  4. JavaScript
  5. E3DC Hauskraftwerk steuern
3.6k Beiträge 73 Kommentatoren 2.2m Aufrufe 64 Beobachtet
  • C Chilihead
    Hallo Arno,
    bei mir kommt immer unknown tag code und ich nehme an das es von deinem Script kommt, sonst hab ich nichts laufen. Hattest du das schon mal?
    javascript.0
    2024-07-09 12:33:54.004	warn	script.js.E3DC_Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
    javascript.0
    2024-07-09 12:33:54.004	info	script.js.E3DC_Charge_Control: ******************* Debug LOG Charge-Control *******************
    e3dc-rscp.0
    2024-07-09 12:33:53.172	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    e3dc-rscp.0
    2024-07-09 12:33:51.175	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    e3dc-rscp.0
    2024-07-09 12:33:49.172	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    e3dc-rscp.0
    2024-07-09 12:33:47.169	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    e3dc-rscp.0
    2024-07-09 12:33:45.165	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    javascript.0
    2024-07-09 12:33:45.004	warn	script.js.E3DC_Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
    javascript.0
    2024-07-09 12:33:45.004	info	script.js.E3DC_Charge_Control: ******************* Debug LOG Charge-Control *******************
    e3dc-rscp.0
    2024-07-09 12:33:43.171	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    e3dc-rscp.0
    2024-07-09 12:33:41.166	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    e3dc-rscp.0
    2024-07-09 12:33:39.167	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    javascript.0
    2024-07-09 12:33:39.004	warn	script.js.E3DC_Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
    javascript.0
    2024-07-09 12:33:39.004	info	script.js.E3DC_Charge_Control: ******************* Debug LOG Charge-Control *******************
    e3dc-rscp.0
    2024-07-09 12:33:37.165	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    e3dc-rscp.0
    2024-07-09 12:33:35.162	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    e3dc-rscp.0
    2024-07-09 12:33:33.196	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    e3dc-rscp.0
    2024-07-09 12:33:31.166	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    javascript.0
    2024-07-09 12:33:30.015	warn	script.js.E3DC_Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
    javascript.0
    2024-07-09 12:33:30.015	info	script.js.E3DC_Charge_Control: ******************* Debug LOG Charge-Control *******************
    e3dc-rscp.0
    2024-07-09 12:33:29.167	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    e3dc-rscp.0
    2024-07-09 12:33:27.167	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    e3dc-rscp.0
    2024-07-09 12:33:25.165	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    javascript.0
    2024-07-09 12:33:24.008	warn	script.js.E3DC_Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
    javascript.0
    2024-07-09 12:33:24.008	info	script.js.E3DC_Charge_Control: ******************* Debug LOG Charge-Control *******************
    e3dc-rscp.0
    2024-07-09 12:33:23.157	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    e3dc-rscp.0
    2024-07-09 12:33:21.162	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    e3dc-rscp.0
    2024-07-09 12:33:19.155	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
    ArnoD
    #2607
    @chilihead
    Das kommt vom e3dc-rscp Adapter.
    Kann es sein das du beim E3DC ein neues Firmware Update erhalten hast oder den Adapter neu installiert hast ?
    Einmal auf Github e3dc-rscp prüfen ob das Problem bereits bekannt ist.
    Nachtrag:
    Kann es sich um diesen Fehler handeln: https://github.com/git-kick/ioBroker.e3dc-rscp/issues/218
    C 1 Antwort Letzte Antwort
    • A ArnoD
      @chilihead
      Nachtrag:
      Chilihead
      #2608
      @arnod du bist der Beste! 1.2.6 installiert und gut is. Hattest du das nicht?
      Das 1.2.6 update unterdrückt ja nur die Meldung
        ArnoD
        #2609
        @chilihead
        Ist mir nicht aufgefallen.
        Ich verwende aber auch nicht die Backup Funktion um alle Adapter Einstellungen wiederherstellen zu können.
        • bluebeanB Offline
          bluebeanB Offline
          bluebean
          schrieb am zuletzt editiert von bluebean
          #2610
          @ArnoD
          Letzte Nach hab ich ein neues E3DC-Update für mein S10 Pro bekommen auf Version P10_2024_024. Seitdem bekomme ich im Log lediglich noch ein "E3DC Connection closed", keinerlei Verbindung oder Regelung mehr.
          (Info: das Release liefert im Wesentlichen zwei neue Features: zum einen kann man jetzt auch die Batterie für die Ladung gegenüber der Wallbox priorisieren und dafür dann auch einen SOC einstellen, bis zu dem das gelten soll. Zu anderen kann man jetzt für dynamische Strompreise einstellen, dass die Batterie unter einem Preislimit geladen wird bis zu einem eiunstellbaren SOC - und dieses kann man für jeden Monat einzeln definieren.)
          PS: nach einem kompletten Restart vom iobroker läuft's wieder. Wer also auch damit kämpft, probiert's mal.
          • bluebeanB bluebean
            @ArnoD
            ArnoD
            #2611
            @bluebean
            Danke für die Information.
            Habe gerade festgestellt das ich gestern auch das Update erhalten habe.
            Bei mir ist aber bis jetzt kein Problem aufgetreten, kann aber auch daran liegen das ich am Abend einige Änderungen getestet habe und dadurch einige Neustarts hatte.
            • P Offline
              psrelax
              #2612
              ich glaube, ich habe in Zeile 683 einen Fehler gefunden.
              if (DebugAusgabeDetail){log(`PV Leistung = ${(await getStateAsync(sID_PvLeistung_ADD_W)).val+Math.abs((await getStateAsync(sID_PvLeistung_ADD_W)).val)} W`)}
              Es werden 2 Mal die selben Werte addiert.
              bluebeanB 1 Antwort Letzte Antwort
              • P psrelax
                bluebeanB Offline
                bluebeanB Offline
                bluebean
                #2613
                Ich vermute auch, dass es beim ersten Summanden sID_PvLeistung_E3DC_W heißen müsste... (vgl. Zeile 367).
                  ArnoD
                  #2614
                  @psrelax @bluebean
                  Ja richtig, ist ein Kopierfehler und so wäre es richtig:
                  if (DebugAusgabeDetail){log(`PV Leistung = ${(await getStateAsync(sID_PvLeistung_E3DC_W)).val+Math.abs((await getStateAsync(sID_PvLeistung_ADD_W)).val)} W`)}
                  Ist bereits korrigiert und wird mit der nächsten Version behoben sein.
                  Danke.
                  • P Offline
                    psrelax
                    #2615
                    Hallo @ArnoD ,
                    ich habe seit einiger Zeit ein Problem mit dem Script und komme irgendwie nicht weiter.
                    Erst war das Problem nur hin und wieder und mittlerweile fast täglich.
                    Das Problem ist, dass einfach die Speicher -entladung/ladung stoppt.
                    Nach einem Neustart des Scriptes läuft alles wieder problemlos.
                    Zu sehen ist das in der nachfolgenden Log unter "Batterie Leistung". Vorher 0 und nach dem Neustart mit Ladeleistung.
                    Ich verwende die letzte Version des Scriptes ohne Änderungen, bis auf Zeile 11-14. -> 1.4.1
                    Ich hoffe du kannst mir dabei helfen.
                    Danke dir schonmal.
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 90
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 10
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikAnwahl =true
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikRegelung =true
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =2
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:23
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:23
                    2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 16:17
                    2024-08-06 15:32:24.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unload = 0
                    2024-08-06 15:32:24.077  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 50
                    2024-08-06 15:32:24.079  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 99
                    2024-08-06 15:32:24.082  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                    2024-08-06 15:32:24.084  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 0
                    2024-08-06 15:32:24.086  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                    2024-08-06 15:32:24.089  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                    2024-08-06 15:32:24.091  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 04:30
                    2024-08-06 15:32:24.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 10
                    2024-08-06 15:32:24.094  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 5
                    2024-08-06 15:32:24.095  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 0.725
                    2024-08-06 15:32:24.097  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 3664W
                    2024-08-06 15:32:24.098  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
                    2024-08-06 15:32:24.100  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 6763 W
                    2024-08-06 15:32:24.100  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 15kWh
                    2024-08-06 15:32:24.141  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 68 %
                    2024-08-06 15:32:24.141  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                    2024-08-06 15:32:24.141  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                    2024-08-06 15:32:24.141  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: NotstromAusNetz =false
                    2024-08-06 15:32:24.183  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                    2024-08-06 15:32:24.183  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                    2024-08-06 15:32:24.183  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                    2024-08-06 15:32:24.183  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                    2024-08-06 15:32:24.184  - warn: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
                    2024-08-06 15:32:25.434  - info: javascript.0 (193) Stopping script script.js.E3DC_ChargeControl.Charge_Control
                    2024-08-06 15:32:29.211  - info: javascript.0 (193) Start JavaScript script.js.E3DC_ChargeControl.Charge_Control (Javascript/js)
                    2024-08-06 15:32:29.241  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Charge-Control Version 1.4.1 ====- "}##
                    2024-08-06 15:32:29.258  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: registered 70 subscriptions, 5 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2024-08-06 15:32:29.258  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" -==== alle Objekt ID's angelegt ====- "}##
                    2024-08-06 15:32:29.379  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" -==== alle Objekte ID's überprüft ====- "}##
                    2024-08-06 15:32:29.391  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Speichergroesse_kWh=15 ====- "}##
                    2024-08-06 15:32:29.392  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" ****************************** Es wird Solcast Dach 2 abgerufen ****************************** "}##
                    2024-08-06 15:32:30.589  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
                    2024-08-06 15:32:30.590  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" ****************************** Es wird Solcast Dach 1 abgerufen ****************************** "}##
                    2024-08-06 15:32:31.442  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
                    2024-08-06 15:32:31.442  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-06 pv_estimate= 6.51 pv_estimate90= 6.55"}##
                    2024-08-06 15:32:31.442  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-07 pv_estimate= 42.65 pv_estimate90= 54"}##
                    2024-08-06 15:32:31.450  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-08 pv_estimate= 30.73 pv_estimate90= 55.16"}##
                    2024-08-06 15:32:31.455  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-09 pv_estimate= 52.55 pv_estimate90= 54.69"}##
                    2024-08-06 15:32:31.460  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-10 pv_estimate= 40.89 pv_estimate90= 54.38"}##
                    2024-08-06 15:32:31.466  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-11 pv_estimate= 51.75 pv_estimate90= 52.17"}##
                    2024-08-06 15:32:31.470  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-12 pv_estimate= 49.69 pv_estimate90= 50.53"}##
                    2024-08-06 15:32:31.579  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" ******************* Es wird die Globalstrahlung ab Tag 0 von Proplanta abgerufen ******************* "}##
                    2024-08-06 15:32:32.092  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Rueckmeldung InterrogateProplanta response.status = 200"}##
                    2024-08-06 15:32:32.097  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Globalstrahlung Tag0 =6.9  Globalstrahlung Tag1 =5.2  Globalstrahlung Tag2 =4.1  Globalstrahlung Tag3 =6.8"}##
                    2024-08-06 15:32:32.188  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Näste Aktualisierung Wetterdaten =21:45 Uhr "}##
                    2024-08-06 15:32:32.189  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" ******************* Es wird die Globalstrahlung ab Tag 4 von Proplanta abgerufen ******************* "}##
                    2024-08-06 15:32:32.737  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Rueckmeldung InterrogateProplanta response.status = 200"}##
                    2024-08-06 15:32:32.740  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Globalstrahlung Tag4 =5.5  Globalstrahlung Tag5 =6.7  Globalstrahlung Tag6 =6.7"}##
                    2024-08-06 15:32:32.799  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Prognose Solcast in kWh = 54.65"}##
                    2024-08-06 15:32:32.800  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Prognose Solcast 90 Perzentil in kWh = 54.71"}##
                    2024-08-06 15:32:32.800  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Prognose Proplanta in kWh = 83.90400000000001"}##
                    2024-08-06 15:32:32.800  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Prognose_kWh nach Abzug Korrekturfaktor  = 75.51360000000001"}##
                    2024-08-06 15:32:32.800  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Bereits produzierte PV-Leistung  = 57.887489475614196"}##
                    2024-08-06 15:32:32.884  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Prognose_kWh_heute für Berechnung = 17.626110524385815"}##
                    2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                    2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                    2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                    2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 90
                    2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                    2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                    2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                    2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 10
                    2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                    2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikAnwahl =true
                    2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikRegelung =true
                    2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =2
                    2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:23
                    2024-08-06 15:32:33.076  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:23
                    2024-08-06 15:32:33.076  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 16:17
                    2024-08-06 15:32:33.117  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unload = 0
                    2024-08-06 15:32:33.158  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 50
                    2024-08-06 15:32:33.199  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 99
                    2024-08-06 15:32:33.240  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                    2024-08-06 15:32:33.281  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 0
                    2024-08-06 15:32:33.283  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                    2024-08-06 15:32:33.324  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                    2024-08-06 15:32:33.367  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 04:30
                    2024-08-06 15:32:33.409  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 10
                    2024-08-06 15:32:33.411  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 5
                    2024-08-06 15:32:33.452  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 0.725
                    2024-08-06 15:32:33.493  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 3664W
                    2024-08-06 15:32:33.534  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
                    2024-08-06 15:32:33.537  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 6747 W
                    2024-08-06 15:32:33.537  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 15kWh
                    2024-08-06 15:32:33.578  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 68 %
                    2024-08-06 15:32:33.578  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                    2024-08-06 15:32:33.578  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                    2024-08-06 15:32:33.578  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: NotstromAusNetz =false
                    2024-08-06 15:32:33.620  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                    2024-08-06 15:32:33.620  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                    2024-08-06 15:32:33.620  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 0
                    2024-08-06 15:32:33.620  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                    2024-08-06 15:32:33.620  - warn: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 0,
                    2024-08-06 15:32:33.901  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Eigenverbrauch Tag = 25"}##
                    2024-08-06 15:32:33.902  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" AktSpeicherSoC in % = 68"}##
                    2024-08-06 15:32:33.902  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Ueberschuss in kWh 6.159443857719148 = (Prognose kWh 17.626110524385815 - Berechneter Eigenverbrauch 6.666666666666668) - FreieKapBatterie_kWh 4.8"}##
                    2024-08-06 15:32:33.902  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Ueberschuss in Prozent = 41.062959051460986"}##
                    2024-08-06 15:32:33.948  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Bewölkungsgrad 12 Uhr Proplanta 12.5"}##
                    2024-08-06 15:32:33.948  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Bewölkungsgrad 15 Uhr Proplanta 12.5"}##
                    2024-08-06 15:32:33.949  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Einstellung 2 aktiv ====-"}##
                    2024-08-06 15:32:42.064  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                    2024-08-06 15:32:42.064  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                    2024-08-06 15:32:42.064  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                    2024-08-06 15:32:42.064  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 90
                    2024-08-06 15:32:42.064  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                    2024-08-06 15:32:42.064  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                    2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                    2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 10
                    2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                    2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikAnwahl =true
                    2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikRegelung =true
                    2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =2
                    2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:23
                    2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:23
                    2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 16:17
                    2024-08-06 15:32:42.108  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unload = 0
                    2024-08-06 15:32:42.110  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 50
                    2024-08-06 15:32:42.111  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 99
                    2024-08-06 15:32:42.114  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                    2024-08-06 15:32:42.115  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 0
                    2024-08-06 15:32:42.117  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                    2024-08-06 15:32:42.119  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                    2024-08-06 15:32:42.120  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 04:30
                    2024-08-06 15:32:42.122  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 10
                    2024-08-06 15:32:42.124  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 5
                    2024-08-06 15:32:42.125  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 0.725
                    2024-08-06 15:32:42.127  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 3698W
                    2024-08-06 15:32:42.129  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
                    2024-08-06 15:32:42.135  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 6761 W
                    2024-08-06 15:32:42.135  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 15kWh
                    2024-08-06 15:32:42.176  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 68 %
                    2024-08-06 15:32:42.176  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                    2024-08-06 15:32:42.176  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                    2024-08-06 15:32:42.176  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: NotstromAusNetz =false
                    2024-08-06 15:32:42.218  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                    2024-08-06 15:32:42.218  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                    2024-08-06 15:32:42.218  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                    2024-08-06 15:32:42.218  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                    2024-08-06 15:32:42.218  - warn: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
                    2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                    2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                    2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                    2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 90
                    2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                    2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                    2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                    2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 10
                    2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                    2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikAnwahl =true
                    2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikRegelung =true
                    2024-08-06 15:32:48.094  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =2
                    2024-08-06 15:32:48.094  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:23
                    2024-08-06 15:32:48.094  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:23
                    2024-08-06 15:32:48.094  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 16:17
                    2024-08-06 15:32:48.137  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unload = 0
                    2024-08-06 15:32:48.139  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 50
                    2024-08-06 15:32:48.141  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 99
                    2024-08-06 15:32:48.144  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                    2024-08-06 15:32:48.146  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 0
                    2024-08-06 15:32:48.148  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                    2024-08-06 15:32:48.189  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                    2024-08-06 15:32:48.191  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 04:30
                    2024-08-06 15:32:48.193  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 10
                    2024-08-06 15:32:48.195  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 5
                    2024-08-06 15:32:48.196  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 0.725
                    2024-08-06 15:32:48.199  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 4441W
                    2024-08-06 15:32:48.201  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 2079 W
                    2024-08-06 15:32:48.204  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 6767 W
                    2024-08-06 15:32:48.204  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 15kWh
                    2024-08-06 15:32:48.246  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 68 %
                    2024-08-06 15:32:48.246  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                    2024-08-06 15:32:48.249  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                    2024-08-06 15:32:48.249  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: NotstromAusNetz =false
                    2024-08-06 15:32:48.295  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                    2024-08-06 15:32:48.295  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                    2024-08-06 15:32:48.295  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                    2024-08-06 15:32:48.295  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                    2024-08-06 15:32:48.295  - warn: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
                    • P psrelax
                      Hallo @ArnoD ,
                      Danke dir schonmal.
                      ArnoD
                      #2616
                      @psrelax
                      Nach dem LOG Eintrag wird in dem Moment vom Script nichts geregelt. ProgrammAblauf 10 sagt aus das die Ladeschwelle 70% nicht erreicht wurde und E3DC die Steuerung überlassen wird, da das Standardverhalten vom E3DC ist, alles an Überschuss in die Batterie zu laden.
                      Notstrom SOC wurde auch nicht erreich, was der einzige Grund wäre, warum das Entladen vom Script verhindert wird.
                      15:32 Uhr wurde das Script neu gestartet und danach eigentlich das Gleiche verhalten, ProgrammAblauf 10
                      Wenn das Problem wieder auftritt, versuch mal nur das Script zu stoppen und nicht neu zu starten, es dürfte sich dann an deinem Problem nichts ändern.
                      Kannst du mal prüfen, was du im Adapter e3dc-rscp unter Einstellungen/Zeitintervalle für Senden/SET_POWER Wiederholintervall eingetragen hast.
                      P 1 Antwort Letzte Antwort
                      • A ArnoD
                        @psrelax
                        psrelax
                        #2617
                        @arnod
                        Danke für die schnelle Rückmeldung.
                        "SET_POWER Wiederholintervall" war auf 1 gestellt. Ist anscheinend mal bei einem Update rein gekommen.
                        Kann es das gewesen sein? Was hat das für eine Auswirkung?
                        • P psrelax
                          @arnod
                          ArnoD
                          #2618
                          @psrelax
                          Ja das war der Fehler :-)
                          E3DC hat bei seiner Schnittstelle eine Sicherheit eingebaut, nämlich dass die Werte zur Leistungssteuerung min. alle 6 sek, wiederholt werden müssen, wenn das nicht erfolgt übernimmt E3DC wieder die Steuerung.
                          "SET_POWER Wiederholintervall" bewirkt, dass der e3dc-rscp Adapter den Wert SET_POWER_VALUE innerhalb der eingestellten Zeit wiederholt.
                          Das Problem ist jetzt aber, dass mein Script genau diesen Sicherheitsmechanismus nutzt und einfach keine Werte mehr setzt, wenn E3DC die Regelung wieder übernehmen soll.
                          Durch die Einstellung 1 hat aber der e3dc-rscp Adapter den letzten Wert 0 vom Skript jede sek. gesetzt und somit das Entladen der Batterie verhindert.
                          • A ArnoD
                            @psrelax
                            psrelax
                            #2619
                            @arnod
                            Ok, vielen Dank für die Info.
                            Wie geht es mit der Tibber-Implementation voran? :-)
                            • P psrelax
                              @arnod
                              ArnoD
                              #2620
                              Nicht einfach, aber es wird schon. :-)
                              • azzkikrboyA Offline
                                azzkikrboyA Offline
                                azzkikrboy
                                #2621
                                Hallo @ArnoD
                                Ich habe gerade ioBroker upgedated und dann folgede Meldung im Log gesehen.
                                Sieht so aus, als ob der javascript-Adapter das zusätzliche Package "FS" nicht installieren kann.
                                Script scheint aber trotzdem zu laufen (auf den ersten Blick ...).
                                Cannot install custom npm package "fs@latest": Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/fs/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
                                Sollte das per Hand nachinstalliert werden?
                                • azzkikrboyA azzkikrboy
                                  Hallo @ArnoD
                                  #2622
                                  @azzkikrboy sagte in E3DC Hauskraftwerk steuern:
                                  Nein, lass das so.
                                  azzkikrboyA 1 Antwort Letzte Antwort
                                    Nein, lass das so.
                                    azzkikrboyA Offline
                                    azzkikrboyA Offline
                                    azzkikrboy
                                    #2623
                                    OK. Danke.
                                    • P psrelax
                                      @arnod
                                      Die View schaut doch schonmal gut aus. Ist sie schon in Github verfügbar? Würde sie gleich mal testen.
                                      Hier meine zusätzlichen Vorschläge:
                                      • Ladung in der Nacht -> wenn Speicher SOC zu gering, um durchzuhalten, bis am nächsten Vormittag wieder genug PV vorhanden ist (Prognose Solcast/Proplanta).
                                      • Ladung in der Nacht -> wenn am nächsten Tag kaum Solarertrag prognostiziert wird, dann so voll laden, bis nächste günstige Prognose von Tibber eintritt.
                                      • Ladung am Tag -> wenn SOC zu niedrig, so viel Laden, um mindestens die teure Zeit bei Tibber in den Abendstunden überbrücken zu können. Evtl. sogar, bis die günstige Zeit laut Tibber in der Nacht beginnt.
                                      • Ladung manuell ansteuern, wie bei mir gerade über einen Datenpunk für die Aktivierung(true/false), Ziel-SOC und evtl. die Ladestärke(Watt). Ist evtl hilfreich, wenn benutzer deines Scripts etwas manuell machen wollen.
                                      Bei alle Szenarien ist aber mit einzuberechnen, ob sich der Preisunterschied rentiert, um eine Ladung zu rechtfertigen. Hier muss man die Kosten der Wandlungsverluste und evtl. den Verschleiß des Akkus berücksichtigen.
                                      Eventuell kannst du dir auch bei folgendem Projekt Anregungen holen, da hier schon einiges durchgearbeitet wurde.
                                      Ich selbst verwende eine etwas abgewandelte Version des ersten veröffentlichten Scriptes um die Ladung zu starten.
                                      https://forum.iobroker.net/topic/69604/hausspeicher-laden-dynamisch-tibberlink-scripte
                                      ArnoD
                                      #2624
                                      @psrelax
                                      Ich habe jetzt mal die erste Version vom Tibber Skript und ChargeControl v. 1.5.0 auf Github hochgeladen.
                                      Branch Issue#10
                                      Wenn du Lust hast, kannst du das so weit mal testen.
                                      Es fehlen noch einige Funktionen und aktuell funktioniert das Laden zum günstigsten Stundenblock.
                                      Die View findest du auch auf Github zum Importieren: View Import Dateien
                                      Bei ChargeControl Version 1.5.0 hat sich einiges geändert und wenn du die History Daten der PV-Prognose für August benötigst, kannst du bis zum 01.09 warten oder die Daten manuell in die jeweiligen Array Objekte eintragen.
                                      Hier die Auflistung der Änderungen:
                                      • Es wird überprüft ob bei den Instanzeinstellungen des e3dc-rscp Adapter __SET_POWER Wiederholintervall auf 0 eingestellt ist.
                                      • Fehler behoben, dass bei Leerlauf Script ChargeControl SET_POWER_MODE nicht auf 0 gesetzt wurde.
                                      • Fehler im DebugLog behoben, wo zweimal die gleichen Werte sID_PvLeistung_ADD_W addiert wurden. (Danke an @psrelax für den Hinweis)
                                      • Kleinere Optimierungen und Fehler behoben für das Script my-pv Heizstab
                                      • Schnittstelle für das Skript Tibber integriert
                                      • Berechnung des durchschnittlichen Hausverbrauchs neu erstellt. Es wird jetzt der Durchschnitt für jeden Tag, getrennt in Verbrauch Tag und Nacht berechnet.
                                        Die Anzeige Autonomiezeit in VIS wurde dadurch auch angepasst. Es wird jetzt die Reichweite der Batterie mit dem neuen Durchschnittsverbrauch berechnet und mit dem aktuellen Verbrauch bei Entladung der Batterie.
                                      • Alle Objekt ID's IstPvLeistung_kWh_1 bis 31 werden nicht mehr benötigt. Daten werden unter der neuen Objekt ID 0_userdata.0.Charge_Control.History.istPV_LeistungTag_kWh gespeichert.
                                      • Alle Objekt ID's PrognoseProp_kWh_1 bis 31 werden nicht mehr benötigt. Daten werden unter der neuen Objekt ID 0_userdata.0.Charge_Control.History.PrognoseProp_kWh gespeichert.
                                      • Alle Objekt ID's PrognoseAuto_kWh_1 bis 31 werden nicht mehr benötigt. Daten werden unter der neuen Objekt ID 0_userdata.0.Charge_Control.History.PrognoseAuto_kWh gespeichert.
                                      • Alle Objekt ID's PrognoseSolcast90_kWh_1 bis 31 werden nicht mehr benötigt. Daten werden unter der neuen Objekt ID 0_userdata.0.Charge_Control.History.PrognoseSolcast90_kWh gespeichert.
                                      • Alle Objekt ID's PrognoseSolcast_kWh_1 bis 31 werden nicht mehr benötigt. Daten werden unter der neuen Objekt ID 0_userdata.0.Charge_Control.History.PrognoseSolcast_kWh gespeichert.
                                        MaLei
                                        #2625
                                        wie upgrade ich eigentlich auf eine neue Charge Control Version?
                                        Meine Version (1.3.1) läuft seit längerer Zeit sehr gut und ich möchte sie mir nicht "zerstören", indem ich einfach die aktuelle drüber kopiere.
                                        MaLei
                                        • M MaLei
                                          MaLei
                                          ArnoD
                                          #2626
                                          @malei
                                          Das Script ChargeControl 1.3.1 kannst du dir ja vorher in eine txt Datei sichern und dann durch die neue Version austauschen.
                                          Um eine saubere Installation zu haben, würde ich folgendermaßen vorgehen:
                                          Im Reiter Skripte das Skript ChargeControl stoppen, öffnen und alles löschen und die neue Version einfügen.
                                          Wenn du im ersten Teil "USER ANPASSUNGEN" vom Skript Änderungen durchgeführt hast, musst du diese auch in der neuen Version machen (wenn du das alte Script in eine txt Datei gesichert hast, kannst du dir die Zeilen mit Copy Paste eintragen).
                                          Vor dem Skript Start dann die Werte der Objekte 0_userdata.0.Charge_Control.History.HistoryJSON und 0_userdata.0.Charge_Control.History.HistoryJSON_01 bis 12 in eine txt Datei kopieren um diese nachher wieder herstellen zu können (außer du benötigst die alten PV Prognosen nicht und startest mit dem Diagramm neu).
                                          Von den 0_userdata.0.Charge_Control.USER_ANPASSUNGEN und 0_userdata.0.Charge_Control.Parameter würde ich nur ein Screenshot machen, um diese nachher wieder eintragen zu können.
                                          Danach alle Objekte 0_userdata.0.Charge_Control löschen und das Script einmal starte und die neuen Objekte erstellen lassen, danach das Script wieder stoppen und die 0_userdata.0.Charge_Control.USER_ANPASSUNGEN und 0_userdata.0.Charge_Control.Parameter alle Werte vom Screenshot wieder eintragen. Bei den Objekten 0_userdata.0.Charge_Control.History.HistoryJSON_01 bis 12 die Werte aus der txt Datei wieder kopieren und einfügen.
                                          Wenn du heute noch abwartest, kannst du die Version 1.5.0 von Github installieren und wärst somit auf dem neusten Stand.
