  4. ...nicht in offiziellem Repo
  5. Test Adapter Hoymiles-wifi
    6.4k
Geplant Angeheftet Gesperrt Verschoben ...nicht in offiziellem Repo
86 Beiträge 15 Kommentatoren 35.8k Aufrufe 11 Beobachtet
    drnicolas
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.8.4-2-pve
          Architecture: x86-64
    model name      : Intel(R) Xeon(R) CPU E5-2667 v2 @ 3.30GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     09:40:35 up 4 min,  1 user,  load average: 2.01, 1.69, 1.69
    CPU threads: 1
    *** Time and Time Zones ***
                   Local time: Sun 2024-09-08 09:40:35 CEST
               Universal time: Sun 2024-09-08 07:40:35 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    nico
    HOME=/home/nico
    GROUPS=nico adm dialout sudo plugdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            1.0G        606M        301M        0.0K        115M        434M
    Swap:           2.0G          0B        2.0G
    Total:          3.1G        606M        2.3G
    Active iob-Instances:   7
             1024 M total memory
              606 M used memory
              551 M active memory
              139 M inactive memory
              301 M free memory
                0 M buffer memory
              116 M swap cache
             2048 M total swap
                0 M used swap
             2048 M free swap
    top - 09:40:35 up 4 min,  1 user,  load average: 2.01, 1.70, 1.69
    Tasks:  47 total,   1 running,  46 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  6.2 us,  0.0 sy,  0.0 ni, 93.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   1024.0 total,    301.5 free,    606.4 used,    116.1 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.    434.3 avail Mem
    *** FAILED SERVICES ***
      UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
    * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
    3 loaded units listed.
    *** FILESYSTEM ***
    Filesystem             Type      Size  Used Avail Use% Mounted on
    DATA/subvol-301-disk-0 zfs       8.0G  2.9G  5.2G  36% /
    none                   tmpfs     492K  4.0K  488K   1% /dev
    udev                   devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs                  tmpfs      32G     0   32G   0% /dev/shm
    tmpfs                  tmpfs      13G  148K   13G   1% /run
    tmpfs                  tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                  tmpfs     6.3G     0  6.3G   0% /run/user/1001
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems:
    TARGET                                SOURCE                         FSTYPE     OPTIONS
    /                                     DATA/subvol-301-disk-0         zfs        rw,relatime,xattr,posixacl,casesensitive
    |-/run                                tmpfs                          tmpfs      rw,nosuid,nodev,size=13162596k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
    | |-/run/lock                         tmpfs                          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
    | `-/run/user/1001                    tmpfs                          tmpfs      rw,nosuid,nodev,relatime,size=6581296k,nr_inodes=1645324,mode=700,uid=101001,gid=101001,inode64
    |-/dev                                none                           tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/dev/shm                          tmpfs                          tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
    | |-/dev/mqueue                       mqueue                         mqueue     rw,nosuid,nodev,noexec,relatime
    | |-/dev/.lxc/proc                    proc                           proc       rw,relatime
    | |-/dev/.lxc/sys                     sys                            sysfs      rw,relatime
    | |-/dev/full                         udev[/full]                    devtmpfs   rw,nosuid,relatime,size=32872676k,nr_inodes=8218169,mode=755,inode64
    | |-/dev/null                         udev[/null]                    devtmpfs   rw,nosuid,relatime,size=32872676k,nr_inodes=8218169,mode=755,inode64
    | |-/dev/random                       udev[/random]                  devtmpfs   rw,nosuid,relatime,size=32872676k,nr_inodes=8218169,mode=755,inode64
    | |-/dev/tty                          udev[/tty]                     devtmpfs   rw,nosuid,relatime,size=32872676k,nr_inodes=8218169,mode=755,inode64
    | |-/dev/urandom                      udev[/urandom]                 devtmpfs   rw,nosuid,relatime,size=32872676k,nr_inodes=8218169,mode=755,inode64
    | |-/dev/zero                         udev[/zero]                    devtmpfs   rw,nosuid,relatime,size=32872676k,nr_inodes=8218169,mode=755,inode64
    | |-/dev/pts                          devpts                         devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/ptmx                         devpts[/ptmx]                  devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/console                      devpts[/0]                     devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/tty1                         devpts[/1]                     devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | `-/dev/tty2                         devpts[/2]                     devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    |-/proc                               proc                           proc       rw,nosuid,nodev,noexec,relatime
    | |-/proc/sys                         proc[/sys]                     proc       ro,relatime
    | | |-/proc/sys/net                   proc[/sys/net]                 proc       rw,nosuid,nodev,noexec,relatime
    | | `-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]            tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/proc/sysrq-trigger               proc[/sysrq-trigger]           proc       ro,relatime
    | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/diskstats                   lxcfs[/proc/diskstats]         fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/loadavg                     lxcfs[/proc/loadavg]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/meminfo                     lxcfs[/proc/meminfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/stat                        lxcfs[/proc/stat]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/swaps                       lxcfs[/proc/swaps]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | `-/proc/uptime                      lxcfs[/proc/uptime]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys                                sysfs                          sysfs      ro,nosuid,nodev,noexec,relatime
      |-/sys/fs/fuse/connections          fusectl                        fusectl    rw,nosuid,nodev,noexec,relatime
      |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]    sysfs      rw,nosuid,nodev,noexec,relatime
      |-/sys/fs/cgroup                    none                           cgroup2    rw,nosuid,nodev,noexec,relatime
      `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    948M    /var/
    547M    /var/cache
    545M    /var/cache/apt
    504M    /var/cache/apt/archives
    288M    /var/log
    Archived and active journals take up 281.2M in the file system.
    /opt/iobroker/backups:
    38M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    129M    /opt/iobroker/iobroker-data/
    80M     /opt/iobroker/iobroker-data/backup-objects
    38M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/backitup.admin
    12M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js
    11M     /opt/iobroker/iobroker-data/objects.jsonl
    7.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
    3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
    3.5M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js
    3.4M    /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.70cad8ba.js
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.17.0
    /usr/bin/node           v20.17.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.17.0-1nodesource1
      Candidate: 20.17.0-1nodesource1
      Version table:
     *** 20.17.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://ftp.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org bullseye-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.11
    admin:          7.0.23
    javascript:     "javascript" not found
    nodejs modules from github:     1
    +-- iobroker.hoymiles-wifi@0.1.1 (git+ssh://git@github.com/MicHi07i/ioBroker.hoymiles-wifi.git#7190a6c4e34eb7f2e89747888ff2d65db7ee2968)
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.hoymiles-wifi.0          : hoymiles-wifi         : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.23   , installed 7.0.23
    Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 3.0.19   , installed 3.0.19
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "miele"        : 0.1.5    , installed 0.1.5
    Adapter    "modbus"       : 6.2.3    , installed 6.2.3
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Objects and States
    Objects:        346
    States:         244
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://packages.grafana.com/enterprise/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://ftp.debian.org/debian bullseye InRelease
    Hit:2 http://ftp.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org bullseye-security InRelease
    Get:4 https://packages.grafana.com/enterprise/deb stable InRelease [7660 B]
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Err:4 https://packages.grafana.com/enterprise/deb stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        73368672   139/systemd-resolve
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          73368975   330/master
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          73355890   1/init
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       73373769   470/io.sonoff.0
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      110        73368752   140/influxd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       73368873   141/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       73368878   141/iobroker.js-con
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        73368678   139/systemd-resolve
    tcp6       0      0 :::5355                 :::*                    LISTEN      104        73368675   139/systemd-resolve
    tcp6       0      0 :::8086                 :::*                    LISTEN      110        73369252   140/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       73373829   463/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          73356160   1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          73355892   1/init
    tcp6       0      0 :::3000                 :::*                    LISTEN      109        73369262   163/grafana
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          73368976   330/master
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        73368677   139/systemd-resolve
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          73356164   86/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          73355891   1/init
    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        73368671   139/systemd-resolve
    udp6       0      0 :::111                  :::*                                0          73355893   1/init
    udp6       0      0 :::5355                 :::*                                104        73368674   139/systemd-resolve
    2024-09-08 09:37:05.171  - warn: hoymiles-wifi.0 (565) Host 192.168.1.50 is not reachable: ping: socket: Operation not permitted
    2024-09-08 09:38:05.160  - warn: hoymiles-wifi.0 (565) Host 192.168.1.50 is not reachable: ping: socket: Operation not permitted
    2024-09-08 09:38:05.165  - warn: hoymiles-wifi.0 (565) Host 192.168.1.50 is not reachable: ping: socket: Operation not permitted
    2024-09-08 09:38:05.170  - warn: hoymiles-wifi.0 (565) Host 192.168.1.50 is not reachable: ping: socket: Operation not permitted
    2024-09-08 09:39:05.163  - warn: hoymiles-wifi.0 (565) Host 192.168.1.50 is not reachable: ping: socket: Operation not permitted
    2024-09-08 09:39:05.169  - warn: hoymiles-wifi.0 (565) Host 192.168.1.50 is not reachable: ping: socket: Operation not permitted
    2024-09-08 09:39:05.174  - warn: hoymiles-wifi.0 (565) Host 192.168.1.50 is not reachable: ping: socket: Operation not permitted
    2024-09-08 09:40:05.165  - warn: hoymiles-wifi.0 (565) Host 192.168.1.50 is not reachable: ping: socket: Operation not permitted
    2024-09-08 09:40:05.170  - warn: hoymiles-wifi.0 (565) Host 192.168.1.50 is not reachable: ping: socket: Operation not permitted
    2024-09-08 09:40:05.177  - warn: hoymiles-wifi.0 (565) Host 192.168.1.50 is not reachable: ping: socket: Operation not permitted
    2024-09-08 09:40:07.047  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 641
    2024-09-08 09:40:08.397  - info: dwd.0 (641) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.11
    2024-09-08 09:40:08.567  - info: dwd.0 (641) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-09-08 09:40:09.096  - info: host.iobroker instance system.adapter.dwd.0 having pid 641 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    • D drnicolas
      Skript v.2024-05-22
      *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 1
                       RTC time: n/a
                RTC in local TZ: no
      nico
      HOME=/home/nico
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           2.0G          0B        2.0G
               1024 M total memory
                606 M used memory
                551 M active memory
                301 M free memory
                  0 M buffer memory
                116 M swap cache
               2048 M total swap
                  0 M used swap
               2048 M free swap
      *** FILESYSTEM ***
      /var:
      948M    /var/
      547M    /var/cache
      545M    /var/cache/apt
      288M    /var/log
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          7.0.23
      Adapter State
      + instance is alive
      Objects and States
      Objects:        346
      States:         244
      Pending Updates: 0
      @drnicolas sagte in Hoymiles hms-800w-2t:
      Chassis: container
      Virtualization: lxc
      Container sind da was 'eigen'.
      Und ich raus, weil ich mich damit nicht beschäftigen will.
        drnicolas
        schrieb am zuletzt editiert von drnicolas
        ich bin etwas weiter gekommen:
           iobroker exit 25
        host.iobroker
        2024-09-08 14:47:38.510	error	iobroker host.iobroker Cannot install iobroker: 0
        host.iobroker
        2024-09-08 14:47:38.509	error	iobroker
        host.iobroker
        2024-09-08 14:47:38.495	info	iobroker added 8 packages, and changed 1 package in 8s71 packages are looking for funding run `npm fund` for details
        host.iobroker
        2024-09-08 14:47:36.329	info	iobroker The object "system.certificates" was updated successfully.
        host.iobroker
        2024-09-08 14:47:36.326	info	iobroker Update certificate defaultPublic
        host.iobroker
        2024-09-08 14:47:36.323	info	iobroker The object "system.certificates" was updated successfully.
        host.iobroker
        2024-09-08 14:47:36.318	info	iobroker Update certificate defaultPrivate
        host.iobroker
        2024-09-08 14:47:36.314	info	iobroker "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nVAAoz8OGk1Jv/YktpM60dm2Q/I0C8gRUhYSt1sERzjMDmg==\r\n-----END CERTIFICATE-----\r\n"}
        host.iobroker
        2024-09-08 14:47:36.312	info	iobroker "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nQ3/DXcIHK45haoz3ebqHwef6a+GLbaX1zQKEnXVhJLdPL6PaRa0=\r\n-----END RSA PRIVATE KEY-----\r\n",
        host.iobroker
        2024-09-08 14:47:36.311	info	iobroker {
        host.iobroker
        2024-09-08 14:47:36.030	info	iobroker Clean up objects and states with forbidden characters ...
        host.iobroker
        2024-09-08 14:47:36.018	info	iobroker Clean up leftover adapters ...
        host.iobroker
        2024-09-08 14:47:36.015	info	iobroker Clean up garbage objects ...
        host.iobroker
        2024-09-08 14:47:36.011	info	iobroker Clean up invalid group assignments ...
        host.iobroker
        2024-09-08 14:47:36.003	info	iobroker Clean up binary states ...
        host.iobroker
        2024-09-08 14:47:36.001	info	iobroker Successfully specified supported "@iobroker/adapter-core" version as "^3.1.6"
        host.iobroker
        2024-09-08 14:47:35.970	info	iobroker object "_design/system" updated
        host.iobroker
        2024-09-08 14:47:35.345	info	iobroker Successfully migrated 239 objects to Redis Sets
        host.iobroker
        2024-09-08 14:47:33.903	info	iobroker > iobroker.js-controller@6.0.11 install> node iobroker.js setup first
        host.iobroker
        2024-09-08 14:47:33.734	info	iobroker NPM version: 10.8.2
        host.iobroker
        2024-09-08 14:47:33.548	info	iobroker > iobroker.js-controller@6.0.11 preinstall> node build/esm/lib/preinstallCheck.js
        host.iobroker
        2024-09-08 14:47:30.869	info	iobroker Installing iobroker... (System call)
        host.iobroker
        2024-09-08 14:47:30.866	info	iobroker NPM version: 10.8.2
        host.iobroker
        2024-09-08 14:47:30.746	info	iobroker install iobroker
        host.iobroker
        2024-09-08 14:47:29.894	info	iobroker url iobroker url /media/adapter/iobroker.hoymiles-wifi-0.0.1.tgz --host iobroker --host iobroker --debug
        • E Offline
          eule01
          Hallo, ich habe im Raspi die Datenabfrage erfolgreich getestet, den Adapter installiert, Instanz hinzugefügt und die IP-Adresse angepasst.
          Im IO-Broker bekomme ich aber folgende Fehlermeldungen:
          hoymiles-wifi.0
          2024-09-08 17:28:39.661	error	stderr: /bin/sh: 1: hoymiles-wifi: not found
          hoymiles-wifi.0
          2024-09-08 17:28:39.660	error	Error executing command: hoymiles-wifi --host 192.168.2.176 --as-json get-real-data
          hoymiles-wifi.0
          2024-09-08 17:28:39.648	info	Host 192.168.2.176 is reachable. Executing command: hoymiles-wifi --host 192.168.2.176 --as-json get-real-data
          hoymiles-wifi.0
          2024-09-08 17:28:39.637	error	stderr: /bin/sh: 1: hoymiles-wifi: not found
          hoymiles-wifi.0
          2024-09-08 17:28:39.636	error	Error executing command: hoymiles-wifi --host 192.168.2.176 --as-json app-get-hist-power
          hoymiles-wifi.0
          2024-09-08 17:28:39.623	info	Host 192.168.2.176 is reachable. Executing command: hoymiles-wifi --host 192.168.2.176 --as-json app-get-hist-power
          Was könnte hier die Ursache sein?
          MOD-Edit: Code in Code-Tags setzen!!!
          Samson71S Thomas BraunT 2 Antworten Letzte Antwort
          • E eule01
            hoymiles-wifi.0
            hoymiles-wifi.0
            hoymiles-wifi.0
            hoymiles-wifi.0
            hoymiles-wifi.0
            hoymiles-wifi.0
            Samson71S Offline
            Samson71S Offline
            Samson71
            @eule01
            Als stiller Mitleser seit mehr als einem Jahr solltest Du Codetags (Menü beim Erstellen des Beitrags: </> ) kennen. Bitte benutze sie auch.
            Markus
            Bitte beachten:
            • E eule01
              hoymiles-wifi.0
              hoymiles-wifi.0
              hoymiles-wifi.0
              hoymiles-wifi.0
              hoymiles-wifi.0
              hoymiles-wifi.0
              @eule01
              Da fehlt das Programm hoymiles-wifi
              E 1 Antwort Letzte Antwort
                @eule01
                eule01
                Das Programm hoymiles-wifi ist installiert. Nach Eingabe des usr und pwd und anschließender Abfragen im RPI, werden die entsprechenden Ergebnisse gezeigt. Lediglich bei der Abfrage über den IO-Broker werden die Fehlermeldungen erzeugt.
                • E eule01
                  @eule01
                  Liegt das denn auch im $PATH des Users ioBroker?
                  Wie wurde das Programm installiert?
                  • E Offline
                    eule01
                    Ich habe das RPI-Image meiner letzten Monatssicherung geladen und "hoymiles-wifi" diesmal im Pfad iobroker installiert. Bei der anschließenden Installation des Adapters ist mir erst jetzt so richtig aufgefallen, dass die Installation mit Error Code 25 abbricht. Nach Aktualisierung ist dieser Adapter allerdings sichtbar und eine Instanz lässt sich anlegen. Deshalb habe ich mir zunächst auch nichts dabei gedacht. Aber die Abfrage funktioniert natürlich nicht. Das ist bei mir das erste Mal, dass eine Installation nicht funktioniert.
                    $ iobroker url iobroker url /media/adapter/iobroker.hoymiles-wifi-0.0.1.tgz --host raspberrypi --debug --host solaranzeige --debug
                    install iobroker
                    NPM version: 10.7.0
                    99 packages are looking for funding run `npm fund` for details
                    host.solaranzeige Cannot install iobroker: 0
                    ERROR: Process exited with code 25
                    • E eule01
                      install iobroker
                      NPM version: 10.7.0
                      @eule01 sagte in Hoymiles hms-800w-2t:
                      Dürfte auch falsch sein, das ist ja ein Link auf ein tgz.
                      M E 2 Antworten Letzte Antwort
                      • D drnicolas
                        @homoran Neustart hat auch nichts gebracht.
                        In iobroker kommt diue Meldung "Host 192.168.1.50 is not reachable: ping: socket: Operation not permitted ".
                        Das hört sich für mich nach einem grundlegenden Problem an.
                        ping kann ich ohnehin nur als sudo ausführen
                        Michael 6
                        @drnicolas PING und HOYMILES-WIFI kann ich als regulärer User ausführen (Raspbian GNU/Linux 11 (bullseye)).
                        Und in diesem Kontext führt der Adapter die Befehle aus und verarbeitet die Antworten.
                        Die Option "Skip Poll" benutzt PING lediglich um zu erkennen ob das Balkonkraftwerk nachts nicht mehr erreichbar ist um sich dann die Abfrage zu sparen. Also einfach deaktivieren, funktionieren sollte es dennoch.
                          Michael 6
                          @thomas-braun Wie kann ich das auf Git besser veröffentlichen?
                            eule01
                            Inzwischen ist der Adapter ordnungsgemäß und ohne Fehlermeldung installiert und die entsprechende Instanz mit der IP-Adresse des Wechselrichters versehen. Ich bekomme aber immer noch die nachfolgenden Fehlermeldungen der Shell.
                            hoymiles-wifi.0
                            2024-09-12 13:27:19.405	error	stderr: /bin/sh: 1: hoymiles-wifi: not found
                            hoymiles-wifi.0
                            2024-09-12 13:27:19.405	error	Error executing command: hoymiles-wifi --host 192.168.2.176 --as-json get-real-data
                            hoymiles-wifi.0
                            2024-09-12 13:27:19.399	info	Host 192.168.2.176 is reachable. Executing command: hoymiles-wifi --host 192.168.2.176 --as-json get-real-data
                            • E eule01
                              hoymiles-wifi.0
                              hoymiles-wifi.0
                              hoymiles-wifi.0
                              Wie und wo installiert? Offenbar liegt hoymiles-wifi nicht im $PATH des aufrufenden users 'iobroker'.
                                eule01
                                Wie kann ich hoymiles-wifi so installieren, dass es im Path iobroker liegt?
                                root@solaranzeige:~# cd /
                                root@solaranzeige:/# find -iname "hoymiles-wifi"
                                ./home/pi/.local/bin/hoymiles-wifi
                                find: ‘./run/user/1000/gvfs’: Keine Berechtigung
                                Thomas BraunT M 2 Antworten Letzte Antwort
                                • E eule01
                                  @eule01
                                  Zunächstmal solttest du NICHT als root herumhampeln.
                                  Und solche Software, wenn sie am Paketmanager vorbei installiert wird, gehört nach /usr/local/bin und nicht in ein home eines users.
                                  • E eule01
                                    Michael 6
                                    @eule01 Oh, das Problem hatte ich auch. Auf die Schnelle hatte ich das Python hoymiles-wifi als root installiert, dann wurde es auch vom ioBroker gefunden. Aber stimmt, als root sollte man sowas nicht machen, besser regulär installieren und den Pfad anpassen.
                                    E S 2 Antworten Letzte Antwort
                                    • M Michael 6
                                      eule01
                                      @michael-6
                                      Vielen Dank für die schnelle Hilfe und die Anmerkungen von Thomas Braun, die mich immer wieder zum Nachdenken gebracht haben. Gestern bin ich tatsächlich nochmals als root "herumgehampelt" und habe hoymiles-wifi entsprechend installiert. Und siehe da, jetzt funktioniert alles. Ich bin begeistert!!! Nochmals Danke an euch...
                                        Schorsch
                                        ich bin ein halber Anfänger und hänge bei der Einbindung des hms-800w-2t in iobroker fest.
                                        Was ich gemacht habe gemäß den Anleitungen der github-Seiten suaveolent/hoymiles-wifi und MicHi07i/iobroker.hoymiles-wifi gemacht habe:
                                        1. Ich habe Python3 installiert
                                        2. den Code "hoymiles-wifi" (github suaveolent/hoymiles-wifi) gmäß Anleitung vom MicHi07i installiert. Die Hinweise von MicHi07i bezüglich bookworm berücksichtigt. Der Code liegt im Pfad /usr/local/bin, der wiederum in $PATH eingetragen ist. Im Github ist noch ein Hinweis enthalten, den Pfad /etc/profile in der Path-Variable einzutragen. Es gibt jedoch keinen Ordner "profile". Ist das richtig?
                                        3. Das Programm homiles-wifi mit im Terminal mit der IP-Adresse des Hoymiles getestet
                                        hoymiles-wifi --host 111.111.111.111 get-real-data-new
                                        Die Antwort enthält mehrere Werte.
                                        4. Den Adapter "iobroker.hoymiles-wifi" vom github MicHi07i installiert, jedoch nach Anleitung von haus:automation (übrings super Seiten). Also aus npm über Terminalbefehl "iobroker url iobroker.hoymiles-wifi".
                                        5. Dann Adapter im iobroker ausgewählt und installiert.
                                        6. In den Einstellungen der Instanz dann die IP-Adresse für den Hoymiles angepasst.
                                        In den Objekten bekomme ich nur hoymiles-wifi.0.info.connection angezeigt, mit dem Wert "true". Sonst nichts.
                                        Muss ich da noch irgendwas machen (z. B. Datenpunkte anlegen oder etwas starten)?
                                        Gibt es eine Möglichkeit, den Rückgabewert aus dem Terminal-Fenster per JavaScript abzufragen?
                                        Vielen Dank für eure Hilfe.
                                          Schorsch
                                          So, ich habe eine Lösung gefunden.
                                          Ich habe es nicht hinbekommen, die $PATH-Variable für den User "iobroker" zu editieren. Somit musste ich aus Blockly immer den kompletten Pfad angeben und der Adapter von @Michael-6 funktionierte nicht (siehe github).
                                          In der $PATH - Variablen von iobroker ist das Verzeichnis /usr/local/bin enthalten. Dort habe ich einen Softlink mit dem Namen hoymiles-wifi platziert, der auf die Datei hoymiles-wifi im Verzeichnis /home/iobroker/.local/pipx/venvs/hoymiles-wifi/bin zeigt.
                                          Erklärung auf den Seiten von ubuntuusers
                                          Jetzt funktioniert auch der Adapter.
