  4. Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]
    6.6k
45 Beiträge 3 Kommentatoren 5.0k Aufrufe 2 Beobachtet
  • K Krissie777
    @marc-berg said in Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]:
    iob diag
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     13:18:48 up 1 day,  3:43,  2 users,  load average: 1.16, 0.75, 0.59
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    ~ Under-voltage detected
    ~ Arm frequency capped
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** Time and Time Zones ***
                   Local time: Fri 2024-08-23 13:18:49 CEST
               Universal time: Fri 2024-08-23 11:18:49 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        1.6G        658M         61M        1.5G        2.6G
    Swap:           99M        7.0M         92M
    Total:         3.9G        1.7G        751M
    Active iob-Instances:   15
             3837 M total memory
             1647 M used memory
              621 M active memory
             2412 M inactive memory
              658 M free memory
              118 M buffer memory
             1413 M swap cache
               99 M total swap
                7 M used swap
               92 M free swap
    top - 13:18:49 up 1 day,  3:43,  2 users,  load average: 1.16, 0.75, 0.59
    Tasks: 159 total,   1 running, 158 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  1.2 us,  6.1 sy,  0.0 ni, 92.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3837.7 total,    658.6 free,   1647.2 used,   1531.9 buff/cache
    MiB Swap:    100.0 total,     92.7 free,      7.3 used.   2561.3 avail Mem
    *** FAILED SERVICES ***
      UNIT               LOAD   ACTIVE SUB    DESCRIPTION
    * PiEMItMgmt.service loaded failed failed PiEM-It! Mgmt-Modul, respawn
    * Webserver.service  loaded failed failed PiEM-It! Webserver-Modul, respawn
    2 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   14G   15G  49% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G   66M  1.9G   4% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Thu Aug 22 09:35:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_b        cm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=E4:5F:01:57:C6:34 vc_mem.mem_base=0x3eb00000 vc_mem        .mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=d2b297f7-02 rootfstype=ext4 elevator=deadline fsc        k.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Aug 22 09:35:19 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Aug 22 09:35:19 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Thu Aug 22 09:35:20 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
    Show mounted filesystems:
    TARGET                                SOURCE     FSTYPE     OPTIONS
    /                                     /dev/sda2  ext4       rw,noatime
    |-/dev                                devtmpfs   devtmpfs   rw,relatime,size=1800056k,nr_inodes=84157,mode=755
    | |-/dev/shm                          tmpfs      tmpfs      rw,nosuid,nodev
    | |-/dev/pts                          devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue                       mqueue     mqueue     rw,relatime
    |-/sys                                sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security              securityfs securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                    tmpfs      tmpfs      ro,nosuid,nodev,noexec,mode=755
    | | |-/sys/fs/cgroup/unified          cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
    | | |-/sys/fs/cgroup/systemd          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
    | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
    | | |-/sys/fs/cgroup/blkio            cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,blkio
    | | |-/sys/fs/cgroup/net_cls,net_prio cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
    | | |-/sys/fs/cgroup/freezer          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,freezer
    | | |-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
    | | |-/sys/fs/cgroup/perf_event       cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
    | | |-/sys/fs/cgroup/cpuset           cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
    | | `-/sys/fs/cgroup/pids             cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,pids
    | |-/sys/fs/bpf                       none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                 debugfs    debugfs    rw,relatime
    | `-/sys/kernel/config                configfs   configfs   rw,relatime
    |-/proc                               proc       proc       rw,relatime
    | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,di        rect
    |-/run                                tmpfs      tmpfs      rw,nosuid,nodev,mode=755
    | |-/run/lock                         tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs                   sunrpc     rpc_pipefs rw,relatime
    | `-/run/user/1000                    tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=392984k,mode=700,uid=1000,gid        =1000
    `-/boot                               /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=as        cii,shortname=mixed,errors=remount-ro
    /var:
    2.6G    /var/
    1.5G    /var/cache/apt
    1.5G    /var/cache
    1.4G    /var/cache/apt/archives
    823M    /var/lib
    Archived and active journals take up 63.9M in the file system.
    /opt/iobroker/backups:
    4.3G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    825M    /opt/iobroker/iobroker-data/
    696M    /opt/iobroker/iobroker-data/files
    441M    /opt/iobroker/iobroker-data/files/javascript.admin
    409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Device_GmbH_DvIR-USB_DvIR-USB_000524-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.4
    /usr/bin/node           v18.20.4
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.0
    nodejs:
      Installed: 18.20.4-1nodesource1
      Candidate: 18.20.4-1nodesource1
      Version table:
     *** 18.20.4-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.20.3-1nodesource1 600
         18.20.2-1nodesource1 600
         18.20.1-1nodesource1 600
         18.20.0-1nodesource1 600
         18.19.1-1nodesource1 600
         18.19.0-1nodesource1 600
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.9
    admin:          7.0.23
    javascript:     8.7.6
    nodejs modules from github:     0
    Adapter State
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
    + system.adapter.ebus.0                   : ebus                  : raspberrypi                              -  enabled
      system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
    + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.wolf-smartset.0          : wolf-smartset         : raspberrypi                              -  enabled
    + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ (index) │   name   │                           url                           │ auto upgrade │
    │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
    │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
    Adapter    "admin"        : 7.0.23   , installed 7.0.23
    Adapter    "backitup"     : 3.0.19   , installed 3.0.19
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "ebus"         : 3.3.4    , installed 3.3.4
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
    Adapter    "hmip"         : 1.23.3   , installed 1.23.3
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.9    , installed 6.0.9
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "solarwetter"  : 1.2.0    , installed 1.2.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
    Objects and States
    Objects:        9367
    States:         8906
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://repos.influxdata.com/debian stable InRelease
    Hit:4 https://repos.influxdata.com/debian buster InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:6 https://repo.ebusd.eu/apt/default/buster buster InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19485      719/sshd
    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          967459     26805/ebusd
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        17333      698/influxd
    tcp        0      0 0.0.0.0:8889            0.0.0.0:*               LISTEN      0          967460     26805/ebusd
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          19744      787/smbd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       93210      11781/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       92549      11781/iobroker.js-c
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          19745      787/smbd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       339575     2777/io.admin.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       93711      11958/io.ws.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        22028      698/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          19487      719/sshd
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          18222      718/xrdp-sesman
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       95441      11971/io.simple-api
    tcp6       0      0 :::3000                 :::*                    LISTEN      109        20748      696/grafana-server
    tcp6       0      0 :::3389                 :::*                    LISTEN      111        20540      757/xrdp
    tcp6       0      0 :::445                  :::*                    LISTEN      0          19742      787/smbd
    tcp6       0      0 :::139                  :::*                    LISTEN      0          19743      787/smbd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16697      693/dhcpcd
    udp        0      0 192.178.168.255:137     0.0.0.0:*                           0          19612      695/nmbd
    udp        0      0 192.178.168.47:137      0.0.0.0:*                           0          19611      695/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          19599      695/nmbd
    udp        0      0 192.178.168.255:138     0.0.0.0:*                           0          19614      695/nmbd
    udp        0      0 192.178.168.47:138      0.0.0.0:*                           0          19613      695/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          19600      695/nmbd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12744      408/avahi-daemon: r
    udp        0      0 0.0.0.0:53558           0.0.0.0:*                           108        12746      408/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16713      693/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        12745      408/avahi-daemon: r
    udp6       0      0 :::33559                :::*                                108        12747      408/avahi-daemon: r
    2024-08-23 13:17:37.693  - info: smartmeter.0 (11903) Received 6 values, 2 updated
    2024-08-23 13:17:44.699  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:17:51.725  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:17:58.714  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:18:05.579  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:18:12.630  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:18:18.357  - error: ebus.0 (30094) exception in ebusd_ReceiveData [Error: connect ECONNREFUSED 127.0.0.1:8080]
    2024-08-23 13:18:19.506  - info: smartmeter.0 (11903) Received 6 values, 2 updated
    2024-08-23 13:18:26.482  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:18:33.583  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:18:40.670  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:18:47.541  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:18:54.556  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:19:01.620  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:19:08.697  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:19:15.827  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:19:22.946  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:19:29.974  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:19:37.037  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:19:45.967  - info: smartmeter.0 (11903) Received 6 values, 2 updated
    2024-08-23 13:19:51.206  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:19:58.233  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:20:05.171  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:20:12.268  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    2024-08-23 13:20:19.374  - info: smartmeter.0 (11903) Received 6 values, 3 updated
    @krissie777 sagte in Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]:
    das OS ist tot und wird nicht mehr gepflegt!!
    hat jetzt nichts mit dem aktuellen Thema zu tun, aber das Netzteil ist zu schwach oder/und da hängt zuviel am USB.
    auch ein Wechsel auf node 20 wäre demnächst fällig.
    ebus ist nicht dabei 🤔
    edit: der Adapter lauscht ja anscheinend nicht auf einem eigenen Port, das macht der daemon.
    > tcp
    • K Krissie777
      @marc-berg
      Hallo Marc,
      nochmal vielen Dank, was mich stutzig macht dass beim ebus kein Port im Protokoll angezeigt wird...
      LG
      Kris
      Marc BergM Offline
      Marc BergM Offline
      Marc Berg
      Doch, der ebusd hält zwei Ports offen 8888 (Telnet) und 8889 (HTTP), alles wie erwartet. Hast du den ioBroker-Adapter entsprechend konfiguriert? Das konnte ich so noch nicht sehen.
      K 2 Antworten Letzte Antwort
      • Marc BergM Marc Berg
        Krissie777
        @marc-berg
        Hallo Marc, ja das habe ich selber Fehler.
        LG
        Christian
          Krissie777
          @marc-berg
          Hallo MArc, nach einem zusätzlichen Neustart des RASPI kommt jetzt diese Fehlermeldung:
          exception in ebusd_ReceiveData [Error: Parse Error: Expected HTTP/]
          Das ist jetzt neu...
          LG
          Kris
          • K Krissie777
            @marc-berg
            LG
            Kris
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            @krissie777
            Bitte nochmal die aktuelle ioBroker Adapter Konfiguration zeigen.
            • K Krissie777
              @marc-berg
              LG
              Christian
              ja das habe ich
              bitte immer alles zeigen!
                @krissie777
                Krissie777
                • K Krissie777
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  @krissie777
                  Das ist genau falsch rum:
                  @marc-berg sagte in Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]:
                  Also bei dir 8889 als HTTP Port und 8888 ist Standard für den Telnet-Port.
                  HomoranH K 2 Antworten Letzte Antwort
                    @krissie777
                    @Krissie777
                    und genau deswegen immer alles zeigen.
                      @krissie777
                      Krissie777
                      @marc-berg
                      ok habe ich vertauscht, wieder der Fehler:
                      exception in ebusd_ReceiveData [Error: connect ECONNREFUSED 127.0.0.1:8889]
                      Kris
                      • Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                        und iob diag gibt jetzt immer noch
                        aus?
                          aus?
                          Krissie777
                          iob diag
                          Skript v.2024-05-22
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm
                          Docker          : false
                          Kernel          : armv7l
                          Userland        : 32 bit
                           15:37:31 up  1:22,  2 users,  load average: 1.21, 0.69, 0.52
                          CPU threads: 4
                          Current issues:
                                         Local time: Fri 2024-08-23 15:37:31 CEST
                                     Universal time: Fri 2024-08-23 13:37:31 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:           3.8G        1.0G        1.4G        9.0M        1.5G        2.8G
                          Swap:           99M          0B         99M
                          Total:         3.9G        1.0G        1.5G
                                   3837 M total memory
                                   1010 M used memory
                                    331 M active memory
                                   2050 M inactive memory
                                   1351 M free memory
                                     87 M buffer memory
                                   1387 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          top - 15:37:32 up  1:22,  2 users,  load average: 1.21, 0.69, 0.52
                          Tasks: 156 total,   2 running, 154 sleeping,   0 stopped,   0 zombie
                          %Cpu(s): 18.3 us, 20.4 sy,  0.0 ni, 58.1 id,  1.1 wa,  0.0 hi,  2.2 si,  0.0 st
                          MiB Mem :   3837.7 total,   1351.6 free,   1010.7 used,   1475.5 buff/cache
                          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2827.9 avail Mem
                          *** FILESYSTEM ***
                          tmpfs          tmpfs     1.9G  9.6M  1.9G   1% /run
                          [Fri Aug 23 14:14:55 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hd        mi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=E4:5F:01:57:C6:34 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tt        yS0,115200 console=tty1 root=PARTUUID=d2b297f7-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.igno        re-serial-consoles
                          [Fri Aug 23 14:14:57 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                          [Fri Aug 23 14:14:57 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                          [Fri Aug 23 14:14:58 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
                          | | `-/sys/fs/cgroup/cpu,cpuacct      cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
                          | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=36,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                          | `-/run/user/1000                    tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=392984k,mode=700,uid=1000,gid=1000
                          `-/boot                               /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mi        xed,errors=remount-ro
                          /var:
                          2.6G    /var/
                          1.5G    /var/cache/apt
                          1.5G    /var/cache
                          789M    /var/lib
                          Archived and active journals take up 8.0M in the file system.
                          824M    /opt/iobroker/iobroker-data/
                          USB-Devices by-id:
                          /usr/bin/npm            10.7.0
                          /usr/bin/npx            10.7.0
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          7.0.23
                          javascript:     8.7.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        9367
                          States:         8906
                          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20676      721/sshd
                          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        20846      703/influxd
                          tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          19480      707/ebusd
                          tcp        0      0 0.0.0.0:8089            0.0.0.0:*               LISTEN      0          19481      707/ebusd
                          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          21030      783/smbd
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19427      970/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19420      970/iobroker.js-con
                          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          21031      783/smbd
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21373      989/io.admin.0
                          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24742      1140/io.ws.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      998        19334      703/influxd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          20686      721/sshd
                          tcp6       0      0 ::1:3350                :::*                    LISTEN      0          18719      718/xrdp-sesman
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23966      1155/io.simple-api.
                          tcp6       0      0 :::3000                 :::*                    LISTEN      109        21203      695/grafana-server
                          tcp6       0      0 :::3389                 :::*                    LISTEN      111        21042      746/xrdp
                          tcp6       0      0 :::445                  :::*                    LISTEN      0          21028      783/smbd
                          tcp6       0      0 :::139                  :::*                    LISTEN      0          21029      783/smbd
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15346      692/dhcpcd
                          udp        0      0 0.0.0.0:50817           0.0.0.0:*                           108        15105      437/avahi-daemon: r
                          udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          19917      694/nmbd
                          udp        0      0 192.168.178.47:137      0.0.0.0:*                           0          19916      694/nmbd
                          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          19904      694/nmbd
                          udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          19919      694/nmbd
                          udp        0      0 192.168.178.47:138      0.0.0.0:*                           0          19918      694/nmbd
                          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          19905      694/nmbd
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15103      437/avahi-daemon: r
                          udp6       0      0 :::546                  :::*                                0          15357      692/dhcpcd
                          udp6       0      0 :::52931                :::*                                108        15106      437/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                108        15104      437/avahi-daemon: r
                          2024-08-23 15:36:15.729  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:36:22.548  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:36:29.418  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:36:36.396  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:36:43.393  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:36:50.112  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:36:57.033  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:37:03.747  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:37:11.014  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:37:18.072  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:37:24.543  - error: ebus.0 (8494) exception in ebusd_ReceiveData [Error: connect ECONNREFUSED 127.0.0.1:8889]
                          2024-08-23 15:37:25.231  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:37:32.418  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:37:39.536  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:37:46.531  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:37:53.634  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:38:00.732  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:38:07.896  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:38:15.017  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:38:22.246  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:38:30.347  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:38:36.389  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:38:43.653  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:38:51.001  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          2024-08-23 15:38:58.341  - info: smartmeter.0 (1093) Received 6 values, 3 updated
                          Marc BergM HomoranH 2 Antworten Letzte Antwort
                          • K Krissie777
                            iob diag
                            Skript v.2024-05-22
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm
                            Docker          : false
                            Kernel          : armv7l
                            Userland        : 32 bit
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           99M          0B         99M
                                     3837 M total memory
                                     1010 M used memory
                                      331 M active memory
                                     1351 M free memory
                                       87 M buffer memory
                                     1387 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            *** FILESYSTEM ***
                            /var:
                            2.6G    /var/
                            1.5G    /var/cache/apt
                            1.5G    /var/cache
                            789M    /var/lib
                            USB-Devices by-id:
                            /usr/bin/npm            10.7.0
                            /usr/bin/npx            10.7.0
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          7.0.23
                            javascript:     8.7.6
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        9367
                            States:         8906
                            Pending Updates: 0
                            Marc BergM Offline
                            Marc BergM Offline
                            Marc Berg
                            Du machst mich fertig. In die ebusd muss 8889 rein als httpport, nicht 8089.
                            EDIT: es sind doch nur zwei Zahlen, ZWEI! 😥
                            • K Krissie777
                              iob diag
                              Skript v.2024-05-22
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm
                              Docker          : false
                              Kernel          : armv7l
                              Userland        : 32 bit
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:           99M          0B         99M
                                       3837 M total memory
                                       1010 M used memory
                                        331 M active memory
                                       1351 M free memory
                                         87 M buffer memory
                                       1387 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              *** FILESYSTEM ***
                              /var:
                              2.6G    /var/
                              1.5G    /var/cache/apt
                              1.5G    /var/cache
                              789M    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            10.7.0
                              /usr/bin/npx            10.7.0
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          7.0.23
                              javascript:     8.7.6
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        9367
                              States:         8906
                              Pending Updates: 0
                              tcp
                              da steht aber wieder was anderes!
                              zeig die Konfiguration!
                                Krissie777
                                @marc-berg
                                Hallo Marc, im Adapter ist es so eingestellt, wie ich gesagt hatte:
                                Wo die 8080 herkommt weiß ich nicht...
                                LG
                                Kris
                                • K Krissie777
                                  @marc-berg
                                  LG
                                  Kris
                                  nicht 8080, sondern 8089.
                                  die kommt vom ebusd nehme ich an
                                    Krissie777
                                    @marc-berg
                                    das ist doch in der Zeile bei influx, oder?
                                    LG
                                    Kris
                                      Krissie777
                                      Hallo Hormoran, entschuldige ich meinte 8089, hatte mich verschieben.
                                      In dem Screenshot seht Ihr dass ich die Adressen richtig eingestellt habe, oder?
                                      LG
                                      Kris
                                      • K Krissie777
                                        @marc-berg
                                        LG
                                        Kris
                                        Marc BergM Offline
                                        Marc BergM Offline
                                        Marc Berg
                                        Nein, ganz andere Baustelle.
                                        Hier hattest du es gaaanz oben schon richtig:
                                        EBUSD_OPTS="--device=192.178.168.70:5002 --httpport=8889 --scanconfig --latency=30000 --configpath=http://ebusd.eu/config/"
                                        Hinter "httpport=", 8889. acht-acht-acht-neun
                                        • K Krissie777
                                          LG
                                          Kris
                                          im Adapter, und was steht im ebusd?
