  4. [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?
    1.0k
64 Beiträge 6 Kommentatoren 10.5k Aufrufe 5 Beobachtet
  • GaspodeG Gaspode
    @sigi234
    Was passiert denn jetzt bei
    python
    in der iob Shell?
    sigi234S Online
    sigi234S Online
    @gaspode sagte in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
    @sigi234
    python
    in der iob Shell?
    ***               Welcome to ioBroker.                 ***
    ***     Type 'iob help' for list of instructions.      ***
    ***                For more help see                   ***
    ***     https://github.com/ioBroker/ioBroker.docs      ***
    Your environment has been set up for using Node.js 20.16.0 (x64) and npm.
    C:\SmartHome>npm i diskusage
    npm error code 1
    npm error path C:\SmartHome\node_modules\diskusage
    npm error command failed
    npm error command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp rebuild
    npm error gyp info it worked if it ends with ok
    npm error gyp info using node-gyp@10.1.0
    npm error gyp info using node@20.16.0 | win32 | x64
    npm error gyp ERR! find Python
    npm error gyp ERR! find Python Python is not set from command line or npm configuration
    npm error gyp ERR! find Python Python is not set from environment variable PYTHON
    npm error gyp ERR! find Python checking if the py launcher can be used to find Python 3
    npm error gyp ERR! find Python - executable path is ""
    npm error gyp ERR! find Python - "" could not be run
    npm error gyp ERR! find Python checking if "python3" can be used
    npm error gyp ERR! find Python checking if "python" can be used
    npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python311\python.exe
    npm error gyp ERR! find Python - version is ""
    npm error gyp ERR! find Python - version is  - should be >=3.6.0
    npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED
    npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python311\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Program Files\Python311\python.exe
    npm error gyp ERR! find Python - "C:\Program Files\Python311\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python311-32\python.exe
    npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python311-32\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Program Files\Python311-32\python.exe
    npm error gyp ERR! find Python - "C:\Program Files\Python311-32\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python311-32\python.exe
    npm error gyp ERR! find Python - "C:\Program Files (x86)\Python311-32\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python310\python.exe
    npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python310\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Program Files\Python310\python.exe
    npm error gyp ERR! find Python - "C:\Program Files\Python310\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python310-32\python.exe
    npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python310-32\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Program Files\Python310-32\python.exe
    npm error gyp ERR! find Python - "C:\Program Files\Python310-32\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python310-32\python.exe
    npm error gyp ERR! find Python - "C:\Program Files (x86)\Python310-32\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python39\python.exe
    npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python39\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Program Files\Python39\python.exe
    npm error gyp ERR! find Python - "C:\Program Files\Python39\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python39-32\python.exe
    npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python39-32\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Program Files\Python39-32\python.exe
    npm error gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python39-32\python.exe
    npm error gyp ERR! find Python - "C:\Program Files (x86)\Python39-32\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python38\python.exe
    npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python38\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Program Files\Python38\python.exe
    npm error gyp ERR! find Python - "C:\Program Files\Python38\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python38-32\python.exe
    npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python38-32\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Program Files\Python38-32\python.exe
    npm error gyp ERR! find Python - "C:\Program Files\Python38-32\python.exe" could not be run
    npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python38-32\python.exe
    npm error gyp ERR! find Python - "C:\Program Files (x86)\Python38-32\python.exe" could not be run
    npm error gyp ERR! find Python **********************************************************
    npm error gyp ERR! find Python You need to install the latest version of Python.
    npm error gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
    npm error gyp ERR! find Python you can try one of the following options:
    npm error gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
    npm error gyp ERR! find Python (accepted by both node-gyp and npm)
    npm error gyp ERR! find Python - Set the environment variable PYTHON
    npm error gyp ERR! find Python - Set the npm configuration variable python:
    npm error gyp ERR! find Python npm config set python "C:\Path\To\python.exe"
    npm error gyp ERR! find Python For more information consult the documentation at:
    npm error gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
    npm error gyp ERR! configure error
    npm error gyp ERR! stack Error: Could not find any Python installation to use
    npm error gyp ERR! stack at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:306:11)
    npm error gyp ERR! stack at PythonFinder.findPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:164:17)
    npm error gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    npm error gyp ERR! stack at async configure (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:27:18)
    npm error gyp ERR! stack at async run (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js:81:18)
    npm error gyp ERR! System Windows_NT 10.0.19045
    npm error gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
    npm error gyp ERR! cwd C:\SmartHome\node_modules\diskusage
    npm error gyp ERR! node -v v20.16.0
    npm error gyp ERR! node-gyp -v v10.1.0
    npm error gyp ERR! not ok
    npm error A complete log of this run can be found in: C:\Users\Sigi\AppData\Local\npm-cache\_logs\2024-08-20T11_21_58_639Z-debug-0.log
    C:\SmartHome>
    GaspodeG 1 Antwort Letzte Antwort
    • sigi234S sigi234
      @sigi234
      python
      in der iob Shell?
      npm error code 1
      C:\SmartHome>
      GaspodeG Offline
      GaspodeG Offline
      Gaspode
      schrieb am zuletzt editiert von Gaspode
      @sigi234
      https://github.com/nodejs/node-gyp#configuring-python-dependency
      Also gucken, was alles verfügbar ist mit
      py --list-paths
      Und testweise setzen mit
      set npm_config_python=C:\python27
      npm i diskusage
      Sollte das klappen (sonst bin ich mit meinem Latein erst mal am Ende), die Variable npm_config_python im System setzen, analog zur Erweiterung von Path, nur halt als neue Variable anlegen.
      Edit: Bei mir war das nicht notwendig, ich hatte Glück und er hat sich die korrekte Version automatisch rausgesucht.
      • GaspodeG Gaspode
        @sigi234
        py --list-paths
        npm i diskusage
        sigi234S Online
        sigi234S Online
        @gaspode
        Ich gebe auf...
        • sigi234S sigi234
          @gaspode
          Ich gebe auf...
          GaspodeG Offline
          GaspodeG Offline
          Gaspode
          @sigi234 said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
          Ich gebe auf...
          Hast du meinen letzten Vorschlag noch probiert?
          • GaspodeG Offline
            GaspodeG Offline
            Gaspode
            So ganz klar ist mir die ganze Sache immer noch nicht, ich habe jetzt noch ein wenig getestet und war unter einem frischen Windows 11 mit wenigen Befehlen erfolgreich. Ich habe das in den Eingangspost geschrieben.
            Ich bleibe aber dran, evtl. bekommen wir die Windows Installation ja doch mal so hin, dass node-gyp sauber aufgesetzt wird.
            • GaspodeG Gaspode
              Ich gebe auf...
              sigi234S Online
              sigi234S Online
              Ich gebe auf...
              Ja
              • sigi234S sigi234
                Ich gebe auf...
                Ja
                GaspodeG Offline
                GaspodeG Offline
                Gaspode
                Ja
                Du bist heute aber nicht besonders gesprächig ;)
                Ich versuche Infos zu sammeln, um das Problem direkt bei der Installation anzugehen, dafür brauche ich aber eure Mithilfe.
                Was sagte denn
                py --list-paths
                Und das Setzen der Variable npm_config_python hat nichts verändert?
                Thomas BraunT sigi234S 2 Antworten Letzte Antwort
                • GaspodeG Gaspode
                  Ja
                  Was sagte denn
                  py --list-paths
                  @gaspode
                  Zwar aus der Linux-Ecke, aber da hat der Installer bis vor kurzem auch noch das eigentlich längst obsolete python 2.7 angeschleppt. Ich weiß aber nicht mehr über welche Abhängigkeit das rein gekommen ist. Aktuelle Setups tun das auch nicht mehr, mein System hat nur noch python 3.xy an Bord.
                    @gaspode
                    GaspodeG Offline
                    GaspodeG Offline
                    Gaspode
                    Danke für den Hinweis. Unter Windows installieren wir derzeit ja weder Python noch einen C++ Compiler während des Setups, da für 95 % aller Adapter nicht erforderlich.
                    Allerdings hatte der "alte" Installer diverse Software mit installiert (u.a. auch Python 2.7), die jetzt wahrscheinlich noch auf einigen PCs vor sich hin dümpelt und mehr Ärger macht als nützt.
                    Ich hatte mich bisher noch nie mit node-gyp beschäftigt, versuche da jetzt ein bisschen die Zusammenhänge zu kapieren und was wo wie konfiguriert wird.
                    • GaspodeG Gaspode
                      Stimmt, ist nur für solche Adapter erforderlich, die Module reinholen die nicht bereits vorkompiliert worden sind.
                      Die github-Seite von node-gyp hast du ja bestimmt schon studiert, da steht eigentlich soweit alles drin, was node-gyp in welchen Versionen benötigt.
                        GaspodeG Offline
                        GaspodeG Offline
                        Gaspode
                        @thomas-braun said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
                        Jep, Danke. Auf nem jungfräulichen Rechner ist das anscheinend auch recht einfach. Auf meinen zwei Rechnern und weiteren VMs hatte ich jedenfalls keine Probleme, das zum Laufen zu bringen.
                        Wenn sich aber 47 verschiedene Python Versionen aus Altlasten tummeln, scheint es schwieriger zu werden. Bei @sigi234 klappt es ja anscheinend nicht, die zu verwendende Installation per Umgebungsvariable zu erzwingen, warum auch immer. Mal sehen, ob er noch weitere Infos beisteuern kann.
                        • GaspodeG Gaspode
                          sigi234S Online
                          sigi234S Online
                          Kommen sobald ich wieder kann.
                          • GaspodeG Gaspode
                            Ja
                            Was sagte denn
                            py --list-paths
                            sigi234S Online
                            sigi234S Online
                            py --list-paths
                            Bin ich da Richtig?
                            • sigi234S sigi234
                              py --list-paths
                              Bin ich da Richtig?
                              GaspodeG Offline
                              GaspodeG Offline
                              Gaspode
                              Bin ich da Richtig?
                              Ja, prinzipiell schon. Anscheinend wird der Python Launcher nicht automatisch installiert, wenn man winget nutzt (im Gegensatz zur MSI Installation :( ).
                              Versuch bitte mal
                              winget install --id=Python.Launcher  -e
                              Und dann nochmal
                              py --list-paths
                              Sorry für das hin und her, ich lerne das auch gerade. :D
                              • GaspodeG Gaspode
                                Bin ich da Richtig?
                                Versuch bitte mal
                                Und dann nochmal
                                py --list-paths
                                sigi234S Online
                                sigi234S Online
                                Bin ich da Richtig?
                                Versuch bitte mal
                                Und dann nochmal
                                py --list-paths
                                • sigi234S sigi234
                                  Bin ich da Richtig?
                                  Versuch bitte mal
                                  Und dann nochmal
                                  py --list-paths
                                  GaspodeG Offline
                                  GaspodeG Offline
                                  Gaspode
                                  Jetzt kapier ich gar nix mehr, winget hattest du doch gerade gestern noch verwendet?
                                  • GaspodeG Gaspode
                                    sigi234S Online
                                    sigi234S Online
                                    Nein, darum ja ich gebe auf...das kam gestern schon so
                                    • sigi234S sigi234
                                      GaspodeG Offline
                                      GaspodeG Offline
                                      Gaspode
                                      @sigi234
                                      Alternativ die Installation per Download:
                                      https://www.python.org/ftp/python/3.12.5/python-3.12.5-amd64.exe
                                      • GaspodeG Gaspode
                                        @sigi234
                                        sigi234S Online
                                        sigi234S Online
                                        @gaspode
                                        Ok, die alte Version deinstallieren?
                                        • sigi234S sigi234
                                          @gaspode
                                          GaspodeG Offline
                                          GaspodeG Offline
                                          Gaspode
                                          Ist der Ordnung halber wohl besser, muss aber nicht sein. Auf meinem Arbeitsrechner hab ich 7 Python Versionen parallel und node-gyp funktioniert erstaunlicherweise und nimmt die richtige Version. :D
