  4. Nach Update js-controller macht host.raspberrypi Fehler
37 Beiträge 5 Kommentatoren 5.7k Aufrufe 3 Beobachtet
  • spicerS spicer
     MB von 922MB (33%)
    2024-08-28 23:27:00.129  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier Swap: 1638
     MB von 2048MB (80%)
    2024-08-28 23:27:10.247  - info: mqtt.1 (26882) Client [mosqsub|20744-Dachrollo] connected with secret 1724880430246_4288
    2024-08-28 23:27:10.252  - info: mqtt.1 (26882) Client [mosqsub|20744-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
    2024-08-28 23:27:10.453  - info: mqtt.1 (26882) Client [mosqsub|20744-Dachrollo] publishOnSubscribe
    2024-08-28 23:27:10.456  - info: mqtt.1 (26882) Client [mosqsub|20744-Dachrollo] connection closed: disconnected
    2024-08-28 23:27:10.546  - info: mqtt.1 (26882) Client [mosqsub|20746-Dachrollo] connected with secret 1724880430545_7858
    2024-08-28 23:27:10.552  - info: mqtt.1 (26882) Client [mosqsub|20746-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
    2024-08-28 23:27:10.752  - info: mqtt.1 (26882) Client [mosqsub|20746-Dachrollo] publishOnSubscribe
    2024-08-28 23:27:10.757  - info: mqtt.1 (26882) Client [mosqsub|20746-Dachrollo] connection closed: disconnected
    2024-08-28 23:27:10.845  - info: mqtt.1 (26882) Client [mosqsub|20748-Dachrollo] connected with secret 1724880430844_7856
    2024-08-28 23:27:10.850  - info: mqtt.1 (26882) Client [mosqsub|20748-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
    2024-08-28 23:27:11.051  - info: mqtt.1 (26882) Client [mosqsub|20748-Dachrollo] publishOnSubscribe
    2024-08-28 23:27:11.054  - info: mqtt.1 (26882) Client [mosqsub|20748-Dachrollo] connection closed: disconnected
    2024-08-28 23:27:11.139  - info: mqtt.1 (26882) Client [mosqsub|20750-Dachrollo] connected with secret 1724880431138_4610
    2024-08-28 23:27:11.143  - info: mqtt.1 (26882) Client [mosqsub|20750-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
    2024-08-28 23:27:11.344  - info: mqtt.1 (26882) Client [mosqsub|20750-Dachrollo] publishOnSubscribe
    2024-08-28 23:27:11.348  - info: mqtt.1 (26882) Client [mosqsub|20750-Dachrollo] connection closed: disconnected
    2024-08-28 23:27:11.436  - info: mqtt.1 (26882) Client [mosqsub|20752-Dachrollo] connected with secret 1724880431435_6621
    2024-08-28 23:27:11.439  - info: mqtt.1 (26882) Client [mosqsub|20752-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
    2024-08-28 23:27:11.640  - info: mqtt.1 (26882) Client [mosqsub|20752-Dachrollo] publishOnSubscribe
    2024-08-28 23:27:11.644  - info: mqtt.1 (26882) Client [mosqsub|20752-Dachrollo] connection closed: disconnected
    2024-08-28 23:27:11.742  - info: mqtt.1 (26882) Client [mosqpub|20754-Dachrollo] connected with secret 1724880431741_3090
    2024-08-28 23:27:11.747  - info: mqtt.1 (26882) Client [mosqpub|20754-Dachrollo] connection closed: disconnected
    2024-08-28 23:27:11.842  - info: mqtt.1 (26882) Client [mosqpub|20756-Dachrollo] connected with secret 1724880431840_414
    2024-08-28 23:27:11.849  - info: mqtt.1 (26882) Client [mosqpub|20756-Dachrollo] connection closed: disconnected
    2024-08-28 23:27:11.920  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connected with secret 1724880431917_6742
    2024-08-28 23:27:11.942  - info: mqtt.1 (26882) Client [mosqpub|20758-Dachrollo] connected with secret 1724880431941_8754
    2024-08-28 23:27:11.947  - info: mqtt.1 (26882) Client [mosqpub|20758-Dachrollo] connection closed: disconnected
    2024-08-28 23:27:12.042  - info: mqtt.1 (26882) Client [mosqpub|20760-Dachrollo] connected with secret 1724880432041_2336
    2024-08-28 23:27:12.047  - info: mqtt.1 (26882) Client [mosqpub|20760-Dachrollo] connection closed: disconnected
    2024-08-28 23:27:12.051  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.12V_on_off"
    2024-08-28 23:27:12.065  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert2"
    2024-08-28 23:27:12.066  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert3"
    2024-08-28 23:27:12.067  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert4"
    2024-08-28 23:27:12.067  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connection closed: disconnected
    2024-08-28 23:27:12.142  - info: mqtt.1 (26882) Client [mosqpub|20762-Dachrollo] connected with secret 1724880432141_7072
    2024-08-28 23:27:12.147  - info: mqtt.1 (26882) Client [mosqpub|20762-Dachrollo] connection closed: disconnected
    2024-08-28 23:27:12.251  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-08-28 23:27:12.265  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-08-28 23:27:12.266  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-08-28 23:27:12.268  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-08-28 23:27:12.432  - info: mqtt.1 (26882) Client [mosqpub|20777-Dachrollo] connected with secret 1724880432431_7101
    2024-08-28 23:27:12.437  - info: mqtt.1 (26882) Client [mosqpub|20777-Dachrollo] connection closed: disconnected
    2024-08-28 23:27:12.465  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connected with secret 1724880432460_7409
    2024-08-28 23:27:12.584  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.12V_on_off"
    2024-08-28 23:27:12.593  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert2"
    2024-08-28 23:27:12.595  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert3"
    2024-08-28 23:27:12.595  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert4"
    2024-08-28 23:27:12.605  - info: mqtt.1 (26882) Client [mosqpub|20783-Dachrollo] connected with secret 1724880432604_1289
    2024-08-28 23:27:12.609  - info: mqtt.1 (26882) Client [mosqpub|20783-Dachrollo] connection closed: disconnected
    2024-08-28 23:27:12.785  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-08-28 23:27:12.794  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-08-28 23:27:12.795  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-08-28 23:27:12.796  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-08-28 23:27:16.040  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connected with secret 1724880433108_3203
    2024-08-28 23:27:16.058  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#" with regex /^Aussenfuehler\..*/
    2024-08-28 23:27:16.059  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#"  with regex /^mqtt\.1\.Aussenfuehler\..*/
    2024-08-28 23:27:16.260  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] publishOnSubscribe send all known states
    2024-08-28 23:27:17.184  - info: web.0 (26709) <== Disconnect system.user.admin from ::ffff:192.168.1.63 vis.0
    2024-08-28 23:27:19.478  - info: web.0 (26709) ==> Connected system.user.admin from ::ffff:192.168.1.63
    2024-08-28 23:28:08.339  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connection closed: disconnected
    2024-08-28 23:28:10.235  - info: mqtt.1 (26882) Client [mosqsub|20808-Dachrollo] connected with secret 1724880490233_3193
    2024-08-28 23:28:10.238  - info: mqtt.1 (26882) Client [mosqsub|20808-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
    2024-08-28 23:28:10.439  - info: mqtt.1 (26882) Client [mosqsub|20808-Dachrollo] publishOnSubscribe
    2024-08-28 23:28:10.443  - info: mqtt.1 (26882) Client [mosqsub|20808-Dachrollo] connection closed: disconnected
    2024-08-28 23:28:10.530  - info: mqtt.1 (26882) Client [mosqsub|20810-Dachrollo] connected with secret 1724880490529_1990
    2024-08-28 23:28:10.534  - info: mqtt.1 (26882) Client [mosqsub|20810-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
    2024-08-28 23:28:10.734  - info: mqtt.1 (26882) Client [mosqsub|20810-Dachrollo] publishOnSubscribe
    2024-08-28 23:28:10.737  - info: mqtt.1 (26882) Client [mosqsub|20810-Dachrollo] connection closed: disconnected
    2024-08-28 23:28:10.824  - info: mqtt.1 (26882) Client [mosqsub|20812-Dachrollo] connected with secret 1724880490822_5106
    2024-08-28 23:28:10.828  - info: mqtt.1 (26882) Client [mosqsub|20812-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
    2024-08-28 23:28:11.030  - info: mqtt.1 (26882) Client [mosqsub|20812-Dachrollo] publishOnSubscribe
    2024-08-28 23:28:11.034  - info: mqtt.1 (26882) Client [mosqsub|20812-Dachrollo] connection closed: disconnected
    2024-08-28 23:28:11.122  - info: mqtt.1 (26882) Client [mosqsub|20814-Dachrollo] connected with secret 1724880491121_2661
    2024-08-28 23:28:11.128  - info: mqtt.1 (26882) Client [mosqsub|20814-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
    2024-08-28 23:28:11.329  - info: mqtt.1 (26882) Client [mosqsub|20814-Dachrollo] publishOnSubscribe
    2024-08-28 23:28:11.333  - info: mqtt.1 (26882) Client [mosqsub|20814-Dachrollo] connection closed: disconnected
    2024-08-28 23:28:11.418  - info: mqtt.1 (26882) Client [mosqsub|20816-Dachrollo] connected with secret 1724880491417_8233
    2024-08-28 23:28:11.424  - info: mqtt.1 (26882) Client [mosqsub|20816-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
    2024-08-28 23:28:11.626  - info: mqtt.1 (26882) Client [mosqsub|20816-Dachrollo] publishOnSubscribe
    2024-08-28 23:28:11.630  - info: mqtt.1 (26882) Client [mosqsub|20816-Dachrollo] connection closed: disconnected
    2024-08-28 23:28:11.730  - info: mqtt.1 (26882) Client [mosqpub|20818-Dachrollo] connected with secret 1724880491729_2398
    2024-08-28 23:28:11.741  - info: mqtt.1 (26882) Client [mosqpub|20818-Dachrollo] connection closed: disconnected
    2024-08-28 23:28:11.836  - info: mqtt.1 (26882) Client [mosqpub|20820-Dachrollo] connected with secret 1724880491834_449
    2024-08-28 23:28:11.841  - info: mqtt.1 (26882) Client [mosqpub|20820-Dachrollo] connection closed: disconnected
    2024-08-28 23:28:11.935  - info: mqtt.1 (26882) Client [mosqpub|20822-Dachrollo] connected with secret 1724880491933_9250
    2024-08-28 23:28:11.940  - info: mqtt.1 (26882) Client [mosqpub|20822-Dachrollo] connection closed: disconnected
    2024-08-28 23:28:12.034  - info: mqtt.1 (26882) Client [mosqpub|20824-Dachrollo] connected with secret 1724880492032_7881
    2024-08-28 23:28:12.040  - info: mqtt.1 (26882) Client [mosqpub|20824-Dachrollo] connection closed: disconnected
    2024-08-28 23:28:12.132  - info: mqtt.1 (26882) Client [mosqpub|20826-Dachrollo] connected with secret 1724880492131_3921
    2024-08-28 23:28:12.137  - info: mqtt.1 (26882) Client [mosqpub|20826-Dachrollo] connection closed: disconnected
    2024-08-28 23:28:12.424  - info: mqtt.1 (26882) Client [mosqpub|20841-Dachrollo] connected with secret 1724880492422_535
    2024-08-28 23:28:12.429  - info: mqtt.1 (26882) Client [mosqpub|20841-Dachrollo] connection closed: disconnected
    2024-08-28 23:28:12.595  - info: mqtt.1 (26882) Client [mosqpub|20847-Dachrollo] connected with secret 1724880492594_2652
    2024-08-28 23:28:12.600  - info: mqtt.1 (26882) Client [mosqpub|20847-Dachrollo] connection closed: disconnected
    2024-08-28 23:28:17.701  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connection closed: timeout
    2024-08-28 23:29:10.238  - info: mqtt.1 (26882) Client [mosqsub|20872-Dachrollo] connected with secret 1724880550237_799
    2024-08-28 23:29:10.242  - info: mqtt.1 (26882) Client [mosqsub|20872-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
    2024-08-28 23:29:10.443  - info: mqtt.1 (26882) Client [mosqsub|20872-Dachrollo] publishOnSubscribe
    2024-08-28 23:29:10.446  - info: mqtt.1 (26882) Client [mosqsub|20872-Dachrollo] connection closed: disconnected
    2024-08-28 23:29:10.534  - info: mqtt.1 (26882) Client [mosqsub|20874-Dachrollo] connected with secret 1724880550533_1548
    2024-08-28 23:29:10.537  - info: mqtt.1 (26882) Client [mosqsub|20874-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
    2024-08-28 23:29:10.740  - info: mqtt.1 (26882) Client [mosqsub|20874-Dachrollo] publishOnSubscribe
    2024-08-28 23:29:10.744  - info: mqtt.1 (26882) Client [mosqsub|20874-Dachrollo] connection closed: disconnected
    2024-08-28 23:29:10.832  - info: mqtt.1 (26882) Client [mosqsub|20876-Dachrollo] connected with secret 1724880550831_672
    2024-08-28 23:29:10.837  - info: mqtt.1 (26882) Client [mosqsub|20876-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
    2024-08-28 23:29:11.038  - info: mqtt.1 (26882) Client [mosqsub|20876-Dachrollo] publishOnSubscribe
    2024-08-28 23:29:11.042  - info: mqtt.1 (26882) Client [mosqsub|20876-Dachrollo] connection closed: disconnected
    2024-08-28 23:29:11.129  - info: mqtt.1 (26882) Client [mosqsub|20878-Dachrollo] connected with secret 1724880551128_5523
    2024-08-28 23:29:11.134  - info: mqtt.1 (26882) Client [mosqsub|20878-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
    2024-08-28 23:29:11.334  - info: mqtt.1 (26882) Client [mosqsub|20878-Dachrollo] publishOnSubscribe
    2024-08-28 23:29:11.338  - info: mqtt.1 (26882) Client [mosqsub|20878-Dachrollo] connection closed: disconnected
    2024-08-28 23:29:11.424  - info: mqtt.1 (26882) Client [mosqsub|20880-Dachrollo] connected with secret 1724880551423_9587
    2024-08-28 23:29:11.427  - info: mqtt.1 (26882) Client [mosqsub|20880-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
    2024-08-28 23:29:11.628  - info: mqtt.1 (26882) Client [mosqsub|20880-Dachrollo] publishOnSubscribe
    2024-08-28 23:29:11.631  - info: mqtt.1 (26882) Client [mosqsub|20880-Dachrollo] connection closed: disconnected
    2024-08-28 23:29:11.728  - info: mqtt.1 (26882) Client [mosqpub|20882-Dachrollo] connected with secret 1724880551727_6491
    2024-08-28 23:29:11.732  - info: mqtt.1 (26882) Client [mosqpub|20882-Dachrollo] connection closed: disconnected
    2024-08-28 23:29:11.825  - info: mqtt.1 (26882) Client [mosqpub|20884-Dachrollo] connected with secret 1724880551824_4315
    2024-08-28 23:29:11.830  - info: mqtt.1 (26882) Client [mosqpub|20884-Dachrollo] connection closed: disconnected
    2024-08-28 23:29:11.924  - info: mqtt.1 (26882) Client [mosqpub|20886-Dachrollo] connected with secret 1724880551923_1207
    2024-08-28 23:29:11.931  - info: mqtt.1 (26882) Client [mosqpub|20886-Dachrollo] connection closed: disconnected
    2024-08-28 23:29:12.025  - info: mqtt.1 (26882) Client [mosqpub|20888-Dachrollo] connected with secret 1724880552024_7072
    2024-08-28 23:29:12.030  - info: mqtt.1 (26882) Client [mosqpub|20888-Dachrollo] connection closed: disconnected
    2024-08-28 23:29:12.124  - info: mqtt.1 (26882) Client [mosqpub|20890-Dachrollo] connected with secret 1724880552123_5335
    2024-08-28 23:29:12.130  - info: mqtt.1 (26882) Client [mosqpub|20890-Dachrollo] connection closed: disconnected
    2024-08-28 23:29:12.416  - info: mqtt.1 (26882) Client [mosqpub|20905-Dachrollo] connected with secret 1724880552414_5267
    2024-08-28 23:29:12.426  - info: mqtt.1 (26882) Client [mosqpub|20905-Dachrollo] connection closed: disconnected
    2024-08-28 23:29:12.593  - info: mqtt.1 (26882) Client [mosqpub|20911-Dachrollo] connected with secret 1724880552592_1927
    2024-08-28 23:29:12.598  - info: mqtt.1 (26882) Client [mosqpub|20911-Dachrollo] connection closed: disconnected
    2024-08-28 23:29:17.143  - info: web.0 (26709) <== Disconnect system.user.admin from ::ffff:192.168.1.63 vis.0
    2024-08-28 23:29:19.190  - info: web.0 (26709) ==> Connected system.user.admin from ::ffff:192.168.1.63
    2024-08-28 23:30:00.147  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: GPU Temp: 51.5 °C
    2024-08-28 23:30:00.149  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: CPU Temp: 51.54 °C
    2024-08-28 23:30:00.167  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier RAM: 291
     MB von 922MB (32%)
    2024-08-28 23:30:00.168  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier Swap: 1641
     MB von 2048MB (80%)
    2024-08-28 23:30:06.383  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connected with secret 1724880606359_1638
    2024-08-28 23:30:06.508  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.12V_on_off"
    2024-08-28 23:30:06.527  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert2"
    2024-08-28 23:30:06.529  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert3"
    2024-08-28 23:30:06.530  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert4"
    2024-08-28 23:30:06.530  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connection closed: disconnected
    2024-08-28 23:30:06.709  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-08-28 23:30:06.728  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-08-28 23:30:06.729  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-08-28 23:30:06.730  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-08-28 23:30:06.926  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connected with secret 1724880606923_6224
    2024-08-28 23:30:07.048  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.12V_on_off"
    2024-08-28 23:30:07.058  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert2"
    2024-08-28 23:30:07.059  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert3"
    2024-08-28 23:30:07.060  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert4"
    2024-08-28 23:30:07.249  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-08-28 23:30:07.259  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-08-28 23:30:07.260  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-08-28 23:30:07.261  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-08-28 23:30:08.311  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connected with secret 1724880608310_4118
    2024-08-28 23:30:08.334  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#" with regex /^Aussenfuehler\..*/
    2024-08-28 23:30:08.335  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#"  with regex /^mqtt\.1\.Aussenfuehler\..*/
    2024-08-28 23:30:08.536  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] publishOnSubscribe send all known states
    2024-08-28 23:30:09.840  - info: mqtt.1 (26882) Client [mosqsub|20937-Dachrollo] connected with secret 1724880609839_84
    2024-08-28 23:30:09.845  - info: mqtt.1 (26882) Client [mosqsub|20937-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
    2024-08-28 23:30:10.047  - info: mqtt.1 (26882) Client [mosqsub|20937-Dachrollo] publishOnSubscribe
    2024-08-28 23:30:10.052  - info: mqtt.1 (26882) Client [mosqsub|20937-Dachrollo] connection closed: disconnected
    2024-08-28 23:30:10.139  - info: mqtt.1 (26882) Client [mosqsub|20939-Dachrollo] connected with secret 1724880610138_6843
    2024-08-28 23:30:10.143  - info: mqtt.1 (26882) Client [mosqsub|20939-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
    2024-08-28 23:30:10.344  - info: mqtt.1 (26882) Client [mosqsub|20939-Dachrollo] publishOnSubscribe
    2024-08-28 23:30:10.348  - info: mqtt.1 (26882) Client [mosqsub|20939-Dachrollo] connection closed: disconnected
    2024-08-28 23:30:10.435  - info: mqtt.1 (26882) Client [mosqsub|20941-Dachrollo] connected with secret 1724880610434_1514
    2024-08-28 23:30:10.439  - info: mqtt.1 (26882) Client [mosqsub|20941-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
    2024-08-28 23:30:10.639  - info: mqtt.1 (26882) Client [mosqsub|20941-Dachrollo] publishOnSubscribe
    2024-08-28 23:30:10.642  - info: mqtt.1 (26882) Client [mosqsub|20941-Dachrollo] connection closed: disconnected
    2024-08-28 23:30:10.729  - info: mqtt.1 (26882) Client [mosqsub|20943-Dachrollo] connected with secret 1724880610729_4274
    2024-08-28 23:30:10.734  - info: mqtt.1 (26882) Client [mosqsub|20943-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
    2024-08-28 23:30:10.933  - info: mqtt.1 (26882) Client [mosqsub|20943-Dachrollo] publishOnSubscribe
    2024-08-28 23:30:10.937  - info: mqtt.1 (26882) Client [mosqsub|20943-Dachrollo] connection closed: disconnected
    2024-08-28 23:30:11.024  - info: mqtt.1 (26882) Client [mosqsub|20945-Dachrollo] connected with secret 1724880611022_7241
    2024-08-28 23:30:11.031  - info: mqtt.1 (26882) Client [mosqsub|20945-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
    2024-08-28 23:30:11.231  - info: mqtt.1 (26882) Client [mosqsub|20945-Dachrollo] publishOnSubscribe
    2024-08-28 23:30:11.235  - info: mqtt.1 (26882) Client [mosqsub|20945-Dachrollo] connection closed: disconnected
    2024-08-28 23:30:11.334  - info: mqtt.1 (26882) Client [mosqpub|20947-Dachrollo] connected with secret 1724880611332_7886
    2024-08-28 23:30:11.340  - info: mqtt.1 (26882) Client [mosqpub|20947-Dachrollo] connection closed: disconnected
    2024-08-28 23:30:11.434  - info: mqtt.1 (26882) Client [mosqpub|20949-Dachrollo] connected with secret 1724880611432_1732
    2024-08-28 23:30:11.438  - info: mqtt.1 (26882) Client [mosqpub|20949-Dachrollo] connection closed: disconnected
    2024-08-28 23:30:11.532  - info: mqtt.1 (26882) Client [mosqpub|20951-Dachrollo] connected with secret 1724880611531_1670
    2024-08-28 23:30:11.536  - info: mqtt.1 (26882) Client [mosqpub|20951-Dachrollo] connection closed: disconnected
    2024-08-28 23:30:11.633  - info: mqtt.1 (26882) Client [mosqpub|20953-Dachrollo] connected with secret 1724880611632_7524
    2024-08-28 23:30:11.637  - info: mqtt.1 (26882) Client [mosqpub|20953-Dachrollo] connection closed: disconnected
    2024-08-28 23:30:11.731  - info: mqtt.1 (26882) Client [mosqpub|20955-Dachrollo] connected with secret 1724880611730_1286
    2024-08-28 23:30:11.737  - info: mqtt.1 (26882) Client [mosqpub|20955-Dachrollo] connection closed: disconnected
    2024-08-28 23:30:12.022  - info: mqtt.1 (26882) Client [mosqpub|20970-Dachrollo] connected with secret 1724880612020_5469
    2024-08-28 23:30:12.028  - info: mqtt.1 (26882) Client [mosqpub|20970-Dachrollo] connection closed: disconnected
    2024-08-28 23:30:12.191  - info: mqtt.1 (26882) Client [mosqpub|20976-Dachrollo] connected with secret 1724880612190_4018
    2024-08-28 23:30:12.196  - info: mqtt.1 (26882) Client [mosqpub|20976-Dachrollo] connection closed: disconnected
    2024-08-28 23:30:16.090  - info: host.raspberrypi instance system.adapter.solarmanpv.0 in version "0.5.1" started with pid 3463
    2024-08-28 23:30:20.386  - info: solarmanpv.0 (3463) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v20.17.0, js-controller: 6.0.11
    2024-08-28 23:30:26.448  - info: solarmanpv.0 (3463) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2024-08-28 23:30:27.010  - info: host.raspberrypi instance system.adapter.solarmanpv.0 having pid 3463 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-08-28 23:31:01.576  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connection closed: disconnected
    2024-08-28 23:31:09.600  - info: mqtt.1 (26882) Client [mosqsub|21001-Dachrollo] connected with secret 1724880669599_266
    2024-08-28 23:31:09.605  - info: mqtt.1 (26882) Client [mosqsub|21001-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
    2024-08-28 23:31:09.806  - info: mqtt.1 (26882) Client [mosqsub|21001-Dachrollo] publishOnSubscribe
    2024-08-28 23:31:09.810  - info: mqtt.1 (26882) Client [mosqsub|21001-Dachrollo] connection closed: disconnected
    2024-08-28 23:31:09.897  - info: mqtt.1 (26882) Client [mosqsub|21003-Dachrollo] connected with secret 1724880669896_5577
    2024-08-28 23:31:09.901  - info: mqtt.1 (26882) Client [mosqsub|21003-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
    2024-08-28 23:31:10.102  - info: mqtt.1 (26882) Client [mosqsub|21003-Dachrollo] publishOnSubscribe
    2024-08-28 23:31:10.105  - info: mqtt.1 (26882) Client [mosqsub|21003-Dachrollo] connection closed: disconnected
    2024-08-28 23:31:10.195  - info: mqtt.1 (26882) Client [mosqsub|21005-Dachrollo] connected with secret 1724880670193_6155
    2024-08-28 23:31:10.199  - info: mqtt.1 (26882) Client [mosqsub|21005-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
    2024-08-28 23:31:10.400  - info: mqtt.1 (26882) Client [mosqsub|21005-Dachrollo] publishOnSubscribe
    2024-08-28 23:31:10.404  - info: mqtt.1 (26882) Client [mosqsub|21005-Dachrollo] connection closed: disconnected
    2024-08-28 23:31:10.494  - info: mqtt.1 (26882) Client [mosqsub|21007-Dachrollo] connected with secret 1724880670492_5423
    2024-08-28 23:31:10.498  - info: mqtt.1 (26882) Client [mosqsub|21007-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
    2024-08-28 23:31:10.700  - info: mqtt.1 (26882) Client [mosqsub|21007-Dachrollo] publishOnSubscribe
    2024-08-28 23:31:10.704  - info: mqtt.1 (26882) Client [mosqsub|21007-Dachrollo] connection closed: disconnected
    2024-08-28 23:31:10.793  - info: mqtt.1 (26882) Client [mosqsub|21009-Dachrollo] connected with secret 1724880670792_2510
    2024-08-28 23:31:10.798  - info: mqtt.1 (26882) Client [mosqsub|21009-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
    2024-08-28 23:31:10.999  - info: mqtt.1 (26882) Client [mosqsub|21009-Dachrollo] publishOnSubscribe
    2024-08-28 23:31:11.004  - info: mqtt.1 (26882) Client [mosqsub|21009-Dachrollo] connection closed: disconnected
    2024-08-28 23:31:11.100  - info: mqtt.1 (26882) Client [mosqpub|21011-Dachrollo] connected with secret 1724880671099_3141
    2024-08-28 23:31:11.105  - info: mqtt.1 (26882) Client [mosqpub|21011-Dachrollo] connection closed: disconnected
    2024-08-28 23:31:11.201  - info: mqtt.1 (26882) Client [mosqpub|21013-Dachrollo] connected with secret 1724880671200_5157
    2024-08-28 23:31:11.205  - info: mqtt.1 (26882) Client [mosqpub|21013-Dachrollo] connection closed: disconnected
    2024-08-28 23:31:11.301  - info: mqtt.1 (26882) Client [mosqpub|21015-Dachrollo] connected with secret 1724880671300_2586
    2024-08-28 23:31:11.306  - info: mqtt.1 (26882) Client [mosqpub|21015-Dachrollo] connection closed: disconnected
    2024-08-28 23:31:11.400  - info: mqtt.1 (26882) Client [mosqpub|21017-Dachrollo] connected with secret 1724880671398_6147
    2024-08-28 23:31:11.406  - info: mqtt.1 (26882) Client [mosqpub|21017-Dachrollo] connection closed: disconnected
    2024-08-28 23:31:11.498  - info: mqtt.1 (26882) Client [mosqpub|21019-Dachrollo] connected with secret 1724880671497_5787
    2024-08-28 23:31:11.502  - info: mqtt.1 (26882) Client [mosqpub|21019-Dachrollo] connection closed: disconnected
    2024-08-28 23:31:11.788  - info: mqtt.1 (26882) Client [mosqpub|21034-Dachrollo] connected with secret 1724880671787_1514
    2024-08-28 23:31:11.793  - info: mqtt.1 (26882) Client [mosqpub|21034-Dachrollo] connection closed: disconnected
    2024-08-28 23:31:11.959  - info: mqtt.1 (26882) Client [mosqpub|21040-Dachrollo] connected with secret 1724880671958_6103
    2024-08-28 23:31:11.964  - info: mqtt.1 (26882) Client [mosqpub|21040-Dachrollo] connection closed: disconnected
    2024-08-28 23:31:12.255  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connection closed: timeout
    2024-08-28 23:31:53.672  - info: web.0 (26709) <== Disconnect system.user.admin from ::ffff:192.168.1.63 vis.0
    2024-08-28 23:32:09.627  - info: mqtt.1 (26882) Client [mosqsub|21065-Dachrollo] connected with secret 1724880729626_9840
    2024-08-28 23:32:09.630  - info: mqtt.1 (26882) Client [mosqsub|21065-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
    2024-08-28 23:32:09.831  - info: mqtt.1 (26882) Client [mosqsub|21065-Dachrollo] publishOnSubscribe
    2024-08-28 23:32:09.836  - info: mqtt.1 (26882) Client [mosqsub|21065-Dachrollo] connection closed: disconnected
    2024-08-28 23:32:09.920  - info: mqtt.1 (26882) Client [mosqsub|21067-Dachrollo] connected with secret 1724880729919_130
    2024-08-28 23:32:09.924  - info: mqtt.1 (26882) Client [mosqsub|21067-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
    2024-08-28 23:32:10.126  - info: mqtt.1 (26882) Client [mosqsub|21067-Dachrollo] publishOnSubscribe
    2024-08-28 23:32:10.131  - info: mqtt.1 (26882) Client [mosqsub|21067-Dachrollo] connection closed: disconnected
    2024-08-28 23:32:10.215  - info: mqtt.1 (26882) Client [mosqsub|21069-Dachrollo] connected with secret 1724880730214_885
    2024-08-28 23:32:10.219  - info: mqtt.1 (26882) Client [mosqsub|21069-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
    2024-08-28 23:32:10.420  - info: mqtt.1 (26882) Client [mosqsub|21069-Dachrollo] publishOnSubscribe
    2024-08-28 23:32:10.424  - info: mqtt.1 (26882) Client [mosqsub|21069-Dachrollo] connection closed: disconnected
    2024-08-28 23:32:10.512  - info: mqtt.1 (26882) Client [mosqsub|21071-Dachrollo] connected with secret 1724880730511_5111
    2024-08-28 23:32:10.515  - info: mqtt.1 (26882) Client [mosqsub|21071-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
    2024-08-28 23:32:10.716  - info: mqtt.1 (26882) Client [mosqsub|21071-Dachrollo] publishOnSubscribe
    2024-08-28 23:32:10.720  - info: mqtt.1 (26882) Client [mosqsub|21071-Dachrollo] connection closed: disconnected
    2024-08-28 23:32:10.808  - info: mqtt.1 (26882) Client [mosqsub|21073-Dachrollo] connected with secret 1724880730807_9951
    2024-08-28 23:32:10.813  - info: mqtt.1 (26882) Client [mosqsub|21073-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
    2024-08-28 23:32:11.014  - info: mqtt.1 (26882) Client [mosqsub|21073-Dachrollo] publishOnSubscribe
    2024-08-28 23:32:11.018  - info: mqtt.1 (26882) Client [mosqsub|21073-Dachrollo] connection closed: disconnected
    2024-08-28 23:32:11.116  - info: mqtt.1 (26882) Client [mosqpub|21075-Dachrollo] connected with secret 1724880731115_4953
    2024-08-28 23:32:11.122  - info: mqtt.1 (26882) Client [mosqpub|21075-Dachrollo] connection closed: disconnected
    2024-08-28 23:32:11.217  - info: mqtt.1 (26882) Client [mosqpub|21077-Dachrollo] connected with secret 1724880731216_3779
    2024-08-28 23:32:11.224  - info: mqtt.1 (26882) Client [mosqpub|21077-Dachrollo] connection closed: disconnected
    2024-08-28 23:32:11.318  - info: mqtt.1 (26882) Client [mosqpub|21079-Dachrollo] connected with secret 1724880731317_7677
    2024-08-28 23:32:11.323  - info: mqtt.1 (26882) Client [mosqpub|21079-Dachrollo] connection closed: disconnected
    2024-08-28 23:32:11.414  - info: mqtt.1 (26882) Client [mosqpub|21081-Dachrollo] connected with secret 1724880731414_1714
    2024-08-28 23:32:11.421  - info: mqtt.1 (26882) Client [mosqpub|21081-Dachrollo] connection closed: disconnected
    2024-08-28 23:32:11.511  - info: mqtt.1 (26882) Client [mosqpub|21083-Dachrollo] connected with secret 1724880731510_2679
    2024-08-28 23:32:11.517  - info: mqtt.1 (26882) Client [mosqpub|21083-Dachrollo] connection closed: disconnected
    2024-08-28 23:32:11.801  - info: mqtt.1 (26882) Client [mosqpub|21098-Dachrollo] connected with secret 1724880731800_6944
    2024-08-28 23:32:11.805  - info: mqtt.1 (26882) Client [mosqpub|21098-Dachrollo] connection closed: disconnected
    2024-08-28 23:32:11.974  - info: mqtt.1 (26882) Client [mosqpub|21104-Dachrollo] connected with secret 1724880731973_9365
    2024-08-28 23:32:11.979  - info: mqtt.1 (26882) Client [mosqpub|21104-Dachrollo] connection closed: disconnected
    2024-08-28 23:33:00.167  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier Swap: 1647
     MB von 2048MB (80%)
    2024-08-28 23:33:00.169  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: GPU Temp: 50.5 °C
    2024-08-28 23:33:00.170  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: CPU Temp: 50.464 °C
    2024-08-28 23:33:00.174  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier RAM: 275
     MB von 922MB (30%)
    2024-08-28 23:33:09.618  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connected with secret 1724880789617_2706
    2024-08-28 23:33:09.748  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.12V_on_off"
    2024-08-28 23:33:09.763  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert2"
    2024-08-28 23:33:09.764  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert3"
    2024-08-28 23:33:09.765  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert4"
    2024-08-28 23:33:09.766  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connection closed: disconnected
    2024-08-28 23:33:09.949  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-08-28 23:33:09.964  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-08-28 23:33:09.970  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-08-28 23:33:09.971  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
    2024-08-28 23:33:10.158  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connected with secret 1724880790154_1169
    2024-08-28 23:33:10.198  - info: mqtt.1 (26882) Client [mosqsub|21130-Dachrollo] connected with secret 1724880790197_1908
    2024-08-28 23:33:10.202  - info: mqtt.1 (26882) Client [mosqsub|21130-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
    2024-08-28 23:33:10.278  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.12V_on_off"
    2024-08-28 23:33:10.288  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert2"
    2024-08-28 23:33:10.289  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert3"
    2024-08-28 23:33:10.290  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert4"
    2024-08-28 23:33:10.403  - info: mqtt.1 (26882) Client [mosqsub|21130-Dachrollo] publishOnSubscribe
    2024-08-28 23:33:10.407  - info: mqtt.1 (26882) Client [mosqsub|21130-Dachrollo] connection closed: disconnected
    2024-08-28 23:33:10.480  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-08-28 23:33:10.489  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-08-28 23:33:10.491  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-08-28 23:33:10.492  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
    2024-08-28 23:33:10.496  - info: mqtt.1 (26882) Client [mosqsub|21132-Dachrollo] connected with secret 1724880790495_8889
    2024-08-28 23:33:10.501  - info: mqtt.1 (26882) Client [mosqsub|21132-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
    2024-08-28 23:33:10.702  - info: mqtt.1 (26882) Client [mosqsub|21132-Dachrollo] publishOnSubscribe
    2024-08-28 23:33:10.707  - info: mqtt.1 (26882) Client [mosqsub|21132-Dachrollo] connection closed: disconnected
    2024-08-28 23:33:10.782  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connected with secret 1724880790781_6189
    2024-08-28 23:33:10.797  - info: mqtt.1 (26882) Client [mosqsub|21134-Dachrollo] connected with secret 1724880790791_138
    2024-08-28 23:33:10.802  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#" with regex /^Aussenfuehler\..*/
    2024-08-28 23:33:10.803  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#"  with regex /^mqtt\.1\.Aussenfuehler\..*/
    2024-08-28 23:33:10.806  - info: mqtt.1 (26882) Client [mosqsub|21134-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
    2024-08-28 23:33:10.837  - info: mqtt.1 (26882) Client [mosqsub|21134-Dachrollo] connection closed: disconnected
    2024-08-28 23:33:10.921  - info: mqtt.1 (26882) Client [mosqsub|21136-Dachrollo] connected with secret 1724880790921_4967
    2024-08-28 23:33:10.926  - info: mqtt.1 (26882) Client [mosqsub|21136-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
    2024-08-28 23:33:11.003  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] publishOnSubscribe send all known states
    2024-08-28 23:33:11.007  - info: mqtt.1 (26882) Client [mosqsub|21134-Dachrollo] publishOnSubscribe
    2024-08-28 23:33:11.126  - info: mqtt.1 (26882) Client [mosqsub|21136-Dachrollo] publishOnSubscribe
    2024-08-28 23:33:11.144  - info: mqtt.1 (26882) Client [mosqsub|21136-Dachrollo] connection closed: disconnected
    2024-08-28 23:33:11.231  - info: mqtt.1 (26882) Client [mosqsub|21138-Dachrollo] connected with secret 1724880791230_2289
    2024-08-28 23:33:11.235  - info: mqtt.1 (26882) Client [mosqsub|21138-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
    2024-08-28 23:33:11.436  - info: mqtt.1 (26882) Client [mosqsub|21138-Dachrollo] publishOnSubscribe
    2024-08-28 23:33:11.440  - info: mqtt.1 (26882) Client [mosqsub|21138-Dachrollo] connection closed: disconnected
    2024-08-28 23:33:11.537  - info: mqtt.1 (26882) Client [mosqpub|21140-Dachrollo] connected with secret 1724880791536_1720
    2024-08-28 23:33:11.542  - info: mqtt.1 (26882) Client [mosqpub|21140-Dachrollo] connection closed: disconnected
    2024-08-28 23:33:11.635  - info: mqtt.1 (26882) Client [mosqpub|21142-Dachrollo] connected with secret 1724880791634_1007
    2024-08-28 23:33:11.640  - info: mqtt.1 (26882) Client [mosqpub|21142-Dachrollo] connection closed: disconnected
    2024-08-28 23:33:11.733  - info: mqtt.1 (26882) Client [mosqpub|21144-Dachrollo] connected with secret 1724880791732_6488
    2024-08-28 23:33:11.739  - info: mqtt.1 (26882) Client [mosqpub|21144-Dachrollo] connection closed: disconnected
    2024-08-28 23:33:11.831  - info: mqtt.1 (26882) Client [mosqpub|21146-Dachrollo] connected with secret 1724880791830_5171
    2024-08-28 23:33:11.837  - info: mqtt.1 (26882) Client [mosqpub|21146-Dachrollo] connection closed: disconnected
    2024-08-28 23:33:11.932  - info: mqtt.1 (26882) Client [mosqpub|21148-Dachrollo] connected with secret 1724880791931_7
    2024-08-28 23:33:11.936  - info: mqtt.1 (26882) Client [mosqpub|21148-Dachrollo] connection closed: disconnected
    2024-08-28 23:33:12.102  - info: host.raspberrypi instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 4431
    2024-08-28 23:33:12.221  - info: mqtt.1 (26882) Client [mosqpub|21163-Dachrollo] connected with secret 1724880792220_4268
    2024-08-28 23:33:12.226  - info: mqtt.1 (26882) Client [mosqpub|21163-Dachrollo] connection closed: disconnected
    2024-08-28 23:33:12.390  - info: mqtt.1 (26882) Client [mosqpub|21169-Dachrollo] connected with secret 1724880792389_8236
    2024-08-28 23:33:12.397  - info: mqtt.1 (26882) Client [mosqpub|21169-Dachrollo] connection closed: disconnected
    2024-08-28 23:33:17.921  - info: openweathermap.0 (4431) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.17.0, js-controller: 6.0.11
    2024-08-28 23:33:33.176  - info: openweathermap.0 (4431) Terminated (NO_ERROR): Without reason
    2024-08-28 23:33:33.731  - info: host.raspberrypi instance system.adapter.openweathermap.0 having pid 4431 terminated with code 0 (NO_ERROR)
    2024-08-28 23:33:55.602  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connection closed: disconnected
    2024-08-28 23:34:05.529  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connection closed: timeout
    2024-08-28 23:34:10.081  - info: mqtt.1 (26882) Client [mosqsub|21194-Dachrollo] connected with secret 1724880850080_3567
    2024-08-28 23:34:10.087  - info: mqtt.1 (26882) Client [mosqsub|21194-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
    2024-08-28 23:34:10.288  - info: mqtt.1 (26882) Client [mosqsub|21194-Dachrollo] publishOnSubscribe
    2024-08-28 23:34:10.292  - info: mqtt.1 (26882) Client [mosqsub|21194-Dachrollo] connection closed: disconnected
    2024-08-28 23:34:10.382  - info: mqtt.1 (26882) Client [mosqsub|21196-Dachrollo] connected with secret 1724880850380_616
    2024-08-28 23:34:10.386  - info: mqtt.1 (26882) Client [mosqsub|21196-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
    2024-08-28 23:34:10.588  - info: mqtt.1 (26882) Client [mosqsub|21196-Dachrollo] publishOnSubscribe
    2024-08-28 23:34:10.592  - info: mqtt.1 (26882) Client [mosqsub|21196-Dachrollo] connection closed: disconnected
    2024-08-28 23:34:10.680  - info: mqtt.1 (26882) Client [mosqsub|21198-Dachrollo] connected with secret 1724880850679_9243
    2024-08-28 23:34:10.684  - info: mqtt.1 (26882) Client [mosqsub|21198-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
    2024-08-28 23:34:10.886  - info: mqtt.1 (26882) Client [mosqsub|21198-Dachrollo] publishOnSubscribe
    2024-08-28 23:34:10.890  - info: mqtt.1 (26882) Client [mosqsub|21198-Dachrollo] connection closed: disconnected
    2024-08-28 23:34:10.979  - info: mqtt.1 (26882) Client [mosqsub|21200-Dachrollo] connected with secret 1724880850978_7977
    2024-08-28 23:34:10.983  - info: mqtt.1 (26882) Client [mosqsub|21200-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
    2024-08-28 23:34:11.184  - info: mqtt.1 (26882) Client [mosqsub|21200-Dachrollo] publishOnSubscribe
    2024-08-28 23:34:11.188  - info: mqtt.1 (26882) Client [mosqsub|21200-Dachrollo] connection closed: disconnected
    2024-08-28 23:34:11.273  - info: mqtt.1 (26882) Client [mosqsub|21202-Dachrollo] connected with secret 1724880851272_675
    2024-08-28 23:34:11.276  - info: mqtt.1 (26882) Client [mosqsub|21202-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
    2024-08-28 23:34:11.477  - info: mqtt.1 (26882) Client [mosqsub|21202-Dachrollo] publishOnSubscribe
    2024-08-28 23:34:11.480  - info: mqtt.1 (26882) Client [mosqsub|21202-Dachrollo] connection closed: disconnected
    2024-08-28 23:34:11.578  - info: mqtt.1 (26882) Client [mosqpub|21204-Dachrollo] connected with secret 1724880851578_9634
    2024-08-28 23:34:11.582  - info: mqtt.1 (26882) Client [mosqpub|21204-Dachrollo] connection closed: disconnected
    2024-08-28 23:34:11.677  - info: mqtt.1 (26882) Client [mosqpub|21206-Dachrollo] connected with secret 1724880851676_7585
    2024-08-28 23:34:11.681  - info: mqtt.1 (26882) Client [mosqpub|21206-Dachrollo] connection closed: disconnected
    2024-08-28 23:34:11.783  - info: mqtt.1 (26882) Client [mosqpub|21208-Dachrollo] connected with secret 1724880851781_2571
    2024-08-28 23:34:11.787  - info: mqtt.1 (26882) Client [mosqpub|21208-Dachrollo] connection closed: disconnected
    2024-08-28 23:34:11.883  - info: mqtt.1 (26882) Client [mosqpub|21210-Dachrollo] connected with secret 1724880851882_5629
    2024-08-28 23:34:11.887  - info: mqtt.1 (26882) Client [mosqpub|21210-Dachrollo] connection closed: disconnected
    2024-08-28 23:34:11.984  - info: mqtt.1 (26882) Client [mosqpub|21212-Dachrollo] connected with secret 1724880851983_6311
    2024-08-28 23:34:11.989  - info: mqtt.1 (26882) Client [mosqpub|21212-Dachrollo] connection closed: disconnected
    2024-08-28 23:34:12.275  - info: mqtt.1 (26882) Client [mosqpub|21227-Dachrollo] connected with secret 1724880852274_1264
    2024-08-28 23:34:12.280  - info: mqtt.1 (26882) Client [mosqpub|21227-Dachrollo] connection closed: disconnected
    2024-08-28 23:34:12.443  - info: mqtt.1 (26882) Client [mosqpub|21233-Dachrollo] connected with secret 1724880852442_7748
    2024-08-28 23:34:12.449  - info: mqtt.1 (26882) Client [mosqpub|21233-Dachrollo] connection closed: disconnected
    2024-08-28 23:35:10.184  - info: mqtt.1 (26882) Client [mosqsub|21259-Dachrollo] connected with secret 1724880910179_266
    2024-08-28 23:35:10.188  - info: mqtt.1 (26882) Client [mosqsub|21259-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
    2024-08-28 23:35:10.389  - info: mqtt.1 (26882) Client [mosqsub|21259-Dachrollo] publishOnSubscribe
    2024-08-28 23:35:10.392  - info: mqtt.1 (26882) Client [mosqsub|21259-Dachrollo] connection closed: disconnected
    2024-08-28 23:35:10.481  - info: mqtt.1 (26882) Client [mosqsub|21261-Dachrollo] connected with secret 1724880910480_4468
    2024-08-28 23:35:10.485  - info: mqtt.1 (26882) Client [mosqsub|21261-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
    2024-08-28 23:35:10.686  - info: mqtt.1 (26882) Client [mosqsub|21261-Dachrollo] publishOnSubscribe
    2024-08-28 23:35:10.691  - info: mqtt.1 (26882) Client [mosqsub|21261-Dachrollo] connection closed: disconnected
    2024-08-28 23:35:10.776  - info: mqtt.1 (26882) Client [mosqsub|21263-Dachrollo] connected with secret 1724880910775_6079
    2024-08-28 23:35:10.780  - info: mqtt.1 (26882) Client [mosqsub|21263-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
    2024-08-28 23:35:10.980  - info: mqtt.1 (26882) Client [mosqsub|21263-Dachrollo] publishOnSubscribe
    2024-08-28 23:35:10.984  - info: mqtt.1 (26882) Client [mosqsub|21263-Dachrollo] connection closed: disconnected
    2024-08-28 23:35:11.074  - info: mqtt.1 (26882) Client [mosqsub|21265-Dachrollo] connected with secret 1724880911073_2895
    2024-08-28 23:35:11.079  - info: mqtt.1 (26882) Client [mosqsub|21265-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
    2024-08-28 23:35:11.280  - info: mqtt.1 (26882) Client [mosqsub|21265-Dachrollo] publishOnSubscribe
    2024-08-28 23:35:11.284  - info: mqtt.1 (26882) Client [mosqsub|21265-Dachrollo] connection closed: disconnected
    2024-08-28 23:35:11.372  - info: mqtt.1 (26882) Client [mosqsub|21267-Dachrollo] connected with secret 1724880911370_5712
    2024-08-28 23:35:11.376  - info: mqtt.1 (26882) Client [mosqsub|21267-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
    2024-08-28 23:35:11.578  - info: mqtt.1 (26882) Client [mosqsub|21267-Dachrollo] publishOnSubscribe
    2024-08-28 23:35:11.581  - info: mqtt.1 (26882) Client [mosqsub|21267-Dachrollo] connection closed: disconnected
    2024-08-28 23:35:11.678  - info: mqtt.1 (26882) Client [mosqpub|21269-Dachrollo] connected with secret 1724880911677_3316
    2024-08-28 23:35:11.682  - info: mqtt.1 (26882) Client [mosqpub|21269-Dachrollo] connection closed: disconnected
    2024-08-28 23:35:11.777  - info: mqtt.1 (26882) Client [mosqpub|21271-Dachrollo] connected with secret 1724880911776_1770
    2024-08-28 23:35:11.781  - info: mqtt.1 (26882) Client [mosqpub|21271-Dachrollo] connection closed: disconnected
    2024-08-28 23:35:11.875  - info: mqtt.1 (26882) Client [mosqpub|21273-Dachrollo] connected with secret 1724880911874_1281
    2024-08-28 23:35:11.879  - info: mqtt.1 (26882) Client [mosqpub|21273-Dachrollo] connection closed: disconnected
    2024-08-28 23:35:11.972  - info: mqtt.1 (26882) Client [mosqpub|21275-Dachrollo] connected with secret 1724880911971_1361
    2024-08-28 23:35:11.976  - info: mqtt.1 (26882) Client [mosqpub|21275-Dachrollo] connection closed: disconnected
    2024-08-28 23:35:12.070  - info: mqtt.1 (26882) Client [mosqpub|21277-Dachrollo] connected with secret 1724880912069_4224
    2024-08-28 23:35:12.075  - info: mqtt.1 (26882) Client [mosqpub|21277-Dachrollo] connection closed: disconnected
    2024-08-28 23:35:12.365  - info: mqtt.1 (26882) Client [mosqpub|21292-Dachrollo] connected with secret 1724880912364_9741
    2024-08-28 23:35:12.374  - info: mqtt.1 (26882) Client [mosqpub|21292-Dachrollo] connection closed: disconnected
    2024-08-28 23:35:12.541  - info: mqtt.1 (26882) Client [mosqpub|21298-Dachrollo] connected with secret 1724880912539_6908
    2024-08-28 23:35:12.546  - info: mqtt.1 (26882) Client [mosqpub|21298-Dachrollo] connection closed: disconnected
    2024-08-28 23:35:16.047  - info: host.raspberrypi instance system.adapter.solarmanpv.0 in version "0.5.1" started with pid 5119
    2024-08-28 23:35:20.529  - info: solarmanpv.0 (5119) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v20.17.0, js-controller: 6.0.11
    2024-08-28 23:35:24.146  - info: solarmanpv.0 (5119) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2024-08-28 23:35:24.701  - info: host.raspberrypi instance system.adapter.solarmanpv.0 having pid 5119 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    pi@raspberrypi:~ $
    spicerS Offline
    spicerS Offline
    spicer
    Das ist wohl interessanter:
    2024-08-28 23:24:40.199  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1228
    2024-08-28 23:24:40.201  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2024-08-28 23:24:40.202  - error: host.raspberrypi Caught by controller[0]:   ^
    2024-08-28 23:24:40.204  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
    2024-08-28 23:24:40.205  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2024-08-28 23:24:40.206  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/main.js
    2024-08-28 23:24:40.207  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
    2024-08-28 23:24:40.208  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
    2024-08-28 23:24:40.210  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
    2024-08-28 23:24:40.210  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
    2024-08-28 23:24:40.211  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
    2024-08-28 23:24:40.211  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
    2024-08-28 23:24:40.212  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
    2024-08-28 23:24:40.213  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
    2024-08-28 23:24:40.214  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
    2024-08-28 23:24:40.215  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
    2024-08-28 23:24:40.215  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-08-28 23:24:40.218  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
    2024-08-28 23:24:40.222  - error: host.raspberrypi Caught by controller[0]: }
    2024-08-28 23:24:40.223  - error: host.raspberrypi Caught by controller[0]: Node.js v20.17.0
    2024-08-28 23:24:40.224  - error: host.raspberrypi instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-08-28 23:24:40.225  - info: host.raspberrypi Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    Wenn es mehrere Möglichkeiten gibt, eine Aufgabe zu erledigen, und eine davon in einer Katastrophe endet oder sonstwie unerwünschte Konsequenzen nach sich zieht, dann wird es jemand genau so machen. Alles, was schiefgehen kann, wird auch schiefgehen.
    (Murphys Gesetz)
    • spicerS spicer
      @spicer
      iobroker rebuild echarts
      parallel in einer zweiten Session das Log beobachten.
      iob logs --watch
      spicerS 1 Antwort Letzte Antwort
        @spicer
        iob logs --watch
        spicerS Offline
        spicerS Offline
        spicer
        pi@raspberrypi:~ $ iobroker rebuild echarts
        Rebuilding native module "echarts" ...
        rebuilt dependencies successfully
        Rebuilding native modules done
        In der anderen Konsole ist nichts relevantes erschienen.
        (Murphys Gesetz)
        • spicerS Offline
          spicerS Offline
          spicer
          Sorry, ich muss jetzt erstmal ins Bett. Kann morgen am späteren Nachmittag weiter machen ;)
          Vielen Dank schonmal für Deine Hilfe.
          (Murphys Gesetz)
            @spicer sagte in Nach Update js-controller macht host.raspberrypi Fehler:
            Operating System: Raspbian GNU/Linux 11 (bullseye)
            Installier das bei nächster Gelegenheit komplett neu.
            Dann ohne Desktop und in der 64Bit-Version.
            Und mit einem username ungleich 'pi' und ungleich 'iobroker'.
            iob start echarts.0
            sagt?
            spicerS Offline
            spicerS Offline
            spicer
            schrieb am zuletzt editiert von spicer
            @thomas-braun sagte in Nach Update js-controller macht host.raspberrypi Fehler:
            Hab ich vor ca 2 Jahren auf Empfehlung von hier bereits gemacht und immer brav die empfohlenen Updates gemacht.
            Damals war das System auch in instabilem Zustand wegen Updates.
            Dann mache ich doch besser keine Updates mehr... ist eigentlich Irrsinn.
            Nein, braucht man nicht. deCONZ läuft auch headless. Und VNC braucht es auf einem Server nie. Weil da nie eine GUI rennt.
            Habe mich ev etwas falsch ausgedrückt.
            Am RPI hängt ein RaspBee 2 (ZigBee Adapter). Um diese GUI zu erhalten
            habe ich keine Lösung gefunden, bei welcher die GUI per http im Browser angeschaut/editiert werden kann.
            Natürlich hat man sonst auf den Servern keine GUI. Das hab ich auf meinen externen Servern auch nirgends drauf ;)
            (Murphys Gesetz)
            • spicerS Offline
              spicerS Offline
              spicer
              Zum Problem zurück.
              Jetzt wird's interessant. eCharts funktioniert und es kommen auch keine Fehler mehr im Log.
              Aber bei den Instanzen steht:
              (Murphys Gesetz)
              • spicerS spicer
                Du sollst es ja auch nicht updaten sondern NEUinstallieren.
                spicerS M 2 Antworten Letzte Antwort
                  spicerS Offline
                  spicerS Offline
                  spicer
                  Ich meine damit, wenn ich wieder ein neu aufgesetztes System habe, mache ich besser keine Updates mehr, da sonst das System wieder beschädigt wird.
                  Das war jetzt bereits das zweite mal, dass das System instabil wurde nach empfohlenen Updates.
                  (Murphys Gesetz)
                  • spicerS spicer
                    Das ist der größte Blödsinn.
                    dann war irgendetwas vorher verbogen.
                    • spicerS Offline
                      spicerS Offline
                      spicer
                      Natürlich ist das Blödsinn.
                      Aber wie sonst kann ich ein gebrochenes System verhindern?
                      Mehr als immer die empfohlenen Updates zu machen kann ich ja nicht.
                      Mir wird dann immer gesagt, diese Version von Modul x und Modul y passen nicht zusammen. Installiere neu.
                      Das kann es doch nicht sein. Der wohl kleinste Teil der User verfügt über genügend Wissen, um zu entscheiden, welche Version jetzt zu gebrauchen ist. Auch machen die meisten nicht extra ein Studium, um alle Zusammenhänge zuverstehn.
                      (Murphys Gesetz)
                      • spicerS spicer
                        @spicer ich verfüge auch nicht über das Wissen das mir nachgesagt wird. Ich lese nur viel.
                        Und mir ist in 11 Jahen noch nie ein System beim Upgrade "zerbrochen".
                        Dabei mache ich mir dabei gar keine Gedanken.
                        Eben weil ich das Wissen nicht habe, mache ich alle 2-3 Jahre einen clean install mit den neuesten Versionen OS, Nodejs, iobroker admin und controller und spiele da mein Backup zurück.
                        In der Zeit dazwischen regelmäßig OS Update was minor nodejs updates enthält, und alle stable Updates der Adapter.
                        Auf dem Server läuft keinerlei weitere Software, die ggf stlren, andere Voraussetzungen benötigt oder irgendwas sonst anstellt.
                        Damit bin ich bisher absolut problemlos zurechtgekommen
                          MacPo
                          Bei mir ist genau das gleiche Verhalten. Die Fehlermeldung von echarts ist beim Start vom js-controller nach dem Update von 6.0.9 auf 6.0.11 erschienen.
                          2024-08-29 17:03:44.064  - info: host.broker01 iobroker rebuild echarts --debug
                          2024-08-29 17:03:44.670  - info: host.broker01 iobroker Rebuilding native module "echarts" ...
                          2024-08-29 17:03:46.850  - info: host.broker01 iobroker rebuilt dependencies successfully
                          2024-08-29 17:03:46.872  - info: host.broker01 iobroker
                          2024-08-29 17:03:46.873  - info: host.broker01 iobroker Rebuilding native modules done
                          2024-08-29 17:03:47.880  - info: host.broker01 iobroker exit 0
                          2024-08-29 17:03:59.213  - info: host.broker01 instance system.adapter.echarts.0 in version "1.7.2" started with pid 3643197
                          2024-08-29 17:03:59.347  - error: host.broker01 Caught by controller[0]: node:internal/modules/cjs/loader:1148
                          2024-08-29 17:03:59.347  - error: host.broker01 Caught by controller[0]:   throw err;
                          2024-08-29 17:03:59.347  - error: host.broker01 Caught by controller[0]:   ^
                          2024-08-29 17:03:59.347  - error: host.broker01 Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
                          2024-08-29 17:03:59.347  - error: host.broker01 Caught by controller[0]: Require stack:
                          2024-08-29 17:03:59.347  - error: host.broker01 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/main.js
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:986:27)
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]: }
                          2024-08-29 17:03:59.348  - error: host.broker01 Caught by controller[0]: Node.js v20.16.0
                          2024-08-29 17:03:59.348  - error: host.broker01 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2024-08-29 17:03:59.348  - info: host.broker01 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                          • spicerS spicer
                            Ja, aber du musst sie halt auch machen. Zeitnah und vollständig.
                            Das ist i.d.R. nur die Folge aus versäumten Updates im Vorfeld. Oder von von vorneherein falscher/ungünstiger Installation.
                            Ich hab auch kein Informatikstudium absolviert. Muss man auch nicht für einfache Systempflege.
                              spicerS Offline
                              spicerS Offline
                              spicer
                              Das nehm ich Dir so jetzt nicht ab.
                              Habe immer sofort updated und, falls, wie beschrieben.
                              Zudem betreibe ich verschiedene Debian Server, welche sauber laufen. Wie kann man einen Server "ungünstig" installieren?
                              (Murphys Gesetz)
                              • spicerS spicer
                                Dann halt nicht. Ich verwende 'Linux' allerdings nicht erst 3 Wochen und weiß wie das da läuft. Insbesondere bei Debian.
                                Ungünstig installiert bezog sich auf eine 32Bit-Installation auf einer 64Bit-CPU.
                                • spicerS spicer
                                  Zum Problem zurück.
                                  spicerS Offline
                                  spicerS Offline
                                  spicer
                                  Zum Problem zurück.
                                  Was muss ich nun wegen dem verstehn?
                                  (Murphys Gesetz)
                                  St BeS 1 Antwort Letzte Antwort
                                  • spicerS spicer
                                    Zum Problem zurück.
                                    St BeS Offline
                                    St BeS Offline
                                    St Be
                                    @spicer Ich lese mal mit..ich habe gleiches Problem
                                    • St BeS St Be
                                      MacPo
                                      @st-be Für das Problem gibt es schon ein Ticket in GitHub https://github.com/ioBroker/ioBroker.echarts/issues/680
                                      Mit der Installation von 1.9.0 (noch nicht im stable) funktioniert der Adapter auch bei mir wieder.
                                      • M MacPo
                                        spicerS Offline
                                        spicerS Offline
                                        spicer
                                        @macpo
                                        Jep danke.
                                        Habe nun wie im Link empfohlen die eCharts V1.8.4 von der beta Repository installiert und das Problem scheint gelöst.
                                        Mit der V1.9.0 ist unterhalb des Charts (zBsp Datenquellen) das Fenster leer.
                                        (Murphys Gesetz)
                                        • spicerS Offline
                                          spicerS Offline
                                          spicer
                                          Der Backitup Adapter hat das gleiche Problem seit dem Update!
                                          Backup error: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js' ... please check your config and and try again!!
                                          Hab ihn aber gerade von Hand gestartet und der Backup ist so durchgelaufen.
                                          (Murphys Gesetz)
