  4. io Broker lässt sich nicht updaten (Linux)
71 Beiträge 4 Kommentatoren 3.6k Aufrufe 3 Beobachtet
    @hans-jürgen-strudler
    iob add heytech
    @thomas-braun sagte in io Broker lässt sich nicht updaten (Linux):
    iob add heytech
    nee, die Instanz ist ja da, das gibt ne zweite!
    iob install heytech müsste die Basis wieder installieren, ggf, gefolgt von iob upload heytech
      iob add heytech
      hans1990H Offline
      hans1990H Offline
      hans1990
      schrieb am zuletzt editiert von hans1990
      @thomas-braun said in io Broker lässt sich nicht updaten (Linux):
      iob add heytech
      da kam das zurück
      pi@rasphj:~ $ iob add heytech
      NPM version: 10.5.0
      Installing iobroker.heytech@1.0.6... (System call)
      added 4 packages, removed 639 packages, and changed 1 package in 16s
      70 packages are looking for funding
        run `npm fund` for details
      host.rasphj install adapter heytech
      upload [4] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/admin.d.ts admin.d.ts video/mp2t
      upload [3] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/heytech.png heytech.png image/png
      upload [2] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/index_m.html index_m.html text/html
      upload [1] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/style.css style.css text/css
      upload [0] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/words.js words.js application/javascript
      host.rasphj object system.adapter.heytech created/updated
      Update "system.adapter.heytech.0"
      host.rasphj create instance heytech
      host.rasphj object system.adapter.heytech.1.alive created
      host.rasphj object system.adapter.heytech.1.connected created
      host.rasphj object system.adapter.heytech.1.compactMode created
      host.rasphj object system.adapter.heytech.1.cpu created
      host.rasphj object system.adapter.heytech.1.cputime created
      host.rasphj object system.adapter.heytech.1.memHeapUsed created
      host.rasphj object system.adapter.heytech.1.memHeapTotal created
      host.rasphj object system.adapter.heytech.1.memRss created
      host.rasphj object system.adapter.heytech.1.uptime created
      host.rasphj object system.adapter.heytech.1.inputCount created
      host.rasphj object system.adapter.heytech.1.outputCount created
      host.rasphj object system.adapter.heytech.1.eventLoopLag created
      host.rasphj object system.adapter.heytech.1.sigKill created
      host.rasphj object system.adapter.heytech.1.logLevel created
      host.rasphj object system.adapter.heytech.1 created
      hier die Logs dazu:
      2024-04-26 17:46:17.534  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
      2024-04-26 17:46:17.538  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
      2024-04-26 17:46:24.616  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T15_46_18_637Z-debug-0.log
      2024-04-26 17:46:24.617  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
      2024-04-26 17:46:25.653  - info: host.rasphj iobroker npm-install: exit 25
      2024-04-26 17:46:26.655  - error: host.rasphj Cannot download and install adapter "heytech@1.0.5". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
      2024-04-26 17:59:32.438  - info: host.rasphj instance system.adapter.heytech.1 started with pid 4420
      2024-04-26 17:59:35.225  - info: heytech.1 (4420) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.heytech, node: v18.20.2, js-controller: 5.0.19
      • hans1990H hans1990
        iob add heytech
        da kam das zurück
        NPM version: 10.5.0
        hier die Logs dazu:
        @hans1990 sagte in io Broker lässt sich nicht updaten (Linux):
        iob del heytech.1
        Und dann nochmal
        iob update
        iob upgrade all
        hans1990H 1 Antwort Letzte Antwort
          iob del heytech.1
          Und dann nochmal
          iob update
          iob upgrade all
          hans1990H Offline
          hans1990H Offline
          hans1990
          iob del heytech.1
          pi@rasphj:~ $ iob del heytech.1
          Delete instance "heytech.1"
          host.rasphj Counted 1 instances of heytech.1
          host.rasphj Counted 14 states of system.adapter.heytech.1
          host.rasphj Counted 14 states (system.adapter.heytech.1.*) from states
          host.rasphj Deleting 15 object(s).
          host.rasphj Deleting 14 state(s).
          iob update
          pi@rasphj:~ $
          iob update
          Used repository: stable
          Adapter    "admin"        : 6.13.16  , installed 5.1.25 [Updatable]
          Adapter    "backitup"     : 2.11.0   , installed 2.2.2  [Updatable]
          Adapter    "discovery"    : 4.4.0    , installed 2.7.3  [Updatable]
          Adapter    "elero-usb-transmitter": 0.5.2, installed 0.5.2
          Adapter    "heytech"      : 1.0.6    , installed 1.0.6
          Adapter    "homee"        : 1.2.0    , installed 1.2.0
          Adapter    "javascript"   : 7.8.0    , installed 5.2.13 [Updatable]
          Controller "js-controller": 5.0.19   , installed 5.0.19
          Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
          Adapter    "nuki"         : 1.6.0    , installed 1.5.0  [Updatable]
          Adapter    "nuki-extended": 2.6.5    , installed 2.3.1  [Updatable]
          Adapter    "octoprint"    : 5.1.0    , installed 1.1.1  [Updatable]
          Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
          Adapter    "shelly"       : 6.8.0    , installed 4.0.7  [Updatable]
          Adapter    "shuttercontrol": 1.7.0   , installed 1.2.1  [Updatable]
          Adapter    "socketio"     : 6.6.1    , installed 6.6.1
          Adapter    "sonoff"       : 3.0.3    , installed 2.4.5  [Updatable]
          Adapter    "synology"     : 3.1.0    , installed 3.1.0
          Adapter    "vis"          : 1.5.4    , installed 1.4.5  [Updatable]
          Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
          Adapter    "web"          : 6.2.5    , installed 3.4.9  [Updatable]
          Adapter    "wled"         : 0.7.2    , installed 0.6.3  [Updatable]
          Ich will alles updaten oder?
            iob del heytech.1
            iob update
            pi@rasphj:~ $
            iob update
            Ja natürlich.
              Ja natürlich.
              hans1990H Offline
              hans1990H Offline
              hans1990
              @Homoran
              DANKE!!! Hat funktioniert. Die Web Oberfläche ist wieder da.
              bei den Adaptern sind aber zwei admins
              wäre admin.1 zu löschen?
                @Homoran
                as I told:
                @homoran sagte in io Broker lässt sich nicht updaten (Linux):
                du hattest zweimal admin auf dem selben port
                  @Homoran
                  iob del admin.1
                  Dann zeig jetzt nochmal die Langfassung vom
                  iob diag
                    iob del admin.1
                    iob diag
                    hans1990H Offline
                    hans1990H Offline
                    hans1990
                    iob diag
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                       Static hostname: rasphj
                             Icon name: computer
                      Operating System: Raspbian GNU/Linux 11 (bullseye)
                                Kernel: Linux 6.1.21-v8+
                          Architecture: arm64
                    Model           : Raspberry Pi 4 Model B Rev 1.1
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : armhf
                    Systemuptime and Load:
                     18:25:22 up 42 min,  1 user,  load average: 0.68, 0.68, 0.67
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** Time and Time Zones ***
                                   Local time: Fri 2024-04-26 18:25:22 CEST
                               Universal time: Fri 2024-04-26 16:25:22 UTC
                                     RTC time: n/a
                                    Time zone: Europe/Vienna (CEST, +0200)
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    pi
                    /home/pi
                    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            3.8G        747M        1.9G        0.0K        1.1G        3.0G
                    Swap:            99M          0B         99M
                    Total:          3.9G        747M        2.0G
                             3794 M total memory
                              748 M used memory
                              817 M active memory
                              866 M inactive memory
                             1949 M free memory
                               67 M buffer memory
                             1029 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** FILESYSTEM ***
                    /dev/root      ext4       59G  4.8G   52G   9% /
                    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                    tmpfs          tmpfs     759M  820K  759M   1% /run
                    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                    [Fri Apr 26 17:42:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:7D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d53cc083-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Fri Apr 26 17:42:36 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Fri Apr 26 17:42:36 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Fri Apr 26 17:42:38 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    TARGET  SOURCE         FSTYPE OPTIONS
                    /       /dev/mmcblk0p2 ext4   rw,noatime
                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                    /var:
                    1.7G    /var/
                    1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
                    1.3G    /var/log
                    202M    /var/cache
                    Archived and active journals take up 1.2G in the file system.
                    /opt/iobroker/backups:
                    24M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    286M    /opt/iobroker/iobroker-data/
                    127M    /opt/iobroker/iobroker-data/files
                    87M     /opt/iobroker/iobroker-data/history
                    57M     /opt/iobroker/iobroker-data/files/javascript.admin
                    45M     /opt/iobroker/iobroker-data/backup-objects
                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                    13M     /opt/iobroker/iobroker-data/objects.jsonl
                    8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
                    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                    6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                    USB-Devices by-id:
                    find: '/dev/serial/by-id/': No such file or directory
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v18.20.2
                    /usr/bin/node           v18.20.2
                    /usr/bin/npm            10.5.0
                    /usr/bin/npx            10.5.0
                    /usr/bin/corepack       0.25.2
                    nodejs:
                      Installed: 18.20.2-1nodesource1
                      Candidate: 18.20.2-1nodesource1
                      Version table:
                     *** 18.20.2-1nodesource1 600
                            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                         18.20.1-1nodesource1 600
                         18.20.0-1nodesource1 600
                         18.19.1-1nodesource1 600
                         18.19.0-1nodesource1 600
                         18.18.2-1nodesource1 600
                         18.18.1-1nodesource1 600
                         18.18.0-1nodesource1 600
                         18.17.1-1nodesource1 600
                         18.17.0-1nodesource1 600
                         18.16.1-1nodesource1 600
                         18.16.0-1nodesource1 600
                         18.15.0-1nodesource1 600
                         18.14.2-1nodesource1 600
                         18.14.1-1nodesource1 600
                         18.14.0-1nodesource1 600
                         18.13.0-1nodesource1 600
                         18.12.0-1nodesource1 600
                         18.11.0-1nodesource1 600
                         18.10.0-1nodesource1 600
                         18.9.1-1nodesource1 600
                         18.9.0-1nodesource1 600
                         18.8.0-1nodesource1 600
                         18.7.0-1nodesource1 600
                         18.6.0-1nodesource1 600
                         18.5.0-1nodesource1 600
                         18.4.0-1nodesource1 600
                         18.3.0-1nodesource1 600
                         18.2.0-1nodesource1 600
                         18.1.0-1nodesource1 600
                         18.0.0-1nodesource1 600
                         12.22.12~dfsg-1~deb11u4 500
                    No problems detected
                    Errors in npm tree:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    admin:          6.13.16
                    javascript:     7.8.0
                    Adapters from github:   0
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : rasphj                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.backitup.0               : backitup              : rasphj                                   -  enabled
                    + system.adapter.discovery.0              : discovery             : rasphj                                   -  enabled
                      system.adapter.elero-usb-transmitter.0  : elero-usb-transmitter : rasphj                                   - disabled
                      system.adapter.flot.0                   : flot                  : rasphj                                   -  enabled
                      system.adapter.heytech.0                : heytech               : rasphj                                   - disabled, port: 1002
                    + system.adapter.history.0                : history               : rasphj                                   -  enabled
                      system.adapter.homee.0                  : homee                 : rasphj                                   - disabled
                    + system.adapter.javascript.0             : javascript            : rasphj                                   -  enabled
                      system.adapter.net-tools.0              : net-tools             : rasphj                                   - disabled
                    + system.adapter.nuki-extended.0          : nuki-extended         : rasphj                                   -  enabled
                    + system.adapter.nuki.0                   : nuki                  : rasphj                                   -  enabled
                    + system.adapter.octoprint.0              : octoprint             : rasphj                                   -  enabled
                      system.adapter.ping.0                   : ping                  : rasphj                                   - disabled
                    + system.adapter.rpi2.0                   : rpi2                  : rasphj                                   -  enabled
                    + system.adapter.shelly.0                 : shelly                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                      system.adapter.shuttercontrol.0         : shuttercontrol        : rasphj                                   - disabled
                    + system.adapter.sonoff.0                 : sonoff                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                      system.adapter.synology.0               : synology              : rasphj                                   - disabled, port: 5000
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : rasphj                                   -  enabled
                      system.adapter.vis.0                    : vis                   : rasphj                                   -  enabled
                    + system.adapter.web.0                    : web                   : rasphj                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.wled.0                   : wled                  : rasphj                                   -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Installed ioBroker-Instances
                    Adapter    "admin"        : 6.13.16  , installed 6.13.16
                    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                    Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                    Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                    Adapter    "vis"          : 1.5.4    , installed 1.5.4
                    Adapter    "web"          : 6.2.5    , installed 6.2.5
                    Adapter    "wled"         : 0.7.2    , installed 0.7.2
                    Adapter    "ws"           : 2.5.11   , installed 2.5.11
                    Objects and States
                    Objects:        3204
                    States:         2100
                    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       34237      5016/io.sonoff.0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14734      495/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14726      495/iobroker.js-con
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14717      526/sshd: /usr/sbin
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38806      5930/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35305      5219/io.admin.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          14719      526/sshd: /usr/sbin
                    tcp6       0      0 :::51989                :::*                    LISTEN      1001       37804      5937/io.nuki-extend
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13799      719/dhcpcd
                    udp        0      0 0.0.0.0:50156           0.0.0.0:*                           108        14626      388/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       33185      4843/io.wled.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14624      388/avahi-daemon: r
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       36491      5530/io.shelly.0
                    udp6       0      0 :::546                  :::*                                0          13811      719/dhcpcd
                    udp6       0      0 :::5353                 :::*                                108        14625      388/avahi-daemon: r
                    udp6       0      0 :::40797                :::*                                108        14627      388/avahi-daemon: r
                    2024-04-26 18:25:45.539  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:25:49.757  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:25:50.522  - warn: sonoff.0 (5016) Client [EnderPro] has invalid password or username
                    2024-04-26 18:25:50.682  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:25:55.853  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:25:56.172  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:26:01.008  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:26:02.056  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:26:06.269  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:26:07.670  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:26:11.441  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:26:13.784  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:26:16.328  - warn: sonoff.0 (5016) Client [EnderPro] has invalid password or username
                    2024-04-26 18:26:16.714  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:26:21.881  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:26:22.508  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:26:27.151  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:26:28.463  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                    2024-04-26 18:26:28.472  - warn: sonoff.0 (5016) Client [shelly1-E8DB84D63938] has invalid password or username
                    2024-04-26 18:26:28.898  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                    2024-04-26 18:26:28.943  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                    2024-04-26 18:26:28.946  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                    2024-04-26 18:26:28.985  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                    2024-04-26 18:26:29.004  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                    2024-04-26 18:26:29.015  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                      iob diag
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : armhf
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            99M          0B         99M
                               3794 M total memory
                                748 M used memory
                                817 M active memory
                               1949 M free memory
                                 67 M buffer memory
                               1029 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      1.7G    /var/
                      1.3G    /var/log
                      202M    /var/cache
                      USB-Devices by-id:
                      /usr/bin/npm            10.5.0
                      /usr/bin/npx            10.5.0
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.13.16
                      javascript:     7.8.0
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        3204
                      States:         2100
                      Pending Updates: 0
                      Wenn das jetzt alles läuft, Backup ziehen und die ganze Kiste NEUinstallieren.
                      Diesmal als reines 64Bit-Lite-System im 'Bookworm'-Release.
                      shelly und sonoff auf dem gleichen Port ist bestimmt auch falsch.
                      HomoranH hans1990H 2 Antworten Letzte Antwort
                        #66
                        @hans1990
                        und diesmal nach dem Restore die Finger weg!
                        jegliche Unterbrechung des rebuilds führt zu einem undefinierten Zustand!!
                        Das kann eine Stunde dauern
                          Hallo! ich möchte meinen ioBroker updaten, da ich das schon lange nicht mehr gemacht habe.
                          Läuft auf einem pi unter linux.
                          Wenn ich der Anleitung folge bekomme ich einen Error:
                          pi@rasphj:~ $ iob upgrade self
                          Update js-controller from @3.3.21 to @5.0.19
                          NPM version: 6.14.16
                          npm install iobroker.js-controller@5.0.19 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                          npm ERR! code ENOTSUP
                          npm ERR! notsup Unsupported engine for iobroker.js-controller@5.0.19: wanted: {"node":">=16.4.0"} (current: {"node":"12.22.12","npm":"6.14.16"})
                          npm ERR! notsup Not compatible with your version of node/npm: iobroker.js-controller@5.0.19
                          npm ERR! notsup Required: {"node":">=16.4.0"}
                          npm ERR! notsup Actual:   {"npm":"6.14.16","node":"12.22.12"}
                          Ich hatte node auch schon auf 18.2 dann bekam ich die Rückmeldung, dass node zwischen 8 und 13 sein muss.
                          Daher glaube ich dass ich den ioBroker nicht direkt von 3.3.21 auf 5.0.19 updaten kann und ein Zwischenschritt auf Version 4.0.x notwendig ist.
                          Kann ich eine Version z.B. 4.0.0 mit dem Befehl iob upgrade self installieren?
                          lg Hans
                          hans1990H Offline
                          hans1990H Offline
                          hans1990
                          #67
                          Danke an @Homoran @Thomas-Braun
                          Zusammenfassung:
                          folgende Befehle haben in diesem Fall den Erfolg gebracht und das Update gelingen lassen.
                          iob stop
                          iob fix
                          iob start
                          iob diag
                          iob nodejs-update
                          iob upgrade self
                          iob add heytech
                          iob del heytech.1
                          iob update
                          iob upgrade all
                            Zusammenfassung:
                            iob stop
                            iob fix
                            iob start
                            iob diag
                            iob nodejs-update
                            iob upgrade self
                            iob add heytech
                            iob del heytech.1
                            iob update
                            iob upgrade all
                            #68
                            @hans1990
                            Da fehlt aber noch ein
                            iob upgrade self
                            Und lass die Kiste künftig nicht mehr so versumpfen.
                              @hans1990
                              iob upgrade self
                              hans1990H Offline
                              hans1990H Offline
                              hans1990
                              #69
                              ich werde darauf achten 🙄
                                hans1990H Offline
                                hans1990H Offline
                                hans1990
                                #70
                                Das Betriebssystem ist bereits auf der SD Karte:
                                Raspberry Pi OS Lite
                                Release date: March 15th 2024
                                System: 64-bit
                                Kernel version: 6.6
                                Debian version: 12 (bookworm)
                                IO Broker installieren würde ich mit:
                                curl -sLf https://iobroker.net/install.sh | bash -
                                Backup ziehen
                                Gibt es ein HOW TO, dass du für Migration der Einstellungen empfehlen kannst?
                                lg Hans
                                  System: 64-bit
                                  Kernel version: 6.6
                                  Backup ziehen
                                  lg Hans
                                  #71
                                  @hans1990
                                  Dann kannst du jetzt dein Backup einspielen. Zum Backitup-Adapter gibt es ausführliche Anleitungen, fall s Fragen sind
