  4. Nach Update js-controller macht host.raspberrypi Fehler
37 Beiträge 5 Kommentatoren 5.7k Aufrufe 3 Beobachtet
    @spicer sagte in Nach Update js-controller macht host.raspberrypi Fehler:
    Dann mache ich doch besser keine Updates mehr... ist eigentlich Irrsinn.
    Du sollst es ja auch nicht updaten sondern NEUinstallieren.
    MacPo
    Bei mir ist genau das gleiche Verhalten. Die Fehlermeldung von echarts ist beim Start vom js-controller nach dem Update von 6.0.9 auf 6.0.11 erschienen.
    2024-08-29 17:03:44.064  - info: host.broker01 iobroker rebuild echarts --debug
    2024-08-29 17:03:44.670  - info: host.broker01 iobroker Rebuilding native module "echarts" ...
    2024-08-29 17:03:46.850  - info: host.broker01 iobroker rebuilt dependencies successfully
    2024-08-29 17:03:46.872  - info: host.broker01 iobroker
    2024-08-29 17:03:46.873  - info: host.broker01 iobroker Rebuilding native modules done
    2024-08-29 17:03:47.880  - info: host.broker01 iobroker exit 0
    2024-08-29 17:03:59.213  - info: host.broker01 instance system.adapter.echarts.0 in version "1.7.2" started with pid 3643197
    2024-08-29 17:03:59.347  - error: host.broker01 Caught by controller[0]: node:internal/modules/cjs/loader:1148
    2024-08-29 17:03:59.347  - error: host.broker01 Caught by controller[0]:   throw err;
    2024-08-29 17:03:59.347  - error: host.broker01 Caught by controller[0]:   ^
    2024-08-29 17:03:59.347  - error: host.broker01 Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
    2024-08-29 17:03:59.347  - error: host.broker01 Caught by controller[0]: Require stack:
    2024-08-29 17:03:59.347  - error: host.broker01 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/main.js
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:986:27)
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]: }
    2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]: Node.js v20.16.0
    2024-08-29 17:03:59.348  - error: host.broker01 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-08-29 17:03:59.348  - info: host.broker01 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    • spicerS spicer
      Natürlich ist das Blödsinn.
      Aber wie sonst kann ich ein gebrochenes System verhindern?
      Mehr als immer die empfohlenen Updates zu machen kann ich ja nicht.
      Mir wird dann immer gesagt, diese Version von Modul x und Modul y passen nicht zusammen. Installiere neu.
      Das kann es doch nicht sein. Der wohl kleinste Teil der User verfügt über genügend Wissen, um zu entscheiden, welche Version jetzt zu gebrauchen ist. Auch machen die meisten nicht extra ein Studium, um alle Zusammenhänge zuverstehn.
      Ja, aber du musst sie halt auch machen. Zeitnah und vollständig.
      Das ist i.d.R. nur die Folge aus versäumten Updates im Vorfeld. Oder von von vorneherein falscher/ungünstiger Installation.
      Ich hab auch kein Informatikstudium absolviert. Muss man auch nicht für einfache Systempflege.
      spicerS 1 Antwort Letzte Antwort
        spicerS Offline
        spicerS Offline
        spicer
        @thomas-braun sagte in Nach Update js-controller macht host.raspberrypi Fehler:
        Das nehm ich Dir so jetzt nicht ab.
        Habe immer sofort updated und, falls, wie beschrieben.
        Zudem betreibe ich verschiedene Debian Server, welche sauber laufen. Wie kann man einen Server "ungünstig" installieren?
        Wenn es mehrere Möglichkeiten gibt, eine Aufgabe zu erledigen, und eine davon in einer Katastrophe endet oder sonstwie unerwünschte Konsequenzen nach sich zieht, dann wird es jemand genau so machen. Alles, was schiefgehen kann, wird auch schiefgehen.
        (Murphys Gesetz)
        • spicerS spicer
          Dann halt nicht. Ich verwende 'Linux' allerdings nicht erst 3 Wochen und weiß wie das da läuft. Insbesondere bei Debian.
          Ungünstig installiert bezog sich auf eine 32Bit-Installation auf einer 64Bit-CPU.
          • spicerS spicer
            Zum Problem zurück.
            Jetzt wird's interessant. eCharts funktioniert und es kommen auch keine Fehler mehr im Log.
            Aber bei den Instanzen steht:
            spicerS Offline
            spicerS Offline
            spicer
            Zum Problem zurück.
            Was muss ich nun wegen dem verstehn?
            (Murphys Gesetz)
            St BeS 1 Antwort Letzte Antwort
            • spicerS spicer
              Zum Problem zurück.
              St BeS Offline
              St BeS Offline
              St Be
              @spicer Ich lese mal mit..ich habe gleiches Problem
              • St BeS St Be
                MacPo
                @st-be Für das Problem gibt es schon ein Ticket in GitHub https://github.com/ioBroker/ioBroker.echarts/issues/680
                Mit der Installation von 1.9.0 (noch nicht im stable) funktioniert der Adapter auch bei mir wieder.
                • M MacPo
                  spicerS Offline
                  spicerS Offline
                  spicer
                  schrieb am zuletzt editiert von spicer
                  @macpo
                  Jep danke.
                  Habe nun wie im Link empfohlen die eCharts V1.8.4 von der beta Repository installiert und das Problem scheint gelöst.
                  Mit der V1.9.0 ist unterhalb des Charts (zBsp Datenquellen) das Fenster leer.
                  (Murphys Gesetz)
                  • spicerS Offline
                    spicerS Offline
                    spicer
                    Der Backitup Adapter hat das gleiche Problem seit dem Update!
                    Backup error: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js' ... please check your config and and try again!!
                    Hab ihn aber gerade von Hand gestartet und der Backup ist so durchgelaufen.
                    (Murphys Gesetz)
                    • spicerS spicer
                      @spicer
                      echad@chet:~ $ ls -l /opt/iobroker/node_modules/iobroker.backitup/node_modules/
                      total 4
                      drwxrwxr-x+ 4 iobroker iobroker 4096 Aug 22 16:28 axios
                      echad@chet:~ $
                        @spicer
                        total 4
                        echad@chet:~ $
                        spicerS Offline
                        spicerS Offline
                        spicer
                        @spicer
                        total 4
                        echad@chet:~ $
                        pi@raspberrypi:~ $ ls -l /opt/iobroker/node_modules/iobroker.backitup/node_modules/
                        insgesamt 4
                        drwxrwxr-x+ 2 iobroker iobroker 4096 30. Aug 21:33 @iobroker
                        pi@raspberrypi:~ $
                        (Murphys Gesetz)
                        • spicerS spicer
                          @macpo
                          Jep danke.
                          MacPo
                          @spicer
                          Bei mir funktioniert die Version 1.9.0. Wenn die Version 1.8.4 bei Dir funktioniert, ist das doch super.
                          Auch bei mir kommt die Meldung bei dem Backitup Adapter, wenn ich die Oberfläche öffne. Die Sicherungen sind aber weiterhin durchgeführt worden.
                          Nachdem ich auf die Version 3.0.20 aktualisiert habe, bleibt die Fehlermeldung aus. Wahrscheinlich ist es durch dependencies updated behoben worden.
                          • M MacPo
                            @spicer
                            spicerS Offline
                            spicerS Offline
                            spicer
                            @macpo
                            eCharts V1.8.4 zeigte bei monatlichen Totalen (bei mir PV Total Monate >> bis 2 Jahre zurück) nichts mehr an.
                            Habe nun auf die offizielle V1.7.2 downgraded und siehe da, der host-Fehler ist nun auch weg.
                            Nun läuft es wieder wie gewohnt.
                            (Murphys Gesetz)
