  4. Fehler in host.raspberryPi
36 Beiträge 3 Kommentatoren 4.2k Aufrufe 2 Beobachtet
    @werner2000x sagte in Fehler in host.raspberryPi:
    Display-Server: true
    Boot Target: graphical.target
    OHNE Desktop.
    werner2000xW Offline
    werner2000x
    @thomas-braun Jetzt ohne Desktop:
                            v.2024-05-22
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.1.21-v8+
        Architecture: arm64
    Kernel:                 aarch64
    Userland:               64 bit
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    36
    Nodejs-Installation:
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    npm:                    N/A
    npx:                    N/A
    corepack:       N/A
    Recommended versions are nodejs  and npm
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please execute
    iobroker nodejs-update
    to fix these errors.
    MEMORY:
    Mem:            8.2G        2.1G        5.1G        1.3M        1.2G        6.1G
    Swap:           104M          0B        104M
    Total:          8.3G        2.1G        5.2G
    Active iob-Instances:   14
    Active repo(s): stable
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                4543
    States:                 3654
    Size of iob-Database:
    16M     /opt/iobroker/iobroker-data/objects.jsonl
    7.1M    /opt/iobroker/iobroker-data/states.jsonl
    Raspi4 8 GB mit Aqara Zigbee USB, iob
    Innogy Smarthome
    Bosch Bridge 2
    HUE Bridge
    OpenWB Wallbox mit EVU Kit
    Google Nest Pro Hub
    HA auf uGreen dxp4800
    • werner2000xW werner2000x
                              v.2024-05-22
             Icon name: computer
          Architecture: arm64
      Kernel:                 aarch64
      Userland:               64 bit
      User-ID:                1000
      npm:                    N/A
      npx:                    N/A
      corepack:       N/A
      Please execute
      MEMORY:
      Swap:           104M          0B        104M
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                4543
      States:                 3654
      iob nodejs-update 20
      Und dann die Updates reinschaufeln.
                                v.2024-05-22
               Icon name: computer
            Architecture: arm64
        Kernel:                 aarch64
        Userland:               64 bit
        User-ID:                1000
        npm:                    N/A
        npx:                    N/A
        corepack:       N/A
        Please execute
        MEMORY:
        Swap:           104M          0B        104M
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                4543
        States:                 3654
        @werner2000x
        Wie schafft man es eigentlich, den ioBroker zu installieren, dann aber bei nodejs irgendwas krummes an Land zu ziehen?
        • werner2000xW Offline
          werner2000x
          @thomas-braun Ich habe die Installation über eine alt 64 Bit Version mit Bullseye gestartet.
          Mit iob diag erhalte ich jetzt` ``
          *** iob diag is starting up, please wait ***
          The state system.host.raspberrypi.versions.nodeNewestNext was not found!
          The state system.host.raspberrypi.versions.npmNewestNext was not found!
          The state system.host.raspberrypi.versions.nodeCurrent was not found!
          Innogy Smarthome
          Bosch Bridge 2
          HUE Bridge
          Google Nest Pro Hub
            Das funktioniert NICHT.
            RaspberryOS 12 'Bookworm' muss KOMPLETT NEUINSTALLIERT WERDEN!
              werner2000x
              schrieb am zuletzt editiert von werner2000x
              @thomas-braun Ich habe die lite version von bookworm installiert, kann mich aber mit keinem login anmelden, obwohl ich einen datei userconf mit login daten erstell habe. Eine SSH Verbindung klappt, jedoch fehlen mit die login daten.
              Wie geht das jetzt bei bookworm?
              Innogy Smarthome
              Bosch Bridge 2
              HUE Bridge
              Google Nest Pro Hub
                ??? Wie sonst auch.
                Was machst du da? Welche Datei 'userconf'?
                Mach es danach:
                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                Da wird dann auch ein user und auch der ssh-Server eingerichtet.
                  werner2000x
                  @thomas-braun Jetzt gabe ich die SD Card neu aufgesetzt.
                  Der Info Adapter konnte nicht gestartet werden, das habe ich Ihn gelöscht.
                  Wie kann man ihn neu installieren?
                  Innogy Smarthome
                  Bosch Bridge 2
                  HUE Bridge
                  Google Nest Pro Hub
                    Gar nicht. Der wird nicht mehr unterstützt.
                    werner2000xW 1 Antwort Letzte Antwort
                      werner2000x
                      @thomas-braun Der RPI Adapter hat noch Fehlermeldungen:
                      rpi2.0
                      2024-09-14 12:51:42.705	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 8780528 107384372 8% / /1024
                      Innogy Smarthome
                      Bosch Bridge 2
                      HUE Bridge
                      Google Nest Pro Hub
                        rpi2.0
                        HomoranH Offline
                        HomoranH Offline
                        welche Version?
                          rpi2.0
                          Nicht in der Version 2..0. Kann sein das die aber noch Beta ist.
                            werner2000x
                            @thomas-braun Ich habe die Version 2.0
                            Innogy Smarthome
                            Bosch Bridge 2
                            HUE Bridge
                            Google Nest Pro Hub
                              Kann eigentlich nicht sein. Das falsche parsing wurde da korrigiert.
                              iob diag
                              in der Langfassung liefert?
                                iob diag
                                werner2000x
                                @thomas-braun Der Fehler ist noch da:
                                2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) VALUE: 204796 POST: (rpi.swap_total - $1)/1024
                                2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.swap.swap_used VALUE = 0
                                2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) CURRENT = temperature true
                                2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) -1
                                2024-09-19 11:54:10.936 - debug: rpi2.0 (4899) ---> POST: $1/1000 for soc_temp in [object Object]
                                2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) VALUE: 66218 POST: $1/1000
                                2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.temperature.soc_temp VALUE = 66.22
                                2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) CURRENT = uptime true
                                2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) -1
                                2024-09-19 11:54:10.937 - debug: rpi2.0 (4899) ---> POST: for uptime in [object Object]
                                2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.uptime.uptime VALUE = 1511
                                2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) CURRENT = wlan true
                                2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) -1
                                2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) ---> POST: $1*-1 for wifi_received in [object Object]
                                2024-09-19 11:54:10.938 - debug: rpi2.0 (4899) VALUE: 0 POST: $1*-1
                                2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.wlan.wifi_received VALUE = 0
                                2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) ---> POST: for wifi_send in [object Object]
                                2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) SETSTATE FOR rpi2.0.wlan.wifi_send VALUE = 0
                                2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) CURRENT = gpios undefined
                                2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) -1
                                2024-09-19 11:54:10.939 - debug: rpi2.0 (4899) CURRENT = inputPullUp undefined
                                2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) -1
                                2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) CURRENT = inputDebounceMs undefined
                                2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) CURRENT = buttonPullUp undefined
                                2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) CURRENT = buttonDebounceMs undefined
                                2024-09-19 11:54:10.940 - debug: rpi2.0 (4899) CURRENT = buttonPressMs undefined
                                2024-09-19 11:54:10.941 - debug: rpi2.0 (4899) -1
                                2024-09-19 11:54:10.941 - debug: rpi2.0 (4899) CURRENT = buttonDoubleMs undefined
                                2024-09-19 11:54:10.941 - debug: rpi2.0 (4899) CURRENT = dhtPollInterval undefined
                                2024-09-19 11:54:11.197 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.cpu_frequency found state = {"val":1800,"ack":true,"ts":1726739651194,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739427963}
                                2024-09-19 11:54:11.239 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.load1 found state = {"val":0.7,"ack":true,"ts":1726739651236,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651236}
                                2024-09-19 11:54:11.241 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.load5 found state = {"val":0.61,"ack":true,"ts":1726739651236,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651236}
                                2024-09-19 11:54:11.244 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.load15 found state = {"val":0.82,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                2024-09-19 11:54:11.245 - debug: rpi2.0 (4899) stateChange for rpi2.0.cpu.scaling_governor found state = {"val":"ondemand","ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972151}
                                2024-09-19 11:54:11.247 - debug: rpi2.0 (4899) stateChange for rpi2.0.raspberry.cpu_voltage found state = {"val":0.92,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739427964}
                                2024-09-19 11:54:11.251 - debug: rpi2.0 (4899) stateChange for rpi2.0.raspberry.mem_arm found state = {"val":948,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310982794}
                                2024-09-19 11:54:11.252 - debug: rpi2.0 (4899) stateChange for rpi2.0.raspberry.mem_gpu found state = {"val":76,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310982794}
                                2024-09-19 11:54:11.254 - debug: rpi2.0 (4899) stateChange for rpi2.0.memory.memory_total found state = {"val":7809.97,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972151}
                                2024-09-19 11:54:11.256 - debug: rpi2.0 (4899) stateChange for rpi2.0.memory.memory_free found state = {"val":4582.61,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                2024-09-19 11:54:11.259 - debug: rpi2.0 (4899) stateChange for rpi2.0.memory.memory_available found state = {"val":5839.04,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                2024-09-19 11:54:11.260 - debug: rpi2.0 (4899) stateChange for rpi2.0.network.net_received found state = {"val":-195147982,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                2024-09-19 11:54:11.262 - debug: rpi2.0 (4899) stateChange for rpi2.0.network.net_send found state = {"val":45400627,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                2024-09-19 11:54:11.264 - debug: rpi2.0 (4899) stateChange for rpi2.0.sdcard.sdcard_root_total found state = {"val":119529.39,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972153}
                                2024-09-19 11:54:11.265 - debug: rpi2.0 (4899) stateChange for rpi2.0.sdcard.sdcard_boot_total found state = {"val":null,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                2024-09-19 11:54:11.267 - debug: rpi2.0 (4899) stateChange for rpi2.0.sdcard.sdcard_root_used found state = {"val":13036.82,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                2024-09-19 11:54:11.269 - debug: rpi2.0 (4899) stateChange for rpi2.0.sdcard.sdcard_boot_used found state = {"val":null,"ack":true,"ts":1726739651237,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651237}
                                2024-09-19 11:54:11.276 - debug: rpi2.0 (4899) stateChange for rpi2.0.swap.swap_total found state = {"val":200,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972163}
                                2024-09-19 11:54:11.277 - debug: rpi2.0 (4899) stateChange for rpi2.0.swap.swap_used found state = {"val":0,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972164}
                                2024-09-19 11:54:11.279 - debug: rpi2.0 (4899) stateChange for rpi2.0.temperature.soc_temp found state = {"val":66.22,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651238}
                                2024-09-19 11:54:11.281 - debug: rpi2.0 (4899) stateChange for rpi2.0.uptime.uptime found state = {"val":1511,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726739651238}
                                2024-09-19 11:54:11.283 - debug: rpi2.0 (4899) stateChange for rpi2.0.wlan.wifi_received found state = {"val":0,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972164}
                                2024-09-19 11:54:11.284 - debug: rpi2.0 (4899) stateChange for rpi2.0.wlan.wifi_send found state = {"val":0,"ack":true,"ts":1726739651238,"q":0,"from":"system.adapter.rpi2.0","user":"system.user.admin","lc":1726310972226}
                                Innogy Smarthome
                                Bosch Bridge 2
                                HUE Bridge
                                Google Nest Pro Hub
                                  @werner2000x
                                  Ich seh da keine Fehler der Art
                                    werner2000x
                                    @thomas-braun Der Log war zu kurz:
                                    pi2.0
                                    2024-09-19 12:19:10.905	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13321100 102843800 12% / /1024
                                    rpi2.0
                                    2024-09-19 12:19:10.904	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13321100 102843800 12% / /1024
                                    rpi2.0
                                    2024-09-19 12:18:10.928	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13320888 102844012 12% / /1024
                                    rpi2.0
                                    2024-09-19 12:18:10.927	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13320888 102844012 12% / /1024
                                    rpi2.0
                                    2024-09-19 12:17:10.907	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13320584 102844316 12% / /1024
                                    rpi2.0
                                    2024-09-19 12:17:10.905	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13320584 102844316 12% / /1024
                                    rpi2.0
                                    2024-09-19 12:16:10.904	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
                                    rpi2.0
                                    2024-09-19 12:16:10.903	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
                                    Innogy Smarthome
                                    Bosch Bridge 2
                                    HUE Bridge
                                    Google Nest Pro Hub
                                      pi2.0
                                      rpi2.0
                                      rpi2.0
                                      rpi2.0
                                      rpi2.0
                                      rpi2.0
                                      rpi2.0
                                      rpi2.0
                                      @werner2000x
                                      cd /opt/iobroker
                                      npm ls
                                        @werner2000x
                                        cd /opt/iobroker
                                        npm ls
                                        werner2000x
                                        Ausgabe:
                                        :/opt/iobroker $ npm ls
                                        iobroker.inst@3.0.0 /opt/iobroker
                                        ├── @emnapi/runtime@1.2.0 extraneous
                                        ├── iobroker.admin@7.1.1
                                        ├── iobroker.alexa2@3.26.5
                                        ├── iobroker.alias-manager@1.2.6
                                        ├── iobroker.backitup@3.0.22
                                        ├── iobroker.ble@0.14.0
                                        ├── iobroker.bshb@0.2.8
                                        ├── iobroker.chromecast@3.4.1
                                        ├── iobroker.cloud@5.0.1
                                        ├── iobroker.daikin-cloud@0.4.8
                                        ├── iobroker.denon@1.15.12
                                        ├── iobroker.device-reminder@3.1.2
                                        ├── iobroker.discovery@5.0.0
                                        ├── iobroker.echarts@1.7.2
                                        ├── iobroker.email@1.3.1
                                        ├── iobroker.energiefluss@3.6.0
                                        ├── iobroker.flot@1.12.0
                                        ├── iobroker.fritzbox@0.6.0
                                        ├── iobroker.fritzdect@2.5.11
                                        ├── iobroker.heos@2.2.1
                                        ├── iobroker.history@3.0.1
                                        ├── iobroker.homeconnect@1.4.1
                                        ├── iobroker.hue@3.12.0
                                        ├── iobroker.ical@1.15.0
                                        ├── iobroker.icons-fatcow-hosting@0.1.0
                                        ├── iobroker.icons-icons8@0.0.1
                                        ├── iobroker.icons-material-png@0.1.0
                                        ├── iobroker.icons-mfd-svg@1.2.0
                                        ├── iobroker.influxdb@4.0.2
                                        ├── iobroker.innogy-smarthome@1.2.6
                                        ├── iobroker.iot@3.3.0
                                        ├── iobroker.iqontrol@2.3.0
                                        ├── iobroker.jarvis@3.1.8
                                        ├── iobroker.javascript@8.7.6
                                        ├── iobroker.js-controller@6.0.11
                                        ├── iobroker.lovelace@4.1.10
                                        ├── iobroker.material@1.3.1
                                        ├── iobroker.meross@1.17.0
                                        ├── iobroker.mqtt@5.2.0
                                        ├── iobroker.net-tools@1.0.11
                                        ├── iobroker.node-red@5.2.1
                                        ├── iobroker.openweathermap@1.1.2
                                        ├── iobroker.parser@2.2.2
                                        ├── iobroker.pushover@4.1.0
                                        ├── iobroker.pvforecast@3.0.0
                                        ├── iobroker.ring@5.1.0
                                        ├── iobroker.rpi2@1.3.2
                                        ├── iobroker.simple-api@2.8.0
                                        ├── iobroker.socketio@6.7.1
                                        ├── iobroker.systeminfo@1.2.0
                                        ├── iobroker.text2command@3.0.3
                                        ├── iobroker.tr-064@4.3.0
                                        ├── iobroker.trashschedule@3.3.0
                                        ├── iobroker.tuya@3.16.0
                                        ├── iobroker.vis-2-widgets-energy@1.0.0
                                        ├── iobroker.vis-2-widgets-gauges@1.1.0
                                        ├── iobroker.vis-2-widgets-material@1.4.8
                                        ├── iobroker.vis-2@2.9.32
                                        ├── iobroker.vis-bars@0.1.4
                                        ├── iobroker.vis-canvas-gauges@1.0.1
                                        ├── iobroker.vis-colorpicker@2.0.3
                                        ├── iobroker.vis-fancyswitch@1.1.0
                                        ├── iobroker.vis-history@1.0.0
                                        ├── iobroker.vis-hqwidgets@1.5.1
                                        ├── iobroker.vis-icontwo@1.5.0
                                        ├── iobroker.vis-inventwo@3.3.4
                                        ├── iobroker.vis-jqui-mfd@1.1.1
                                        ├── iobroker.vis-justgage@2.1.7
                                        ├── iobroker.vis-map@1.1.2
                                        ├── iobroker.vis-material-advanced@1.7.4
                                        ├── iobroker.vis-material@0.1.3
                                        ├── iobroker.vis-materialdesign@0.5.9
                                        ├── iobroker.vis-metro@1.2.0
                                        ├── iobroker.vis-timeandweather@1.2.2
                                        ├── iobroker.vis@1.5.6
                                        ├── iobroker.web@6.2.5
                                        └── iobroker.ws@2.6.2
                                        pi@raspberrypi:/opt/iobroker $
                                        Innogy Smarthome
                                        Bosch Bridge 2
                                        HUE Bridge
                                        Google Nest Pro Hub
                                          Ausgabe:
                                          werner2000x
                                          @werner2000x Heute immer noch der selbe Fehler:
                                          rpi2.0
                                          2024-09-20 17:49:56.547	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13640780 102524120 12% / /1024
                                          rpi2.0
                                          2024-09-20 17:49:56.535	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 13640780 102524120 12% / /1024
                                          rpi2.0
                                          2024-09-20 17:48:56.304	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
                                          rpi2.0
                                          2024-09-20 17:48:56.302	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on/dev/mmcblk0p2 122398100 13640584 102524316 12% //1024
                                          Innogy Smarthome
                                          Bosch Bridge 2
                                          HUE Bridge
                                          Google Nest Pro Hub
