  4. [gelöst] Iobroker startet nicht
15 Beiträge 4 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • peterk34P peterk34
    ich habe meinen Raspi getauscht. Alles ist auf Festplatte und funktioniert von Anfang an. Leider startet der Iobroker nicht richtig
    Log:
    2024-08-14 13:21:36.815  - info: host.pi4iobroker iobroker.js-controller version 6.0.10 js-controller starting
    2024-08-14 13:21:36.821  - info: host.pi4iobroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2024-08-14 13:21:36.822  - info: host.pi4iobroker hostname: pi4iobroker, node: v20.16.0
    2024-08-14 13:21:36.825  - info: host.pi4iobroker ip addresses: 192.168.8.164 fd00::da03:2108:e015:d64b fe80::1c6:8c0c:c2f6:1482
    2024-08-14 13:21:37.282  - info: host.pi4iobroker connected to Objects and States
    2024-08-14 13:21:37.311  - info: host.pi4iobroker added notifications configuration of host
    2024-08-14 13:21:37.773  - info: host.pi4iobroker 52 instances found
    2024-08-14 13:21:37.798  - warn: host.pi4iobroker does not start any instances on this host
    fix, Neustart bringt nichts
    gibts eine Idee?
    CodierknechtC Offline
    Codierknecht
    @peterk34 sagte in Iobroker startet nicht:
    Redis auch?
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
      			v.2024-05-22
       Static hostname: pi4iobroker
             Icon name: computer
                Kernel: Linux 6.6.31+rpt-rpi-v8
          Architecture: arm64
      Installation: 		native
      Kernel: 		aarch64
      Userland: 		64 bit
      Timezone: 		Europe/Vienna (CEST, +0200)
      User-ID: 		1000
      Display-Server: 	false
      Boot Target: 		multi-user.target
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation:
      /usr/bin/nodejs 	v20.16.0
      /usr/bin/node 		v20.16.0
      /usr/bin/npm 		10.8.1
      /usr/bin/npx 		10.8.1
      /usr/bin/corepack 	0.28.2
      Recommended versions are nodejs  and npm
      MEMORY:
      Mem:            8.2G        1.5G        6.2G        1.2M        667M        6.7G
      Swap:           209M          0B        209M
      Total:          8.4G        1.5G        6.4G
      Active iob-Instances: 	1
      Upgrade policy: none
      ioBroker Core: 		js-controller 		6.0.10
      			admin 			7.0.22
      ioBroker Status: 	iobroker is running on this host.
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
        system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 		53315
      States: 		46851
      Size of iob-Database:
      5.0M	/opt/iobroker/iobroker-data/objects.jsonl
      116K	/opt/iobroker/iobroker-data/states.jsonl
      bevor er loslegt kommt:
      The state system.host.pi4iobroker.versions.nodeNewestNext was not found!
      The state system.host.pi4iobroker.versions.npmNewestNext was not found!
      The state system.host.pi4iobroker.versions.nodeCurrent was not found!
      @peterk34
      apt policy redis
      sagt?
      peterk34P 1 Antwort Letzte Antwort
        @peterk34
        apt policy redis
        sagt?
        peterk34P Offline
        peterk34P Offline
        peterk34
        ich hab wohl einen Fehler entdeckt ... ich hatte den host namen geändert ... war offenbar eine blöde idee.
          @peterk34
          iob host this
          bringt das in Ordnung.
            @peterk34
            iob host this
            peterk34P Offline
            peterk34P Offline
            peterk34
            schrieb am zuletzt editiert von peterk34
            @thomas-braun ich habe ihn zurückbenannt, jetzt läuft er wieder, zeigt unter hosts aber zewi an
            wie kriege ich den zweiten weg?
              da ist eine Mülltonne!
              EDIT:
              Wo kommt denn jetzt der Screenshot her?
                Warum? Und wie?
                Mit hostnames musst du vorsichtig umgehen.
                  Warum? Und wie?
                  peterk34P Offline
                  peterk34P Offline
                  peterk34
                  ich hab ihn über die raspi-config auf den Namen gestellt den der pi vorher hatte.
                  nach iob stop habe ich den 2. host mit
                  iobroker host remove pi4iobroker
                  wegbekommen.
                  So wies aussieht läuft jetzt alles.
                  Danke für Deine Unterstützung
                    wegbekommen.
                    @peterk34 sagte in [gelöst] Iobroker startet nicht:
                    und hoffentlich danach rebootet!??
                      peterk34P Offline
                      peterk34P Offline
                      peterk34
                      @homoran yep
