  4. Fehler in host.raspberryPi
36 Beiträge 3 Kommentatoren 4.2k Aufrufe 2 Beobachtet
    @werner2000x
    ls -l /opt/iobroker/node_modules/iobroker.js-controller/pids.txt
    Aber da scheint dir die Datei abhanden gekommen zu sein.
    werner2000xW Offline
    werner2000x
    @thomas-braun iob diag:
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 32 bit
    Systemuptime and Load:
     20:32:16 up 75 days,  1:36,  2 users,  load average: 2.20, 1.01, 0.97
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    *** Time and Time Zones ***
                   Local time: Tue 2024-09-10 20:32:17 CEST
               Universal time: Tue 2024-09-10 18:32:17 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev bluetooth lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=users tty dialout sudo audio video plugdev ssh bluetooth gpio i2c
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        3.9G        950M        0.0K        3.0G        4.0G
    Swap:            99M         36M         63M
    Total:          7.9G        3.9G        1.0G
    Active iob-Instances:   50
             7812 M total memory
             3886 M used memory
             1324 M active memory
             4992 M inactive memory
              950 M free memory
              143 M buffer memory
             2831 M swap cache
               99 M total swap
               36 M used swap
               63 M free swap
    top - 20:32:17 up 75 days,  1:36,  2 users,  load average: 2.10, 1.01, 0.97
    Tasks: 212 total,   3 running, 209 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 12.3 us,  5.5 sy,  0.0 ni, 82.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7812.3 total,    951.2 free,   3885.8 used,   2975.3 buff/cache
    MiB Swap:    100.0 total,     63.2 free,     36.8 used.   4032.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      117G   40G   73G  35% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  820K  1.6G   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     782M   24K  782M   1% /run/user/1000
    [Thu Jun 27 18:55:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:C4:F8:86 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a7cf6190-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Jun 27 18:55:23 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Jun 27 18:55:23 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Jun 27 18:55:27 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET                       SOURCE         FSTYPE     OPTIONS
    /                            /dev/mmcblk0p2 ext4       rw,noatime
    |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=3735680k,nr_inodes=933920,mode=755
    | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
    | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
    |-/proc                      proc           proc       rw,relatime
    | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
    | `-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
    |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=1599964k,nr_inodes=819200,mode=755
    | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
    | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=799980k,nr_inodes=199995,mode=700,uid=1000,gid=1000
    `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    15G     /var/
    8.1G    /var/log
    5.1G    /var/cache/apt
    5.1G    /var/cache
    5.0G    /var/cache/apt/archives
    Archived and active journals take up 3.6G in the file system.
    /opt/iobroker/backups:
    5.9G    /opt/iobroker/backups/
    296K    /opt/iobroker/backups/scripte
    268K    /opt/iobroker/backups/scripte/Meine_Geräte
    252K    /opt/iobroker/backups/Meine_Geräte
    8.0K    /opt/iobroker/backups/scripte/common
    /opt/iobroker/iobroker-data:
    2.6G    /opt/iobroker/iobroker-data/
    1.4G    /opt/iobroker/iobroker-data/files
    834M    /opt/iobroker/iobroker-data/node-red
    833M    /opt/iobroker/iobroker-data/node-red/node_modules
    557M    /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow
    197M    /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow/tfjs-node/deps/lib/libtensorflow.so.2.5.0
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow/tfjs-node/deps/lib/libtensorflow_framework.so.2.5.0
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.4
    /usr/bin/node           v18.20.4
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.0
    nodejs:
      Installed: 18.20.4-1nodesource1
      Candidate: 18.20.4-1nodesource1
      Version table:
     *** 18.20.4-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.20.3-1nodesource1 1001
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.0.23
    javascript:     8.7.6
    nodejs modules from github:     0
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              -  enabled
    + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
    + system.adapter.bshb.0                   : bshb                  : raspberrypi                              -  enabled
    + system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
    + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
    + system.adapter.device-reminder.1        : device-reminder       : raspberrypi                              -  enabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
    + system.adapter.heos.0                   : heos                  : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
    + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 443
    + system.adapter.innogy-smarthome.0       : innogy-smarthome      : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
    + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
    + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
      system.adapter.material.0               : material              : raspberrypi                              - disabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1881, bind: 192.168.198.39
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
    + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
    + system.adapter.ring.0                   : ring                  : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartthings.0            : smartthings           : raspberrypi                              -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              -  enabled
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.tuya.1                   : tuya                  : raspberrypi                              - disabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │   name   │                           url                           │ auto upgrade │
    │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
    │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.23   , installed 7.0.23
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 3.0.22   , installed 3.0.22
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "bshb"         : 0.2.8    , installed 0.2.8
    Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
    Adapter    "daikin-cloud" : 0.4.8    , installed 0.4.8
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "heos"         : 2.2.1    , installed 2.2.1
    Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
    Adapter    "homekit-controller": 0.5.10, installed 0.5.10
    Adapter    "hue"          : 3.12.0   , installed 3.12.0
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "parser"       : 2.2.2    , installed 2.2.2
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
    Adapter    "ring"         : 5.1.0    , installed 5.1.0
    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
    Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
    Adapter    "vis-2-widgets-energy": 1.0.0, installed 1.0.0
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-material": 1.4.8, installed 1.4.8
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Objects and States
    Objects:        20187
    States:         15024
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://apt.grafana.com stable InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          207079122  29841/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       174940546  10877/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       174941426  10877/iobroker.js-c
    tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          15279      372/connmand
    tcp        0      0 192.168.198.39:1881     0.0.0.0:*               LISTEN      1001       174940039  11033/node-red
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13277      604/influxd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12174      572/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       174948372  11754/io.jarvis.0
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          13134      573/vncserver-x11-c
    tcp6       0      0 :::3000                 :::*                    LISTEN      115        172565314  32651/grafana
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       195168933  13480/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       174944003  11609/io.web.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       174948359  11866/io.simple-api
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        16620      604/influxd
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       174947735  11907/io.lovelace.0
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          14018      570/xrdp-sesman
    tcp6       0      0 :::3389                 :::*                    LISTEN      116        14065      583/xrdp
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          207079121  29841/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12176      572/sshd: /usr/sbin
    tcp6       0      0 ::1:53                  :::*                    LISTEN      0          15283      372/connmand
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          13133      573/vncserver-x11-c
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       174944273  11096/io.chromecast
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15224      345/avahi-daemon: r
    udp        0      0 0.0.0.0:58804           0.0.0.0:*                           1001       174948531  11966/io.heos.0
    udp        0      0 0.0.0.0:35087           0.0.0.0:*                           0          207323002  372/connmand
    udp        0      0 0.0.0.0:56449           0.0.0.0:*                           1001       174948532  11966/io.heos.0
    udp        0      0 0.0.0.0:44316           0.0.0.0:*                           108        15226      345/avahi-daemon: r
    udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          15271      372/connmand
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          209354836  372/connmand
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15349      433/dhcpcd
    udp        0      0 0.0.0.0:53413           0.0.0.0:*                           1001       174941677  11033/node-red
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          207077920  29842/cups-browsed
    udp        0      0 192.168.198.39:1194     0.0.0.0:*                           0          16389      603/openvpn
    udp6       0      0 :::5353                 :::*                                108        15225      345/avahi-daemon: r
    udp6       0      0 :::40133                :::*                                108        15227      345/avahi-daemon: r
    udp6       0      0 ::1:53                  :::*                                0          15275      372/connmand
    udp6       0      0 :::546                  :::*                                0          15431      433/dhcpcd
    Copy text starting here:
                            v.2024-05-22
             Icon name: computer
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               32 bit
    User-ID:                1000
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/nodejs         v18.20.4        /usr/bin/node           v18.20.4
    /usr/bin/npm            10.7.0        /usr/bin/npx            10.7.0
    Recommended versions are nodejs 20.17.0 and npm 10.8.2
    MEMORY:
    Mem:            7.8G        4.0G        817M        0.0K        3.0G        3.9G
    Swap:            99M         36M         63M
    Total:          7.9G        4.1G        880M
    ioBroker Core:          js-controller           6.0.11
                            admin                   7.0.23
    Objects type: jsonl
    States  type: jsonl
    Objects:                20187
    States:                 15024
    Size of iob-Database:
    15M     /opt/iobroker/iobroker-data/objects.json.migrated
    15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    21M     /opt/iobroker/iobroker-data/states.jsonl
    3.4M    /opt/iobroker/iobroker-data/states.json.migrated
    3.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    === Mark text until here for copying ===
    pi@raspberrypi:~ $
    Raspi4 8 GB mit Aqara Zigbee USB, iob
    Innogy Smarthome
    Bosch Bridge 2
    HUE Bridge
    OpenWB Wallbox mit EVU Kit
    Google Nest Pro Hub
    HA auf uGreen dxp4800
    • werner2000xW werner2000x
      Skript v.2024-05-22
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         36M         63M
               7812 M total memory
               3886 M used memory
                950 M free memory
                143 M buffer memory
               2831 M swap cache
                 99 M total swap
                 36 M used swap
                 63 M free swap
      *** FILESYSTEM ***
      /var:
      15G     /var/
      8.1G    /var/log
      5.1G    /var/cache/apt
      5.1G    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          7.0.23
      javascript:     8.7.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        20187
      States:         15024
      Pending Updates: 0
                              v.2024-05-22
               Icon name: computer
            Architecture: arm64
      Kernel:                 aarch64
      Userland:               32 bit
      User-ID:                1000
      MEMORY:
      Swap:            99M         36M         63M
                              admin                   7.0.23
      Objects type: jsonl
      States  type: jsonl
      Objects:                20187
      States:                 15024
      pi@raspberrypi:~ $
      @werner2000x sagte in Fehler in host.raspberryPi:
      Installier da NEU RaspberryOS 12 'Bookworm'.
      Und diesmal in der reinen 64Bit-Version.
      werner2000xW 1 Antwort Letzte Antwort
        werner2000x
        @thomas-braun kann das über die alte Installation gehen oder komplett neu?
        Innogy Smarthome
        Bosch Bridge 2
        HUE Bridge
        Google Nest Pro Hub
          @werner2000x
          Komplett von Grund auf NEU.
          Und in der Lite-Version, ohne Desktop.
            Skript v.2024-05-22
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : 32 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M         36M         63M
                     7812 M total memory
                     3886 M used memory
                      950 M free memory
                      143 M buffer memory
                     2831 M swap cache
                       99 M total swap
                       36 M used swap
                       63 M free swap
            *** FILESYSTEM ***
            /var:
            15G     /var/
            8.1G    /var/log
            5.1G    /var/cache/apt
            5.1G    /var/cache
            USB-Devices by-id:
            /usr/bin/npm            10.7.0
            /usr/bin/npx            10.7.0
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          7.0.23
            javascript:     8.7.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        20187
            States:         15024
            Pending Updates: 0
                                    v.2024-05-22
                     Icon name: computer
                  Architecture: arm64
            Kernel:                 aarch64
            Userland:               32 bit
            User-ID:                1000
            MEMORY:
            Swap:            99M         36M         63M
                                    admin                   7.0.23
            Objects type: jsonl
            States  type: jsonl
            Objects:                20187
            States:                 15024
            pi@raspberrypi:~ $
            HomoranH Offline
            HomoranH Offline
            und beschaff dir ein vernünftiges Netzteil
              @werner2000x
              werner2000x
              @thomas-braun Jetzt habe ich auf "Bookworm" aktualisiert, erhalte jedoch noch Fehler:
                                      v.2024-05-22
                     Icon name: computer
                  Architecture: arm64
              Kernel:                 aarch64
              Userland:               64 bit
              User-ID:                1000
              Display-Server:         true
              Pending iob updates:    36
              /usr/bin/nodejs         v18.19.0
              /usr/bin/node           v18.19.0
              npm:                    N/A
              npx:                    N/A
              corepack:       N/A
              Recommended versions are nodejs  and npm
              *** nodejs is NOT correctly installed ***
              Wrong installation path detected. This needs to be fixed.
              Please execute
              iobroker nodejs-update
              to fix these errors.
              MEMORY:
              Mem:            8.2G        2.0G        4.8G         22M        1.6G        6.2G
              Swap:           104M          0B        104M
              Total:          8.3G        2.0G        4.9G
              Active iob-Instances:   22
              ioBroker Core:          js-controller           4.0.24
                                      admin                   6.3.5
              Objects type: jsonl
              States  type: jsonl
                system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
              Objects:                4543
              States:                 3654
              16M     /opt/iobroker/iobroker-data/objects.jsonl
              5.7M    /opt/iobroker/iobroker-data/states.jsonl
              Innogy Smarthome
              Bosch Bridge 2
              HUE Bridge
              Google Nest Pro Hub
                                        v.2024-05-22
                       Icon name: computer
                    Architecture: arm64
                Kernel:                 aarch64
                Userland:               64 bit
                User-ID:                1000
                npm:                    N/A
                npx:                    N/A
                corepack:       N/A
                Please execute
                MEMORY:
                Swap:           104M          0B        104M
                                        admin                   6.3.5
                Objects type: jsonl
                States  type: jsonl
                Objects:                4543
                States:                 3654
                Boot Target: graphical.target
                OHNE Desktop.
                  OHNE Desktop.
                  werner2000x
                  @thomas-braun Jetzt ohne Desktop:
                                          v.2024-05-22
                         Icon name: computer
                      Architecture: arm64
                  Kernel:                 aarch64
                  Userland:               64 bit
                  User-ID:                1000
                  npm:                    N/A
                  npx:                    N/A
                  corepack:       N/A
                  Please execute
                  MEMORY:
                  Mem:            8.2G        2.1G        5.1G        1.3M        1.2G        6.1G
                  Swap:           104M          0B        104M
                  Total:          8.3G        2.1G        5.2G
                  Active iob-Instances:   14
                                          admin                   6.3.5
                  Objects type: jsonl
                  States  type: jsonl
                    system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  Objects:                4543
                  States:                 3654
                  7.1M    /opt/iobroker/iobroker-data/states.jsonl
                  Innogy Smarthome
                  Bosch Bridge 2
                  HUE Bridge
                  Google Nest Pro Hub
                                            v.2024-05-22
                           Icon name: computer
                        Architecture: arm64
                    Kernel:                 aarch64
                    Userland:               64 bit
                    User-ID:                1000
                    npm:                    N/A
                    npx:                    N/A
                    corepack:       N/A
                    Please execute
                    MEMORY:
                    Swap:           104M          0B        104M
                                            admin                   6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                4543
                    States:                 3654
                    iob nodejs-update 20
                    Und dann die Updates reinschaufeln.
                                              v.2024-05-22
                             Icon name: computer
                          Architecture: arm64
                      Kernel:                 aarch64
                      Userland:               64 bit
                      User-ID:                1000
                      npm:                    N/A
                      npx:                    N/A
                      corepack:       N/A
                      Please execute
                      MEMORY:
                      Swap:           104M          0B        104M
                                              admin                   6.3.5
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                4543
                      States:                 3654
                      @werner2000x
                      Wie schafft man es eigentlich, den ioBroker zu installieren, dann aber bei nodejs irgendwas krummes an Land zu ziehen?
                      • werner2000xW Offline
                        werner2000x
                        @thomas-braun Ich habe die Installation über eine alt 64 Bit Version mit Bullseye gestartet.
                        Mit iob diag erhalte ich jetzt` ``
                        *** iob diag is starting up, please wait ***
                        The state system.host.raspberrypi.versions.nodeNewestNext was not found!
                        The state system.host.raspberrypi.versions.npmNewestNext was not found!
                        The state system.host.raspberrypi.versions.nodeCurrent was not found!
                        Innogy Smarthome
                        Bosch Bridge 2
                        HUE Bridge
                        Google Nest Pro Hub
                          Das funktioniert NICHT.
                          RaspberryOS 12 'Bookworm' muss KOMPLETT NEUINSTALLIERT WERDEN!
                            werner2000x
                            schrieb am zuletzt editiert von werner2000x
                            @thomas-braun Ich habe die lite version von bookworm installiert, kann mich aber mit keinem login anmelden, obwohl ich einen datei userconf mit login daten erstell habe. Eine SSH Verbindung klappt, jedoch fehlen mit die login daten.
                            Wie geht das jetzt bei bookworm?
                            Innogy Smarthome
                            Bosch Bridge 2
                            HUE Bridge
                            Google Nest Pro Hub
                              ??? Wie sonst auch.
                              Was machst du da? Welche Datei 'userconf'?
                              Mach es danach:
                              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                              Da wird dann auch ein user und auch der ssh-Server eingerichtet.
                                werner2000x
                                @thomas-braun Jetzt gabe ich die SD Card neu aufgesetzt.
                                Der Info Adapter konnte nicht gestartet werden, das habe ich Ihn gelöscht.
                                Wie kann man ihn neu installieren?
                                Innogy Smarthome
                                Bosch Bridge 2
                                HUE Bridge
                                Google Nest Pro Hub
                                  Gar nicht. Der wird nicht mehr unterstützt.
                                    werner2000x
                                    @thomas-braun Der RPI Adapter hat noch Fehlermeldungen:
                                    rpi2.0
                                    2024-09-14 12:51:42.705	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 122398100 8780528 107384372 8% / /1024
                                    Innogy Smarthome
                                    Bosch Bridge 2
                                    HUE Bridge
                                    Google Nest Pro Hub
                                      rpi2.0
                                      HomoranH Offline
                                      HomoranH Offline
                                      welche Version?
                                        rpi2.0
                                        Nicht in der Version 2..0. Kann sein das die aber noch Beta ist.
                                          werner2000x
                                          @thomas-braun Ich habe die Version 2.0
                                          Innogy Smarthome
                                          Bosch Bridge 2
                                          HUE Bridge
                                          Google Nest Pro Hub
