  4. io Broker lässt sich nicht updaten (Linux)
71 Beiträge 4 Kommentatoren 3.6k Aufrufe 3 Beobachtet
  • hans1990H hans1990
    @thomas-braun said in io Broker lässt sich nicht updaten (Linux):
    iob upgrade heytech@1.0.6
    pi@rasphj:~ $ iob upgrade heytech@1.0.6
    Adapter "heytech"        is not installed.
    @hans-jürgen-strudler
    iob add heytech
    HomoranH hans1990H 2 Antworten Letzte Antwort
      iob add heytech
      @thomas-braun sagte in io Broker lässt sich nicht updaten (Linux):
      iob add heytech
      nee, die Instanz ist ja da, das gibt ne zweite!
      iob install heytech müsste die Basis wieder installieren, ggf, gefolgt von iob upload heytech
        iob add heytech
        hans1990H Offline
        hans1990H Offline
        hans1990
        schrieb am zuletzt editiert von hans1990
        iob add heytech
        da kam das zurück
        pi@rasphj:~ $ iob add heytech
        NPM version: 10.5.0
        Installing iobroker.heytech@1.0.6... (System call)
        added 4 packages, removed 639 packages, and changed 1 package in 16s
        70 packages are looking for funding
          run `npm fund` for details
        host.rasphj install adapter heytech
        upload [4] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/admin.d.ts admin.d.ts video/mp2t
        upload [3] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/heytech.png heytech.png image/png
        upload [2] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/index_m.html index_m.html text/html
        upload [1] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/style.css style.css text/css
        upload [0] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/words.js words.js application/javascript
        host.rasphj object system.adapter.heytech created/updated
        Update "system.adapter.heytech.0"
        host.rasphj create instance heytech
        host.rasphj object system.adapter.heytech.1.alive created
        host.rasphj object system.adapter.heytech.1.connected created
        host.rasphj object system.adapter.heytech.1.compactMode created
        host.rasphj object system.adapter.heytech.1.cpu created
        host.rasphj object system.adapter.heytech.1.cputime created
        host.rasphj object system.adapter.heytech.1.memHeapUsed created
        host.rasphj object system.adapter.heytech.1.memHeapTotal created
        host.rasphj object system.adapter.heytech.1.memRss created
        host.rasphj object system.adapter.heytech.1.uptime created
        host.rasphj object system.adapter.heytech.1.inputCount created
        host.rasphj object system.adapter.heytech.1.outputCount created
        host.rasphj object system.adapter.heytech.1.eventLoopLag created
        host.rasphj object system.adapter.heytech.1.sigKill created
        host.rasphj object system.adapter.heytech.1.logLevel created
        host.rasphj object system.adapter.heytech.1 created
        hier die Logs dazu:
        2024-04-26 17:46:17.534  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
        2024-04-26 17:46:17.538  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
        2024-04-26 17:46:24.616  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T15_46_18_637Z-debug-0.log
        2024-04-26 17:46:24.617  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
        2024-04-26 17:46:25.653  - info: host.rasphj iobroker npm-install: exit 25
        2024-04-26 17:46:26.655  - error: host.rasphj Cannot download and install adapter "heytech@1.0.5". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        2024-04-26 17:59:32.438  - info: host.rasphj instance system.adapter.heytech.1 started with pid 4420
        2024-04-26 17:59:35.225  - info: heytech.1 (4420) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.heytech, node: v18.20.2, js-controller: 5.0.19
          iob add heytech
          da kam das zurück
          NPM version: 10.5.0
          hier die Logs dazu:
          @hans1990 sagte in io Broker lässt sich nicht updaten (Linux):
          iob del heytech.1
          Und dann nochmal
          iob update
          iob upgrade all
          hans1990H 1 Antwort Letzte Antwort
            iob del heytech.1
            Und dann nochmal
            iob update
            iob upgrade all
            hans1990H Offline
            hans1990H Offline
            hans1990
            iob del heytech.1
            pi@rasphj:~ $ iob del heytech.1
            Delete instance "heytech.1"
            host.rasphj Counted 1 instances of heytech.1
            host.rasphj Counted 14 states of system.adapter.heytech.1
            host.rasphj Counted 14 states (system.adapter.heytech.1.*) from states
            host.rasphj Deleting 15 object(s).
            host.rasphj Deleting 14 state(s).
            iob update
            pi@rasphj:~ $
            iob update
            Used repository: stable
            Adapter    "admin"        : 6.13.16  , installed 5.1.25 [Updatable]
            Adapter    "backitup"     : 2.11.0   , installed 2.2.2  [Updatable]
            Adapter    "discovery"    : 4.4.0    , installed 2.7.3  [Updatable]
            Adapter    "elero-usb-transmitter": 0.5.2, installed 0.5.2
            Adapter    "heytech"      : 1.0.6    , installed 1.0.6
            Adapter    "homee"        : 1.2.0    , installed 1.2.0
            Adapter    "javascript"   : 7.8.0    , installed 5.2.13 [Updatable]
            Controller "js-controller": 5.0.19   , installed 5.0.19
            Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
            Adapter    "nuki"         : 1.6.0    , installed 1.5.0  [Updatable]
            Adapter    "nuki-extended": 2.6.5    , installed 2.3.1  [Updatable]
            Adapter    "octoprint"    : 5.1.0    , installed 1.1.1  [Updatable]
            Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
            Adapter    "shelly"       : 6.8.0    , installed 4.0.7  [Updatable]
            Adapter    "shuttercontrol": 1.7.0   , installed 1.2.1  [Updatable]
            Adapter    "socketio"     : 6.6.1    , installed 6.6.1
            Adapter    "sonoff"       : 3.0.3    , installed 2.4.5  [Updatable]
            Adapter    "synology"     : 3.1.0    , installed 3.1.0
            Adapter    "vis"          : 1.5.4    , installed 1.4.5  [Updatable]
            Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
            Adapter    "web"          : 6.2.5    , installed 3.4.9  [Updatable]
            Adapter    "wled"         : 0.7.2    , installed 0.6.3  [Updatable]
            Ich will alles updaten oder?
              iob del heytech.1
              iob update
              pi@rasphj:~ $
              iob update
              Ja natürlich.
                Ja natürlich.
                hans1990H Offline
                hans1990H Offline
                hans1990
                @Homoran
                DANKE!!! Hat funktioniert. Die Web Oberfläche ist wieder da.
                bei den Adaptern sind aber zwei admins
                wäre admin.1 zu löschen?
                  @Homoran
                  as I told:
                  @homoran sagte in io Broker lässt sich nicht updaten (Linux):
                  du hattest zweimal admin auf dem selben port
                    @Homoran
                    iob del admin.1
                    Dann zeig jetzt nochmal die Langfassung vom
                    iob diag
                      iob del admin.1
                      iob diag
                      hans1990H Offline
                      hans1990H Offline
                      hans1990
                      iob diag
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                         Static hostname: rasphj
                               Icon name: computer
                        Operating System: Raspbian GNU/Linux 11 (bullseye)
                                  Kernel: Linux 6.1.21-v8+
                            Architecture: arm64
                      Model           : Raspberry Pi 4 Model B Rev 1.1
                      Docker          : false
                      Virtualization  : none
                      Kernel          : aarch64
                      Userland        : armhf
                      Systemuptime and Load:
                       18:25:22 up 42 min,  1 user,  load average: 0.68, 0.68, 0.67
                      CPU threads: 4
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** Time and Time Zones ***
                                     Local time: Fri 2024-04-26 18:25:22 CEST
                                 Universal time: Fri 2024-04-26 16:25:22 UTC
                                       RTC time: n/a
                                      Time zone: Europe/Vienna (CEST, +0200)
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      pi
                      /home/pi
                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                      *** X-Server-Setup ***
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        747M        1.9G        0.0K        1.1G        3.0G
                      Swap:            99M          0B         99M
                      Total:          3.9G        747M        2.0G
                               3794 M total memory
                                748 M used memory
                                817 M active memory
                                866 M inactive memory
                               1949 M free memory
                                 67 M buffer memory
                               1029 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      /dev/root      ext4       59G  4.8G   52G   9% /
                      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                      tmpfs          tmpfs     759M  820K  759M   1% /run
                      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                      [Fri Apr 26 17:42:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:7D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d53cc083-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Fri Apr 26 17:42:36 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Fri Apr 26 17:42:36 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Fri Apr 26 17:42:38 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                      TARGET  SOURCE         FSTYPE OPTIONS
                      /       /dev/mmcblk0p2 ext4   rw,noatime
                      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                      /var:
                      1.7G    /var/
                      1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
                      1.3G    /var/log
                      202M    /var/cache
                      Archived and active journals take up 1.2G in the file system.
                      /opt/iobroker/backups:
                      24M     /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      286M    /opt/iobroker/iobroker-data/
                      127M    /opt/iobroker/iobroker-data/files
                      87M     /opt/iobroker/iobroker-data/history
                      57M     /opt/iobroker/iobroker-data/files/javascript.admin
                      45M     /opt/iobroker/iobroker-data/backup-objects
                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                      13M     /opt/iobroker/iobroker-data/objects.jsonl
                      8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
                      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                      6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                      USB-Devices by-id:
                      find: '/dev/serial/by-id/': No such file or directory
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.20.2
                      /usr/bin/node           v18.20.2
                      /usr/bin/npm            10.5.0
                      /usr/bin/npx            10.5.0
                      /usr/bin/corepack       0.25.2
                      nodejs:
                        Installed: 18.20.2-1nodesource1
                        Candidate: 18.20.2-1nodesource1
                        Version table:
                       *** 18.20.2-1nodesource1 600
                              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                           18.20.1-1nodesource1 600
                           18.20.0-1nodesource1 600
                           18.19.1-1nodesource1 600
                           18.19.0-1nodesource1 600
                           18.18.2-1nodesource1 600
                           18.18.1-1nodesource1 600
                           18.18.0-1nodesource1 600
                           18.17.1-1nodesource1 600
                           18.17.0-1nodesource1 600
                           18.16.1-1nodesource1 600
                           18.16.0-1nodesource1 600
                           18.15.0-1nodesource1 600
                           18.14.2-1nodesource1 600
                           18.14.1-1nodesource1 600
                           18.14.0-1nodesource1 600
                           18.13.0-1nodesource1 600
                           18.12.0-1nodesource1 600
                           18.11.0-1nodesource1 600
                           18.10.0-1nodesource1 600
                           18.9.1-1nodesource1 600
                           18.9.0-1nodesource1 600
                           18.8.0-1nodesource1 600
                           18.7.0-1nodesource1 600
                           18.6.0-1nodesource1 600
                           18.5.0-1nodesource1 600
                           18.4.0-1nodesource1 600
                           18.3.0-1nodesource1 600
                           18.2.0-1nodesource1 600
                           18.1.0-1nodesource1 600
                           18.0.0-1nodesource1 600
                           12.22.12~dfsg-1~deb11u4 500
                      No problems detected
                      Errors in npm tree:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Core adapters versions
                      admin:          6.13.16
                      javascript:     7.8.0
                      Adapters from github:   0
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : rasphj                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.backitup.0               : backitup              : rasphj                                   -  enabled
                      + system.adapter.discovery.0              : discovery             : rasphj                                   -  enabled
                        system.adapter.elero-usb-transmitter.0  : elero-usb-transmitter : rasphj                                   - disabled
                        system.adapter.flot.0                   : flot                  : rasphj                                   -  enabled
                        system.adapter.heytech.0                : heytech               : rasphj                                   - disabled, port: 1002
                      + system.adapter.history.0                : history               : rasphj                                   -  enabled
                        system.adapter.homee.0                  : homee                 : rasphj                                   - disabled
                      + system.adapter.javascript.0             : javascript            : rasphj                                   -  enabled
                        system.adapter.net-tools.0              : net-tools             : rasphj                                   - disabled
                      + system.adapter.nuki-extended.0          : nuki-extended         : rasphj                                   -  enabled
                      + system.adapter.nuki.0                   : nuki                  : rasphj                                   -  enabled
                      + system.adapter.octoprint.0              : octoprint             : rasphj                                   -  enabled
                        system.adapter.ping.0                   : ping                  : rasphj                                   - disabled
                      + system.adapter.rpi2.0                   : rpi2                  : rasphj                                   -  enabled
                      + system.adapter.shelly.0                 : shelly                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                        system.adapter.shuttercontrol.0         : shuttercontrol        : rasphj                                   - disabled
                      + system.adapter.sonoff.0                 : sonoff                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                        system.adapter.synology.0               : synology              : rasphj                                   - disabled, port: 5000
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : rasphj                                   -  enabled
                        system.adapter.vis.0                    : vis                   : rasphj                                   -  enabled
                      + system.adapter.web.0                    : web                   : rasphj                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.wled.0                   : wled                  : rasphj                                   -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Installed ioBroker-Instances
                      Adapter    "admin"        : 6.13.16  , installed 6.13.16
                      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                      Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                      Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                      Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                      Adapter    "vis"          : 1.5.4    , installed 1.5.4
                      Adapter    "web"          : 6.2.5    , installed 6.2.5
                      Adapter    "wled"         : 0.7.2    , installed 0.7.2
                      Adapter    "ws"           : 2.5.11   , installed 2.5.11
                      Objects and States
                      Objects:        3204
                      States:         2100
                      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       34237      5016/io.sonoff.0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14734      495/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14726      495/iobroker.js-con
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14717      526/sshd: /usr/sbin
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38806      5930/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35305      5219/io.admin.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          14719      526/sshd: /usr/sbin
                      tcp6       0      0 :::51989                :::*                    LISTEN      1001       37804      5937/io.nuki-extend
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13799      719/dhcpcd
                      udp        0      0 0.0.0.0:50156           0.0.0.0:*                           108        14626      388/avahi-daemon: r
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       33185      4843/io.wled.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14624      388/avahi-daemon: r
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       36491      5530/io.shelly.0
                      udp6       0      0 :::546                  :::*                                0          13811      719/dhcpcd
                      udp6       0      0 :::5353                 :::*                                108        14625      388/avahi-daemon: r
                      udp6       0      0 :::40797                :::*                                108        14627      388/avahi-daemon: r
                      2024-04-26 18:25:45.539  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:25:49.757  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:25:50.522  - warn: sonoff.0 (5016) Client [EnderPro] has invalid password or username
                      2024-04-26 18:25:50.682  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:25:55.853  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:25:56.172  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:26:01.008  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:26:02.056  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:26:06.269  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:26:07.670  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:26:11.441  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:26:13.784  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:26:16.328  - warn: sonoff.0 (5016) Client [EnderPro] has invalid password or username
                      2024-04-26 18:26:16.714  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:26:21.881  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:26:22.508  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:26:27.151  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:26:28.463  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                      2024-04-26 18:26:28.472  - warn: sonoff.0 (5016) Client [shelly1-E8DB84D63938] has invalid password or username
                      2024-04-26 18:26:28.898  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                      2024-04-26 18:26:28.943  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                      2024-04-26 18:26:28.946  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                      2024-04-26 18:26:28.985  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                      2024-04-26 18:26:29.004  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                      2024-04-26 18:26:29.015  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                        iob diag
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : armhf
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M          0B         99M
                                 3794 M total memory
                                  748 M used memory
                                  817 M active memory
                                 1949 M free memory
                                   67 M buffer memory
                                 1029 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        1.7G    /var/
                        1.3G    /var/log
                        202M    /var/cache
                        USB-Devices by-id:
                        /usr/bin/npm            10.5.0
                        /usr/bin/npx            10.5.0
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.13.16
                        javascript:     7.8.0
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        3204
                        States:         2100
                        Pending Updates: 0
                        Wenn das jetzt alles läuft, Backup ziehen und die ganze Kiste NEUinstallieren.
                        Diesmal als reines 64Bit-Lite-System im 'Bookworm'-Release.
                        shelly und sonoff auf dem gleichen Port ist bestimmt auch falsch.
                          #66
                          @hans1990
                          und diesmal nach dem Restore die Finger weg!
                          jegliche Unterbrechung des rebuilds führt zu einem undefinierten Zustand!!
                          Das kann eine Stunde dauern
                            Hallo! ich möchte meinen ioBroker updaten, da ich das schon lange nicht mehr gemacht habe.
                            Läuft auf einem pi unter linux.
                            Wenn ich der Anleitung folge bekomme ich einen Error:
                            pi@rasphj:~ $ iob upgrade self
                            Update js-controller from @3.3.21 to @5.0.19
                            NPM version: 6.14.16
                            npm install iobroker.js-controller@5.0.19 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                            npm ERR! code ENOTSUP
                            npm ERR! notsup Unsupported engine for iobroker.js-controller@5.0.19: wanted: {"node":">=16.4.0"} (current: {"node":"12.22.12","npm":"6.14.16"})
                            npm ERR! notsup Not compatible with your version of node/npm: iobroker.js-controller@5.0.19
                            npm ERR! notsup Required: {"node":">=16.4.0"}
                            npm ERR! notsup Actual:   {"npm":"6.14.16","node":"12.22.12"}
                            Ich hatte node auch schon auf 18.2 dann bekam ich die Rückmeldung, dass node zwischen 8 und 13 sein muss.
                            Daher glaube ich dass ich den ioBroker nicht direkt von 3.3.21 auf 5.0.19 updaten kann und ein Zwischenschritt auf Version 4.0.x notwendig ist.
                            Kann ich eine Version z.B. 4.0.0 mit dem Befehl iob upgrade self installieren?
                            lg Hans
                            hans1990H Offline
                            hans1990H Offline
                            hans1990
                            #67
                            Danke an @Homoran @Thomas-Braun
                            Zusammenfassung:
                            folgende Befehle haben in diesem Fall den Erfolg gebracht und das Update gelingen lassen.
                            iob stop
                            iob fix
                            iob start
                            iob diag
                            iob nodejs-update
                            iob upgrade self
                            iob add heytech
                            iob del heytech.1
                            iob update
                            iob upgrade all
                              Zusammenfassung:
                              iob stop
                              iob fix
                              iob start
                              iob diag
                              iob nodejs-update
                              iob upgrade self
                              iob add heytech
                              iob del heytech.1
                              iob update
                              iob upgrade all
                              #68
                              @hans1990
                              Da fehlt aber noch ein
                              iob upgrade self
                              Und lass die Kiste künftig nicht mehr so versumpfen.
                                @hans1990
                                iob upgrade self
                                hans1990H Offline
                                hans1990H Offline
                                hans1990
                                #69
                                ich werde darauf achten 🙄
                                  hans1990H Offline
                                  hans1990H Offline
                                  hans1990
                                  #70
                                  Das Betriebssystem ist bereits auf der SD Karte:
                                  Raspberry Pi OS Lite
                                  Release date: March 15th 2024
                                  System: 64-bit
                                  Kernel version: 6.6
                                  Debian version: 12 (bookworm)
                                  IO Broker installieren würde ich mit:
                                  curl -sLf https://iobroker.net/install.sh | bash -
                                  Backup ziehen
                                  Gibt es ein HOW TO, dass du für Migration der Einstellungen empfehlen kannst?
                                  lg Hans
                                    System: 64-bit
                                    Kernel version: 6.6
                                    Backup ziehen
                                    lg Hans
                                    #71
                                    @hans1990
                                    Dann kannst du jetzt dein Backup einspielen. Zum Backitup-Adapter gibt es ausführliche Anleitungen, fall s Fragen sind
