  4. Test Adapter flexcharts - Stapeldiagramme und mehr
chartchartsdiagrammeechartsvisualisierungvisualization
280 Beiträge 21 Kommentatoren 75.6k Aufrufe 24 Beobachtet
  • M MCU
    @jrbwh Problem nach Update.
    web.1
    2024-10-15 23:16:24.879	warn	setTimeout called, but adapter is shutting down
    web.0
    2024-10-15 23:16:24.878	warn	setTimeout called, but adapter is shutting down
    host.iobrokerProd
    2024-10-15 23:16:24.645	info	Rebuild for adapter system.adapter.flexcharts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.iobrokerProd
    2024-10-15 23:16:24.645	error	instance system.adapter.flexcharts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobrokerProd
    2024-10-15 23:16:24.645	error	Caught by controller[0]: Node.js v20.17.0
    host.iobrokerProd
    2024-10-15 23:16:24.645	error	Caught by controller[0]: }
    host.iobrokerProd
    2024-10-15 23:16:24.645	error	Caught by controller[0]: requireStack: []
    host.iobrokerProd
    2024-10-15 23:16:24.645	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.iobrokerProd
    2024-10-15 23:16:24.645	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
    host.iobrokerProd
    2024-10-15 23:16:24.645	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
    host.iobrokerProd
    2024-10-15 23:16:24.645	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
    host.iobrokerProd
    2024-10-15 23:16:24.645	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
    host.iobrokerProd
    2024-10-15 23:16:24.645	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.flexcharts'
    host.iobrokerProd
    2024-10-15 23:16:24.645	error	Caught by controller[0]: ^
    host.iobrokerProd
    2024-10-15 23:16:24.645	error	Caught by controller[0]: throw err;
    host.iobrokerProd
    2024-10-15 23:16:24.645	error	Caught by controller[0]: node:internal/modules/cjs/loader:1228
    host.iobrokerProd
    2024-10-15 23:16:24.610	info	iobroker upload [0] flexcharts.admin /opt/iobroker/node_modules/iobroker.flexcharts/admin/flexcharts.png flexcharts.png image/png
    host.iobrokerProd
    2024-10-15 23:16:24.609	info	iobroker upload [1] flexcharts.admin /opt/iobroker/node_modules/iobroker.flexcharts/admin/flexcharts-icon.png flexcharts-icon.png image/png
    host.iobrokerProd
    2024-10-15 23:16:24.607	info	iobroker upload [2] flexcharts.admin /opt/iobroker/node_modules/iobroker.flexcharts/admin/flexcharts-icon-small.png flexcharts-icon-small.png image/png
    host.iobrokerProd
    2024-10-15 23:16:24.598	info	instance system.adapter.flexcharts.0 in version "0.1.5" started with pid 213243
    jrbwhJ Offline
    jrbwhJ Offline
    jrbwh
    #86
    @mcu Habe eben mit 2 Web-Adapter-Instanzen probiert, flexcharts zu deinstallieren und dann neu zu installieren. Das hat problemlos funktioniert. flexcharts ist auf beiden Ports erreichbar.
    Kann mir die Meldungen grade nicht erklären.
    Von welcher Version hast Du aktualisiert und auf wie (Adapter-GUI, NPM-GUI, ...)?
    Bitte mal probieren komplett deinstallieren und neu installieren.
    • jrbwhJ jrbwh
      M Online
      M Online
      MCU
      #87
      @jrbwh Das hat geholfen, Danke.
      • jrbwhJ jrbwh
        What's new in v0.7.1
        SSE chart updates without page reload — when using &sse, the chart now updates in place instead of reloading the full page:
        • ECharts animations run smoothly on every data update
        • No flickering or chart rebuild on refresh
        • Works transparently for all existing &sse URLs — no changes needed
        SSE demo
        flexcharts_sse_demo.mkv
        New feature in Flexcharts 0.7.0
        Event-triggered chart refresh via SSE — charts now update automatically when their source data changes, without any polling:
        • Add &sse to a chart URL to activate Server-Sent Events
        • With source=state: the chart reloads whenever the state specified by &id= changes
        • With source=script: add &triggerid=<state_id> to specify which state triggers the reload
        Example: http://localhost:8082/flexcharts/echarts.html?source=state&id=0_userdata.0.echarts.chart1&sse
        See Event-triggered chart refresh (SSE) for full details.
        Major Update auf Apache ECharts 6.0.0
        16.10.2025: Apache hat vor ein paar Wochen die Version 6.0.0 von ECharts veröffentlicht, hier sind die Neuerungen im Detail beschrieben. Das Standard-Thema, also das visuelle Erscheinungsbild, wurde deutlich verändert, es gibt einige neue Funktionen und Diagrammtypen und man kann nun dynamisch zwischen hellem und dunklem Design umschalten, getriggert durch die Systemeinstellung.
        Ich habe Flexcharts entsprechend erweitert:
        • mit &themev5 kann man dafür sorgen, dass das alte Erscheinungsbild (Version 5) bestehen bleibt
        • mit &darkmode=auto aktiviert man die erwähnte dynamische Umschaltung
        • es ist jetzt möglich, eigene Themen zu definieren und an Flexcharts zu übergeben
        • zusätzliche Funktionsdefinitionen können nun in unbegrenzter Anzahl übergeben werden
        Gerne mal ausprobieren, vor allem auch die Abwärtskompatibilität. Es sollte alles funktionieren wie bisher. Evtl. sehen die Chart visuell anders aus, dann sollte &themev5 das alte Erscheinungsbild zurück bringen. Die Version ist im Beta-Repo verfügbar.
        Im Readme sind die neuen Möglichkeiten beschrieben. Auch ein einfaches Beispiel wie man die Themen nutzen kann, ist enthalten.
        Freue mich auf euer Feedback.
        Motivation für Flexcharts
        Habt ihr auch schon mal die Möglichkeit vermisst, "richtige" Stapeldiagramme zu erzeugen? Oder andere spezielle Diagramme, die momentan mit ioBroker nicht möglich sind? Mit dem Adapter flexcharts ist das möglich. Ein Stapeldiagramm sieht dann z.B. so aus:
        Der ECharts-Adapter ist klasse, hat aber durch das UI-Konzept Einschränkungen bzgl. der möglichen Diagramm-Typen.
        Konzept
        Mit dem flexcharts-Adapter ist es möglich, alle Diagrammtypen zu erzeugen, die Apache eCharts anbietet. Dazu übergibt man dem Adapter die komplette Definition des Charts (den Inhalt von options in den Beispielen als JSON-Objekt). Man kann das Chart also nicht per UI zusammen klicken (es gibt keine UI), sondern muss es per Javascript oder Blockly erstellen.
        Der Adapter arbeitet als Web-Extension, benötigt also den Web-Adapter und ist per Default auf Port 8082 erreichbar. Das Verhalten steuert man über Parameter im http-Aufruf. Beispiel:
        • Definition und Daten des Charts hat man im State 0_userdata.0.echarts.chart1 gespeichert
        • Dann erzeugt der Aufruf http://localhost:8082/flexcharts/echarts.html?source=state&id=0_userdata.0.echarts.chart1 das entsprechende eChart. Diese Adresse kann man als iFrame z.B. in der vis oder in jarvis eintragen. Oder direkt in einem Browser-Tab. Statt localhost ggf. die Adresse der ioBroker-Rechners verwenden.
        • Statt die Chart-Daten in einem State zu speichern, kann man sie direkt per Skript erzeugen und mit callback() an den Adapter übergeben.
        • Ein Demo-Chart ist im Adapter hinterlegt, das ruft man auf mit http://localhost:8082/flexcharts/echarts.html?source=state&id=flexcharts.0.info.chart1
        Details zu Installation und Verwendung sind im README beschrieben:
        https://github.com/MyHomeMyData/ioBroker.flexcharts
        Bitte ausprobieren
        Adapter ist im Beta-Repo verfügbar. Link zum npm-Paket.
        Ich freue mich auf eure Rückmeldungen!
        Hinweis zu Versionen kleiner als 0.1.4
        Falls jemand eine Version vor 0.1.4 installiert hat: Bitte einmal den Adapter (nicht nur die Instanz) komplett deinstallieren und neu installieren. Dadurch wird das Zusammenspiel mit dem Admin-Adapter aufgeräumt. Da der Adapter keine eigene Konfigurationsparameter hat, kann dabei nichts verloren gehen.
        N Offline
        N Offline
        Neopholus
        #88
        Hallo @jrbwh,
        danke für den tollen Adapter! Bin bei eCharts schon verzweifelt, weil gerade die Balkendiagramme recht schlecht unterstützt wurden. Das klappt mit deinem Adapter sehr gut. Ich würde mir die Charts gerne per Telegram zusenden lassen, im eCharts-Adapter kann man dafür einen JPG Renderer definieren und das Bild im Dateisystem speichern und das dann verschicken. Eine entsprechende Möglichkeit habe ich in flexcharts nicht gefunden.
        Ist es irgendwie möglich, ein JPG-Bild von einem Chart zu erzeugen?
        Danke,
        Neopholus
        jrbwhJ 2 Antworten Letzte Antwort
        • mcm1957M mcm1957
          @sigi234 said in Test Adapter flexcharts 0.0.1 - Stapeldiagramme und mehr:
          @jrbwh
          Hi, wie ist der genaue Installations Vorgang?
          Cli oder via Admin
          Der Adapter ist im LATEST repository und wie jeder andere Adapetr via UI oder iobroker cli installier und upgradebar.
          Wenn eine der Versionen nicht funktioniert ist das ein Bug und bitte ein Issue erstellen.
          Delphinis
          schrieb am zuletzt editiert von Delphinis
          #89
          @mcm1957
          Hab gerade versucht, den (neuen) Adapter zu installieren. Vorgehen:
          1. npm uninstall iobroker.flexcharts -> OK
          2. installieren in iob via Adapter
            Fehlermeldung:
          $ iobroker add flexcharts auto --host MiniPC --debug
          host.MiniPC Adapter "system.adapter.flexcharts.0" is stopped.
          host.MiniPC Unknown packetName flexcharts. Please install packages from outside the repository using npm!
          ERROR: Process exited with code 12
          log:
          host.MiniPC	2024-10-29 08:08:00.313	info	iobroker exit 12
          host.MiniPC	2024-10-29 08:07:59.820	info	Restart adapter system.adapter.web.0 because enabled
          host.MiniPC	2024-10-29 08:07:59.819	error	instance system.adapter.web.0 terminated with code 4294967196 ()
          host.MiniPC	2024-10-29 08:07:59.257	error	iobroker host.MiniPC Unknown packetName flexcharts. Please install packages from outside the repository using npm!
          web.0	2024-10-29 08:07:59.239	warn	Terminated (-100): Without reason
          host.MiniPC	2024-10-29 08:07:59.219	info	"system.adapter.flexcharts.0" disabled
          host.MiniPC	2024-10-29 08:07:59.212	info	iobroker host.MiniPC Adapter "system.adapter.flexcharts.0" is stopped.
          host.MiniPC	2024-10-29 08:07:55.276	info	iobroker add flexcharts auto --host MiniPC --debug
          Der Flexadapter erscheint nun in den Instanzen funktioniert aber nicht, auch wenn ich ihn starte.
          Ausserdem finde ich den Flexadapter nicht mehr unter den Adaptern.
          Windows-System.
          • N Neopholus
            Hallo @jrbwh,
            Danke,
            Neopholus
            jrbwhJ Offline
            jrbwhJ Offline
            jrbwh
            #90
            @neopholus Freut mich, dass Dir der Adapter gefällt!
            JPG Export ist eine gute Idee, wird aber im Moment nicht unterstützt. Schaue ich mir am WE an, bin grade ohne Laptop unterwegs.
            Grüße aus der Schweiz
            Jürgen
            • D Delphinis
              @mcm1957
                Fehlermeldung:
              log:
              Windows-System.
              mcm1957M Online
              mcm1957M Online
              mcm1957
              #91
              @delphinis said in Test Adapter flexcharts - Stapeldiagramme und mehr:
              @mcm1957
              NIEMALS Installationen oder Deinstallationsn von ioBroker Komponenten mittels npm ausführen. Es gibt für alles iobroker ... Befehle wenn du auf der Commandline arbeiten willst.
              Da ich aber nicht ausschließen kann, dass du diese Antwort wieder als total OT ansiehst (siehe https://forum.iobroker.net/topic/62239/iobroker-unter-windows-eine-anleitung-und-ein-rückblick/61) werde ich von weiteren Antworten auf deine Fragen Abstand nehmen. Bitte lass dich von anderen über die sinnvolle Anwendung der iobroker commandline Befehle aufklären.
              Support Repositoryverwaltung.
              LESEN - gute Forenbeitrage
              • mcm1957M mcm1957
                @mcm1957
                Delphinis
                #92
                @mcm1957
                sorry, diese Frage sollte nicht an dich, sondern an @jrbwh.
                jrbwhJ 1 Antwort Letzte Antwort
                • D Delphinis
                  @mcm1957
                  jrbwhJ Offline
                  jrbwhJ Offline
                  jrbwh
                  #93
                  @delphinis Ich fürchte, da bin ich überfragt. npm in der ioBroker-Umgebung zu nutzen ist keine gute Idee und kann das System beschädigen. Das musste ich auch schon lernen.
                  @mcm1957 ist hier schon der richtige Ansprechpartner.
                  Gruß, Jürgen
                  • jrbwhJ jrbwh
                    Gruß, Jürgen
                    Delphinis
                    #94
                    @jrbwh
                    Ok, werde npm in zukunft meiden.
                    Hab's jetzt hingekriegt, ihn wieder mittels iob Adapter zu installieren.
                    L 1 Antwort Letzte Antwort
                    -1
                    • D Delphinis
                      @jrbwh
                      legro
                      schrieb am zuletzt editiert von legro
                      #95
                      @Alle
                      Nachdem ich die doch recht hohen Hürden beim Einstieg überwunden hatte, machte das Ganze richtig Spaß.
                      Was ich damit so alles schon habe umsetzen können, habe ich hier dokumentiert. Resultat: Was ich zuvor in einem halben Dutzend Diagrammen verpackt hatte, kann ich nunmehr mit nur zwei Charts erzeugen, da deren Ansichten über die sog. Legende (mit den darin referenzierten Datenreihen) dynamisch verändert werden können.
                      Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
                      • Merlin123M Offline
                        Merlin123M Offline
                        Merlin123
                        schrieb am zuletzt editiert von Merlin123
                        #96
                        Bräuchte mal Hilfe für den Einstieg.
                        Vorab: Meine Javascript Kenntnisse sind höchstens rudimentär vorhanden.... Bestehende Scripte ändern geht teilweise, neu schreiben krieg ich nicht wirklich hin.
                        Was will ich umsetzen?
                        Ich habe einen dynamischen Stromtarif von Tibber. Ich möchte ein Diagramm, wo für jede Stunde des Tages ein vertikaler Balken ist, dessen Höhe vom Preis für diese Stunde abhängt.
                        Die Balken sollen in Abhängigkeit einer Schwelle eine von zwei Farben haben. Die Schwelle ist ein Preis, der in einem DP abgelegt ist. Kleiner Gleich dieser Schwelle ist das Schnellladen der Wallbox aktiv.
                        Die Preise pro Stunde liegen in eigenen DPs in der Form:
                        tibberlink.0.Homes.xxx.PricesToday.0.total
                        tibberlink.0.Homes.xxx.PricesToday.1.total
                        tibberlink.0.Homes.x.PricesToday.23.total
                        Zusatzwunsch:
                        Wir planen die Anschaffung eines Speichers für unsere PV Anlage, den wir auch Steuern wollen.
                        Dafür gibt es zwei Grenzen: Laden ab x ct, entladen ab y ct
                        Wäre cool, wenn man diese Spanne in den Hintergrund des Charts legen könnte. (Im Beispiel der dunkelgraue Bereich hinter den Balken)
                        Ich habe dafür eine Lösung mit dem Material Design Barchart gefunden, was grundsätzlich geht. Leider sind die Material Design Widgets nicht VIS2 kompatibel. Das Chart aktualisiert z.B. die Farben nicht, wenn die Schwelle geändert wird. Man muss die View neu laden. In Vis1 geht es.
                        Kann mir da jemand mal nen Schubs geben, wie ich das am Besten anfange?
                        Rein die Balken würde ich mit nem State als Quelle hinbekommen. Da würde ich mit nem Blockly halt das JSON basteln (wobei ich noch keine Idee habe, wie ich die Balken unterschiedlich einfärben könnte. Eventuell mit 2 "name:" und halt nur den einen oder anderen einbauen). Aber keine Idee, wie ich da für den Speicher noch was in den Hintergrund bekommen könnte.
                        Beta-Tester
                        Merlin123M 1 Antwort Letzte Antwort
                        • Merlin123M Merlin123
                          Zusatzwunsch:
                          Merlin123M Offline
                          Merlin123M Offline
                          Merlin123
                          #97
                          Hab hier das mal als JSON probiert.... Wie kann ich denn das alles auf eine Seite bringen? Skalieren in einem iFrame?
                          Beta-Tester
                            jrbwhJ Offline
                            jrbwhJ Offline
                            jrbwh
                            #98
                            @merlin123 Das Diagramm sollte sich automatisch auf die Seite bzw. ins iFrame einpassen. Tut es das nicht? Auf was für einem System arbeitest Du, welchen Browser verwendest Du?
                            Bitte mal das JSON posten.
                            Zum "Zusatzwunsch": Ich habe in Apache ECharts keine Möglichkeit gefunden, den Hintergrund pro Balken zu variieren. Vielleicht kannst Du eine zusätzliche Serie mit gestapelten Balken (evtl. als 100%-Darstellung) erzeugen und die hinter die Preis-Balken legen.
                            • jrbwhJ jrbwh
                              Merlin123M Offline
                              Merlin123M Offline
                              Merlin123
                              #99
                              @jrbwh Hab das einfach in nem Tab in Chrome unter Windows aufgerufen.
                              Hab das JSON aus dem Beispiel genommen und angepasst. Hab aber keine Ahnung, ob ich das richtig gemacht habe :P
                              Das JSON lasse ich in nem Blockly zusammenbauen
                              { "tooltip": {"trigger": "axis","axisPointer": {"type": "shadow"}},   "legend": {},   "xAxis": [{"type": "category","data": ["0","","2","","4","","6","","8","","10","","12","","14","","16","","18","","20","","22",""]}],   "yAxis": [{"type": "value"}],   "dataZoom": [{"show": true,"start": 0, "end": 50}],   "series": [{ "name": "Load", "type": "bar", "color": "#4CAF50", "stack": "Tibber",       "data": [0,0,0,28.09,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,27.86]},{ "name": "NoLoad", "type": "bar", "color": "#2196F3", "stack": "Tibber",       "data": [29.91,29.24,28.55,0,28.51,28.92,31.01,32.83,35.63,35.92,35.77,35.36,34.81,34.33,33.85,32.5,32.99,33.86,33.2,32.16,31.11,30.19,29.7,0]}   ] }
                              Wie kann ich denn Balken hinter Balken legen bzw. die Breite von Balken variieren?
                              Beta-Tester
                                jrbwhJ Offline
                                jrbwhJ Offline
                                jrbwh
                                #100
                                @merlin123 Bei mir passt sich das Diagramm ins Fenster ein, auch bei Größenänderungen. Bitte einen Screenshot machen, so dass man das Problem sieht.
                                Übereinanderlegen geht mit barGap: https://echarts.apache.org/en/option.html#series-bar.barGap
                                • jrbwhJ jrbwh
                                  Merlin123M Offline
                                  Merlin123M Offline
                                  Merlin123
                                  #101
                                  @jrbwh
                                  So sieht das Browserfenster aus. Hab unterhalb der Bookmarks und unten in der Taskleiste abgeschnitten, volle Bildschirmbreite.
                                  Das mit barGap schau ich mir an. Danke!
                                  Beta-Tester
                                  M jrbwhJ 2 Antworten Letzte Antwort
                                    @jrbwh
                                    M Online
                                    M Online
                                    MCU
                                    #102
                                    @merlin123 Bin mir nicht sicher was du erreichen willst, aber du musst schon den Anzeige-Bereich auf 100% stellen, wenn du alles sehen möchtest.
                                    -> rechten Slider nach rechts ziehen
                                      @jrbwh
                                      jrbwhJ Offline
                                      jrbwhJ Offline
                                      jrbwh
                                      #103
                                      @merlin123 Dich stören die Abstände links und rechts? Oder was ist das Problem?
                                      • M MCU
                                        Merlin123M Offline
                                        Merlin123M Offline
                                        Merlin123
                                        #104
                                        @mcu @jrbwh
                                        Wie man an dem Screenshot in meinem ersten Beispiel sieht (von dem Material Design Barchart), sind es eigentlich 24 Balken. Die sollen direkt alle angezeigt werden.
                                        Beta-Tester
                                          @mcu @jrbwh
                                          jrbwhJ Offline
                                          jrbwhJ Offline
                                          jrbwh
                                          #105
                                          @merlin123 Das erreichst Du mit "dataZoom": [{"show": true,"start": 0,"end": 100}], oder "dataZoom": [{"show": true}],
