  4. [gelöst] VIS-2 Start über Instanzlink nicht möglich
    6.0k
31 Beiträge 7 Kommentatoren 5.1k Aufrufe 7 Beobachtet
  • M MCU
    Ich habe VIS-2 hinzugefügt kann aber die VIS nicht starten über den Instanz-Link.
    Das zugehörige LOG ist sehr kurz, obwohl debug eingeschaltet.
    vis-2.0
    2024-07-26 00:21:10.862	info	vis-2 license is OK.
    vis-2.0
    2024-07-26 00:21:10.650	info	starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.16.0, js-controller: 5.0.19
    vis-2.0
    2024-07-26 00:21:10.542	debug	Plugin sentry Initialize Plugin (enabled=true)
    iob diag
    Skript v.2024-05-22
    *** BASE SYSTEM ***
     Static hostname: iobrokerPROD
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.8-3-pve
        Architecture: x86-64
    model name      : 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     00:24:42 up  1:09,  2 users,  load average: 1.35, 1.20, 1.17
    CPU threads: 6
    *** Time and Time Zones ***
                   Local time: Fri 2024-07-26 00:24:42 CEST
               Universal time: Thu 2024-07-25 22:24:42 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    prox
    HOME=/home/prox
    GROUPS=prox adm sudo iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            8.6G        3.2G        4.5G        131K        980M        5.4G
    Swap:           536M          0B        536M
    Total:          9.1G        3.2G        5.0G
    Active iob-Instances:   47
             8192 M total memory
             3005 M used memory
             3019 M active memory
              746 M inactive memory
             4250 M free memory
                0 M buffer memory
              935 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 00:24:42 up  1:10,  2 users,  load average: 1.32, 1.20, 1.17
    Tasks:  77 total,   1 running,  76 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   4248.8 free,   3007.7 used,    935.7 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5184.3 avail Mem
    *** FAILED SERVICES ***
      UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
    * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
    3 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--150--disk--0 ext4       30G   15G   14G  52% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs   16G     0   16G   0% /dev/tty
    /dev/mapper/pve-root             ext4       94G   29G   61G  33% /mnt/windows
    tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
    tmpfs                            tmpfs     6.2G  124K  6.2G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     3.1G     0  3.1G   0% /run/user/1001
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems:
    TARGET                                                  SOURCE                                  FSTYPE     OPTIONS
    /                                                       /dev/mapper/pve-vm--150--disk--0        ext4       rw,relatime,stripe=16
    |-/run                                                  tmpfs                                   tmpfs      rw,nosuid,nodev,size=6497012k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
    | |-/run/lock                                           tmpfs                                   tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
    | |-/run/user/1001                                      tmpfs                                   tmpfs      rw,nosuid,nodev,relatime,size=3248504k,nr_inodes=812126,mode=700,uid=101001,gid=101001,inode64
    | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                                   ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-sysctl.service             ramfs                                   ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-sysusers.service           ramfs                                   ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    | `-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                                   ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
    |-/dev                                                  none                                    tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/dev/shm                                            tmpfs                                   tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
    | |-/dev/mqueue                                         mqueue                                  mqueue     rw,nosuid,nodev,noexec,relatime
    | |-/dev/ttyUSB0                                        udev[/ttyUSB0]                          devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
    | |-/dev/.lxc/proc                                      proc                                    proc       rw,relatime
    | |-/dev/.lxc/sys                                       sys                                     sysfs      rw,relatime
    | |-/dev/full                                           udev[/full]                             devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
    | |-/dev/null                                           udev[/null]                             devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
    | |-/dev/random                                         udev[/random]                           devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
    | |-/dev/tty                                            udev[/tty]                              devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
    | |-/dev/urandom                                        udev[/urandom]                          devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
    | |-/dev/zero                                           udev[/zero]                             devtmpfs   rw,nosuid,relatime,size=16208696k,nr_inodes=4052174,mode=755,inode64
    | |-/dev/pts                                            devpts                                  devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/ptmx                                           devpts[/ptmx]                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/console                                        devpts[/0]                              devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/tty1                                           devpts[/1]                              devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | `-/dev/tty2                                           devpts[/2]                              devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    |-/proc                                                 proc                                    proc       rw,nosuid,nodev,noexec,relatime
    | |-/proc/sys                                           proc[/sys]                              proc       ro,relatime
    | | |-/proc/sys/net                                     proc[/sys/net]                          proc       rw,nosuid,nodev,noexec,relatime
    | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]                     tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]                    proc       ro,relatime
    | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/diskstats                                     lxcfs[/proc/diskstats]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/loadavg                                       lxcfs[/proc/loadavg]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/meminfo                                       lxcfs[/proc/meminfo]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]                   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/stat                                          lxcfs[/proc/stat]                       fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/swaps                                         lxcfs[/proc/swaps]                      fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | `-/proc/uptime                                        lxcfs[/proc/uptime]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/sys                                                  sysfs                                   sysfs      ro,nosuid,nodev,noexec,relatime
    | |-/sys/fs/fuse/connections                            fusectl                                 fusectl    rw,nosuid,nodev,noexec,relatime
    | |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]             sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                                      none                                    cgroup2    rw,nosuid,nodev,noexec,relatime
    | `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/mnt/windows                                          /dev/mapper/pve-root[/mnt/pve/windows]  ext4       rw,relatime,errors=remount-ro
    `-/mnt/nas                                              /dev/mapper/pve-root[/mnt/pve/fritznas] ext4       rw,relatime,errors=remount-ro
    /var:
    1.5G    /var/
    1.2G    /var/log/journal/69ffeed97a1945f88a51d8df571b2606
    1.2G    /var/log
    155M    /var/lib
    Archived and active journals take up 1.1G in the file system.
    /opt/iobroker/backups:
    451M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.3G    /opt/iobroker/iobroker-data/
    926M    /opt/iobroker/iobroker-data/files
    299M    /opt/iobroker/iobroker-data/files/javascript.admin
    265M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    264M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    87M     /opt/iobroker/iobroker-data/states.jsonl
    38M     /opt/iobroker/iobroker-data/objects.jsonl
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.16.0
    /usr/bin/node           v20.16.0
    /usr/bin/npm            10.8.1
    /usr/bin/npx            10.8.1
    /usr/bin/corepack       0.28.2
    nodejs:
      Installed: 20.16.0-1nodesource1
      Candidate: 20.16.0-1nodesource1
      Version table:
     *** 20.16.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://ftp.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    admin:          7.0.19
    javascript:     8.6.0
    nodejs modules from github:     4
    +-- iobroker.alexa2@3.26.5 (git+ssh://git@github.com/Apollon77/ioBroker.alexa2.git#37160cf729a9c70ca70679d4b1d3c16ba51c6456)
    +-- iobroker.hue-extended@2.0.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.hue-extended.git#f3d1d9187fbc9bcdde5c39c1fbc80371ec7941f2)
    +-- iobroker.jarvis@3.2.0-beta.47 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#b2aa6c5e163660c5447353ff595b6d93441915cd)
    +-- iobroker.meross@1.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.meross.git#31fe999d84e17f0c79b2c5243f8227776035c718)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobrokerPROD                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobrokerPROD                             -  enabled
    + system.adapter.backitup.0               : backitup              : iobrokerPROD                             -  enabled
      system.adapter.birthdays.0              : birthdays             : iobrokerPROD                             - disabled
    + system.adapter.bring.0                  : bring                 : iobrokerPROD                             -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : iobrokerPROD                             -  enabled
    + system.adapter.cameras.0                : cameras               : iobrokerPROD                             -  enabled, port: 8200, bind: 127.0.0.1
    + system.adapter.chromecast.0             : chromecast            : iobrokerPROD                             -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobrokerPROD                             -  enabled
      system.adapter.daswetter.0              : daswetter             : iobrokerPROD                             -  enabled
      system.adapter.devices.0                : devices               : iobrokerPROD                             -  enabled
    + system.adapter.discovery.0              : discovery             : iobrokerPROD                             -  enabled
      system.adapter.dwd.0                    : dwd                   : iobrokerPROD                             - disabled
    + system.adapter.echarts.0                : echarts               : iobrokerPROD                             -  enabled
    + system.adapter.email.0                  : email                 : iobrokerPROD                             -  enabled
    + system.adapter.fahrplan.0               : fahrplan              : iobrokerPROD                             -  enabled
      system.adapter.flot.0                   : flot                  : iobrokerPROD                             -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobrokerPROD                             -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobrokerPROD                             -  enabled
    + system.adapter.history.0                : history               : iobrokerPROD                             -  enabled
    + system.adapter.hue-extended.0           : hue-extended          : iobrokerPROD                             -  enabled
      system.adapter.hue.0                    : hue                   : iobrokerPROD                             - disabled, port: 443
      system.adapter.ical.0                   : ical                  : iobrokerPROD                             -  enabled
    + system.adapter.info.0                   : info                  : iobrokerPROD                             -  enabled
    + system.adapter.iot.0                    : iot                   : iobrokerPROD                             -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobrokerPROD                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.jarvis.1                 : jarvis                : iobrokerPROD                             -  enabled
    + system.adapter.jarvis.2                 : jarvis                : iobrokerPROD                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : iobrokerPROD                             -  enabled
      system.adapter.javascript.1             : javascript            : iobrokerPROD                             - disabled
      system.adapter.meross.0                 : meross                : iobrokerPROD                             - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobrokerPROD                             -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.notificationforandroidtv.0: notificationforandroidtv: iobrokerPROD                             -  enabled
    + system.adapter.onvif.0                  : onvif                 : iobrokerPROD                             -  enabled, port: 8000
    + system.adapter.onvif.1                  : onvif                 : iobrokerPROD                             -  enabled, port: 8000
      system.adapter.pegelalarm.0             : pegelalarm            : iobrokerPROD                             -  enabled
    + system.adapter.ping.0                   : ping                  : iobrokerPROD                             -  enabled
      system.adapter.proxy.0                  : proxy                 : iobrokerPROD                             -  enabled
    + system.adapter.pushover.0               : pushover              : iobrokerPROD                             -  enabled
    + system.adapter.rest-api.0               : rest-api              : iobrokerPROD                             -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.rssfeed.0                : rssfeed               : iobrokerPROD                             -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobrokerPROD                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.snmp.0                   : snmp                  : iobrokerPROD                             -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobrokerPROD                             -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.spotify-premium.0        : spotify-premium       : iobrokerPROD                             - disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobrokerPROD                             -  enabled
    + system.adapter.telegram.0               : telegram              : iobrokerPROD                             -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobrokerPROD                             -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : iobrokerPROD                             -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.tr-064.0                 : tr-064                : iobrokerPROD                             -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobrokerPROD                             -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : iobrokerPROD                             -  enabled
      system.adapter.twinkly.0                : twinkly               : iobrokerPROD                             - disabled
    + system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobrokerPROD                             -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobrokerPROD                             -  enabled
    + system.adapter.web.0                    : web                   : iobrokerPROD                             -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.1                    : web                   : iobrokerPROD                             -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.wifilight.0              : wifilight             : iobrokerPROD                             -  enabled
    + system.adapter.wled.0                   : wled                  : iobrokerPROD                             -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobrokerPROD                             -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 7.0.19   , installed 7.0.19
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.10   , installed 3.0.10
    Adapter    "birthdays"    : 3.0.1    , installed 3.0.1
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "cameras"      : 2.1.2    , installed 2.1.2
    Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "echarts"      : 1.8.4    , installed 1.8.4
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "fullybrowser" : 3.0.12   , installed 2.2.0  [Updatable]
    Adapter    "hue"          : 3.12.0   , installed 3.12.0
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.2.0-beta.47
    Adapter    "javascript"   : 8.7.3    , installed 8.6.0  [Updatable]
    Controller "js-controller": 6.0.9    , installed 5.0.19 [Updatable]
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mqtt"         : 6.0.0    , installed 6.0.0
    Adapter    "notificationforandroidtv": 3.0.4, installed 3.0.4
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "pushover"     : 4.0.0    , installed 4.0.0
    Adapter    "reolink"      : 1.1.0    , installed 1.1.0
    Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
    Adapter    "rssfeed"      : 3.0.0    , installed 3.0.0
    Adapter    "snmp"         : 3.2.0    , installed 3.2.0
    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
    Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "tibberlink"   : 3.4.3    , installed 3.4.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
    Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
    Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "web"          : 6.3.0    , installed 6.3.0
    Adapter    "wifilight"    : 1.2.2    , installed 1.2.2
    Adapter    "wled"         : 0.7.3-beta.0, installed 0.7.2 [Updatable]
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        27922
    States:         22122
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://ftp.debian.org/debian bookworm InRelease
    Hit:3 http://ftp.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1002       2908608    586/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       2909656    409/io.sonoff.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          2919832    1334/master
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2899893    1/init
    tcp        0      0 127.0.0.1:8200          0.0.0.0:*               LISTEN      1002       2923868    1649/io.cameras.0
    tcp        0      0 0.0.0.0:8402            0.0.0.0:*               LISTEN      1002       2927763    1871/io.jarvis.2
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1002       2916360    725/io.jarvis.0
    tcp        0      0 0.0.0.0:8401            0.0.0.0:*               LISTEN      1002       2923337    1810/io.jarvis.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       2903826    155/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       2904576    155/iobroker.js-con
    tcp6       0      0 :::8087                 :::*                    LISTEN      1002       2920853    1474/io.simple-api.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1002       2912107    683/io.web.0
    tcp6       0      0 :::8083                 :::*                    LISTEN      1002       2927793    1892/io.web.1
    tcp6       0      0 :::8081                 :::*                    LISTEN      1002       2896741    181/io.admin.0
    tcp6       0      0 :::8093                 :::*                    LISTEN      1002       2923142    1740/io.rest-api.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1002       2917396    745/io.terminal.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          2899895    1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          2904527    1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          2919833    1334/master
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1002       2912479    502/io.broadlink2.0
    udp        0      0 0.0.0.0:48534           0.0.0.0:*                           1002       2911519    480/io.snmp.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2899894    1/init
    udp        0      0 0.0.0.0:50201           0.0.0.0:*                           1002       2912482    502/io.broadlink2.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       2922591    1564/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       2913302    606/io.chromecast.0
    udp        0      0 0.0.0.0:57664           0.0.0.0:*                           1002       2912481    502/io.broadlink2.0
    udp        0      0 0.0.0.0:42730           0.0.0.0:*                           1002       2912483    502/io.broadlink2.0
    udp6       0      0 :::111                  :::*                                0          2899896    1/init
    2024-07-26 00:21:07.161  - info: host.iobrokerPROD stopInstance system.adapter.vis-2.0 send kill signal
    2024-07-26 00:21:07.558  - info: vis-2.0 (15962) terminating
    2024-07-26 00:21:07.588  - info: host.iobrokerPROD instance system.adapter.vis-2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-07-26 00:21:10.196  - info: host.iobrokerPROD instance system.adapter.vis-2.0 started with pid 17036
    2024-07-26 00:21:10.384  - debug: vis-2.0 (17036) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-07-26 00:21:10.405  - debug: vis-2.0 (17036) Objects client ready ... initialize now
    2024-07-26 00:21:10.405  - debug: vis-2.0 (17036) Objects create System PubSub Client
    2024-07-26 00:21:10.406  - debug: vis-2.0 (17036) Objects create User PubSub Client
    2024-07-26 00:21:10.439  - debug: vis-2.0 (17036) Objects client initialize lua scripts
    2024-07-26 00:21:10.441  - debug: vis-2.0 (17036) Objects connected to redis: 127.0.0.1:9001
    2024-07-26 00:21:10.459  - debug: vis-2.0 (17036) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-07-26 00:21:10.469  - debug: vis-2.0 (17036) States create System PubSub Client
    2024-07-26 00:21:10.469  - debug: vis-2.0 (17036) States create User PubSub Client
    2024-07-26 00:21:10.527  - debug: vis-2.0 (17036) States connected to redis: 127.0.0.1:9000
    2024-07-26 00:21:10.542  - debug: vis-2.0 (17036) Plugin sentry Initialize Plugin (enabled=true)
    2024-07-26 00:21:10.650  - info: vis-2.0 (17036) starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.16.0, js-controller: 5.0.19
    2024-07-26 00:21:10.862  - info: vis-2.0 (17036) vis-2 license is OK.
    2024-07-26 00:21:27.605  - info: javascript.0 (208) script.js.HUE-EXTENDED.HUE-NEWAPI: running  function after change of hue-extended.0.lights.001-lampe_tisch.action.level
    2024-07-26 00:21:58.530  - info: javascript.0 (208) script.js.HUE-EXTENDED.HUE-NEWAPI: missing update instructions for scenes.status.status
    2024-07-26 00:21:58.530  - info: javascript.0 (208) script.js.HUE-EXTENDED.HUE-NEWAPI: {"status":{"status":{"active":"inactive"}}}
    2024-07-26 00:22:24.221  - info: javascript.0 (208) script.js.HUE-EXTENDED.HUE-NEWAPI: missing update instructions for scenes.status.status
    2024-07-26 00:22:24.221  - info: javascript.0 (208) script.js.HUE-EXTENDED.HUE-NEWAPI: {"status":{"status":{"active":"static"}}}
    2024-07-26 00:22:24.273  - info: javascript.0 (208) script.js.HUE-EXTENDED.HUE-NEWAPI: running  function after change of hue-extended.0.lights.001-lampe_tisch.action.level
    2024-07-26 00:23:18.639  - info: fahrplan.0 (1825) Updated 1 routes, 1 enabled and 0 disabled
    2024-07-26 00:23:18.936  - info: fahrplan.0 (1825) Updated 1 departure timetables, 1 enabled and 0 disabled
    Was kann ich tun? Wo muss ich ansetzen?
    Vielen Dank
    EDIT:
    Schau ich in die Übersicht dann sehe ich die Kacheln
    und kann diese auch nutzen.
    Welche Kachel soll man denn nutzen?
    Visualisierung Next Generation (sehr wahrscheinlich) für die Entwicklung
    Wofür hat man die "RunTime"-Kacheln? Um direkt ein fertiges Projekt zu starten?
    sigi234S Online
    sigi234S Online
    @mcu
    Ja da stimmt was nicht:
    Ist seit Heute so, gestern ging es noch.
    Ev. hat es was mit den Updatest zu tun?
    Admin:7.0.19
    JS-Controller: 6.0.9
    Node.js: v20.16.0
    NPM: 10.8.1
    • sigi234S sigi234
      @mcu
      Admin:7.0.19
      Node.js: v20.16.0
      NPM: 10.8.1
      arteckA Offline
      arteckA Offline
      arteck
      @sigi234 das wird am Admin liegen
      • arteckA arteck
        MCU
        @arteck Habe ein Issue eröffnet.
        https://github.com/ioBroker/ioBroker.admin/issues/2570
        Bernd1967B 1 Antwort Letzte Antwort
        • M MCU
          Bernd1967B Offline
          Bernd1967B Offline
          Bernd1967
          @MCU
          Hatte Gestern auch mal zum testen vis-2 Adapter installiert.
          Hier funktioniert es mit beiden Instanz Link (vis und vis-2)
          Könnte es vielleicht mit HTTPS zusammenhängen ?
          Ich benutzte weiterhin unverschlüsselte Verbindung.
          Oder Browser cache löschen ?
          Fehler in der Konsole ?
          Admin:7.0.19
          Node.js: v20.16.0
          NPM: 10.8.1
          Bernd1967B M 2 Antworten Letzte Antwort
          • Bernd1967B Bernd1967
            @MCU
            Admin:7.0.19
            Node.js: v20.16.0
            NPM: 10.8.1
            Bernd1967B Offline
            Bernd1967B Offline
            Bernd1967
            schrieb am zuletzt editiert von Bernd1967
            Was mir noch aufgefallen ist das bei mir der vis-2 Adapter die selbe Portnummer hat wie der vis Adapter.
            Bei Euch ist eine ander Portnummer.
            vis Link:
            http://xxx.xxx.xxx:8082/vis/edit.html#DemoView
            vis-2 Link:
            http://xxx.xxx.xxx:8082/vis-2/edit.html#DemoView
            • M MCU
              vis-2.0
              vis-2.0
              vis-2.0
              iob diag
              Skript v.2024-05-22
              *** BASE SYSTEM ***
                Virtualization: lxc
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 6
                               RTC time: n/a
                        RTC in local TZ: no
              prox
              HOME=/home/prox
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           536M          0B        536M
                       8192 M total memory
                       3005 M used memory
                       4250 M free memory
                          0 M buffer memory
                        935 M swap cache
                        512 M total swap
                          0 M used swap
                        512 M free swap
              *** FILESYSTEM ***
              /var:
              1.5G    /var/
              1.2G    /var/log
              155M    /var/lib
              USB-Devices by-id:
              HINT:
              /dev/ttyUSB0
              /usr/bin/npm            10.8.1
              /usr/bin/npx            10.8.1
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          7.0.19
              javascript:     8.6.0
              Adapter State
              + instance is alive
              Objects and States
              Objects:        27922
              States:         22122
              Pending Updates: 3
              Vielen Dank
              EDIT:
              Bernd1967B Offline
              Bernd1967B Offline
              Bernd1967
              @mcu sagte in VIS-2 Start über Instanzlink nicht möglich Voraussetzungen?:
              Korrekt, bei mir öffnet sich dann die DemoView
                vis Link:
                vis-2 Link:
                MCU
                @bernd1967 Die unterschiedlichen Port nummern kommen von den Web-Instanzen.
                Das könnte aber der Grund sein, dafür das der Instanzlink nicht funktioniert?
                Da mehrere Web-Instanzen vorhanden sind, weiß er nicht welche er nehmen soll?
                  @MCU
                  Admin:7.0.19
                  Node.js: v20.16.0
                  NPM: 10.8.1
                  MCU
                  @bernd1967 Cache gelöscht bringt aber nichts. Instanz-Links funktionieren nicht.
                  • M MCU
                    sigi234S Online
                    sigi234S Online
                    Nein, habe auch mehrere Web Instanzen und es hat bis gestern immer funktioniert
                    • sigi234S sigi234
                      MCU
                      @sigi234 Hatte man nicht früher eine Auswahl, wenn man drauf geklickt, welche Web-Instanz man nutzen möchte?
                      sigi234S 2 Antworten Letzte Antwort
                      • M MCU
                        sigi234S Online
                        sigi234S Online
                        Ja
                        • sigi234S sigi234
                          Ja
                          Bernd1967B Offline
                          Bernd1967B Offline
                          Bernd1967
                          Wenn ich versuche eine zweite Instanz vom vis-2 Adapter hinzuzufügen kommt folgender Fehler:
                          ERROR: Process exited with code 19
                          $ iobroker add vis-2 auto --host Server(SmartHome) --debug
                          host.Server(SmartHome) error: this adapter does not allow multiple instances
                            MCU
                            @bernd1967 Ich habe keine 2. VIS-2- Instanz sondern eine 2. WEB-Instanz
                              HomoranH Offline
                              HomoranH Offline
                              @bernd1967 sagte in VIS-2 Start über Instanzlink nicht möglich Voraussetzungen?:
                              klar doch!
                              Das tut man ja auch nicht.
                                klar doch!
                                Bernd1967B Offline
                                Bernd1967B Offline
                                Bernd1967
                                Hab ich mir gedacht :-) aktuell kann ich mit Admin 7 aber auch keine zweite web Instanz hinzufügen.
                                Aber dafür gibt es auf Github schon ein Issue....
                                • M MCU
                                  sigi234S Online
                                  sigi234S Online
                                  Hallo, bin mal auf die Stable vom Admin gegangen, gleicher Fehler.
                                  Doch kein Admin Problem? JS-Controller?
                                  • sigi234S sigi234
                                    Bernd1967B Offline
                                    Bernd1967B Offline
                                    Bernd1967
                                    Mit Admin 7.0.21 funktioniert das hinzufügen wieder.
                                    Vielleicht gehts dann auch mit dem Instanz LInk bei Euch ?
                                      MCU
                                      @bernd1967 Nein, keine Änderung.
                                      • wendy2702W Offline
                                        wendy2702W Offline
                                        Könnt ihr mal schauen ob es nur der VIS2 Instanz Link ist?
                                        Bei mir gehen schon seit längerem diverse nicht mehr
                                        • wendy2702W wendy2702
                                          Hier funktionieren alle Instanzlinks. Inklusive vis2. Da komme ich auf den Editor.
