  4. Web Admin nicht mehr erreichbar
28 Beiträge 7 Kommentatoren 2.6k Aufrufe 4 Beobachtet
  • G gmt94
    Vielen Dank zunächst für Eure Unterstützung.
    Copy text starting here:
    ```bash
                            v.2024-09-21
       Static hostname: iobroker-pi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Kernel:                 armv7l
    Userland:               32 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Error: unknown repository is active - "live". Known: Stable (default), Beta (latest)
    Pending iob updates:    51
    Nodejs-Installation:
    nodejs:                 N/A
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    Recommended versions are nodejs  and npm
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please execute
    iob nodejs-update
    to fix these errors.
    MEMORY:
    Mem:           3.9G        220M        2.3G        8.0M        1.4G        3.6G
    Swap:           99M          0B         99M
    Total:         4.0G        220M        2.4G
    Active iob-Instances:   1
    Upgrade policy: none
    ioBroker Core:          js-controller           7.0.3
                            admin                   7.4.1
    ioBroker Status:        iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : iobroker-pi                              -  enabled, port: 9091, bind: 0.0.0.0, run as: admin
      system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.webuntis.0               : webuntis              : iobroker-pi                              - disabled
    Objects:                13888
    States:                 9726
    Size of iob-Database:
    21M     /opt/iobroker/iobroker-data/objects.jsonl
    2.6M    /opt/iobroker/iobroker-data/objects.json.migrated
    2.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    2.4M    /opt/iobroker/iobroker-data/states.jsonl
    16K     /opt/iobroker/iobroker-data/states.json.migrated
    16K     /opt/iobroker/iobroker-data/states.json.bak.migrated
    Debian Release codenamed 'buster' reached its END OF LIFE and needs to be updated to the latest stable release 'bookworm' NOW!
    === Mark text until here for copying ===
    pi@iobroker-pi:~ $ rl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
    -bash: rl: command not found
    pi@iobroker-pi:~ $ chmod 744 iob_diag.sh
    pi@iobroker-pi:~ $ ./iob_diag.shcurl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
    -bash: ./iob_diag.shcurl: No such file or directory
    pi@iobroker-pi:~ $
    @gmt94 sagte in Web Admin nicht mehr erreichbar:
    Dein Betriebssystem ist aber mausetot und muss neuinsttalliert werden.
    G 1 Antwort Letzte Antwort
      gmt94
      Ok, Mist, woran siehst du das?
      • G gmt94
        @gmt94
        An der Meldung, die ich zitiere...
        Und die auf deinem Bildschirm in ROT dargestellt werden sollte.
        • G Offline
          gmt94
          kann ich das Betriebssystem updaten ohne den IOB neu aufsetzen zu müssen?
          • G gmt94
            Nein.
            Deswegen: Auf dem Alt-System den ioBroker auf den aktuellstmöglichen Stand bringen (nodejs@18 auf dem ollen Buster), davon ein Backup ziehen, das aktuelle RaspberryOS 12 'Bookworm' installieren, ioBroker installieren, Backup einspielen, fertig.
            • G Offline
              gmt94
              Vielen Dank erstmal für deinen Support.
              Ein Backup ziehe ich mir zum Glück täglich auf meine NAS. Dann werde ich das mal neu aufsetzen. Ist es ratsam nach 5 Jahren gleich eine neue SD Karte zu benutzen?
              • G gmt94
                Ja. Hat auch den Vorteil, das du das Alt-System nicht löschen musst.
                • G gmt94
                  Da bringt dir aber nur bedingt was, wenn das z. B. so altes Zeug ist, das nicht mal eben so auf dem neuen System (mit neuem js-controller z.B.) einfach so einzuspielen ist.
                  Deswegen fährt man das so nah wie möglich an das aktuelle System heran.
                  • G Offline
                    gmt94
                    also auf dem alten lief bereits nodeja@18 und js controler 6.xxxx
                    • G gmt94
                      nodeja@18
                      Aber nicht in der richtigen/aktuellsten Version. Da ist noch die alte Quelle aktiv.
                      iob nodejs 18
                      fixt zumindest das aber.
                      • G Offline
                        gmt94
                        du meinst ich soll installieren bevor ist das backup einspiele? Sorry für die blöden Fragen :-(
                        • G gmt94
                          nimm eine neue Karte!
                          installier da das aktuelle raspberrypi OS Bookworm lite drauf
                          installiete da iobroker drauf
                          dann stell das Backup wieder her
                          fertig!
                          • G Offline
                            gmt94
                            VIelen lieben Dank Euch allen. Das Backup wird gerade eingespielt.
                            Wie kann ich denn in Zukunft mein Betriebssystem immer auf den aktuellsten Stand halten?
                            Vg
                            • G gmt94
                              Vg
                              CodierknechtC Offline
                              Codierknecht
                              In regelmäßigen Abständen mal drauf schauen. ioBroker sagt Dir schon, wenn Updates vorliegen.
                              Und bei Updates für das OS:
                              sudo apt update
                              sudo apt full-upgrade
                              HmIP|ZigBee|Tasmota|Unifi
                              Zabbix Certified Specialist
                              • G Offline
                                gmt94
                                Noch eine kurze Rückmeldung von mit, das System läuft soweit wieder.
                                Aktuell kämpfe ich aber noch mit Grafana. Vielen lieben Dank nochmals für die Unterstützung.
