  3. Cloud Dienste
  4. Script "AlexaLogOn": Alexa LogOn mit User/Pass + 2FA Code
128 Beiträge 37 Kommentatoren 48.6k Aufrufe
  • C
    C
    csamaggi
    Erstmal danke für dieses Skript und auch das LICHT AN/AUS super arbeit nun wollte ich dass bei mir mal testen aber es mag nicht laufen das LOGON.
    javascript.2	2018-01-16 00:40:03.219	warn	at process._tickCallback (internal/process/next_tick.js:104:9)
    javascript.2	2018-01-16 00:40:03.219	warn	at _combinedTickCallback (internal/process/next_tick.js:80:11)
    javascript.2	2018-01-16 00:40:03.218	warn	at endReadableNT (_stream_readable.js:974:12)
    javascript.2	2018-01-16 00:40:03.218	warn	at IncomingMessage.emit (events.js:185:7)
    javascript.2	2018-01-16 00:40:03.218	warn	at emitNone (events.js:91:20)
    javascript.2	2018-01-16 00:40:03.218	warn	at IncomingMessage.g (events.js:292:16)
    javascript.2	2018-01-16 00:40:03.218	warn	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1085:12)
    javascript.2	2018-01-16 00:40:03.217	warn	at Request.emit (events.js:188:7)
    javascript.2	2018-01-16 00:40:03.217	warn	at emitOne (events.js:96:13)
    javascript.2	2018-01-16 00:40:03.217	warn	at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1163:10)
    javascript.2	2018-01-16 00:40:03.217	warn	at Request.emit (events.js:191:7)
    javascript.2	2018-01-16 00:40:03.217	warn	at emitTwo (events.js:106:13)
    javascript.2	2018-01-16 00:40:03.217	warn	at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22)
    javascript.2	2018-01-16 00:40:03.217	warn	at Request._callback (script.js.Automation.Alexa-LOGON:422:13)
    javascript.2	2018-01-16 00:40:03.216	warn	Wrong type of javascript.2.productive.alexalogon.cookievalid: "string". Please fix, while deprecated and will not work in next versions.
    javascript.2	2018-01-16 00:40:03.215	info	script.js.Automation.Alexa-LOGON: LogOn Failed.
    javascript.2	2018-01-16 00:40:03.215	info	script.js.Automation.Alexa-LOGON: Cookie Complete: session-id=260-6210881-5253612; session-id-time=2146779600l; session-id=258-7106391-7160766; session-id-time=2146779600l; ubid-acbde=262-8388273-013
    javascript.2	2018-01-16 00:40:03.214	info	script.js.Automation.Alexa-LOGON: Set-Cookies: ["ap-fid=\"\"; Domain=.amazon.de; Expires=Thu, 01-Jan-1970 00:00:10 GMT; Path=/ap/; Secure","ubid-acbde=262-8388273-0138550; Domain=.amazon.de; Expires=
    javascript.2	2018-01-16 00:40:03.108	warn	at process._tickCallback (internal/process/next_tick.js:104
    Hoffe das dies reicht aus dem Log.
    Der Datenpunkt wird angelegt allerdings mit dem Wert "false" was mir ja logisch erscheint wenn er nicht verbunden kann.
    Mein Benutzer und Passwort ist aber korrekt eine 2FA ist nicht aktiv.
    MFG Maggi
      @csamaggi:
      Mein Benutzer und Passwort ist aber korrekt eine 2FA ist nicht aktiv. `
      Schau mal bitte im Log in der Zeile "Cookie Complete", ob es darin einen Eintrag session-token=… gibt.
      • C
        C
        csamaggi
        Also es gibt nur dies bei der Zeile
        javascript.2	2018-01-16 00:50:03.438	info	script.js.Automation.Alexa-LOGON: Cookie Complete: session-id=258-1677792-0480659; session-id-time=2146780201l; session-id=258-4274010-2185559; session-id-time=2146780201l; ubid-acbde=258-7202031-046
        MFG
        Maggi
          hmmm, dann hat der LogOn selbst nicht geklappt. Sprich, Amazon hat die User/Password-Kombination abgelehnt.
          Ich schaue heute Abend nochmal, dass ich in dem Fall die Fehlermeldungen im Script verbessere.
          • C
            C
            csamaggi
            Moin Stefan,
            also wie es scheint war es wohl doch ein Userfehler meine Frau hat wohl das Amazon Passwort geändert gehabt und mir nicht gesagt nun ist der LOGON erfolgreich.
            MFG
            Maggi
            • A
              A
              Arnulf
              @csamaggi:
              Moin Stefan,
              MFG
              Maggi `
              :lol:
              negativer WAF
              • arteckA
                arteckA
                arteck
                habe das Script auch am laufen..klasse arbeit
                aber
                nimm bitte noch im Anfangsthread auf das man für das Script am besten eine eigene javainstanz machen soll
                bei mir hat heute der 2FA zugeschlagen und die ganze javainstanz ging auf Fehler und wurde beendet..
                und da auf diese auch meine Rollo Steuerung lief war heute dunkel. :? :?
                  @arteck:
                  aber
                  und da auf diese auch meine Rollo Steuerung lief war heute dunkel. :? :? `
                  Hmm, das ist natürlich unschön.
                  Ich bin im Moment dran aus dem Script einen Adapter zu machen, dass es für die Benutzer schlicht einfacher wird. Zusätzlich würden solche Probleme dann auch nicht mehr auftauchen.
                  • lobomauL
                    lobomauL
                    lobomau
                    Einen Adapter in Arbeit? Das hört man gerne :-)
                    Geht mir auch so, dass ich das Script ungerne auf Instanz.0 laufen lassen (wo alle wichtigen Sachen wie Rollos und Lichter drauf laufen).
                    Bei Problemen mit einem Script kann schon mal der einzelne javascript Adapter abstürzen.
                    Host: NUC8i3 mit Proxmox:
                    • Slave: Pi4
                    • M
                      M
                      my-knx-shop
                      Leider kenne ich mich mit scripten und java etc. garnicht aus. Die Funktion allerdings, dem Echo oder Spot den man anspricht zu sagen ( schalte das Licht an ) und dann auch nur in diesem Raum das Licht einschalten zu lassen finde ich genial.
                      Desweiteren suche ich auch noch nach der Funktion einen bestimmten Spot das Radio abzuschalten wenn ich das möchte ohen ihn anzusprechen.
                      Dafür gibt es ja ein anderes Script, das ich leider auch nicht verstehe oder weiß wie es eingerichtet werden müsste.
                      Wenn hier jemand ist, der das alles realisieren kann und mir dabei mal unter die Arme greifen könnte wäre ich super dankbar.
                      Grüße aus Berlin
                      Olaf
                        @my-knx-shop:
                        Grüße aus Berlin
                        Olaf `
                        Für die Lichtschaltung würde ich Dir die Gruppensteuerung in der Alexa-App empfehlen. Pro Raum eine Gruppe anlegen und dann Lampen und den Echo in die Gruppe. Dann sollte Licht automatisch pro Raum funktionieren.
                        Für die Steuerung des Radios wird es schon schwieriger. Dafür wirst Du um Scripte nicht herumkommen. Du brauchst dafür 2:
                        • AlexaLogOn (dieser Thread)
                        • Kommandos an Alexa (http://forum.iobroker.net/viewtopic.php?f=37&t=6035)
                        Das erste Script kümmert sich um den Login. Es erstellt ein Cookie, dass andere Scripte nutzen können, um sich zu authentifizieren.
                        Das zweite Script übernimmt die eigentliche Steuerung.
                        Du musst für beide Scripte im Javascript-Adapter von ioBroker ein neues Script anlegen. Als Namen verwendest Du für das erste Script AlexaLogOn und für das zweite zum Beispiel AlexaKommandos.
                        Dann den Source Code aus dem ersten Eintrag dieses Threads einfügen. Das gleiche für das zweite Script.
                        Anschließend folgst Du den Anleitungen, was in den beiden Scripts zu konfigurieren ist (z.B. User/Pass).
                        • liv-in-skyL
                          liv-in-skyL
                          hallo - ich bin mir nicht ganz sicher, aber muss das script nicht noch für den echo spot aktualisiert werden, damit "der echo spot" erkannt wird. bin mir nicht sicher (glaube aber es so gelesen zu haben) oder vielleicht ist es schon geändert
                            @liv-in-sky:
                            hallo - ich bin mir nicht ganz sicher, aber muss das script nicht noch für den echo spot aktualisiert werden, damit "der echo spot" erkannt wird. bin mir nicht sicher (glaube aber es so gelesen zu haben) oder vielleicht ist es schon geändert `
                            Dafür solltest Du am besten in dem Thread zu den Alexa-Kommandos nachfragen http://forum.iobroker.net/viewtopic.php?f=37&t=6035.
                            Der Quelltext im ersten Post hat jedenfalls noch keinen Eintrag für einen Echo Spot…
                            • M
                              M
                              my-knx-shop
                              @Stefan.Franke:
                              Anschließend folgst Du den Anleitungen, was in den beiden Scripts zu konfigurieren ist (z.B. User/Pass). `
                              Vielen Dank,
                              ich habe mir das Script hier angesehen und festgestellt dass hier Informationen benötigt werden, die ich nicht kenne:
                              Was ist zum Beispiel:
                              twofacode = "";
                              Wozu werden folgende benötigt:
                              // Wenn gewünscht, Pfad und Name nach eigenen Vorstellungen anpassen
                              // Wenn gewünscht, Name und desc für den Datenpunkt anpassen.
                              // Wenn gewünscht, Pfad und Name nach eigenen Vorstellungen anpassen.
                              Bei dem Script für die Kommandos gibt es auch einiges zum anpassen. Was muss hier unbedingt angepasst werden ?
                              Danke euch vorab
                              • liv-in-skyL
                                liv-in-skyL
                                #66
                                wie stefan.franke schrieb: du solltest es in dem anderen forumeintrag posten und danach fragen. ich denke der ersteller des scripts wird dir weiterhelfen können. die anfrage nach dem "spot" wird sicher auch andere interessieren.
                                ich hab es (die beiden scripts) vor kurzem selbst erst installiert und bin mit meinen 3 dot's happy - habe alle in der vis eingebunden - funktioniert sehr gut.
                                • BBTownB
                                  BBTownB
                                  BBTown
                                  #67
                                  @my-knx-shop:
                                  twofacode = ""; ` das ist eine "2 Faktor Authentifizierung".
                                  Sofern Du diese gar nicht aktivert hast, werden hier auch keine Einträge benötigt.
                                  @my-knx-shop:
                                  Bei dem Script für die Kommandos gibt es auch einiges zum anpassen. Was muss hier unbedingt angepasst werden ? ` überhaupt nichts.
                                  Du bist schon vertraut mit dem Begriff/der Bedeutung von "Wenn gewünscht" ;) 8-) ??
                                  ioBroker auf NUC (VM debian v13 (Trixie ), node v24.21.0 npm v11.19.0, js-controller v7.2.5 jsonl/jsonl / HomeMatic CCU-2 (Wired und Funk) / Philips HUE / echo.DOT / Broadlink RM pro / SONOS
                                  • M
                                    M
                                    my-knx-shop
                                    #68
                                    Das schon ;-) aber welcher Pfad ist gemeint, was für ein desc und welchen Namen soll ich hier anpassen ?
                                    • M
                                      M
                                      my-knx-shop
                                      #69
                                      @Stefan.Franke:
                                      Für die Lichtschaltung würde ich Dir die Gruppensteuerung in der Alexa-App empfehlen. Pro Raum eine Gruppe anlegen und dann Lampen und den Echo in die Gruppe. Dann sollte Licht automatisch pro Raum funktionieren. `
                                      Das funktioniert leider nicht.
                                      Ich habe alles entsprechend zugeordnet, aber wenn ich sage "schalte Decke ein" wird mit gesagt, dass es mehrere mit der Bezeichnung 2Decke " gibt und welches ich möchte.
                                        #70
                                        @my-knx-shop:
                                        Ich habe alles entsprechend zugeordnet, aber wenn ich sage "schalte Decke ein" wird mit gesagt, dass es mehrere mit der Bezeichnung 2Decke " gibt und welches ich möchte. `
                                        Ja, das ist das erwartete Verhalten. Amazons Implementierung zielt darauf ab, dass Du nur "licht an/aus" sagen musst. Wenn Du weiter qualifizieren willst pro Raum (wie bei Dir jetzt "Decke"), dann kann Alexa das "out-of-the-box" nicht.
                                        Es ist mit dem LichtAn-Script prinzipiell möglich, das umzusetzen. Ich würde Dir aber erstmal empfehlen, Dich mit den Scripten und der ganzen Umgebung vertraut zu machen - zum Beispiel in dem Du das LogOn-Script und die Kommandos zum Laufen bringst. Danach kannst Du dich in dem Thread zum LichtAn-Script nochmal melden.
                                        • E
                                          E
                                          eXTreMe
                                          #71
                                          @liv-in-sky:
                                          Einfach in (ca.) Zeile 139 unter var knownDeviceType folgende Zeile hinzufügen:
                                          "A10A33FOX2NUBK":   {"device":"Echo Spot",          "anlegen": true},
                                          Anschließend das Script einmal neustarten, dann sollte der Echo Spot als Objekt auftauchen.
                                          84.1k
