  4. Lösung zur Wertspeicherung
232 Beiträge 6 Kommentatoren 44.0k Aufrufe 4 Beobachtet
  • mickymM mickym
    @accuface Gut bei der einfachen Lösung importierst Du Dir diese kleine Gruppe in Dein Node-Red:
           "id": "9aa4e669cb291598",
           "type": "group",
           "z": "d2ff8c1dc9ccdccc",
           "name": "Download files aus /home/iobroker",
           "style": {
               "label": true,
               "fill": "#7fb7df",
               "color": "#ffffff"
           "nodes": [
               "f31a598d.9fd2c8",
               "98261154.3006",
               "34dc99e5.495466",
               "38d65d59.1d8aa2",
               "3b8014a.86ad8ec",
               "5de7cbb4.fa21a4",
               "67ecfa7f.3f0e24",
               "eac128f4fd832c06"
           "x": 134,
           "y": 99,
           "w": 732,
           "h": 222
           "id": "f31a598d.9fd2c8",
           "type": "function",
           "g": "9aa4e669cb291598",
           "name": "Set base path",
           "func": "//restrict to /home/iobroker/\nvar basePath = \"/home/iobroker/\";\nvar filename = msg.req.params.fn;\n\n\nif(filename.includes(\"..\\\\\")){\n    msg.payload = \"Illegal file path\";\n    msg.statusCode = 405;//not allowed\n    return [null, msg];//fire output 2\n} else if(filename.includes(\"../\")){\n    msg.payload = \"Illegal file path\";\n    msg.statusCode = 405;//not allowed\n    return [null, msg];//fire output 2\n} \n//TODO: add more checks\n\nmsg.filename = basePath + filename;\nreturn [msg, null];//fire output 1\n\n\n",
           "outputs": 2,
           "timeout": "",
           "noerr": 0,
           "initialize": "",
           "finalize": "",
           "libs": [],
           "x": 440,
           "y": 200,
           "wires": [
                   "34dc99e5.495466"
                   "eac128f4fd832c06"
           "id": "98261154.3006",
           "type": "http response",
           "name": "",
           "statusCode": "",
           "headers": {},
           "x": 790,
           "y": 240,
           "wires": []
           "id": "34dc99e5.495466",
           "type": "file in",
           "name": "",
           "filename": "filename",
           "filenameType": "msg",
           "format": "",
           "chunk": false,
           "sendError": false,
           "encoding": "none",
           "allProps": false,
           "x": 630,
           "y": 180,
           "wires": [
                   "98261154.3006"
           "id": "38d65d59.1d8aa2",
           "type": "catch",
           "name": "",
           "scope": [
               "34dc99e5.495466"
           "uncaught": false,
           "x": 250,
           "y": 280,
           "wires": [
                   "3b8014a.86ad8ec"
           "id": "3b8014a.86ad8ec",
           "type": "function",
           "name": "Set 404",
           "func": "msg.payload = msg.error;\nmsg.statusCode = 404;//resource not found\nreturn msg;",
           "outputs": 1,
           "timeout": "",
           "noerr": 0,
           "initialize": "",
           "finalize": "",
           "libs": [],
           "x": 460,
           "y": 280,
           "wires": [
                   "eac128f4fd832c06"
           "id": "5de7cbb4.fa21a4",
           "type": "comment",
           "name": "Create http endpoint <nodered>/files/xxx  where xxx is the file name to download",
           "info": "",
           "x": 480,
           "y": 140,
           "wires": []
           "id": "67ecfa7f.3f0e24",
           "type": "http in",
           "name": "",
           "url": "/files/:fn",
           "method": "get",
           "upload": false,
           "swaggerDoc": "",
           "x": 230,
           "y": 200,
           "wires": [
                   "f31a598d.9fd2c8"
           "id": "eac128f4fd832c06",
           "type": "junction",
           "x": 600,
           "y": 240,
           "wires": [
                   "98261154.3006"
    Damit kannst Du dann Datein NUR aus dem Verzeichnis: /home/iobroker auf dein Notebook runterladen.
    Also für Deine test.txt Datei gibst Du dannn im Browser folgendes ein:
    <ip-Adresse des iobrokers>:1880/files/test.text
    Dann solltest Du den normalen Download Dialog bekommen und Du kannst die Datei auf Deinem Laptop speichern.
    A
    A
    Accuface
    schrieb am zuletzt editiert von Accuface
    @mickym said in Lösung zur Wertspeicherung:
           "type": "group",
           "style": {
               "label": true,
               "fill": "#7fb7df",
               "color": "#ffffff"
           "nodes": [
               "f31a598d.9fd2c8",
               "98261154.3006",
               "34dc99e5.495466",
               "38d65d59.1d8aa2",
               "3b8014a.86ad8ec",
               "5de7cbb4.fa21a4",
               "67ecfa7f.3f0e24",
               "eac128f4fd832c06"
           "x": 134,
           "y": 99,
           "w": 732,
           "h": 222
           "type": "function",
           "outputs": 2,
           "timeout": "",
           "noerr": 0,
           "initialize": "",
           "finalize": "",
           "libs": [],
           "x": 440,
           "y": 200,
           "wires": [
                   "34dc99e5.495466"
                   "eac128f4fd832c06"
           "name": "",
           "statusCode": "",
           "headers": {},
           "x": 790,
           "y": 240,
           "wires": []
           "type": "file in",
           "name": "",
           "format": "",
           "chunk": false,
           "sendError": false,
           "encoding": "none",
           "allProps": false,
           "x": 630,
           "y": 180,
           "wires": [
                   "98261154.3006"
           "type": "catch",
           "name": "",
           "scope": [
               "34dc99e5.495466"
           "uncaught": false,
           "x": 250,
           "y": 280,
           "wires": [
                   "3b8014a.86ad8ec"
           "type": "function",
           "name": "Set 404",
           "outputs": 1,
           "timeout": "",
           "noerr": 0,
           "initialize": "",
           "finalize": "",
           "libs": [],
           "x": 460,
           "y": 280,
           "wires": [
                   "eac128f4fd832c06"
           "type": "comment",
           "info": "",
           "x": 480,
           "y": 140,
           "wires": []
           "type": "http in",
           "name": "",
           "method": "get",
           "upload": false,
           "swaggerDoc": "",
           "x": 230,
           "y": 200,
           "wires": [
                   "f31a598d.9fd2c8"
           "type": "junction",
           "x": 600,
           "y": 240,
           "wires": [
                   "98261154.3006"
    Vielen Dank schon mal.
    Ich bin jetzt irritiert, das ist jetzt zum Download oder wie?
    Ich dachte eigentlich dass die Werte Automatisch zu nem bestimmten Zeitpunkt in die Excelliste geschrieben werden können.
    Sorry wenn ih mich da viell. unverständlich ausgedrükt habe.
    Ich hab ja (noch) keinen Flow um meine gewünschten Zählerwerte aus den DP in die Excelliste zu übertragen.
    Ich hab mir zwar die von Dir geposteten Themen angesehen, versteh aber im moment noch nicht was da alles an nodes benötigt wird und was in welche nodes eingetragen werden muss. Soweit bin ich noch ned.
    • A Accuface
             "type": "group",
             "style": {
                 "label": true,
                 "fill": "#7fb7df",
                 "color": "#ffffff"
             "nodes": [
                 "f31a598d.9fd2c8",
                 "98261154.3006",
                 "34dc99e5.495466",
                 "38d65d59.1d8aa2",
                 "3b8014a.86ad8ec",
                 "5de7cbb4.fa21a4",
                 "67ecfa7f.3f0e24",
                 "eac128f4fd832c06"
             "x": 134,
             "y": 99,
             "w": 732,
             "h": 222
             "type": "function",
             "outputs": 2,
             "timeout": "",
             "noerr": 0,
             "initialize": "",
             "finalize": "",
             "libs": [],
             "x": 440,
             "y": 200,
             "wires": [
                     "34dc99e5.495466"
                     "eac128f4fd832c06"
             "name": "",
             "statusCode": "",
             "headers": {},
             "x": 790,
             "y": 240,
             "wires": []
             "type": "file in",
             "name": "",
             "format": "",
             "chunk": false,
             "sendError": false,
             "encoding": "none",
             "allProps": false,
             "x": 630,
             "y": 180,
             "wires": [
                     "98261154.3006"
             "type": "catch",
             "name": "",
             "scope": [
                 "34dc99e5.495466"
             "uncaught": false,
             "x": 250,
             "y": 280,
             "wires": [
                     "3b8014a.86ad8ec"
             "type": "function",
             "name": "Set 404",
             "outputs": 1,
             "timeout": "",
             "noerr": 0,
             "initialize": "",
             "finalize": "",
             "libs": [],
             "x": 460,
             "y": 280,
             "wires": [
                     "eac128f4fd832c06"
             "type": "comment",
             "info": "",
             "x": 480,
             "y": 140,
             "wires": []
             "type": "http in",
             "name": "",
             "method": "get",
             "upload": false,
             "swaggerDoc": "",
             "x": 230,
             "y": 200,
             "wires": [
                     "f31a598d.9fd2c8"
             "type": "junction",
             "x": 600,
             "y": 240,
             "wires": [
                     "98261154.3006"
      mickymM
      mickymM
      mickym
      @accuface Das weiß ich doch alles - Du solltest ein bisschen geduldiger sein. Wir kümmern uns ja nun erst mal darum, dass Du eine Datei auf Dein laptop laden kannst.
      Dazu kopierst Du das was ich Dir in dem Spoiler geschickt habe in Deine Zwischenablage:
      Dann machst Du dein NodeRed auf und importierst diesen Flow:
      Kopierst dann den Inhalt der Zwischenablage in das rosa Fenster
      drückst auf Import und plazierst diese Nodes in einen Flow Deiner Wahl klickst auf übernehmen.
      Anschließend probierst Du den Link in Deinem Browser aus, den ich Dir gepostet habe, natürlich mit deiner IP Adresse und versuchst damit die Textdatei - die Du gestern im Homeverzeichnis des iobrokers erstellst auf Dein Laptop zu laden.
      Ein Schritt nach dem anderen OK?
      Nein die werden nicht automatisch in eine Excelliste geschrieben - sinnvoller ist es auch, das als CSV zu laden - da Du ja das Excel auf Deinem LAPTOP hast, das nicht 24 Std. an ist. Der Vorteil es in eine CSV zu schreiben ist, dass dann nicht nur die neuen Daten sondern die Datei die Historie erhält Du aber in Dein Excel nur das DELTA importierst.
      Also iobroker soureanalytics -> NodeRed in CSV unter /home/iobroker -> Download auf Dein Laptop -> Excel aufmachen und Sheet auf Aktualisieren klicken. (Vorausgesetzt Du speicherst auf Deinem Laptop immer auf die gleiche Datei).
      In dem einen Link habe ich doch Schritt für Schritt erklärt, was Du im Excel machen musst:
      • mickymM mickym
        A
        A
        Accuface
        😬 okok....sorry. Ich und geduld passt nur bedingt zusammen.
        werde ich später testen wenn ich zuhause bin.
        • A Accuface
          mickymM
          mickymM
          mickym
          @accuface Hier habe ich doch zusammengefasst, was Du im Excel dann machen musst.
          • mickymM mickym
            A
            A
            Accuface
            ja, alles gut.
            Hab das jetzt getestet.....
            das funzt. *Freu
            Ich hab nun eine neue test.txt datei angelegt, in Excel eingelesen, hat funktioniert, dann hab ich in diese Datei auf dem Raspi weitere Zeilen (Text) eingefügt. runtergeladen, natürlich musste ich die erste Löschen, die Aktualiesierte umbenennen und konnte über aktualisieren die zugefügten Zeilen (text) sehen.
            Das funktioniert auch soweit.
            • A Accuface
              ja, alles gut.
              das funzt. *Freu
              mickymM
              mickymM
              mickym
              @accuface In Zukunft löscht Du nichts mehr sondern kopierst Du die Datei einfach auf die bestehende drauf - ohne Löschen und irgendwas - und drückst im Excel nur auf Aktualisieren - wie ich das im Screenshot gezeigt habe.
              Dann importierst erst mal den Flow aus dem anderen Thread: https://forum.iobroker.net/post/1159322
              Und dann werden wir langsam eine Node nach der anderen durchsprechen.
              • mickymM mickym
                A
                A
                Accuface
                @accuface ...........sondern kopierst Du die Datei einfach auf die bestehende drauf -
                wenn ich die über den Link im Browser downloade, dann vergibt er doch automatisch den namen plus (1), weil sie ja genauso heisst. da kann ich doch nix kopieren, oder wie?
                in den rein wo der Flow zum Downlaoden ist?
                OK
                • A Accuface
                  OK
                  mickymM
                  mickymM
                  mickym
                  @accuface sagte in Lösung zur Wertspeicherung:
                  Dan
                  Ja aber Du kannst auch die bestehende Datei auswählen und die vorhandene ersetzen.
                  • A Accuface
                    OK
                    mickymM
                    mickymM
                    mickym
                    Wo immer Du willst. - Machs halt in den gleichen Flow - dann hast Du alles zusammen.
                    • mickymM mickym
                      A
                      A
                      Accuface
                      erledigt.
                      Was muss/darf ich da jetzt alles ändern?
                      Klar, ganz Links muss ich meinen Datenpunkt/Datenpunkte ändern.
                      Frage vorab: lässt sich das später um weitere DP erweitern?
                      • A Accuface
                        erledigt.
                        mickymM
                        mickymM
                        mickym
                        @accuface Ja Du kannst soviele dran machen, wie Du willst. Du musst ja nur die iobroker_In Nodes kopieren und an die JOIN Node anflanschen.
                        • mickymM mickym
                          A
                          A
                          Accuface
                          ok, fangen wir klein an. Ich kann nämlich recht gut ein Chaos produzieren oder auch Provuzieren. 😂
                          • A Accuface
                            mickymM
                            mickymM
                            mickym
                            @accuface In einer halben Std. ca. ,muss erst was Essen.
                            mickymM A 2 Antworten Letzte Antwort
                            • mickymM mickym
                              mickymM
                              mickymM
                              mickym
                              @mickym Du musst Dir schon mal überlegen, welche Datenpunkte Du haben willst, die sollen ja ungefähr zur gleichen Zeit triggern - da Du die ja in eine Zeile schreiben willst.
                              • mickymM mickym
                                A
                                A
                                Accuface
                                alles klar.... Guddn.
                                muss aber auch nimmer unbedingt heute sein, ausser du hast da jetzt gerade Bock Drauf.....bzw bin ich dann auch nur bis etwa 21 uhr da.
                                werden einige sein.
                                Frage: Was macht mehr Sinn, die Werte aus Blau einmal die Woche (sonntagnacht) zu speichern, oder die Grüne 01 jeden Tag speichern?
                                wobei ich denk dass man einfach alle gewollten werte, jede Nacht speichert, dann hat man nur einmal das gerödel und nicht 5 verschieden Speicherzeitpunkte, oder?
                                Blau ist quasi die Wochenübersicht, hier ist quasi (Heute) der Wert 04, der selbe wie bei Grün der Wert 01
                                Grün 02 ist dann der Wert von Gestern.
                                • A Accuface
                                  werden einige sein.
                                  mickymM
                                  mickymM
                                  mickym
                                  @accuface Ja das sind alles Punkte, die um den Tageswechsel aktualisiert werden. Bei den Wochentagen bleiben halt die Zeilen leer, dessen Wochentag nicht ist.
                                  Du holst die Punkte deshalb nicht aus dem iobroker. Schau Dir mal die Zeitstempel an, wann die Datenpunkte geschrieben wurden.
                                  Du musst Dir das so vorstellen, dass Du alle Spalten sammeln musst, die zu einem Zeitpunkt gesammelt werden.
                                  Also musst du immer warten bis eine Zeile voll geschrieben ist.
                                  • mickymM mickym
                                    A
                                    A
                                    Accuface
                                    also bei den Blauen sind die Zeitpunkte (Uhrzeit) unterschiedlich.
                                    ?? versteh ich nicht, bzw, kann mir dass gerade nicht in einer Liste vorstellen
                                    • A Accuface
                                      mickymM
                                      mickymM
                                      mickym
                                      @accuface Na ja wir werden erst mal nur die blauen anschauen. da kommt ja pro Tag nur eine Nachricht. Wir werden da wahrscheinlich doch teilweise was neues basteln müssen. Das Problem was Du generell haben wirst, ist dass wenn NodeRed oder Dein iobroker neu gestartet wird - du neue unterschiedliche Dateien bekommst, die Du erst in Excel selbst zusammenfügen musst.
                                      Mach nochmal einen Screenshot mit den Zeitstempeln.
                                      dann kopier mir bitte mal den Pfad bis zur currentWeek hierein. Den importierten Flow können wir leider nur teilweise nutzen.
                                      • mickymM mickym
                                        A
                                        A
                                        Accuface
                                        sourceanalytix.0.0_userdata__0__Eigenverbrauch.currentYear.consumed.currentWeek
                                        Montag:
                                        sourceanalytix.0.0_userdata__0__Eigenverbrauch.currentYear.consumed.currentWeek.01_Monday
                                        Zeitstempel Dienstag:
                                        • A Accuface
                                          Montag:
                                          mickymM
                                          mickymM
                                          mickym
                                          @accuface Nein du musst die 1 im Admin drücken (ggf. den Expertenmodus einschalten - den Kopf
                                          83.8k
