  4. Einrichtung Multihost klappt nicht - Meldung Slave
61 Beiträge 4 Kommentatoren 8.4k Aufrufe 2 Beobachtet
  • SMSS SMS
    @thomas-braun eindeutig!
    jetzt läuft nur der Adapter DS18B20 nicht mehr.
    ds18b20.1
    	2024-05-30 22:52:51.757	warn	Error reading sensor 28-0120506f240b: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0120506f240b/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.705	warn	Error reading sensor 28-0316a279ee0c: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a279ee0c/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.656	warn	Error reading sensor 28-0316a2793d5d: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a2793d5d/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.608	warn	Error reading sensor 28-01144fc984aa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144fc984aa/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.560	warn	Error reading sensor 28-01144fb5fcaa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144fb5fcaa/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.512	warn	Error reading sensor 28-01144fb07eaa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144fb07eaa/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.464	warn	Error reading sensor 28-01144fa090aa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144fa090aa/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.413	warn	Error reading sensor 28-01144f9dd2aa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144f9dd2aa/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.360	warn	Error reading sensor 28-01144f959aaa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144f959aaa/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.253	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.ds18b20, node: v20.14.0, js-controller: 5.0.19
    ds18b20.1
    	2024-05-30 22:52:43.051	info	terminating
    ds18b20.1
    	2024-05-30 22:52:42.619	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    ds18b20.1
    	2024-05-30 22:52:42.617	info	terminating
    ds18b20.1
    	2024-05-30 22:52:42.567	info	Got terminate signal TERMINATE_YOURSELF
    ds18b20.1
    	2024-05-30 22:52:42.562	info	Got terminate signal TERMINATE_YOURSELF
    ds18b20.1
    	2024-05-30 22:52:42.558	info	Got terminate signal TERMINATE_YOURSELF
    ds18b20.1
    	2024-05-30 22:52:42.556	info	Got terminate signal TERMINATE_YOURSELF
    ds18b20.1
    	2024-05-30 22:52:42.545	info	Got terminate signal TERMINATE_YOURSELF
    da fehlt bestimmt auch irgendwas
    haselchenH Offline
    haselchenH Offline
    haselchen
    @sms sagte in Einrichtung Multihost klappt nicht - Meldung Slave:
    ds18b20.1
    Hast du noch eine andere Instanz davon?
    ds18b20.1
      @homoran sagte in Einrichtung Multihost klappt nicht - Meldung Slave:
      laut username ein pi
      Auf usernames geb ich nix. Scheinbar wird pi für alles mögliche verwendet. Wobei das selbst auf Raspberry OS nicht mehr verwendet werden soll sondern individuelle usernames empfohlen werden.
      @thomas-braun sagte in Einrichtung Multihost klappt nicht - Meldung Slave:
      jepp, ist auch bei mir der Standard Username, egal wo. Abet mit anderen Passworten
      SMSS 1 Antwort Letzte Antwort
        SMSS Offline
        SMSS Offline
        SMS
        schrieb am zuletzt editiert von SMS
        @homoran also der pi hat schon einen eigenen Namen. Nur beim anmelden ist der Benutzername pi.
        Auf einem anderen pi läuft die Instanz. Denke das ich ein Spannungsproblem habe. 4 von den 8 Sensoren zeigen Werte an. Muss ich morgen mal schauen
        jetzt muss ich noch grafana installieren. Nach deiner Anleitung:
        pi@Homee:~ $ sudo apt-get install -y apt-transport-https
        Reading package lists... Done
        The following packages were automatically installed and are no longer required:
          libraspberrypi0 libwpe-1.0-1 libwpebackend-fdo-1.0-1
        Use 'sudo apt autoremove' to remove them.
        The following NEW packages will be installed:
          apt-transport-https
        0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
        Need to get 25.2 kB of archives.
        After this operation, 35.8 kB of additional disk space will be used.
        Get:1 http://deb.debian.org/debian bookworm/main arm64 apt-transport-https all 2.6.1 [25.2 kB]
        Fetched 25.2 kB in 0s (295 kB/s)
        Selecting previously unselected package apt-transport-https.
        (Reading database ... 158457 files and directories currently installed.)
        Preparing to unpack .../apt-transport-https_2.6.1_all.deb ...
        Unpacking apt-transport-https (2.6.1) ...
        Setting up apt-transport-https (2.6.1) ...
        pi@Homee:~ $ sudo apt-get install -y software-properties-common wget
        wget is already the newest version (1.21.3-1+b1).
        wget set to manually installed.
        The following additional packages will be installed:
          python3-httplib2 python3-lazr.restfulclient python3-lazr.uri python3-pyparsing python3-software-properties python3-wadllib
        Suggested packages:
          python-pyparsing-doc
        0 upgraded, 7 newly installed, 0 to remove and 0 not upgraded.
        Need to get 370 kB of archives.
        After this operation, 1,836 kB of additional disk space will be used.
        Get:1 http://deb.debian.org/debian bookworm/main arm64 python3-pyparsing all 3.0.9-1 [138 kB]
        Get:2 http://deb.debian.org/debian bookworm/main arm64 python3-httplib2 all 0.20.4-3 [36.0 kB]
        Get:3 http://deb.debian.org/debian bookworm/main arm64 python3-lazr.uri all 1.0.6-3 [13.7 kB]
        Get:4 http://deb.debian.org/debian bookworm/main arm64 python3-wadllib all 1.3.6-4 [37.2 kB]
        Get:5 http://deb.debian.org/debian bookworm/main arm64 python3-lazr.restfulclient all 0.14.5-1 [50.4 kB]
        Get:6 http://deb.debian.org/debian bookworm/main arm64 python3-software-properties all 0.99.30-4 [32.7 kB]
        Get:7 http://deb.debian.org/debian bookworm/main arm64 software-properties-common all 0.99.30-4 [62.0 kB]
        Fetched 370 kB in 0s (4,820 kB/s)
        Selecting previously unselected package python3-pyparsing.
        (Reading database ... 158461 files and directories currently installed.)
        Preparing to unpack .../0-python3-pyparsing_3.0.9-1_all.deb ...
        Unpacking python3-pyparsing (3.0.9-1) ...
        Selecting previously unselected package python3-httplib2.
        Preparing to unpack .../1-python3-httplib2_0.20.4-3_all.deb ...
        Unpacking python3-httplib2 (0.20.4-3) ...
        Selecting previously unselected package python3-lazr.uri.
        Preparing to unpack .../2-python3-lazr.uri_1.0.6-3_all.deb ...
        Unpacking python3-lazr.uri (1.0.6-3) ...
        Selecting previously unselected package python3-wadllib.
        Preparing to unpack .../3-python3-wadllib_1.3.6-4_all.deb ...
        Unpacking python3-wadllib (1.3.6-4) ...
        Selecting previously unselected package python3-lazr.restfulclient.
        Preparing to unpack .../4-python3-lazr.restfulclient_0.14.5-1_all.deb ...
        Unpacking python3-lazr.restfulclient (0.14.5-1) ...
        Selecting previously unselected package python3-software-properties.
        Preparing to unpack .../5-python3-software-properties_0.99.30-4_all.deb ...
        Unpacking python3-software-properties (0.99.30-4) ...
        Selecting previously unselected package software-properties-common.
        Preparing to unpack .../6-software-properties-common_0.99.30-4_all.deb ...
        Unpacking software-properties-common (0.99.30-4) ...
        Setting up python3-lazr.uri (1.0.6-3) ...
        Setting up python3-pyparsing (3.0.9-1) ...
        Setting up python3-wadllib (1.3.6-4) ...
        Setting up python3-httplib2 (0.20.4-3) ...
        Setting up python3-lazr.restfulclient (0.14.5-1) ...
        Setting up python3-software-properties (0.99.30-4) ...
        Setting up software-properties-common (0.99.30-4) ...
        Processing triggers for man-db (2.11.2-2) ...
        Processing triggers for dbus (1.14.10-1~deb12u1) ...
        pi@Homee:~ $ sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
        pi@Homee:~ $ echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
        pi@Homee:~ $
        Alles richtig?
        • SMSS SMS
            apt-transport-https
          Suggested packages:
          pi@Homee:~ $
          Alles richtig?
          @sms
          Laufen die Kernelmodule dazu?
          lsmod
          bzw
          lsmod | grep w1
          anschauen.
          Wobei ich von 1-wire keine Ahnung habe, ob sich das nicht wegen GPIO-Umstellereien im aktuellen Raspberry OS wieder alles geändert hat.
          • SMSS SMS
              apt-transport-https
            Suggested packages:
            pi@Homee:~ $
            Alles richtig?
            Alles richtig?
            Ich denke.
            Hast du das aus den 'phantastischen Repos' kopiert?
              @sms
              lsmod
              bzw
              lsmod | grep w1
              anschauen.
              SMSS Offline
              SMSS Offline
              SMS
              @sms
              lsmod
              pi@Homee:~ $ lsmod
              Module                  Size  Used by
              rfcomm                 53248  4
              snd_seq_dummy          12288  0
              snd_hrtimer            12288  1
              snd_seq                81920  7 snd_seq_dummy
              snd_seq_device         16384  1 snd_seq
              cmac                   12288  3
              algif_hash             12288  1
              aes_arm64              12288  3
              aes_generic            32768  1 aes_arm64
              algif_skcipher         12288  1
              af_alg                 28672  6 algif_hash,algif_skcipher
              bnep                   24576  2
              brcmfmac_wcc           12288  0
              ftdi_sio               53248  0
              brcmfmac              348160  1 brcmfmac_wcc
              usbserial              45056  1 ftdi_sio
              binfmt_misc            16384  1
              hci_uart               49152  0
              btbcm                  24576  1 hci_uart
              brcmutil               24576  1 brcmfmac
              bluetooth             606208  33 hci_uart,btbcm,bnep,rfcomm
              rpivid_hevc            45056  0
              bcm2835_codec          45056  0
              cfg80211              995328  1 brcmfmac
              bcm2835_isp            28672  0
              v4l2_mem2mem           53248  2 bcm2835_codec,rpivid_hevc
              ecdh_generic           16384  2 bluetooth
              bcm2835_v4l2           40960  0
              bcm2835_mmal_vchiq     36864  3 bcm2835_codec,bcm2835_v4l2,bcm2835_isp
              ecc                    36864  1 ecdh_generic
              videobuf2_vmalloc      12288  1 bcm2835_v4l2
              videobuf2_dma_contig    20480  3 bcm2835_codec,rpivid_hevc,bcm2835_isp
              videobuf2_memops       12288  2 videobuf2_vmalloc,videobuf2_dma_contig
              libaes                 12288  3 aes_arm64,bluetooth,aes_generic
              raspberrypi_hwmon      12288  0
              videobuf2_v4l2         32768  5 bcm2835_codec,bcm2835_v4l2,rpivid_hevc,v4l2_mem2mem,bcm2835_isp
              rfkill                 32768  6 bluetooth,cfg80211
              videodev              319488  6 bcm2835_codec,videobuf2_v4l2,bcm2835_v4l2,rpivid_hevc,v4l2_mem2mem,bcm2835_isp
              raspberrypi_gpiomem    12288  0
              videobuf2_common       73728  9 bcm2835_codec,videobuf2_vmalloc,videobuf2_dma_contig,videobuf2_v4l2,bcm2835_v4l2,rpivid_hevc,v4l2_mem2mem,videobuf2_memops,bcm2835_isp
              mc                     65536  7 videodev,bcm2835_codec,videobuf2_v4l2,videobuf2_common,rpivid_hevc,v4l2_mem2mem,bcm2835_isp
              snd_bcm2835            24576  1
              vc_sm_cma              28672  2 bcm2835_mmal_vchiq,bcm2835_isp
              nvmem_rmem             12288  0
              uio_pdrv_genirq        12288  0
              uio                    20480  1 uio_pdrv_genirq
              i2c_dev                16384  0
              fuse                  139264  5
              dm_mod                143360  0
              ip_tables              32768  0
              x_tables               57344  1 ip_tables
              ipv6                  573440  73
              vc4                   372736  10
              snd_soc_hdmi_codec     20480  2
              drm_display_helper     16384  1 vc4
              cec                    53248  1 vc4
              drm_dma_helper         24576  2 vc4
              drm_kms_helper        233472  2 drm_dma_helper,vc4
              snd_soc_core          307200  2 vc4,snd_soc_hdmi_codec
              v3d                    90112  4
              snd_compress           20480  1 snd_soc_core
              gpu_sched              53248  1 v3d
              drm_shmem_helper       24576  1 v3d
              snd_pcm_dmaengine      16384  1 snd_soc_core
              drm                   688128  17 gpu_sched,drm_kms_helper,drm_dma_helper,v3d,vc4,drm_shmem_helper,drm_display_helper
              drm_panel_orientation_quirks    24576  1 drm
              snd_pcm               151552  5 snd_bcm2835,snd_soc_hdmi_codec,snd_compress,snd_soc_core,snd_pcm_dmaengine
              i2c_brcmstb            12288  0
              snd_timer              36864  3 snd_seq,snd_hrtimer,snd_pcm
              snd                   122880  12 snd_seq,snd_seq_device,snd_bcm2835,snd_soc_hdmi_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm
              backlight              24576  1 drm
              pi@Homee:~ $
              bzw
              lsmod | grep w1
              pi@Homee:~ $ lsmod | grep w1
              pi@Homee:~ $
              Ja, habe ich von dir
              • SMSS SMS
                @sms
                lsmod
                pi@Homee:~ $ lsmod
                Module                  Size  Used by
                rfcomm                 53248  4
                snd_hrtimer            12288  1
                cmac                   12288  3
                algif_hash             12288  1
                aes_arm64              12288  3
                bnep                   24576  2
                ftdi_sio               53248  0
                binfmt_misc            16384  1
                hci_uart               49152  0
                rpivid_hevc            45056  0
                bcm2835_isp            28672  0
                snd_bcm2835            24576  1
                nvmem_rmem             12288  0
                i2c_dev                16384  0
                fuse                  139264  5
                dm_mod                143360  0
                ip_tables              32768  0
                ipv6                  573440  73
                vc4                   372736  10
                cec                    53248  1 vc4
                v3d                    90112  4
                i2c_brcmstb            12288  0
                pi@Homee:~ $
                bzw
                lsmod | grep w1
                pi@Homee:~ $
                @sms
                Dann halt wie üblich:
                sudo apt update
                sudo apt install grafana
                Zu 1wire kann ich dir nix sagen, hab ich noch nie mit zu tun gehabt.
                • SMSS Offline
                  SMSS Offline
                  SMS
                  Da schau ich morgen mal nach
                    @sms
                    sudo apt update
                    SMSS Offline
                    SMSS Offline
                    SMS
                    @sms
                    sudo apt update
                    Und nun:
                    pi@Homee:~ $ sudo apt install grafana
                      musl
                      grafana musl
                    0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                    Need to get 111 MB of archives.
                    After this operation, 424 MB of additional disk space will be used.
                    Do you want to continue? [Y/n] y
                    Get:1 http://deb.debian.org/debian bookworm/main arm64 musl arm64 1.2.3-1 [392 kB]
                    Get:2 https://apt.grafana.com stable/main arm64 grafana arm64 11.0.0 [111 MB]
                    Fetched 111 MB in 9s (12.0 MB/s)
                    Selecting previously unselected package musl:arm64.
                    (Reading database ... 158707 files and directories currently installed.)
                    Preparing to unpack .../musl_1.2.3-1_arm64.deb ...
                    Unpacking musl:arm64 (1.2.3-1) ...
                    Selecting previously unselected package grafana.
                    Preparing to unpack .../grafana_11.0.0_arm64.deb ...
                    Unpacking grafana (11.0.0) ...
                    Setting up musl:arm64 (1.2.3-1) ...
                    Setting up grafana (11.0.0) ...
                    Adding system user `grafana' (UID 112) ...
                    Adding new user `grafana' (UID 112) with group `grafana' ...
                    Not creating home directory `/usr/share/grafana'.
                    ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
                     sudo /bin/systemctl daemon-reload
                     sudo /bin/systemctl enable grafana-server
                    ### You can start grafana-server by executing
                     sudo /bin/systemctl start grafana-server
                    • SMSS SMS
                      @sms
                      sudo apt update
                      Und nun:
                        musl
                        grafana musl
                      @sms
                      Gut. Wenn das ganze automatisch gestartet werden soll halt die drei systemctl-Befehle noch eingeben.
                        @sms
                        SMSS Offline
                        SMSS Offline
                        SMS
                        @thomas-braun welches PW ist gemeint?
                        pi@Homee:~ $ sudo systemctl enable grafana-server
                        Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
                        Executing: /lib/systemd/systemd-sysv-install enable grafana-server
                        Created symlink /etc/systemd/system/multi-user.target.wants/grafana-server.service → /lib/systemd/system/grafana-server.service.
                        pi@Homee:~ $ systemctl enable grafana-server.service
                        ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ====
                        Authentication is required to reload the systemd state.
                        Authenticating as: ,,, (pi)
                        Password:
                        ==== AUTHENTICATION COMPLETE ====
                        Password:
                        ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ====
                        Authentication is required to manage system service or unit files.
                        Password:
                        Password:
                        polkit-agent-helper-1: pam_authenticate failed: Authentication failure
                        ==== AUTHENTICATION FAILED ====
                        Reload daemon failed: Access denied
                        pi@Homee:~ $
                        pi@Homee:~ $ systemctl status grafana-server
                        ○ grafana-server.service - Grafana instance
                             Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; preset: enabled)
                             Active: inactive (dead)
                               Docs: http://docs.grafana.org
                        • SMSS SMS
                          Password:
                          Password:
                          Password:
                          Password:
                          pi@Homee:~ $
                          @sms
                          Muss mit sudo eingeleitet werden.
                          Deswegen steht das auch so drin.
                            @sms
                            SMSS Offline
                            SMSS Offline
                            SMS
                            OK, auf die Seite komme ich jetzt wieder. Aber wie ist der Benutzername und das Passwort? Das Alte funzt nicht mehr.
                            • SMSS SMS
                              Ich verwende Grafana nicht.
                              Aber war da nicht irgendwas mit Token, die da benutzt werden?
                                SMSS Offline
                                SMSS Offline
                                SMS
                                @thomas-braun keine Ahnung
                                • SMSS SMS
                                  keine Ahnung
                                  Ich auch nicht. Steht bestimmt in der Doku zu Grafana drin.
                                  SMSS 2 Antworten Letzte Antwort
                                    keine Ahnung
                                    SMSS Offline
                                    SMSS Offline
                                    SMS
                                    @thomas-braun morgen geht's weiter.
                                    Danke, warst wie immer eine große HILFE!! :-)
                                      keine Ahnung
                                      SMSS Offline
                                      SMSS Offline
                                      SMS
                                      @thomas-braun Hi, muss mal wieder kurz stören.
                                      Da mitlerweile alles wieder läuft, zumindest die Adapter, habe ich festgestellt das meine GPIOs nicht mehr funktionieren. Habe irgendwas im Kopf das man die wo freischalten muss. Hier
                                      sudo raspi-config
                                      habe ich sie aktiviert.
                                      Kannst du mir weiterhelfen?
                                      Danke!
                                      • SMSS SMS
                                        sudo raspi-config
                                        Danke!
                                        Da wurde einiges umgestellt. Wie greifst du auf die GPIOs zu?
                                          SMSS Offline
                                          SMSS Offline
                                          SMS
                                          @thomas-braun über den Adapter rpi2
