  4. Test Adapter Bosch ebik connect / flow
208 Beiträge 41 Kommentatoren 59.2k Aufrufe 46 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    #96
    ebike flow
    Funktioniert der Adapter bei euch noch ?
    Danke.
    • bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      #97
      Auch mit der 0.1.9 bekomme ich noch error:
      host.iobroker
      2024-12-30 10:22:28.476	error	instance system.adapter.bosch-ebike.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker
      2024-12-30 10:22:28.476	error	Caught by controller[1]: at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
      host.iobroker
      2024-12-30 10:22:28.476	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      host.iobroker
      2024-12-30 10:22:28.476	error	Caught by controller[1]: at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:204:65)
      host.iobroker
      2024-12-30 10:22:28.476	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'split')
      host.iobroker
      2024-12-30 10:22:28.475	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      bosch-ebike.0
      2024-12-30 10:22:27.893	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      bosch-ebike.0
      2024-12-30 10:22:27.892	info	terminating
      bosch-ebike.0
      2024-12-30 10:22:27.883	error	Cannot read properties of undefined (reading 'split')
      bosch-ebike.0
      2024-12-30 10:22:27.883	error	TypeError: Cannot read properties of undefined (reading 'split') at BoschEbike.loginFlow (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:204:65) at processTicksAndRejections (node:internal/process/task_queues:95:5) at BoschEbike.onReady (/opt/iobroker/node_modules/iobroker.bosch-ebike/main.js:79:7)
      bosch-ebike.0
      2024-12-30 10:22:27.881	error	unhandled promise rejection: Cannot read properties of undefined (reading 'split')
      bosch-ebike.0
      2024-12-30 10:22:27.880	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      bosch-ebike.0
      2024-12-30 10:22:27.150	info	Login to eBike flow
      Danke.
      B T 2 Antworten Letzte Antwort
      • bahnuhrB bahnuhr
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        bosch-ebike.0
        bosch-ebike.0
        bosch-ebike.0
        bosch-ebike.0
        bosch-ebike.0
        bosch-ebike.0
        bosch-ebike.0
        bommel_030
        #98
        @bahnuhr
        Bei mir lief er einwandfrei. Nach deinem Post hab ich neu gestartet, seitdem den gleichen Fehler :-(
        • bahnuhrB bahnuhr
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          bosch-ebike.0
          bosch-ebike.0
          bosch-ebike.0
          bosch-ebike.0
          bosch-ebike.0
          bosch-ebike.0
          bosch-ebike.0
          tombox
          #99
          @bahnuhr @bommel_030
          bitte die GitHub Version testen
          bahnuhrB B 2 Antworten Letzte Antwort
          • T tombox
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            #100
            @tombox
            Habe von github installiert.
            Im log kommt dann:
            bosch-ebike.0
            2025-01-03 14:46:01.590	error	Please set captcha in the instance settings
            Dann probiert die Instanz zu öffnen.
            Unten erscheint dann:
            file "jsonConfig.json: Not exist
            Bitte nochmal schauen. Danke.
            Danke.
            • bahnuhrB bahnuhr
              @tombox
              Im log kommt dann:
              bosch-ebike.0
              tombox
              #101
              @bahnuhr ich musste was umstellen
              entweder man löscht die Instanz und erzeugt sie neu
              oder man löscht in
              "adminUI": {
                "config": "json"
              • T tombox
                oder man löscht in
                "adminUI": {
                  "config": "json"
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #102
                @tombox sagte in Test Adapter Bosch ebik connect / flow:
                oder man löscht in
                Super, Danke.
                Das löschen hat geklappt und die Instanz öffnet sich wieder.
                Danke.
                • R Offline
                  reini84
                  #103
                  läuft die 0.1.11 bei euch?
                  Captcha erstellt aber dennoch Fehler im Log
                  • R reini84
                    tombox
                    #104
                    @reini84 Im Debug log gucken ob mehr angezeigt wird
                    R 1 Antwort Letzte Antwort
                    • T tombox
                      reini84
                      #105
                      @tombox
                      2025-01-05 11:04:07.694 - info: admin.0 (622645) <== Disconnect system.user.admin from ::ffff:192.168.178.105 admin
                      2025-01-05 11:04:08.082 - info: admin.0 (622645) ==> Connected system.user.admin from ::ffff:192.168.178.105
                      2025-01-05 11:04:18.799 - info: host.iobroker stopInstance system.adapter.bosch-ebike.0 (force=false, process=true)
                      2025-01-05 11:04:18.801 - info: bosch-ebike.0 (630546) Got terminate signal TERMINATE_YOURSELF
                      2025-01-05 11:04:18.802 - info: bosch-ebike.0 (630546) terminating
                      2025-01-05 11:04:18.802 - debug: bosch-ebike.0 (630546) Plugin sentry destroyed
                      2025-01-05 11:04:18.802 - info: bosch-ebike.0 (630546) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2025-01-05 11:04:18.840 - info: host.iobroker stopInstance system.adapter.bosch-ebike.0 send kill signal
                      2025-01-05 11:04:19.303 - info: bosch-ebike.0 (630546) terminating
                      2025-01-05 11:04:19.348 - info: host.iobroker instance system.adapter.bosch-ebike.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2025-01-05 11:04:22.643 - info: host.iobroker instance system.adapter.bosch-ebike.0 in version "0.1.11" (non-npm: TA2k/ioBroker.bosch-ebike#9d120a0b148beb20559824ec0febdd65da975e2d) started with pid 630576
                      2025-01-05 11:04:23.116 - debug: bosch-ebike.0 (630576) Redis Objects: Use Redis connection: 0.0.0.0:9001
                      2025-01-05 11:04:23.134 - debug: bosch-ebike.0 (630576) Objects client ready ... initialize now
                      2025-01-05 11:04:23.176 - debug: bosch-ebike.0 (630576) Objects create System PubSub Client
                      2025-01-05 11:04:23.177 - debug: bosch-ebike.0 (630576) Objects create User PubSub Client
                      2025-01-05 11:04:23.202 - debug: bosch-ebike.0 (630576) Objects client initialize lua scripts
                      2025-01-05 11:04:23.205 - debug: bosch-ebike.0 (630576) Objects connected to redis: 0.0.0.0:9001
                      2025-01-05 11:04:23.223 - debug: bosch-ebike.0 (630576) Redis States: Use Redis connection: 0.0.0.0:9000
                      2025-01-05 11:04:23.231 - debug: bosch-ebike.0 (630576) States create System PubSub Client
                      2025-01-05 11:04:23.231 - debug: bosch-ebike.0 (630576) States create User PubSub Client
                      2025-01-05 11:04:23.286 - debug: bosch-ebike.0 (630576) States connected to redis: 0.0.0.0:9000
                      2025-01-05 11:04:23.303 - debug: bosch-ebike.0 (630576) Plugin sentry Initialize Plugin (enabled=true)
                      2025-01-05 11:04:23.439 - info: bosch-ebike.0 (630576) starting. Version 0.1.11 (non-npm: TA2k/ioBroker.bosch-ebike#9d120a0b148beb20559824ec0febdd65da975e2d) in /opt/iobroker/node_modules/iobroker.bosch-ebike, node: v20.18.1, js-controller: 7.0.6
                      2025-01-05 11:04:23.455 - info: bosch-ebike.0 (630576) Login to eBike flow
                      2025-01-05 11:04:23.456 - error: bosch-ebike.0 (630576) Please set captcha in the instance settings
                      2025-01-05 11:04:29.847 - info: admin.0 (622645) ==> Connected system.user.admin from ::ffff:192.168.178.105
                      2025-01-05 11:04:30.049 - info: sonoff.0 (613233) Client [Heizung] reconnected. Old secret 1735914402782_2115 ==> New secret 1736071470048_7239
                      2025-01-05 11:04:33.129 - info: host.iobroker stopInstance system.adapter.bosch-ebike.0 (force=false, process=true)
                      2025-01-05 11:04:33.131 - info: bosch-ebike.0 (630576) Got terminate signal TERMINATE_YOURSELF
                      2025-01-05 11:04:33.132 - info: bosch-ebike.0 (630576) terminating
                      2025-01-05 11:04:33.132 - debug: bosch-ebike.0 (630576) Plugin sentry destroyed
                      2025-01-05 11:04:33.133 - info: bosch-ebike.0 (630576) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2025-01-05 11:04:33.171 - info: host.iobroker stopInstance system.adapter.bosch-ebike.0 send kill signal
                      2025-01-05 11:04:33.633 - info: bosch-ebike.0 (630576) terminating
                      2025-01-05 11:04:33.676 - info: host.iobroker instance system.adapter.bosch-ebike.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2025-01-05 11:04:36.589 - info: admin.0 (622645) <== Disconnect system.user.admin from ::ffff:192.168.178.105
                      2025-01-05 11:04:36.972 - info: host.iobroker instance system.adapter.bosch-ebike.0 in version "0.1.11" (non-npm: TA2k/ioBroker.bosch-ebike#9d120a0b148beb20559824ec0febdd65da975e2d) started with pid 630591
                      2025-01-05 11:04:37.452 - debug: bosch-ebike.0 (630591) Redis Objects: Use Redis connection: 0.0.0.0:9001
                      2025-01-05 11:04:37.469 - debug: bosch-ebike.0 (630591) Objects client ready ... initialize now
                      2025-01-05 11:04:37.470 - debug: bosch-ebike.0 (630591) Objects create System PubSub Client
                      2025-01-05 11:04:37.471 - debug: bosch-ebike.0 (630591) Objects create User PubSub Client
                      2025-01-05 11:04:37.497 - debug: bosch-ebike.0 (630591) Objects client initialize lua scripts
                      2025-01-05 11:04:37.500 - debug: bosch-ebike.0 (630591) Objects connected to redis: 0.0.0.0:9001
                      2025-01-05 11:04:37.519 - debug: bosch-ebike.0 (630591) Redis States: Use Redis connection: 0.0.0.0:9000
                      2025-01-05 11:04:37.527 - debug: bosch-ebike.0 (630591) States create System PubSub Client
                      2025-01-05 11:04:37.528 - debug: bosch-ebike.0 (630591) States create User PubSub Client
                      2025-01-05 11:04:37.583 - debug: bosch-ebike.0 (630591) States connected to redis: 0.0.0.0:9000
                      2025-01-05 11:04:37.602 - debug: bosch-ebike.0 (630591) Plugin sentry Initialize Plugin (enabled=true)
                      2025-01-05 11:04:37.728 - info: bosch-ebike.0 (630591) starting. Version 0.1.11 (non-npm: TA2k/ioBroker.bosch-ebike#9d120a0b148beb20559824ec0febdd65da975e2d) in /opt/iobroker/node_modules/iobroker.bosch-ebike, node: v20.18.1, js-controller: 7.0.6
                      2025-01-05 11:04:37.744 - info: bosch-ebike.0 (630591) Login to eBike flow
                      2025-01-05 11:04:38.583 - <span class="type">debug</span>: bosch-ebike.0 (630591) "\n\n\n\n \n <title>Willkommen - SingleKey ID</title>\n <meta name="\"description\"" content="\"Willkommen\"">\n\n <base href="\"https://singlekey-id.com\"">\n <link rel="\"icon\"" type="\"image/svg+xml\"" href="\"https://cdn.singlekey-id.com/images/favicons/vector.fLinwNmN0b4.svg\"" sizes="\"any\"">\n <link rel="\"icon\"" type="\"image/png\"" href="\"https://cdn.singlekey-id.com/images/favicons/16x16.Ie2d4OLHBZc.png\"" sizes="\"16x16\"">\n\n <meta name="\"viewport\"" content="\"width=device-width," initial-scale="1\"">\n\n <meta name="\"htmx-config\"" content="{\"inlineScriptNonce\":\"BGPomBS76d7pEfO8KFP12B-e\", \"includeIndicatorStyles\":false, \"refreshOnHistoryMiss\": true, \"timeout\": 20000}">\n\n \n <link rel="\"stylesheet\"" href="\"https://cdn.singlekey-id.com/styles/default.8ULbJ7zIe70.css\"">\n\n \n\n\n <script nonce="\"BGPomBS76d7pEfO8KFP12B-e\"">\n document.querySelector(\"html\").className = \"js\";\n </script>\n \n\n \n <div class="\"captcha-dialog\"">\n <div class="\"captcha-dialog__content\""></div>\n </div>\n\n \n\n\n\n<header class="\"seamless-layout__header\"">\n <h1>\n <a class="\"seamless-layout__header-link\"" data-hx-boost="\"false\"" href="\"/de-de/home\"">\n <picture>\n <source media="\"(max-width:" 767.999px)\"="" srcset="\"https://cdn.singlekey-id.com/images/logo-on-dark.t-FKZg_FN7I.svg\"">\n <img class="\"seamless-layout__skid-logo\"" src="\"https://cdn.singlekey-id.com/images/logo-on-light.qEQuOq98Y4I.svg\"" alt="\"SingleKey" id\"="">\n </picture>\n </a>\n </h1>\n\n <img class="\"seamless-layout__partner-logo\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/brand-logo.4p7gk_UxIDA.svg\"" alt="\"Bosch\"" data-testid="\"seamless-partner-logo\"">\n</header>\n\n<main class="\"seamless-layout__main\"" data-hx-swap="\"show:none" focus-scroll:true\"="">\n <div class="\"seamless-layout__left-panel\"">\n <div class="\"seamless-layout__content\"">\n \n<div id="\"inline-messages\"" class="\"" messages\"="">\n <noscript>\n <div class=\"message message--error message--permanent\" data-testid=\"javascript-required-error\">\n <i class=\"message__icon icon icon--size-l icon--error\"></i>\n <span>Bitte aktivieren Sie JavaScript, um fortzufahren.</span>\n </div>\n </noscript>\n</div>\n\n <div id="\"body\"">\n \n\n\n<div class="\"seamless-content\"" data-hx-boost="\"true\"" data-testid="\"enter-username\"">\n <h2 class="\"seamless-content__header\"">\n Registrieren oder einloggen\n \n<div class="\"popup" \"="">\n <a class="\"popup__open-popup\"" role="\"button\"" aria-label="\"Open" popup\"="" aria-expanded="\"false\"" aria-controls="\"signup-or-login-hint\"" hx-boost="\"false\"" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx#signup-or-login-hint\"">\n <i class="\"icon" icon--info="" popup__open-popup-icon="" icon--size-s\"=""></i>\n </a>\n <div id="\"signup-or-login-hint\"" class="\"popup__content\"">\n <h2 class="\"popup__header\"">\n Registrieren oder einloggen\n <a class="\"popup__close-popup\"" role="\"button\"" aria-label="\"Close" popup\"="" hx-boost="\"false\"" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx#\"">\n <i class="\"icon" icon--close="" icon--invert="" icon--size-s\"=""></i>\n </a>\n </h2>\n <p class="\"popup__text\"">Bitte geben Sie Ihre E-Mail-Adresse oder Handynummer ein, damit wir prüfen können, ob Sie bereits eine SingleKey ID haben. Wir leiten Sie dann entweder zur Anmeldung oder zur Registrierung weiter.</p>\n </div>\n</div>\n </h2>\n\n <form class="\"form\"" method="\"post\"">\n \n\n<div>\n\n\n\n\n<div class="\"input\"">\n <input class="\"input__element\"" type="\"text\"" inputmode="\"email\"" placeholder="\" \"" autocomplete="\"email\"" autofocus="\"autofocus\"" id="\"UserIdentifierInput_EmailInput_StringValue\"" name="\"UserIdentifierInput.EmailInput.StringValue\"" value="\"\"">\n <label class="\"input__placeholder\"" for="\"UserIdentifierInput_EmailInput_StringValue\"">E-Mail</label>\n \n</div> <a data-testid="\"user-identifier-switch-to-phone-link\"" class="\"link" user-identifier__switch-link\"="" href="\"/de-de/login?input=phone&returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n <i class="\"user-identifier__icon" icon="" icon--smartphone-blue="" icon--size-s\"=""></i>\n <span>Handynummer verwenden</span>\n </a>\n</div>\n\n \n<div class="\"form__actions\"">\n\n <button class="\"button" button--submit="" button--protected\"="" data-loading-class="\"button--loading\"" data-testid="\"enter-username.submit\"" data-sitekey="\"f8fe2d56-ad42-4f44-b9fe-5b30fcb0dd38\"" data-hl="\"de\"" disabled="\"\"">\n Weiter\n <span class="\"button__spinner\"">\n <i class="\"icon" icon--spinner="" icon--size-l\"=""></i>\n </span>\n </button>\n</div>\n <input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QDUtwJh6c3XWMrt76-0kJH1OHg_Pq9_HtGlJxUojIXIcAaAm4GUzUZhnb8_WQePNhamcWkEB8hWgGAsVBD4J4UL9QTWI3xbsRIcIPmFGG2eeri6g99HyBg_3BXed-6zu7M\""></form>\n</div>\n </div>\n </div>\n <div class="\"about\"" id="\"about\"" data-hx-boost="\"false\"">\n <div class="\"about__header\"">\n <text class="\"about__title\"">Ein Login für viele Marken</text>\n <a class="\"about__show-info\"" role="\"button\"" aria-expanded="\"false\"" aria-controls="\"info\"" aria-label="\"Show" singlekey="" id="" info\"="" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx#about\"">\n <i class="\"icon" icon--arrow-down="" icon--size-m="" icon--invert="" icon--rotate180\"=""></i>\n </a>\n <a class="\"about__hide-info\"" role="\"button\"" aria-expanded="\"false\"" aria-controls="\"info\"" aria-label="\"Hide" singlekey="" id="" info\"="" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx#\"">\n <i class="\"icon" icon--arrow-down="" icon--size-m="" icon--invert\"=""></i>\n </a>\n </div>\n \n<div class="\"brands" about__brands\"="">\n <button class="\"brands__nav" brands__btn-left="" brands__btn-left--hidden="" button="" button--icon\"="" role="\"button\"" aria-hidden="\"true\"">\n <i class="\"icon" icon--arrow-left="" icon--size-m\"=""></i>\n </button>\n <div class="\"brands__carousel\"">\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Bosch\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_01.4p7gk_UxIDA.svg\"" width="\"130\"" height="\"28,822172\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Siemens" home="" appliances\"="" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_02.VXu-FBivXhE.svg\"" width="\"130\"" height="\"52,769993\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Buderus\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_03.OiMrTqOdPwk.svg\"" width="\"130\"" height="\"47,068966\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Home" connect\"="" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_04.yP-gzACpJjE.svg\"" width="\"130\"" height="\"21,77665\"" draggable="\"false\"">\n </div>\n </div>\n <button class="\"brands__nav" brands__btn-right="" button="" button--icon\"="" role="\"button\"">\n <i class="\"icon" icon--arrow-right="" icon--size-m\"=""></i>\n </button>\n</div>\n <div class="\"about__info\""><a href="\"/our-promise/\"">SingleKey ID</a> bietet bequemen Zugang zu Websites, Shops, Apps und Services vieler Marken mit <b>einem einzigen Login</b>.</div>\n </div>\n </div>\n <div class="\"seamless-layout__right-panel\"">\n <picture>\n <source media="\"(max-width:" 767.999px)\"="" sizes="\"1px\"" srcset="\"https://cdn.singlekey-id.com/images/none.590RTqhrx1o.gif" 1w\"="">\n\n <source media="\"(min-width:" 768px)\"="" type="\"image/avif\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.DzqOrR_opYg.avif" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.7mgln4u6d_s.avif="" 1024w,="" background_1366x986.zu1usdfcir4.avif="" 1366w,="" background_1600x1155.5wo0czejume.avif="" 1600w,="" background_1920x1386.mhctivdddms.avif="" 1920w\"="">\n <source media="\"(min-width:" 768px)\"="" type="\"image/webp\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.4m-_t_WNuD4.webp" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.aqnzlbdi_no.webp="" 1024w,="" background_1366x986.ulgityj-5a0.webp="" 1366w,="" background_1600x1155.gviq-nk338y.webp="" 1600w,="" background_1920x1386.efuynlavpgu.webp="" 1920w\"="">\n <source media="\"(min-width:" 768px)\"="" type="\"image/jpeg\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.AAH3SmmHwGE.jpg" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.xzvtpkydfve.jpg="" 1024w,="" background_1366x986.jfxrhjeqyw8.jpg="" 1366w,="" background_1600x1155.udo9ihuhy48.jpg="" 1600w,="" background_1920x1386.g6onbgekap8.jpg="" 1920w\"="">\n <img class="\"seamless-layout__hero-image\"" alt="\"\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/background_1920x1386.g6ONbGEKAp8.jpg\"" data-testid="\"seamless-background\"">\n </picture>\n </div>\n</main>\n\n\n\n<footer class="\"footer\"">\n <nav class="\"footer__content" footer__content--justified\"="">\n <ul class="\"footer__links\"">\n <li>\n <a class="\"footer__link\"" href="\"/de-de/corporate-info-and-legal-notice\"" data-hx-boost="\"false\"">\n Impressum\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/de-de/data-protection-notice\"" data-hx-boost="\"false\"">\n Datenschutzrichtlinie\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/de-de/corporate-info-and-legal-notice\"" data-hx-boost="\"false\"">\n Rechtliche Hinweise\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/de-de/terms-of-use\"" data-hx-boost="\"false\"">\n Nutzungsbedingungen\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"https://cdn.singlekey-id.com/disclosure-document.BMdLREMiXRU.pdf\"" data-hx-boost="\"false\"">\n Open Source Informationen\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/de-de/frequently-asked-questions\"" data-hx-boost="\"false\"">\n FAQs\n </a>\n </li>\n </ul>\n \n\n<form class="\"language-switch" footer__link\"="" method="\"post\"" action="\"/de-de/language\"">\n <i class="\"icon" icon--globe="" icon--size-xl\"=""></i>\n <select name="\"culture\"" class="\"language-switch__select\"" data-testid="\"language-switch\""><option value="\"az-AZ\"">azərbaycan (Azərbaycan)</option>\n<option value="\"bs-BA\"">bosanski (Bosna i Hercegovina)</option>\n<option value="\"cs-CZ\"">čeština (Česko)</option>\n<option value="\"da-DK\"">dansk (Danmark)</option>\n<option value="\"de-BE\"">Deutsch (Belgien)</option>\n<option selected="\"selected\"" value="\"de-DE\"">Deutsch (Deutschland)</option>\n<option value="\"de-LI\"">Deutsch (Liechtenstein)</option>\n<option value="\"de-LU\"">Deutsch (Luxemburg)</option>\n<option value="\"de-AT\"">Deutsch (Österreich)</option>\n<option value="\"de-CH\"">Deutsch (Schweiz)</option>\n<option value="\"et-EE\"">eesti (Eesti)</option>\n<option value="\"en-AU\"">English (Australia)</option>\n<option value="\"en-BD\"">English (Bangladesh)</option>\n<option value="\"en-CA\"">English (Canada)</option>\n<option value="\"en-GH\"">English (Ghana)</option>\n<option value="\"en-IN\"">English (India)</option>\n<option value="\"en-IE\"">English (Ireland)</option>\n<option value="\"en-KE\"">English (Kenya)</option>\n<option value="\"en-MY\"">English (Malaysia)</option>\n<option value="\"en-MT\"">English (Malta)</option>\n<option value="\"en-NP\"">English (Nepal)</option>\n<option value="\"en-NZ\"">English (New Zealand)</option>\n<option value="\"en-NG\"">English (Nigeria)</option>\n<option value="\"en-PH\"">English (Philippines)</option>\n<option value="\"en-SG\"">English (Singapore)</option>\n<option value="\"en-ZA\"">English (South Africa)</option>\n<option value="\"en-LK\"">English (Sri Lanka)</option>\n<option value="\"en-GB\"">English (United Kingdom)</option>\n<option value="\"en-US\"">English (United States)</option>\n<option value="\"es-AR\"">español (Argentina)</option>\n<option value="\"es-BO\"">español (Bolivia)</option>\n<option value="\"es-CL\"">español (Chile)</option>\n<option value="\"es-CO\"">español (Colombia)</option>\n<option value="\"es-CR\"">español (Costa Rica)</option>\n<option value="\"es-EC\"">español (Ecuador)</option>\n<option value="\"es-SV\"">español (El Salvador)</option>\n<option value="\"es-ES\"">español (España)</option>\n<option value="\"es-GT\"">español (Guatemala)</option>\n<option value="\"es-HN\"">español (Honduras)</option>\n<option value="\"es-MX\"">español (México)</option>\n<option value="\"es-NI\"">español (Nicaragua)</option>\n<option value="\"es-PA\"">español (Panamá)</option>\n<option value="\"es-PY\"">español (Paraguay)</option>\n<option value="\"es-PE\"">español (Perú)</option>\n<option value="\"es-DO\"">español (República Dominicana)</option>\n<option value="\"es-UY\"">español (Uruguay)</option>\n<option value="\"es-VE\"">español (Venezuela)</option>\n<option value="\"fr-BE\"">français (Belgique)</option>\n<option value="\"fr-CA\"">français (Canada)</option>\n<option value="\"fr-FR\"">français (France)</option>\n<option value="\"fr-LU\"">français (Luxembourg)</option>\n<option value="\"fr-CH\"">français (Suisse)</option>\n<option value="\"fr-TN\"">français (Tunisie)</option>\n<option value="\"hr-HR\"">hrvatski (Hrvatska)</option>\n<option value="\"id-ID\"">Indonesia (Indonesia)</option>\n<option value="\"is-IS\"">íslenska (Ísland)</option>\n<option value="\"it-IT\"">italiano (Italia)</option>\n<option value="\"it-CH\"">italiano (Svizzera)</option>\n<option value="\"lv-LV\"">latviešu (Latvija)</option>\n<option value="\"lt-LT\"">lietuvių (Lietuva)</option>\n<option value="\"hu-HU\"">magyar (Magyarország)</option>\n<option value="\"cnr-ME\"">Montenegrin (Montenegro)</option>\n<option value="\"nl-BE\"">Nederlands (België)</option>\n<option value="\"nl-NL\"">Nederlands (Nederland)</option>\n<option value="\"no-NO\"">norsk (Norge)</option>\n<option value="\"pl-PL\"">polski (Polska)</option>\n<option value="\"pt-AO\"">português (Angola)</option>\n<option value="\"pt-BR\"">português (Brasil)</option>\n<option value="\"pt-PT\"">português (Portugal)</option>\n<option value="\"ro-MD\"">română (Republica Moldova)</option>\n<option value="\"ro-RO\"">română (România)</option>\n<option value="\"sq-XK\"">shqip (Kosovë)</option>\n<option value="\"sq-AL\"">shqip (Shqipëri)</option>\n<option value="\"sk-SK\"">slovenčina (Slovensko)</option>\n<option value="\"sl-SI\"">slovenščina (Slovenija)</option>\n<option value="\"fi-FI\"">suomi (Suomi)</option>\n<option value="\"sv-SE\"">svenska (Sverige)</option>\n<option value="\"vi-VN\"">Tiếng Việt (Việt Nam)</option>\n<option value="\"tr-TR\"">Türkçe (Türkiye)</option>\n<option value="\"el-GR\"">Ελληνικά (Ελλάδα)</option>\n<option value="\"el-CY\"">Ελληνικά (Κύπρος)</option>\n<option value="\"bg-BG\"">български (България)</option>\n<option value="\"kk-KZ\"">қазақ тілі (Қазақстан)</option>\n<option value="\"mk-MK\"">македонски (Северна Македонија)</option>\n<option value="\"sr-RS\"">српски (Србија)</option>\n<option value="\"uk-UA\"">українська (Україна)</option>\n<option value="\"ka-GE\"">ქართული (საქართველო)</option>\n<option value="\"he-IL\"">עברית (ישראל)</option>\n<option value="\"ar-AE\"">العربية (الإمارات العربية المتحدة)</option>\n<option value="\"ar-BH\"">العربية (البحرين)</option>\n<option value="\"ar-KW\"">العربية (الكويت)</option>\n<option value="\"ar-MA\"">العربية (المغرب)</option>\n<option value="\"ar-SA\"">العربية (المملكة العربية السعودية)</option>\n<option value="\"ar-TN\"">العربية (تونس)</option>\n<option value="\"ar-OM\"">العربية (عُمان)</option>\n<option value="\"ar-QA\"">العربية (قطر)</option>\n<option value="\"ar-LB\"">العربية (لبنان)</option>\n<option value="\"ar-EG\"">العربية (مصر)</option>\n<option value="\"th-TH\"">ไทย (ไทย)</option>\n<option value="\"ko-KR\"">한국어(대한민국)</option>\n<option value="\"zh-HK\"">中文(中國香港特別行政區)</option>\n<option value="\"zh-TW\"">中文(台灣)</option>\n<option value="\"ja-JP\"">日本語 (日本)</option>\n</select>\n <input data-hx-swap-oob="\"true\"" id="\"language-switch\"" name="\"returnPath\"" type="\"hidden\"" value="\"/de-de/login?ReturnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n\n <button class="\"language-switch__submit" button="" button--submit\"="" type="\"submit\"">\n Speichern\n </button>\n<input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QDUtwJh6c3XWMrt76-0kJH1OHg_Pq9_HtGlJxUojIXIcAaAm4GUzUZhnb8_WQePNhamcWkEB8hWgGAsVBD4J4UL9QTWI3xbsRIcIPmFGG2eeri6g99HyBg_3BXed-6zu7M\""></form>\n </nav>\n</footer>\n\n <script type="\"module\"" src="\"https://cdn.singlekey-id.com/scripts/htmx.00GdzawUlLg.mjs\""></script>\n\n <script type="\"module\"" src="\"https://cdn.singlekey-id.com/scripts/base.veDyGCvmY8w.mjs\""></script>\n <script defer="" nomodule="" src="\"https://cdn.singlekey-id.com/scripts/base.B5E8ztDgVe0.js\""></script>\n\n <script nonce="\"BGPomBS76d7pEfO8KFP12B-e\"">(function() {\n if (window.hcaptcha === undefined) {\n var hcaptchaScript = document.createElement('script');\n hcaptchaScript.src = 'https://js.hcaptcha.com/1/api.js?recaptchacompat=off&onload=onHCaptchaLoaded&render=explicit';\n hcaptchaScript.defer = true;\n hcaptchaScript.async = true;\n document.head.appendChild(hcaptchaScript);\n }\n})();</script>\n\n \n \n\n \n\n"
                      2025-01-05 11:04:38.892 - <span class="type">debug</span>: bosch-ebike.0 (630591) "\n\n\n\n\n<div class="\"seamless-content\"" data-hx-boost="\"true\"">\n <h2 class="\"seamless-content__header\"">Einloggen</h2>\n <form class="\"form\"" method="\"post\"" data-hx-boost="\"true\"">\n \n<a class="\"seamless-content__username-link" link\"="" data-testid="\"link-back-to-login\"" href="\"/de-de/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n <i class="\"icon" icon--arrow-left="" icon--size-s\"=""></i>\n <span class="\"break-word\"">reinhold.dobmeier@gmail.com</span>\n</a>\n \n<div class="\"input\"">\n <input class="\"input__element\"" placeholder="\" \"" autocomplete="\"current-password\"" autofocus="\"autofocus\"" type="\"password\"" id="\"Password\"" name="\"Password\"">\n <label class="\"input__placeholder\"" for="\"Password\"">Passwort</label>\n \n\n <button class="\"input__password-toggle" button="" button--icon\"="" type="\"button\"" role="\"switch\"" aria-pressed="\"false\"" title="\"Sichtbarkeit" des="" passworts="" umschalten\"="" aria-label="\"Sichtbarkeit">\n <i class="\"icon" icon--eye-open="" icon--size-l\"=""></i>\n </button>\n</div>\n <div class="\"password\"">\n <div class="\"password__remember-me\"">\n \n<div class="\"input" checkbox\"="">\n <div class="\"checkbox__group\"">\n <input class="\"checkbox__element\"" type="\"checkbox\"" id="\"RememberMe\"" name="\"RememberMe\"" value="\"true\"">\n <label class="\"checkbox__label\"" for="\"RememberMe\"">Eingeloggt bleiben</label>\n </div>\n \n</div>\n </div>\n <div class="\"password__forgot-password\"">\n <button class="\"link\"" data-testid="\"link-forgot-password\"" formaction="\"/de-de/login/password?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx&handler=ForgotPassword\"">Passwort vergessen?</button>\n </div>\n </div>\n\n \n<div class="\"form__actions\"">\n\n <button class="\"button" button--submit\"="" data-loading-class="\"button--loading\"" type="\"submit\"" data-testid="\"enter-password.submit\"">\n Weiter\n <span class="\"button__spinner\"">\n <i class="\"icon" icon--spinner="" icon--size-l\"=""></i>\n </span>\n </button>\n</div>\n <input name="\"RememberMe\"" type="\"hidden\"" value="\"false\""><input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QA2_h-JjdAD9WWabPzgckLb0i_cF9CmQ3AO_iWkbi31ZwyLoMAuYMnxcL3Ud9woFzIn8b3ALwarwhrgQXSA2ty9xynP2QoZgjRVY5BNbCqIJa5Asyy6JNvIsWMa24f_2-0\""></form>\n</div>\n\n<script nonce="\"X90qMjdVnI65X4PF1ou1P7ev\"">\n setTimeout(() => {\n document.title = \"Willkommen - SingleKey ID\";\n document.querySelector('meta[name=\"description\"]').setAttribute(\"content\", \"Willkommen\");\n document.body.setAttribute(\"data-testid\", \"login\");\n }, 0);\n</script>\n\n <a id="\"login-button\"" class="\"header__button" header__button--secondary="" header__button--login\"="" data-hx-swap-oob="\"true\"" data-hx-boost="\"false\"" data-testid="\"login\"" href="\"/de-de/login?forward=%2Fde-de%2Flogin%2Fpassword%3FreturnUrl%3D%252Fauth%252Fconnect%252Fauthorize%252Fcallback%253Fscope%253Dopenid%252520email%252520profile%252520offline_access%2526state%253DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%2526response_type%253Dcode%2526client_id%253DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%2526redirect_uri%253Dhttps%25253A%25252F%25252Fp9.authz.bosch.com%25252Fauth%25252Frealms%25252Fobc%25252Fbroker%25252Fskid%25252Fendpoint%2526prompt%253Dlogin%2526code_challenge%253DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%2526code_challenge_method%253DS256%2526nonce%253DMZqss0rdp9TovSq2Zs_vZQ%2526suppressed_prompt%253Dlogin%26f%3DaUyx&returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n Einloggen\n </a>\n\n\n\n\n\n<div id="\"inline-messages\"" class="\"" messages\"="" data-hx-swap-oob="\"innerHTML\"">\n</div>\n\n <input data-hx-swap-oob="\"true\"" id="\"language-switch\"" name="\"returnPath\"" type="\"hidden\"" value="\"/de-de/login/password?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=aUyx\"">\n\n\n\n <link rel="\"stylesheet\"" href="\"https://cdn.singlekey-id.com/styles/pages/login-or-signup/enter-password.ni6XlYwjP1Q.css\"">\n\n\n\n"
                      2025-01-05 11:04:39.643 - <span class="type">debug</span>: bosch-ebike.0 (630591) "\n\n\n\n \n <title>Welcome - SingleKey ID</title>\n <meta name="\"description\"" content="\"Welcome\"">\n\n <base href="\"https://singlekey-id.com\"">\n <link rel="\"icon\"" type="\"image/svg+xml\"" href="\"https://cdn.singlekey-id.com/images/favicons/vector.fLinwNmN0b4.svg\"" sizes="\"any\"">\n <link rel="\"icon\"" type="\"image/png\"" href="\"https://cdn.singlekey-id.com/images/favicons/16x16.Ie2d4OLHBZc.png\"" sizes="\"16x16\"">\n\n <meta name="\"viewport\"" content="\"width=device-width," initial-scale="1\"">\n\n <meta name="\"htmx-config\"" content="{\"inlineScriptNonce\":\"xi6ip3ZL9NWZ-x3udR9k7D8N\", \"includeIndicatorStyles\":false, \"refreshOnHistoryMiss\": true, \"timeout\": 20000}">\n\n \n <link rel="\"stylesheet\"" href="\"https://cdn.singlekey-id.com/styles/default.8ULbJ7zIe70.css\"">\n\n \n\n\n <script nonce="\"xi6ip3ZL9NWZ-x3udR9k7D8N\"">\n document.querySelector(\"html\").className = \"js\";\n </script>\n \n\n \n <div class="\"captcha-dialog\"">\n <div class="\"captcha-dialog__content\""></div>\n </div>\n\n \n\n\n\n<header class="\"seamless-layout__header\"">\n <h1>\n <a class="\"seamless-layout__header-link\"" data-hx-boost="\"false\"" href="\"/en-gb/home\"">\n <picture>\n <source media="\"(max-width:" 767.999px)\"="" srcset="\"https://cdn.singlekey-id.com/images/logo-on-dark.t-FKZg_FN7I.svg\"">\n <img class="\"seamless-layout__skid-logo\"" src="\"https://cdn.singlekey-id.com/images/logo-on-light.qEQuOq98Y4I.svg\"" alt="\"SingleKey" id\"="">\n </picture>\n </a>\n </h1>\n\n <img class="\"seamless-layout__partner-logo\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/brand-logo.4p7gk_UxIDA.svg\"" alt="\"Bosch\"" data-testid="\"seamless-partner-logo\"">\n</header>\n\n<main class="\"seamless-layout__main\"" data-hx-swap="\"show:none" focus-scroll:true\"="">\n <div class="\"seamless-layout__left-panel\"">\n <div class="\"seamless-layout__content\"">\n \n<div id="\"inline-messages\"" class="\"" messages\"="">\n <noscript>\n <div class=\"message message--error message--permanent\" data-testid=\"javascript-required-error\">\n <i class=\"message__icon icon icon--size-l icon--error\"></i>\n <span>Please activate JavaScript in order to progress.</span>\n </div>\n </noscript>\n</div>\n\n <div id="\"body\"">\n \n\n\n<div class="\"seamless-content\"" data-hx-boost="\"true\"" data-testid="\"enter-username\"">\n <h2 class="\"seamless-content__header\"">\n Sign up or log in\n \n<div class="\"popup" \"="">\n <a class="\"popup__open-popup\"" role="\"button\"" aria-label="\"Open" popup\"="" aria-expanded="\"false\"" aria-controls="\"signup-or-login-hint\"" hx-boost="\"false\"" href="\"/en-gb/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U#signup-or-login-hint\"">\n <i class="\"icon" icon--info="" popup__open-popup-icon="" icon--size-s\"=""></i>\n </a>\n <div id="\"signup-or-login-hint\"" class="\"popup__content\"">\n <h2 class="\"popup__header\"">\n Sign up or log in\n <a class="\"popup__close-popup\"" role="\"button\"" aria-label="\"Close" popup\"="" hx-boost="\"false\"" href="\"/en-gb/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U#\"">\n <i class="\"icon" icon--close="" icon--invert="" icon--size-s\"=""></i>\n </a>\n </h2>\n <p class="\"popup__text\"">Please enter your email address or mobile phone number and we will check if you already have a SingleKey ID. We will then redirect you to either login or signup.</p>\n </div>\n</div>\n </h2>\n\n <form class="\"form\"" method="\"post\"">\n \n\n<div>\n\n\n\n\n<div class="\"input\"">\n <input class="\"input__element\"" type="\"text\"" inputmode="\"email\"" placeholder="\" \"" autocomplete="\"email\"" autofocus="\"autofocus\"" id="\"UserIdentifierInput_EmailInput_StringValue\"" name="\"UserIdentifierInput.EmailInput.StringValue\"" value="\"\"">\n <label class="\"input__placeholder\"" for="\"UserIdentifierInput_EmailInput_StringValue\"">Email</label>\n \n</div> <a data-testid="\"user-identifier-switch-to-phone-link\"" class="\"link" user-identifier__switch-link\"="" href="\"/en-gb/login?input=phone&returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U\"">\n <i class="\"user-identifier__icon" icon="" icon--smartphone-blue="" icon--size-s\"=""></i>\n <span>Use mobile phone number </span>\n </a>\n</div>\n\n \n<div class="\"form__actions\"">\n\n <button class="\"button" button--submit="" button--protected\"="" data-loading-class="\"button--loading\"" data-testid="\"enter-username.submit\"" data-sitekey="\"f8fe2d56-ad42-4f44-b9fe-5b30fcb0dd38\"" data-hl="\"en\"" disabled="\"\"">\n Continue\n <span class="\"button__spinner\"">\n <i class="\"icon" icon--spinner="" icon--size-l\"=""></i>\n </span>\n </button>\n</div>\n <input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QDFDwsyguCI1OC2qSE4eGok8_Ub_Sb1sUkzhNvfOMH1PoGYxvsWgO9NDDyDGR_itfjTwG1yA09fs1iL4xN0snXsQaj2M6Zorz1-0qVbpFTii3_VOSv7wi1OYNtRTsFI1J0\""></form>\n</div>\n </div>\n </div>\n <div class="\"about\"" id="\"about\"" data-hx-boost="\"false\"">\n <div class="\"about__header\"">\n <text class="\"about__title\"">One login for many brands</text>\n <a class="\"about__show-info\"" role="\"button\"" aria-expanded="\"false\"" aria-controls="\"info\"" aria-label="\"Show" singlekey="" id="" info\"="" href="\"/en-gb/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U#about\"">\n <i class="\"icon" icon--arrow-down="" icon--size-m="" icon--invert="" icon--rotate180\"=""></i>\n </a>\n <a class="\"about__hide-info\"" role="\"button\"" aria-expanded="\"false\"" aria-controls="\"info\"" aria-label="\"Hide" singlekey="" id="" info\"="" href="\"/en-gb/login?returnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U#\"">\n <i class="\"icon" icon--arrow-down="" icon--size-m="" icon--invert\"=""></i>\n </a>\n </div>\n \n<div class="\"brands" about__brands\"="">\n <button class="\"brands__nav" brands__btn-left="" brands__btn-left--hidden="" button="" button--icon\"="" role="\"button\"" aria-hidden="\"true\"">\n <i class="\"icon" icon--arrow-left="" icon--size-m\"=""></i>\n </button>\n <div class="\"brands__carousel\"">\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Bosch\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_01.4p7gk_UxIDA.svg\"" width="\"130\"" height="\"28.822172\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Siemens" home="" appliances\"="" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_02.VXu-FBivXhE.svg\"" width="\"130\"" height="\"52.769993\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Buderus\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_03.OiMrTqOdPwk.svg\"" width="\"130\"" height="\"47.068966\"" draggable="\"false\"">\n </div>\n <div class="\"brands__item\"">\n <img class="\"brands__logo\"" alt="\"Home" connect\"="" src="\"https://cdn.singlekey-id.com/images/default-cobranding/partner-brand-logo_04.yP-gzACpJjE.svg\"" width="\"130\"" height="\"21.77665\"" draggable="\"false\"">\n </div>\n </div>\n <button class="\"brands__nav" brands__btn-right="" button="" button--icon\"="" role="\"button\"">\n <i class="\"icon" icon--arrow-right="" icon--size-m\"=""></i>\n </button>\n</div>\n <div class="\"about__info\""><a href="\"/our-promise/\"">SingleKey ID</a> offers convenient access to websites, shops, apps and services from many different brands with <b>one single login</b>.</div>\n </div>\n </div>\n <div class="\"seamless-layout__right-panel\"">\n <picture>\n <source media="\"(max-width:" 767.999px)\"="" sizes="\"1px\"" srcset="\"https://cdn.singlekey-id.com/images/none.590RTqhrx1o.gif" 1w\"="">\n\n <source media="\"(min-width:" 768px)\"="" type="\"image/avif\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.DzqOrR_opYg.avif" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.7mgln4u6d_s.avif="" 1024w,="" background_1366x986.zu1usdfcir4.avif="" 1366w,="" background_1600x1155.5wo0czejume.avif="" 1600w,="" background_1920x1386.mhctivdddms.avif="" 1920w\"="">\n <source media="\"(min-width:" 768px)\"="" type="\"image/webp\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.4m-_t_WNuD4.webp" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.aqnzlbdi_no.webp="" 1024w,="" background_1366x986.ulgityj-5a0.webp="" 1366w,="" background_1600x1155.gviq-nk338y.webp="" 1600w,="" background_1920x1386.efuynlavpgu.webp="" 1920w\"="">\n <source media="\"(min-width:" 768px)\"="" type="\"image/jpeg\"" srcset="\"https://cdn.singlekey-id.com/images/default-cobranding/background_768x555.AAH3SmmHwGE.jpg" 768w,="" https:="" cdn.singlekey-id.com="" images="" default-cobranding="" background_1024x739.xzvtpkydfve.jpg="" 1024w,="" background_1366x986.jfxrhjeqyw8.jpg="" 1366w,="" background_1600x1155.udo9ihuhy48.jpg="" 1600w,="" background_1920x1386.g6onbgekap8.jpg="" 1920w\"="">\n <img class="\"seamless-layout__hero-image\"" alt="\"\"" src="\"https://cdn.singlekey-id.com/images/default-cobranding/background_1920x1386.g6ONbGEKAp8.jpg\"" data-testid="\"seamless-background\"">\n </picture>\n </div>\n</main>\n\n\n\n<footer class="\"footer\"">\n <nav class="\"footer__content" footer__content--justified\"="">\n <ul class="\"footer__links\"">\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/corporate-info-and-legal-notice\"" data-hx-boost="\"false\"">\n Corporate Information\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/data-protection-notice\"" data-hx-boost="\"false\"">\n Data Protection Policy\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/corporate-info-and-legal-notice\"" data-hx-boost="\"false\"">\n Legal Notice\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/terms-of-use\"" data-hx-boost="\"false\"">\n Terms of Use\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"https://cdn.singlekey-id.com/disclosure-document.BMdLREMiXRU.pdf\"" data-hx-boost="\"false\"">\n Open Source Disclosure\n </a>\n </li>\n <li>\n <a class="\"footer__link\"" href="\"/en-gb/frequently-asked-questions\"" data-hx-boost="\"false\"">\n FAQs\n </a>\n </li>\n </ul>\n \n\n<form class="\"language-switch" footer__link\"="" method="\"post\"" action="\"/en-gb/language\"">\n <i class="\"icon" icon--globe="" icon--size-xl\"=""></i>\n <select name="\"culture\"" class="\"language-switch__select\"" data-testid="\"language-switch\""><option value="\"az-AZ\"">azərbaycan (Azərbaycan)</option>\n<option value="\"bs-BA\"">bosanski (Bosna i Hercegovina)</option>\n<option value="\"cs-CZ\"">čeština (Česko)</option>\n<option value="\"da-DK\"">dansk (Danmark)</option>\n<option value="\"de-BE\"">Deutsch (Belgien)</option>\n<option value="\"de-DE\"">Deutsch (Deutschland)</option>\n<option value="\"de-LI\"">Deutsch (Liechtenstein)</option>\n<option value="\"de-LU\"">Deutsch (Luxemburg)</option>\n<option value="\"de-AT\"">Deutsch (Österreich)</option>\n<option value="\"de-CH\"">Deutsch (Schweiz)</option>\n<option value="\"et-EE\"">eesti (Eesti)</option>\n<option value="\"en-AU\"">English (Australia)</option>\n<option value="\"en-BD\"">English (Bangladesh)</option>\n<option value="\"en-CA\"">English (Canada)</option>\n<option value="\"en-GH\"">English (Ghana)</option>\n<option value="\"en-IN\"">English (India)</option>\n<option value="\"en-IE\"">English (Ireland)</option>\n<option value="\"en-KE\"">English (Kenya)</option>\n<option value="\"en-MY\"">English (Malaysia)</option>\n<option value="\"en-MT\"">English (Malta)</option>\n<option value="\"en-NP\"">English (Nepal)</option>\n<option value="\"en-NZ\"">English (New Zealand)</option>\n<option value="\"en-NG\"">English (Nigeria)</option>\n<option value="\"en-PH\"">English (Philippines)</option>\n<option value="\"en-SG\"">English (Singapore)</option>\n<option value="\"en-ZA\"">English (South Africa)</option>\n<option value="\"en-LK\"">English (Sri Lanka)</option>\n<option selected="\"selected\"" value="\"en-GB\"">English (United Kingdom)</option>\n<option value="\"en-US\"">English (United States)</option>\n<option value="\"es-AR\"">español (Argentina)</option>\n<option value="\"es-BO\"">español (Bolivia)</option>\n<option value="\"es-CL\"">español (Chile)</option>\n<option value="\"es-CO\"">español (Colombia)</option>\n<option value="\"es-CR\"">español (Costa Rica)</option>\n<option value="\"es-EC\"">español (Ecuador)</option>\n<option value="\"es-SV\"">español (El Salvador)</option>\n<option value="\"es-ES\"">español (España)</option>\n<option value="\"es-GT\"">español (Guatemala)</option>\n<option value="\"es-HN\"">español (Honduras)</option>\n<option value="\"es-MX\"">español (México)</option>\n<option value="\"es-NI\"">español (Nicaragua)</option>\n<option value="\"es-PA\"">español (Panamá)</option>\n<option value="\"es-PY\"">español (Paraguay)</option>\n<option value="\"es-PE\"">español (Perú)</option>\n<option value="\"es-DO\"">español (República Dominicana)</option>\n<option value="\"es-UY\"">español (Uruguay)</option>\n<option value="\"es-VE\"">español (Venezuela)</option>\n<option value="\"fr-BE\"">français (Belgique)</option>\n<option value="\"fr-CA\"">français (Canada)</option>\n<option value="\"fr-FR\"">français (France)</option>\n<option value="\"fr-LU\"">français (Luxembourg)</option>\n<option value="\"fr-CH\"">français (Suisse)</option>\n<option value="\"fr-TN\"">français (Tunisie)</option>\n<option value="\"hr-HR\"">hrvatski (Hrvatska)</option>\n<option value="\"id-ID\"">Indonesia (Indonesia)</option>\n<option value="\"is-IS\"">íslenska (Ísland)</option>\n<option value="\"it-IT\"">italiano (Italia)</option>\n<option value="\"it-CH\"">italiano (Svizzera)</option>\n<option value="\"lv-LV\"">latviešu (Latvija)</option>\n<option value="\"lt-LT\"">lietuvių (Lietuva)</option>\n<option value="\"hu-HU\"">magyar (Magyarország)</option>\n<option value="\"cnr-ME\"">Montenegrin (Montenegro)</option>\n<option value="\"nl-BE\"">Nederlands (België)</option>\n<option value="\"nl-NL\"">Nederlands (Nederland)</option>\n<option value="\"no-NO\"">norsk (Norge)</option>\n<option value="\"pl-PL\"">polski (Polska)</option>\n<option value="\"pt-AO\"">português (Angola)</option>\n<option value="\"pt-BR\"">português (Brasil)</option>\n<option value="\"pt-PT\"">português (Portugal)</option>\n<option value="\"ro-MD\"">română (Republica Moldova)</option>\n<option value="\"ro-RO\"">română (România)</option>\n<option value="\"sq-XK\"">shqip (Kosovë)</option>\n<option value="\"sq-AL\"">shqip (Shqipëri)</option>\n<option value="\"sk-SK\"">slovenčina (Slovensko)</option>\n<option value="\"sl-SI\"">slovenščina (Slovenija)</option>\n<option value="\"fi-FI\"">suomi (Suomi)</option>\n<option value="\"sv-SE\"">svenska (Sverige)</option>\n<option value="\"vi-VN\"">Tiếng Việt (Việt Nam)</option>\n<option value="\"tr-TR\"">Türkçe (Türkiye)</option>\n<option value="\"el-GR\"">Ελληνικά (Ελλάδα)</option>\n<option value="\"el-CY\"">Ελληνικά (Κύπρος)</option>\n<option value="\"bg-BG\"">български (България)</option>\n<option value="\"kk-KZ\"">қазақ тілі (Қазақстан)</option>\n<option value="\"mk-MK\"">македонски (Северна Македонија)</option>\n<option value="\"sr-RS\"">српски (Србија)</option>\n<option value="\"uk-UA\"">українська (Україна)</option>\n<option value="\"ka-GE\"">ქართული (საქართველო)</option>\n<option value="\"he-IL\"">עברית (ישראל)</option>\n<option value="\"ar-AE\"">العربية (الإمارات العربية المتحدة)</option>\n<option value="\"ar-BH\"">العربية (البحرين)</option>\n<option value="\"ar-KW\"">العربية (الكويت)</option>\n<option value="\"ar-MA\"">العربية (المغرب)</option>\n<option value="\"ar-SA\"">العربية (المملكة العربية السعودية)</option>\n<option value="\"ar-TN\"">العربية (تونس)</option>\n<option value="\"ar-OM\"">العربية (عُمان)</option>\n<option value="\"ar-QA\"">العربية (قطر)</option>\n<option value="\"ar-LB\"">العربية (لبنان)</option>\n<option value="\"ar-EG\"">العربية (مصر)</option>\n<option value="\"th-TH\"">ไทย (ไทย)</option>\n<option value="\"ko-KR\"">한국어(대한민국)</option>\n<option value="\"zh-HK\"">中文(中國香港特別行政區)</option>\n<option value="\"zh-TW\"">中文(台灣)</option>\n<option value="\"ja-JP\"">日本語 (日本)</option>\n</select>\n <input data-hx-swap-oob="\"true\"" id="\"language-switch\"" name="\"returnPath\"" type="\"hidden\"" value="\"/en-gb/login?ReturnUrl=%2Fauth%2Fconnect%2Fauthorize%2Fcallback%3Fscope%3Dopenid%2520email%2520profile%2520offline_access%26state%3DmHm1yLHNfkCxPLt_ac2V9WdoDqig0HD4inqJ4OJy1Do.hNiHL66Ymac.F30z_5ulQyijx4RP1mOV-A%26response_type%3Dcode%26client_id%3DD6A94EF4-997E-4F02-9EE4-C5CECD333EF4%26redirect_uri%3Dhttps%253A%252F%252Fp9.authz.bosch.com%252Fauth%252Frealms%252Fobc%252Fbroker%252Fskid%252Fendpoint%26prompt%3Dlogin%26code_challenge%3DZlkg0PeExS0wgXzznGXvM3qswa3bUaUxTyn6glHolhk%26code_challenge_method%3DS256%26nonce%3DMZqss0rdp9TovSq2Zs_vZQ%26suppressed_prompt%3Dlogin&f=6e7U\"">\n\n <button class="\"language-switch__submit" button="" button--submit\"="" type="\"submit\"">\n Save\n </button>\n<input name="\"__RequestVerificationToken\"" type="\"hidden\"" value="\"CfDJ8EiKAo5x2-xPtI1bvpAm0QDFDwsyguCI1OC2qSE4eGok8_Ub_Sb1sUkzhNvfOMH1PoGYxvsWgO9NDDyDGR_itfjTwG1yA09fs1iL4xN0snXsQaj2M6Zorz1-0qVbpFTii3_VOSv7wi1OYNtRTsFI1J0\""></form>\n </nav>\n</footer>\n\n <script type="\"module\"" src="\"https://cdn.singlekey-id.com/scripts/htmx.00GdzawUlLg.mjs\""></script>\n\n <script type="\"module\"" src="\"https://cdn.singlekey-id.com/scripts/base.veDyGCvmY8w.mjs\""></script>\n <script defer="" nomodule="" src="\"https://cdn.singlekey-id.com/scripts/base.B5E8ztDgVe0.js\""></script>\n\n <script nonce="\"xi6ip3ZL9NWZ-x3udR9k7D8N\"">(function() {\n if (window.hcaptcha === undefined) {\n var hcaptchaScript = document.createElement('script');\n hcaptchaScript.src = 'https://js.hcaptcha.com/1/api.js?recaptchacompat=off&onload=onHCaptchaLoaded&render=explicit';\n hcaptchaScript.defer = true;\n hcaptchaScript.async = true;\n document.head.appendChild(hcaptchaScript);\n }\n})();</script>\n\n \n \n\n \n\n"
                      2025-01-05 11:04:39.644 - error: bosch-ebike.0 (630591) No code received.
                      2025-01-05 11:04:39.864 - error: bosch-ebike.0 (630591) AxiosError: Request failed with status code 400
                      2025-01-05 11:04:39.865 - error: bosch-ebike.0 (630591) {"error":"invalid_request","error_description":"Missing parameter: code"}
                      • R reini84
                        @tombox
                        tombox
                        #106
                        @reini84 Irgendwas ist mit dem Passwort komisch
                        • T tombox
                          bommel_030
                          #107
                          @tombox
                          Danke, Instanz löschen, neu anlegen und läuft wieder.
                          • T tombox
                            reini84
                            #108
                            @tombox
                            Vielen Dank, das Passwort war das Problem
                            • R reini84
                              @tombox
                              tombox
                              #109
                              @reini84 Falsch oder Sonderzeichen
                              • W Offline
                                W Offline
                                wolfgangf
                                #110
                                Ich komme leider nicht über die hCaptcha Stelle hinweg:
                                Hat da jemand eine Idee oder einen Tipp?
                                Ivan AndricI 1 Antwort Letzte Antwort
                                • W wolfgangf
                                  Ivan AndricI Offline
                                  Ivan Andric
                                  #111
                                  @wolfgangf Einen Tipp habe ich leider nicht, jedoch das gleiche Problem.
                                  • Ivan AndricI Ivan Andric
                                    tombox
                                    #112
                                    @ivan-andric Bitte die GitHub version test. Login flow wurde geändert
                                    L 1 Antwort Letzte Antwort
                                    • T tombox
                                      lindi200000
                                      #113
                                      @tombox Moin, hab das gleiche Problem und die Github Version getestet.
                                      Ich komme nicht in die EInstellungen des Adapters rein, es kommt immer [JsonConfig] Cannot read file "jsonConfig.json: Not exists
                                      Reload, anderer Browser etc .... alles schon gemacht, keine Besserung. Andere Adapter Einstellungen gehen, nur nicht der hier.
                                      • L lindi200000
                                        tombox
                                        #114
                                        @lindi200000 probier die aktuelle GitHub version
                                        • T tombox
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          #115
                                          @tombox
                                          Habe die git installiert.
                                          Komme aber mit der Anleitung nicht klar.
                                          Im Einzelnen:
                                          Dort steht:
                                          zu 1.
                                          Habe unten auf den Link geklickt.
                                          Dann kam ich zur Seite:
                                          Dann mich dort angemeldet und war drin.
                                          zu 2.
                                          F12 gedrückt.
                                          zu 3.
                                          Ich sehe dort keine Fehlermeldung.
                                          Fazit:
                                          Fehlermeldung hab ich nicht.
                                          Was mach ich denn nun falsch ?
                                          Bitte kurze Rückinfo.
                                          Danke.
                                          Danke.
                                          T L 2 Antworten Letzte Antwort
