  4. [gelöst] Iobroker startet nicht
15 Beiträge 4 Kommentatoren 1.5k Aufrufe 3 Beobachtet
    @peterk34 sagte in Iobroker startet nicht:
    gibts eine Idee?
    iob diag
    anschauen ist immer eine Idee.
    peterk34P Offline
    peterk34P Offline
    peterk34
    @thomas-braun vorher Iob stop?
      gibts eine Idee?
      iob diag
      peterk34P Offline
      peterk34P Offline
      peterk34
      schrieb am zuletzt editiert von peterk34
      			v.2024-05-22
       Static hostname: pi4iobroker
             Icon name: computer
                Kernel: Linux 6.6.31+rpt-rpi-v8
          Architecture: arm64
      Installation: 		native
      Kernel: 		aarch64
      Userland: 		64 bit
      Timezone: 		Europe/Vienna (CEST, +0200)
      User-ID: 		1000
      Display-Server: 	false
      Boot Target: 		multi-user.target
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation:
      /usr/bin/nodejs 	v20.16.0
      /usr/bin/node 		v20.16.0
      /usr/bin/npm 		10.8.1
      /usr/bin/npx 		10.8.1
      /usr/bin/corepack 	0.28.2
      Recommended versions are nodejs  and npm
      MEMORY:
      Mem:            8.2G        1.5G        6.2G        1.2M        667M        6.7G
      Swap:           209M          0B        209M
      Total:          8.4G        1.5G        6.4G
      Active iob-Instances: 	1
      Upgrade policy: none
      ioBroker Core: 		js-controller 		6.0.10
      			admin 			7.0.22
      ioBroker Status: 	iobroker is running on this host.
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
        system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 		53315
      States: 		46851
      Size of iob-Database:
      5.0M	/opt/iobroker/iobroker-data/objects.jsonl
      116K	/opt/iobroker/iobroker-data/states.jsonl
      bevor er loslegt kommt:
      The state system.host.pi4iobroker.versions.nodeNewestNext was not found!
      The state system.host.pi4iobroker.versions.npmNewestNext was not found!
      The state system.host.pi4iobroker.versions.nodeCurrent was not found!
      • peterk34P peterk34
        			v.2024-05-22
               Icon name: computer
            Architecture: arm64
        Kernel: 		aarch64
        Userland: 		64 bit
        User-ID: 		1000
        /usr/bin/npm 		10.8.1
        /usr/bin/npx 		10.8.1
        MEMORY:
        Swap:           209M          0B        209M
        			admin 			7.0.22
        Objects type: redis
        States  type: redis
        Objects: 		53315
        States: 		46851
        @peterk34
        Die Langfassung bitte.
          ich habe meinen Raspi getauscht. Alles ist auf Festplatte und funktioniert von Anfang an. Leider startet der Iobroker nicht richtig
          Log:
          2024-08-14 13:21:36.815  - info: host.pi4iobroker iobroker.js-controller version 6.0.10 js-controller starting
          2024-08-14 13:21:36.821  - info: host.pi4iobroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
          2024-08-14 13:21:36.822  - info: host.pi4iobroker hostname: pi4iobroker, node: v20.16.0
          2024-08-14 13:21:36.825  - info: host.pi4iobroker ip addresses: 192.168.8.164 fd00::da03:2108:e015:d64b fe80::1c6:8c0c:c2f6:1482
          2024-08-14 13:21:37.282  - info: host.pi4iobroker connected to Objects and States
          2024-08-14 13:21:37.311  - info: host.pi4iobroker added notifications configuration of host
          2024-08-14 13:21:37.773  - info: host.pi4iobroker 52 instances found
          2024-08-14 13:21:37.798  - warn: host.pi4iobroker does not start any instances on this host
          fix, Neustart bringt nichts
          gibts eine Idee?
          CodierknechtC Offline
          Codierknecht
          Redis auch?
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
            			v.2024-05-22
                   Icon name: computer
                Architecture: arm64
            Kernel: 		aarch64
            Userland: 		64 bit
            User-ID: 		1000
            /usr/bin/npm 		10.8.1
            /usr/bin/npx 		10.8.1
            MEMORY:
            Swap:           209M          0B        209M
            			admin 			7.0.22
            Objects type: redis
            States  type: redis
            Objects: 		53315
            States: 		46851
            @peterk34
            apt policy redis
            sagt?
            peterk34P 1 Antwort Letzte Antwort
              @peterk34
              apt policy redis
              sagt?
              peterk34P Offline
              peterk34P Offline
              peterk34
              ich hab wohl einen Fehler entdeckt ... ich hatte den host namen geändert ... war offenbar eine blöde idee.
                @peterk34
                iob host this
                bringt das in Ordnung.
                  @peterk34
                  iob host this
                  peterk34P Offline
                  peterk34P Offline
                  peterk34
                  @thomas-braun ich habe ihn zurückbenannt, jetzt läuft er wieder, zeigt unter hosts aber zewi an
                  wie kriege ich den zweiten weg?
                    da ist eine Mülltonne!
                    EDIT:
                    Wo kommt denn jetzt der Screenshot her?
                      Warum? Und wie?
                      Mit hostnames musst du vorsichtig umgehen.
                        Warum? Und wie?
                        peterk34P Offline
                        peterk34P Offline
                        peterk34
                        ich hab ihn über die raspi-config auf den Namen gestellt den der pi vorher hatte.
                        nach iob stop habe ich den 2. host mit
                        iobroker host remove pi4iobroker
                        wegbekommen.
                        So wies aussieht läuft jetzt alles.
                        Danke für Deine Unterstützung
                          wegbekommen.
                          @peterk34 sagte in [gelöst] Iobroker startet nicht:
                          und hoffentlich danach rebootet!??
                            peterk34P Offline
                            peterk34P Offline
                            peterk34
                            @homoran yep
