  4. Blink Camera System
Blink Camera System
blink xtcamera
407 Beiträge 63 Kommentatoren 166.2k Aufrufe 65 Beobachtet
    @gurke258
    Das war auch nicht die Langfassung.
    Also nochmal, nachdem nodejs repariert ist.
    Gurke258G Offline
    Gurke258G Offline
    Gurke258
    #371
    @thomas-braun sagte in Blink Camera System:
    @gurke258
    Sorry. Hier bitte :)
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: HomePi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     10:25:29 up  5:25,  2 users,  load average: 1.50, 1.40, 1.31
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2023-11-05 10:25:29 CET
               Universal time: Sun 2023-11-05 09:25:29 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	true
    Desktop: 	LXDE-pi
    Terminal: 	x11
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            3.8G        2.3G        505M        164M        965M        1.2G
    Swap:            99M          0B         99M
    Total:          3.9G        2.3G        605M
             3794 M total memory
             2323 M used memory
             2886 M active memory
               65 M inactive memory
              504 M free memory
                9 M buffer memory
              956 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   14G   15G  48% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G   20M  1.9G   2% /dev/shm
    tmpfs          tmpfs     759M  976K  758M   1% /run
    /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
    tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
    [Sun Nov  5 05:00:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:63:9E:04 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=0f229ca1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Nov  5 05:00:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Nov  5 05:00:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Nov  5 05:00:26 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    5.4G	/var/
    3.1G	/var/log/journal/c82d6a18bd344322b99e963f9b19b8e6
    3.1G	/var/log
    1.8G	/var/cache/apt
    Archived and active journals take up 3.0G in the file system.
    /opt/iobroker/backups:
    106M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    668M	/opt/iobroker/iobroker-data/
    498M	/opt/iobroker/iobroker-data/files
    98M	/opt/iobroker/iobroker-data/files/vis-2-beta
    72M	/opt/iobroker/iobroker-data/files/telegram.admin
    71M	/opt/iobroker/iobroker-data/node-red/node_modules
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M	/opt/iobroker/iobroker-data/objects.jsonl
    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.18.2
    /usr/bin/node 		v18.18.2
    /usr/bin/npm 		9.8.1
    /usr/bin/npx 		9.8.1
    /usr/bin/corepack 	0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.12
    admin: 		6.12.0
    javascript: 	7.1.4
    Adapters from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : HomePi                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : HomePi                                   -  enabled
    + system.adapter.backitup.0               : backitup              : HomePi                                   -  enabled
    + system.adapter.bring.0                  : bring                 : HomePi                                   -  enabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: HomePi                                   -  enabled
      system.adapter.daswetter.0              : daswetter             : HomePi                                   -  enabled
      system.adapter.devices.0                : devices               : HomePi                                   - disabled
    + system.adapter.discovergy.0             : discovergy            : HomePi                                   -  enabled
    + system.adapter.discovery.0              : discovery             : HomePi                                   -  enabled
      system.adapter.dwd.0                    : dwd                   : HomePi                                   -  enabled
    + system.adapter.ham.0                    : ham                   : HomePi                                   -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : HomePi                                   -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : HomePi                                   -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : HomePi                                   -  enabled, port: 12001
      system.adapter.ical.0                   : ical                  : HomePi                                   -  enabled
      system.adapter.ical.1                   : ical                  : HomePi                                   -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : HomePi                                   -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : HomePi                                   - disabled
      system.adapter.influxdb.0               : influxdb              : HomePi                                   - disabled, port: 8086
    + system.adapter.info.0                   : info                  : HomePi                                   -  enabled
    + system.adapter.iot.0                    : iot                   : HomePi                                   -  enabled
    + system.adapter.javascript.0             : javascript            : HomePi                                   -  enabled
    + system.adapter.netatmo.0                : netatmo               : HomePi                                   -  enabled
    + system.adapter.nina.0                   : nina                  : HomePi                                   -  enabled
    + system.adapter.node-red.0               : node-red              : HomePi                                   -  enabled, port: 1880, bind: 192.168.178.79
    + system.adapter.ping.0                   : ping                  : HomePi                                   -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : HomePi                                   -  enabled
    + system.adapter.smartthings.0            : smartthings           : HomePi                                   -  enabled
      system.adapter.spotify-premium.0        : spotify-premium       : HomePi                                   - disabled
    + system.adapter.synology.0               : synology              : HomePi                                   -  enabled, port: 5001
      system.adapter.systeminfo.0             : systeminfo            : HomePi                                   - disabled
      system.adapter.tankerkoenig.0           : tankerkoenig          : HomePi                                   - disabled
    + system.adapter.telegram.0               : telegram              : HomePi                                   -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : HomePi                                   -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : HomePi                                   -  enabled
    + system.adapter.tuya.0                   : tuya                  : HomePi                                   -  enabled
      system.adapter.vis-2-beta.0             : vis-2-beta            : HomePi                                   - disabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : HomePi                                   -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : HomePi                                   -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: HomePi                                   -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : HomePi                                   -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomePi                                   - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : HomePi                                   - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : HomePi                                   -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomePi                                   - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : HomePi                                   - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : HomePi                                   - disabled
      system.adapter.vis-metro.0              : vis-metro             : HomePi                                   - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : HomePi                                   -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : HomePi                                   - disabled
      system.adapter.vis.0                    : vis                   : HomePi                                   -  enabled
    + system.adapter.web.0                    : web                   : HomePi                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "adguard"      : 0.0.8    , installed 0.0.8
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.25.5   , installed 3.25.5
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hid-community": 0.3.0    , installed 0.3.0
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "tibberlink"   : 1.4.1    , installed 1.4.1
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
    Adapter    "withings"     : 0.0.13   , installed 0.0.13
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Objects and States
    Objects: 	15792
    States: 	13665
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15591      542/cupsd
    tcp        0      0 192.168.178.79:18701    0.0.0.0:*               LISTEN      1001       280874     29233/io.hm-rpc.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       280609     29088/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       280616     29088/iobroker.js-c
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          16404      578/vncserver-x11-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13802      606/sshd: /usr/sbin
    tcp        0      0 192.168.178.79:1880     0.0.0.0:*               LISTEN      1001       279873     29195/node-red
    tcp        0      0 192.168.178.79:12001    0.0.0.0:*               LISTEN      1001       280923     29256/io.hm-rpc.1
    tcp6       0      0 :::3310                 :::*                    LISTEN      115        15720      661/mariadbd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15590      542/cupsd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       278103     29109/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       283724     29863/io.web.0
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          16403      578/vncserver-x11-c
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13804      606/sshd: /usr/sbin
    tcp6       0      0 :::80                   :::*                    LISTEN      0          16428      687/apache2
    udp        0      0 0.0.0.0:53157           0.0.0.0:*                           108        14400      407/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16455      485/dhcpcd
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       279265     29478/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       279266     29478/io.tuya.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14572      666/cups-browsed
    udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       303130     32252/chromium-brow
    udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       303128     32252/chromium-brow
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14398      407/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13950      485/dhcpcd
    udp6       0      0 :::37916                :::*                                108        14401      407/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14399      407/avahi-daemon: r
    2023-11-05 10:19:34.236  - info: ham.0 (32072) updateState Blink-Blink-Flur.Blink-Flur-Privacy-Mode.Name: value = Blink Flur Privacy Mode /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
    2023-11-05 10:19:34.259  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-Flur.Blink-Flur-Privacy-Mode.Name {"val":"Blink Flur Privacy Mode","ack":true,"ts":1699175968047,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1693823092789}
    2023-11-05 10:19:34.306  - info: ham.0 (32072) updateState Blink-Blink-Flur.Blink-Flur-Privacy-Mode.On: value = false /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
    2023-11-05 10:19:34.334  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-Flur.Blink-Flur-Privacy-Mode.On {"val":false,"ack":true,"ts":1699175968067,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1693823092845}
    2023-11-05 10:19:37.943  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699175977940,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699175977940}
    2023-11-05 10:19:41.270  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699175981267,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699175977940}
    2023-11-05 10:19:56.106  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":false,"ts":1699175996101,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699175996101}
    2023-11-05 10:19:56.129  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":true,"ts":1699175996125,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699175996101}
    2023-11-05 10:20:00.062  - info: host.HomePi instance system.adapter.dwd.0 started with pid 32168
    2023-11-05 10:20:03.699  - info: dwd.0 (32168) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
    2023-11-05 10:20:06.936  - info: dwd.0 (32168) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-05 10:20:07.480  - info: host.HomePi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-05 10:20:36.192  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699176036188,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176036188}
    2023-11-05 10:20:36.215  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699176036210,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176036188}
    2023-11-05 10:20:41.279  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":false,"ts":1699176041276,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176041276}
    2023-11-05 10:20:44.229  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":true,"ts":1699176044225,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176041276}
    2023-11-05 10:20:53.611  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699176053606,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176053606}
    2023-11-05 10:20:53.683  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699176053678,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176053606}
    2023-11-05 10:21:32.141  - info: web.0 (29863) ==> Connected system.user.admin from ::ffff:192.168.178.79
    2023-11-05 10:23:41.482  - info: admin.0 (29109) ==> Connected system.user.admin from ::ffff:192.168.178.123
    2023-11-05 10:23:49.815  - info: admin.0 (29109) <== Disconnect system.user.admin from ::ffff:192.168.178.123
    2023-11-05 10:25:00.062  - info: host.HomePi instance system.adapter.dwd.0 started with pid 32832
    2023-11-05 10:25:03.554  - info: dwd.0 (32832) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
    2023-11-05 10:25:06.028  - info: dwd.0 (32832) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-05 10:25:06.573  - info: host.HomePi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    [/s]
      @gurke258 sagte in Blink Camera System:
      Deswegen wollte ich die alte Version mal testen
      Die alte blinkpy-Version vor dem breaking change? Die kann man mit sudo pip install blinkpy==0.21.0 installieren. Musste ich auch machen, weil ich das Skript auf die v0.22.0 nicht angepasst bekommen habe.
      @Thomas-Braun: Gibt es für die Erstellung einer Bildaufnahme eine funktionierende Vorlage? Dann würde ich es vielleicht noch einmal mit der neuen Version testen.
      Meine 'bild.py' für v0.21.0 sieht so aus:
      import requests
      from blinkpy.blinkpy import Blink
      from blinkpy.auth import Auth
      from blinkpy.camera import BlinkCamera
      blink = Blink()
      auth = Auth({"username": "******", "password": "*******"}, no_prompt=True)
      blink.auth = auth
      blink.start()
      auth.send_auth_key(blink, "******")
      blink.setup_post_verify()
      bild = '/opt/iobroker/blink.jpg'
      for name, camera in blink.cameras.items(): print(name), print(camera.attributes)
      camera = blink.cameras['Eingangstuere']
      camera.snap_picture()
      blink.refresh()
      camera.image_to_file(bild)
      Gurke258G Offline
      Gurke258G Offline
      Gurke258
      #372
      @dr-bakterius
      Da habe ich leider nach wie vor den selben Fehler...
      from blinkpy.blinkpy import Blink ImportError: No module named blinkpy.blinkpy
      Trotz dem 0.21.0 :(
      Naja ich habe dank @Pischleuder erstmal ne Lösung und muss denke ich auch mal von bullseye auf Bookworm wechseln mim Pi4
        import requests
        blink = Blink()
        blink.auth = auth
        blink.start()
        blink.refresh()
        PischleuderP Online
        PischleuderP Online
        Pischleuder
        #373
        @dr-bakterius sagte in Blink Camera System:
        import requests
        blink = Blink()
        blink.auth = auth
        blink.start()
        blink.refresh()
        Moin,
        nein - ich hatte dieses script damals zusammengedängelt, mir aber nicht die Mühe gemacht, das auf die neue blinkpy umzusetzen, da es immer noch keinen livestream support geben wird.
        Dr. BakteriusD 1 Antwort Letzte Antwort
        • PischleuderP Pischleuder
          import requests
          blink = Blink()
          blink.auth = auth
          blink.start()
          blink.refresh()
          Moin,
          Dr. BakteriusD Offline
          Dr. Bakterius
          #374
          @pischleuder sagte in Blink Camera System:
          Verstehe. Allerdings haben alle die die aktuelle v0.22.0 installieren dann das Problem, dass das Skript nicht tut. Ich hatte zwar versucht es nach der Beschreibung auf Git-Hub anzupassen, bin aber gescheitert. Für meinen Zweck würde es schon reichen ein Bild aufzunehmen und am gewünschten Ort zu speichern. Livestream ist mit Batterie ohnehin eine weniger gute Idee und könnte ich ja immer noch mit der Blink-App haben.
          PischleuderP 1 Antwort Letzte Antwort
            PischleuderP Online
            PischleuderP Online
            Pischleuder
            #375
            @dr-bakterius
            ja, das Problem ist nur, dass Module benötigt werden, die in der aktuellen Python-Version (3.11) noch nicht enthalten sind und man kann diese nicht so ohne weiteres über pip nachladen. Lediglich als venv Variante. Der Aufwand ist derzeit zum Nutzen einfach zu hoch.
            • Dr. BakteriusD Offline
              Dr. Bakterius
              #376
              Ich grabe diesen Thread aus aktuellem Anlass wieder aus.
              Seit irgendwann im April hat Blinkpy nicht mehr funktioniert, weil Amazon bei der Anmeldung etwas geändert hat und dadurch jedes Mal ein neuer 2FA Code gesendet wurde. Das wurde auch auf GitHub behandelt (https://github.com/fronzbot/blinkpy/issues/917). Inzwischen dürfte es eine Lösung geben die ich hier gerne zusammenfassen möchte. Vielleicht nützt es ja jemandem.
              Aktuell muss man folgende beiden Skripte von GitHub herunterladen und bei sich im Ordner /home/<user>/.local/lib/python3.11/site-packages/blinkpy ersetzen: auth.py und blinkpy.py.
              Man erstellt einmalig ein Skript (z.B. anmelden.py) mit folgendem Inhalt:
              import asyncio
              from aiohttp import ClientSession
              async def start():
                  blink = Blink(session=ClientSession())
                  # Can set no_prompt when initializing auth handler
                  auth = Auth({"username": <your username>, "password": <your password>}, no_prompt=True)
                  blink.auth = auth
                  await blink.start()
                  await blink.save("/opt/iobroker/blink_auth.json")
                  return blink
              blink = asyncio.run(start())
              Wenn man dieses von der Console aufruft
              python3.11 anmelden.py
              , wird man nach seinen Anmeldedaten gefragt und erhält dann den 2FA Code welchen man angibt. Anschließend wird in /opt/iobroker die Datei blink_auth.json erstellt. Diese enthält die Anmeldedaten für künftige Abfragen. Danach kann man das Skript wenn man möchte wieder löschen.
              Um jetzt ein Bild abzufragen braucht man folgendes Skript:
              import asyncio
              from blinkpy.helpers.util import json_load
              async def start():
                  blink = Blink()
                  auth = Auth(await json_load("/opt/iobroker/blink_auth.json"))   # Anmeldeinformationen laden
                  blink.auth = auth   # Anmeldeinformationen senden
                  await blink.start()   # Verbindung starten
                  camera = blink.cameras['<Kameraname>']   # Kameraname angeben
                  await camera.snap_picture()   # Bild aufnehmen
                  await blink.refresh()   # Daten vom Blink-Server abfragen
                  await camera.image_to_file('/opt/iobroker/blink.jpg')   # Bild speichern
                  return blink
              Leider ist es mir nicht gelungen das Skript mit exec (JS oder Blockly) wegen fehlender Berechtigung aufzurufen. Ich habe das dann mit dem Linux-Control Adapter gelöst.
              F D 2 Antworten Letzte Antwort
                import asyncio
                async def start():
                    blink.auth = auth
                    await blink.start()
                    return blink
                import asyncio
                async def start():
                    blink = Blink()
                    return blink
                Flowski
                #377
                gibt es mittlerweile eine Möglichkeit auf die Bilder der Cam zuzugreifen??
                • F Flowski
                  Dr. Bakterius
                  #378
                  @flowski Geht doch wie oben beschrieben.
                  F 2 Antworten Letzte Antwort
                    Flowski
                    #379
                    @dr-bakterius said in Blink Camera System:
                    oh wow das habe ich wohl übersehen, bzw. inhaltlich garnicht wirklich begriffen, befinde mich noch in den Anfängen des ganzen... wie zuverlässig läuft das ganze? Sind die Bilder auch schnell verfügbar dass es auch Sinn macht?
                    • F Flowski
                      Dr. Bakterius
                      #380
                      @flowski Was ist schnell? Ich lasse mir die Bilder mit Pushover ans Handy schicken. Das dauert etwa 15 Sekunden. Der Verbinungsaufbau meiner Blink Outdoor dauert alleine schon 10-12 Sekunden.
                      F 1 Antwort Letzte Antwort
                        Flowski
                        #381
                        @dr-bakterius : 15 sek. empfinde ich als schnell von daher würde das passen.
                          Flowski
                          #382
                          @dr-bakterius gibt es da irgendwo eine Anleitung für Dummies zu? Mit meinem Wissensstand kriege ich das leider nicht gebacken vermute ich :(
                          • L Offline
                            line
                            #383
                            Hallo, kann mir jemand sagen, ob sich die Blink Outdoor Kamaras nun in den Iobroker integrieren lassen mit einem Adapter? Also ich will nur in meinem IQontrol das bild von der Kamara sehen. Ist dies nun möglich? Momentan sind Prime Days und preislich interessant.
                            • F Flowski
                              Dr. Bakterius
                              #384
                              @flowski Einfach probieren. Wenn es wo hakt, beschreiben was nicht geht (Fehlermeldung oder Screenshot). Eine Schritt-für-Schritt Anleitung kenne ich nicht.
                              L F 2 Antworten Letzte Antwort
                                line
                                #385
                                @dr-bakterius dann entscheide ich mich evt. Doch lieber für eine IP Kamera. Hoffentlich geht das besser, wie die von Blink
                                • L line
                                  Dr. Bakterius
                                  #386
                                  @line sagte in Blink Camera System:
                                  Ja, wenn das in deiner Situation möglich ist, ist das sicher die bessere Wahl. Ich würde aber darauf achten nicht von einer Cloud abhängig zu sein. Also lieber ein paar Euro mehr investieren.
                                    Flowski
                                    #387
                                    @dr-bakterius danke für das Angebot.. werde mich morgen dransetzen. Zum Verständnis, das erstellen der Scripte erledige ich alles unter Scripte -> Java Script... und für das Aufrufen dann über den Linux controller?
                                    • F Flowski
                                      Dr. Bakterius
                                      #388
                                      @flowski Nein, du installierst auf der Linux-Konsole erst Python und dann mittels pip install blinkpy die eigentliche Software. Ich glaube, dass der Austausch der beiden Dateien inzwischen nicht mehr notwendig sein wird.
                                      Danach erstellst du (z.B. mit nano) die beiden Skripte die du natürlich auf deine Gegebenheiten anpasst. Das erste Skript musst du nur einmal aufrufen um die Anmeldedaten zu speichern. Das zweite kannst du dann per cron, händisch oder mit dem linux-control Adapter aufrufen wenn du eine Aufnahme speichern möchtest. Dieses Bild kannst du dann wie gewünscht versenden oder archivieren.
                                      Also mit der Konsole solltest du nicht auf Kriegsfuß stehen... 😊
                                      V 1 Antwort Letzte Antwort
                                        V Offline
                                        V Offline
                                        varg
                                        schrieb am zuletzt editiert von varg
                                        #389
                                        Frickel schon bei der Installation seit ner Stunde rum 👌
                                        pi@iobroker:~ $ pip install blinkpy
                                        error: externally-managed-environment
                                        × This environment is externally managed
                                        ╰─> To install Python packages system-wide, try apt install
                                            python3-xyz, where xyz is the package you are trying to
                                            install.
                                            If you wish to install a non-Debian-packaged Python package,
                                            create a virtual environment using python3 -m venv path/to/venv.
                                            Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                                            sure you have python3-full installed.
                                            For more information visit http://rptl.io/venv
                                        note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
                                        hint: See PEP 668 for the detailed specification.
                                        pi@iobroker:~ $ ^C
                                        Egal was ich mache ich kann das ding nicht installieren. Evtl. hat mir jemand einen Tip ?
                                        Dr. BakteriusD V 2 Antworten Letzte Antwort
                                        • V varg
                                              install.
                                          pi@iobroker:~ $ ^C
                                          Dr. Bakterius
                                          #390
                                          @varg Steht doch in der Meldung. Du benötigst python. Hast du das installiert?
