  4. Node-Red
  5. PAJ GPS mit Node-Red abfragen
    6.0k
153 Beiträge 6 Kommentatoren 29.4k Aufrufe 6 Beobachtet
  • NegaleinN Negalein
    @mickym sagte in PAJ GPS mit Node-Red abfragen:
    Ich würde mal "iob diag" laufen lassen.
    hab ich vorhin gemacht.
    Da passt alles.
    Na in meinen Augen hilft das nicht, wenn was schief hängt.
    hat geholfen ;)
    nega@ioBroker:/opt/iobroker$ iobroker install node-red
    NPM version: 10.7.0
    Installing iobroker.node-red@5.2.1... (System call)
    added 186 packages, and changed 8 packages in 30s
    458 packages are looking for funding
      run `npm fund` for details
    host.ioBroker install adapter node-red
    upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/jsonConfig.json jsonConfig.json application/json
    upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
    host.ioBroker object system.adapter.node-red created/updated
    nega@ioBroker:/opt/iobroker$ iobroker add node-red
    host.ioBroker create instance node-red
    host.ioBroker object system.adapter.node-red.0.alive created
    host.ioBroker object system.adapter.node-red.0.connected created
    host.ioBroker object system.adapter.node-red.0.compactMode created
    host.ioBroker object system.adapter.node-red.0.cpu created
    host.ioBroker object system.adapter.node-red.0.cputime created
    host.ioBroker object system.adapter.node-red.0.memHeapUsed created
    host.ioBroker object system.adapter.node-red.0.memHeapTotal created
    host.ioBroker object system.adapter.node-red.0.memRss created
    host.ioBroker object system.adapter.node-red.0.uptime created
    host.ioBroker object system.adapter.node-red.0.inputCount created
    host.ioBroker object system.adapter.node-red.0.outputCount created
    host.ioBroker object system.adapter.node-red.0.eventLoopLag created
    host.ioBroker object system.adapter.node-red.0.sigKill created
    host.ioBroker object system.adapter.node-red.0.logLevel created
    host.ioBroker object node-red.0.info created
    host.ioBroker object node-red.0.info.connection created
    host.ioBroker Set default value of node-red.0.info.connection: false
    host.ioBroker object system.adapter.node-red.0 created
    Dann würde ich das Repository wieder auf default umstellen. Bei dem latest hast Du halt ggf. auch Adapter im Beta Stadium dabei.
    Yes, das ist mir bewusst und so gewollt ;)
    Wie gesagt jeder Adapter der installiert wird, schreibt was in das Log.
    mir ist was in Erinnerung, dass solche Probleme öfter mal von Usern berichtet wurden.
    Muss mal das Forum durchforsten.
    Du bist doch schon ein iobroker-Veteran 😉 - Du solltest doch mitbekommen, wie oft bei Leuten das System oft schief hängt, wenn sich Adapter nicht installieren lassen (unabhängig von der Art des Adapters).
    Ja, bald ein halbes Jahrhundert ;) Und schon lange (mit 2 Anläufen) hier.
    Ich denke, das PAJ-Projekt gehn wir dann morgen mal an. :)
    mickymM Offline
    mickymM Offline
    mickym
    @negalein Ok - Super. - Also der Adapter läuft nun?
    • mickymM mickym
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      Ja, ich komm auf die Konfig, aber NR bleibt weiß (bei klick in der linken Leiste) und über die Kachel in Übersicht macht er àbout:blank` auf.
      node-red.0
      2024-07-04 23:30:21.930	warn	Node-RED: 4 Jul 23:30:21 - [warn] Projects disabled : editorTheme.projects.enabled=false
      node-red.0
      2024-07-04 23:30:19.706	info	Node-RED started successfully (PID: 3015936)
      node-red.0
      2024-07-04 23:30:19.700	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      node-red.0
      2024-07-04 23:30:18.471	warn	Cannot enable the dynamic object read as admin has authentication
      node-red.0
      2024-07-04 23:30:18.430	info	Requested NPM packages: []
      node-red.0
      2024-07-04 23:30:18.349	info	starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.14.0, js-controller: 5.0.19
      node-red.0
      2024-07-04 23:30:14.255	info	terminating
      node-red.0
      2024-07-04 23:30:13.756	info	Terminated (NO_ERROR): Without reason
      node-red.0
      2024-07-04 23:30:13.756	info	terminating
      node-red.0
      2024-07-04 23:30:13.751	info	cleaned everything up...
      node-red.0
      2024-07-04 23:30:08.760	info	Node-RED exited with 0
      node-red.0
      2024-07-04 23:30:08.748	info	kill node-red task
      node-red.0
      2024-07-04 23:16:50.577	warn	Node-RED: 4 Jul 23:16:50 - [warn] Projects disabled : editorTheme.projects.enabled=false
      node-red.0
      2024-07-04 23:16:48.523	info	Node-RED started successfully (PID: 3015593)
      node-red.0
      2024-07-04 23:16:48.520	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      node-red.0
      2024-07-04 23:16:47.204	warn	Cannot enable the dynamic object read as admin has authentication
      node-red.0
      2024-07-04 23:16:47.166	info	Requested NPM packages: []
      node-red.0
      2024-07-04 23:16:47.085	info	starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.14.0, js-controller: 5.0.19
      admin.0
      2024-07-04 23:35:47.829	warn	node-red has an invalid jsonConfig: [{"instancePath":"/items/_authentication/items/authExt/items/2","schemaPath":"#/items/allOf/35/then/allOf/1/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"width"},"message":"must NOT have additional properties"},{"instancePath":"/items/_authentication/items/authExt","schemaPath":"#/patternProperties/%5E.%2B/allOf/23/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/_authentication","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
      ° Fixer ---> iob fix
      • NegaleinN Offline
        NegaleinN Offline
        Negalein
        mit manueller Eingabe von IP:Port funktionierts.
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          node-red.0
          admin.0
          mickymM Offline
          mickymM Offline
          mickym
          @negalein Hmm
          da scheinst Du irgendeine Art Authentifizierung im iobroker zu haben.
          Schau mal ob Du node-red direkt im Browser aufmachen kannst.
          Ich geh mal davon aus, dass Dein iobroker die IP 10.0.1.202 hat.
          Dann solltest Du Node-Red mit
          http://10.0.1.202:1880
          öffnen können
            mickymM Offline
            mickymM Offline
            mickym
            @negalein sagte in PAJ GPS mit Node-Red abfragen:
            Ah dann haben sich unsere Posts überschnitten. Wie gesagt - irgendwas an Deinem iobroker hängt schief, aber über den Browser können wir ja morgen dann auch arbeiten.
            Du scheinst aber schon irgendwelche Flows da drin zu haben - also hattest Du nochwas in deinem
            Verzeichnis.
            Wenn Du die Flows nicht brauchst, dann lösch die Flows am Besten.
            • mickymM mickym
              Verzeichnis.
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              ich forsch noch etwas weiter.
              Bis Morgen
              Gn8 🛌
              mickymM OliverIOO 2 Antworten Letzte Antwort
                Bis Morgen
                Gn8 🛌
                mickymM Offline
                mickymM Offline
                mickym
                Bis Morgen
                Gn8 🛌
                Jo schlaf gut - und wie gesagt - die Flows würde ich löschen - das sind noch Reste von einer vergangenen Installation.
                  Bis Morgen
                  Gn8 🛌
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  mach mal
                  iob upload all
                  auf der console
                  Meine Adapter und Widgets
                  Links im Profil
                  • OliverIOO OliverIO
                    mach mal
                    iob upload all
                    auf der console
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    @oliverio sagte in PAJ GPS mit Node-Red abfragen:
                    iob upload all
                    bleibt so.
                    In der Kachel ist httpundefined://10.0.1.202:1880/ hinterlegt.
                    Das lässt sich nicht ändern. :(
                    • NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      @mickym
                      @OliverIO
                      Sorry für die Abwesenheit.
                      Hatte Stress mit der Kleinen.
                      NR läuft nun (mit direkter URL im Browser; über IOB selbes wie gestern (trotz Reboot, Fix, Deinstall, usw.).
                      Dazu mach ich demnächst einen eigenen Thread auf.
                      Hier nun zum PAJ die Links
                      Login: https://connect.paj-gps.de/api/v1/login?email=christian%40xxxxxxxx.xx&password=xxxxxxxx
                        "success": {
                          "token": "xxxxxxxxxxxxxxxxxxxx",
                          "refresh_token": "xxxxxxxxxxxxxxxxxxxx",
                          "expires_in": 2592000,
                          "isAdmin": 0,
                          "userID": xxxxxxxxxx,
                          "routeIcon": "arrow",
                          "Petsevices": 0
                      Tracking Data: https://connect.paj-gps.de/api/v1/trackerdata/---ID---/last_points?lastPoints=1&gps=1&wifi=0
                      hier der letzte GPS-Standort
                        "success": [
                            "id": "xxxxxxxxxxxxx",
                            "lat": xx.xxxxx,
                            "lng": xx.xxxxx,
                            "direction": 0,
                            "dateunix": 1720124721,
                            "battery": 100,
                            "speed": 0,
                            "iddevice": xxxxxxxxxx,
                            "steps": 0,
                            "heartbeat": 0,
                            "accuracy": 0,
                            "wifi": null,
                            "note": null,
                            "upt": null
                        "number_of_correct_markers": 1,
                        "faulty_markers": [],
                        "number_of_faulty_markers": 0,
                        "distance": 0
                      • mickymM Offline
                        mickymM Offline
                        mickym
                        Also wenn Du wieder da bist, dann können wir ja mal einen Versuch wagen.
                        Die Doku der API ist ja hier: https://connect.paj-gps.de/api/documentation
                          @mickym
                          @OliverIO
                            "success": {
                              "isAdmin": 0,
                              "Petsevices": 0
                            "success": [
                                "lat": xx.xxxxx,
                                "lng": xx.xxxxx,
                                "direction": 0,
                                "battery": 100,
                                "speed": 0,
                                "steps": 0,
                                "heartbeat": 0,
                                "accuracy": 0,
                                "wifi": null,
                                "note": null,
                                "upt": null
                            "distance": 0
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          @negalein
                          hast du in node-red schon einen request durchführen können?
                          du kannst ja mal den folgenden flow mal als lernbasis verwenden.
                          einfach den inhalt kopieren und im burgermenü von node-red oben rechts auf import gehen und als neuen flow importieren.
                          danach auf Übernahme/deploy drücken (muss man bei jeder Änderung machen.
                          Danach kannst du den kleinen Knopf rechts der ersten Inject node drücken. das startet diesen Flow manuell. Das Ergebnis der debug-node kannst du rechts unterhalb des Burger menüs durch druck auf das Käfersymbol dann sehen.
                          Der Flow ruft mal eine Beispiel API ab und ruft Beispielobjekte (irgendwelche Filmfiguren) ab.
                          Eine node kann man dann durch Doppelklick auf einer node konfigurieren. Also bei dir dann bei http-request..
                          Die automatisierung mit iobroker machen wir dann später. erst muss die Kernfunktionalität funktionieren.
                          wenn du eine node konfigurierst und rechts neben dem käfersymbol auf das buch icon klickst, siehst du die hilfe für die ausgewählte node
                                  "id": "366db1589150b476",
                                  "type": "tab",
                                  "label": "Flow 3",
                                  "disabled": false,
                                  "info": "",
                                  "env": []
                                  "id": "e8c8fbba21beb8a4",
                                  "type": "http request",
                                  "z": "366db1589150b476",
                                  "name": "",
                                  "method": "GET",
                                  "ret": "obj",
                                  "paytoqs": "body",
                                  "url": "https://api.sampleapis.com/futurama/characters",
                                  "tls": "",
                                  "persist": false,
                                  "proxy": "",
                                  "insecureHTTPParser": false,
                                  "authType": "",
                                  "senderr": false,
                                  "headers": [],
                                  "x": 410,
                                  "y": 120,
                                  "wires": [
                                          "8118e4eac98c67a6"
                                  "id": "8118e4eac98c67a6",
                                  "type": "debug",
                                  "name": "debug",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "complete": "payload",
                                  "targetType": "msg",
                                  "statusVal": "",
                                  "statusType": "auto",
                                  "x": 570,
                                  "y": 120,
                                  "wires": []
                                  "id": "f3570f56bea9a4eb",
                                  "type": "inject",
                                  "name": "",
                                  "props": [
                                          "p": "topic",
                                          "vt": "str"
                                  "repeat": "",
                                  "crontab": "",
                                  "once": false,
                                  "onceDelay": 0.1,
                                  "topic": "",
                                  "x": 250,
                                  "y": 120,
                                  "wires": [
                                          "e8c8fbba21beb8a4"
                          Links im Profil
                          • mickymM mickym
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            bin da, aber eventuell bald stromlos wegen Gewitter.
                            daraus hab ich mir die obigen 2 Abfragen erstellt.
                            Ok, den http request hab ich so.
                            Da kommt dann nur
                            6.7.2024, 17:19:25node: e8c8fbba21beb8a4
                            msg : string[16]
                            "JSON parse error"
                            6.7.2024, 17:19:25node: debug
                            msg.payload : string[1009]
                            <!DOCTYPE html>
                            <html lang="en">
                            <head>
                                <meta charset="UTF-8" />
                                <meta name="robots" content="noindex,nofollow,noarchive" />
                                <title>An Error Occurred: Method Not Allowed</title>
                                <link rel="icon" href="data:image/svg+xml,<svg xmlns=%22http://www.w3.org/2000/svg%22 viewBox=%220 0 128 128%22><text y=%221.2em%22 font-size=%2296%22>❌</text></svg>" />
                                <style>body { background-color: #fff; color: #222; font: 16px/1.5 -apple-system, BlinkMacSystemFont, "Segoe UI", Roboto, "Helvetica Neue", Arial, sans-serif; margin: 0; }
                            .container { margin: 30px; max-width: 600px; }
                            h1 { color: #dc3545; font-size: 24px; }
                            h2 { font-size: 18px; }</style>
                            </head>
                            <body>
                            <div class="container">
                                <h1>Oops! An Error Occurred</h1>
                                <h2>The server returned a "405 Method Not Allowed".</h2>
                                <p>
                                    Something is broken. Please let us know what you were doing when this error occurred.
                                    We will fix it as soon as possible. Sorry for any inconvenience caused.
                                </p>
                            </div>
                            </body...
                              @negalein
                                      "type": "tab",
                                      "label": "Flow 3",
                                      "disabled": false,
                                      "info": "",
                                      "env": []
                                      "name": "",
                                      "method": "GET",
                                      "ret": "obj",
                                      "paytoqs": "body",
                                      "tls": "",
                                      "persist": false,
                                      "proxy": "",
                                      "authType": "",
                                      "senderr": false,
                                      "headers": [],
                                      "x": 410,
                                      "y": 120,
                                      "wires": [
                                              "8118e4eac98c67a6"
                                      "type": "debug",
                                      "name": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 570,
                                      "y": 120,
                                      "wires": []
                                      "type": "inject",
                                      "name": "",
                                      "props": [
                                              "p": "topic",
                                              "vt": "str"
                                      "repeat": "",
                                      "crontab": "",
                                      "once": false,
                                      "onceDelay": 0.1,
                                      "topic": "",
                                      "x": 250,
                                      "y": 120,
                                      "wires": [
                                              "e8c8fbba21beb8a4"
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              @oliverio
                              funktioniert :)
                              hab das übersehn.
                              von GET auf POST
                              jetzt bekomm ich den Token
                              jetzt muss dann der Token noch für die Session gespeichert werden?
                              Oder kann ich gleich den nächsten http request anhängen?
                              Ok, so gehts nicht.
                              6.7.2024, 17:38:25node: debug
                              msg.payload : string[27]
                              "{"error":"Unauthenticated"}"
                                Da kommt dann nur
                                msg : string[16]
                                "JSON parse error"
                                <!DOCTYPE html>
                                <html lang="en">
                                <head>
                                </head>
                                <body>
                                    <p>
                                    </p>
                                </div>
                                </body...
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @negalein Also ich will mich grundsätzlich nicht parallel hier reindrängen, wenn @OliverIO das Projekt mit Dir durchführen will, dann kann ich mich auch auf die Beobachterrolle zurückziehen.
                                Grundsätzlich, um ggf. nachvollziehen zu können, müsstest Du Dein token ggf. mitteilen, was aber kein Problem sein sollte, weil das token ja nur begrenzte Gültigkeit hat. Dein Anmeldedaten musst Du immer für Dich behalten.
                                Vielleicht ein paar Grundlagen für Node-Red. Während in Blockly alles von oben nach unten verläuft, ist in NodeRed wie in einem Buch, sprich der Flow verläuft in der Regel von links nach rechts so wie Du liest.
                                Jede Node hat in der Regel - einen Eingang oder keinen Eingang (wenn sie selbst triggert oder wie bei der Inject Node eine Taste hat) und ein oder mehrere Ausgänge.
                                Über die Debug Node - kannst Du Dir entweder das ganze Nachrichtenobjekt ausgeben lassen oder nur eine Eigenschaft des Nachrichtenobjektes (standardmässig) ist das immer die Eigenschaft "payload" des Nachrichtenobjektes.
                                Wenn Du eine Node auswählst und rechts im Fenster auf das Buch klickst, dann bekommst Du in der Regel einen Hilfetext zu einer Node.
                                Wenn Du eine Inject Node rausziehst, ist diese immer mit einem timestamp als payload und einem leeren topic vorbelegt.
                                Wenn Du also direkt eine Debug Node anschließt, dann kannst Du nun entweder nur die payload, das topic als einzelne Eigenschaft ins Debugfenster oder das gesamte Nachrichtenobjekt.
                                Aber wie gesagt, wenn Du einfach so loslegen willst, kannst Du es gerne tun. Du weißt ja - viele Köche verderben den Brei.
                                [{"id":"8c240df122ab8026","type":"inject","z":"366db1589150b476","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":240,"y":280,"wires":[["2e8425e235bfdd9f","004ccdf6f9124f72","917e9185015556d8"]]},{"id":"2e8425e235bfdd9f","type":"debug","z":"366db1589150b476","name":"payload","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":440,"y":240,"wires":[]},{"id":"004ccdf6f9124f72","type":"debug","z":"366db1589150b476","name":"topic","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"topic","targetType":"msg","statusVal":"","statusType":"auto","x":430,"y":280,"wires":[]},{"id":"917e9185015556d8","type":"debug","z":"366db1589150b476","name":"gesamtes Nachrichtenobjekt","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":500,"y":320,"wires":[]}]
                                • mickymM mickym
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  aktueller Token (per PN auch gerne die Zugangsdaten an dich und Oliver)
                                    "success": {
                                      "token": "eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJhdWQiOiIzOCIsImp0aSI6IjA0NDYzYjMzZGQ0NGM2OTExOTcyOWYwNzk1MGJiNjg2MWZjZWVjMmQwYzNiY2E5ZjQ3Y2U1MjM1YWIzNGM1YWQwOTM3MTNkYmIzODg2MGE5IiwiaWF0IjoxNzIwMjgwOTMwLjIyODE0MiwibmJmIjoxNzIwMjgwOTMwLjIyODE0NSwiZXhwIjoxNzIyODcyOTMwLjE5OTYzOCwic3ViIjoiMjk1MjM0NSIsInNjb3BlcyI6W119.f5oY-BKAoDaxyO-jskPIQdZe3Hy7fK_YRidCRRyKXSZ3TGS0iy5U_21wnkasgQVlTkMk-7Kxvk30CWZx6PdI3bAJypTmXsiQ7j6sLVCNdpjbY6uedCnDoXSP50W8sYLPZy8ws-Z_qXc3s3Ylld2TUeiH-9r-LYImFi1s2jO1Jrk9PSoQp2f7EVuvfZFDRV9izewU0GgsQ7QdT3h5xrxDYvI1vzOfJu8CnltKy20E-w2YBRKVUWVdAKQMyNhLNMJFNFWnJBH5maV5Y5dELoPgjAGwiVKYont0GYLUmsKdy4bFyEZFbguJbuyR4thNKEEzQpZx3hWDbe2_BSyCDSzltw0nywumVTHRYjsHutCL3AcwHxw5AY5WBziPa5mTrXwi4K1aaUPGP7ixmKT3kVR56c2_HHUKOsiFJaodjwG6SIpocMqJJxdIqGfuNAzztmtO4Ck5oMOMp67jP6wjsJJ9MQgxY-lrx5wgpzVJ8hgwsG7cLTKbjPqUKiVZfwUzigzwO3uPurZ7K0jUq1ifCzR1-iYml1CvKeZLYG0ZG5qPDBiPkwMFbpFHLnLsA2fjfU-G9h6klYJyxpC7w5jzrCJ_Iboqs-WVXU2wyUF_syZrPf4PQav3h86ClJInvh9EvREnFQ7Ndzks-QAis7cuFp3vB6XmAf4YVY-55kOrFVrN1Yc",
                                      "refresh_token": "def502002ce29ee67844eac2a70befa3a2964f1603076e414fd40a287246c0927f5044f7a7918c06b4d9a3a2296c84dde80810c7bf76afc5a5eb1a7684d949100709172c7b893f8dab518ab564f217a6e3df401f7d1b2e4c7343eb050bfb286f5f0b919f99250e8274f8d9bd5712075dde672b3566d7ad1cbffcf9486ba118532a66c4cf1bb68c4a08b69a05a447848502b51d8e5c65d7d9ff90bcd7af073f53fdc8fb665a7b5ad1776349ddeadf9ef6d7e954d77b44b411e228f1af8fd0ae3ac21de40f505146b7e77f2453346c14340fa895bb05db28bc7ab4514c2f6e24e84245dfdac6b577428259b233a23ab897a232dbc0262965287b9d4e10e5feab0fce5f85b2410b5d2b73b90fa68eda0c155e0107622b55a780d12a1e2533f9b07754d98972acf77c4dc94585b4f5b88b16cdad6fd3ac55c3029abece858f71605b6f0ca4c4793bdcfd87ad05e02d7317f21e84f2e4b1338b9069efdd8ad9aa704c2baf19e6b62d04bf",
                                      "isAdmin": 0,
                                      "userID": 2952345,
                                      "Petsevices": 0
                                  hab ich gefunden und gelesen :)
                                  müsste dann obiger Screenshot mit 2 Request nacheinander passen?
                                  Aber wo macht er den Login inkl. Token?
                                      "success": {
                                        "isAdmin": 0,
                                        "userID": 2952345,
                                        "Petsevices": 0
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @negalein Ja im Moment wollte ich den noch gar nicht. Hast Du mal meinen Flow importiert und verstanden wie ein Nachrichtenobjekt aufgebaut ist und welche Möglichkeiten Du hast, Eigenschaften des Nachrichtenobjektes im Debugfenster ausgeben zu lassen?
                                        "success": {
                                          "isAdmin": 0,
                                          "userID": 2952345,
                                          "Petsevices": 0
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      Nein das passt noch lange nicht. Aber ich dachte, wir entwickeln das zusammen?
                                      • mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @Negalein Wenn Du soweit bist, dann melde Dich halt - sonst warte ich hier, wenn keine Rückmeldung kommt.
                                        • mickymM mickym
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          Ja, die 3 grünen Nodes sind alles eigene Debugs.
                                          Und der blaue Timestamp ist das ausführbare Teil. Also der Start von Allem.
                                          Im Payload steht eine Nummer (wo kommt die her).
                                          Im Topic steht nichts.
                                          Und im Nachrichtenobjekt steht wieder die Nummer vom Payload.
                                          Also der Payload übergibt an das Nachrichtenobjekt.
                                          Und ich schätze im Topic wird mal das Ergebnis (zB GPS-Koordinaten) stehn.
                                          6.7.2024, 18:02:58node: payload
                                          msg.payload : number
                                          1720281778711
                                          6.7.2024, 18:02:58node: topic
                                          msg.topic : string[0]
                                          6.7.2024, 18:02:58node: gesamtes Nachrichtenobjekt
                                          msg : Object
                                          object
                                          _msgid: "8ec694ca908771a0"
                                          payload: 1720281778711
                                          topic: ""
