  4. Test Adapter rpi2 2.x
    1.9k
    1.5k
519 Beiträge 29 Kommentatoren 212.9k Aufrufe 20 Beobachtet
    @smallfeuer
    Das wird dahin installiert, wo du sagst das es hin soll...
    S
    S
    Smallfeuer
    #327
    @thomas-braun sagte in Test Adapter rpi2 2.x:
    Bei der installation in der Rubrik Adapter habe ich den pi3 ausgewählt, installiert wurde dort aber nichts
    $ iobroker add rpi2 auto --host pi3garage --debug
    upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
    upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
    upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
    host.pi3garage create instance rpi2
    • S Smallfeuer
      S
      S
      Smallfeuer
      schrieb am zuletzt editiert von Smallfeuer
      #328
      admin.0
      2024-12-29 23:25:08.046	warn	rpi2 has an invalid jsonConfig: [{"instancePath":"/items/_gpios/items/_pullUpWarning/hidden","schemaPath":"#/patternProperties/%5E.%2B/properties/hidden/type","keyword":"type","params":{"type":"string"},"message":"must be string"},{"instancePath":"/items/_gpios","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
      Aufgefallen ist es mir auf Grund dieser Meldung
      • S Smallfeuer
        admin.0
        S
        S
        Smallfeuer
        #329
        @Garfonso @thomas-braun
        Fall jemand eine Idee hat, bin für jeden Rat dankbar.
        Ich hab jetzt ein sauberes - neu aufgesetztes System als Slave und kann mit der aktuellen Beta seit dem letzten Host Update im stable keine Gpio mehr sehen bzw. setzen. Der Host läuft auf Proxmoxx, der Slave ist ein Pi3 B. Falls ich noch irgendwie mit Daten beitragen kann sagt es.
        • S
          S
          Smallfeuer
          #330
          Hier noch der DEBUG Text.
          rpi2.0
          2024-12-30 12:24:43.720	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
          rpi2.0
          2024-12-30 12:24:43.720	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
          rpi2.0
          2024-12-30 12:24:43.719	warn	Cannot initialize GPIO: No chip found. GPIO functionality disabled!
          rpi2.0
          2024-12-30 12:24:43.718	debug	Got 3 from Raspberry Pi 3 Model B Plus Rev 1.3.
          rpi2.0
          2024-12-30 12:24:43.716	debug	STDERR:
          rpi2.0
          2024-12-30 12:24:43.715	debug	CPU Info: Raspberry Pi 3 Model B Plus Rev 1.3
          rpi2.0
          2024-12-30 12:24:43.700	debug	undefined
          rpi2.0
          2024-12-30 12:24:43.459	debug	Creating gpio.17.isInput
          rpi2.0
          2024-12-30 12:24:43.375	debug	wlan disabled -> clean up.
          • S Smallfeuer
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            Thomas BraunT
            Thomas BraunT
            #331
            @smallfeuer sagte in Test Adapter rpi2 2.x:
            Ist das im
            rpi-config
            aktiviert?
            S S 2 Antworten Letzte Antwort
              Ist das im
              rpi-config
              aktiviert?
              S
              S
              Smallfeuer
              #332
              @thomas-braun Guten Morgen ;) raspi-config meinst du? Ja, dort ist aktiv. Testweise hab ich grad den Zugriff mit folgender "Datei" getestet:
              import lgpio
              import time
              # Öffne den GPIO-Chip
              h = lgpio.gpiochip_open(0)
              # Definiere den Pin 17 als Eingang
              lgpio.gpio_claim_output(h, 17, lgpio.LOW)
              lgpio.gpio_claim_input(h, 17)
              while True:
                  # Lies den Zustand des Pins
                  zustand = lgpio.gpio_read(h, 17)
                  print("Pin 17: ", zustand)
                  time.sleep(0.1)
              # Schließe den GPIO-Chip
              lgpio.gpiochip_close(h)
              Das auslesen des Pins klappt damit einwandfrei.
                Der Befehl npm list | grep opengpio bringt auch keine Ausgabe
                In welchem Verzeichnis ausgeführt?
                Am besten immer die vollen Ein- und Ausgaben inkl. prompt im Terminal zeigen.
                Der adapter sollte sich eigentlich so melden:
                2024-12-29 21:57:25.585  - info: rpi2.0 (558114) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v23.5.0, js-controller: 7.0.6
                2024-12-29 21:57:26.227  - info: rpi2.0 (558114) GPIO ports are not configured
                GPIOs habe ich auf meiner Kiste nicht eingestellt, daher die Meldung an der Stelle.
                S
                S
                Smallfeuer
                #333
                Hast du mal testweise einen EINGANG bei dir definiert?
                • S Smallfeuer
                  Thomas BraunT
                  Thomas BraunT
                  #334
                  Nein, mit GPIOs hab ich noch nie irgendwas gemacht.
                    S
                    S
                    Smallfeuer
                    #335
                    @thomas-braun Na probier doch mal, ein Eingang definieren tut ja nicht weh. Dann mal neu starten ob der Fehler bei dir identisch auftritt. Wenn ich keine GPIO definiere/brauche, hab ich ja keine Fehlermeldung. Dann sieht es aus wie bei dir.
                    • S Smallfeuer
                      Thomas BraunT
                      Thomas BraunT
                      #336
                      @smallfeuer
                      Nein, werde ich nicht machen.
                        @smallfeuer
                        S
                        S
                        Smallfeuer
                        #337
                        @thomas-braun Naja, bisher hörte sich das immer so an, als ob es bei dir mit der 2.3.0 funktioniert. Da du keine GPIO Pin nutzt, brauchst, geschweige denn testen möchtest, weiß ich ehrlich gesagt nicht wie wir hier weiter kommen wollen.
                        Hatte ja gestern noch Hoffnung das es an meinem alten System liegt.
                        @ALL Hat jemand die 2.3.0 evtl. mit der 32 Bit Lite Version am laufen, bzw. überhaupt irgendwie GPIO EIN-AUSgänge die er/sie nutzt?
                        • S Smallfeuer
                          Thomas BraunT
                          Thomas BraunT
                          #338
                          @smallfeuer
                          Ich weiß nicht mal wo und wie man die Dinger einstellt, weil ich das noch nie benötigt habe.
                            @smallfeuer
                            S
                            S
                            Smallfeuer
                            #339
                            @thomas-braun Na das ist easy, einfach bei der Instanz auf Einstellung, dann der Reiter GPIO und dort hinzufügen. Kannst die Pin 17 beispielsweise einfach als Eingang definieren. Dort auch wieder löschen, neustart -> Fehlermeldung wieder weg.
                            • S Smallfeuer
                              Thomas BraunT
                              Thomas BraunT
                              #340
                              @smallfeuer
                              Hier kein Ding:
                              2024-12-30 13:25:47.003  - info: rpi2.0 (558114) Got terminate signal TERMINATE_YOURSELF
                              2024-12-30 13:25:47.011  - info: rpi2.0 (558114) terminating
                              2024-12-30 13:25:47.013  - info: rpi2.0 (558114) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2024-12-30 13:25:47.511  - info: rpi2.0 (558114) terminating
                              2024-12-30 13:25:54.001  - info: rpi2.0 (609403) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v23.5.0, js-controller: 7.0.6
                              Nix Fehlermeldung.
                              Edit: Wenn ich den neuen Eintrag dann wieder lösche kommt natürlich korrekterweise der Hinweis, das kein GPIO konfiguriert ist:
                              2024-12-30 13:35:54.277  - info: rpi2.0 (609889) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v23.5.0, js-controller: 7.0.6
                              2024-12-30 13:35:54.846  - info: rpi2.0 (609889) GPIO ports are not configured
                                @smallfeuer
                                Hier kein Ding:
                                Nix Fehlermeldung.
                                S
                                S
                                Smallfeuer
                                #341
                                @thomas-braun na das ist ja interessant. Was für ein Pi hast du? Kann es sein das es an der Node Version liegt?
                                Den State in den Objekten bekommst du angezeigt?
                                • S Smallfeuer
                                  S
                                  S
                                  Smallfeuer
                                  #342
                                  Ich hab jetzt node mal auf 23.5. gezogen -> ebenfalls keine Verbesserung.
                                  Wovon wir aber abgekommen sind, der Installationspfad.
                                  Für npm list | grep opengpio bekommme ich auf dem Raspberry Pi (SLAVE) keine Installation angezeigt. Das installiert er auf dem Master, darauf habe ich keinen Einfluss. Kann ich das manuell nachinstallieren? Am Master gibt es ja keine GPIO ;)
                                  • S Smallfeuer
                                    #343
                                    wieso nicht?
                                    Hast du keinen SSH-Zugriff auf den Slave?
                                    • S Smallfeuer
                                      Thomas BraunT
                                      Thomas BraunT
                                      #344
                                      Versuch den Adapter mal direkt auf dem Slave zu installieren. Mit der Option --host geht das.
                                        #345
                                        @thomas-braun ich dachte er meint opengpio würde auf dem Master installiert.
                                        das kann man doch via SSH auf dem Slave installieren.
                                          S
                                          S
                                          Smallfeuer
                                          #346
                                          Der 1. Befehlt (npm list | grep opengpio) gibt keine Ausgabe, der 2.( npm ls opengpio ) Befehlt passt wie folgt:
                                          smallfeuer@pi3garage:/opt/iobroker $ npm list | grep opengpio
                                          smallfeuer@pi3garage:/opt/iobroker $ cd /opt/iobroker
                                          npm ls opengpio
                                          iobroker.inst@3.0.0 /opt/iobroker
                                          └─┬ iobroker.rpi2@2.3.0
                                            └── opengpio@1.0.17
                                          die Json Datei die wir gestern angesprochen haben liegt aber auf dem Master.
                                          @thomas braun Kannst du mir sagen wie ich den Adapter jetzt mit --host installieren soll? Über benutzerdefinierte Installation ? -> dann so?
                                          https://github.com/iobroker-community-adapters/ioBroker.rpi2.git --pi3garage
                                          oder via ssh ? mit welchem Befehl ?
                                          83.8k
