  4. ZigBee Störung
ZigBee Störung
56 Beiträge 9 Kommentatoren 4.7k Aufrufe 6 Beobachtet
  • L legro
    Hier das Log von einem Neustart ..
    zigbee.0
    2024-05-07 19:32:38.817	info	Device '0x00124b000621ad0e' announced itself
    zigbee.0
    2024-05-07 16:56:41.462	warn	Send command to 0x001788010db82a55 failed with: Code 205 (No network route)
    zigbee.0
    2024-05-07 16:56:19.683	warn	Send command to 0x001788010db82a55 failed with: Code 205 (No network route)
    zigbee.0
    2024-05-07 16:52:55.887	info	Device '0x00124b00077b7fe8' announced itself
    zigbee.0
    2024-05-07 16:52:37.138	info	Device '0x00124b0008a50109' announced itself
    zigbee.0
    2024-05-07 16:52:34.018	info	Device '0x00124b00074e8fdf' announced itself
    zigbee.0
    2024-05-07 16:46:44.677	error	Error 225 on send command to 0x001788010db82a55. Error: Error: ZCL command 0x001788010db82a55/11 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:48:17) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1131:32) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
    zigbee.0
    2024-05-07 16:46:38.827	info	Device '0x00124b00090da34c' announced itself
    zigbee.0
    2024-05-07 16:46:14.310	warn	Send command to 0x001788010db82a55 failed with: Code 205 (No network route)
    zigbee.0
    2024-05-07 16:43:29.298	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100QXL","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100QXL","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyS0"}]
    @legro sagte in ZigBee Störung:
    bitte beantworte meine Frage und die von @MartinP
    L 1 Antwort Letzte Antwort
      legro
      schrieb am zuletzt editiert von legro
      pi@raspiBullseye:~ $ ls -l /dev/serial/by-id
      total 0
      lrwxrwxrwx 1 root root 13 May  7 16:17 usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if00 -> ../../ttyACM0
      lrwxrwxrwx 1 root root 13 May  7 16:17 usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if03 -> ../../ttyACM1
      pi@raspiBullseye:~ $ ls -l /dev/tty*
      crw-rw-rw- 1 root tty       5,  0 May  7 16:17 /dev/tty
      crw--w---- 1 root tty       4,  0 May  7 16:17 /dev/tty0
      crw------- 1 pi   tty       4,  1 May  7 16:39 /dev/tty1
      crw--w---- 1 root tty       4, 10 May  7 16:17 /dev/tty10
      crw--w---- 1 root tty       4, 11 May  7 16:17 /dev/tty11
      crw--w---- 1 root tty       4, 12 May  7 16:17 /dev/tty12
      crw--w---- 1 root tty       4, 13 May  7 16:17 /dev/tty13
      crw--w---- 1 root tty       4, 14 May  7 16:17 /dev/tty14
      crw--w---- 1 root tty       4, 15 May  7 16:17 /dev/tty15
      crw--w---- 1 root tty       4, 16 May  7 16:17 /dev/tty16
      crw--w---- 1 root tty       4, 17 May  7 16:17 /dev/tty17
      crw--w---- 1 root tty       4, 18 May  7 16:17 /dev/tty18
      crw--w---- 1 root tty       4, 19 May  7 16:17 /dev/tty19
      crw--w---- 1 root tty       4,  2 May  7 16:17 /dev/tty2
      crw--w---- 1 root tty       4, 20 May  7 16:17 /dev/tty20
      crw--w---- 1 root tty       4, 21 May  7 16:17 /dev/tty21
      crw--w---- 1 root tty       4, 22 May  7 16:17 /dev/tty22
      crw--w---- 1 root tty       4, 23 May  7 16:17 /dev/tty23
      crw--w---- 1 root tty       4, 24 May  7 16:17 /dev/tty24
      crw--w---- 1 root tty       4, 25 May  7 16:17 /dev/tty25
      crw--w---- 1 root tty       4, 26 May  7 16:17 /dev/tty26
      crw--w---- 1 root tty       4, 27 May  7 16:17 /dev/tty27
      crw--w---- 1 root tty       4, 28 May  7 16:17 /dev/tty28
      crw--w---- 1 root tty       4, 29 May  7 16:17 /dev/tty29
      crw--w---- 1 root tty       4,  3 May  7 16:17 /dev/tty3
      crw--w---- 1 root tty       4, 30 May  7 16:17 /dev/tty30
      crw--w---- 1 root tty       4, 31 May  7 16:17 /dev/tty31
      crw--w---- 1 root tty       4, 32 May  7 16:17 /dev/tty32
      crw--w---- 1 root tty       4, 33 May  7 16:17 /dev/tty33
      crw--w---- 1 root tty       4, 34 May  7 16:17 /dev/tty34
      crw--w---- 1 root tty       4, 35 May  7 16:17 /dev/tty35
      crw--w---- 1 root tty       4, 36 May  7 16:17 /dev/tty36
      crw--w---- 1 root tty       4, 37 May  7 16:17 /dev/tty37
      crw--w---- 1 root tty       4, 38 May  7 16:17 /dev/tty38
      crw--w---- 1 root tty       4, 39 May  7 16:17 /dev/tty39
      crw--w---- 1 root tty       4,  4 May  7 16:17 /dev/tty4
      crw--w---- 1 root tty       4, 40 May  7 16:17 /dev/tty40
      crw--w---- 1 root tty       4, 41 May  7 16:17 /dev/tty41
      crw--w---- 1 root tty       4, 42 May  7 16:17 /dev/tty42
      crw--w---- 1 root tty       4, 43 May  7 16:17 /dev/tty43
      crw--w---- 1 root tty       4, 44 May  7 16:17 /dev/tty44
      crw--w---- 1 root tty       4, 45 May  7 16:17 /dev/tty45
      crw--w---- 1 root tty       4, 46 May  7 16:17 /dev/tty46
      crw--w---- 1 root tty       4, 47 May  7 16:17 /dev/tty47
      crw--w---- 1 root tty       4, 48 May  7 16:17 /dev/tty48
      crw--w---- 1 root tty       4, 49 May  7 16:17 /dev/tty49
      crw--w---- 1 root tty       4,  5 May  7 16:17 /dev/tty5
      crw--w---- 1 root tty       4, 50 May  7 16:17 /dev/tty50
      crw--w---- 1 root tty       4, 51 May  7 16:17 /dev/tty51
      crw--w---- 1 root tty       4, 52 May  7 16:17 /dev/tty52
      crw--w---- 1 root tty       4, 53 May  7 16:17 /dev/tty53
      crw--w---- 1 root tty       4, 54 May  7 16:17 /dev/tty54
      crw--w---- 1 root tty       4, 55 May  7 16:17 /dev/tty55
      crw--w---- 1 root tty       4, 56 May  7 16:17 /dev/tty56
      crw--w---- 1 root tty       4, 57 May  7 16:17 /dev/tty57
      crw--w---- 1 root tty       4, 58 May  7 16:17 /dev/tty58
      crw--w---- 1 root tty       4, 59 May  7 16:17 /dev/tty59
      crw--w---- 1 root tty       4,  6 May  7 16:17 /dev/tty6
      crw--w---- 1 root tty       4, 60 May  7 16:17 /dev/tty60
      crw--w---- 1 root tty       4, 61 May  7 16:17 /dev/tty61
      crw--w---- 1 root tty       4, 62 May  7 16:17 /dev/tty62
      crw--w---- 1 root tty       4, 63 May  7 16:17 /dev/tty63
      crw--w---- 1 root tty       4,  7 May  7 16:17 /dev/tty7
      crw--w---- 1 root tty       4,  8 May  7 16:17 /dev/tty8
      crw--w---- 1 root tty       4,  9 May  7 16:17 /dev/tty9
      crw-rw---- 1 root dialout 166,  0 May  7 21:43 /dev/ttyACM0
      crw-rw---- 1 root dialout 166,  1 May  7 16:17 /dev/ttyACM1
      crw------- 1 root root      5,  3 May  7 16:17 /dev/ttyprintk
      crw-rw---- 1 root dialout   4, 64 May  7 16:17 /dev/ttyS0
      Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
      • L legro
        total 0
        @legro und die Antwort meine Frage????
        @homoran sagte in ZigBee Störung:
        hast du jetzt auf /dev/serial/by-id/ umgestellt?
        ...oder immer noch auf /ttyACM...
        Wenn immer noch, dann welchen?
          legro
          Wo soll ich das wie machen?
          • L legro
            du sollst seit Stunden die Schnittstelle in der Konfiguration des Zigbee Adapters auf die Schreibweise mit /dev/serial/ by-id/ ändern!
              legro
              Danach frage ich doch gerade. Wie?
              • L legro
                Da wo man den COM-Port definiert. Trag da
                /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if00
                ein, falls da was anderes drin steht.
                  legro
                  Ich fürchte, ich habe noch immer nicht verstanden, was ich genau machen soll. So sieht das bei mir aus ..
                  • L legro
                    und wie endet dort die Zeile mit /dev/serial.....
                      legro
                      Seit Jahr und Tag hat das if00 stets funktioniert.
                      • L legro
                        MartinPM Online
                        MartinPM Online
                        MartinP
                        @legro Ist dieses "Network = DDDDDDDDDDDDDDDDDDDDDDDA" auch schon immer so gewesen?
                        Langsam gehen mir die Ideen aus ...
                        Ob das Betriebssystem gemeint hat, den Braille-TTY Prozess zu starten könntest Du noch prüfen.
                        Siehe: https://github.com/arduino/help-center-content/issues/155
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          können wir uns jetzt mal dem Problem widmen.. anstatt Sinlos irgendwelche Konfigurationen durchzugehen (sry aber anders kann ich es nicht audrücken)
                          @legro poste bitte die nvbackup.json aus dem Ordner /opt/iobroker/iobroker-data/zigbee_0
                          sollte diese ok sein. wird mit dem Board was nicht ok sein und ich würde es neu flashen..
                          wie @Asgothian schon geschrieben hat .. es stimmt mit dem Netzwerk was nicht ..NICHT mit den Adapter Einstellungen
                          • arteckA arteck
                            legro
                            @arteck
                            Erst einmal vielen Dank an alle, die mir - dem schon lange die Ideen ausgegangen sind - helfen.
                            Hier die gewünschten Daten ..
                              "metadata": {
                                "format": "zigpy/open-coordinator-backup",
                                "version": 1,
                                "source": "zigbee-herdsman@0.41.2",
                                "internal": {
                                  "date": "2024-05-07T04:10:45.563Z",
                                  "znpVersion": 1
                              "stack_specific": {
                                "zstack": {
                                  "tclk_seed": "960898014577f65027ed5828c80758f4"
                              "coordinator_ieee": "00124b001caa6cf6",
                              "pan_id": "1a62",
                              "extended_pan_id": "ddddddddddddddda",
                              "nwk_update_id": 0,
                              "security_level": 5,
                              "channel": 11,
                              "channel_mask": [
                              "network_key": {
                                "key": "01030507090b0d0f00020406080a0c0a",
                                "sequence_number": 0,
                                "frame_counter": 10115573
                              "devices": [
                                  "nwk_address": "cc89",
                                  "ieee_address": "00124b0008a50109",
                                  "is_child": true,
                                  "link_key": {
                                    "key": "51f53300984a5777ff5182e55863da07",
                                    "rx_counter": 0,
                                    "tx_counter": 748
                                  "nwk_address": "8d4d",
                                  "ieee_address": "00124b000621ad0e",
                                  "is_child": true,
                                  "link_key": {
                                    "key": "96ac6471f61b35ed5685e90158bf8408",
                                    "rx_counter": 0,
                                    "tx_counter": 754
                                  "nwk_address": "1991",
                                  "ieee_address": "00124b00074e8fdf",
                                  "is_child": true,
                                  "link_key": {
                                    "key": "d8d7ba9108d31345a8791e20ed133ac8",
                                    "rx_counter": 0,
                                    "tx_counter": 934
                                  "nwk_address": "0de6",
                                  "ieee_address": "00124b00077b7fe8",
                                  "is_child": true,
                                  "link_key": {
                                    "key": "ad088d5727a64a28207823f396438a01",
                                    "rx_counter": 0,
                                    "tx_counter": 717
                                  "nwk_address": "7d27",
                                  "ieee_address": "00124b0008a68663",
                                  "is_child": true,
                                  "link_key": {
                                    "key": "3b723000984a577795d681e55863da07",
                                    "rx_counter": 0,
                                    "tx_counter": 399
                                  "nwk_address": "b472",
                                  "ieee_address": "00124b0008e7395c",
                                  "is_child": true,
                                  "link_key": {
                                    "key": "74f1e050f4dd1a985d7c90fe506cff58",
                                    "rx_counter": 0,
                                    "tx_counter": 747
                                  "nwk_address": "e437",
                                  "ieee_address": "00124b00090da34c",
                                  "is_child": true,
                                  "link_key": {
                                    "key": "baf32ae45863da0714579b01984a5777",
                                    "rx_counter": 0,
                                    "tx_counter": 751
                                  "nwk_address": "642a",
                                  "ieee_address": "00124b0008e73540",
                                  "is_child": true,
                                  "link_key": {
                                    "key": "18c17100984a5777b665c0e55863da07",
                                    "rx_counter": 0,
                                    "tx_counter": 752
                                  "nwk_address": "84b8",
                                  "ieee_address": "8418260000074b81",
                                  "is_child": false,
                                  "link_key": {
                                    "key": "f6bd5727ed7e304c8613f39608be19c1",
                                    "rx_counter": 0,
                                    "tx_counter": 748
                                  "nwk_address": "e20c",
                                  "ieee_address": "841826000007fd2c",
                                  "is_child": false,
                                  "link_key": {
                                    "key": "b4fc4277f6763f6974d5cf0758d28e8c",
                                    "rx_counter": 0,
                                    "tx_counter": 748
                                  "nwk_address": "d001",
                                  "ieee_address": "841826000007feec",
                                  "is_child": false,
                                  "link_key": {
                                    "key": "a989f15027cb40ac24f95ff4962e8085",
                                    "rx_counter": 0,
                                    "tx_counter": 748
                                  "nwk_address": "ab83",
                                  "ieee_address": "8418260000ca4b3f",
                                  "is_child": false,
                                  "link_key": {
                                    "key": "38133e9608be19c148bd9a27ed7e304c",
                                    "rx_counter": 0,
                                    "tx_counter": 748
                                  "nwk_address": "ff8b",
                                  "ieee_address": "001788010278c53e",
                                  "is_child": false,
                                  "link_key": {
                                    "key": "f6c220f697808f017bb28e5226654f28",
                                    "rx_counter": 0,
                                    "tx_counter": 220
                                  "nwk_address": "008f",
                                  "ieee_address": "001788010db82a55",
                                  "is_child": false,
                                  "link_key": {
                                    "key": "72c7e025c98f4ff4c322200c44ffe150",
                                    "rx_counter": 0,
                                    "tx_counter": 165
                            An der Konfiguration habe ich seit deren Einrichtung nie mehr etwas geändert. Die Anlage lief seit 2020 problemlos. Erst nach den Stromausfällen - es haute uns drei Tage in Folge immer wieder mal den FI raus - traten diese Fehler auf.
                            Da der Raspberry Pi hinter einer USV liegt, sollte keine Überspannung etwas beschädigt haben können.
                            • L legro
                              @arteck
                                "metadata": {
                                  "version": 1,
                                  "internal": {
                                    "znpVersion": 1
                                "stack_specific": {
                                  "zstack": {
                                "pan_id": "1a62",
                                "nwk_update_id": 0,
                                "channel": 11,
                                "channel_mask": [
                                "network_key": {
                                "devices": [
                                    "is_child": true,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 748
                                    "is_child": true,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 754
                                    "is_child": true,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 934
                                    "is_child": true,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 717
                                    "is_child": true,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 399
                                    "is_child": true,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 747
                                    "is_child": true,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 751
                                    "is_child": true,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 752
                                    "is_child": false,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 748
                                    "is_child": false,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 748
                                    "is_child": false,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 748
                                    "is_child": false,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 748
                                    "is_child": false,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 220
                                    "is_child": false,
                                    "link_key": {
                                      "rx_counter": 0,
                                      "tx_counter": 165
                              arteckA Offline
                              arteckA Offline
                              arteck
                              @legro ok die einstellungen passen.. hätte mich auch gewundert wenn nicht .. da sonst der adapter beim start gemeckert hätte
                              läuft der adapter jetzt nach den ?? ist der grün ?
                              kannst du die
                              9290024406A - Philips Hue P45 light bulb (Router)
                              neu anlernen
                              L 2 Antworten Letzte Antwort
                              • arteckA arteck
                                kannst du die
                                neu anlernen
                                legro
                                @arteck sagte in ZigBee Störung:
                                kannst du die
                                neu anlernen
                                Eigentlich komme ich mit eurem Adapter richtig gut klar. Du und Asgothian habt mir vor vier Jahren geholfen, meine BITRON-Geräte im eurem ZigBee-Adapter ans Laufen zu bekommen. Da konnte ich viel von euch lernen.👍 Aber das ist eben schon vier Jahre her, vieles habe ich wieder vergessen.
                                Nun aber zum Anlernen der HUE P45 Lampe ..
                                Hierzu muss ich doch die Lampe erst einmal zurücksetzen. Dies habe ich bisher stets mittels der HUE-App gemacht, indem ich die Lampen als verwaiste Geräte über ihre Seriennummer ansprach, wobei sie ja zurückgesetzt werden. Anschließend habe ich sie aus der HUE-App wieder gelöscht, wodurch sie ja ebenfalls zurückgesetzt werden.
                                Gibt es einen einfacheren Weg?
                                • arteckA arteck
                                  kannst du die
                                  neu anlernen
                                  legro
                                  neu anlernen
                                  Da ich den Umweg über die HUE-App scheute, habe ich folgendes probiert ..
                                  • Ich habe versucht, die P45 über den ZigBee-Adapter zu löschen
                                  • Dies schlug aufgrund der Störungen natürlich fehl, aber an der Kachel der P45 im ZigBee-Adapter erschien das Symbol zum Pairen für diese Lampe.
                                  • Ich klickte auf dieses Pairing-Symbol, dabei erhielt ich die nachfolgende dargestellte Ausgabe ..
                                  Error: Failed to open the network: Error: Data request failed with error: 'MAC channel access failure' (225)
                                      at GreenPower.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/greenPower.ts:229:13)
                                      at Controller.permitJoinInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:251:13)
                                      at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:238:9)
                                      at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:525:17). undefined
                                  Pairing started 0x001788010db82a55
                                  • L legro
                                    neu anlernen
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @legro der Button ist nicht dafür da...
                                    hast du einen Dimmer ?? von Hue..damit gehts auch
                                    ansonsten muss der coordinator an die Lampe dran .. dann gehts auch mit dem Touchlink
                                    da wo der quadrat ist..
                                    • arteckA arteck
                                      legro
                                      Ich hab's geahnt.😖
                                      Einen Dimmer habe ich nicht. Schließlich will ich die HUE-Bridge künftig komplett ersetzen. Ich habe sie daher nur noch in Betrieb, um nach und nach alles auf den den ZigBee-Coordinator CC26X2R1 umzustellen.
                                      Das Einfachste wird daher sein, ich versuche die Lampe in die Nähe (wenige cm ??) des Coordinators zu bringen und per Touchlink Reset und Neuanlernen zu initiieren.
                                      • arteckA arteck
                                        legro
                                        @arteck
                                        Ich habe die Lampe wie hier (über die HUE-App) beschrieben zurückgesetzt. Anschließend versuchte ich sie über den CC26X2R1 zu koppeln. Leider funktionierte die Kopplung nicht. Die Lampe wurde nicht erkannt.
                                        Und hier die Daten im Log ..
                                        zigbee.0
                                        2024-05-08 12:04:28.185	info	Zigbee: stop joining
                                        zigbee.0
                                        2024-05-08 12:03:26.934	info	Zigbee: allowing new devices to join.
                                        zigbee.0
                                        2024-05-08 12:02:28.450	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100QXL","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100QXL","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyS0"}]
                                        • L legro
                                          @arteck
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          oder die war nicht kopplungsmodus.. kannst du ein anderes Gerät anlernen ?? geht das überhaupt ..??
                                          sonst würde ich mal sagen flash das board neu
                                          nimm die Die seite
                                          https://github.com/Koenkk/Z-Stack-firmware/discussions/478
                                          mit der version 20230922
                                          die läuft relativ stabiel..die neuere hat paar Bugs
