  3. Einsteigerfragen
  4. Installation
  5. [gelöst] ioBroker Web nach Backitup nicht erreichbar
adminbackitupbackuprestore
22 Beiträge 5 Kommentatoren 3.2k Aufrufe 5 Beobachtet
  • CodierknechtC Codierknecht
    @bene241
    Wie immer gilt: Man kann mehr sagen, wenn man Details Deines Systems kennt.
    Also die Langfassung von
    iob diag
    hier posten. In Code-Tags</>
    Ich habe das so eine Vermutung ...
    Bene241
    @codierknecht ```
    Vielen Dank für die schnelle Rückmeldung, anbei der Auszug:
    code_text
    ```bash
    Skript v.2024-08-12
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.6.51+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     15:31:07 up  1:22,  2 users,  load average: 0.75, 0.48, 0.27
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-10-06 15:31:07 CEST
               Universal time: Sun 2024-10-06 13:31:07 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        407M        815M        1.2M        2.8G        3.6G
    Swap:           209M          0B        209M
    Total:          4.2G        407M        1.0G
    Active iob-Instances:   2
             3791 M total memory
              389 M used memory
              411 M active memory
             2316 M inactive memory
              777 M free memory
              128 M buffer memory
             2574 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 15:31:07 up  1:22,  2 users,  load average: 0.75, 0.48, 0.27
    Tasks: 168 total,   1 running, 167 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3792.0 total,    776.7 free,    389.6 used,   2702.5 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3402.3 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4       29G  4.1G   24G  15% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sun Oct  6 14:08:47 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:F4:D7:06 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d3f39d23-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Sun Oct  6 14:08:49 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
    [Sun Oct  6 14:08:51 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    620M    /var/
    206M    /var/cache
    200M    /var/cache/apt
    166M    /var/lib
    134M    /var/lib/apt/lists
    Archived and active journals take up 47.6M in the file system.
    /opt/iobroker/backups:
    6.6M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    235M    /opt/iobroker/iobroker-data/
    210M    /opt/iobroker/iobroker-data/files
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/telegram.admin
    32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    21M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
    7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.0
    /usr/bin/node           v20.18.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.18.0-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
     *** 20.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.11
    admin:          6.3.5
    javascript:     6.1.4
    nodejs modules from github:     0
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
      system.adapter.bring.0                  : bring                 : raspberrypi                              - disabled
      system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
      system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              - disabled, port: 12001
      system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              - disabled, port: 12010
      system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              - disabled
      system.adapter.hue.0                    : hue                   : raspberrypi                              - disabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
      system.adapter.info.0                   : info                  : raspberrypi                              - disabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
      system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              - disabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
      system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 0.0.0.0
      system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
      system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
      system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
      system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
      system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.ws.0                     : ws                    : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : raspberrypi                              - disabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name      │ url                                                     │ auto upgrade │
    │ 0       │ 'stable'  │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'beta'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'default' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 6.3.5  [Updatable]
    Adapter    "alexa2"       : 3.26.5   , installed 3.23.2 [Updatable]
    Adapter    "backitup"     : 3.0.22   , installed 2.6.23 [Updatable]
    Adapter    "bring"        : 1.8.4    , installed 1.8.1  [Updatable]
    Adapter    "denon"        : 1.15.12  , installed 1.13.4 [Updatable]
    Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
    Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
    Adapter    "fullybrowser" : 3.0.12   , installed 2.1.2  [Updatable]
    Adapter    "hm-rega"      : 5.0.0    , installed 3.0.40 [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
    Adapter    "hue"          : 3.12.0   , installed 3.7.1  [Updatable]
    Adapter    "ical"         : 1.15.0   , installed 1.13.2 [Updatable]
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
    Adapter    "javascript"   : 8.8.3    , installed 6.1.4  [Updatable]
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "lgtv"         : 2.2.0    , installed 1.1.10 [Updatable]
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
    Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
    Adapter    "sonos"        : 3.0.0    , installed 2.3.1  [Updatable]
    Adapter    "telegram"     : 3.9.0    , installed 1.15.2 [Updatable]
    Adapter    "tr-064"       : 4.3.0    , installed 4.2.17 [Updatable]
    Adapter    "trashschedule": 3.3.0    , installed 2.2.0  [Updatable]
    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.1  [Updatable]
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
    Adapter    "yahka"        : 1.0.3    , installed 0.13.1 [Updatable]
    Objects and States
    Objects:        9204
    States:         7433
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4086       675/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       42941      12340/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       42946      12340/iobroker.js-c
    tcp6       0      0 :::22                   :::*                    LISTEN      0          4088       675/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5870       523/avahi-daemon: r
    udp        0      0 0.0.0.0:33453           0.0.0.0:*                           104        5872       523/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        5871       523/avahi-daemon: r
    udp6       0      0 fe80::dad5:b9d2:3d5:546 :::*                                0          6163       593/NetworkManager
    udp6       0      0 :::35741                :::*                                104        5873       523/avahi-daemon: r
    2024-10-06 15:22:11.709  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
    2024-10-06 15:22:11.711  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
    2024-10-06 15:22:19.063  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_22_11_989Z-debug-0.log
    2024-10-06 15:22:19.064  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
    2024-10-06 15:22:20.093  - info: host.raspberrypi iobroker npm-install: exit 25
    2024-10-06 15:22:21.093  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
    2024-10-06 15:22:21.095  - info: host.raspberrypi iobroker install vis@1.4.15 using installedVersion
    2024-10-06 15:22:24.068  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
    2024-10-06 15:22:24.070  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
    2024-10-06 15:22:33.026  - info: vis.0 (12750) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
    2024-10-06 15:22:33.307  - info: vis.0 (12750) vis license is OK.
    2024-10-06 15:22:33.512  - error: vis.0 (12750) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-10-06 15:22:33.514  - error: vis.0 (12750) unhandled promise rejection: Not exists
    2024-10-06 15:22:33.516  - error: vis.0 (12750) Error: Not exists
        at ObjectsInRedisClient._readFile (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:850:19)
        at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:887:59)
        at process.processImmediate (node:internal/timers:485:21)
    2024-10-06 15:22:33.517  - error: vis.0 (12750) Not exists
    2024-10-06 15:22:34.023  - info: vis.0 (12750) terminating
    2024-10-06 15:22:34.024  - warn: vis.0 (12750) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-10-06 15:22:34.694  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_22_24_350Z-debug-0.log
    2024-10-06 15:22:34.695  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
    2024-10-06 15:22:35.722  - info: host.raspberrypi iobroker npm-install: exit 25
    2024-10-06 15:22:36.724  - error: host.raspberrypi Cannot download and install adapter "mihome-vacuum@3.8.8". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    2024-10-06 15:22:37.225  - error: host.raspberrypi Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    • B Bene241
      @codierknecht ```
      code_text
      ```bash
      Skript v.2024-08-12
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           209M          0B        209M
               3791 M total memory
                389 M used memory
                411 M active memory
                777 M free memory
                128 M buffer memory
               2574 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      *** FILESYSTEM ***
      /var:
      620M    /var/
      206M    /var/cache
      200M    /var/cache/apt
      166M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        9204
      States:         7433
      Pending Updates: 0
      CodierknechtC Offline
      Codierknecht
      @bene241
      Starte mal den Admin
      iob start admin.0
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      B crunchipC 2 Antworten Letzte Antwort
        @bene241 sagte in ioBroker Web nach Backitup nicht erreichbar:
        Können irgendwelche Versionunterschiede ein Problem verursachen?
        Ich habe es nun mit zwei Backups probiert, eines aus 09/2023
        möglicherweise, eins aus 10/2024 sollte funktionieren, sofern du auch "relativ" aktuell mit deinem iobroker gefahren bist
        Seit dem kann ich per Browser nicht mehr zugreifen.
        Per ssh ist der Pi erreichbar.
        Bei den laufenden Instanzen "iobroker list instances" wird nur der backitup adapter als aktiv angezeigt.
        er muss ja jetzt erstmal die eigentliche Installation bewerkstelligen und dies dauert eine Weile, du kannst in log sehen, was er gerade macht
        iob logs --watch
        Bene241
        @crunchip said in ioBroker Web nach Backitup nicht erreichbar:
        Da könnte das Problem liegen, da alles erst einmal funktionierte, war ich "inaktiv" beim ioBroker.
        Ich wollte alles auf den neusten Stand bringen und habe dort wahrscheinlich beim Updaten einen fehler gemacht.
        Daher ist das Backup aus 10/2024 auch mit relativen alten Versionen.
          @bene241
          iob start admin.0
          Bene241
          @codierknecht said in ioBroker Web nach Backitup nicht erreichbar:
          @bene241
          iob start admin.0
          Leider passiert dann garnichts, da müsste doch eigentlich die Rückmeldung kommen, dass der Adapter gestartet wurde...
          • B Bene241
            @bene241
            iob start admin.0
            Codierknecht
            Eigentlich schon
            codierknecht@nuc:~$ iob start admin.0
            The adapter "admin.0" was started.
              @bene241
              iob start admin.0
              crunchipC Offline
              crunchipC Offline
              @codierknecht laut log ist er noch am arbeiten mit einigen error Meldungen
                iob logs --watch
                Bene241
                iob logs --watch
                Das schemißt er raus:
                pi@raspberrypi:~ $ iob logs --watch
                2024-10-06 14:33:19.831  - info: host.raspberrypi iobroker npm-install: upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                2024-10-06 14:33:19.842  - info: host.raspberrypi iobroker npm-install: upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                2024-10-06 14:33:19.850  - info: host.raspberrypi iobroker npm-install: upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                2024-10-06 14:33:20.046  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.web created/updated
                2024-10-06 14:33:21.137  - info: host.raspberrypi iobroker npm-install: exit 0
                2024-10-06 14:33:22.137  - warn: host.raspberrypi startInstance cannot find adapter "ws@1.3.0". Try to install it... 1 attempt
                2024-10-06 14:33:22.138  - info: host.raspberrypi iobroker install ws@1.3.0 using installedVersion
                2024-10-06 14:33:24.455  - info: host.raspberrypi iobroker npm-install: adapter "ws" already installed. Use "upgrade" to upgrade to a newer version.
                2024-10-06 14:33:25.498  - info: host.raspberrypi iobroker npm-install: exit 51
                2024-10-06 14:33:26.499  - warn: host.raspberrypi startInstance cannot find adapter "yahka@0.13.1". Try to install it... 1 attempt
                2024-10-06 14:33:26.501  - info: host.raspberrypi iobroker install yahka@0.13.1 using installedFrom
                2024-10-06 14:33:29.596  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 14:33:29.598  - info: host.raspberrypi iobroker npm-install: Installing iobroker.yahka@0.13.1... (System call)
                2024-10-06 14:33:41.908  - info: host.raspberrypi iobroker npm-install:
                2024-10-06 14:33:41.909  - info: host.raspberrypi iobroker npm-install: added 38 packages in 12s
                2024-10-06 14:33:41.910  - info: host.raspberrypi iobroker npm-install:
                2024-10-06 14:33:41.911  - info: host.raspberrypi iobroker npm-install: 193 packages are looking for funding
                2024-10-06 14:33:41.913  - info: host.raspberrypi iobroker npm-install:   run `npm fund` for details
                2024-10-06 14:33:41.950  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter yahka@0.13.1
                2024-10-06 14:33:48.322  - error: host.raspberrypi iobroker npm-install: Cannot install "pam-devel": WARNING: apt does not have a stable CLI interface. Use with caution in scripts.E: Unable to locate package pam-develThe following apt packages could not be installed: pam-devel. Please install them manually.
                2024-10-06 14:33:48.323  - info: host.raspberrypi iobroker npm-install: Installed the following apt packages: pam-develThese apt packages were already installed: libavahi-compat-libdnssd-dev
                2024-10-06 14:33:48.398  - info: host.raspberrypi iobroker npm-install: upload [19] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css
                2024-10-06 14:33:48.409  - info: host.raspberrypi iobroker npm-install: upload [18] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-colors.min.css ext/metroui/css/metro-colors.min.css text/css
                2024-10-06 14:33:48.417  - info: host.raspberrypi iobroker npm-install: upload [17] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-icons.min.css ext/metroui/css/metro-icons.min.css text/css
                2024-10-06 14:33:48.424  - info: host.raspberrypi iobroker npm-install: upload [16] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-responsive.min.css ext/metroui/css/metro-responsive.min.css text/css
                2024-10-06 14:33:48.431  - info: host.raspberrypi iobroker npm-install: upload [15] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-rtl.min.css ext/metroui/css/metro-rtl.min.css text/css
                2024-10-06 14:33:48.437  - info: host.raspberrypi iobroker npm-install: upload [14] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-schemes.min.css ext/metroui/css/metro-schemes.min.css text/css
                2024-10-06 14:33:48.444  - info: host.raspberrypi iobroker npm-install: upload [13] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro.min.css ext/metroui/css/metro.min.css text/css
                2024-10-06 14:33:48.453  - info: host.raspberrypi iobroker npm-install: upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
                2024-10-06 14:33:48.460  - info: host.raspberrypi iobroker npm-install: upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
                2024-10-06 14:33:48.472  - info: host.raspberrypi iobroker npm-install: upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf
                2024-10-06 14:33:48.479  - info: host.raspberrypi iobroker npm-install: upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff
                2024-10-06 14:33:48.487  - info: host.raspberrypi iobroker npm-install: upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
                2024-10-06 14:33:48.501  - info: host.raspberrypi iobroker npm-install: upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
                2024-10-06 14:33:48.509  - info: host.raspberrypi iobroker npm-install: upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
                2024-10-06 14:33:48.515  - info: host.raspberrypi iobroker npm-install: upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
                2024-10-06 14:33:48.522  - info: host.raspberrypi iobroker npm-install: upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
                2024-10-06 14:33:48.528  - info: host.raspberrypi iobroker npm-install: upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
                2024-10-06 14:33:48.534  - info: host.raspberrypi iobroker npm-install: upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
                2024-10-06 14:33:48.695  - info: host.raspberrypi iobroker npm-install: upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
                2024-10-06 14:33:48.862  - info: host.raspberrypi iobroker npm-install: upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
                2024-10-06 14:33:48.882  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object yahka.meta._accessoryCategories created/updated
                2024-10-06 14:33:48.891  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.yahka created/updated
                2024-10-06 14:33:48.974  - info: host.raspberrypi iobroker npm-install: Update "system.adapter.yahka.0"
                2024-10-06 14:33:50.014  - info: host.raspberrypi iobroker npm-install: exit 0
                2024-10-06 14:33:51.015  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 2 attempt
                2024-10-06 14:33:51.016  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedFrom
                2024-10-06 14:33:54.092  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 14:33:54.094  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
                2024-10-06 14:34:03.558  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T12_33_54_373Z-debug-0.log
                2024-10-06 14:34:03.560  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
                2024-10-06 14:34:04.589  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 14:34:05.590  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 2 attempt
                2024-10-06 14:34:05.591  - info: host.raspberrypi iobroker install vis@1.4.15 using installedFrom
                2024-10-06 14:34:08.677  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 14:34:08.679  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                2024-10-06 14:34:17.590  - info: vis.0 (11909) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
                2024-10-06 14:34:17.887  - info: vis.0 (11909) vis license is OK.
                2024-10-06 14:34:18.097  - error: vis.0 (11909) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2024-10-06 14:34:18.098  - error: vis.0 (11909) unhandled promise rejection: Not exists
                2024-10-06 14:34:18.100  - error: vis.0 (11909) Error: Not exists
                2024-10-06 14:34:18.101  - error: vis.0 (11909) Not exists
                2024-10-06 14:34:18.607  - info: vis.0 (11909) terminating
                2024-10-06 14:34:18.609  - warn: vis.0 (11909) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-10-06 14:34:19.275  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T12_34_08_958Z-debug-0.log
                2024-10-06 14:34:19.276  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                2024-10-06 14:34:20.305  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 14:34:21.305  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 3 attempt
                2024-10-06 14:34:21.308  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedVersion
                2024-10-06 14:34:24.355  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 14:34:24.357  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
                2024-10-06 14:34:31.625  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T12_34_24_639Z-debug-0.log
                2024-10-06 14:34:31.626  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
                2024-10-06 14:34:32.653  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 14:34:33.655  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 3 attempt
                2024-10-06 14:34:33.655  - info: host.raspberrypi iobroker install vis@1.4.15 using installedVersion
                2024-10-06 14:34:36.662  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 14:34:36.663  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                2024-10-06 14:34:45.598  - info: vis.0 (11991) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
                2024-10-06 14:34:45.893  - info: vis.0 (11991) vis license is OK.
                2024-10-06 14:34:46.101  - error: vis.0 (11991) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2024-10-06 14:34:46.103  - error: vis.0 (11991) unhandled promise rejection: Not exists
                2024-10-06 14:34:46.105  - error: vis.0 (11991) Error: Not exists
                2024-10-06 14:34:46.106  - error: vis.0 (11991) Not exists
                2024-10-06 14:34:46.612  - info: vis.0 (11991) terminating
                2024-10-06 14:34:46.613  - warn: vis.0 (11991) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-10-06 14:34:47.281  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T12_34_36_958Z-debug-0.log
                2024-10-06 14:34:47.282  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                2024-10-06 14:34:48.311  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 14:34:49.312  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 4 attempt
                2024-10-06 14:34:49.313  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedVersion
                2024-10-06 14:34:52.305  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 14:34:52.307  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
                2024-10-06 14:34:59.572  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T12_34_52_586Z-debug-0.loghost.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
                2024-10-06 14:35:00.601  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 14:35:01.602  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
                2024-10-06 14:35:01.603  - info: host.raspberrypi iobroker install vis@1.4.15 using installedVersion
                2024-10-06 14:35:04.576  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 14:35:04.579  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                2024-10-06 14:35:13.586  - info: vis.0 (12072) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
                2024-10-06 14:35:13.888  - info: vis.0 (12072) vis license is OK.
                2024-10-06 14:35:14.074  - error: vis.0 (12072) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2024-10-06 14:35:14.076  - error: vis.0 (12072) unhandled promise rejection: Not exists
                2024-10-06 14:35:14.077  - error: vis.0 (12072) Error: Not exists
                2024-10-06 14:35:14.079  - error: vis.0 (12072) Not exists
                2024-10-06 14:35:14.584  - info: vis.0 (12072) terminating
                2024-10-06 14:35:14.586  - warn: vis.0 (12072) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-10-06 14:35:15.260  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T12_35_04_857Z-debug-0.log
                2024-10-06 14:35:15.261  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                2024-10-06 14:35:16.289  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 14:35:17.290  - error: host.raspberrypi Cannot download and install adapter "mihome-vacuum@3.8.8". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                2024-10-06 14:35:17.791  - error: host.raspberrypi Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                2024-10-06 15:19:34.015  - info: host.raspberrypi received SIGTERM
                2024-10-06 15:19:34.018  - info: backitup.0 (9416) cleaned everything up...
                2024-10-06 15:19:34.021  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=false)
                2024-10-06 15:19:34.021  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=false)
                2024-10-06 15:19:34.022  - info: host.raspberrypi stopInstance system.adapter.telegram.0 (force=false, process=false)
                2024-10-06 15:19:34.022  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=false)
                2024-10-06 15:19:34.023  - info: host.raspberrypi stopInstance system.adapter.hm-rega.0 (force=false, process=false)
                2024-10-06 15:19:34.023  - info: host.raspberrypi stopInstance system.adapter.hm-rpc.0 (force=false, process=false)
                2024-10-06 15:19:34.023  - info: host.raspberrypi stopInstance system.adapter.hm-rpc.1 (force=false, process=false)
                2024-10-06 15:19:34.023  - info: host.raspberrypi stopInstance system.adapter.hm-rpc.2 (force=false, process=false)
                2024-10-06 15:19:34.024  - info: host.raspberrypi stopInstance system.adapter.hue.0 (force=false, process=false)
                2024-10-06 15:19:34.024  - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false)
                2024-10-06 15:19:34.024  - info: host.raspberrypi stopInstance system.adapter.mihome-vacuum.0 (force=false, process=false)
                2024-10-06 15:19:34.025  - info: host.raspberrypi stopInstance system.adapter.mihome.0 (force=false, process=false)
                2024-10-06 15:19:34.025  - info: host.raspberrypi stopInstance system.adapter.ping.0 (force=false, process=false)
                2024-10-06 15:19:34.025  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 (force=false, process=false)
                2024-10-06 15:19:34.025  - info: host.raspberrypi stopInstance system.adapter.sonos.0 (force=false, process=false)
                2024-10-06 15:19:34.026  - info: host.raspberrypi stopInstance system.adapter.tr-064.0 (force=false, process=false)
                2024-10-06 15:19:34.030  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=false)
                2024-10-06 15:19:34.030  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                2024-10-06 15:19:34.031  - info: host.raspberrypi stopInstance system.adapter.bring.0 (force=false, process=false)
                2024-10-06 15:19:34.031  - info: host.raspberrypi stopInstance system.adapter.denon.0 (force=false, process=false)
                2024-10-06 15:19:34.031  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=false)
                2024-10-06 15:19:34.032  - info: host.raspberrypi stopInstance system.adapter.fullybrowser.0 (force=false, process=false)
                2024-10-06 15:19:34.032  - info: host.raspberrypi stopInstance system.adapter.hue-extended.0 (force=false, process=false)
                2024-10-06 15:19:34.032  - info: host.raspberrypi stopInstance system.adapter.icons-mfd-png.0 (force=false, process=false)
                2024-10-06 15:19:34.032  - info: host.raspberrypi stopInstance system.adapter.icons-ultimate-png.0 (force=false, process=false)
                2024-10-06 15:19:34.032  - info: host.raspberrypi stopInstance system.adapter.info.0 (force=false, process=false)
                2024-10-06 15:19:34.033  - info: host.raspberrypi stopInstance system.adapter.lgtv.0 (force=false, process=false)
                2024-10-06 15:19:34.033  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 (force=false, process=false)
                2024-10-06 15:19:34.033  - info: host.raspberrypi stopInstance system.adapter.vis-bars.0 (force=false, process=false)
                2024-10-06 15:19:34.033  - info: host.raspberrypi stopInstance system.adapter.vis-fancyswitch.0 (force=false, process=false)
                2024-10-06 15:19:34.033  - info: host.raspberrypi stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
                2024-10-06 15:19:34.034  - info: host.raspberrypi stopInstance system.adapter.vis-inventwo.0 (force=false, process=false)
                2024-10-06 15:19:34.034  - info: host.raspberrypi stopInstance system.adapter.vis-players.0 (force=false, process=false)
                2024-10-06 15:19:34.034  - info: host.raspberrypi stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
                2024-10-06 15:19:34.034  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
                2024-10-06 15:19:34.034  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=false)
                2024-10-06 15:19:34.035  - info: host.raspberrypi stopInstance system.adapter.ws.0 (force=false, process=false)
                2024-10-06 15:19:34.035  - info: host.raspberrypi stopInstance system.adapter.yahka.0 (force=false, process=false)
                2024-10-06 15:19:34.043  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                2024-10-06 15:19:34.042  - info: backitup.0 (9416) Got terminate signal TERMINATE_YOURSELF
                2024-10-06 15:19:34.047  - info: backitup.0 (9416) terminating
                2024-10-06 15:19:34.049  - info: backitup.0 (9416) Terminated (NO_ERROR): Without reason
                2024-10-06 15:19:34.526  - info: backitup.0 (9416) terminating
                2024-10-06 15:19:34.763  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                2024-10-06 15:19:34.763  - info: host.raspberrypi All instances are stopped.
                2024-10-06 15:19:34.946  - info: host.raspberrypi terminated
                2024-10-06 15:20:28.227  - info: host.raspberrypi iobroker.js-controller version 6.0.11 js-controller starting
                2024-10-06 15:20:28.233  - info: host.raspberrypi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                2024-10-06 15:20:28.234  - info: host.raspberrypi hostname: raspberrypi, node: v20.18.0
                2024-10-06 15:20:28.235  - info: host.raspberrypi ip addresses: 192.168.178.65 2a02:908:1c40:1f80:892:a253:c9a7:6444 fe80::dad5:b9d2:3d51:2e39
                2024-10-06 15:20:29.891  - info: host.raspberrypi connected to Objects and States
                2024-10-06 15:20:29.931  - info: host.raspberrypi added notifications configuration of host
                2024-10-06 15:20:30.589  - info: host.raspberrypi 38 instances found
                2024-10-06 15:20:30.646  - info: host.raspberrypi starting 2 instances
                2024-10-06 15:20:30.656  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 1 attempt
                2024-10-06 15:20:30.658  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedFrom
                2024-10-06 15:20:31.125  - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
                2024-10-06 15:20:31.153  - info: host.raspberrypi Some obsolete host states deleted.
                2024-10-06 15:20:31.174  - info: host.raspberrypi instance system.adapter.admin.0 in version "6.3.5" started with pid 12369
                2024-10-06 15:20:34.162  - info: admin.0 (12369) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.0, js-controller: 6.0.11
                2024-10-06 15:20:34.182  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 15:20:34.184  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
                2024-10-06 15:20:34.239  - info: admin.0 (12369) requesting all states
                2024-10-06 15:20:34.241  - info: admin.0 (12369) requesting all objects
                2024-10-06 15:20:36.023  - info: host.raspberrypi instance system.adapter.backitup.0 in version "2.6.23" started with pid 12419
                2024-10-06 15:20:36.266  - info: admin.0 (12369) received all objects
                2024-10-06 15:20:36.349  - error: admin.0 (12369) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
                2024-10-06 15:20:36.351  - info: admin.0 (12369) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2024-10-06 15:20:36.965  - warn: admin.0 (12369) redis get admin.0.info.newsLastId, error - Connection is closed.
                2024-10-06 15:20:36.985  - error: admin.0 (12369) Cannot update news: Error: DB closed
                2024-10-06 15:20:36.987  - warn: admin.0 (12369) Cannot check node.js/npm version
                2024-10-06 15:20:37.001  - info: admin.0 (12369) terminating http server on port 8081
                2024-10-06 15:20:37.165  - info: host.raspberrypi instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                2024-10-06 15:20:37.167  - info: host.raspberrypi Do not restart adapter system.adapter.admin.0 because desired by instance
                2024-10-06 15:20:39.761  - info: backitup.0 (12419) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.0, js-controller: 6.0.11
                2024-10-06 15:20:40.009  - info: backitup.0 (12419) [iobroker] backup will be activated at 02:40 every 1 day(s)
                2024-10-06 15:20:40.125  - info: backitup.0 (12419) [ccu] backup will be activated at 01:30 every 3 day(s)
                2024-10-06 15:20:44.994  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_20_34_497Z-debug-0.log
                2024-10-06 15:20:44.995  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
                2024-10-06 15:20:46.031  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 15:20:47.032  - warn: host.raspberrypi startInstance cannot find adapter "hue-extended@2.0.0". Try to install it... 1 attempt
                2024-10-06 15:20:47.034  - info: host.raspberrypi iobroker install hue-extended@2.0.0 using installedFrom
                2024-10-06 15:20:49.848  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Unknown packet name hue-extended. Please install packages from outside the repository using "iobroker url <url-or-package>"!
                2024-10-06 15:20:49.849  - error: host.raspberrypi iobroker npm-install: adapter "hue-extended" cannot be installed: Unknown packetName hue-extended. Please install packages from outside the repository using npm!
                2024-10-06 15:20:50.904  - info: host.raspberrypi iobroker npm-install: exit 12
                2024-10-06 15:20:51.904  - warn: host.raspberrypi startInstance cannot find adapter "info@1.9.19". Try to install it... 1 attempt
                2024-10-06 15:20:51.906  - info: host.raspberrypi iobroker install info@1.9.19 using installedFrom
                2024-10-06 15:20:54.570  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Unknown packet name info. Please install packages from outside the repository using "iobroker url <url-or-package>"!
                2024-10-06 15:20:54.571  - error: host.raspberrypi iobroker npm-install: adapter "info" cannot be installed: Unknown packetName info. Please install packages from outside the repository using npm!
                2024-10-06 15:20:55.631  - info: host.raspberrypi iobroker npm-install: exit 12
                2024-10-06 15:20:56.632  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 1 attempt
                2024-10-06 15:20:56.633  - info: host.raspberrypi iobroker install vis@1.4.15 using installedFrom
                2024-10-06 15:20:59.610  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 15:20:59.612  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                2024-10-06 15:21:08.952  - info: vis.0 (12506) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
                2024-10-06 15:21:09.253  - info: vis.0 (12506) vis license is OK.
                2024-10-06 15:21:09.477  - error: vis.0 (12506) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2024-10-06 15:21:09.479  - error: vis.0 (12506) unhandled promise rejection: Not exists
                2024-10-06 15:21:09.481  - error: vis.0 (12506) Error: Not exists
                2024-10-06 15:21:09.482  - error: vis.0 (12506) Not exists
                2024-10-06 15:21:09.988  - info: vis.0 (12506) terminating
                2024-10-06 15:21:09.989  - warn: vis.0 (12506) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-10-06 15:21:10.660  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_20_59_899Z-debug-0.log
                2024-10-06 15:21:10.662  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                2024-10-06 15:21:11.690  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 15:21:12.690  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 2 attempt
                2024-10-06 15:21:12.693  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedFrom
                2024-10-06 15:21:15.763  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 15:21:15.765  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
                2024-10-06 15:21:23.145  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_21_16_046Z-debug-0.log
                2024-10-06 15:21:23.147  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
                2024-10-06 15:21:24.177  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 15:21:25.178  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 2 attempt
                2024-10-06 15:21:25.179  - info: host.raspberrypi iobroker install vis@1.4.15 using installedFrom
                2024-10-06 15:21:28.146  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 15:21:28.148  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                2024-10-06 15:21:37.017  - info: vis.0 (12587) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
                2024-10-06 15:21:37.305  - info: vis.0 (12587) vis license is OK.
                2024-10-06 15:21:37.516  - error: vis.0 (12587) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2024-10-06 15:21:37.518  - error: vis.0 (12587) unhandled promise rejection: Not exists
                2024-10-06 15:21:37.520  - error: vis.0 (12587) Error: Not exists
                2024-10-06 15:21:37.521  - error: vis.0 (12587) Not exists
                2024-10-06 15:21:38.027  - info: vis.0 (12587) terminating
                2024-10-06 15:21:38.028  - warn: vis.0 (12587) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-10-06 15:21:38.699  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_21_28_427Z-debug-0.log
                2024-10-06 15:21:38.700  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                2024-10-06 15:21:39.728  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 15:21:40.729  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 3 attempt
                2024-10-06 15:21:40.730  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedVersion
                2024-10-06 15:21:43.701  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 15:21:43.703  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
                2024-10-06 15:21:51.009  - error: host.raspberrypi iobroker npm-install: npm error code 127npm error path /opt/iobroker/node_modules/zlibnpm error command failednpm error command sh -c node-waf clean || true; node-waf configure buildnpm error sh: 1: node-waf: not foundnpm error sh: 1: node-waf: not foundnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_21_43_982Z-debug-0.loghost.raspberrypi Cannot install iobroker.mihome-vacuum@3.8.8: 127
                2024-10-06 15:21:52.040  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 15:21:53.040  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 3 attempt
                2024-10-06 15:21:53.042  - info: host.raspberrypi iobroker install vis@1.4.15 using installedVersion
                2024-10-06 15:21:56.057  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 15:21:56.059  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                2024-10-06 15:22:04.895  - info: vis.0 (12669) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
                2024-10-06 15:22:05.271  - info: vis.0 (12669) vis license is OK.
                2024-10-06 15:22:05.479  - error: vis.0 (12669) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2024-10-06 15:22:05.481  - error: vis.0 (12669) unhandled promise rejection: Not exists
                2024-10-06 15:22:05.483  - error: vis.0 (12669) Error: Not exists
                2024-10-06 15:22:05.484  - error: vis.0 (12669) Not exists
                2024-10-06 15:22:05.990  - info: vis.0 (12669) terminating
                2024-10-06 15:22:05.992  - warn: vis.0 (12669) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-10-06 15:22:06.662  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_21_56_340Z-debug-0.loghost.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                2024-10-06 15:22:07.691  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 15:22:08.692  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@3.8.8". Try to install it... 4 attempt
                2024-10-06 15:22:08.694  - info: host.raspberrypi iobroker install mihome-vacuum@3.8.8 using installedVersion
                2024-10-06 15:44:22.936  - info: host.raspberrypi "system.adapter.vis.0" enabled
                2024-10-06 15:44:23.415  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 1 attempt
                2024-10-06 15:44:23.416  - info: host.raspberrypi iobroker install vis@1.4.15 using installedFrom
                2024-10-06 15:44:26.380  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 15:44:26.382  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                2024-10-06 15:44:35.746  - info: vis.0 (15614) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
                2024-10-06 15:44:36.028  - info: vis.0 (15614) vis license is OK.
                2024-10-06 15:44:36.232  - error: vis.0 (15614) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2024-10-06 15:44:36.234  - error: vis.0 (15614) unhandled promise rejection: Not exists
                2024-10-06 15:44:36.236  - error: vis.0 (15614) Error: Not exists
                2024-10-06 15:44:36.237  - error: vis.0 (15614) Not exists
                2024-10-06 15:44:36.741  - info: vis.0 (15614) terminating
                2024-10-06 15:44:36.743  - warn: vis.0 (15614) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-10-06 15:44:37.418  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_44_26_661Z-debug-0.log
                2024-10-06 15:44:37.420  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                2024-10-06 15:44:38.448  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 15:44:39.449  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 2 attempt
                2024-10-06 15:44:39.450  - info: host.raspberrypi iobroker install vis@1.4.15 using installedFrom
                2024-10-06 15:44:41.571  - info: host.raspberrypi "system.adapter.web.0" enabled
                2024-10-06 15:44:42.202  - info: host.raspberrypi instance system.adapter.web.0 in version "4.3.0" started with pid 15650
                2024-10-06 15:44:43.430  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2Installing iobroker.vis@1.4.15... (System call)
                2024-10-06 15:44:43.814  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1228
                2024-10-06 15:44:43.814  - error: host.raspberrypi Caught by controller[0]:   throw err;
                2024-10-06 15:44:43.814  - error: host.raspberrypi Caught by controller[0]:   ^
                2024-10-06 15:44:43.815  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                2024-10-06 15:44:43.815  - error: host.raspberrypi Caught by controller[0]: Require stack:
                2024-10-06 15:44:43.815  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                2024-10-06 15:44:43.815  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                2024-10-06 15:44:43.815  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
                2024-10-06 15:44:43.816  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                2024-10-06 15:44:43.816  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                2024-10-06 15:44:43.816  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                2024-10-06 15:44:43.816  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                2024-10-06 15:44:43.816  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                2024-10-06 15:44:43.817  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                2024-10-06 15:44:43.817  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                2024-10-06 15:44:43.817  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
                2024-10-06 15:44:43.817  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                2024-10-06 15:44:43.817  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                2024-10-06 15:44:43.817  - error: host.raspberrypi Caught by controller[0]: }
                2024-10-06 15:44:43.818  - error: host.raspberrypi Caught by controller[0]: Node.js v20.18.0
                2024-10-06 15:44:43.818  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-10-06 15:44:43.818  - info: host.raspberrypi Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
                2024-10-06 15:44:43.819  - info: host.raspberrypi system.adapter.web.0 will be rebuilt
                2024-10-06 15:44:52.410  - info: vis.0 (15681) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
                2024-10-06 15:44:52.701  - info: vis.0 (15681) vis license is OK.
                2024-10-06 15:44:52.909  - error: vis.0 (15681) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2024-10-06 15:44:52.911  - error: vis.0 (15681) unhandled promise rejection: Not exists
                2024-10-06 15:44:52.913  - error: vis.0 (15681) Error: Not exists
                2024-10-06 15:44:52.914  - error: vis.0 (15681) Not exists
                2024-10-06 15:44:53.420  - info: vis.0 (15681) terminating
                2024-10-06 15:44:53.421  - warn: vis.0 (15681) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-10-06 15:44:54.099  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_44_43_778Z-debug-0.log
                2024-10-06 15:44:54.100  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                2024-10-06 15:44:55.127  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 15:44:56.128  - warn: host.raspberrypi adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                2024-10-06 15:44:56.129  - info: host.raspberrypi iobroker rebuild
                2024-10-06 15:44:57.896  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules ...
                2024-10-06 15:45:42.200  - info: host.raspberrypi iobroker npm-rebuild: rebuilt dependencies successfully
                2024-10-06 15:45:42.233  - info: host.raspberrypi iobroker npm-rebuild:
                2024-10-06 15:45:42.234  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules done
                2024-10-06 15:45:43.246  - info: host.raspberrypi iobroker npm-rebuild: exit 0
                2024-10-06 15:45:43.792  - info: host.raspberrypi instance system.adapter.web.0 in version "4.3.0" started with pid 16132
                2024-10-06 15:45:44.248  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 3 attempt
                2024-10-06 15:45:44.250  - info: host.raspberrypi iobroker install vis@1.4.15 using installedVersion
                2024-10-06 15:45:45.313  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1228
                2024-10-06 15:45:45.313  - error: host.raspberrypi Caught by controller[0]:   throw err;
                2024-10-06 15:45:45.314  - error: host.raspberrypi Caught by controller[0]:   ^
                2024-10-06 15:45:45.314  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                2024-10-06 15:45:45.314  - error: host.raspberrypi Caught by controller[0]: Require stack:
                2024-10-06 15:45:45.314  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                2024-10-06 15:45:45.315  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                2024-10-06 15:45:45.315  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
                2024-10-06 15:45:45.315  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                2024-10-06 15:45:45.315  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                2024-10-06 15:45:45.315  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                2024-10-06 15:45:45.316  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                2024-10-06 15:45:45.316  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                2024-10-06 15:45:45.316  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                2024-10-06 15:45:45.316  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                2024-10-06 15:45:45.316  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
                2024-10-06 15:45:45.317  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                2024-10-06 15:45:45.317  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                2024-10-06 15:45:45.317  - error: host.raspberrypi Caught by controller[0]: }
                2024-10-06 15:45:45.317  - error: host.raspberrypi Caught by controller[0]: Node.js v20.18.0
                2024-10-06 15:45:45.317  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-10-06 15:45:45.318  - info: host.raspberrypi Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                2024-10-06 15:45:45.318  - info: host.raspberrypi system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"6.0.11"})
                2024-10-06 15:45:47.453  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 15:45:47.456  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                2024-10-06 15:45:57.836  - info: vis.0 (16176) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
                2024-10-06 15:45:58.174  - info: vis.0 (16176) vis license is OK.
                2024-10-06 15:45:58.373  - error: vis.0 (16176) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2024-10-06 15:45:58.375  - error: vis.0 (16176) unhandled promise rejection: Not exists
                2024-10-06 15:45:58.377  - error: vis.0 (16176) Error: Not exists
                2024-10-06 15:45:58.378  - error: vis.0 (16176) Not exists
                2024-10-06 15:45:58.884  - info: vis.0 (16176) terminating
                2024-10-06 15:45:58.885  - warn: vis.0 (16176) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-10-06 15:45:59.767  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_45_47_734Z-debug-0.log
                2024-10-06 15:45:59.768  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                2024-10-06 15:46:00.797  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 15:46:01.797  - warn: host.raspberrypi adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                2024-10-06 15:46:01.799  - info: host.raspberrypi iobroker rebuild iobroker.js-controller@6.0.11 --path /opt/iobroker/node_modules
                2024-10-06 15:46:03.292  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native module "iobroker.js-controller@6.0.11" in /opt/iobroker/node_modules ...
                2024-10-06 15:46:20.538  - info: host.raspberrypi iobroker npm-rebuild: rebuilt dependencies successfully
                2024-10-06 15:46:20.571  - info: host.raspberrypi iobroker npm-rebuild:
                2024-10-06 15:46:20.571  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules done
                2024-10-06 15:46:21.584  - info: host.raspberrypi iobroker npm-rebuild: exit 0
                2024-10-06 15:46:21.994  - info: host.raspberrypi instance system.adapter.web.0 in version "4.3.0" started with pid 16246
                2024-10-06 15:46:22.584  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
                2024-10-06 15:46:22.585  - info: host.raspberrypi iobroker install vis@1.4.15 using installedVersion
                2024-10-06 15:46:23.506  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1228
                2024-10-06 15:46:23.506  - error: host.raspberrypi Caught by controller[0]:   throw err;
                2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]:   ^
                2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]: Require stack:
                2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
                2024-10-06 15:46:23.507  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                2024-10-06 15:46:23.508  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                2024-10-06 15:46:23.508  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                2024-10-06 15:46:23.508  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                2024-10-06 15:46:23.508  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                2024-10-06 15:46:23.508  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                2024-10-06 15:46:23.509  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                2024-10-06 15:46:23.509  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
                2024-10-06 15:46:23.510  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                2024-10-06 15:46:23.510  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                2024-10-06 15:46:23.510  - error: host.raspberrypi Caught by controller[0]: }
                2024-10-06 15:46:23.510  - error: host.raspberrypi Caught by controller[0]: Node.js v20.18.0
                2024-10-06 15:46:23.510  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-10-06 15:46:23.511  - info: host.raspberrypi Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
                2024-10-06 15:46:23.511  - info: host.raspberrypi system.adapter.web.0 will be rebuilt
                2024-10-06 15:46:25.762  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                2024-10-06 15:46:25.764  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
                2024-10-06 15:46:36.200  - info: vis.0 (16288) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
                2024-10-06 15:46:36.531  - info: vis.0 (16288) vis license is OK.
                2024-10-06 15:46:36.727  - error: vis.0 (16288) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2024-10-06 15:46:36.729  - error: vis.0 (16288) unhandled promise rejection: Not exists
                2024-10-06 15:46:36.731  - error: vis.0 (16288) Error: Not exists
                2024-10-06 15:46:36.732  - error: vis.0 (16288) Not exists
                2024-10-06 15:46:37.238  - info: vis.0 (16288) terminating
                2024-10-06 15:46:37.240  - warn: vis.0 (16288) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-10-06 15:46:38.120  - error: host.raspberrypi iobroker npm-install: npm error code 6npm error path /opt/iobroker/node_modules/iobroker.visnpm error command failednpm error command sh -c node main.js --installnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-10-06T13_46_26_043Z-debug-0.log
                2024-10-06 15:46:38.121  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                2024-10-06 15:46:39.149  - info: host.raspberrypi iobroker npm-install: exit 25
                2024-10-06 15:46:40.150  - warn: host.raspberrypi adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                2024-10-06 15:46:40.151  - info: host.raspberrypi iobroker rebuild
                2024-10-06 15:46:41.843  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules ...
                2024-10-06 15:47:25.422  - info: host.raspberrypi iobroker npm-rebuild: rebuilt dependencies successfully
                2024-10-06 15:47:25.464  - info: host.raspberrypi iobroker npm-rebuild:
                2024-10-06 15:47:25.465  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules done
                2024-10-06 15:47:26.479  - info: host.raspberrypi iobroker npm-rebuild: exit 0
                2024-10-06 15:47:26.985  - info: host.raspberrypi instance system.adapter.web.0 in version "4.3.0" started with pid 16999
                2024-10-06 15:47:27.481  - error: host.raspberrypi Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                2024-10-06 15:47:28.552  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1228
                2024-10-06 15:47:28.553  - error: host.raspberrypi Caught by controller[0]:   throw err;
                2024-10-06 15:47:28.553  - error: host.raspberrypi Caught by controller[0]:   ^
                2024-10-06 15:47:28.553  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                2024-10-06 15:47:28.554  - error: host.raspberrypi Caught by controller[0]: Require stack:
                2024-10-06 15:47:28.554  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                2024-10-06 15:47:28.554  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                2024-10-06 15:47:28.554  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
                2024-10-06 15:47:28.555  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                2024-10-06 15:47:28.555  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                2024-10-06 15:47:28.555  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                2024-10-06 15:47:28.555  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                2024-10-06 15:47:28.556  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                2024-10-06 15:47:28.556  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                2024-10-06 15:47:28.556  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                2024-10-06 15:47:28.557  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
                2024-10-06 15:47:28.557  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                2024-10-06 15:47:28.557  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                2024-10-06 15:47:28.558  - error: host.raspberrypi Caught by controller[0]: }
                2024-10-06 15:47:28.558  - error: host.raspberrypi Caught by controller[0]: Node.js v20.18.0
                2024-10-06 15:47:28.559  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2024-10-06 15:47:28.559  - info: host.raspberrypi Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                  Codierknecht
                  @crunchip sagte in ioBroker Web nach Backitup nicht erreichbar:
                  Jo - nicht drauf geachtet :-(
                  • CodierknechtC Codierknecht
                    Bene241
                    @codierknecht @crunchip
                    werdet ihr denn aus den Fehlermeldungen schlau?
                    • B Bene241
                      @bene241
                      Backup sollte ja jetzt durch sein bzw. in timeout gelaufen sein.
                      Sauberen reboot und dann eine frische Ausgabe von
                      iob diag
                        @bene241
                        iob diag
                        Bene241
                        @thomas-braun said in ioBroker Web nach Backitup nicht erreichbar:
                        @bene241
                        iob diag
                        Vielen Dank nochmals :)
                        ```bash
                        Skript v.2024-08-12
                        *** BASE SYSTEM ***
                         Static hostname: raspberrypi
                               Icon name: computer
                                  Kernel: Linux 6.6.51+rpt-rpi-v8
                            Architecture: arm64
                        OS is similar to:
                        Model           : Raspberry Pi 4 Model B Rev 1.2
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         16:58:10 up 1 min,  2 users,  load average: 1.41, 0.42, 0.15
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                       Local time: Sun 2024-10-06 16:58:10 CEST
                                   Universal time: Sun 2024-10-06 14:58:10 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        pi
                        HOME=/home/pi
                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                        iobroker
                        HOME=/home/iobroker
                        *** Display-Server-Setup ***
                        Display-Server: false
                        Desktop:
                        Terminal:       tty
                        Boot Target:    multi-user.target
                        *** MEMORY ***
                        Mem:            4.0G        370M        3.4G        1.2M        304M        3.6G
                        Swap:           209M          0B        209M
                        Total:          4.2G        370M        3.6G
                        Active iob-Instances:   2
                                 3791 M total memory
                                  353 M used memory
                                  360 M active memory
                                  123 M inactive memory
                                 3217 M free memory
                                   44 M buffer memory
                                  246 M swap cache
                                  199 M total swap
                                    0 M used swap
                                  199 M free swap
                        top - 16:58:10 up 1 min,  2 users,  load average: 1.41, 0.42, 0.15
                        Tasks: 182 total,   2 running, 180 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 33.3 us, 16.7 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   3792.0 total,   3216.7 free,    354.9 used,    291.1 buff/cache
                        MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3437.1 avail Mem
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        udev           devtmpfs  1.6G     0  1.6G   0% /dev
                        tmpfs          tmpfs     380M  1.2M  379M   1% /run
                        /dev/mmcblk0p2 ext4       29G  4.3G   24G  16% /
                        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                        /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                        [Sun Oct  6 16:57:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:F4:D7:06 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d3f39d23-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                        [Sun Oct  6 16:57:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                        [Sun Oct  6 16:57:06 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                        Show mounted filesystems:
                        TARGET           SOURCE         FSTYPE OPTIONS
                        /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        628M    /var/
                        206M    /var/cache
                        200M    /var/cache/apt
                        166M    /var/lib
                        134M    /var/lib/apt/lists
                        Archived and active journals take up 55.6M in the file system.
                        /opt/iobroker/backups:
                        6.6M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        235M    /opt/iobroker/iobroker-data/
                        210M    /opt/iobroker/iobroker-data/files
                        51M     /opt/iobroker/iobroker-data/files/javascript.admin
                        48M     /opt/iobroker/iobroker-data/files/telegram.admin
                        32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                        21M     /opt/iobroker/iobroker-data/objects.jsonl
                        15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                        14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                        7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
                        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                        USB-Devices by-id:
                        No Devices found 'by-id'
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v20.18.0
                        /usr/bin/node           v20.18.0
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        /usr/bin/corepack       0.29.3
                        nodejs:
                          Installed: 20.18.0-1nodesource1
                          Candidate: 20.18.0-1nodesource1
                          Version table:
                         *** 20.18.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                             20.17.0-1nodesource1 1001
                             20.16.0-1nodesource1 1001
                             20.15.1-1nodesource1 1001
                             20.15.0-1nodesource1 1001
                             20.14.0-1nodesource1 1001
                             20.13.1-1nodesource1 1001
                             20.13.0-1nodesource1 1001
                             20.12.2-1nodesource1 1001
                             20.12.1-1nodesource1 1001
                             20.12.0-1nodesource1 1001
                             20.11.1-1nodesource1 1001
                             20.11.0-1nodesource1 1001
                             20.10.0-1nodesource1 1001
                             20.9.0-1nodesource1 1001
                             20.8.1-1nodesource1 1001
                             20.8.0-1nodesource1 1001
                             20.7.0-1nodesource1 1001
                             20.6.1-1nodesource1 1001
                             20.6.0-1nodesource1 1001
                             20.5.1-1nodesource1 1001
                             20.5.0-1nodesource1 1001
                             20.4.0-1nodesource1 1001
                             20.3.1-1nodesource1 1001
                             20.3.0-1nodesource1 1001
                             20.2.0-1nodesource1 1001
                             20.1.0-1nodesource1 1001
                             20.0.0-1nodesource1 1001
                             18.19.0+dfsg-6~deb12u2 500
                                500 http://deb.debian.org/debian bookworm/main arm64 Packages
                             18.19.0+dfsg-6~deb12u1 500
                                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        admin:          6.3.5
                        javascript:     6.1.4
                        nodejs modules from github:     0
                        Adapter State
                          system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
                          system.adapter.bring.0                  : bring                 : raspberrypi                              - disabled
                          system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
                          system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                          system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
                          system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
                          system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              - disabled
                          system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 18701
                          system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              - disabled, port: 12001
                          system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              - disabled, port: 12010
                          system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              - disabled
                          system.adapter.hue.0                    : hue                   : raspberrypi                              - disabled, port: 443
                          system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
                          system.adapter.info.0                   : info                  : raspberrypi                              - disabled
                          system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
                          system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              - disabled
                          system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
                          system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 0.0.0.0
                          system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                          system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
                          system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
                          system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                          system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                          system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
                          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                          system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
                          system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                          system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.ws.0                     : ws                    : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                          system.adapter.yahka.0                  : yahka                 : raspberrypi                              - disabled
                        + instance is alive
                        ioBroker-Repositories
                        │ (index) │ name      │ url                                                     │ auto upgrade │
                        │ 0       │ 'stable'  │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                        │ 1       │ 'beta'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                        │ 2       │ 'default' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                        Active repo(s): stable
                        Upgrade policy: none
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 7.1.5    , installed 6.3.5  [Updatable]
                        Adapter    "alexa2"       : 3.26.5   , installed 3.23.2 [Updatable]
                        Adapter    "backitup"     : 3.0.22   , installed 2.6.23 [Updatable]
                        Adapter    "bring"        : 1.8.4    , installed 1.8.1  [Updatable]
                        Adapter    "denon"        : 1.15.12  , installed 1.13.4 [Updatable]
                        Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
                        Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
                        Adapter    "fullybrowser" : 3.0.12   , installed 2.1.2  [Updatable]
                        Adapter    "hm-rega"      : 5.0.0    , installed 3.0.40 [Updatable]
                        Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
                        Adapter    "hue"          : 3.12.0   , installed 3.7.1  [Updatable]
                        Adapter    "ical"         : 1.15.0   , installed 1.13.2 [Updatable]
                        Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
                        Adapter    "javascript"   : 8.8.3    , installed 6.1.4  [Updatable]
                        Controller "js-controller": 6.0.11   , installed 6.0.11
                        Adapter    "lgtv"         : 2.2.0    , installed 1.1.10 [Updatable]
                        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                        Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                        Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
                        Adapter    "sonos"        : 3.0.0    , installed 2.3.1  [Updatable]
                        Adapter    "telegram"     : 3.9.0    , installed 1.15.2 [Updatable]
                        Adapter    "tr-064"       : 4.3.0    , installed 4.2.17 [Updatable]
                        Adapter    "trashschedule": 3.3.0    , installed 2.2.0  [Updatable]
                        Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
                        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.1  [Updatable]
                        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                        Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
                        Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
                        Adapter    "yahka"        : 1.0.3    , installed 0.13.1 [Updatable]
                        Objects and States
                        Objects:        9203
                        States:         7435
                        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                        Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                        Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6493       673/iobroker.js-con
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6488       673/iobroker.js-con
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1777       681/sshd: /usr/sbin
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          1779       681/sshd: /usr/sbin
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5546       535/avahi-daemon: r
                        udp        0      0 0.0.0.0:56761           0.0.0.0:*                           104        5548       535/avahi-daemon: r
                        udp6       0      0 :::42211                :::*                                104        5549       535/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                104        5547       535/avahi-daemon: r
                        udp6       0      0 fe80::dad5:b9d2:3d5:546 :::*                                0          1822       603/NetworkManager
                        2024-10-06 16:59:03.703  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1228
                        2024-10-06 16:59:03.703  - error: host.raspberrypi Caught by controller[0]:   throw err;
                        2024-10-06 16:59:03.704  - error: host.raspberrypi Caught by controller[0]:   ^
                        2024-10-06 16:59:03.704  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                        2024-10-06 16:59:03.704  - error: host.raspberrypi Caught by controller[0]: Require stack:
                        2024-10-06 16:59:03.705  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                        2024-10-06 16:59:03.705  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                        2024-10-06 16:59:03.705  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
                        2024-10-06 16:59:03.706  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                        2024-10-06 16:59:03.706  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                        2024-10-06 16:59:03.706  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                        2024-10-06 16:59:03.706  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                        2024-10-06 16:59:03.707  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                        2024-10-06 16:59:03.707  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                        2024-10-06 16:59:03.707  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                        2024-10-06 16:59:03.707  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
                        2024-10-06 16:59:03.707  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2024-10-06 16:59:03.708  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                        2024-10-06 16:59:03.708  - error: host.raspberrypi Caught by controller[0]: }
                        2024-10-06 16:59:03.708  - error: host.raspberrypi Caught by controller[0]: Node.js v20.18.0
                        2024-10-06 16:59:03.708  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2024-10-06 16:59:03.709  - info: host.raspberrypi Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                        2024-10-06 16:59:03.710  - info: host.raspberrypi system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"6.0.11"})
                        2024-10-06 16:59:06.094  - info: host.raspberrypi iobroker npm-install: NPM version: 10.8.2
                        2024-10-06 16:59:06.096  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@3.8.8... (System call)
                        • B Bene241
                          @bene241
                          iob diag
                          ```bash
                          Skript v.2024-08-12
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           209M          0B        209M
                                   3791 M total memory
                                    353 M used memory
                                    360 M active memory
                                   3217 M free memory
                                     44 M buffer memory
                                    246 M swap cache
                                    199 M total swap
                                      0 M used swap
                                    199 M free swap
                          *** FILESYSTEM ***
                          /var:
                          628M    /var/
                          206M    /var/cache
                          200M    /var/cache/apt
                          166M    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.3.5
                          javascript:     6.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        9203
                          States:         7435
                          Pending Updates: 0
                          @bene241
                          iob update
                          iob upgrade all -y
                            @bene241
                            iob update
                            iob upgrade all -y
                            Bene241
                            schrieb am zuletzt editiert von Bene241
                            @bene241
                            iob update
                            iob upgrade all -y
                            Super, ich komme wieder auf die Web-Oberfläche.
                            Vielen vielen Dank.
                            Woran hat das denn jetzt gelegen?
                            Zwei Fragen bleiben bei mir nun noch offen:
                            1. Das aktuell aufgespielte war nun "leider" das ältere Backup, kann ich das gleiche Prozedere nun mit dem 10/2024 Backup durchspielen?
                            2. Aktuell komme ich nicht auf die Vis-Oberfläche.
                              Bei "http://192.168.178.65:8082/vis/edit.html" sagt der "File edit.html not found: {}"
                              Instanz vis.0 zeigt wenn man auf Einstellungen klickt:
                            Nochmal Danke!
                            Thomas BraunT B 2 Antworten Letzte Antwort
                            • B Bene241
                              @bene241
                              iob update
                              iob upgrade all -y
                              Vielen vielen Dank.
                              Nochmal Danke!
                              @bene241 sagte in ioBroker Web nach Backitup nicht erreichbar:
                              An deinem steinalten System. Halt die Kiste R E G E L M Ä S S I G auf Stand.
                              • B Bene241
                                @bene241
                                iob update
                                iob upgrade all -y
                                Vielen vielen Dank.
                                Nochmal Danke!
                                Bene241
                                Nochmal Danke!
                                Zu 1:
                                Hat funktioniert, mit dem gleichen Weg wie oben mit dem älteren Update.
                                Zu 2:
                                Funktioniert nun auch wieder nach dem aufspielen des neueren Backups.
                                Danke an Alle!
                                Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
                                • B Bene241
                                  Nochmal Danke!
                                  Zu 1:
                                  Zu 2:
                                  Danke an Alle!
                                  Meister MopperM Online
                                  Meister Mopper
                                  Danke an Alle!
                                  Na dann setze bitte den thread im Titel auf [gelöst], dann können andere ebenfalls profitieren.
                                  Proxmox und HA ...
                                  • B Bene241
                                    Nochmal Danke!
                                    Zu 1:
                                    Zu 2:
                                    Danke an Alle!
                                    @bene241
                                    Dann zeig jetzt nochmal abschließend
                                    iob diag
                                    Die Zusammenfassung reicht.
                                      @bene241
                                      iob diag
                                      Bene241
                                      @bene241
                                      iob diag
                                      Copy text starting here:
                                      ```bash
                                                              v.2024-08-12
                                             Icon name: computer
                                          Architecture: arm64
                                      Kernel:                 aarch64
                                      Userland:               64 bit
                                      User-ID:                1000
                                      Pending OS-Updates:     0
                                      Pending iob updates:    0
                                      Nodejs-Installation:
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      Recommended versions are nodejs 20.18.0 and npm 10.8.2
                                      MEMORY:
                                      Mem:            4.0G        2.0G        484M        282K        1.5G        2.0G
                                      Swap:           209M        1.0M        208M
                                      Total:          4.2G        2.0G        692M
                                      Active iob-Instances:   28
                                      ioBroker Core:          js-controller           6.0.11
                                                              admin                   7.1.5
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                9307
                                      States:                 7580
                                      Size of iob-Database:
                                      25M     /opt/iobroker/iobroker-data/objects.jsonl
                                      13M     /opt/iobroker/iobroker-data/states.jsonl
                                      • B Bene241
                                        @bene241
                                        iob diag
                                        ```bash
        v.2024-08-12
                                               Icon name: computer
                                            Architecture: arm64
                                        Kernel:                 aarch64
                                        Userland:               64 bit
                                        User-ID:                1000
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        MEMORY:
        admin                   7.1.5
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                9307
                                        States:                 7580
                                        @bene241
                                        Passt. Ab jetzt regelmäßig aktuell halten und auch regelmäßig Backups machen.
                                        Mit dem Backitup-Adapter kann man das automatisch vornehmen lassen.
