  4. Test Adapter rpi2 2.x
    6.6k
519 Beiträge 29 Kommentatoren 195.2k Aufrufe 20 Beobachtet
    @dfred sagte in Raspberry 4B GPIOs since Update NodeJs 20.x are not Working:
    Vermutlich seit dem Update der NodeJs gehen die GPIOs des Raspi nicht mehr.
    Das hat mit nodejs@20 nix zu tun.
    iob stop
    iob fix
    iob start
    Und dann funktioniert auch
    iob diag
    dfred
    #71
    @thomas-braun said in Raspberry 4B GPIOs since Update NodeJs 20.x are not Working:
        iob stop        iob fix        iob start
    das hab ich schon mehrfach probiert. Iob diag funkt
    • D dfred
      @dfred
      hello, IOB diag nun richtig:
                              v.2024-05-22
         Static hostname: IOBMain
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.6.35-v8+
            Architecture: arm64
      Kernel:                 aarch64
      Userland:               32 bit
      User-ID:                1000
      Display-Server:         false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.16.0
      /usr/bin/node           v20.16.0
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      /usr/bin/corepack       0.28.2
      Recommended versions are nodejs 20.16.0 and npm 10.8.1
      MEMORY:
      Mem:            7.8G        1.8G        4.4G        0.0K        1.6G        5.9G
      Swap:            99M          0B         99M
      Total:          7.9G        1.8G        4.5G
      Active iob-Instances:   44
      Upgrade policy: none
      ioBroker Core:          js-controller           6.0.10
                              admin                   7.0.22
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : IOBMain                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : IOBMain                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                40910
      States:                 35311
      Size of iob-Database:
      38M     /opt/iobroker/iobroker-data/objects.jsonl
      15M     /opt/iobroker/iobroker-data/objects.json.migrated
      15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      4.0K    /opt/iobroker/iobroker-data/objects.json.old
      0       /opt/iobroker/iobroker-data/objects.json.broken
      44M     /opt/iobroker/iobroker-data/states.jsonl
      5.5M    /opt/iobroker/iobroker-data/states.json.old
      3.5M    /opt/iobroker/iobroker-data/states.json.migrated
      3.5M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      HomoranH Offline
      HomoranH Offline
      #72
      nein!
      leider nur die Zusammenfassung.
        nein!
        mcm1957M Online
        mcm1957M Online
        mcm1957
        #73
        Für die BETA 2.0.0 von rpi2 gibts einen eigenen Thread. Sollte DORT diskutiert werden,
        https://forum.iobroker.net/topic/75290/test-adapter-rpi2-2-x
        Und ja, 2.0.0 ist noch beta und es funktioniert noch nicht alles. Siehe oben genannten Thread und Issues im Repo. DANKE fürs Testen der BETA Version.
        @Homoran
        Ich rege an das zu mergen.
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • HomoranH Offline
          HomoranH Offline
          #74
          @mcm1957 erledigt!
          @mcm1957 sagte in Test Adapter rpi2 2.x:
          Das war mir nicht bewusst.
          ich dachte @dfred wäre noch im stable unterwegs.
            Tiedi
            #75
            also wird an der Sache weiter gearbeitet, richtig?
            Bei mir gehts auch mit 2.0.0 bisher nicht am Raspi 4.
            • T Tiedi
              #76
              @tiedi sagte in Test Adapter rpi2 2.x:
              Ja. Möglicherweise funktioniert es vollumfänglich mit einer angepassten Version von 'opengpio'. Da muss man aber ein paar unschöne Klimmzüge machen und ggfls. muss auch im Adapter noch was angepasst werden.
              Was geht genau nicht?
                Tiedi
                #77
                @thomas-braun Ich nutze 3 gpio PINs. Diese werden seit dem Update auf bookworm an meinem Raspi 4 nicht mehr aktualisiert.
                • GarfonsoG Offline
                  GarfonsoG Offline
                  Garfonso
                  #78
                  @tiedi
                  IMHO hat der Raspberry 4 damit überhaupt nichts zu tun, nur das verwendete Raspian.
                  @tiedi said in Test Adapter rpi2 2.x:
                  Gibt es log Ausgaben dazu?
                  Hast du die Bibliothek libgpiod-dev installiert?
                  Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
                  Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
                  HomoranH S 3 Antworten Letzte Antwort
                  • GarfonsoG Garfonso
                    @tiedi
                    HomoranH Offline
                    HomoranH Offline
                    #79
                    @garfonso sagte in Test Adapter rpi2 2.x:
                    so ist es!
                    mit Bookworm wurden die alten Pakete, mit deren Ausgaben der rpi2 bisher arbeitete, gegen die neuen getauscht.
                    Das Hauptproblem ist jetzt dass alte und neue Installation abgedeckt werden müssen.
                      so ist es!
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      #80
                      Na ja
                      Wenn rpi2 1.x.x auf ALTEN Systemen funktioniert dann spricht m.E. nichts dagegen für rpi2 2.x.x os xxx als Minimum vorauszusetzen.
                      HomoranH GarfonsoG 2 Antworten Letzte Antwort
                      • mcm1957M mcm1957
                        Na ja
                        HomoranH Offline
                        HomoranH Offline
                        #81
                        Na ja
                        und bei 2 verschiedenen RasPis im System?
                        du kannst keine unterschiedlichen Versionen in Instanzen haben
                          Na ja
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          #82
                          Ich hab dich so verstanden dass die Änderung der Basislibs miit Debian xxx gekommen ist. Warum kann ich nicht auf alle Pi holes dieselbe OS Version fahren?
                          Natürlich kann man nur eine rpi2version installieren.
                          • mcm1957M mcm1957
                            HomoranH Offline
                            HomoranH Offline
                            #83
                            kann ich!
                            auch ohne Löcher 😁
                            aber nicht alle wollen es
                              kann ich!
                              auch ohne Löcher 😁
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              #84
                              Ok
                              Dann kann der Adapter v2.0.0 das auch fordern wenn es die Arbeit erleichtert. Ist zumindest meine Meinung.
                              Sooo viele Systeme mit mehreren pis auf den allen rpi2 laufen muss wird es nicht geben.
                              Aber garfonso wird wissen ob die Unterstützung von mehreren os Versionen nennenswerten Aufwand ist oder ehschon gelöst ist
                              GarfonsoG 1 Antwort Letzte Antwort
                              • mcm1957M mcm1957
                                Na ja
                                GarfonsoG Offline
                                GarfonsoG Offline
                                Garfonso
                                #85
                                @mcm1957
                                Ja, aber warum?
                                Ich hab die 2.x Version auch auf pre-Bookworm getestet und die funktioniert aus meiner Sicht dort genauso gut. Es bleibt auf beiden Systemen das Problem, dass ein paar Features fehlen. Insofern ist ein Update nicht empfehlenswert, wenn man was komplizierteres an den GPIOs hat.
                                • mcm1957M mcm1957
                                  Ok
                                  GarfonsoG Offline
                                  GarfonsoG Offline
                                  Garfonso
                                  #86
                                  @mcm1957 said in Test Adapter rpi2 2.x:
                                  Ne, mehrere OS Versionen würde ich nicht unterstützen. Aber zumindest buster funktioniert libgpoid2 genauso, wie auf bookworm. Insofern ist da im ersten Schritt kein größerer Aufwand.
                                  Bezüglich der features, die noch fehlen, kann das nochmal anders aussehen. Da muss ich nochmal ausprobieren.
                                    #87
                                    Ergänzend noch:
                                    Die Situation könnte sich mit libgpiod3 noch verbessern.
                                    https://packages.debian.org/experimental/libgpiod3
                                    Diese lib bringt nochmal erweiterte Funktionen mit, aber zum einen ist die für Debian noch experimentel und zum anderen bedingt diese Version auch Änderungen am nodejs-Modul 'opengpio', welches wiederum vom rpi2-Adapter verwendet wird.
                                    Ob die libgpiod3 im nächsten Jahr mit Debian 13 'Trixie' ausgeliefert werden kann ist im Moment wohl noch offen.
                                      @tiedi
                                      searcher57
                                      #88
                                      @garfonso
                                      Hallo Garfonso, schön, dass Du Dich nach dem Urlaub wieder dem Problem annimmst! Denn es funktionieren die GPIO Eingänge leider wieder nicht.
                                      Skript v.2024-05-22
                                      *** BASE SYSTEM ***
                                       Static hostname: Raspi58GB
                                             Icon name: computer
                                                Kernel: Linux 6.6.31+rpt-rpi-2712
                                          Architecture: arm64
                                      Model           : Raspberry Pi 5 Model B Rev 1.0
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                      Systemuptime and Load:
                                       16:40:39 up 25 min,  2 users,  load average: 0.16, 0.10, 0.14
                                      CPU threads: 4
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                      *** Time and Time Zones ***
                                                     Local time: Thu 2024-08-29 16:40:40 CEST
                                                 Universal time: Thu 2024-08-29 14:40:40 UTC
                                                       RTC time: Thu 2024-08-29 14:40:40
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      pi
                                      HOME=/home/pi
                                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      *** Display-Server-Setup ***
                                      Desktop:
                                      Terminal:       tty
                                      Boot Target:    multi-user.target
                                      *** MEMORY ***
                                      Mem:            8.4G        2.7G        5.1G        5.6M        728M        5.8G
                                      Swap:           209M          0B        209M
                                      Total:          8.7G        2.7G        5.4G
                                      Active iob-Instances:   28
                                               8052 M total memory
                                               2544 M used memory
                                               2425 M active memory
                                                348 M inactive memory
                                               4907 M free memory
                                                 80 M buffer memory
                                                613 M swap cache
                                                199 M total swap
                                                  0 M used swap
                                                199 M free swap
                                      top - 16:40:40 up 25 min,  2 users,  load average: 0.16, 0.10, 0.14
                                      Tasks: 186 total,   1 running, 185 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 60.0 id, 20.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   8052.4 total,   4904.9 free,   2547.0 used,    694.6 buff/cache
                                      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5505.4 avail Mem
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  3.8G     0  3.8G   0% /dev
                                      tmpfs          tmpfs     806M  5.3M  800M   1% /run
                                      /dev/mmcblk0p2 ext4       59G   11G   45G  20% /
                                      tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                                      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                      /dev/sda1      exfat      29G  315M   29G   2% /mnt/usb0
                                      /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                                      tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
                                      [Thu Aug 29 16:14:41 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:2F:A6:31 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=4e8600df-02 rootfstype=ext4 fsck.repair=yes rootwait
                                      [Thu Aug 29 16:14:42 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                                      [Thu Aug 29 16:14:45 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                                      Show mounted filesystems:
                                      TARGET                                                  SOURCE         FSTYPE      OPTIONS
                                      /                                                       /dev/mmcblk0p2 ext4        rw,noatime
                                      |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                      | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                                      | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
                                      | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
                                      |-/proc                                                 proc           proc        rw,relatime
                                      | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5799
                                      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
                                      |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=3950816k,nr_inodes=246926,mode=755
                                      | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                      | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
                                      | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
                                      |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=824576k,mode=755
                                      | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                                      | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                      | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                      | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
                                      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                      | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=824560k,nr_inodes=206140,mode=700,uid=1000,gid=1000
                                      |-/mnt/usb0                                             /dev/sda1      exfat       rw,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
                                      `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      4.5G    /var/
                                      3.4G    /var/lib
                                      3.3G    /var/lib/influxdb/engine
                                      3.2G    /var/lib/influxdb/engine/data/102a10908fd45983/autogen
                                      Archived and active journals take up 656.3M in the file system.
                                      /opt/iobroker/backups:
                                      45M     /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      1.2G    /opt/iobroker/iobroker-data/
                                      1013M   /opt/iobroker/iobroker-data/files
                                      441M    /opt/iobroker/iobroker-data/files/javascript.admin
                                      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                      25M     /opt/iobroker/iobroker-data/objects.jsonl
                                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                      USB-Devices by-id:
                                      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0
                                      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                                      *** NodeJS-Installation ***
                                      /usr/bin/nodejs         v18.20.4
                                      /usr/bin/node           v18.20.4
                                      /usr/bin/npm            10.7.0
                                      /usr/bin/npx            10.7.0
                                      /usr/bin/corepack       0.28.0
                                      nodejs:
                                        Installed: 18.20.4-1nodesource1
                                        Candidate: 18.20.4-1nodesource1
                                        Version table:
                                       *** 18.20.4-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                           18.20.3-1nodesource1 1001
                                           18.20.2-1nodesource1 1001
                                           18.20.1-1nodesource1 1001
                                           18.20.0-1nodesource1 1001
                                           18.19.1-1nodesource1 1001
                                           18.19.0+dfsg-6~deb12u2 500
                                              500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                           18.19.0+dfsg-6~deb12u1 500
                                              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                                           18.19.0-1nodesource1 1001
                                           18.18.2-1nodesource1 1001
                                           18.18.1-1nodesource1 1001
                                           18.18.0-1nodesource1 1001
                                           18.17.1-1nodesource1 1001
                                           18.17.0-1nodesource1 1001
                                           18.16.1-1nodesource1 1001
                                           18.16.0-1nodesource1 1001
                                           18.15.0-1nodesource1 1001
                                           18.14.2-1nodesource1 1001
                                           18.14.1-1nodesource1 1001
                                           18.14.0-1nodesource1 1001
                                           18.13.0-1nodesource1 1001
                                           18.12.0-1nodesource1 1001
                                           18.11.0-1nodesource1 1001
                                           18.10.0-1nodesource1 1001
                                           18.9.1-1nodesource1 1001
                                           18.9.0-1nodesource1 1001
                                           18.8.0-1nodesource1 1001
                                           18.7.0-1nodesource1 1001
                                           18.6.0-1nodesource1 1001
                                           18.5.0-1nodesource1 1001
                                           18.4.0-1nodesource1 1001
                                           18.3.0-1nodesource1 1001
                                           18.2.0-1nodesource1 1001
                                           18.1.0-1nodesource1 1001
                                           18.0.0-1nodesource1 1001
                                      No problems detected
                                      Errors in npm tree:
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Core adapters versions
                                      js-controller:  6.0.11
                                      admin:          7.0.23
                                      javascript:     8.7.6
                                      nodejs modules from github:     0
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : Raspi58GB                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.alexa2.0                 : alexa2                : Raspi58GB                                -  enabled
                                        system.adapter.alias-manager.0          : alias-manager         : Raspi58GB                                - disabled
                                      + system.adapter.awtrix-light.0           : awtrix-light          : Raspi58GB                                -  enabled
                                      + system.adapter.backitup.0               : backitup              : Raspi58GB                                -  enabled
                                      + system.adapter.broadlink2.0             : broadlink2            : Raspi58GB                                -  enabled
                                        system.adapter.devices.0                : devices               : Raspi58GB                                - disabled
                                      + system.adapter.discovery.0              : discovery             : Raspi58GB                                -  enabled
                                      + system.adapter.doorbird.0               : doorbird              : Raspi58GB                                -  enabled
                                      + system.adapter.echarts.0                : echarts               : Raspi58GB                                -  enabled
                                      + system.adapter.followthesun.0           : followthesun          : Raspi58GB                                -  enabled
                                      + system.adapter.frontier_silicon.0       : frontier_silicon      : Raspi58GB                                -  enabled
                                        system.adapter.frontier_silicon.1       : frontier_silicon      : Raspi58GB                                - disabled
                                        system.adapter.frontier_silicon.2       : frontier_silicon      : Raspi58GB                                - disabled
                                        system.adapter.frontier_silicon.3       : frontier_silicon      : Raspi58GB                                - disabled
                                      + system.adapter.hm-rega.0                : hm-rega               : Raspi58GB                                -  enabled
                                      + system.adapter.hm-rpc.0                 : hm-rpc                : Raspi58GB                                -  enabled, port: 0
                                      + system.adapter.hm-rpc.1                 : hm-rpc                : Raspi58GB                                -  enabled, port: 0
                                      + system.adapter.influxdb.0               : influxdb              : Raspi58GB                                -  enabled, port: 8086
                                      + system.adapter.iot.0                    : iot                   : Raspi58GB                                -  enabled
                                      + system.adapter.javascript.0             : javascript            : Raspi58GB                                -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : Raspi58GB                                -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.rpi2.0                   : rpi2                  : Raspi58GB                                -  enabled
                                      + system.adapter.shelly.0                 : shelly                : Raspi58GB                                -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.shelly.1                 : shelly                : Raspi58GB                                -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.simple-api.0             : simple-api            : Raspi58GB                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      + system.adapter.smartmeter.0             : smartmeter            : Raspi58GB                                -  enabled
                                      + system.adapter.tankerkoenig.0           : tankerkoenig          : Raspi58GB                                -  enabled
                                      + system.adapter.telegram.0               : telegram              : Raspi58GB                                -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.vis-2.0                  : vis-2                 : Raspi58GB                                -  enabled
                                        system.adapter.vis.0                    : vis                   : Raspi58GB                                -  enabled
                                      + system.adapter.web.0                    : web                   : Raspi58GB                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        system.adapter.yr.0                     : yr                    : Raspi58GB                                -  enabled
                                      + system.adapter.zigbee.0                 : zigbee                : Raspi58GB                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0867d5d6b78ded11959b02f6b86ce6f8-if00-port0
                                      + instance is alive
                                      ioBroker-Repositories
                                      │ (index) │   name   │                           url                           │ auto upgrade │
                                      │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
                                      │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
                                      Active repo(s): stable
                                      Installed ioBroker-Instances
                                      Used repository: stable
                                      Adapter    "admin"        : 7.0.23   , installed 7.0.23
                                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                                      Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
                                      Adapter    "backitup"     : 3.0.19   , installed 3.0.19
                                      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                                      Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                      Adapter    "doorbird"     : 1.6.0    , installed 1.6.0
                                      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                      Adapter    "followthesun" : 0.5.0    , installed 0.5.0
                                      Adapter    "frontier_silicon": 0.2.0 , installed 0.2.0
                                      Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                                      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                      Controller "js-controller": 6.0.11   , installed 6.0.11
                                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                      Adapter    "rpi2"         : 1.3.2    , installed 2.0.0
                                      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                      Adapter    "vis-2"        : 2.9.32   , installed 2.9.42
                                      Adapter    "web"          : 6.2.5    , installed 6.2.5
                                      Adapter    "yr"           : 5.3.0    , installed 5.3.0
                                      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                      Objects and States
                                      Objects:        11879
                                      States:         9389
                                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                      Hit:5 https://repos.influxdata.com/debian stable InRelease
                                      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Reading package lists...
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 192.168.178.57:42010    0.0.0.0:*               LISTEN      1001       7919       1126/io.hm-rpc.0
                                      tcp        0      0 192.168.178.57:2001     0.0.0.0:*               LISTEN      1001       6713       1141/io.hm-rpc.1
                                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       7695       958/iobroker.js-con
                                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       7688       958/iobroker.js-con
                                      tcp        0      0 192.168.178.57:8100     0.0.0.0:*               LISTEN      1001       9459       1326/io.doorbird.0
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4800       831/sshd: /usr/sbin
                                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       6905       1281/io.shelly.1
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        1808       826/mosquitto
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        7672       899/influxd
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10347      1386/io.simple-api.
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6501       977/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9206       1486/io.web.0
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          4802       831/sshd: /usr/sbin
                                      tcp6       0      0 :::1883                 :::*                    LISTEN      106        1809       826/mosquitto
                                      udp        0      0 0.0.0.0:47626           0.0.0.0:*                           1001       7898       1096/io.broadlink2.
                                      udp        0      0 0.0.0.0:47735           0.0.0.0:*                           1001       6665       1096/io.broadlink2.
                                      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       6651       1096/io.broadlink2.
                                      udp        0      0 0.0.0.0:51914           0.0.0.0:*                           1001       6661       1096/io.broadlink2.
                                      udp        0      0 0.0.0.0:35953           0.0.0.0:*                           1001       6668       1096/io.broadlink2.
                                      udp        0      0 0.0.0.0:48478           0.0.0.0:*                           1001       6654       1096/io.broadlink2.
                                      udp        0      0 0.0.0.0:40771           0.0.0.0:*                           1001       6664       1096/io.broadlink2.
                                      udp        0      0 0.0.0.0:48991           0.0.0.0:*                           1001       6659       1096/io.broadlink2.
                                      udp        0      0 0.0.0.0:40867           0.0.0.0:*                           1001       6660       1096/io.broadlink2.
                                      udp        0      0 0.0.0.0:50113           0.0.0.0:*                           1001       6658       1096/io.broadlink2.
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7202       669/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       9290       1220/io.shelly.0
                                      udp        0      0 0.0.0.0:55035           0.0.0.0:*                           104        7204       669/avahi-daemon: r
                                      udp        0      0 0.0.0.0:34600           0.0.0.0:*                           1001       6655       1096/io.broadlink2.
                                      udp        0      0 0.0.0.0:34858           0.0.0.0:*                           1001       6669       1096/io.broadlink2.
                                      udp6       0      0 :::5353                 :::*                                104        7203       669/avahi-daemon: r
                                      udp6       0      0 :::46438                :::*                                104        7205       669/avahi-daemon: r
                                      2024-08-29 16:18:09.780  - info: rpi2.0 (1171) terminating
                                      2024-08-29 16:18:09.823  - info: host.Raspi58GB instance system.adapter.rpi2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-08-29 16:18:13.178  - info: host.Raspi58GB instance system.adapter.rpi2.0 in version "2.0.0" started with pid 1548
                                      2024-08-29 16:18:14.064  - info: rpi2.0 (1548) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.20.4, js-controller: 6.0.11
                                      2024-08-29 16:18:14.708  - error: rpi2.0 (1548) Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'watch')
                                      2024-08-29 16:18:18.498  - info: admin.0 (977) ==> Connected system.user.admin from ::ffff:192.168.178.30
                                      2024-08-29 16:18:27.335  - info: admin.0 (977) <== Disconnect system.user.admin from ::ffff:192.168.178.30
                                      2024-08-29 16:21:09.623  - info: smartmeter.0 (1235) Received 13 values, 6 updated
                                      2024-08-29 16:22:22.965  - info: admin.0 (977) ==> Connected system.user.admin from ::ffff:192.168.178.30
                                      2024-08-29 16:22:29.933  - info: javascript.0 (1033) Start JavaScript script.js.Haushalt.Gas.Verbrauch_Gestern (Blockly)
                                      2024-08-29 16:22:29.947  - info: javascript.0 (1033) script.js.Haushalt.Gas.Verbrauch_Gestern: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                      2024-08-29 16:22:53.911  - info: admin.0 (977) <== Disconnect system.user.admin from ::ffff:192.168.178.30 javascript
                                      2024-08-29 16:24:22.139  - info: admin.0 (977) ==> Connected system.user.admin from ::ffff:192.168.178.30
                                      2024-08-29 16:26:10.983  - info: smartmeter.0 (1235) Received 13 values, 5 updated
                                      2024-08-29 16:29:55.429  - info: admin.0 (977) <== Disconnect system.user.admin from ::ffff:192.168.178.30
                                      2024-08-29 16:31:11.653  - info: smartmeter.0 (1235) Received 13 values, 6 updated
                                      2024-08-29 16:36:12.545  - info: smartmeter.0 (1235) Received 13 values, 6 updated
                                      2024-08-29 16:40:48.014  - info: host.Raspi58GB instance system.adapter.yr.0 in version "5.3.0" started with pid 2655
                                      2024-08-29 16:40:49.098  - info: yr.0 (2655) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v18.20.4, js-controller: 6.0.11
                                      2024-08-29 16:40:49.107  - info: yr.0 (2655) longitude/longitude not set, get data from system
                                      2024-08-29 16:40:49.117  - info: yr.0 (2655) system latitude: 50.622376836807405 longitude: 7.0362624235667255
                                      2024-08-29 16:41:14.050  - info: smartmeter.0 (1235) Received 13 values, 6 updated
                                      2024-08-29 16:41:15.154  - info: yr.0 (2655) Data updated.
                                      2024-08-29 16:41:15.154  - info: yr.0 (2655) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2024-08-29 16:41:15.666  - info: host.Raspi58GB instance system.adapter.yr.0 having pid 2655 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                                              v.2024-05-22
                                             Icon name: computer
                                          Architecture: arm64
                                      Kernel:                 aarch64
                                      Userland:               64 bit
                                      User-ID:                1000
                                      /usr/bin/npm            10.7.0
                                      /usr/bin/npx            10.7.0
                                      Recommended versions are nodejs 20.17.0 and npm 10.8.2
                                      MEMORY:
                                      Mem:            8.4G        2.8G        4.8G        5.6M        1.0G        5.7G
                                      Swap:           209M          0B        209M
                                      Total:          8.7G        2.8G        5.0G
                                      ioBroker Core:          js-controller           6.0.11
                                                              admin                   7.0.23
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                11879
                                      States:                 9389
                                      34M     /opt/iobroker/iobroker-data/objects.jsonl
                                      11M     /opt/iobroker/iobroker-data/states.jsonl
                                      sudo apt install -y libgpiod-dev
                                      libgpiod-dev ist schon die neueste Version (1.6.3-1+b3).
                                      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                          Plattform: linux
                                          Betriebssystem: linux
                                          Architektur: arm64
                                          CPUs: 4
                                          Geschwindigkeit: 2400 MHz
                                          Modell: Cortex-A76
                                          RAM: 7.8 GB
                                          System-Betriebszeit: 24 T. 19:42:19
                                          Node.js: v18.20.4
                                          time: 1724934925682
                                          timeOffset: -120
                                          NPM: 10.7.0
                                          Adapter-Anzahl: 539
                                          Datenträgergröße: 58.0 GB
                                          Freier Festplattenspeicher: 47.3 GB
                                          Aktive Instanzen: 4
                                          Pfad: /opt/iobroker/
                                          Betriebszeit: 00:00:17
                                          aktiv: true
                                      Ich benutze 2 GPIO Eingänge. Einen wie oben schon geschrieben des Gaszählers. Es wäre toll, wenn das wieder zu nutzen wäre!
                                        @tiedi
                                        searcher57
                                        #89
                                        @garfonso said in Test Adapter rpi2 2.x:
                                        rpi2.0
                                        	2024-08-29 16:15:58.398	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.20.4, js-controller: 6.0.11
                                        rpi2.0
                                        	2024-08-29 16:15:59.166	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'watch')
                                        rpi2.0
                                        	2024-08-29 16:18:09.280	info	Got terminate signal TERMINATE_YOURSELF
                                        rpi2.0
                                        	2024-08-29 16:18:09.281	info	terminating
                                        rpi2.0
                                        	2024-08-29 16:18:09.282	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        rpi2.0
                                        	2024-08-29 16:18:09.780	info	terminating
                                        rpi2.0
                                        	2024-08-29 16:18:14.064	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.20.4, js-controller: 6.0.11
                                        rpi2.0
                                        	2024-08-29 16:18:14.708	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'watch')
                                        • S searcher57
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          GarfonsoG Offline
                                          GarfonsoG Offline
                                          Garfonso
                                          #90
                                          @searcher57
                                          danke für das Log. Könntest du den rpi2 adapter auf debug umstellen und mir dann nochmal ein log vom neustart geben? (der sollte beim umstellen direkt neugestartet werden, sonst bitte von Hand).
                                          Irgendwie ist mir noch nicht klar, warum das GPIO Objekt da undefined ist.
                                          S 2 Antworten Letzte Antwort
