  4. TibberLink Adapter
TibberLink Adapter
651 Beiträge 89 Kommentatoren 278.5k Aufrufe 80 Beobachtet
  • R ReblausGT
    @merlin123 said in TibberLink Adapter:
    Bisher ging der nur bei nem echten Problem auf false.
    Also ich kann es akut nur so feststellen.... Schalte mal den Debug Mode an.... da hat sich nichts geändert, ich schreibe nur nicht mehr so viel in das normale Log....
    Merlin123M Offline
    Merlin123M Offline
    Merlin123
    #365
    @reblausgt so... Eben wieder 9:50, 9:51, 9:52
    Im Log sieht das so aus:
    tibberlink.0
    2024-12-10 09:52:31.077	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:31.077: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 9d 01 09:52:31.077: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 9d 01 09:52:31.077: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:31.077: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:31.077: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:31.077: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:31.077: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 00 01
    tibberlink.0
    2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Power","value":256,"unit":"W"}
    tibberlink.0
    2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:31.076	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:31.076	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:52:30.529	debug	Attempting to reconnect to TibberFeed in 36sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:52:30.158	debug	Polled local Tibber Bridge metrics: {"type":"node_status","node_status":{"product_id":49344,"bootloader_version":17563650,"meter_mode":3,"node_battery_voltage":3.469,"node_temperature":18.354,"node_avg_rssi":-37.999,"node_avg_lqi":197.511,"radio_tx_power":0,"node_uptime_ms":3519011234,"meter_msg_count_sent":98,"meter_pkg_count_sent":138,"time_in_em0_ms":4669,"time_in_em1_ms":35,"time_in_em2_ms":295447,"acmp_rx_autolevel_9600":167,"invalid_meter_readings_count":0},"hub_attachments":{"meter_pkg_count_recv":140,"meter_reading_count_recv":95,"meter_corrupt_reading_count_recv":5,"compression_error_readings_count":4,"node_version":"1172-e5b13c4f"}}
    tibberlink.0
    2024-12-10 09:52:29.044	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:29.043: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 9d 01 09:52:29.043: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 9d 01 09:52:29.043: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:29.044: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:29.044: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:29.044: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:29.044: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 00 01
    tibberlink.0
    2024-12-10 09:52:29.044	debug	Pulse mode 3 parse result: {"name":"Power","value":256,"unit":"W"}
    tibberlink.0
    2024-12-10 09:52:29.044	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:29.044	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:29.044	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:29.043	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:29.043	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:29.043	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:29.043	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:29.043	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:52:27.085	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:27.084: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 9b 01 09:52:27.084: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 9b 01 09:52:27.084: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:27.084: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:27.085: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:27.085: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:27.085: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 f0 01
    tibberlink.0
    2024-12-10 09:52:27.085	debug	Pulse mode 3 parse result: {"name":"Power","value":240,"unit":"W"}
    tibberlink.0
    2024-12-10 09:52:27.085	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:27.085	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:27.084	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:27.084	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:27.084	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:27.084	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:27.084	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:27.084	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:52:27.065	debug	Attempting to reconnect to TibberFeed in 34sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:52:25.040	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:25.039: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 99 01 09:52:25.039: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 99 01 09:52:25.039: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:25.040: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:25.040: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:25.040: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:25.040: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 f3 01
    tibberlink.0
    2024-12-10 09:52:25.040	debug	Pulse mode 3 parse result: {"name":"Power","value":243,"unit":"W"}
    tibberlink.0
    2024-12-10 09:52:25.040	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:25.040	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:25.040	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:25.039	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:25.039	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:25.039	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:25.039	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:25.039	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:52:23.026	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:23.025: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 99 01 09:52:23.026: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 99 01 09:52:23.026: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:23.026: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:23.026: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:23.026: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:23.026: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 f3 01
    tibberlink.0
    2024-12-10 09:52:23.026	debug	Pulse mode 3 parse result: {"name":"Power","value":243,"unit":"W"}
    tibberlink.0
    2024-12-10 09:52:23.026	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:23.026	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:23.026	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:23.026	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:23.025	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:23.025	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:23.025	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:23.025	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:52:22.613	debug	Attempting to reconnect to TibberFeed in 32sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:52:21.045	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:21.044	debug	got HEX data from local pulse:
    tibberlink.0
    2024-12-10 09:52:19.093	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:19.093	debug	got HEX data from local pulse:
    tibberlink.0
    2024-12-10 09:52:18.253	debug	Attempting to reconnect to TibberFeed in 30sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:52:17.973	debug	Attempting to reconnect to TibberFeed in 28sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:52:17.047	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:17.046	debug	got HEX data from local pulse:
    tibberlink.0
    2024-12-10 09:52:15.098	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:15.098	debug	got HEX data from local pulse:
    tibberlink.0
    2024-12-10 09:52:13.054	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:13.054	debug	got HEX data from local pulse:
    tibberlink.0
    2024-12-10 09:52:13.046	debug	Attempting to reconnect to TibberFeed in 26sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:52:11.842	debug	Attempting to reconnect to TibberFeed in 24sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:52:11.106	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:11.106	debug	got HEX data from local pulse:
    tibberlink.0
    2024-12-10 09:52:09.057	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:09.056: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8e 01 09:52:09.056: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8e 01 09:52:09.056: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:09.056: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:09.057: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:09.057: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:09.057: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01
    tibberlink.0
    2024-12-10 09:52:09.057	debug	Pulse mode 3 parse result: {"name":"Power","value":0,"unit":"W"}
    tibberlink.0
    2024-12-10 09:52:09.057	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:09.057	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:09.056	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:09.056	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:09.056	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:09.056	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:09.056	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:09.056	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:52:08.529	debug	Attempting to reconnect to TibberFeed in 22sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:52:07.115	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:07.115: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8b 01 09:52:07.115: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8b 01 09:52:07.115: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:07.115: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:07.115: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:07.115: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:07.115: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 06 01
    tibberlink.0
    2024-12-10 09:52:07.115	debug	Pulse mode 3 parse result: {"name":"Power","value":262,"unit":"W"}
    tibberlink.0
    2024-12-10 09:52:07.115	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:07.115	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:07.115	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:07.115	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:07.115	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:07.114	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:07.114	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:07.114	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:52:07.065	debug	Attempting to reconnect to TibberFeed in 20sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:52:05.066	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:05.066: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8b 01 09:52:05.066: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8b 01 09:52:05.066: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:05.066: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:05.066: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:05.066: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:05.066: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 06 01
    tibberlink.0
    2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Power","value":262,"unit":"W"}
    tibberlink.0
    2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:05.065	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:05.065	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:52:04.613	debug	Attempting to reconnect to TibberFeed in 18sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:52:03.121	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:03.120: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8a 01 09:52:03.121: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8a 01 09:52:03.121: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:03.121: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:03.121: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:03.121: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:03.121: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 03 01
    tibberlink.0
    2024-12-10 09:52:03.121	debug	Pulse mode 3 parse result: {"name":"Power","value":259,"unit":"W"}
    tibberlink.0
    2024-12-10 09:52:03.121	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:03.121	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:03.121	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:03.121	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:03.120	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:03.120	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:03.120	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:03.120	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:52:02.253	debug	Attempting to reconnect to TibberFeed in 16sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:52:01.073	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:01.073: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 87 01 09:52:01.073: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 87 01 09:52:01.073: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:01.073: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:01.073: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:01.073: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:01.073: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 f6 01
    tibberlink.0
    2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Power","value":246,"unit":"W"}
    tibberlink.0
    2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:52:01.072	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:52:01.072	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:59.045	debug	Attempting to reconnect to TibberFeed in 14sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:59.031	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:59.030: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 87 01 09:51:59.030: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 87 01 09:51:59.030: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:59.030: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:59.030: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:59.030: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:59.031: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 f6 01
    tibberlink.0
    2024-12-10 09:51:59.031	debug	Pulse mode 3 parse result: {"name":"Power","value":246,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:59.030	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:59.030	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:59.030	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:59.030	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:59.030	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:59.030	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:59.030	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:59.029	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:57.084	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:57.084: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 84 01 09:51:57.084: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 84 01 09:51:57.084: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:57.084: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:57.084: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:57.084: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:57.084: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 00 01
    tibberlink.0
    2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Power","value":256,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:57.084	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:57.083	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:56.527	debug	Attempting to reconnect to TibberFeed in 12sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:55.136	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:55.136: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 84 01 09:51:55.136: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 84 01 09:51:55.136: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:55.136: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:55.136: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:55.136: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:55.136: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 00 01
    tibberlink.0
    2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Power","value":256,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:55.135	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:55.135	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:54.612	debug	Attempting to reconnect to TibberFeed in 10sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:53.087	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:53.086: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 83 01 09:51:53.086: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 83 01 09:51:53.086: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:53.087: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:53.087: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:53.087: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:53.087: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 10 01
    tibberlink.0
    2024-12-10 09:51:53.087	debug	Pulse mode 3 parse result: {"name":"Power","value":272,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:53.087	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:53.087	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:53.086	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:53.086	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:53.086	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:53.086	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:53.086	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:53.086	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:51.044	debug	Attempting to reconnect to TibberFeed in 8sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:51.038	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:51.038: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 80 01 09:51:51.038: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 80 01 09:51:51.038: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:51.038: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:51.038: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:51.038: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:51.038: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 00 01
    tibberlink.0
    2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Power","value":256,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:51.037	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:51.037	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:49.088	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:49.087: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 80 01 09:51:49.087: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 80 01 09:51:49.087: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:49.087: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:49.087: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:49.088: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:49.088: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 00 01
    tibberlink.0
    2024-12-10 09:51:49.088	debug	Pulse mode 3 parse result: {"name":"Power","value":256,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:49.087	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:49.087	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:49.087	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:49.087	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:49.087	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:49.087	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:49.087	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:49.086	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:48.611	debug	Attempting to reconnect to TibberFeed in 6sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:48.611	debug	A feed was disconnected. I try to to reconnect with incremental delay - Error text sent by Tibber: Disconnected from Tibber feed.
    tibberlink.0
    2024-12-10 09:51:48.610	warn	Error on Tibber feed: Unknown error
    tibberlink.0
    2024-12-10 09:51:48.564	debug	Tibber feed connected: Connected to Tibber feed.
    tibberlink.0
    2024-12-10 09:51:47.971	debug	Attempting to reconnect to TibberFeed in 30sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:47.049	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:47.048: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 7d 01 09:51:47.049: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 7d 01 09:51:47.049: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:47.049: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:47.049: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:47.049: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:47.049: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 05 01
    tibberlink.0
    2024-12-10 09:51:47.049	debug	Pulse mode 3 parse result: {"name":"Power","value":261,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:47.049	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:47.049	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:47.049	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:47.049	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:47.048	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:47.048	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:47.048	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:47.048	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:45.096	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:45.095: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 7c 01 09:51:45.096: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 7c 01 09:51:45.096: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:45.096: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:45.096: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:45.096: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:45.096: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 fa 01
    tibberlink.0
    2024-12-10 09:51:45.096	debug	Pulse mode 3 parse result: {"name":"Power","value":250,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:45.096	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:45.096	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:45.096	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:45.096	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:45.095	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:45.095	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:45.095	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:45.095	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:43.840	debug	Attempting to reconnect to TibberFeed in 28sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:43.046	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:43.045: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 7c 01 09:51:43.045: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 7c 01 09:51:43.045: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:43.046: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:43.046: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:43.046: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:43.046: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 fa 01
    tibberlink.0
    2024-12-10 09:51:43.046	debug	Pulse mode 3 parse result: {"name":"Power","value":250,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:43.046	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:43.046	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:43.045	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:43.045	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:43.045	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:43.045	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:43.045	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:43.045	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:41.106	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:41.105: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 79 01 09:51:41.105: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 79 01 09:51:41.105: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:41.106: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:41.106: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:41.106: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:41.106: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 fc 01
    tibberlink.0
    2024-12-10 09:51:41.106	debug	Pulse mode 3 parse result: {"name":"Power","value":252,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:41.106	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:41.106	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:41.105	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:41.105	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:41.105	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:41.105	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:41.105	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:41.105	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:41.065	debug	Attempting to reconnect to TibberFeed in 26sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:39.061	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:39.061: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 77 01 09:51:39.061: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 77 01 09:51:39.061: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:39.061: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:39.061: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:39.061: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:39.061: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 05 01
    tibberlink.0
    2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Power","value":261,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:39.060	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:39.060	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:38.253	debug	Attempting to reconnect to TibberFeed in 24sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:37.125	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:37.125: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 77 01 09:51:37.125: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 77 01 09:51:37.125: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:37.125: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:37.125: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:37.125: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:37.125: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 05 01
    tibberlink.0
    2024-12-10 09:51:37.125	debug	Pulse mode 3 parse result: {"name":"Power","value":261,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:37.125	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:37.125	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:37.125	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:37.125	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:37.125	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:37.124	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:37.124	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:37.124	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:35.073	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:35.072: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 75 01 09:51:35.072: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 75 01 09:51:35.072: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:35.072: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:35.072: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:35.073: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:35.073: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 f7 01
    tibberlink.0
    2024-12-10 09:51:35.073	debug	Pulse mode 3 parse result: {"name":"Power","value":247,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:35.072	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:35.072	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:35.072	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:35.072	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:35.072	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:35.072	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:35.072	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:35.071	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:34.526	debug	Attempting to reconnect to TibberFeed in 22sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:33.118	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:33.117: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 73 01 09:51:33.117: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 73 01 09:51:33.117: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:33.117: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:33.118: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:33.118: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:33.118: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 09 01
    tibberlink.0
    2024-12-10 09:51:33.118	debug	Pulse mode 3 parse result: {"name":"Power","value":265,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:33.118	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:33.117	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:33.117	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:33.117	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:33.117	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:33.117	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:33.117	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:33.116	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:31.068	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:31.068: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 73 01 09:51:31.068: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 73 01 09:51:31.068: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:31.068: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:31.068: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:31.068: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:31.068: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 09 01
    tibberlink.0
    2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Power","value":265,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:31.067	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:31.067	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:31.045	debug	Attempting to reconnect to TibberFeed in 20sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:30.047	debug	Polled local Tibber Bridge metrics: {"type":"node_status","node_status":{"product_id":49344,"bootloader_version":17563650,"meter_mode":3,"node_battery_voltage":3.47,"node_temperature":18.354,"node_avg_rssi":-37.998,"node_avg_lqi":197.206,"radio_tx_power":0,"node_uptime_ms":3518711083,"meter_msg_count_sent":98,"meter_pkg_count_sent":136,"time_in_em0_ms":4627,"time_in_em1_ms":33,"time_in_em2_ms":295492,"acmp_rx_autolevel_9600":167,"invalid_meter_readings_count":0},"hub_attachments":{"meter_pkg_count_recv":136,"meter_reading_count_recv":98,"meter_corrupt_reading_count_recv":0,"compression_error_readings_count":0,"node_version":"1172-e5b13c4f"}}
    tibberlink.0
    2024-12-10 09:51:29.971	debug	Attempting to reconnect to TibberFeed in 18sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:29.019	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:29.018: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 70 01 09:51:29.018: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 70 01 09:51:29.018: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:29.018: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:29.019: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:29.019: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:29.019: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 0d 01
    tibberlink.0
    2024-12-10 09:51:29.019	debug	Pulse mode 3 parse result: {"name":"Power","value":269,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:29.019	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:29.019	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:29.018	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:29.018	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:29.018	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:29.018	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:29.018	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:29.018	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:27.840	debug	Attempting to reconnect to TibberFeed in 16sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:27.077	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:27.076: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6f 01 09:51:27.076: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6f 01 09:51:27.076: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:27.076: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:27.076: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:27.076: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:27.077: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 12 01
    tibberlink.0
    2024-12-10 09:51:27.077	debug	Pulse mode 3 parse result: {"name":"Power","value":274,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:27.076	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:27.076	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:27.076	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:27.076	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:27.076	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:27.076	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:27.076	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:27.075	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:27.064	debug	Attempting to reconnect to TibberFeed in 14sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:26.251	debug	Attempting to reconnect to TibberFeed in 12sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:25.024	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:25.023: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6f 01 09:51:25.023: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6f 01 09:51:25.024: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:25.024: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:25.024: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:25.024: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:25.024: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 12 01
    tibberlink.0
    2024-12-10 09:51:25.024	debug	Pulse mode 3 parse result: {"name":"Power","value":274,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:25.024	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:25.024	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:25.024	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:25.024	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:25.023	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:25.023	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:25.023	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:25.023	debug	got HEX data from local pulse: 1b1b1b1b0101010176051480d43762006200726301017601010506d59c130b090149534b000449219c0101639ad50076051480d438620062007263070177010b090149534b000449219c070100620affff72620165093674e47a77078181c78203ff010101010449534b0177070100000009ff010101010b090149534b000449219c0177070100010800ff650001018201621e52ff59000000000ab8d06f0177070100010801ff0101621e52ff59000000000ab8d06f0177070100010802ff0101621e52ff5900000000000000000177070100020800ff0101621e52ff59000000000ead48410177070100020801ff0101621e52ff59000000000ead48410177070100020802ff0101621e52ff5900000000000000000177070100100700ff0101621b520055000001120177078181c78205ff010101018302d932dc60b4775ca1128ee60bd3332a5d77b444d97e5aceb7e68220a4e13056715fcaeb4c08206146127348a59b542f4801010163f33d0076051480d43962006200726302017101632d68001b1b1b1b1a0036ea
    tibberlink.0
    2024-12-10 09:51:25.024	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:25.023: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6f 0109:51:25.023: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6f 0109:51:25.024: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 0109:51:25.024: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 0109:51:25.024: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 0109:51:25.024: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 0109:51:25.024: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 12 01
    tibberlink.0
    tibberlink.0
    tibberlink.0
    tibberlink.0
    tibberlink.0
    tibberlink.0
    tibberlink.0
    tibberlink.0
    tibberlink.0
    tibberlink.0
    2024-12-10 09:51:24.526	debug	Attempting to reconnect to TibberFeed in 10sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:23.078	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:23.077: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6c 0109:51:23.077: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6c 0109:51:23.077: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 0109:51:23.078: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 0109:51:23.078: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 0109:51:23.078: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 0109:51:23.078: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 10 01
    tibberlink.0
    2024-12-10 09:51:23.078	debug	Pulse mode 3 parse result: {"name":"Power","value":272,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:23.078	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:23.078	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:23.078	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:23.077	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:23.077	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:23.077	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:23.077	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:23.077	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:23.045	debug	Attempting to reconnect to TibberFeed in 8sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:21.032	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:21.031: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6a 0109:51:21.032: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6a 0109:51:21.032: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 0109:51:21.032: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 0109:51:21.032: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 0109:51:21.032: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 0109:51:21.032: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 fa 01
    tibberlink.0
    2024-12-10 09:51:21.032	debug	Pulse mode 3 parse result: {"name":"Power","value":250,"unit":"W"}
    tibberlink.0
    2024-12-10 09:51:21.032	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:21.032	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:21.032	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:21.032	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:21.031	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:21.031	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
    tibberlink.0
    2024-12-10 09:51:21.031	debug	trying to parse meter mode 3
    tibberlink.0
    2024-12-10 09:51:21.031	debug	got HEX data from local pulse: 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
    tibberlink.0
    2024-12-10 09:51:20.251	debug	Attempting to reconnect to TibberFeed in 6sec interval - (of max. 900sec)
    tibberlink.0
    2024-12-10 09:51:20.251	debug	A feed was disconnected. I try to to reconnect with incremental delay - Error text sent by Tibber: Disconnected from Tibber feed.
    tibberlink.0
    2024-12-10 09:51:20.250	warn	Error on Tibber feed: Unknown error
    tibberlink.0
    2024-12-10 09:51:20.151	debug	Tibber feed connected: Connected to Tibber feed.
    Beta-Tester
    R 1 Antwort Letzte Antwort
    • Merlin123M Merlin123
      @reblausgt so... Eben wieder 9:50, 9:51, 9:52
      Im Log sieht das so aus:
      tibberlink.0
      2024-12-10 09:52:31.077	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:31.077: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 9d 01 09:52:31.077: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 9d 01 09:52:31.077: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:31.077: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:31.077: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:31.077: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:31.077: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 00 01
      tibberlink.0
      2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Power","value":256,"unit":"W"}
      tibberlink.0
      2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:31.077	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:31.076	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:31.076	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:52:30.529	debug	Attempting to reconnect to TibberFeed in 36sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:52:30.158	debug	Polled local Tibber Bridge metrics: {"type":"node_status","node_status":{"product_id":49344,"bootloader_version":17563650,"meter_mode":3,"node_battery_voltage":3.469,"node_temperature":18.354,"node_avg_rssi":-37.999,"node_avg_lqi":197.511,"radio_tx_power":0,"node_uptime_ms":3519011234,"meter_msg_count_sent":98,"meter_pkg_count_sent":138,"time_in_em0_ms":4669,"time_in_em1_ms":35,"time_in_em2_ms":295447,"acmp_rx_autolevel_9600":167,"invalid_meter_readings_count":0},"hub_attachments":{"meter_pkg_count_recv":140,"meter_reading_count_recv":95,"meter_corrupt_reading_count_recv":5,"compression_error_readings_count":4,"node_version":"1172-e5b13c4f"}}
      tibberlink.0
      2024-12-10 09:52:29.044	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:29.043: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 9d 01 09:52:29.043: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 9d 01 09:52:29.043: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:29.044: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:29.044: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:29.044: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:29.044: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 00 01
      tibberlink.0
      2024-12-10 09:52:29.044	debug	Pulse mode 3 parse result: {"name":"Power","value":256,"unit":"W"}
      tibberlink.0
      2024-12-10 09:52:29.044	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:29.044	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:29.044	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:29.043	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:29.043	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:29.043	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:29.043	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:29.043	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:52:27.085	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:27.084: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 9b 01 09:52:27.084: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 9b 01 09:52:27.084: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:27.084: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:27.085: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:27.085: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:27.085: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 f0 01
      tibberlink.0
      2024-12-10 09:52:27.085	debug	Pulse mode 3 parse result: {"name":"Power","value":240,"unit":"W"}
      tibberlink.0
      2024-12-10 09:52:27.085	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:27.085	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:27.084	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:27.084	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:27.084	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:27.084	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:27.084	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:27.084	debug	got HEX data from local pulse: 1b1b1b1b0101010176051480d4bb62006200726301017601010506d59c3f0b090149534b000449219c0101632a180076051480d4bc620062007263070177010b090149534b000449219c070100620affff72620165093675217a77078181c78203ff010101010449534b0177070100000009ff010101010b090149534b000449219c0177070100010800ff650001018201621e52ff59000000000ab8d09b0177070100010801ff0101621e52ff59000000000ab8d09b0177070100010802ff0101621e52ff5900000000000000000177070100020800ff0101621e52ff59000000000ead48410177070100020801ff0101621e52ff59000000000ead48410177070100020802ff0101621e52ff5900000000000000000177070100100700ff0101621b520055000000f00177078181c78205ff010101018302d932dc60b4775ca1128ee60bd3332a5d77b444d97e5aceb7e68220a4e13056715fcaeb4c08206146127348a59b542f4801010163fee20076051480d4bd620062007263020171016363a4001b1b1b1b1a00ede6
      tibberlink.0
      2024-12-10 09:52:27.065	debug	Attempting to reconnect to TibberFeed in 34sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:52:25.040	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:25.039: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 99 01 09:52:25.039: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 99 01 09:52:25.039: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:25.040: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:25.040: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:25.040: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:25.040: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 f3 01
      tibberlink.0
      2024-12-10 09:52:25.040	debug	Pulse mode 3 parse result: {"name":"Power","value":243,"unit":"W"}
      tibberlink.0
      2024-12-10 09:52:25.040	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:25.040	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:25.040	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:25.039	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:25.039	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:25.039	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:25.039	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:25.039	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:52:23.026	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:23.025: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 99 01 09:52:23.026: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 99 01 09:52:23.026: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:23.026: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:23.026: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:23.026: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:23.026: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 f3 01
      tibberlink.0
      2024-12-10 09:52:23.026	debug	Pulse mode 3 parse result: {"name":"Power","value":243,"unit":"W"}
      tibberlink.0
      2024-12-10 09:52:23.026	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:23.026	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:23.026	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:23.026	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:23.025	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:23.025	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:23.025	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:23.025	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:52:22.613	debug	Attempting to reconnect to TibberFeed in 32sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:52:21.045	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:21.044	debug	got HEX data from local pulse:
      tibberlink.0
      2024-12-10 09:52:19.093	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:19.093	debug	got HEX data from local pulse:
      tibberlink.0
      2024-12-10 09:52:18.253	debug	Attempting to reconnect to TibberFeed in 30sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:52:17.973	debug	Attempting to reconnect to TibberFeed in 28sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:52:17.047	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:17.046	debug	got HEX data from local pulse:
      tibberlink.0
      2024-12-10 09:52:15.098	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:15.098	debug	got HEX data from local pulse:
      tibberlink.0
      2024-12-10 09:52:13.054	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:13.054	debug	got HEX data from local pulse:
      tibberlink.0
      2024-12-10 09:52:13.046	debug	Attempting to reconnect to TibberFeed in 26sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:52:11.842	debug	Attempting to reconnect to TibberFeed in 24sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:52:11.106	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:11.106	debug	got HEX data from local pulse:
      tibberlink.0
      2024-12-10 09:52:09.057	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:09.056: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8e 01 09:52:09.056: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8e 01 09:52:09.056: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:09.056: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:09.057: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:09.057: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:09.057: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01
      tibberlink.0
      2024-12-10 09:52:09.057	debug	Pulse mode 3 parse result: {"name":"Power","value":0,"unit":"W"}
      tibberlink.0
      2024-12-10 09:52:09.057	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:09.057	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:09.056	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:09.056	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:09.056	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:09.056	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:09.056	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:09.056	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:52:08.529	debug	Attempting to reconnect to TibberFeed in 22sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:52:07.115	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:07.115: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8b 01 09:52:07.115: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8b 01 09:52:07.115: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:07.115: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:07.115: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:07.115: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:07.115: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 06 01
      tibberlink.0
      2024-12-10 09:52:07.115	debug	Pulse mode 3 parse result: {"name":"Power","value":262,"unit":"W"}
      tibberlink.0
      2024-12-10 09:52:07.115	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:07.115	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:07.115	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:07.115	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:07.115	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:07.114	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:07.114	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:07.114	debug	got HEX data from local pulse: 1b1b1b1b0101010176051480d48b62006200726301017601010506d59c2f0b090149534b000449219c010163cbef0076051480d48c620062007263070177010b090149534b000449219c070100620affff726201650936750b7a77078181c78203ff010101010449534b0177070100000009ff010101010b090149534b000449219c0177070100010800ff650001018201621e52ff59000000000ab8d08b0177070100010801ff0101621e52ff59000000000ab8d08b0177070100010802ff0101621e52ff5900000000000000000177070100020800ff0101621e52ff59000000000ead48410177070100020801ff0101621e52ff59000000000ead48410177070100020802ff0101621e52ff5900000000000000000177070100100700ff0101621b520055000001060177078181c78205ff010101018302d932dc60b4775ca1128ee60bd3332a5d77b444d97e5aceb7e68220a4e13056715fcaeb4c08206146127348a59b542f4801010163649f0076051480d48d6200620072630201710163ac37001b1b1b1b1a00e808
      tibberlink.0
      2024-12-10 09:52:07.065	debug	Attempting to reconnect to TibberFeed in 20sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:52:05.066	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:05.066: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8b 01 09:52:05.066: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8b 01 09:52:05.066: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:05.066: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:05.066: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:05.066: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:05.066: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 06 01
      tibberlink.0
      2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Power","value":262,"unit":"W"}
      tibberlink.0
      2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:05.066	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:05.065	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:05.065	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:52:04.613	debug	Attempting to reconnect to TibberFeed in 18sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:52:03.121	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:03.120: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8a 01 09:52:03.121: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 8a 01 09:52:03.121: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:03.121: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:03.121: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:03.121: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:03.121: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 03 01
      tibberlink.0
      2024-12-10 09:52:03.121	debug	Pulse mode 3 parse result: {"name":"Power","value":259,"unit":"W"}
      tibberlink.0
      2024-12-10 09:52:03.121	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:03.121	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:03.121	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:03.121	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:03.120	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:03.120	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:03.120	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:03.120	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:52:02.253	debug	Attempting to reconnect to TibberFeed in 16sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:52:01.073	debug	Format for https://tasmota-sml-parser.dicp.net : 09:52:01.073: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 87 01 09:52:01.073: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 87 01 09:52:01.073: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:01.073: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:01.073: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:52:01.073: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:52:01.073: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 f6 01
      tibberlink.0
      2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Power","value":246,"unit":"W"}
      tibberlink.0
      2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:01.073	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:52:01.072	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:52:01.072	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:59.045	debug	Attempting to reconnect to TibberFeed in 14sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:59.031	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:59.030: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 87 01 09:51:59.030: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 87 01 09:51:59.030: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:59.030: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:59.030: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:59.030: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:59.031: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 f6 01
      tibberlink.0
      2024-12-10 09:51:59.031	debug	Pulse mode 3 parse result: {"name":"Power","value":246,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:59.030	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:59.030	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:59.030	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:59.030	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:59.030	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:59.030	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:59.030	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:59.029	debug	got HEX data from local pulse: 1b1b1b1b0101010176051480d47f62006200726301017601010506d59c2b0b090149534b000449219c010163503a0076051480d480620062007263070177010b090149534b000449219c070100620affff72620165093675057a77078181c78203ff010101010449534b0177070100000009ff010101010b090149534b000449219c0177070100010800ff650001018201621e52ff59000000000ab8d0870177070100010801ff0101621e52ff59000000000ab8d0870177070100010802ff0101621e52ff5900000000000000000177070100020800ff0101621e52ff59000000000ead48410177070100020801ff0101621e52ff59000000000ead48410177070100020802ff0101621e52ff5900000000000000000177070100100700ff0101621b520055000000f60177078181c78205ff010101018302d932dc60b4775ca1128ee60bd3332a5d77b444d97e5aceb7e68220a4e13056715fcaeb4c08206146127348a59b542f480101016391aa0076051480d481620062007263020171016353d5001b1b1b1b1a000d71
      tibberlink.0
      2024-12-10 09:51:57.084	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:57.084: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 84 01 09:51:57.084: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 84 01 09:51:57.084: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:57.084: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:57.084: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:57.084: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:57.084: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 00 01
      tibberlink.0
      2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Power","value":256,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:57.084	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:57.084	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:57.083	debug	got HEX data from local pulse: 1b1b1b1b0101010176051480d47662006200726301017601010506d59c280b090149534b000449219c01016314960076051480d477620062007263070177010b090149534b000449219c070100620affff72620165093675017a77078181c78203ff010101010449534b0177070100000009ff010101010b090149534b000449219c0177070100010800ff650001018201621e52ff59000000000ab8d0840177070100010801ff0101621e52ff59000000000ab8d0840177070100010802ff0101621e52ff5900000000000000000177070100020800ff0101621e52ff59000000000ead48410177070100020801ff0101621e52ff59000000000ead48410177070100020802ff0101621e52ff5900000000000000000177070100100700ff0101621b520055000001000177078181c78205ff010101018302d932dc60b4775ca1128ee60bd3332a5d77b444d97e5aceb7e68220a4e13056715fcaeb4c08206146127348a59b542f4801010163922a0076051480d4786200620072630201710163b9f0001b1b1b1b1a001498
      tibberlink.0
      2024-12-10 09:51:56.527	debug	Attempting to reconnect to TibberFeed in 12sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:55.136	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:55.136: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 84 01 09:51:55.136: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 84 01 09:51:55.136: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:55.136: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:55.136: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:55.136: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:55.136: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 00 01
      tibberlink.0
      2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Power","value":256,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:55.136	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:55.135	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:55.135	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:54.612	debug	Attempting to reconnect to TibberFeed in 10sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:53.087	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:53.086: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 83 01 09:51:53.086: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 83 01 09:51:53.086: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:53.087: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:53.087: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:53.087: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:53.087: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 10 01
      tibberlink.0
      2024-12-10 09:51:53.087	debug	Pulse mode 3 parse result: {"name":"Power","value":272,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:53.087	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:53.087	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:53.086	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:53.086	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:53.086	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:53.086	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:53.086	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:53.086	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:51.044	debug	Attempting to reconnect to TibberFeed in 8sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:51.038	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:51.038: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 80 01 09:51:51.038: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 80 01 09:51:51.038: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:51.038: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:51.038: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:51.038: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:51.038: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 00 01
      tibberlink.0
      2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Power","value":256,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:51.038	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:51.037	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:51.037	debug	got HEX data from local pulse: 1b1b1b1b0101010176051480d46a62006200726301017601010506d59c240b090149534b000449219c01016399190076051480d46b620062007263070177010b090149534b000449219c070100620affff72620165093674fb7a77078181c78203ff010101010449534b0177070100000009ff010101010b090149534b000449219c0177070100010800ff650001018201621e52ff59000000000ab8d0800177070100010801ff0101621e52ff59000000000ab8d0800177070100010802ff0101621e52ff5900000000000000000177070100020800ff0101621e52ff59000000000ead48410177070100020801ff0101621e52ff59000000000ead48410177070100020802ff0101621e52ff5900000000000000000177070100100700ff0101621b520055000001000177078181c78205ff010101018302d932dc60b4775ca1128ee60bd3332a5d77b444d97e5aceb7e68220a4e13056715fcaeb4c08206146127348a59b542f4801010163dacb0076051480d46c6200620072630201710163a9df001b1b1b1b1a000b21
      tibberlink.0
      2024-12-10 09:51:49.088	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:49.087: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 80 01 09:51:49.087: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 80 01 09:51:49.087: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:49.087: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:49.087: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:49.088: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:49.088: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 00 01
      tibberlink.0
      2024-12-10 09:51:49.088	debug	Pulse mode 3 parse result: {"name":"Power","value":256,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:49.087	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:49.087	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:49.087	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:49.087	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:49.087	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:49.087	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:49.087	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:49.086	debug	got HEX data from local pulse: 1b1b1b1b0101010176051480d46a62006200726301017601010506d59c240b090149534b000449219c01016399190076051480d46b620062007263070177010b090149534b000449219c070100620affff72620165093674fb7a77078181c78203ff010101010449534b0177070100000009ff010101010b090149534b000449219c0177070100010800ff650001018201621e52ff59000000000ab8d0800177070100010801ff0101621e52ff59000000000ab8d0800177070100010802ff0101621e52ff5900000000000000000177070100020800ff0101621e52ff59000000000ead48410177070100020801ff0101621e52ff59000000000ead48410177070100020802ff0101621e52ff5900000000000000000177070100100700ff0101621b520055000001000177078181c78205ff010101018302d932dc60b4775ca1128ee60bd3332a5d77b444d97e5aceb7e68220a4e13056715fcaeb4c08206146127348a59b542f4801010163dacb0076051480d46c6200620072630201710163a9df001b1b1b1b1a000b21
      tibberlink.0
      2024-12-10 09:51:48.611	debug	Attempting to reconnect to TibberFeed in 6sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:48.611	debug	A feed was disconnected. I try to to reconnect with incremental delay - Error text sent by Tibber: Disconnected from Tibber feed.
      tibberlink.0
      2024-12-10 09:51:48.610	warn	Error on Tibber feed: Unknown error
      tibberlink.0
      2024-12-10 09:51:48.564	debug	Tibber feed connected: Connected to Tibber feed.
      tibberlink.0
      2024-12-10 09:51:47.971	debug	Attempting to reconnect to TibberFeed in 30sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:47.049	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:47.048: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 7d 01 09:51:47.049: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 7d 01 09:51:47.049: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:47.049: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:47.049: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:47.049: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:47.049: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 05 01
      tibberlink.0
      2024-12-10 09:51:47.049	debug	Pulse mode 3 parse result: {"name":"Power","value":261,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:47.049	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:47.049	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:47.049	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:47.049	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:47.048	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:47.048	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:47.048	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:47.048	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:45.096	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:45.095: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 7c 01 09:51:45.096: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 7c 01 09:51:45.096: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:45.096: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:45.096: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:45.096: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:45.096: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 fa 01
      tibberlink.0
      2024-12-10 09:51:45.096	debug	Pulse mode 3 parse result: {"name":"Power","value":250,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:45.096	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:45.096	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:45.096	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:45.096	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:45.095	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:45.095	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:45.095	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:45.095	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:43.840	debug	Attempting to reconnect to TibberFeed in 28sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:43.046	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:43.045: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 7c 01 09:51:43.045: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 7c 01 09:51:43.045: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:43.046: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:43.046: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:43.046: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:43.046: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 fa 01
      tibberlink.0
      2024-12-10 09:51:43.046	debug	Pulse mode 3 parse result: {"name":"Power","value":250,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:43.046	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:43.046	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:43.045	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:43.045	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:43.045	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:43.045	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:43.045	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:43.045	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:41.106	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:41.105: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 79 01 09:51:41.105: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 79 01 09:51:41.105: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:41.106: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:41.106: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:41.106: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:41.106: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 fc 01
      tibberlink.0
      2024-12-10 09:51:41.106	debug	Pulse mode 3 parse result: {"name":"Power","value":252,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:41.106	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:41.106	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:41.105	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:41.105	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:41.105	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:41.105	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:41.105	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:41.105	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:41.065	debug	Attempting to reconnect to TibberFeed in 26sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:39.061	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:39.061: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 77 01 09:51:39.061: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 77 01 09:51:39.061: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:39.061: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:39.061: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:39.061: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:39.061: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 05 01
      tibberlink.0
      2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Power","value":261,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:39.061	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:39.060	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:39.060	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:38.253	debug	Attempting to reconnect to TibberFeed in 24sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:37.125	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:37.125: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 77 01 09:51:37.125: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 77 01 09:51:37.125: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:37.125: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:37.125: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:37.125: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:37.125: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 05 01
      tibberlink.0
      2024-12-10 09:51:37.125	debug	Pulse mode 3 parse result: {"name":"Power","value":261,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:37.125	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:37.125	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:37.125	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:37.125	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:37.125	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:37.124	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.42,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:37.124	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:37.124	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:35.073	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:35.072: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 75 01 09:51:35.072: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 75 01 09:51:35.072: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:35.072: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:35.072: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:35.073: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:35.073: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 f7 01
      tibberlink.0
      2024-12-10 09:51:35.073	debug	Pulse mode 3 parse result: {"name":"Power","value":247,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:35.072	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:35.072	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:35.072	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:35.072	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:35.072	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:35.072	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:35.072	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:35.071	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:34.526	debug	Attempting to reconnect to TibberFeed in 22sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:33.118	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:33.117: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 73 01 09:51:33.117: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 73 01 09:51:33.117: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:33.117: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:33.118: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:33.118: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:33.118: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 09 01
      tibberlink.0
      2024-12-10 09:51:33.118	debug	Pulse mode 3 parse result: {"name":"Power","value":265,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:33.118	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:33.117	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:33.117	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:33.117	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:33.117	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:33.117	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:33.117	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:33.116	debug	got HEX data from local pulse: 1b1b1b1b0101010176051480d44362006200726301017601010506d59c170b090149534b000449219c01016391f80076051480d444620062007263070177010b090149534b000449219c070100620affff72620165093674e97a77078181c78203ff010101010449534b0177070100000009ff010101010b090149534b000449219c0177070100010800ff650001018201621e52ff59000000000ab8d0730177070100010801ff0101621e52ff59000000000ab8d0730177070100010802ff0101621e52ff5900000000000000000177070100020800ff0101621e52ff59000000000ead48410177070100020801ff0101621e52ff59000000000ead48410177070100020802ff0101621e52ff5900000000000000000177070100100700ff0101621b520055000001090177078181c78205ff010101018302d932dc60b4775ca1128ee60bd3332a5d77b444d97e5aceb7e68220a4e13056715fcaeb4c08206146127348a59b542f48010101630c760076051480d445620062007263020171016318d4001b1b1b1b1a007d6b
      tibberlink.0
      2024-12-10 09:51:31.068	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:31.068: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 73 01 09:51:31.068: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 73 01 09:51:31.068: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:31.068: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:31.068: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:31.068: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:31.068: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 09 01
      tibberlink.0
      2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Power","value":265,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:31.068	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:31.067	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:31.067	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:31.045	debug	Attempting to reconnect to TibberFeed in 20sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:30.047	debug	Polled local Tibber Bridge metrics: {"type":"node_status","node_status":{"product_id":49344,"bootloader_version":17563650,"meter_mode":3,"node_battery_voltage":3.47,"node_temperature":18.354,"node_avg_rssi":-37.998,"node_avg_lqi":197.206,"radio_tx_power":0,"node_uptime_ms":3518711083,"meter_msg_count_sent":98,"meter_pkg_count_sent":136,"time_in_em0_ms":4627,"time_in_em1_ms":33,"time_in_em2_ms":295492,"acmp_rx_autolevel_9600":167,"invalid_meter_readings_count":0},"hub_attachments":{"meter_pkg_count_recv":136,"meter_reading_count_recv":98,"meter_corrupt_reading_count_recv":0,"compression_error_readings_count":0,"node_version":"1172-e5b13c4f"}}
      tibberlink.0
      2024-12-10 09:51:29.971	debug	Attempting to reconnect to TibberFeed in 18sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:29.019	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:29.018: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 70 01 09:51:29.018: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 70 01 09:51:29.018: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:29.018: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:29.019: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:29.019: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:29.019: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 0d 01
      tibberlink.0
      2024-12-10 09:51:29.019	debug	Pulse mode 3 parse result: {"name":"Power","value":269,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:29.019	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:29.019	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:29.018	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:29.018	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:29.018	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:29.018	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:29.018	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:29.018	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:27.840	debug	Attempting to reconnect to TibberFeed in 16sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:27.077	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:27.076: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6f 01 09:51:27.076: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6f 01 09:51:27.076: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:27.076: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:27.076: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:27.076: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:27.077: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 12 01
      tibberlink.0
      2024-12-10 09:51:27.077	debug	Pulse mode 3 parse result: {"name":"Power","value":274,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:27.076	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:27.076	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:27.076	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:27.076	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:27.076	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:27.076	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:27.076	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:27.075	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:27.064	debug	Attempting to reconnect to TibberFeed in 14sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:26.251	debug	Attempting to reconnect to TibberFeed in 12sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:25.024	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:25.023: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6f 01 09:51:25.023: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6f 01 09:51:25.024: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:25.024: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:25.024: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 01 09:51:25.024: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 09:51:25.024: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 12 01
      tibberlink.0
      2024-12-10 09:51:25.024	debug	Pulse mode 3 parse result: {"name":"Power","value":274,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:25.024	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:25.024	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:25.024	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:25.024	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:25.023	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:25.023	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:25.023	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:25.023	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:25.024	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:25.023: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6f 0109:51:25.023: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6f 0109:51:25.024: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 0109:51:25.024: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 0109:51:25.024: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 0109:51:25.024: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 0109:51:25.024: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 12 01
      tibberlink.0
      tibberlink.0
      tibberlink.0
      tibberlink.0
      tibberlink.0
      tibberlink.0
      tibberlink.0
      tibberlink.0
      tibberlink.0
      tibberlink.0
      2024-12-10 09:51:24.526	debug	Attempting to reconnect to TibberFeed in 10sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:23.078	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:23.077: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6c 0109:51:23.077: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6c 0109:51:23.077: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 0109:51:23.078: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 0109:51:23.078: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 0109:51:23.078: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 0109:51:23.078: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 01 10 01
      tibberlink.0
      2024-12-10 09:51:23.078	debug	Pulse mode 3 parse result: {"name":"Power","value":272,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:23.078	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:23.078	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:23.078	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:23.077	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:23.077	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:23.077	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:23.077	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:23.077	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:23.045	debug	Attempting to reconnect to TibberFeed in 8sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:21.032	debug	Format for https://tasmota-sml-parser.dicp.net : 09:51:21.031: 77 07 01 00 01 08 00 ff 65 00 01 01 82 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6a 0109:51:21.032: 77 07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0a b8 d0 6a 0109:51:21.032: 77 07 01 00 01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 0109:51:21.032: 77 07 01 00 02 08 00 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 0109:51:21.032: 77 07 01 00 02 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 0e ad 48 41 0109:51:21.032: 77 07 01 00 02 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 0109:51:21.032: 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 55 00 00 00 fa 01
      tibberlink.0
      2024-12-10 09:51:21.032	debug	Pulse mode 3 parse result: {"name":"Power","value":250,"unit":"W"}
      tibberlink.0
      2024-12-10 09:51:21.032	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:21.032	debug	Pulse mode 3 parse result: {"name":"Export_total_tarif_1","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:21.032	debug	Pulse mode 3 parse result: {"name":"Export_total","value":24623.72,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:21.032	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_2","value":0,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:21.031	debug	Pulse mode 3 parse result: {"name":"Import_total_tarif_1","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:21.031	debug	Pulse mode 3 parse result: {"name":"Import_total","value":17988.41,"unit":"kWh"}
      tibberlink.0
      2024-12-10 09:51:21.031	debug	trying to parse meter mode 3
      tibberlink.0
      2024-12-10 09:51:21.031	debug	got HEX data from local pulse: 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
      tibberlink.0
      2024-12-10 09:51:20.251	debug	Attempting to reconnect to TibberFeed in 6sec interval - (of max. 900sec)
      tibberlink.0
      2024-12-10 09:51:20.251	debug	A feed was disconnected. I try to to reconnect with incremental delay - Error text sent by Tibber: Disconnected from Tibber feed.
      tibberlink.0
      2024-12-10 09:51:20.250	warn	Error on Tibber feed: Unknown error
      tibberlink.0
      2024-12-10 09:51:20.151	debug	Tibber feed connected: Connected to Tibber feed.
      ReblausGT
      #366
      @merlin123 said in TibberLink Adapter:
      09:51:48 hast du auch einen Übergang auf False und wieder True bei tibberlink.0.info.connection??
      Merlin123M 1 Antwort Letzte Antwort
      • R ReblausGT
        Merlin123M Offline
        Merlin123M Offline
        Merlin123
        schrieb am zuletzt editiert von Merlin123
        #367
        @reblausgt Hatte das sogar viermal seh ich gerade. Hab ein Blockly, das mich benachrichtigt, wenn die Verbindung weg ist oder wieder kommt.
        Hab das leider nicht auf die Sekunde genau, aber könnte dann schon sein, dass das eine 9:51:48 war
        Beta-Tester
        R 1 Antwort Letzte Antwort
        • Merlin123M Merlin123
          ReblausGT
          #368
          @merlin123 Äh... die Meldung im Log meckert über die Verbindung zum Tibber Server... Dein Blockly spricht von der Tibber Bridge - das sind 2 Paar Stiefel und hat nicht wirklich was miteinander zu tun. ?!!?
          • R ReblausGT
            Merlin123M Offline
            Merlin123M Offline
            Merlin123
            #369
            @reblausgt Mein Blockly sagt nur, was ich es schicken lasse.... Die Formulierung ist da wohl nicht korrekt ;) Ich schicke mir da nur die Info, wie der DP tibberlink.0.info.connection aussieht. Bei true den einen Text, bei false den anderen
            Beta-Tester
            • Merlin123M Offline
              Merlin123M Offline
              Merlin123
              #370
              Mal noch ne ganz andere Frage:
              Hat jemand eine Lösung, wie man sich seinen aktuellen persönlichen Durchschnittspreis für den aktuellen Monat berechnen kann? Direkt aus dem Adapter bekomme ich die Infos ja nicht.
              Muss auch nicht 100% stimmen (wegen den Fixkosten pro Monat, die ja immer etwas schwanken), aber so ca.
              Beta-Tester
                arteckA Offline
                arteckA Offline
                arteck
                #371
                @merlin123 jag die Daten in die influx und mach es von da aus.. rechnen musst du ehh selber
                  ReblausGT
                  #372
                  tibberlink.0.info.connection ist ein offizieller state den der Adapter haben sollte.... eigentlich eine gute Sache, aber bei der Sicherheit mit der der Tibber Server korrekt arbeitet macht das IMHO keine großen Sinn das zu benutzen. Da bräuchte man dann eher einen State der einen durchschnittliche Ausfallzeit darstellt.
                  • arteckA arteck
                    Merlin123M Offline
                    Merlin123M Offline
                    Merlin123
                    #373
                    @arteck hmmm... müsste ich mal schauen, was ich da speichern müsste und wie ich das berechnen kann.....
                    Beta-Tester
                    • R ReblausGT
                      Merlin123M Offline
                      Merlin123M Offline
                      Merlin123
                      #374
                      @reblausgt Hab ich sonst eine Möglichkeit zu sehen, ob die Bridge Daten an den Server sendet?
                      Beta-Tester
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #375
                        @merlin123 sagte in TibberLink Adapter:
                        wireshark
                        • arteckA arteck
                          wireshark
                          Merlin123M Offline
                          Merlin123M Offline
                          Merlin123
                          #376
                          @arteck OK... Die Hardcorevariante ;) Hatte gehofft, es gäbe was, das eh schon in iobroker ist
                          Beta-Tester
                            ReblausGT
                            #377
                            Hat arteck schon recht.... evtl. kann es dein Router... sprich ausgehender Datenstrom mit "gleichmäßigem" Volumen.
                            • R ReblausGT
                              Merlin123M Offline
                              Merlin123M Offline
                              Merlin123
                              #378
                              @reblausgt ich hatte einfach gehofft, dass man lokal aus der Bridge auslesen kann, ob sie eine Verbindung zum Server hat oder nicht :) Sie weiß es ja eigentlich.
                              Beta-Tester
                              • M BM Offline
                                M BM Offline
                                M B
                                #379
                                ich habe seit 2 Tagen das Problem, dass der Tibberlink Adapter nicht mehr verbindet. Ich habe die Fritzbox neu verbunden, dann reagiert die API kurz (auf dem Bild ist der demo token). Sobald ich aber den Adapter starte, kommen Netzwerkfehler und "no homes available".
                                Ich habe am Adapter selbst nichts verändert, daher weiß ich leider nicht wo die Ursache lag. Der Versuch eine andere Version zu installieren bracht auch nichts. Jetzt bin ich so weit und wollte euch mal um Hilfe bitten.
                                M Merlin123M 2 Antworten Letzte Antwort
                                • M BM M B
                                  M Online
                                  M Online
                                  MCU
                                  #380
                                  @m-b gelöscht
                                  • M BM M B
                                    Merlin123M Offline
                                    Merlin123M Offline
                                    Merlin123
                                    #381
                                    @m-b Schau mal in der App in Deinem Profil ob da ein "zuhause" definiert ist. Laut dem Kommentar von MCU scheint das zu fehlen.
                                    Beta-Tester
                                      ReblausGT
                                      #382
                                      @merlin123 Er nutzt den Demo Tocken.... da kann er in der App nichts sehen.
                                      @M-B Ich habe eine Test-Maschine laufen mit dem Demo Token.... das ist nicht so ungewöhnlich, der Demo Zugang ist sehr oft tot.
                                      • R ReblausGT
                                        ReblausGT
                                        #383
                                        ... heute z.B. habe ich bis 8:00 massig Fehler im Protokoll, ab da alles prima mit dem Demo Token
                                        • M BM Offline
                                          M BM Offline
                                          M B
                                          #384
                                          Das Problem ist gelöst!
                                          Ich hatte das gleiche Problem mit meinem richtigen Token, den wollte ich aber hier nicht veröffentlichen. Das Bild hat nur als Beispiel gedient.
                                          Zusätzlich zu Iobroker habe ich noch Evcc laufen, welcher auch Daten bei Tibber abfragt. Die hatten anscheinend das Timeoutintervall verändert und so kam es zum Problem. Evcc hat das direkt gefixt und jetzt läuft alles wieder.
                                          Vielen Dank für eure Mühe, schönen Sonntag!
