  4. Einrichtung Multihost klappt nicht - Meldung Slave
61 Beiträge 4 Kommentatoren 8.4k Aufrufe 2 Beobachtet
  • SMSS Offline
    SMSS Offline
    SMS
    Zu 1wire kann ich dir nix sagen, hab ich noch nie mit zu tun gehabt.
    Da schau ich morgen mal nach
      @sms
      Dann halt wie üblich:
      sudo apt update
      sudo apt install grafana
      SMSS Offline
      SMSS Offline
      SMS
      @thomas-braun sagte in Einrichtung Multihost klappt nicht - Meldung Slave:
      @sms
      sudo apt update
      Und nun:
      pi@Homee:~ $ sudo apt install grafana
      Reading package lists... Done
      The following packages were automatically installed and are no longer required:
        libraspberrypi0 libwpe-1.0-1 libwpebackend-fdo-1.0-1
      Use 'sudo apt autoremove' to remove them.
      The following additional packages will be installed:
        musl
      The following NEW packages will be installed:
        grafana musl
      0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
      Need to get 111 MB of archives.
      After this operation, 424 MB of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Get:1 http://deb.debian.org/debian bookworm/main arm64 musl arm64 1.2.3-1 [392 kB]
      Get:2 https://apt.grafana.com stable/main arm64 grafana arm64 11.0.0 [111 MB]
      Fetched 111 MB in 9s (12.0 MB/s)
      Selecting previously unselected package musl:arm64.
      (Reading database ... 158707 files and directories currently installed.)
      Preparing to unpack .../musl_1.2.3-1_arm64.deb ...
      Unpacking musl:arm64 (1.2.3-1) ...
      Selecting previously unselected package grafana.
      Preparing to unpack .../grafana_11.0.0_arm64.deb ...
      Unpacking grafana (11.0.0) ...
      Setting up musl:arm64 (1.2.3-1) ...
      Setting up grafana (11.0.0) ...
      Adding system user `grafana' (UID 112) ...
      Adding new user `grafana' (UID 112) with group `grafana' ...
      Not creating home directory `/usr/share/grafana'.
      ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
       sudo /bin/systemctl daemon-reload
       sudo /bin/systemctl enable grafana-server
      ### You can start grafana-server by executing
       sudo /bin/systemctl start grafana-server
      Processing triggers for man-db (2.11.2-2) ...
      • SMSS SMS
        @sms
        sudo apt update
        Und nun:
          musl
          grafana musl
        @sms
        Gut. Wenn das ganze automatisch gestartet werden soll halt die drei systemctl-Befehle noch eingeben.
        SMSS 1 Antwort Letzte Antwort
          @sms
          SMSS Offline
          SMSS Offline
          SMS
          @thomas-braun welches PW ist gemeint?
          pi@Homee:~ $ sudo systemctl enable grafana-server
          Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
          Executing: /lib/systemd/systemd-sysv-install enable grafana-server
          Created symlink /etc/systemd/system/multi-user.target.wants/grafana-server.service → /lib/systemd/system/grafana-server.service.
          pi@Homee:~ $ systemctl enable grafana-server.service
          ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ====
          Authentication is required to reload the systemd state.
          Authenticating as: ,,, (pi)
          Password:
          ==== AUTHENTICATION COMPLETE ====
          Password:
          ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ====
          Authentication is required to manage system service or unit files.
          Password:
          Password:
          polkit-agent-helper-1: pam_authenticate failed: Authentication failure
          ==== AUTHENTICATION FAILED ====
          Reload daemon failed: Access denied
          pi@Homee:~ $
          pi@Homee:~ $ systemctl status grafana-server
          ○ grafana-server.service - Grafana instance
               Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; preset: enabled)
               Active: inactive (dead)
                 Docs: http://docs.grafana.org
          • SMSS SMS
            Password:
            Password:
            Password:
            Password:
            pi@Homee:~ $
            @sms
            Muss mit sudo eingeleitet werden.
            Deswegen steht das auch so drin.
              @sms
              SMSS Offline
              SMSS Offline
              SMS
              OK, auf die Seite komme ich jetzt wieder. Aber wie ist der Benutzername und das Passwort? Das Alte funzt nicht mehr.
              • SMSS SMS
                @sms sagte in Einrichtung Multihost klappt nicht - Meldung Slave:
                Ich verwende Grafana nicht.
                Aber war da nicht irgendwas mit Token, die da benutzt werden?
                  SMSS Offline
                  SMSS Offline
                  SMS
                  @thomas-braun keine Ahnung
                  • SMSS SMS
                    keine Ahnung
                    Ich auch nicht. Steht bestimmt in der Doku zu Grafana drin.
                    SMSS 2 Antworten Letzte Antwort
                      keine Ahnung
                      SMSS Offline
                      SMSS Offline
                      SMS
                      @thomas-braun morgen geht's weiter.
                      Danke, warst wie immer eine große HILFE!! :-)
                        keine Ahnung
                        SMSS Offline
                        SMSS Offline
                        SMS
                        @thomas-braun Hi, muss mal wieder kurz stören.
                        Da mitlerweile alles wieder läuft, zumindest die Adapter, habe ich festgestellt das meine GPIOs nicht mehr funktionieren. Habe irgendwas im Kopf das man die wo freischalten muss. Hier
                        sudo raspi-config
                        habe ich sie aktiviert.
                        Kannst du mir weiterhelfen?
                        Danke!
                        • SMSS SMS
                          sudo raspi-config
                          Danke!
                          Da wurde einiges umgestellt. Wie greifst du auf die GPIOs zu?
                            SMSS Offline
                            SMSS Offline
                            SMS
                            @thomas-braun über den Adapter rpi2
                            • SMSS SMS
                              @sms
                              Der wird soweit ich das sehe gerade auf neue Gegebenheiten angepasst.
                              Wie weit das gediehen ist kann ich dir aber nicht sagen.
                                @sms
                                SMSS Offline
                                SMSS Offline
                                SMS
                                @thomas-braun gibt es ne andere Möglichkeit? Steuere darüber meine Poolpumpe und andere Sachen
                                • SMSS SMS
                                  @sms
                                  Ist der iobroker zumindest in der Gruppe gpiodrin?
                                  sudo -H -u iobroker groups
                                    @sms
                                    SMSS Offline
                                    SMSS Offline
                                    SMS
                                    @sms
                                    pi@Gartenklo:~ $ sudo -H -u iobroker groups
                                    iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                    pi@Gartenklo:~ $
                                    • SMSS SMS
                                      @sms
                                      pi@Gartenklo:~ $
                                      @sms
                                      Hier sieht man Aktivitäten bzgl. einer Version 2.0.
                                      https://github.com/iobroker-community-adapters/ioBroker.rpi2
                                      • SMSS SMS
                                        @sms
                                        pi@Gartenklo:~ $
                                        @sms
                                        https://github.com/iobroker-community-adapters/ioBroker.rpi2/issues/167
                                        Du könntest also beim Testing beitragen, Garfonso würde sich bestimmt freuen:
                                        I modified the adapter to use libgpiod. If anybody wants to try, go ahead and give 2.0.0-alpha.6 a try.
                                        I could not really test GPIO Inputs (since I seem to have destroyed my testing PI 3 and need to get a replacement for that).... I'd be interested to see if those work. Control works in Raspian Bookworm and also in Buster.
                                          @sms
                                          SMSS Offline
                                          SMSS Offline
                                          SMS
                                          @thomas-braun falls der nicht mehr funktioniert, was mache ich dann? Gibt es Alternativen?
