  4. Einrichtung Multihost klappt nicht - Meldung Slave
61 Beiträge 4 Kommentatoren 8.4k Aufrufe 2 Beobachtet
  • SMSS SMS
    @thomas-braun eindeutig!
    jetzt läuft nur der Adapter DS18B20 nicht mehr.
    ds18b20.1
    	2024-05-30 22:52:51.757	warn	Error reading sensor 28-0120506f240b: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0120506f240b/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.705	warn	Error reading sensor 28-0316a279ee0c: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a279ee0c/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.656	warn	Error reading sensor 28-0316a2793d5d: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-0316a2793d5d/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.608	warn	Error reading sensor 28-01144fc984aa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144fc984aa/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.560	warn	Error reading sensor 28-01144fb5fcaa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144fb5fcaa/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.512	warn	Error reading sensor 28-01144fb07eaa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144fb07eaa/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.464	warn	Error reading sensor 28-01144fa090aa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144fa090aa/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.413	warn	Error reading sensor 28-01144f9dd2aa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144f9dd2aa/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.360	warn	Error reading sensor 28-01144f959aaa: Error: ENOENT: no such file or directory, open '/sys/bus/w1/devices/28-01144f959aaa/w1_slave'
    ds18b20.1
    	2024-05-30 22:52:51.253	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.ds18b20, node: v20.14.0, js-controller: 5.0.19
    ds18b20.1
    	2024-05-30 22:52:43.051	info	terminating
    ds18b20.1
    	2024-05-30 22:52:42.619	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    ds18b20.1
    	2024-05-30 22:52:42.617	info	terminating
    ds18b20.1
    	2024-05-30 22:52:42.567	info	Got terminate signal TERMINATE_YOURSELF
    ds18b20.1
    	2024-05-30 22:52:42.562	info	Got terminate signal TERMINATE_YOURSELF
    ds18b20.1
    	2024-05-30 22:52:42.558	info	Got terminate signal TERMINATE_YOURSELF
    ds18b20.1
    	2024-05-30 22:52:42.556	info	Got terminate signal TERMINATE_YOURSELF
    ds18b20.1
    	2024-05-30 22:52:42.545	info	Got terminate signal TERMINATE_YOURSELF
    da fehlt bestimmt auch irgendwas
    @sms sagte in Einrichtung Multihost klappt nicht - Meldung Slave:
    Ist das ein Raspberry da? Ist das '1-wire'-Interface aktiv?
      @thomas-braun sagte in Einrichtung Multihost klappt nicht - Meldung Slave:
      laut username ein pi und ein bookworm.
      SMSS Thomas BraunT 2 Antworten Letzte Antwort
        SMSS Offline
        SMSS Offline
        SMS
        @homoran hier habe ich es aktiviert:
        sudo raspi-config
          @homoran sagte in Einrichtung Multihost klappt nicht - Meldung Slave:
          Auf usernames geb ich nix. Scheinbar wird pi für alles mögliche verwendet. Wobei das selbst auf Raspberry OS nicht mehr verwendet werden soll sondern individuelle usernames empfohlen werden.
          • SMSS SMS
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            ds18b20.1
            haselchenH Offline
            haselchenH Offline
            haselchen
            ds18b20.1
            Hast du noch eine andere Instanz davon?
            ds18b20.1
              jepp, ist auch bei mir der Standard Username, egal wo. Abet mit anderen Passworten
              SMSS 1 Antwort Letzte Antwort
                SMSS Offline
                SMSS Offline
                SMS
                schrieb am zuletzt editiert von SMS
                @homoran also der pi hat schon einen eigenen Namen. Nur beim anmelden ist der Benutzername pi.
                Auf einem anderen pi läuft die Instanz. Denke das ich ein Spannungsproblem habe. 4 von den 8 Sensoren zeigen Werte an. Muss ich morgen mal schauen
                jetzt muss ich noch grafana installieren. Nach deiner Anleitung:
                pi@Homee:~ $ sudo apt-get install -y apt-transport-https
                Reading package lists... Done
                The following packages were automatically installed and are no longer required:
                  libraspberrypi0 libwpe-1.0-1 libwpebackend-fdo-1.0-1
                Use 'sudo apt autoremove' to remove them.
                The following NEW packages will be installed:
                  apt-transport-https
                0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                Need to get 25.2 kB of archives.
                After this operation, 35.8 kB of additional disk space will be used.
                Get:1 http://deb.debian.org/debian bookworm/main arm64 apt-transport-https all 2.6.1 [25.2 kB]
                Fetched 25.2 kB in 0s (295 kB/s)
                Selecting previously unselected package apt-transport-https.
                (Reading database ... 158457 files and directories currently installed.)
                Preparing to unpack .../apt-transport-https_2.6.1_all.deb ...
                Unpacking apt-transport-https (2.6.1) ...
                Setting up apt-transport-https (2.6.1) ...
                pi@Homee:~ $ sudo apt-get install -y software-properties-common wget
                wget is already the newest version (1.21.3-1+b1).
                wget set to manually installed.
                The following additional packages will be installed:
                  python3-httplib2 python3-lazr.restfulclient python3-lazr.uri python3-pyparsing python3-software-properties python3-wadllib
                Suggested packages:
                  python-pyparsing-doc
                0 upgraded, 7 newly installed, 0 to remove and 0 not upgraded.
                Need to get 370 kB of archives.
                After this operation, 1,836 kB of additional disk space will be used.
                Get:1 http://deb.debian.org/debian bookworm/main arm64 python3-pyparsing all 3.0.9-1 [138 kB]
                Get:2 http://deb.debian.org/debian bookworm/main arm64 python3-httplib2 all 0.20.4-3 [36.0 kB]
                Get:3 http://deb.debian.org/debian bookworm/main arm64 python3-lazr.uri all 1.0.6-3 [13.7 kB]
                Get:4 http://deb.debian.org/debian bookworm/main arm64 python3-wadllib all 1.3.6-4 [37.2 kB]
                Get:5 http://deb.debian.org/debian bookworm/main arm64 python3-lazr.restfulclient all 0.14.5-1 [50.4 kB]
                Get:6 http://deb.debian.org/debian bookworm/main arm64 python3-software-properties all 0.99.30-4 [32.7 kB]
                Get:7 http://deb.debian.org/debian bookworm/main arm64 software-properties-common all 0.99.30-4 [62.0 kB]
                Fetched 370 kB in 0s (4,820 kB/s)
                Selecting previously unselected package python3-pyparsing.
                (Reading database ... 158461 files and directories currently installed.)
                Preparing to unpack .../0-python3-pyparsing_3.0.9-1_all.deb ...
                Unpacking python3-pyparsing (3.0.9-1) ...
                Selecting previously unselected package python3-httplib2.
                Preparing to unpack .../1-python3-httplib2_0.20.4-3_all.deb ...
                Unpacking python3-httplib2 (0.20.4-3) ...
                Selecting previously unselected package python3-lazr.uri.
                Preparing to unpack .../2-python3-lazr.uri_1.0.6-3_all.deb ...
                Unpacking python3-lazr.uri (1.0.6-3) ...
                Selecting previously unselected package python3-wadllib.
                Preparing to unpack .../3-python3-wadllib_1.3.6-4_all.deb ...
                Unpacking python3-wadllib (1.3.6-4) ...
                Selecting previously unselected package python3-lazr.restfulclient.
                Preparing to unpack .../4-python3-lazr.restfulclient_0.14.5-1_all.deb ...
                Unpacking python3-lazr.restfulclient (0.14.5-1) ...
                Selecting previously unselected package python3-software-properties.
                Preparing to unpack .../5-python3-software-properties_0.99.30-4_all.deb ...
                Unpacking python3-software-properties (0.99.30-4) ...
                Selecting previously unselected package software-properties-common.
                Preparing to unpack .../6-software-properties-common_0.99.30-4_all.deb ...
                Unpacking software-properties-common (0.99.30-4) ...
                Setting up python3-lazr.uri (1.0.6-3) ...
                Setting up python3-pyparsing (3.0.9-1) ...
                Setting up python3-wadllib (1.3.6-4) ...
                Setting up python3-httplib2 (0.20.4-3) ...
                Setting up python3-lazr.restfulclient (0.14.5-1) ...
                Setting up python3-software-properties (0.99.30-4) ...
                Setting up software-properties-common (0.99.30-4) ...
                Processing triggers for man-db (2.11.2-2) ...
                Processing triggers for dbus (1.14.10-1~deb12u1) ...
                pi@Homee:~ $ sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
                pi@Homee:~ $ echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
                pi@Homee:~ $
                Alles richtig?
                • SMSS SMS
                    apt-transport-https
                  Suggested packages:
                  pi@Homee:~ $
                  Alles richtig?
                  @sms
                  Laufen die Kernelmodule dazu?
                  lsmod
                  bzw
                  lsmod | grep w1
                  anschauen.
                  Wobei ich von 1-wire keine Ahnung habe, ob sich das nicht wegen GPIO-Umstellereien im aktuellen Raspberry OS wieder alles geändert hat.
                  • SMSS SMS
                      apt-transport-https
                    Suggested packages:
                    pi@Homee:~ $
                    Alles richtig?
                    Alles richtig?
                    Ich denke.
                    Hast du das aus den 'phantastischen Repos' kopiert?
                      @sms
                      lsmod
                      bzw
                      lsmod | grep w1
                      anschauen.
                      SMSS Offline
                      SMSS Offline
                      SMS
                      @sms
                      lsmod
                      pi@Homee:~ $ lsmod
                      Module                  Size  Used by
                      rfcomm                 53248  4
                      snd_seq_dummy          12288  0
                      snd_hrtimer            12288  1
                      snd_seq                81920  7 snd_seq_dummy
                      snd_seq_device         16384  1 snd_seq
                      cmac                   12288  3
                      algif_hash             12288  1
                      aes_arm64              12288  3
                      aes_generic            32768  1 aes_arm64
                      algif_skcipher         12288  1
                      af_alg                 28672  6 algif_hash,algif_skcipher
                      bnep                   24576  2
                      brcmfmac_wcc           12288  0
                      ftdi_sio               53248  0
                      brcmfmac              348160  1 brcmfmac_wcc
                      usbserial              45056  1 ftdi_sio
                      binfmt_misc            16384  1
                      hci_uart               49152  0
                      btbcm                  24576  1 hci_uart
                      brcmutil               24576  1 brcmfmac
                      bluetooth             606208  33 hci_uart,btbcm,bnep,rfcomm
                      rpivid_hevc            45056  0
                      bcm2835_codec          45056  0
                      cfg80211              995328  1 brcmfmac
                      bcm2835_isp            28672  0
                      v4l2_mem2mem           53248  2 bcm2835_codec,rpivid_hevc
                      ecdh_generic           16384  2 bluetooth
                      bcm2835_v4l2           40960  0
                      bcm2835_mmal_vchiq     36864  3 bcm2835_codec,bcm2835_v4l2,bcm2835_isp
                      ecc                    36864  1 ecdh_generic
                      videobuf2_vmalloc      12288  1 bcm2835_v4l2
                      videobuf2_dma_contig    20480  3 bcm2835_codec,rpivid_hevc,bcm2835_isp
                      videobuf2_memops       12288  2 videobuf2_vmalloc,videobuf2_dma_contig
                      libaes                 12288  3 aes_arm64,bluetooth,aes_generic
                      raspberrypi_hwmon      12288  0
                      videobuf2_v4l2         32768  5 bcm2835_codec,bcm2835_v4l2,rpivid_hevc,v4l2_mem2mem,bcm2835_isp
                      rfkill                 32768  6 bluetooth,cfg80211
                      videodev              319488  6 bcm2835_codec,videobuf2_v4l2,bcm2835_v4l2,rpivid_hevc,v4l2_mem2mem,bcm2835_isp
                      raspberrypi_gpiomem    12288  0
                      videobuf2_common       73728  9 bcm2835_codec,videobuf2_vmalloc,videobuf2_dma_contig,videobuf2_v4l2,bcm2835_v4l2,rpivid_hevc,v4l2_mem2mem,videobuf2_memops,bcm2835_isp
                      mc                     65536  7 videodev,bcm2835_codec,videobuf2_v4l2,videobuf2_common,rpivid_hevc,v4l2_mem2mem,bcm2835_isp
                      snd_bcm2835            24576  1
                      vc_sm_cma              28672  2 bcm2835_mmal_vchiq,bcm2835_isp
                      nvmem_rmem             12288  0
                      uio_pdrv_genirq        12288  0
                      uio                    20480  1 uio_pdrv_genirq
                      i2c_dev                16384  0
                      fuse                  139264  5
                      dm_mod                143360  0
                      ip_tables              32768  0
                      x_tables               57344  1 ip_tables
                      ipv6                  573440  73
                      vc4                   372736  10
                      snd_soc_hdmi_codec     20480  2
                      drm_display_helper     16384  1 vc4
                      cec                    53248  1 vc4
                      drm_dma_helper         24576  2 vc4
                      drm_kms_helper        233472  2 drm_dma_helper,vc4
                      snd_soc_core          307200  2 vc4,snd_soc_hdmi_codec
                      v3d                    90112  4
                      snd_compress           20480  1 snd_soc_core
                      gpu_sched              53248  1 v3d
                      drm_shmem_helper       24576  1 v3d
                      snd_pcm_dmaengine      16384  1 snd_soc_core
                      drm                   688128  17 gpu_sched,drm_kms_helper,drm_dma_helper,v3d,vc4,drm_shmem_helper,drm_display_helper
                      drm_panel_orientation_quirks    24576  1 drm
                      snd_pcm               151552  5 snd_bcm2835,snd_soc_hdmi_codec,snd_compress,snd_soc_core,snd_pcm_dmaengine
                      i2c_brcmstb            12288  0
                      snd_timer              36864  3 snd_seq,snd_hrtimer,snd_pcm
                      snd                   122880  12 snd_seq,snd_seq_device,snd_bcm2835,snd_soc_hdmi_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm
                      backlight              24576  1 drm
                      pi@Homee:~ $
                      bzw
                      lsmod | grep w1
                      pi@Homee:~ $ lsmod | grep w1
                      pi@Homee:~ $
                      Ja, habe ich von dir
                      • SMSS SMS
                        @sms
                        lsmod
                        pi@Homee:~ $ lsmod
                        Module                  Size  Used by
                        rfcomm                 53248  4
                        snd_hrtimer            12288  1
                        cmac                   12288  3
                        algif_hash             12288  1
                        aes_arm64              12288  3
                        bnep                   24576  2
                        ftdi_sio               53248  0
                        binfmt_misc            16384  1
                        hci_uart               49152  0
                        rpivid_hevc            45056  0
                        bcm2835_isp            28672  0
                        snd_bcm2835            24576  1
                        nvmem_rmem             12288  0
                        i2c_dev                16384  0
                        fuse                  139264  5
                        dm_mod                143360  0
                        ip_tables              32768  0
                        ipv6                  573440  73
                        vc4                   372736  10
                        cec                    53248  1 vc4
                        v3d                    90112  4
                        i2c_brcmstb            12288  0
                        pi@Homee:~ $
                        bzw
                        lsmod | grep w1
                        pi@Homee:~ $
                        @sms
                        Dann halt wie üblich:
                        sudo apt update
                        sudo apt install grafana
                        Zu 1wire kann ich dir nix sagen, hab ich noch nie mit zu tun gehabt.
                        • SMSS Offline
                          SMSS Offline
                          SMS
                          Da schau ich morgen mal nach
                            @sms
                            sudo apt update
                            SMSS Offline
                            SMSS Offline
                            SMS
                            @sms
                            sudo apt update
                            Und nun:
                            pi@Homee:~ $ sudo apt install grafana
                              musl
                              grafana musl
                            0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                            Need to get 111 MB of archives.
                            After this operation, 424 MB of additional disk space will be used.
                            Do you want to continue? [Y/n] y
                            Get:1 http://deb.debian.org/debian bookworm/main arm64 musl arm64 1.2.3-1 [392 kB]
                            Get:2 https://apt.grafana.com stable/main arm64 grafana arm64 11.0.0 [111 MB]
                            Fetched 111 MB in 9s (12.0 MB/s)
                            Selecting previously unselected package musl:arm64.
                            (Reading database ... 158707 files and directories currently installed.)
                            Preparing to unpack .../musl_1.2.3-1_arm64.deb ...
                            Unpacking musl:arm64 (1.2.3-1) ...
                            Selecting previously unselected package grafana.
                            Preparing to unpack .../grafana_11.0.0_arm64.deb ...
                            Unpacking grafana (11.0.0) ...
                            Setting up musl:arm64 (1.2.3-1) ...
                            Setting up grafana (11.0.0) ...
                            Adding system user `grafana' (UID 112) ...
                            Adding new user `grafana' (UID 112) with group `grafana' ...
                            Not creating home directory `/usr/share/grafana'.
                            ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
                             sudo /bin/systemctl daemon-reload
                             sudo /bin/systemctl enable grafana-server
                            ### You can start grafana-server by executing
                             sudo /bin/systemctl start grafana-server
                            • SMSS SMS
                              @sms
                              sudo apt update
                              Und nun:
                                musl
                                grafana musl
                              @sms
                              Gut. Wenn das ganze automatisch gestartet werden soll halt die drei systemctl-Befehle noch eingeben.
                                @sms
                                SMSS Offline
                                SMSS Offline
                                SMS
                                @thomas-braun welches PW ist gemeint?
                                pi@Homee:~ $ sudo systemctl enable grafana-server
                                Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
                                Executing: /lib/systemd/systemd-sysv-install enable grafana-server
                                Created symlink /etc/systemd/system/multi-user.target.wants/grafana-server.service → /lib/systemd/system/grafana-server.service.
                                pi@Homee:~ $ systemctl enable grafana-server.service
                                ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ====
                                Authentication is required to reload the systemd state.
                                Authenticating as: ,,, (pi)
                                Password:
                                ==== AUTHENTICATION COMPLETE ====
                                Password:
                                ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ====
                                Authentication is required to manage system service or unit files.
                                Password:
                                Password:
                                polkit-agent-helper-1: pam_authenticate failed: Authentication failure
                                ==== AUTHENTICATION FAILED ====
                                Reload daemon failed: Access denied
                                pi@Homee:~ $
                                pi@Homee:~ $ systemctl status grafana-server
                                ○ grafana-server.service - Grafana instance
                                     Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; preset: enabled)
                                     Active: inactive (dead)
                                       Docs: http://docs.grafana.org
                                • SMSS SMS
                                  Password:
                                  Password:
                                  Password:
                                  Password:
                                  pi@Homee:~ $
                                  @sms
                                  Muss mit sudo eingeleitet werden.
                                  Deswegen steht das auch so drin.
                                    @sms
                                    SMSS Offline
                                    SMSS Offline
                                    SMS
                                    OK, auf die Seite komme ich jetzt wieder. Aber wie ist der Benutzername und das Passwort? Das Alte funzt nicht mehr.
                                    • SMSS SMS
                                      Ich verwende Grafana nicht.
                                      Aber war da nicht irgendwas mit Token, die da benutzt werden?
                                        SMSS Offline
                                        SMSS Offline
                                        SMS
                                        @thomas-braun keine Ahnung
                                        • SMSS SMS
                                          keine Ahnung
                                          Ich auch nicht. Steht bestimmt in der Doku zu Grafana drin.
                                          SMSS 2 Antworten Letzte Antwort
