  4. Blink Camera System
Blink Camera System
blink xtcamera
407 Beiträge 63 Kommentatoren 166.3k Aufrufe 65 Beobachtet
  • Gurke258G Gurke258
    pipx geht bei mmir nicht:
    pi@HomePi:~ $ sudo apt update
    OK:1 http://security.debian.org/debian-security bullseye-security InRelease
    OK:2 http://deb.debian.org/debian bullseye InRelease
    OK:3 http://deb.debian.org/debian bullseye-updates InRelease
    OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Holen:5 https://deb.nodesource.com/node_14.x bullseye InRelease [4.586 B]
    Es wurden 4.586 B in 2 s geholt (2.264 B/s).
    Abhängigkeitsbaum wird aufgebaut... Fertig
    Statusinformationen werden eingelesen... Fertig
    Alle Pakete sind aktuell.
    pi@HomePi:~ $ sudo apt install pipx
    E: Paket pipx kann nicht gefunden werden.
    pi@HomePi:~ $
    und mit pip3 ist es installiert:
    pi@HomePi:~ $ pip3 install blinkpy
    Defaulting to user installation because normal site-packages is not writeable
    Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
    Requirement already satisfied: blinkpy in ./.local/lib/python3.9/site-packages (0.22.2)
    Requirement already satisfied: python-dateutil>=2.8.1 in ./.local/lib/python3.9/site-packages (from blinkpy) (2.8.2)
    Requirement already satisfied: requests>=2.24.0 in /usr/lib/python3/dist-packages (from blinkpy) (2.25.1)
    Requirement already satisfied: python-slugify>=4.0.1 in ./.local/lib/python3.9/site-packages (from blinkpy) (8.0.1)
    Requirement already satisfied: sortedcontainers~=2.4.0 in ./.local/lib/python3.9/site-packages (from blinkpy) (2.4.0)
    Requirement already satisfied: aiohttp>=3.8.4 in ./.local/lib/python3.9/site-packages (from blinkpy) (3.8.6)
    Requirement already satisfied: aiofiles>=23.1.0 in ./.local/lib/python3.9/site-packages (from blinkpy) (23.2.1)
    Requirement already satisfied: attrs>=17.3.0 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (23.1.0)
    Requirement already satisfied: charset-normalizer<4.0,>=2.0 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (3.3.2)
    Requirement already satisfied: multidict<7.0,>=4.5 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (6.0.4)
    Requirement already satisfied: async-timeout<5.0,>=4.0.0a3 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (4.0.3)
    Requirement already satisfied: yarl<2.0,>=1.0 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (1.9.2)
    Requirement already satisfied: frozenlist>=1.1.1 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (1.4.0)
    Requirement already satisfied: aiosignal>=1.1.2 in ./.local/lib/python3.9/site-packages (from aiohttp>=3.8.4->blinkpy) (1.3.1)
    Requirement already satisfied: six>=1.5 in /usr/lib/python3/dist-packages (from python-dateutil>=2.8.1->blinkpy) (1.16.0)
    Requirement already satisfied: text-unidecode>=1.3 in ./.local/lib/python3.9/site-packages (from python-slugify>=4.0.1->blinkpy) (1.3)
    Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp>=3.8.4->blinkpy) (2.10)
    pi@HomePi:~ $
    #355
    @gurke258 sagte in Blink Camera System:
    node_14
    Bring das dringend auf nodejs@18.
    pipx gibt es für Bullseye nicht, erst ab 'Bookworm'.
    • Gurke258G Offline
      Gurke258G Offline
      Gurke258
      #356
      Ist eig auf 18 ^^
      Aber dann muss ich mal schauen das ich den ioBroker sichern kann und auch dann auf dem neuen OS wiederherstellen kann ^^
        Ist eig auf 18 ^^
        #357
        @gurke258
        Das ist die FALSCHE Version. Das ist die dfsg-Version.
        iob stop
        iob fix
        iob nodejs-update
        iob start
          leider wird ja der IFTTT Service von Amazon nicht mehr unterstützt, weswegen ich jetzt wieder auf die „alte“ Variante zurückgreifen muss. Vorher hatte ich es über Homebridge.
          Bedauerlicherweise bekomme ich es aber nicht mehr installiert. Habe mir alles von Github geklont, aber die setup.py fehlt leider. Somit funktioniert die alte Anleitung nicht mehr und auch mit
          Gehts nicht.
          Bekomme immer folgende Meldung:
          from blinkpy.blinkpy import Blink ImportError: No module named blinkpy.blinkpy
          Hier ist mein Code:
          #!/usr/bin/python3
          from blinkpy.auth import Auth
          blink = Blink()
          auth = Auth({"username": "steven.XXXXXXX@YXXX", "password": "XXXXXX"}, no_prompt=True)
          blink.auth = auth
          blink.start()
          auth.send_auth_key(blink, "EuerKey")
          blink.setup_post_verify()
          blink.sync['XXXXX'].arm = True
          Hat da jmd ne Lösung für mich?
          EDIT:
          Habs in den Ordner blinkpy kopiert und dort ausgeführt aber bekomme trotzdem ne Fehlermeldung:_
          Traceback (most recent call last):
            File "blinkarm.py", line 2, in <module>
            File "/home/pi/blinkpy/blinkpy/blinkpy.py", line 83
              async def refresh(self, force=False, force_cache=False):
          SyntaxError: invalid syntax
          Gurke258G Offline
          Gurke258G Offline
          Gurke258
          #358
          Okay ist jetzt geupdatet auf 18 ;)
          bekomme aber noch immer den gleichen fehler
          Gehts nicht.
          Hier ist mein Code:
          #!/usr/bin/python3
          blink = Blink()
          blink.auth = auth
          blink.start()
          EDIT:
            Gehts nicht.
            Hier ist mein Code:
            #!/usr/bin/python3
            blink = Blink()
            blink.auth = auth
            blink.start()
            EDIT:
            #359
            @gurke258
            Gib mal die Langfassung von
            iob diag
            bekannt.
            Gurke258G 1 Antwort Letzte Antwort
              Gehts nicht.
              Hier ist mein Code:
              #!/usr/bin/python3
              blink = Blink()
              blink.auth = auth
              blink.start()
              EDIT:
              #360
              @gurke258
              Die Readme hast du gelesen?
              BREAKING CHANGE WARNING: As of 0.22.0 the library uses asyncio which will break any user scripts used prior to this version. Please see the updated examples below and the blinkapp.py or blinksync.py examples in the blinkapp/ directory for examples on how to migrate.
              Quelle: https://github.com/fronzbot/blinkpy
                @gurke258
                iob diag
                bekannt.
                Gurke258G Offline
                Gurke258G Offline
                Gurke258
                #361
                @thomas-braun sagte in Blink Camera System:
                @gurke258
                iob diag
                bekannt.
                Copy text starting here:
                			v.2023-10-10
                   Static hostname: HomePi
                         Icon name: computer
                  Operating System: Debian GNU/Linux 11 (bullseye)
                            Kernel: Linux 6.1.21-v8+
                      Architecture: arm64
                Installation: 		native
                Kernel: 		aarch64
                Userland: 		arm64
                Timezone: 		Europe/Berlin (CET, +0100)
                User-ID: 		1000
                X-Server: 		true
                Boot Target: 		graphical.target
                Pending OS-Updates: 	0
                Pending iob updates: 	0
                Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
                			/usr/local/bin/node 		v18.13.0
                			/usr/local/bin/npm 		8.19.3
                			/usr/local/bin/npx 		8.19.3
                			/usr/local/bin/corepack 	0.15.2
                Recommended versions are nodejs 18.18.2 and npm 9.8.1
                *** nodejs is NOT correctly installed ***
                Wrong installation path detected. This needs to be fixed.
                Please check
                https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                for more information on how to fix these errors.
                MEMORY:
                Mem:            3.8G        2.0G        484M         69M        1.3G        1.6G
                Swap:            99M          0B         99M
                Total:          3.9G        2.0G        584M
                Active iob-Instances: 	27
                Active repo(s): stable
                ioBroker Core: 		js-controller 		5.0.12
                			admin 			6.12.0
                ioBroker Status: 	iobroker is running on this host.
                Objects type: jsonl
                States  type: jsonl
                + system.adapter.admin.0                  : admin                 : HomePi                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.web.0                    : web                   : HomePi                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                Objects: 		15766
                States: 		13659
                Size of iob-Database:
                15M	/opt/iobroker/iobroker-data/objects.jsonl
                18M	/opt/iobroker/iobroker-data/states.jsonl
                Er sagt immer noch das es nicht korrekt installiert wurde :/
                  @gurke258
                  Gurke258G Offline
                  Gurke258G Offline
                  Gurke258
                  #362
                  @gurke258
                  Hatte ich gelesen und getestet aber auch da nen fehler bekommen. Deswegen wollte ich die alte Version mal testen
                  Thomas BraunT PischleuderP Dr. BakteriusD 4 Antworten Letzte Antwort
                    @gurke258
                    #363
                    @gurke258
                    Schalt den DESKTOP aus.
                    Und nodejs ist noch falsch installiert.
                    iob nodejs-update
                    Da dann die Pfade reparieren lassen.
                      @gurke258
                      #364
                      @gurke258
                      Das war auch nicht die Langfassung.
                      Also nochmal, nachdem nodejs repariert ist.
                        @gurke258
                        PischleuderP Online
                        PischleuderP Online
                        Pischleuder
                        #365
                        @gurke258
                        Moin,
                        die Frage ist, was willst Du noch mit dem alten script ? Das wird so nicht mehr funktionieren, da sich die syntax zum einloggen etc. etwas verändert hat.
                        Nutze doch einfach das homebridge plugin, sofern Du die Anlage scharf oder unscharf schalten möchtest.
                        Gruss
                        • PischleuderP Pischleuder
                          @gurke258
                          Moin,
                          Gruss
                          Gurke258G Offline
                          Gurke258G Offline
                          Gurke258
                          #366
                          @pischleuder sagte in Blink Camera System:
                          @gurke258
                          Moin,
                          Gruss
                          Ja mit dem Homebridge funktioniert es bei mir nicht mehr :/ Keine ahnung warum :/
                          PischleuderP 1 Antwort Letzte Antwort
                            @gurke258
                            Moin,
                            Gruss
                            PischleuderP Online
                            PischleuderP Online
                            Pischleuder
                            schrieb am zuletzt editiert von Pischleuder
                            #367
                            @gurke258
                            welches npm Modul hast Du denn in der Homebridge Instanz eingegeben ?
                            Es sollte homebridge-blink-for-home@3.9.2 dort stehen und die Instanz im Wrapper Modus
                            starten.
                            in der Konfig dann so:
                            "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                            "accessories": [],
                            "platforms": [
                            "name": "Blink",
                            "username": "Email-Adresse",
                            "password": "Dein Passwort",
                            "pin": "Deine Pin",
                            "platform": "Blink"
                              @gurke258
                              Dr. BakteriusD Online
                              Dr. Bakterius
                              #368
                              Die alte blinkpy-Version vor dem breaking change? Die kann man mit sudo pip install blinkpy==0.21.0 installieren. Musste ich auch machen, weil ich das Skript auf die v0.22.0 nicht angepasst bekommen habe.
                              @Thomas-Braun: Gibt es für die Erstellung einer Bildaufnahme eine funktionierende Vorlage? Dann würde ich es vielleicht noch einmal mit der neuen Version testen.
                              Meine 'bild.py' für v0.21.0 sieht so aus:
                              import requests
                              from blinkpy.camera import BlinkCamera
                              blink = Blink()
                              auth = Auth({"username": "******", "password": "*******"}, no_prompt=True)
                              blink.auth = auth
                              blink.start()
                              auth.send_auth_key(blink, "******")
                              bild = '/opt/iobroker/blink.jpg'
                              for name, camera in blink.cameras.items(): print(name), print(camera.attributes)
                              camera = blink.cameras['Eingangstuere']
                              camera.snap_picture()
                              blink.refresh()
                              camera.image_to_file(bild)
                              Thomas BraunT Gurke258G PischleuderP 3 Antworten Letzte Antwort
                                @gurke258
                                starten.
                                "accessories": [],
                                "platforms": [
                                "name": "Blink",
                                "pin": "Deine Pin",
                                "platform": "Blink"
                                Gurke258G Offline
                                Gurke258G Offline
                                Gurke258
                                schrieb am zuletzt editiert von Gurke258
                                #369
                                @gurke258
                                starten.
                                "accessories": [],
                                "platforms": [
                                "name": "Blink",
                                "pin": "Deine Pin",
                                "platform": "Blink"
                                So habe ich es jetzt eingestellt aber ich bekomme in der Config folgende Meldung:
                                Either the "platform" or "accessory" property must be set
                                EDIT: Okay ich denke ich habe es hinbekommen!.. Ist aber sehr träge im Vergleich zu vorher. :/
                                  import requests
                                  blink = Blink()
                                  blink.auth = auth
                                  blink.start()
                                  blink.refresh()
                                  #370
                                  @dr-bakterius sagte in Blink Camera System:
                                  Keine Ahnung. Ich hab keine Blink Camera im Einsatz.
                                    @gurke258
                                    Gurke258G Offline
                                    Gurke258G Offline
                                    Gurke258
                                    #371
                                    @gurke258
                                    Sorry. Hier bitte :)
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Model		: Raspberry Pi 4 Model B Rev 1.1
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : aarch64
                                    Userland        : arm64
                                    Systemuptime and Load:
                                     10:25:29 up  5:25,  2 users,  load average: 1.50, 1.40, 1.31
                                    CPU threads: 4
                                    *** RASPBERRY THROTTLING ***
                                    Current issues:
                                    Previously detected issues:
                                    *** Time and Time Zones ***
                                                   Local time: Sun 2023-11-05 10:25:29 CET
                                               Universal time: Sun 2023-11-05 09:25:29 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** User and Groups ***
                                    pi
                                    /home/pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                    *** X-Server-Setup ***
                                    X-Server: 	true
                                    Desktop: 	LXDE-pi
                                    Terminal: 	x11
                                    *** MEMORY ***
                                    Mem:            3.8G        2.3G        505M        164M        965M        1.2G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        2.3G        605M
                                             3794 M total memory
                                             2323 M used memory
                                             2886 M active memory
                                               65 M inactive memory
                                              504 M free memory
                                                9 M buffer memory
                                              956 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FAILED SERVICES ***
                                    0 loaded units listed.
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       29G   14G   15G  48% /
                                    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                    tmpfs          tmpfs     1.9G   20M  1.9G   2% /dev/shm
                                    tmpfs          tmpfs     759M  976K  758M   1% /run
                                    /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
                                    tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
                                    [Sun Nov  5 05:00:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:63:9E:04 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=0f229ca1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                    [Sun Nov  5 05:00:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Sun Nov  5 05:00:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Sun Nov  5 05:00:26 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    TARGET  SOURCE         FSTYPE OPTIONS
                                    /       /dev/mmcblk0p2 ext4   rw,noatime
                                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                    /var:
                                    5.4G	/var/
                                    3.1G	/var/log/journal/c82d6a18bd344322b99e963f9b19b8e6
                                    3.1G	/var/log
                                    1.8G	/var/cache/apt
                                    Archived and active journals take up 3.0G in the file system.
                                    /opt/iobroker/backups:
                                    106M	/opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    668M	/opt/iobroker/iobroker-data/
                                    498M	/opt/iobroker/iobroker-data/files
                                    98M	/opt/iobroker/iobroker-data/files/vis-2-beta
                                    72M	/opt/iobroker/iobroker-data/files/telegram.admin
                                    71M	/opt/iobroker/iobroker-data/node-red/node_modules
                                    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                    21M	/opt/iobroker/iobroker-data/objects.jsonl
                                    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                                    19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                                    18M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                                    USB-Devices by-id:
                                    find: '/dev/serial/by-id/': No such file or directory
                                    *** NodeJS-Installation ***
                                    /usr/bin/node 		v18.18.2
                                    /usr/bin/npm 		9.8.1
                                    /usr/bin/npx 		9.8.1
                                    /usr/bin/corepack 	0.19.0
                                    nodejs:
                                      Installed: 18.18.2-1nodesource1
                                      Candidate: 18.18.2-1nodesource1
                                      Version table:
                                     *** 18.18.2-1nodesource1 1001
                                            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                         18.18.1-1nodesource1 1001
                                         18.18.0-1nodesource1 1001
                                         18.17.1-1nodesource1 1001
                                         18.17.0-1nodesource1 1001
                                         18.16.1-1nodesource1 1001
                                         18.16.0-1nodesource1 1001
                                         18.15.0-1nodesource1 1001
                                         18.14.2-1nodesource1 1001
                                         18.14.1-1nodesource1 1001
                                         18.14.0-1nodesource1 1001
                                         18.13.0-1nodesource1 1001
                                         18.12.0-1nodesource1 1001
                                         18.11.0-1nodesource1 1001
                                         18.10.0-1nodesource1 1001
                                         18.9.1-1nodesource1 1001
                                         18.9.0-1nodesource1 1001
                                         18.8.0-1nodesource1 1001
                                         18.7.0-1nodesource1 1001
                                         18.6.0-1nodesource1 1001
                                         18.5.0-1nodesource1 1001
                                         18.4.0-1nodesource1 1001
                                         18.3.0-1nodesource1 1001
                                         18.2.0-1nodesource1 1001
                                         18.1.0-1nodesource1 1001
                                         18.0.0-1nodesource1 1001
                                         12.22.12~dfsg-1~deb11u4 500
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                    No problems detected
                                    Errors in npm tree:
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Core adapters versions
                                    js-controller: 	5.0.12
                                    admin: 		6.12.0
                                    javascript: 	7.1.4
                                    Adapters from github: 	0
                                    Adapter State
                                    + system.adapter.alexa2.0                 : alexa2                : HomePi                                   -  enabled
                                    + system.adapter.backitup.0               : backitup              : HomePi                                   -  enabled
                                    + system.adapter.bring.0                  : bring                 : HomePi                                   -  enabled
                                      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: HomePi                                   -  enabled
                                      system.adapter.daswetter.0              : daswetter             : HomePi                                   -  enabled
                                      system.adapter.devices.0                : devices               : HomePi                                   - disabled
                                    + system.adapter.discovergy.0             : discovergy            : HomePi                                   -  enabled
                                    + system.adapter.discovery.0              : discovery             : HomePi                                   -  enabled
                                      system.adapter.dwd.0                    : dwd                   : HomePi                                   -  enabled
                                    + system.adapter.ham.0                    : ham                   : HomePi                                   -  enabled
                                    + system.adapter.hm-rega.0                : hm-rega               : HomePi                                   -  enabled
                                    + system.adapter.hm-rpc.0                 : hm-rpc                : HomePi                                   -  enabled, port: 18701
                                    + system.adapter.hm-rpc.1                 : hm-rpc                : HomePi                                   -  enabled, port: 12001
                                      system.adapter.ical.0                   : ical                  : HomePi                                   -  enabled
                                      system.adapter.ical.1                   : ical                  : HomePi                                   -  enabled
                                      system.adapter.icons-material-svg.0     : icons-material-svg    : HomePi                                   -  enabled
                                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : HomePi                                   - disabled
                                      system.adapter.influxdb.0               : influxdb              : HomePi                                   - disabled, port: 8086
                                    + system.adapter.info.0                   : info                  : HomePi                                   -  enabled
                                    + system.adapter.iot.0                    : iot                   : HomePi                                   -  enabled
                                    + system.adapter.javascript.0             : javascript            : HomePi                                   -  enabled
                                    + system.adapter.netatmo.0                : netatmo               : HomePi                                   -  enabled
                                    + system.adapter.nina.0                   : nina                  : HomePi                                   -  enabled
                                    + system.adapter.node-red.0               : node-red              : HomePi                                   -  enabled, port: 1880, bind: 192.168.178.79
                                    + system.adapter.ping.0                   : ping                  : HomePi                                   -  enabled
                                    + system.adapter.rpi2.0                   : rpi2                  : HomePi                                   -  enabled
                                    + system.adapter.smartthings.0            : smartthings           : HomePi                                   -  enabled
                                      system.adapter.spotify-premium.0        : spotify-premium       : HomePi                                   - disabled
                                    + system.adapter.synology.0               : synology              : HomePi                                   -  enabled, port: 5001
                                      system.adapter.systeminfo.0             : systeminfo            : HomePi                                   - disabled
                                      system.adapter.tankerkoenig.0           : tankerkoenig          : HomePi                                   - disabled
                                    + system.adapter.telegram.0               : telegram              : HomePi                                   -  enabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.text2command.0           : text2command          : HomePi                                   -  enabled
                                    + system.adapter.trashschedule.0          : trashschedule         : HomePi                                   -  enabled
                                    + system.adapter.tuya.0                   : tuya                  : HomePi                                   -  enabled
                                      system.adapter.vis-2-beta.0             : vis-2-beta            : HomePi                                   - disabled
                                      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : HomePi                                   -  enabled
                                      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : HomePi                                   -  enabled
                                      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: HomePi                                   -  enabled
                                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : HomePi                                   -  enabled
                                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomePi                                   - disabled
                                      system.adapter.vis-icontwo.0            : vis-icontwo           : HomePi                                   - disabled
                                    + system.adapter.vis-inventwo.0           : vis-inventwo          : HomePi                                   -  enabled
                                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomePi                                   - disabled
                                      system.adapter.vis-keyboard.0           : vis-keyboard          : HomePi                                   - disabled
                                      system.adapter.vis-material-advanced.0  : vis-material-advanced : HomePi                                   - disabled
                                      system.adapter.vis-metro.0              : vis-metro             : HomePi                                   - disabled
                                      system.adapter.vis-rgraph.0             : vis-rgraph            : HomePi                                   -  enabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : HomePi                                   - disabled
                                      system.adapter.vis.0                    : vis                   : HomePi                                   -  enabled
                                    + instance is alive
                                    ioBroker-Repositories
                                    Installed ioBroker-Instances
                                    Used repository: stable
                                    Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                                    Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                    Adapter    "alexa2"       : 3.25.5   , installed 3.25.5
                                    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                                    Adapter    "bring"        : 1.8.4    , installed 1.8.4
                                    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                                    Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                    Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
                                    Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                    Adapter    "hid-community": 0.3.0    , installed 0.3.0
                                    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                                    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                                    Adapter    "ical"         : 1.13.3   , installed 1.13.3
                                    Adapter    "info"         : 2.0.0    , installed 2.0.0
                                    Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                    Controller "js-controller": 5.0.12   , installed 5.0.12
                                    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                    Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                                    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                                    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                                    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
                                    Adapter    "synology"     : 3.0.1    , installed 3.0.1
                                    Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
                                    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                                    Adapter    "text2command" : 3.0.2    , installed 3.0.2
                                    Adapter    "tibberlink"   : 1.4.1    , installed 1.4.1
                                    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                                    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                                    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                                    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                    Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
                                    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                                    Adapter    "withings"     : 0.0.13   , installed 0.0.13
                                    Adapter    "ws"           : 2.5.5    , installed 2.5.5
                                    Objects and States
                                    Objects: 	15792
                                    States: 	13665
                                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                                    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                    Reading package lists...
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15591      542/cupsd
                                    tcp        0      0 192.168.178.79:18701    0.0.0.0:*               LISTEN      1001       280874     29233/io.hm-rpc.0
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       280609     29088/iobroker.js-c
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       280616     29088/iobroker.js-c
                                    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          16404      578/vncserver-x11-c
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13802      606/sshd: /usr/sbin
                                    tcp        0      0 192.168.178.79:1880     0.0.0.0:*               LISTEN      1001       279873     29195/node-red
                                    tcp        0      0 192.168.178.79:12001    0.0.0.0:*               LISTEN      1001       280923     29256/io.hm-rpc.1
                                    tcp6       0      0 :::3310                 :::*                    LISTEN      115        15720      661/mariadbd
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15590      542/cupsd
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       278103     29109/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       283724     29863/io.web.0
                                    tcp6       0      0 :::5900                 :::*                    LISTEN      0          16403      578/vncserver-x11-c
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13804      606/sshd: /usr/sbin
                                    tcp6       0      0 :::80                   :::*                    LISTEN      0          16428      687/apache2
                                    udp        0      0 0.0.0.0:53157           0.0.0.0:*                           108        14400      407/avahi-daemon: r
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16455      485/dhcpcd
                                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       279265     29478/io.tuya.0
                                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       279266     29478/io.tuya.0
                                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14572      666/cups-browsed
                                    udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       303130     32252/chromium-brow
                                    udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       303128     32252/chromium-brow
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14398      407/avahi-daemon: r
                                    udp6       0      0 :::546                  :::*                                0          13950      485/dhcpcd
                                    udp6       0      0 :::37916                :::*                                108        14401      407/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                108        14399      407/avahi-daemon: r
                                    2023-11-05 10:19:34.236  - info: ham.0 (32072) updateState Blink-Blink-Flur.Blink-Flur-Privacy-Mode.Name: value = Blink Flur Privacy Mode /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                    2023-11-05 10:19:34.259  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-Flur.Blink-Flur-Privacy-Mode.Name {"val":"Blink Flur Privacy Mode","ack":true,"ts":1699175968047,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1693823092789}
                                    2023-11-05 10:19:34.306  - info: ham.0 (32072) updateState Blink-Blink-Flur.Blink-Flur-Privacy-Mode.On: value = false /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
                                    2023-11-05 10:19:34.334  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-Flur.Blink-Flur-Privacy-Mode.On {"val":false,"ack":true,"ts":1699175968067,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1693823092845}
                                    2023-11-05 10:19:37.943  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699175977940,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699175977940}
                                    2023-11-05 10:19:41.270  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699175981267,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699175977940}
                                    2023-11-05 10:19:56.106  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":false,"ts":1699175996101,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699175996101}
                                    2023-11-05 10:19:56.129  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":true,"ts":1699175996125,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699175996101}
                                    2023-11-05 10:20:00.062  - info: host.HomePi instance system.adapter.dwd.0 started with pid 32168
                                    2023-11-05 10:20:03.699  - info: dwd.0 (32168) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
                                    2023-11-05 10:20:06.936  - info: dwd.0 (32168) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-11-05 10:20:07.480  - info: host.HomePi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2023-11-05 10:20:36.192  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699176036188,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176036188}
                                    2023-11-05 10:20:36.215  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699176036210,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176036188}
                                    2023-11-05 10:20:41.279  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":false,"ts":1699176041276,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176041276}
                                    2023-11-05 10:20:44.229  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":true,"ack":true,"ts":1699176044225,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176041276}
                                    2023-11-05 10:20:53.611  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":false,"ts":1699176053606,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1699176053606}
                                    2023-11-05 10:20:53.683  - info: ham.0 (32072) stateChange ham.0.Blink-Blink-GurkenHome.Blink-GurkenHome-Arm.On {"val":false,"ack":true,"ts":1699176053678,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699176053606}
                                    2023-11-05 10:21:32.141  - info: web.0 (29863) ==> Connected system.user.admin from ::ffff:192.168.178.79
                                    2023-11-05 10:23:41.482  - info: admin.0 (29109) ==> Connected system.user.admin from ::ffff:192.168.178.123
                                    2023-11-05 10:23:49.815  - info: admin.0 (29109) <== Disconnect system.user.admin from ::ffff:192.168.178.123
                                    2023-11-05 10:25:00.062  - info: host.HomePi instance system.adapter.dwd.0 started with pid 32832
                                    2023-11-05 10:25:03.554  - info: dwd.0 (32832) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
                                    2023-11-05 10:25:06.028  - info: dwd.0 (32832) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-11-05 10:25:06.573  - info: host.HomePi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    [/s]
                                      import requests
                                      blink = Blink()
                                      blink.auth = auth
                                      blink.start()
                                      blink.refresh()
                                      Gurke258G Offline
                                      Gurke258G Offline
                                      Gurke258
                                      #372
                                      @dr-bakterius
                                      Da habe ich leider nach wie vor den selben Fehler...
                                      Trotz dem 0.21.0 :(
                                      Naja ich habe dank @Pischleuder erstmal ne Lösung und muss denke ich auch mal von bullseye auf Bookworm wechseln mim Pi4
                                        import requests
                                        blink = Blink()
                                        blink.auth = auth
                                        blink.start()
                                        blink.refresh()
                                        PischleuderP Online
                                        PischleuderP Online
                                        Pischleuder
                                        #373
                                        import requests
                                        blink = Blink()
                                        blink.auth = auth
                                        blink.start()
                                        blink.refresh()
                                        Moin,
                                        nein - ich hatte dieses script damals zusammengedängelt, mir aber nicht die Mühe gemacht, das auf die neue blinkpy umzusetzen, da es immer noch keinen livestream support geben wird.
                                        Dr. BakteriusD 1 Antwort Letzte Antwort
                                          import requests
                                          blink = Blink()
                                          blink.auth = auth
                                          blink.start()
                                          blink.refresh()
                                          Moin,
                                          Dr. Bakterius
                                          #374
                                          Verstehe. Allerdings haben alle die die aktuelle v0.22.0 installieren dann das Problem, dass das Skript nicht tut. Ich hatte zwar versucht es nach der Beschreibung auf Git-Hub anzupassen, bin aber gescheitert. Für meinen Zweck würde es schon reichen ein Bild aufzunehmen und am gewünschten Ort zu speichern. Livestream ist mit Batterie ohnehin eine weniger gute Idee und könnte ich ja immer noch mit der Blink-App haben.
