  3. Cloud Dienste
  4. Script "AlexaLogOn": Alexa LogOn mit User/Pass + 2FA Code
    apollon77A
128 Beiträge 37 Kommentatoren 47.0k Aufrufe
  • sigi234S
    sigi234S
    bekomme folgenden Fehler und der Adapter geht mal auf Grün und dann wieder auf Rot?:
    alexa.0 2017-12-17 21:45:14.143 error at Decoder.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-emitter\index.js:134:20)
    alexa.0 2017-12-17 21:45:14.143 error at Decoder. (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
    alexa.0 2017-12-17 21:45:14.143 error at Manager.ondecoded (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\manager.js:332:8)
    alexa.0 2017-12-17 21:45:14.143 error at Manager.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
    alexa.0 2017-12-17 21:45:14.143 error at Manager. (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
    alexa.0 2017-12-17 21:45:14.143 error at Socket.onpacket (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:236:12)
    alexa.0 2017-12-17 21:45:14.143 error at Socket.onack (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:312:9)
    alexa.0 2017-12-17 21:45:14.143 error at Socket.adapter.objects.getObjectView (C:\ioBroker\node_modules\iobroker.alexa\alexa.js:236:42)
    alexa.0 2017-12-17 21:45:14.143 error at Array.forEach (native)
    alexa.0 2017-12-17 21:45:14.143 error at Object.keys.forEach (C:\ioBroker\node_modules\iobroker.alexa\alexa.js:239:55)
    alexa.0 2017-12-17 21:45:14.143 error TypeError: soef.ns.with is not a function
    alexa.0 2017-12-17 21:45:14.142 error uncaught exception: soef.ns.with is not a function
    alexa.0 2017-12-17 21:45:12.296 info starting. Version 0.0.28 in C:/ioBroker/node_modules/iobroker.alexa, node: v6.11.0
    Sigi
    • S
      S
      Stefan.Franke
      @sigi234:
      Sigi `
      Das passiert wann und wo in dem Script?
      In dem Callstack kommt das Script nicht vor.
      • sigi234S
        sigi234S
        nicht im Script ich glaube das ist so ok:
        22:50:50.462 [info] javascript.0 Start javascript script.js.Sigi.AlexaLogOn
        22:50:50.462 [info] javascript.0 script.js.Sigi.AlexaLogOn: registered 0 subscriptions and 1 schedule
        22:50:51.472 [info] javascript.0 script.js.Sigi.AlexaLogOn: Start LogOn Process
        22:50:51.851 [info] javascript.0 script.js.Sigi.AlexaLogOn: First Char: true
        22:50:51.851 [info] javascript.0 script.js.Sigi.AlexaLogOn: Auth String Exists: 20
        22:50:51.851 [info] javascript.0 script.js.Sigi.AlexaLogOn: Stored Cookie is still valid. No LogOn Required.
        Das andere ist das Logfile vom Iobroker!
        • S
          S
          Stefan.Franke
          @sigi234:
          Das andere ist das Logfile vom Iobroker! `
          Ja, das sieht für das Script richtig aus.
          Bei den Sachen zu ioBroker kann ich Dir nicht wirklich weiterhelfen. Was macht der "alexa" adapter? Ich hab den nicht.
          • sigi234S
            sigi234S
            https://github.com/soef/ioBroker.alexa
            • S
              S
              Stefan.Franke
              @sigi234:
              https://github.com/soef/ioBroker.alexa `
              OK, dann musst Du das an den entsprechenden Entwickler melden. ;-)
              • apollon77A
                apollon77A
                Wo hast du den Adapter denn aufgetan. Der würde noch nicht mal im Forum angekündigt und ist nicht im repo …
                • E
                  E
                  Erti1337
                  Den hab ich auch erst gefunden als ich nach alexa iobroker github gesucht hab ;)
                  Jedoch geht der Adapter bei mir erst garnicht :D
                  Deswegen test ich nu mit dem von hier :)
                  • sigi234S
                    sigi234S
                    @apollon77:
                    Wo hast du den Adapter denn aufgetan. Der würde noch nicht mal im Forum angekündigt und ist nicht im repo … `
                    Das weis ich nicht mehr, aber sicher irgendwo in einen Forum…..
                    • C
                      C
                      csamaggi
                      Erstmal danke für dieses Skript und auch das LICHT AN/AUS super arbeit nun wollte ich dass bei mir mal testen aber es mag nicht laufen das LOGON.
                      javascript.2	2018-01-16 00:40:03.219	warn	at process._tickCallback (internal/process/next_tick.js:104:9)
                      javascript.2	2018-01-16 00:40:03.219	warn	at _combinedTickCallback (internal/process/next_tick.js:80:11)
                      javascript.2	2018-01-16 00:40:03.218	warn	at endReadableNT (_stream_readable.js:974:12)
                      javascript.2	2018-01-16 00:40:03.218	warn	at IncomingMessage.emit (events.js:185:7)
                      javascript.2	2018-01-16 00:40:03.218	warn	at emitNone (events.js:91:20)
                      javascript.2	2018-01-16 00:40:03.218	warn	at IncomingMessage.g (events.js:292:16)
                      javascript.2	2018-01-16 00:40:03.218	warn	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1085:12)
                      javascript.2	2018-01-16 00:40:03.217	warn	at Request.emit (events.js:188:7)
                      javascript.2	2018-01-16 00:40:03.217	warn	at emitOne (events.js:96:13)
                      javascript.2	2018-01-16 00:40:03.217	warn	at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1163:10)
                      javascript.2	2018-01-16 00:40:03.217	warn	at Request.emit (events.js:191:7)
                      javascript.2	2018-01-16 00:40:03.217	warn	at emitTwo (events.js:106:13)
                      javascript.2	2018-01-16 00:40:03.217	warn	at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22)
                      javascript.2	2018-01-16 00:40:03.217	warn	at Request._callback (script.js.Automation.Alexa-LOGON:422:13)
                      javascript.2	2018-01-16 00:40:03.216	warn	Wrong type of javascript.2.productive.alexalogon.cookievalid: "string". Please fix, while deprecated and will not work in next versions.
                      javascript.2	2018-01-16 00:40:03.215	info	script.js.Automation.Alexa-LOGON: LogOn Failed.
                      javascript.2	2018-01-16 00:40:03.215	info	script.js.Automation.Alexa-LOGON: Cookie Complete: session-id=260-6210881-5253612; session-id-time=2146779600l; session-id=258-7106391-7160766; session-id-time=2146779600l; ubid-acbde=262-8388273-013
                      javascript.2	2018-01-16 00:40:03.214	info	script.js.Automation.Alexa-LOGON: Set-Cookies: ["ap-fid=\"\"; Domain=.amazon.de; Expires=Thu, 01-Jan-1970 00:00:10 GMT; Path=/ap/; Secure","ubid-acbde=262-8388273-0138550; Domain=.amazon.de; Expires=
                      javascript.2	2018-01-16 00:40:03.108	warn	at process._tickCallback (internal/process/next_tick.js:104
                      Hoffe das dies reicht aus dem Log.
                      Der Datenpunkt wird angelegt allerdings mit dem Wert "false" was mir ja logisch erscheint wenn er nicht verbunden kann.
                      Mein Benutzer und Passwort ist aber korrekt eine 2FA ist nicht aktiv.
                      MFG Maggi
                      • S
                        S
                        Stefan.Franke
                        @csamaggi:
                        Mein Benutzer und Passwort ist aber korrekt eine 2FA ist nicht aktiv. `
                        Schau mal bitte im Log in der Zeile "Cookie Complete", ob es darin einen Eintrag session-token=… gibt.
                        • C
                          C
                          csamaggi
                          Also es gibt nur dies bei der Zeile
                          javascript.2	2018-01-16 00:50:03.438	info	script.js.Automation.Alexa-LOGON: Cookie Complete: session-id=258-1677792-0480659; session-id-time=2146780201l; session-id=258-4274010-2185559; session-id-time=2146780201l; ubid-acbde=258-7202031-046
                          MFG
                          Maggi
                          • S
                            S
                            Stefan.Franke
                            hmmm, dann hat der LogOn selbst nicht geklappt. Sprich, Amazon hat die User/Password-Kombination abgelehnt.
                            Ich schaue heute Abend nochmal, dass ich in dem Fall die Fehlermeldungen im Script verbessere.
                            • C
                              C
                              csamaggi
                              Moin Stefan,
                              also wie es scheint war es wohl doch ein Userfehler meine Frau hat wohl das Amazon Passwort geändert gehabt und mir nicht gesagt nun ist der LOGON erfolgreich.
                              MFG
                              Maggi
                              • A
                                A
                                Arnulf
                                @csamaggi:
                                Moin Stefan,
                                MFG
                                Maggi `
                                :lol:
                                negativer WAF
                                • arteckA
                                  arteckA
                                  arteck
                                  habe das Script auch am laufen..klasse arbeit
                                  aber
                                  nimm bitte noch im Anfangsthread auf das man für das Script am besten eine eigene javainstanz machen soll
                                  bei mir hat heute der 2FA zugeschlagen und die ganze javainstanz ging auf Fehler und wurde beendet..
                                  und da auf diese auch meine Rollo Steuerung lief war heute dunkel. :? :?
                                  • S
                                    S
                                    Stefan.Franke
                                    @arteck:
                                    aber
                                    und da auf diese auch meine Rollo Steuerung lief war heute dunkel. :? :? `
                                    Hmm, das ist natürlich unschön.
                                    Ich bin im Moment dran aus dem Script einen Adapter zu machen, dass es für die Benutzer schlicht einfacher wird. Zusätzlich würden solche Probleme dann auch nicht mehr auftauchen.
                                    • lobomauL
                                      lobomauL
                                      lobomau
                                      Einen Adapter in Arbeit? Das hört man gerne :-)
                                      Geht mir auch so, dass ich das Script ungerne auf Instanz.0 laufen lassen (wo alle wichtigen Sachen wie Rollos und Lichter drauf laufen).
                                      Bei Problemen mit einem Script kann schon mal der einzelne javascript Adapter abstürzen.
                                      Host: NUC8i3 mit Proxmox:
                                      • Slave: Pi4
                                      • M
                                        M
                                        my-knx-shop
                                        Leider kenne ich mich mit scripten und java etc. garnicht aus. Die Funktion allerdings, dem Echo oder Spot den man anspricht zu sagen ( schalte das Licht an ) und dann auch nur in diesem Raum das Licht einschalten zu lassen finde ich genial.
                                        Desweiteren suche ich auch noch nach der Funktion einen bestimmten Spot das Radio abzuschalten wenn ich das möchte ohen ihn anzusprechen.
                                        Dafür gibt es ja ein anderes Script, das ich leider auch nicht verstehe oder weiß wie es eingerichtet werden müsste.
                                        Wenn hier jemand ist, der das alles realisieren kann und mir dabei mal unter die Arme greifen könnte wäre ich super dankbar.
                                        Grüße aus Berlin
                                        Olaf
                                        • S
                                          S
                                          Stefan.Franke
                                          @my-knx-shop:
                                          Grüße aus Berlin
                                          Olaf `
                                          Für die Lichtschaltung würde ich Dir die Gruppensteuerung in der Alexa-App empfehlen. Pro Raum eine Gruppe anlegen und dann Lampen und den Echo in die Gruppe. Dann sollte Licht automatisch pro Raum funktionieren.
                                          Für die Steuerung des Radios wird es schon schwieriger. Dafür wirst Du um Scripte nicht herumkommen. Du brauchst dafür 2:
                                          • AlexaLogOn (dieser Thread)
                                          • Kommandos an Alexa (http://forum.iobroker.net/viewtopic.php?f=37&t=6035)
                                          Das erste Script kümmert sich um den Login. Es erstellt ein Cookie, dass andere Scripte nutzen können, um sich zu authentifizieren.
                                          Das zweite Script übernimmt die eigentliche Steuerung.
                                          Du musst für beide Scripte im Javascript-Adapter von ioBroker ein neues Script anlegen. Als Namen verwendest Du für das erste Script AlexaLogOn und für das zweite zum Beispiel AlexaKommandos.
                                          Dann den Source Code aus dem ersten Eintrag dieses Threads einfügen. Das gleiche für das zweite Script.
                                          Anschließend folgst Du den Anleitungen, was in den beiden Scripts zu konfigurieren ist (z.B. User/Pass).
                                          83.9k
