  4. Test Adapter Bosch ebik connect / flow
208 Beiträge 41 Kommentatoren 59.2k Aufrufe 46 Beobachtet
  • T tombox
    @reini84 Im Debug log gucken ob mehr angezeigt wird
    reini84
    #105
    @tombox
    2025-01-05 11:04:07.694 - info: admin.0 (622645) <== Disconnect system.user.admin from ::ffff:192.168.178.105 admin
    2025-01-05 11:04:08.082 - info: admin.0 (622645) ==> Connected system.user.admin from ::ffff:192.168.178.105
    2025-01-05 11:04:18.799 - info: host.iobroker stopInstance system.adapter.bosch-ebike.0 (force=false, process=true)
    2025-01-05 11:04:18.801 - info: bosch-ebike.0 (630546) Got terminate signal TERMINATE_YOURSELF
    2025-01-05 11:04:18.802 - info: bosch-ebike.0 (630546) terminating
    2025-01-05 11:04:18.802 - debug: bosch-ebike.0 (630546) Plugin sentry destroyed
    2025-01-05 11:04:18.802 - info: bosch-ebike.0 (630546) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-01-05 11:04:18.840 - info: host.iobroker stopInstance system.adapter.bosch-ebike.0 send kill signal
    2025-01-05 11:04:19.303 - info: bosch-ebike.0 (630546) terminating
    2025-01-05 11:04:19.348 - info: host.iobroker instance system.adapter.bosch-ebike.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-01-05 11:04:22.643 - info: host.iobroker instance system.adapter.bosch-ebike.0 in version "0.1.11" (non-npm: TA2k/ioBroker.bosch-ebike#9d120a0b148beb20559824ec0febdd65da975e2d) started with pid 630576
    2025-01-05 11:04:23.116 - debug: bosch-ebike.0 (630576) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2025-01-05 11:04:23.134 - debug: bosch-ebike.0 (630576) Objects client ready ... initialize now
    2025-01-05 11:04:23.176 - debug: bosch-ebike.0 (630576) Objects create System PubSub Client
    2025-01-05 11:04:23.177 - debug: bosch-ebike.0 (630576) Objects create User PubSub Client
    2025-01-05 11:04:23.202 - debug: bosch-ebike.0 (630576) Objects client initialize lua scripts
    2025-01-05 11:04:23.205 - debug: bosch-ebike.0 (630576) Objects connected to redis: 0.0.0.0:9001
    2025-01-05 11:04:23.223 - debug: bosch-ebike.0 (630576) Redis States: Use Redis connection: 0.0.0.0:9000
    2025-01-05 11:04:23.231 - debug: bosch-ebike.0 (630576) States create System PubSub Client
    2025-01-05 11:04:23.231 - debug: bosch-ebike.0 (630576) States create User PubSub Client
    2025-01-05 11:04:23.286 - debug: bosch-ebike.0 (630576) States connected to redis: 0.0.0.0:9000
    2025-01-05 11:04:23.303 - debug: bosch-ebike.0 (630576) Plugin sentry Initialize Plugin (enabled=true)
    2025-01-05 11:04:23.439 - info: bosch-ebike.0 (630576) starting. Version 0.1.11 (non-npm: TA2k/ioBroker.bosch-ebike#9d120a0b148beb20559824ec0febdd65da975e2d) in /opt/iobroker/node_modules/iobroker.bosch-ebike, node: v20.18.1, js-controller: 7.0.6
    2025-01-05 11:04:23.455 - info: bosch-ebike.0 (630576) Login to eBike flow
    2025-01-05 11:04:23.456 - error: bosch-ebike.0 (630576) Please set captcha in the instance settings
    2025-01-05 11:04:29.847 - info: admin.0 (622645) ==> Connected system.user.admin from ::ffff:192.168.178.105
    2025-01-05 11:04:30.049 - info: sonoff.0 (613233) Client [Heizung] reconnected. Old secret 1735914402782_2115 ==> New secret 1736071470048_7239
    2025-01-05 11:04:33.129 - info: host.iobroker stopInstance system.adapter.bosch-ebike.0 (force=false, process=true)
    2025-01-05 11:04:33.131 - info: bosch-ebike.0 (630576) Got terminate signal TERMINATE_YOURSELF
    2025-01-05 11:04:33.132 - info: bosch-ebike.0 (630576) terminating
    2025-01-05 11:04:33.132 - debug: bosch-ebike.0 (630576) Plugin sentry destroyed
    2025-01-05 11:04:33.133 - info: bosch-ebike.0 (630576) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-01-05 11:04:33.171 - info: host.iobroker stopInstance system.adapter.bosch-ebike.0 send kill signal
    2025-01-05 11:04:33.633 - info: bosch-ebike.0 (630576) terminating
    2025-01-05 11:04:33.676 - info: host.iobroker instance system.adapter.bosch-ebike.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-01-05 11:04:36.589 - info: admin.0 (622645) <== Disconnect system.user.admin from ::ffff:192.168.178.105
    2025-01-05 11:04:36.972 - info: host.iobroker instance system.adapter.bosch-ebike.0 in version "0.1.11" (non-npm: TA2k/ioBroker.bosch-ebike#9d120a0b148beb20559824ec0febdd65da975e2d) started with pid 630591
    2025-01-05 11:04:37.452 - debug: bosch-ebike.0 (630591) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2025-01-05 11:04:37.469 - debug: bosch-ebike.0 (630591) Objects client ready ... initialize now
    2025-01-05 11:04:37.470 - debug: bosch-ebike.0 (630591) Objects create System PubSub Client
    2025-01-05 11:04:37.471 - debug: bosch-ebike.0 (630591) Objects create User PubSub Client
    2025-01-05 11:04:37.497 - debug: bosch-ebike.0 (630591) Objects client initialize lua scripts
    2025-01-05 11:04:37.500 - debug: bosch-ebike.0 (630591) Objects connected to redis: 0.0.0.0:9001
    2025-01-05 11:04:37.519 - debug: bosch-ebike.0 (630591) Redis States: Use Redis connection: 0.0.0.0:9000
    2025-01-05 11:04:37.527 - debug: bosch-ebike.0 (630591) States create System PubSub Client
    2025-01-05 11:04:37.528 - debug: bosch-ebike.0 (630591) States create User PubSub Client
    2025-01-05 11:04:37.583 - debug: bosch-ebike.0 (630591) States connected to redis: 0.0.0.0:9000
    2025-01-05 11:04:37.602 - debug: bosch-ebike.0 (630591) Plugin sentry Initialize Plugin (enabled=true)
    2025-01-05 11:04:37.728 - info: bosch-ebike.0 (630591) starting. Version 0.1.11 (non-npm: TA2k/ioBroker.bosch-ebike#9d120a0b148beb20559824ec0febdd65da975e2d) in /opt/iobroker/node_modules/iobroker.bosch-ebike, node: v20.18.1, js-controller: 7.0.6
    2025-01-05 11:04:37.744 - info: bosch-ebike.0 (630591) Login to eBike flow
    2025-01-05 11:04:38.583 - <span class="type">debug</span>: bosch-ebike.0 (630591) "\n\n\n\n \n <title>Willkommen - SingleKey ID</title>\n <meta name="\"description\"" content="\"Willkommen\"">\n\n <base href="\"https://singlekey-id.com\"">\n <link rel="\"icon\"" type="\"image/svg+xml\"" href="\"https://cdn.singlekey-id.com/images/favicons/vector.fLinwNmN0b4.svg\"" sizes="\"any\"">\n <link rel="\"icon\"" type="\"image/png\"" href="\"https://cdn.singlekey-id.com/images/favicons/16x16.Ie2d4OLHBZc.png\"" sizes="\"16x16\"">\n\n <meta name="\"viewport\"" content="\"width=device-width," initial-scale="1\"">\n\n <meta name="\"htmx-config\"" content="{\"inlineScriptNonce\":\"BGPomBS76d7pEfO8KFP12B-e\", \"includeIndicatorStyles\":false, \"refreshOnHistoryMiss\": true, \"timeout\": 20000}">\n\n \n <link rel="\"stylesheet\"" href="\"https://cdn.singlekey-id.com/styles/default.8ULbJ7zIe70.css\"">\n\n \n\n\n <script nonce="\"BGPomBS76d7pEfO8KFP12B-e\"">\n document.querySelector(\"html\").className = \"js\";\n </script>\n \n\n \n <div class="\"captcha-dialog\"">\n <div class="\"captcha-dialog__content\""></div>\n </div>\n\n \n\n\n\n<header class="\"seamless-layout__header\"">\n <h1>\n <a class="\"seamless-layout__header-link\"" data-hx-boost="\"false\"" href="\"/de-de/home\"">\n <picture>\n <source media="\"(max-width:" 767.999px)\"="" srcset="\"https://cdn.singlekey-id.com/images/logo-on-dark.t-FKZg_FN7I.svg\"">\n <img class="\"seamless-layout__skid-logo\"" src="\"https://cdn.singlekey-id.com/images/logo-on-light.qEQuOq98Y4I.svg\"" alt="\"SingleKey" id\"="">\n </picture>\n </a>\n </h1>\n\n <img class="\"seamless-layout__partner-logo\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/brand-logo.4p7gk_UxIDA.svg\"" alt="\"Bosch\"" data-testid="\"seamless-partner-logo\"">\n</header>\n\n<main class="\"seamless-layout__main\"" data-hx-swap="\"show:none" focus-scroll:true\"="">\n <div class="\"seamless-layout__left-panel\"">\n <div class="\"seamless-layout__content\"">\n \n<div id="\"inline-messages\"" class="\"" messages\"="">\n <noscript>\n <div class=\"message message--error message--permanent\" data-testid=\"javascript-required-error\">\n <i class=\"message__icon icon icon--size-l icon--error\"></i>\n <span>Bitte aktivieren Sie JavaScript, um fortzufahren.</span>\n </div>\n </noscript>\n</div>\n\n <div id="\"body\"">\n \n\n\n<div class="\"seamless-content\"" data-hx-boost="\"true\"" data-testid="\"enter-username\"">\n <h2 class="\"seamless-content__header\"">\n Registrieren oder einloggen\n \n<div class="\"popup" \"="">\n <a class="\"popup__open-popup\"" role="\"button\"" aria-label="\"Open" popup\"="" aria-expanded="\"false\"" aria-controls="\"signup-or-login-hint\"" hx-boost="\"false\"" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx#signup-or-login-hint\"">\n <i class="\"icon" icon--info="" popup__open-popup-icon="" icon--size-s\"=""></i>\n </a>\n <div id="\"signup-or-login-hint\"" class="\"popup__content\"">\n <h2 class="\"popup__header\"">\n Registrieren oder einloggen\n <a class="\"popup__close-popup\"" role="\"button\"" aria-label="\"Close" popup\"="" hx-boost="\"false\"" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx#\"">\n <i class="\"icon" icon--close="" icon--invert="" icon--size-s\"=""></i>\n </a>\n </h2>\n <p class="\"popup__text\"">Bitte geben Sie Ihre E-Mail-Adresse oder Handynummer ein, damit wir prüfen können, ob Sie bereits eine SingleKey ID haben. Wir leiten Sie dann entweder zur Anmeldung oder zur Registrierung weiter.</p>\n </div>\n</div>\n </h2>\n\n <form class="\"form\"" method="\"post\"">\n \n\n<div>\n\n\n\n\n<div class="\"input\"">\n <input class="\"input__element\"" type="\"text\"" inputmode="\"email\"" placeholder="\" \"" autocomplete="\"email\"" autofocus="\"autofocus\"" id="\"UserIdentifierInput_EmailInput_StringValue\"" name="\"UserIdentifierInput.EmailInput.StringValue\"" value="\"\"">\n <label class="\"input__placeholder\"" for="\"UserIdentifierInput_EmailInput_StringValue\"">E-Mail</label>\n \n</div> <a data-testid="\"user-identifier-switch-to-phone-link\"" class="\"link" user-identifier__switch-link\"="" href="\"/de-de/login?input=phone&returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n <i class="\"user-identifier__icon" icon="" icon--smartphone-blue="" icon--size-s\"=""></i>\n <span>Handynummer verwenden</span>\n </a>\n</div>\n\n \n<div class="\"form__actions\"">\n\n <button class="\"button" button--submit="" button--protected\"="" data-loading-class="\"button--loading\"" data-testid="\"enter-username.submit\"" data-sitekey="\"f8fe2d56-ad42-4f44-b9fe-5b30fcb0dd38\"" data-hl="\"de\"" disabled="\"\"">\n Weiter\n <span class="\"button__spinner\"">\n <i class="\"icon" icon--spinner="" icon--size-l\"=""></i>\n </span>\n </button>\n</div>\n <input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QDUtwJh6c3XWMrt76-0kJH1OHg_Pq9_HtGlJxUojIXIcAaAm4GUzUZhnb8_WQePNhamcWkEB8hWgGAsVBD4J4UL9QTWI3xbsRIcIPmFGG2eeri6g99HyBg_3BXed-6zu7M\""></form>\n</div>\n </div>\n </div>\n <div class="\"about\"" id="\"about\"" data-hx-boost="\"false\"">\n <div class="\"about__header\"">\n <text class="\"about__title\"">Ein Login für viele Marken</text>\n <a class="\"about__show-info\"" role="\"button\"" aria-expanded="\"false\"" aria-controls="\"info\"" aria-label="\"Show" singlekey="" id="" info\"="" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx#about\"">\n <i class="\"icon" icon--arrow-down="" icon--size-m="" icon--invert="" icon--rotate180\"=""></i>\n </a>\n <a class="\"about__hide-info\"" role="\"button\"" aria-expanded="\"false\"" aria-controls="\"info\"" aria-label="\"Hide" singlekey="" id="" info\"="" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx#\"">\n <i class="\"icon" icon--arrow-down="" icon--size-m="" icon--invert\"=""></i>\n </a>\n </div>\n \n<div class="\"brands" about__brands\"="">\n <button class="\"brands__nav" brands__btn-left="" brands__btn-left--hidden="" button="" button--icon\"="" role="\"button\"" aria-hidden="\"true\"">\n <i class="\"icon" icon--arrow-left="" icon--size-m\"=""></i>\n </button>\n <div class="\"brands__carousel\"">\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Bosch\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_01.4p7gk_UxIDA.svg\"" width="\"130\"" height="\"28,822172\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Siemens" home="" appliances\"="" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_02.VXu-FBivXhE.svg\"" width="\"130\"" height="\"52,769993\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Buderus\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_03.OiMrTqOdPwk.svg\"" width="\"130\"" height="\"47,068966\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Home" connect\"="" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_04.yP-gzACpJjE.svg\"" width="\"130\"" height="\"21,77665\"" draggable="\"false\"">\n </div>\n </div>\n <button class="\"brands__nav" brands__btn-right="" button="" button--icon\"="" role="\"button\"">\n <i class="\"icon" icon--arrow-right="" icon--size-m\"=""></i>\n </button>\n</div>\n <div class="\"about__info\""><a href="\"/our-promise/\"">SingleKey ID</a> bietet bequemen Zugang zu Websites, Shops, Apps und Services vieler Marken mit <b>einem einzigen Login</b>.</div>\n </div>\n </div>\n <div class="\"seamless-layout__right-panel\"">\n <picture>\n <source media="\"(max-width:" 767.999px)\"="" sizes="\"1px\"" srcset="\"https://cdn.singlekey-id.com/images/none.590RTqhrx1o.gif" 1w\"="">\n\n <source media="\"(min-width:" 768px)\"="" type="\"image/avif\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.DzqOrR_opYg.avif" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.7mgln4u6d_s.avif="" 1024w,="" background_1366x986.zu1usdfcir4.avif="" 1366w,="" background_1600x1155.5wo0czejume.avif="" 1600w,="" background_1920x1386.mhctivdddms.avif="" 1920w\"="">\n <source media="\"(min-width:" 768px)\"="" type="\"image/webp\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.4m-_t_WNuD4.webp" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.aqnzlbdi_no.webp="" 1024w,="" background_1366x986.ulgityj-5a0.webp="" 1366w,="" background_1600x1155.gviq-nk338y.webp="" 1600w,="" background_1920x1386.efuynlavpgu.webp="" 1920w\"="">\n <source media="\"(min-width:" 768px)\"="" type="\"image/jpeg\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.AAH3SmmHwGE.jpg" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.xzvtpkydfve.jpg="" 1024w,="" background_1366x986.jfxrhjeqyw8.jpg="" 1366w,="" background_1600x1155.udo9ihuhy48.jpg="" 1600w,="" background_1920x1386.g6onbgekap8.jpg="" 1920w\"="">\n <img class="\"seamless-layout__hero-image\"" alt="\"\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/background_1920x1386.g6ONbGEKAp8.jpg\"" data-testid="\"seamless-background\"">\n </picture>\n </div>\n</main>\n\n\n\n<footer class="\"footer\"">\n <nav class="\"footer__content" footer__content--justified\"="">\n <ul class="\"footer__links\"">\n <li>\n <a class="\"footer__link\"" href="\"/de-de/corporate-info-and-legal-notice\"" data-hx-boost="\"false\"">\n Impressum\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/de-de/data-protection-notice\"" data-hx-boost="\"false\"">\n Datenschutzrichtlinie\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/de-de/corporate-info-and-legal-notice\"" data-hx-boost="\"false\"">\n Rechtliche Hinweise\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/de-de/terms-of-use\"" data-hx-boost="\"false\"">\n Nutzungsbedingungen\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"https://cdn.singlekey-id.com/disclosure-document.BMdLREMiXRU.pdf\"" data-hx-boost="\"false\"">\n Open Source Informationen\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/de-de/frequently-asked-questions\"" data-hx-boost="\"false\"">\n FAQs\n </a>\n </li>\n </ul>\n \n\n<form class="\"language-switch" footer__link\"="" method="\"post\"" action="\"/de-de/language\"">\n <i class="\"icon" icon--globe="" icon--size-xl\"=""></i>\n <select name="\"culture\"" class="\"language-switch__select\"" data-testid="\"language-switch\""><option value="\"az-AZ\"">azərbaycan (Azərbaycan)</option>\n<option value="\"bs-BA\"">bosanski (Bosna i Hercegovina)</option>\n<option value="\"cs-CZ\"">čeština (Česko)</option>\n<option value="\"da-DK\"">dansk (Danmark)</option>\n<option value="\"de-BE\"">Deutsch (Belgien)</option>\n<option selected="\"selected\"" value="\"de-DE\"">Deutsch (Deutschland)</option>\n<option value="\"de-LI\"">Deutsch (Liechtenstein)</option>\n<option value="\"de-LU\"">Deutsch (Luxemburg)</option>\n<option value="\"de-AT\"">Deutsch (Österreich)</option>\n<option value="\"de-CH\"">Deutsch (Schweiz)</option>\n<option value="\"et-EE\"">eesti (Eesti)</option>\n<option value="\"en-AU\"">English (Australia)</option>\n<option value="\"en-BD\"">English (Bangladesh)</option>\n<option value="\"en-CA\"">English (Canada)</option>\n<option value="\"en-GH\"">English (Ghana)</option>\n<option value="\"en-IN\"">English (India)</option>\n<option value="\"en-IE\"">English (Ireland)</option>\n<option value="\"en-KE\"">English (Kenya)</option>\n<option value="\"en-MY\"">English (Malaysia)</option>\n<option value="\"en-MT\"">English (Malta)</option>\n<option value="\"en-NP\"">English (Nepal)</option>\n<option value="\"en-NZ\"">English (New Zealand)</option>\n<option value="\"en-NG\"">English (Nigeria)</option>\n<option value="\"en-PH\"">English (Philippines)</option>\n<option value="\"en-SG\"">English (Singapore)</option>\n<option value="\"en-ZA\"">English (South Africa)</option>\n<option value="\"en-LK\"">English (Sri Lanka)</option>\n<option value="\"en-GB\"">English (United Kingdom)</option>\n<option value="\"en-US\"">English (United States)</option>\n<option value="\"es-AR\"">español (Argentina)</option>\n<option value="\"es-BO\"">español (Bolivia)</option>\n<option value="\"es-CL\"">español (Chile)</option>\n<option value="\"es-CO\"">español (Colombia)</option>\n<option value="\"es-CR\"">español (Costa Rica)</option>\n<option value="\"es-EC\"">español (Ecuador)</option>\n<option value="\"es-SV\"">español (El Salvador)</option>\n<option value="\"es-ES\"">español (España)</option>\n<option value="\"es-GT\"">español (Guatemala)</option>\n<option value="\"es-HN\"">español (Honduras)</option>\n<option value="\"es-MX\"">español (México)</option>\n<option value="\"es-NI\"">español (Nicaragua)</option>\n<option value="\"es-PA\"">español (Panamá)</option>\n<option value="\"es-PY\"">español (Paraguay)</option>\n<option value="\"es-PE\"">español (Perú)</option>\n<option value="\"es-DO\"">español (República Dominicana)</option>\n<option value="\"es-UY\"">español (Uruguay)</option>\n<option value="\"es-VE\"">español (Venezuela)</option>\n<option value="\"fr-BE\"">français (Belgique)</option>\n<option value="\"fr-CA\"">français (Canada)</option>\n<option value="\"fr-FR\"">français (France)</option>\n<option value="\"fr-LU\"">français (Luxembourg)</option>\n<option value="\"fr-CH\"">français (Suisse)</option>\n<option value="\"fr-TN\"">français (Tunisie)</option>\n<option value="\"hr-HR\"">hrvatski (Hrvatska)</option>\n<option value="\"id-ID\"">Indonesia (Indonesia)</option>\n<option value="\"is-IS\"">íslenska (Ísland)</option>\n<option value="\"it-IT\"">italiano (Italia)</option>\n<option value="\"it-CH\"">italiano (Svizzera)</option>\n<option value="\"lv-LV\"">latviešu (Latvija)</option>\n<option value="\"lt-LT\"">lietuvių (Lietuva)</option>\n<option value="\"hu-HU\"">magyar (Magyarország)</option>\n<option value="\"cnr-ME\"">Montenegrin (Montenegro)</option>\n<option value="\"nl-BE\"">Nederlands (België)</option>\n<option value="\"nl-NL\"">Nederlands (Nederland)</option>\n<option value="\"no-NO\"">norsk (Norge)</option>\n<option value="\"pl-PL\"">polski (Polska)</option>\n<option value="\"pt-AO\"">português (Angola)</option>\n<option value="\"pt-BR\"">português (Brasil)</option>\n<option value="\"pt-PT\"">português (Portugal)</option>\n<option value="\"ro-MD\"">română (Republica Moldova)</option>\n<option value="\"ro-RO\"">română (România)</option>\n<option value="\"sq-XK\"">shqip (Kosovë)</option>\n<option value="\"sq-AL\"">shqip (Shqipëri)</option>\n<option value="\"sk-SK\"">slovenčina (Slovensko)</option>\n<option value="\"sl-SI\"">slovenščina (Slovenija)</option>\n<option value="\"fi-FI\"">suomi (Suomi)</option>\n<option value="\"sv-SE\"">svenska (Sverige)</option>\n<option value="\"vi-VN\"">Tiếng Việt (Việt Nam)</option>\n<option value="\"tr-TR\"">Türkçe (Türkiye)</option>\n<option value="\"el-GR\"">Ελληνικά (Ελλάδα)</option>\n<option value="\"el-CY\"">Ελληνικά (Κύπρος)</option>\n<option value="\"bg-BG\"">български (България)</option>\n<option value="\"kk-KZ\"">қазақ тілі (Қазақстан)</option>\n<option value="\"mk-MK\"">македонски (Северна Македонија)</option>\n<option value="\"sr-RS\"">српски (Србија)</option>\n<option value="\"uk-UA\"">українська (Україна)</option>\n<option value="\"ka-GE\"">ქართული (საქართველო)</option>\n<option value="\"he-IL\"">עברית (ישראל)</option>\n<option value="\"ar-AE\"">العربية (الإمارات العربية المتحدة)</option>\n<option value="\"ar-BH\"">العربية (البحرين)</option>\n<option value="\"ar-KW\"">العربية (الكويت)</option>\n<option value="\"ar-MA\"">العربية (المغرب)</option>\n<option value="\"ar-SA\"">العربية (المملكة العربية السعودية)</option>\n<option value="\"ar-TN\"">العربية (تونس)</option>\n<option value="\"ar-OM\"">العربية (عُمان)</option>\n<option value="\"ar-QA\"">العربية (قطر)</option>\n<option value="\"ar-LB\"">العربية (لبنان)</option>\n<option value="\"ar-EG\"">العربية (مصر)</option>\n<option value="\"th-TH\"">ไทย (ไทย)</option>\n<option value="\"ko-KR\"">한국어(대한민국)</option>\n<option value="\"zh-HK\"">中文(中國香港特別行政區)</option>\n<option value="\"zh-TW\"">中文(台灣)</option>\n<option value="\"ja-JP\"">日本語 (日本)</option>\n</select>\n <input data-hx-swap-oob="\"true\"" id="\"language-switch\"" name="\"returnPath\"" type="\"hidden\"" value="\"/de-de/login?ReturnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n\n <button class="\"language-switch__submit" button="" button--submit\"="" type="\"submit\"">\n Speichern\n </button>\n<input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QDUtwJh6c3XWMrt76-0kJH1OHg_Pq9_HtGlJxUojIXIcAaAm4GUzUZhnb8_WQePNhamcWkEB8hWgGAsVBD4J4UL9QTWI3xbsRIcIPmFGG2eeri6g99HyBg_3BXed-6zu7M\""></form>\n </nav>\n</footer>\n\n <script type="\"module\"" src="\"https://cdn.singlekey-id.com/scripts/htmx.00GdzawUlLg.mjs\""></script>\n\n <script type="\"module\"" src="\"https://cdn.singlekey-id.com/scripts/base.veDyGCvmY8w.mjs\""></script>\n <script defer="" nomodule="" src="\"https://cdn.singlekey-id.com/scripts/base.B5E8ztDgVe0.js\""></script>\n\n <script nonce="\"BGPomBS76d7pEfO8KFP12B-e\"">(function() {\n if (window.hcaptcha === undefined) {\n var hcaptchaScript = document.createElement('script');\n hcaptchaScript.src = 'https://js.hcaptcha.com/1/api.js?recaptchacompat=off&onload=onHCaptchaLoaded&render=explicit';\n hcaptchaScript.defer = true;\n hcaptchaScript.async = true;\n document.head.appendChild(hcaptchaScript);\n }\n})();</script>\n\n \n \n\n \n\n"
    2025-01-05 11:04:38.892 - <span class="type">debug</span>: bosch-ebike.0 (630591) "\n\n\n\n\n<div class="\"seamless-content\"" data-hx-boost="\"true\"">\n <h2 class="\"seamless-content__header\"">Einloggen</h2>\n <form class="\"form\"" method="\"post\"" data-hx-boost="\"true\"">\n \n<a class="\"seamless-content__username-link" link\"="" data-testid="\"link-back-to-login\"" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n <i class="\"icon" icon--arrow-left="" icon--size-s\"=""></i>\n <span class="\"break-word\"">reinhold.dobmeier@gmail.com</span>\n</a>\n \n<div class="\"input\"">\n <input class="\"input__element\"" placeholder="\" \"" autocomplete="\"current-password\"" autofocus="\"autofocus\"" type="\"password\"" id="\"Password\"" name="\"Password\"">\n <label class="\"input__placeholder\"" for="\"Password\"">Passwort</label>\n \n\n <button class="\"input__password-toggle" button="" button--icon\"="" type="\"button\"" role="\"switch\"" aria-pressed="\"false\"" title="\"Sichtbarkeit" des="" passworts="" umschalten\"="" aria-label="\"Sichtbarkeit">\n <i class="\"icon" icon--eye-open="" icon--size-l\"=""></i>\n </button>\n</div>\n <div class="\"password\"">\n <div class="\"password__remember-me\"">\n \n<div class="\"input" checkbox\"="">\n <div class="\"checkbox__group\"">\n <input class="\"checkbox__element\"" type="\"checkbox\"" id="\"RememberMe\"" name="\"RememberMe\"" value="\"true\"">\n <label class="\"checkbox__label\"" for="\"RememberMe\"">Eingeloggt bleiben</label>\n </div>\n \n</div>\n </div>\n <div class="\"password__forgot-password\"">\n <button class="\"link\"" data-testid="\"link-forgot-password\"" formaction="\"/de-de/login/password?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx&handler=ForgotPassword\"">Passwort vergessen?</button>\n </div>\n </div>\n\n \n<div class="\"form__actions\"">\n\n <button class="\"button" button--submit\"="" data-loading-class="\"button--loading\"" type="\"submit\"" data-testid="\"enter-password.submit\"">\n Weiter\n <span class="\"button__spinner\"">\n <i class="\"icon" icon--spinner="" icon--size-l\"=""></i>\n </span>\n </button>\n</div>\n <input name="\"RememberMe\"" type="\"hidden\"" value="\"false\""><input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QA2_h-JjdAD9WWabPzgckLb0i_cF9CmQ3AO_iWkbi31ZwyLoMAuYMnxcL3Ud9woFzIn8b3ALwarwhrgQXSA2ty9xynP2QoZgjRVY5BNbCqIJa5Asyy6JNvIsWMa24f_2-0\""></form>\n</div>\n\n<script nonce="\"X90qMjdVnI65X4PF1ou1P7ev\"">\n setTimeout(() => {\n document.title = \"Willkommen - SingleKey ID\";\n document.querySelector('meta[name=\"description\"]').setAttribute(\"content\", \"Willkommen\");\n document.body.setAttribute(\"data-testid\", \"login\");\n }, 0);\n</script>\n\n <a id="\"login-button\"" class="\"header__button" header__button--secondary="" header__button--login\"="" data-hx-swap-oob="\"true\"" data-hx-boost="\"false\"" data-testid="\"login\"" href="\"/de-de/login?forward=%2Fde-de%2Flogin%2Fpassword%3FreturnUrl%3D%252Fauth%252Fconnect%252Fauthorize%252Fcallback%253Fscope%253Dopenid%252520email%252520profile%252520offline_access%2526state%253DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%2526response_type%253Dcode%2526client_id%253DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%2526redirect_uri%253Dhttps%25253A%25252F%25252Fp9.authz.bosch.com%25252Fauth%25252Frealms%25252Fobc%25252Fbroker%25252Fskid%25252Fendpoint%2526prompt%253Dlogin%2526code_challenge%253DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%2526code_challenge_method%253DS256%2526nonce%253DMZqss0rdp9TovSq2Zs_vZQ%2526suppressed_prompt%253Dlogin%26f%3DaUyx&returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n Einloggen\n </a>\n\n\n\n\n\n<div id="\"inline-messages\"" class="\"" messages\"="" data-hx-swap-oob="\"innerHTML\"">\n</div>\n\n <input data-hx-swap-oob="\"true\"" id="\"language-switch\"" name="\"returnPath\"" type="\"hidden\"" value="\"/de-de/login/password?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n\n\n\n <link rel="\"stylesheet\"" href="\"https://cdn.singlekey-id.com/styles/pages/login-or-signup/enter-password.ni6XlYwjP1Q.css\"">\n\n\n\n"
    2025-01-05 11:04:39.643 - <span class="type">debug</span>: bosch-ebike.0 (630591) "\n\n\n\n \n <title>Welcome - SingleKey ID</title>\n <meta name="\"description\"" content="\"Welcome\"">\n\n <base href="\"https://singlekey-id.com\"">\n <link rel="\"icon\"" type="\"image/svg+xml\"" href="\"https://cdn.singlekey-id.com/images/favicons/vector.fLinwNmN0b4.svg\"" sizes="\"any\"">\n <link rel="\"icon\"" type="\"image/png\"" href="\"https://cdn.singlekey-id.com/images/favicons/16x16.Ie2d4OLHBZc.png\"" sizes="\"16x16\"">\n\n <meta name="\"viewport\"" content="\"width=device-width," initial-scale="1\"">\n\n <meta name="\"htmx-config\"" content="{\"inlineScriptNonce\":\"xi6ip3ZL9NWZ-x3udR9k7D8N\", \"includeIndicatorStyles\":false, \"refreshOnHistoryMiss\": true, \"timeout\": 20000}">\n\n \n <link rel="\"stylesheet\"" href="\"https://cdn.singlekey-id.com/styles/default.8ULbJ7zIe70.css\"">\n\n \n\n\n <script nonce="\"xi6ip3ZL9NWZ-x3udR9k7D8N\"">\n document.querySelector(\"html\").className = \"js\";\n </script>\n \n\n \n <div class="\"captcha-dialog\"">\n <div class="\"captcha-dialog__content\""></div>\n </div>\n\n \n\n\n\n<header class="\"seamless-layout__header\"">\n <h1>\n <a class="\"seamless-layout__header-link\"" data-hx-boost="\"false\"" href="\"/en-gb/home\"">\n <picture>\n <source media="\"(max-width:" 767.999px)\"="" srcset="\"https://cdn.singlekey-id.com/images/logo-on-dark.t-FKZg_FN7I.svg\"">\n <img class="\"seamless-layout__skid-logo\"" src="\"https://cdn.singlekey-id.com/images/logo-on-light.qEQuOq98Y4I.svg\"" alt="\"SingleKey" id\"="">\n </picture>\n </a>\n </h1>\n\n <img class="\"seamless-layout__partner-logo\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/brand-logo.4p7gk_UxIDA.svg\"" alt="\"Bosch\"" data-testid="\"seamless-partner-logo\"">\n</header>\n\n<main class="\"seamless-layout__main\"" data-hx-swap="\"show:none" focus-scroll:true\"="">\n <div class="\"seamless-layout__left-panel\"">\n <div class="\"seamless-layout__content\"">\n \n<div id="\"inline-messages\"" class="\"" messages\"="">\n <noscript>\n <div class=\"message message--error message--permanent\" data-testid=\"javascript-required-error\">\n <i class=\"message__icon icon icon--size-l icon--error\"></i>\n <span>Please activate JavaScript in order to progress.</span>\n </div>\n </noscript>\n</div>\n\n <div id="\"body\"">\n \n\n\n<div class="\"seamless-content\"" data-hx-boost="\"true\"" data-testid="\"enter-username\"">\n <h2 class="\"seamless-content__header\"">\n Sign up or log in\n \n<div class="\"popup" \"="">\n <a class="\"popup__open-popup\"" role="\"button\"" aria-label="\"Open" popup\"="" aria-expanded="\"false\"" aria-controls="\"signup-or-login-hint\"" hx-boost="\"false\"" href="\"/en-gb/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U#signup-or-login-hint\"">\n <i class="\"icon" icon--info="" popup__open-popup-icon="" icon--size-s\"=""></i>\n </a>\n <div id="\"signup-or-login-hint\"" class="\"popup__content\"">\n <h2 class="\"popup__header\"">\n Sign up or log in\n <a class="\"popup__close-popup\"" role="\"button\"" aria-label="\"Close" popup\"="" hx-boost="\"false\"" href="\"/en-gb/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U#\"">\n <i class="\"icon" icon--close="" icon--invert="" icon--size-s\"=""></i>\n </a>\n </h2>\n <p class="\"popup__text\"">Please enter your email address or mobile phone number and we will check if you already have a SingleKey ID. We will then redirect you to either login or signup.</p>\n </div>\n</div>\n </h2>\n\n <form class="\"form\"" method="\"post\"">\n \n\n<div>\n\n\n\n\n<div class="\"input\"">\n <input class="\"input__element\"" type="\"text\"" inputmode="\"email\"" placeholder="\" \"" autocomplete="\"email\"" autofocus="\"autofocus\"" id="\"UserIdentifierInput_EmailInput_StringValue\"" name="\"UserIdentifierInput.EmailInput.StringValue\"" value="\"\"">\n <label class="\"input__placeholder\"" for="\"UserIdentifierInput_EmailInput_StringValue\"">Email</label>\n \n</div> <a data-testid="\"user-identifier-switch-to-phone-link\"" class="\"link" user-identifier__switch-link\"="" href="\"/en-gb/login?input=phone&returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U\"">\n <i class="\"user-identifier__icon" icon="" icon--smartphone-blue="" icon--size-s\"=""></i>\n <span>Use mobile phone number </span>\n </a>\n</div>\n\n \n<div class="\"form__actions\"">\n\n <button class="\"button" button--submit="" button--protected\"="" data-loading-class="\"button--loading\"" data-testid="\"enter-username.submit\"" data-sitekey="\"f8fe2d56-ad42-4f44-b9fe-5b30fcb0dd38\"" data-hl="\"en\"" disabled="\"\"">\n Continue\n <span class="\"button__spinner\"">\n <i class="\"icon" icon--spinner="" icon--size-l\"=""></i>\n </span>\n </button>\n</div>\n <input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QDFDwsyguCI1OC2qSE4eGok8_Ub_Sb1sUkzhNvfOMH1PoGYxvsWgO9NDDyDGR_itfjTwG1yA09fs1iL4xN0snXsQaj2M6Zorz1-0qVbpFTii3_VOSv7wi1OYNtRTsFI1J0\""></form>\n</div>\n </div>\n </div>\n <div class="\"about\"" id="\"about\"" data-hx-boost="\"false\"">\n <div class="\"about__header\"">\n <text class="\"about__title\"">One login for many brands</text>\n <a class="\"about__show-info\"" role="\"button\"" aria-expanded="\"false\"" aria-controls="\"info\"" aria-label="\"Show" singlekey="" id="" info\"="" href="\"/en-gb/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U#about\"">\n <i class="\"icon" icon--arrow-down="" icon--size-m="" icon--invert="" icon--rotate180\"=""></i>\n </a>\n <a class="\"about__hide-info\"" role="\"button\"" aria-expanded="\"false\"" aria-controls="\"info\"" aria-label="\"Hide" singlekey="" id="" info\"="" href="\"/en-gb/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U#\"">\n <i class="\"icon" icon--arrow-down="" icon--size-m="" icon--invert\"=""></i>\n </a>\n </div>\n \n<div class="\"brands" about__brands\"="">\n <button class="\"brands__nav" brands__btn-left="" brands__btn-left--hidden="" button="" button--icon\"="" role="\"button\"" aria-hidden="\"true\"">\n <i class="\"icon" icon--arrow-left="" icon--size-m\"=""></i>\n </button>\n <div class="\"brands__carousel\"">\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Bosch\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_01.4p7gk_UxIDA.svg\"" width="\"130\"" height="\"28.822172\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Siemens" home="" appliances\"="" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_02.VXu-FBivXhE.svg\"" width="\"130\"" height="\"52.769993\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Buderus\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_03.OiMrTqOdPwk.svg\"" width="\"130\"" height="\"47.068966\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Home" connect\"="" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_04.yP-gzACpJjE.svg\"" width="\"130\"" height="\"21.77665\"" draggable="\"false\"">\n </div>\n </div>\n <button class="\"brands__nav" brands__btn-right="" button="" button--icon\"="" role="\"button\"">\n <i class="\"icon" icon--arrow-right="" icon--size-m\"=""></i>\n </button>\n</div>\n <div class="\"about__info\""><a href="\"/our-promise/\"">SingleKey ID</a> offers convenient access to websites, shops, apps and services from many different brands with <b>one single login</b>.</div>\n </div>\n </div>\n <div class="\"seamless-layout__right-panel\"">\n <picture>\n <source media="\"(max-width:" 767.999px)\"="" sizes="\"1px\"" srcset="\"https://cdn.singlekey-id.com/images/none.590RTqhrx1o.gif" 1w\"="">\n\n <source media="\"(min-width:" 768px)\"="" type="\"image/avif\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.DzqOrR_opYg.avif" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.7mgln4u6d_s.avif="" 1024w,="" background_1366x986.zu1usdfcir4.avif="" 1366w,="" background_1600x1155.5wo0czejume.avif="" 1600w,="" background_1920x1386.mhctivdddms.avif="" 1920w\"="">\n <source media="\"(min-width:" 768px)\"="" type="\"image/webp\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.4m-_t_WNuD4.webp" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.aqnzlbdi_no.webp="" 1024w,="" background_1366x986.ulgityj-5a0.webp="" 1366w,="" background_1600x1155.gviq-nk338y.webp="" 1600w,="" background_1920x1386.efuynlavpgu.webp="" 1920w\"="">\n <source media="\"(min-width:" 768px)\"="" type="\"image/jpeg\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.AAH3SmmHwGE.jpg" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.xzvtpkydfve.jpg="" 1024w,="" background_1366x986.jfxrhjeqyw8.jpg="" 1366w,="" background_1600x1155.udo9ihuhy48.jpg="" 1600w,="" background_1920x1386.g6onbgekap8.jpg="" 1920w\"="">\n <img class="\"seamless-layout__hero-image\"" alt="\"\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/background_1920x1386.g6ONbGEKAp8.jpg\"" data-testid="\"seamless-background\"">\n </picture>\n </div>\n</main>\n\n\n\n<footer class="\"footer\"">\n <nav class="\"footer__content" footer__content--justified\"="">\n <ul class="\"footer__links\"">\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/corporate-info-and-legal-notice\"" data-hx-boost="\"false\"">\n Corporate Information\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/data-protection-notice\"" data-hx-boost="\"false\"">\n Data Protection Policy\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/corporate-info-and-legal-notice\"" data-hx-boost="\"false\"">\n Legal Notice\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/terms-of-use\"" data-hx-boost="\"false\"">\n Terms of Use\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"https://cdn.singlekey-id.com/disclosure-document.BMdLREMiXRU.pdf\"" data-hx-boost="\"false\"">\n Open Source Disclosure\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/frequently-asked-questions\"" data-hx-boost="\"false\"">\n FAQs\n </a>\n </li>\n </ul>\n \n\n<form class="\"language-switch" footer__link\"="" method="\"post\"" action="\"/en-gb/language\"">\n <i class="\"icon" icon--globe="" icon--size-xl\"=""></i>\n <select name="\"culture\"" class="\"language-switch__select\"" data-testid="\"language-switch\""><option value="\"az-AZ\"">azərbaycan (Azərbaycan)</option>\n<option value="\"bs-BA\"">bosanski (Bosna i Hercegovina)</option>\n<option value="\"cs-CZ\"">čeština (Česko)</option>\n<option value="\"da-DK\"">dansk (Danmark)</option>\n<option value="\"de-BE\"">Deutsch (Belgien)</option>\n<option value="\"de-DE\"">Deutsch (Deutschland)</option>\n<option value="\"de-LI\"">Deutsch (Liechtenstein)</option>\n<option value="\"de-LU\"">Deutsch (Luxemburg)</option>\n<option value="\"de-AT\"">Deutsch (Österreich)</option>\n<option value="\"de-CH\"">Deutsch (Schweiz)</option>\n<option value="\"et-EE\"">eesti (Eesti)</option>\n<option value="\"en-AU\"">English (Australia)</option>\n<option value="\"en-BD\"">English (Bangladesh)</option>\n<option value="\"en-CA\"">English (Canada)</option>\n<option value="\"en-GH\"">English (Ghana)</option>\n<option value="\"en-IN\"">English (India)</option>\n<option value="\"en-IE\"">English (Ireland)</option>\n<option value="\"en-KE\"">English (Kenya)</option>\n<option value="\"en-MY\"">English (Malaysia)</option>\n<option value="\"en-MT\"">English (Malta)</option>\n<option value="\"en-NP\"">English (Nepal)</option>\n<option value="\"en-NZ\"">English (New Zealand)</option>\n<option value="\"en-NG\"">English (Nigeria)</option>\n<option value="\"en-PH\"">English (Philippines)</option>\n<option value="\"en-SG\"">English (Singapore)</option>\n<option value="\"en-ZA\"">English (South Africa)</option>\n<option value="\"en-LK\"">English (Sri Lanka)</option>\n<option selected="\"selected\"" value="\"en-GB\"">English (United Kingdom)</option>\n<option value="\"en-US\"">English (United States)</option>\n<option value="\"es-AR\"">español (Argentina)</option>\n<option value="\"es-BO\"">español (Bolivia)</option>\n<option value="\"es-CL\"">español (Chile)</option>\n<option value="\"es-CO\"">español (Colombia)</option>\n<option value="\"es-CR\"">español (Costa Rica)</option>\n<option value="\"es-EC\"">español (Ecuador)</option>\n<option value="\"es-SV\"">español (El Salvador)</option>\n<option value="\"es-ES\"">español (España)</option>\n<option value="\"es-GT\"">español (Guatemala)</option>\n<option value="\"es-HN\"">español (Honduras)</option>\n<option value="\"es-MX\"">español (México)</option>\n<option value="\"es-NI\"">español (Nicaragua)</option>\n<option value="\"es-PA\"">español (Panamá)</option>\n<option value="\"es-PY\"">español (Paraguay)</option>\n<option value="\"es-PE\"">español (Perú)</option>\n<option value="\"es-DO\"">español (República Dominicana)</option>\n<option value="\"es-UY\"">español (Uruguay)</option>\n<option value="\"es-VE\"">español (Venezuela)</option>\n<option value="\"fr-BE\"">français (Belgique)</option>\n<option value="\"fr-CA\"">français (Canada)</option>\n<option value="\"fr-FR\"">français (France)</option>\n<option value="\"fr-LU\"">français (Luxembourg)</option>\n<option value="\"fr-CH\"">français (Suisse)</option>\n<option value="\"fr-TN\"">français (Tunisie)</option>\n<option value="\"hr-HR\"">hrvatski (Hrvatska)</option>\n<option value="\"id-ID\"">Indonesia (Indonesia)</option>\n<option value="\"is-IS\"">íslenska (Ísland)</option>\n<option value="\"it-IT\"">italiano (Italia)</option>\n<option value="\"it-CH\"">italiano (Svizzera)</option>\n<option value="\"lv-LV\"">latviešu (Latvija)</option>\n<option value="\"lt-LT\"">lietuvių (Lietuva)</option>\n<option value="\"hu-HU\"">magyar (Magyarország)</option>\n<option value="\"cnr-ME\"">Montenegrin (Montenegro)</option>\n<option value="\"nl-BE\"">Nederlands (België)</option>\n<option value="\"nl-NL\"">Nederlands (Nederland)</option>\n<option value="\"no-NO\"">norsk (Norge)</option>\n<option value="\"pl-PL\"">polski (Polska)</option>\n<option value="\"pt-AO\"">português (Angola)</option>\n<option value="\"pt-BR\"">português (Brasil)</option>\n<option value="\"pt-PT\"">português (Portugal)</option>\n<option value="\"ro-MD\"">română (Republica Moldova)</option>\n<option value="\"ro-RO\"">română (România)</option>\n<option value="\"sq-XK\"">shqip (Kosovë)</option>\n<option value="\"sq-AL\"">shqip (Shqipëri)</option>\n<option value="\"sk-SK\"">slovenčina (Slovensko)</option>\n<option value="\"sl-SI\"">slovenščina (Slovenija)</option>\n<option value="\"fi-FI\"">suomi (Suomi)</option>\n<option value="\"sv-SE\"">svenska (Sverige)</option>\n<option value="\"vi-VN\"">Tiếng Việt (Việt Nam)</option>\n<option value="\"tr-TR\"">Türkçe (Türkiye)</option>\n<option value="\"el-GR\"">Ελληνικά (Ελλάδα)</option>\n<option value="\"el-CY\"">Ελληνικά (Κύπρος)</option>\n<option value="\"bg-BG\"">български (България)</option>\n<option value="\"kk-KZ\"">қазақ тілі (Қазақстан)</option>\n<option value="\"mk-MK\"">македонски (Северна Македонија)</option>\n<option value="\"sr-RS\"">српски (Србија)</option>\n<option value="\"uk-UA\"">українська (Україна)</option>\n<option value="\"ka-GE\"">ქართული (საქართველო)</option>\n<option value="\"he-IL\"">עברית (ישראל)</option>\n<option value="\"ar-AE\"">العربية (الإمارات العربية المتحدة)</option>\n<option value="\"ar-BH\"">العربية (البحرين)</option>\n<option value="\"ar-KW\"">العربية (الكويت)</option>\n<option value="\"ar-MA\"">العربية (المغرب)</option>\n<option value="\"ar-SA\"">العربية (المملكة العربية السعودية)</option>\n<option value="\"ar-TN\"">العربية (تونس)</option>\n<option value="\"ar-OM\"">العربية (عُمان)</option>\n<option value="\"ar-QA\"">العربية (قطر)</option>\n<option value="\"ar-LB\"">العربية (لبنان)</option>\n<option value="\"ar-EG\"">العربية (مصر)</option>\n<option value="\"th-TH\"">ไทย (ไทย)</option>\n<option value="\"ko-KR\"">한국어(대한민국)</option>\n<option value="\"zh-HK\"">中文(中國香港特別行政區)</option>\n<option value="\"zh-TW\"">中文(台灣)</option>\n<option value="\"ja-JP\"">日本語 (日本)</option>\n</select>\n <input data-hx-swap-oob="\"true\"" id="\"language-switch\"" name="\"returnPath\"" type="\"hidden\"" value="\"/en-gb/login?ReturnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U\"">\n\n <button class="\"language-switch__submit" button="" button--submit\"="" type="\"submit\"">\n Save\n </button>\n<input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QDFDwsyguCI1OC2qSE4eGok8_Ub_Sb1sUkzhNvfOMH1PoGYxvsWgO9NDDyDGR_itfjTwG1yA09fs1iL4xN0snXsQaj2M6Zorz1-0qVbpFTii3_VOSv7wi1OYNtRTsFI1J0\""></form>\n </nav>\n</footer>\n\n <script type="\"module\"" src="\"https://cdn.singlekey-id.com/scripts/htmx.00GdzawUlLg.mjs\""></script>\n\n <script type="\"module\"" src="\"https://cdn.singlekey-id.com/scripts/base.veDyGCvmY8w.mjs\""></script>\n <script defer="" nomodule="" src="\"https://cdn.singlekey-id.com/scripts/base.B5E8ztDgVe0.js\""></script>\n\n <script nonce="\"xi6ip3ZL9NWZ-x3udR9k7D8N\"">(function() {\n if (window.hcaptcha === undefined) {\n var hcaptchaScript = document.createElement('script');\n hcaptchaScript.src = 'https://js.hcaptcha.com/1/api.js?recaptchacompat=off&onload=onHCaptchaLoaded&render=explicit';\n hcaptchaScript.defer = true;\n hcaptchaScript.async = true;\n document.head.appendChild(hcaptchaScript);\n }\n})();</script>\n\n \n \n\n \n\n"
    2025-01-05 11:04:39.644 - error: bosch-ebike.0 (630591) No code received.
    2025-01-05 11:04:39.864 - error: bosch-ebike.0 (630591) AxiosError: Request failed with status code 400
    2025-01-05 11:04:39.865 - error: bosch-ebike.0 (630591) {"error":"invalid_request","error_description":"Missing parameter: code"}
    • R reini84
      @tombox
      tombox
      #106
      @reini84 Irgendwas ist mit dem Passwort komisch
      R 1 Antwort Letzte Antwort
      • T tombox
        @bahnuhr @bommel_030
        bitte die GitHub Version testen
        bommel_030
        #107
        @tombox
        Danke, Instanz löschen, neu anlegen und läuft wieder.
        • T tombox
          reini84
          #108
          @tombox
          Vielen Dank, das Passwort war das Problem
          • R reini84
            @tombox
            tombox
            #109
            @reini84 Falsch oder Sonderzeichen
            • W Offline
              W Offline
              wolfgangf
              #110
              Ich komme leider nicht über die hCaptcha Stelle hinweg:
              Hat da jemand eine Idee oder einen Tipp?
              Ivan AndricI 1 Antwort Letzte Antwort
              • W wolfgangf
                Ivan AndricI Offline
                Ivan Andric
                #111
                @wolfgangf Einen Tipp habe ich leider nicht, jedoch das gleiche Problem.
                • Ivan AndricI Ivan Andric
                  tombox
                  #112
                  @ivan-andric Bitte die GitHub version test. Login flow wurde geändert
                  L 1 Antwort Letzte Antwort
                  • T tombox
                    lindi200000
                    #113
                    @tombox Moin, hab das gleiche Problem und die Github Version getestet.
                    Ich komme nicht in die EInstellungen des Adapters rein, es kommt immer [JsonConfig] Cannot read file "jsonConfig.json: Not exists
                    Reload, anderer Browser etc .... alles schon gemacht, keine Besserung. Andere Adapter Einstellungen gehen, nur nicht der hier.
                    • L lindi200000
                      tombox
                      #114
                      @lindi200000 probier die aktuelle GitHub version
                      • T tombox
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #115
                        @tombox
                        Habe die git installiert.
                        Komme aber mit der Anleitung nicht klar.
                        Im Einzelnen:
                        Dort steht:
                        zu 1.
                        Habe unten auf den Link geklickt.
                        Dann kam ich zur Seite:
                        Dann mich dort angemeldet und war drin.
                        zu 2.
                        F12 gedrückt.
                        zu 3.
                        Ich sehe dort keine Fehlermeldung.
                        Fazit:
                        Fehlermeldung hab ich nicht.
                        Was mach ich denn nun falsch ?
                        Bitte kurze Rückinfo.
                        Danke.
                        Danke.
                        T L 2 Antworten Letzte Antwort
                        • bahnuhrB bahnuhr
                          @tombox
                          Im Einzelnen:
                          Dort steht:
                          zu 1.
                          zu 2.
                          F12 gedrückt.
                          zu 3.
                          Fazit:
                          Danke.
                          tombox
                          #116
                          @bahnuhr was siehst du nach dem login
                          • T tombox
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #117
                            @tombox
                            Beim Login auf singlekey sehe ich oben rechts meine Email.
                            Folglich korrekt angemeldet.
                            Oder meinst du was anderes?
                            Danke.
                            • bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              #118
                              Nachtrag:
                              im iob log kommt:
                              bosch-ebike.0
                              2025-01-14 07:23:54.272	error	Please set code url in the instance settings
                              Aber das ist ja genau der Punkt.
                              Ich weiß ja nicht wo ich den her bekommen soll.
                              Denn wie oben erwähnt.
                              Punkt 3 und 4 klappt ja nicht.
                              Danke.
                              • bahnuhrB bahnuhr
                                @tombox
                                Im Einzelnen:
                                Dort steht:
                                zu 1.
                                zu 2.
                                F12 gedrückt.
                                zu 3.
                                Fazit:
                                Danke.
                                lindi200000
                                #119
                                @bahnuhr Wenn du F12 drückst, musst du auf Console gehen, es kann sein das man in einem anderen Tab unterwegs ist.
                                Bei Chrome sieht das so aus:
                                Hier hat es ohne Probleme funktioniert.
                                • L lindi200000
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #120
                                  @lindi200000 sagte in Test Adapter Bosch ebik connect / flow:
                                  EI, ja das hab ich ja gemacht.
                                  Benutze auch Chrome.
                                  Wie oben geschrieben.
                                  Ich logge mich bei single key ein, dann F12
                                  Aber ein Fehler wird mir nicht angezeigt.
                                  Schreib doch mal genau deine Vorgehensweise.
                                  Danke.
                                  Danke.
                                  • bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    #121
                                    @tombox
                                    @lindi200000
                                    Bin ein Stück weiter. Jetzt sehe ich die Fehlermeldung:
                                    onebikeapp-ios://com.bosch.ebike.onebikeapp/oauth.....................
                                    Diese kopiert in die Instanz. Im log kommt dann:
                                    bosch-ebike.0
                                    2025-01-14 09:12:34.843	error	{"error":"invalid_grant","error_description":"Code not valid"}
                                    bosch-ebike.0
                                    2025-01-14 09:12:34.843	error	AxiosError: Request failed with status code 400
                                    Tut mir leid, ich bekomme dies nicht hin.
                                    Irgendwas stimmt doch da nicht.
                                    Bitte kurze Rückinfo. Vielleicht was ja jemand was da falsch läuft.
                                    Danke.
                                    • bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      #122
                                      So, Nachtrag.
                                      Habe nun die komplette Instanz und Adapter gelöscht.
                                      Danach neu von git.
                                      Daten eingegeben.
                                      Und ............
                                      es wurde grün.
                                      Also erledigt von meiner Seite.
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        So, Nachtrag.
                                        Danach neu von git.
                                        Daten eingegeben.
                                        Und ............
                                        es wurde grün.
                                        McLane
                                        schrieb am zuletzt editiert von McLane
                                        #123
                                        Hallo, ich habe mich korrekt im Adapter angemeldet, "Verbunden mit Gerät oder Dienst" bleibt jedoch rot.
                                        Leider ist die Anmeldeprozedur nur rudimentär beschrieben, finde ich.
                                        Muss ich zwingend den SingleKey Login wählen? Habe das wie beschrieben im Firefox Browser versucht.
                                        Die Seite zeigt nach der Einwahl "Sie sind bereits angemeldet". In der Konsole werden auch Fehler gemeldet.
                                        Etwas wie "onebikeapp-ios...." finde ich jedoch nicht. Die Links beginnen mit:
                                        https://p9.authz.bosch.com/auth/realms/.......
                                        Was mache ich falsch?
                                        Jo
                                        • O Offline
                                          O Offline
                                          oxivanisher
                                          #124
                                          Bei mir klappt das auch nicht. Ich sehe ebenfalls keine onebikeapp-ios url:
                                          Samson71S T 2 Antworten Letzte Antwort
