartHourly",
              "acl": {
                "object": 1638,
                "state": 1638,
                "owner": "system.user.admin",
            und bei tibberHourly:
              "common": {
                "name": "tibberHourly",
                "role": "state",
                "type": "json",
                "read": true,
                "write": true
              "type": "state",
              "native": {},
              "ts": 1738172636549,
              "_id": "0_userdata.0.flexcharts.tibberLink.tibberHourly",
              "acl": {
                "object": 1638,
                "state": 1638,
            jrbwhJ Offline
            jrbwhJ Offline
            jrbwh
            #164
            @sms Ich habe eine "Variante 2" des Skripts erstellt. Das benötigt keine zusätzlichen Datenpunkte und kann stündliche, tägliche, wöchentliche und monatliche Daten direkt verarbeiten. Man muss lediglich die IDs der tibberLink-Datenpunkte ("tibberLink.0.Homes...") im Skript bei "IDS" korrekt eintragen, dann sollte es funktioniert. Die Auswahl der Daten erfolgt dann im http-Aufruf.
            Wäre super, wenn Du das mal ausprobieren könntest. Ich kann es selber nicht gut testen, da ich keine tibberLink-Daten habe.
            SMSS 1 Antwort Letzte Antwort
            • Merlin123M Merlin123
              @jrbwh Bei Fragen können sich die Leute gerne melden. Hab da auch genug Fragen gestellt, bis ich das halbwegs verstanden habe :)
              jrbwhJ Offline
              jrbwhJ Offline
              jrbwh
              #165
              @merlin123 Ich habe ein Skript erstellt, um ein einfaches Chart für Verbrauch und Kosten zu generieren. Passt für Dich vermutlich nicht, aber es wäre klasse, wenn Du "Variante 2" mal ausprobieren könntest. Mein Problem ist, dass ich ohne Tibber-Daten nur sehr grob testen kann.
              Merlin123M 1 Antwort Letzte Antwort
              • jrbwhJ jrbwh
                SMSS Online
                SMSS Online
                SMS
                #166
                @jrbwh Hi! Läuft seit heute morgen ca. 8Uhr! Scheint zu funktionieren. :-)
                • SMSS SMS
                  jrbwhJ Offline
                  jrbwhJ Offline
                  jrbwh
                  #167
                  @sms Sehr schön! Du benutzt "Variante 2", richtig?
                  • jrbwhJ jrbwh
                    SMSS Online
                    SMSS Online
                    SMS
                    #168
                    @jrbwh JA, vielen Dank dafür!
                    Wo kann ich denn die Balkenfarbe ändern?
                    Das hier ändert mir nur die seitlichen Achsen:
                    xAxis: [{ type: "category", axisTick: { alignWithLabel: true }, data: []}],
                                        yAxis: [{ type: "value", position: "left",  alignTicks: true, axisLine: { show: true, lineStyle: { color: "#5470C6" }}, axisLabel: { formatter: "{value} kWh" }},
                                                { type: "value", position: "right", alignTicks: true, axisLine: { show: true, lineStyle: { color: "#91CC75" }}, axisLabel: { formatter: "{value} €" }}],
                                        series: [{ name: "Consumption", type: "bar", yAxisIndex: 0, data: []},
                                                 { name: "Cost",        type: "bar", yAxisIndex: 1, data: []}]
                    Die Schriftfarbe müsste ich auch ändern, da ich einen dunklen Hintergrund habe. Eine Veränderung hier ändert abernichts:
                    } else {
                            console.log('Invalid chart type >>'+myChart+'<<');
                            callback({title: { left: "center", textStyle: { color: "#ff0000" }, text: "INVALID
                    • SMSS SMS
                      } else {
                      jrbwhJ Offline
                      jrbwhJ Offline
                      jrbwh
                      #169
                      @sms Wenn Du die Farben der Balken ändern möchtest, musst auch in deren Definition was ändern. Z.B. so:
                                          series: [{ name: "Consumption", type: "bar", color: "#ff0000", yAxisIndex: 0, data: []},
                                                   { name: "Cost",        type: "bar", color: "#00ff00", yAxisIndex: 1, data: []}]
                      Der "else"-Zweig sorgt nur dafür, dass eine Fehlermeldung angezeigt wird, wenn Du einen ungültigen Chart-Type anforderst, z.B. mit &chart=Käse. Das hat mit dem eigentlichen Chart überhaupt nichts zu tun.
                      Generell solltest Du - wie auch schon von @legro empfohlen - versuchen, zu verstehen was du tust. Da helfen Readme, Dokus, Tutorials, Youtube-Videos wirklich weiter. Probier's mal!
                      Die Referenz zu Chart-Definitionen findest Du übrigens hier. Wenn Du da die Option "series" aufklappst, findest Du den Parameter "color".
                      • jrbwhJ jrbwh
                        Merlin123M Offline
                        Merlin123M Offline
                        Merlin123
                        schrieb am zuletzt editiert von Merlin123
                        #170
                        @jrbwh Script funktioniert super! Gefällt mir sehr gut :) Mal schauen, wie ich das in meiner VIS einbauen kann.
                        Kleiner Verbesserungsvorschlag:
                        Statt die 4 einzelnen DPs im Script eintragen zu müssen könnte man eine Variable mit der HomeID machen und die 4 anderen DPs daraus automatisch erzeugen.
                        Und blöde Frage: Werden die Charts automatisch aktualisiert? Ich sehe im Scrips nichts, aber meine JS Fähigkeiten sind "limitiert" ;)
                        Beta-Tester
                        SMSS jrbwhJ 2 Antworten Letzte Antwort
                          SMSS Online
                          SMSS Online
                          SMS
                          #171
                          @merlin123 Bei mir nur wenn ich die Seite aktualisiere
                            jrbwhJ Offline
                            jrbwhJ Offline
                            jrbwh
                            #172
                            @merlin123 Das ist eine gute Idee. Die DPs sehen so aus:
                            tibberLink.0.Homes.xxx.Consumption.jsonHourly
                            tibberLink.0.Homes.xxx.Consumption.jsonDaily
                            tibberLink.0.Homes.xxx.Consumption.jsonWeekly
                            tibberLink.0.Homes.xxx.Consumption.jsonMonthly
                            Ist das korrekt? Man könnte also tibberLink.0.Homes.xxx.Consumption also Konstante machen.
                            Nein. Das gibt das Konzept nicht her. Wie ich auch in der Beschreibung geschrieben habe:
                            "Das Chart kann per Hand oder regelmäßig mit der Option refresh (siehe Readme) neu geladen werden. Oder über entsprechende Einstellungen des iFrames."
                            Mit &refresh=30 wird automatisch alle 30 Sekunden aktualisiert. Oder Du konfigurierst den iFrame so, dass regelmäßig aktualisiert wird.
                            • jrbwhJ jrbwh
                              Merlin123M Offline
                              Merlin123M Offline
                              Merlin123
                              #173
                              @jrbwh Jup... sehen bei mir auch so aus:
                              const IDS = { hourly:  'tibberlink.0.Homes.xxx.Consumption.jsonHourly',  // hourly data
                                            daily:   'tibberlink.0.Homes.xxx.Consumption.jsonDaily',  // daily data
                                            weekly:  'tibberlink.0.Homes.xxx.Consumption.jsonWeekly',  // weekly data
                                            monthly: 'tibberlink.0.Homes.xxx.Consumption.jsonMonthly'   // monthly data
                              Aktualisierung:
                              Das hab ich überlesen.
                              Wenn die aber beim Laden des Frames aktualisiert werden, reicht mir das auch :)
                              Beta-Tester
                              jrbwhJ M-A HuebM 2 Antworten Letzte Antwort
                                Aktualisierung:
                                jrbwhJ Offline
                                jrbwhJ Offline
                                jrbwh
                                #174
                                @merlin123 Gut. Hier mal ein Skript zum Testen:
                                // Create chart for Tibber data. To be used with flexcharts.
                                // Sample http request for hourly data chart:
                                // http://localhost:8082/flexcharts/echarts.html?source=script&message=tibber&chart=hourly
                                // Replace 'MY-TOKEN' with your own token:
                                const ID_TIBBER = 'tibberLink.0.Homes.MY-TOKEN.Consumption';
                                const IDS = { hourly:  '.jsonHourly',  // hourly data
                                              daily:   '.jsonDaily',   // daily data
                                              weekly:  '.jsonWeekly',  // weekly data
                                              monthly: '.jsonMonthly'  // monthly data
                                onMessage('tibber', (httpParams, callback) => {
                                    // Use hourly data in case of invalid chart type
                                    const id = (httpParams.chart && httpParams.chart in IDS ? ID_TIBBER+IDS[httpParams.chart] : ID_TIBBER+IDS['hourly']);
                                    if (existsState(id)) {
                                        evalTibberData(httpParams.chart, id, result => callback(result));
                                    } else {
                                        console.log('Requested state is not available >>'+id+'<<');
                                        callback({title: { left: "center", textStyle: { color: "#ff0000" }, text: "REQUESTED STATE IS NOT AVAILABLE: >>" + id +"<<" }});
                                function evalTibberData(myChart, id, callback) {
                                    const tibber = JSON.parse(getState(id).val);  // Read tibber data
                                    const chart = {
                                                    tooltip: { trigger: "axis", axisPointer: { type: "cross" }},
                                                    legend: { show: true, orient: "horizontal", left: "center", top: 25 },
                                                    title: { left: "center", text: "Tibber " },
                                                    grid: { right: "20%" },
                                                    toolbox: { feature: { dataView: { show: true, readOnly: false }, restore: { show: true }, saveAsImage: { show: true }}},
                                    const xAxis  = [];
                                    const yAxis0 = [];
                                    const yAxis1 = [];
                                        const isHourly = (myChart == 'hourly');  // Hourly data?
                                        xAxis.push(xValue);
                                    chart.title.text += myChart;             // Add type of chart to title
                                    console.log('Evaluation of tibber '+myChart+' data done.');
                                    callback(chart);
                                • jrbwhJ jrbwh
                                      } else {
                                      const chart = {
                                      const xAxis  = [];
                                      const yAxis0 = [];
                                      const yAxis1 = [];
                                          xAxis.push(xValue);
                                      callback(chart);
                                  Merlin123M Offline
                                  Merlin123M Offline
                                  Merlin123
                                  #175
                                  @jrbwh nope...
                                  der Name des DPs sieht aber richtig aus....
                                  Beta-Tester
                                    @jrbwh nope...
                                    jrbwhJ Offline
                                    jrbwhJ Offline
                                    jrbwh
                                    #176
                                    @merlin123 Ups, es muss tibberlink heißen und nicht tibberLink (mit großem L). Bitte nochmal mit kleinem l probieren.
                                    • jrbwhJ jrbwh
                                      Merlin123M Offline
                                      Merlin123M Offline
                                      Merlin123
                                      #177
                                      @jrbwh Geht :) Das hab ich jetzt auch nicht gesehen :P
                                      Beta-Tester
                                        jrbwhJ Offline
                                        jrbwhJ Offline
                                        jrbwh
                                        #178
                                        @merlin123 Hab auch eine Weile gebraucht. Aber es musste ein Schreibfehler sein.
                                        Werde gleich den Beitrag unter "Discussions" entsprechend anpassen.
                                        Danke!
                                        • jrbwhJ jrbwh
                                          Danke!
                                          Merlin123M Offline
                                          Merlin123M Offline
                                          Merlin123
                                          #179
                                          @jrbwh Gern.... Bei Hourly macht das Format der Zeit keinen Sinn... Minuten und Sekunden braucht man da nicht. Kann man das anpassen?
                                          Beta-Tester
