  4. io Broker lässt sich nicht updaten (Linux)
    2.5k
    4.5k
71 Beiträge 4 Kommentatoren 3.1k Aufrufe 3 Beobachtet
  • hans1990H hans1990
    @homoran said in io Broker lässt sich nicht updaten (Linux):
    und bei einem neuen iob logs --watch??
    ok, dann ist da was schiefgelaufen
    bitte wenn nichts neues kommt aktuellen iob diag posten
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: rasphj
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     17:18:36 up  3:03,  1 user,  load average: 2.09, 0.61, 0.31
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2024-04-26 17:18:36 CEST
               Universal time: Fri 2024-04-26 15:18:36 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        589M        1.5G        0.0K        1.7G        3.1G
    Swap:            99M          0B         99M
    Total:          3.9G        589M        1.6G
             3794 M total memory
              589 M used memory
              635 M active memory
             1380 M inactive memory
             1530 M free memory
              169 M buffer memory
             1504 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G  4.6G   52G   9% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  820K  759M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Fri Apr 26 14:15:03 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:7D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d53cc083-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Apr 26 14:15:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Apr 26 14:15:04 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Apr 26 14:15:06 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.7G    /var/
    1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
    1.3G    /var/log
    202M    /var/cache
    Archived and active journals take up 1.2G in the file system.
    /opt/iobroker/backups:
    24M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    202M    /opt/iobroker/iobroker-data/
    87M     /opt/iobroker/iobroker-data/history
    52M     /opt/iobroker/iobroker-data/files
    45M     /opt/iobroker/iobroker-data/backup-objects
    27M     /opt/iobroker/iobroker-data/files/javascript.admin
    9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
    6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    6.2M    /opt/iobroker/iobroker-data/objects.jsonl
    4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.2
    /usr/bin/node           v18.20.2
    /usr/bin/npm            10.5.0
    /usr/bin/npx            10.5.0
    /usr/bin/corepack       0.25.2
    nodejs:
      Installed: 18.20.2-1nodesource1
      Candidate: 18.20.2-1nodesource1
      Version table:
     *** 18.20.2-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.20.1-1nodesource1 600
         18.20.0-1nodesource1 600
         18.19.1-1nodesource1 600
         18.19.0-1nodesource1 600
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          5.1.25
    javascript:     5.2.13
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : rasphj                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : rasphj                                   - disabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : rasphj                                   -  enabled
      system.adapter.discovery.0              : discovery             : rasphj                                   -  enabled
      system.adapter.elero-usb-transmitter.0  : elero-usb-transmitter : rasphj                                   - disabled
      system.adapter.flot.0                   : flot                  : rasphj                                   -  enabled
      system.adapter.heytech.0                : heytech               : rasphj                                   - disabled, port: 1002
    + system.adapter.history.0                : history               : rasphj                                   -  enabled
      system.adapter.homee.0                  : homee                 : rasphj                                   - disabled
    + system.adapter.javascript.0             : javascript            : rasphj                                   -  enabled
      system.adapter.net-tools.0              : net-tools             : rasphj                                   - disabled
    + system.adapter.nuki-extended.0          : nuki-extended         : rasphj                                   -  enabled
    + system.adapter.nuki.0                   : nuki                  : rasphj                                   -  enabled
    + system.adapter.octoprint.0              : octoprint             : rasphj                                   -  enabled
      system.adapter.ping.0                   : ping                  : rasphj                                   - disabled
    + system.adapter.rpi2.0                   : rpi2                  : rasphj                                   -  enabled
    + system.adapter.shelly.0                 : shelly                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : rasphj                                   - disabled
    + system.adapter.sonoff.0                 : sonoff                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.synology.0               : synology              : rasphj                                   - disabled, port: 5000
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : rasphj                                   -  enabled
      system.adapter.vis.0                    : vis                   : rasphj                                   -  enabled
      system.adapter.web.0                    : web                   : rasphj                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : rasphj                                   -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 5.1.25 [Updatable]
    Adapter    "backitup"     : 2.11.0   , installed 2.2.2  [Updatable]
    Adapter    "discovery"    : 4.4.0    , installed 2.7.3  [Updatable]
    Adapter    "elero-usb-transmitter": 0.5.2, installed 0.5.2
    Adapter    "homee"        : 1.2.0    , installed 1.2.0
    Adapter    "javascript"   : 7.8.0    , installed 5.2.13 [Updatable]
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
    Adapter    "nuki"         : 1.6.0    , installed 1.5.0  [Updatable]
    Adapter    "nuki-extended": 2.6.5    , installed 2.3.1  [Updatable]
    Adapter    "octoprint"    : 5.1.0    , installed 1.1.1  [Updatable]
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
    Adapter    "shelly"       : 6.8.0    , installed 4.0.7  [Updatable]
    Adapter    "shuttercontrol": 1.7.0   , installed 1.2.1  [Updatable]
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "sonoff"       : 3.0.3    , installed 2.4.5  [Updatable]
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "vis"          : 1.5.4    , installed 1.4.5  [Updatable]
    Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
    Adapter    "web"          : 6.2.5    , installed 3.4.9  [Updatable]
    Adapter    "wled"         : 0.7.2    , installed 0.6.3  [Updatable]
    Objects and States
    Objects:        3146
    States:         2056
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       145618     23162/io.sonoff.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       145498     23046/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       144524     23046/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11069      520/sshd: /usr/sbin
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       145658     23186/io.nuki-exten
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11071      520/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       147919     24059/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14706      388/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       147929     23996/io.shelly.0
    udp        0      0 0.0.0.0:52988           0.0.0.0:*                           108        14708      388/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13180      729/dhcpcd
    udp6       0      0 :::546                  :::*                                0          11105      729/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14707      388/avahi-daemon: r
    udp6       0      0 :::48970                :::*                                108        14709      388/avahi-daemon: r
    2024-04-26 17:19:53.598  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    2024-04-26 17:19:53.598  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
    2024-04-26 17:19:53.598  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-04-26 17:19:53.599  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-04-26 17:19:53.599  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
    2024-04-26 17:19:53.599  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-04-26 17:19:53.600  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-04-26 17:19:53.600  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-04-26 17:19:53.600  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-04-26 17:19:53.600  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
    2024-04-26 17:19:53.601  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-04-26 17:19:53.601  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
    2024-04-26 17:19:53.601  - error: host.rasphj Caught by controller[0]: }
    2024-04-26 17:19:53.601  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
    2024-04-26 17:19:53.602  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-04-26 17:19:53.602  - info: host.rasphj Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
    2024-04-26 17:19:53.602  - info: host.rasphj system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.19"})
    2024-04-26 17:19:57.139  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
    2024-04-26 17:19:57.142  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
    2024-04-26 17:20:05.490  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T15_19_58_387Z-debug-0.log
    2024-04-26 17:20:05.491  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
    2024-04-26 17:20:06.531  - info: host.rasphj iobroker npm-install: exit 25
    2024-04-26 17:20:07.531  - warn: host.rasphj adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
    2024-04-26 17:20:07.532  - info: host.rasphj iobroker rebuild iobroker.js-controller@5.0.19 --path /opt/iobroker/node_modules
    2024-04-26 17:20:09.540  - info: host.rasphj iobroker npm-rebuild: Rebuilding native module "iobroker.js-controller@5.0.19" in /opt/iobroker/node_modules ...
    @hans-jürgen-strudler sagte in io Broker lässt sich nicht updaten (Linux):
    da sind doch noch logeinträge nach 16:25!!!!
    er war also noch nicht fertig!!
    @homoran sagte in io Broker lässt sich nicht updaten (Linux):
    Nein. Das war die letzte Zeile
    ok, dann ist da was schiefgelaufen :-(
    hans1990H 1 Antwort Letzte Antwort
      hans1990H Offline
      hans1990H Offline
      hans1990
      schrieb am zuletzt editiert von hans1990
      Macht es sinn nochmal vom backup zu starten?
      iob nodejs-update
      iob stop
      iob update
      iob upgrade self
      iob start
      Weboberfläche erst öffnen wenn die adapter fertig neu sind?
      Wie würdest du nach dem Befehl
      iob nodejs-update
      weiter vorgehen?
      Danke für deine Geduld und Hilfe!
        iob nodejs-update
        iob stop
        iob update
        iob upgrade self
        iob start
        iob nodejs-update
        weiter vorgehen?
        iob nodejs-update
        Kannst du dir sparen, das ist ja jetzt die richtige Version.
        Ist jetzt im LogFile Ruhe eingekehrt?
        iob update
        sagt?
          iob nodejs-update
          iob update
          sagt?
          hans1990H Offline
          hans1990H Offline
          hans1990
          @thomas-braun said in io Broker lässt sich nicht updaten (Linux):
          iob update
          sagt?
          pi@rasphj:~ $ iob update
          ja war ruhig - hab dann einen reboot gemacht und ist wieder hier hängen geblieben
          2024-04-26 17:46:13.582  - info: host.rasphj Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
          2024-04-26 17:46:13.929  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
          2024-04-26 17:46:13.929  - error: host.rasphj Caught by controller[0]:   throw err;
          2024-04-26 17:46:13.930  - error: host.rasphj Caught by controller[0]:   ^
          2024-04-26 17:46:13.930  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
          2024-04-26 17:46:13.930  - error: host.rasphj Caught by controller[0]: Require stack:
          2024-04-26 17:46:13.931  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
          2024-04-26 17:46:13.931  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
          2024-04-26 17:46:13.931  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
          2024-04-26 17:46:13.932  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
          2024-04-26 17:46:13.932  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
          2024-04-26 17:46:13.932  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
          2024-04-26 17:46:13.933  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
          2024-04-26 17:46:13.933  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
          2024-04-26 17:46:13.934  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
          2024-04-26 17:46:13.934  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
          2024-04-26 17:46:13.934  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
          2024-04-26 17:46:13.935  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
          2024-04-26 17:46:13.935  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
          2024-04-26 17:46:13.935  - error: host.rasphj Caught by controller[0]: }
          2024-04-26 17:46:13.936  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
          2024-04-26 17:46:13.936  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-04-26 17:46:13.936  - info: host.rasphj Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
          2024-04-26 17:46:17.534  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
          2024-04-26 17:46:17.538  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
          2024-04-26 17:46:24.616  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T15_46_18_637Z-debug-0.log
          2024-04-26 17:46:24.617  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
          2024-04-26 17:46:25.653  - info: host.rasphj iobroker npm-install: exit 25
          2024-04-26 17:46:26.655  - error: host.rasphj Cannot download and install adapter "heytech@1.0.5". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
            iob update
            sagt?
            iob upgrade heytech@1.0.6
              hans1990H Offline
              hans1990H Offline
              hans1990
              pi@rasphj:~ $ iob upgrade heytech@1.0.6
              Adapter "heytech"        is not installed.
                iob update
                sagt?
                Ja da wirst du die Installation unterbrochen haben und der admin ist jetzt in einem undefinierten Zustand.
                ich gab jetzt den vollständigen Pfad zum Adapter directory nicht im Kopf. Thomas wird es dir sagen
                  @hans-jürgen-strudler dann hattest du ihn über github installiert. Das konnte wegen der alten Dependencies nicht wiederhergestellt werden.
                    iob add heytech
                    HomoranH hans1990H 2 Antworten Letzte Antwort
                      iob add heytech
                      @thomas-braun sagte in io Broker lässt sich nicht updaten (Linux):
                      iob add heytech
                      nee, die Instanz ist ja da, das gibt ne zweite!
                      iob install heytech müsste die Basis wieder installieren, ggf, gefolgt von iob upload heytech
                        iob add heytech
                        hans1990H Offline
                        hans1990H Offline
                        hans1990
                        iob add heytech
                        da kam das zurück
                        pi@rasphj:~ $ iob add heytech
                        NPM version: 10.5.0
                        Installing iobroker.heytech@1.0.6... (System call)
                        added 4 packages, removed 639 packages, and changed 1 package in 16s
                        70 packages are looking for funding
                          run `npm fund` for details
                        host.rasphj install adapter heytech
                        upload [4] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/admin.d.ts admin.d.ts video/mp2t
                        upload [3] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/heytech.png heytech.png image/png
                        upload [2] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/index_m.html index_m.html text/html
                        upload [1] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/style.css style.css text/css
                        upload [0] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/words.js words.js application/javascript
                        host.rasphj object system.adapter.heytech created/updated
                        Update "system.adapter.heytech.0"
                        host.rasphj create instance heytech
                        host.rasphj object system.adapter.heytech.1.alive created
                        host.rasphj object system.adapter.heytech.1.connected created
                        host.rasphj object system.adapter.heytech.1.compactMode created
                        host.rasphj object system.adapter.heytech.1.cpu created
                        host.rasphj object system.adapter.heytech.1.cputime created
                        host.rasphj object system.adapter.heytech.1.memHeapUsed created
                        host.rasphj object system.adapter.heytech.1.memHeapTotal created
                        host.rasphj object system.adapter.heytech.1.memRss created
                        host.rasphj object system.adapter.heytech.1.uptime created
                        host.rasphj object system.adapter.heytech.1.inputCount created
                        host.rasphj object system.adapter.heytech.1.outputCount created
                        host.rasphj object system.adapter.heytech.1.eventLoopLag created
                        host.rasphj object system.adapter.heytech.1.sigKill created
                        host.rasphj object system.adapter.heytech.1.logLevel created
                        host.rasphj object system.adapter.heytech.1 created
                        hier die Logs dazu:
                        2024-04-26 17:59:32.438  - info: host.rasphj instance system.adapter.heytech.1 started with pid 4420
                        2024-04-26 17:59:35.225  - info: heytech.1 (4420) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.heytech, node: v18.20.2, js-controller: 5.0.19
                          iob add heytech
                          da kam das zurück
                          NPM version: 10.5.0
                          hier die Logs dazu:
                          @hans1990 sagte in io Broker lässt sich nicht updaten (Linux):
                          iob del heytech.1
                          Und dann nochmal
                          iob update
                          iob upgrade all
                            iob del heytech.1
                            Und dann nochmal
                            iob update
                            iob upgrade all
                            hans1990H Offline
                            hans1990H Offline
                            hans1990
                            iob del heytech.1
                            pi@rasphj:~ $ iob del heytech.1
                            Delete instance "heytech.1"
                            host.rasphj Counted 1 instances of heytech.1
                            host.rasphj Counted 14 states of system.adapter.heytech.1
                            host.rasphj Counted 14 states (system.adapter.heytech.1.*) from states
                            host.rasphj Deleting 15 object(s).
                            host.rasphj Deleting 14 state(s).
                            iob update
                            pi@rasphj:~ $
                            iob update
                            Adapter    "heytech"      : 1.0.6    , installed 1.0.6
                            Ich will alles updaten oder?
                              iob del heytech.1
                              iob update
                              pi@rasphj:~ $
                              iob update
                              Ja natürlich.
                                Ja natürlich.
                                hans1990H Offline
                                hans1990H Offline
                                hans1990
                                @Homoran
                                DANKE!!! Hat funktioniert. Die Web Oberfläche ist wieder da.
                                bei den Adaptern sind aber zwei admins
                                wäre admin.1 zu löschen?
                                  @Homoran
                                  as I told:
                                  du hattest zweimal admin auf dem selben port
                                    @Homoran
                                    iob del admin.1
                                    Dann zeig jetzt nochmal die Langfassung vom
                                    iob diag
                                      iob del admin.1
                                      iob diag
                                      hans1990H Offline
                                      hans1990H Offline
                                      hans1990
                                      iob diag
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : armhf
                                       18:25:22 up 42 min,  1 user,  load average: 0.68, 0.68, 0.67
                                      CPU threads: 4
                                      Current issues:
                                                     Local time: Fri 2024-04-26 18:25:22 CEST
                                                 Universal time: Fri 2024-04-26 16:25:22 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            3.8G        747M        1.9G        0.0K        1.1G        3.0G
                                      Swap:            99M          0B         99M
                                      Total:          3.9G        747M        2.0G
                                               3794 M total memory
                                                748 M used memory
                                                817 M active memory
                                                866 M inactive memory
                                               1949 M free memory
                                                 67 M buffer memory
                                               1029 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /dev/root      ext4       59G  4.8G   52G   9% /
                                      [Fri Apr 26 17:42:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:7D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d53cc083-02 rootfstype=ext4 fsck.repair=yes rootwait
                                      [Fri Apr 26 17:42:36 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Fri Apr 26 17:42:36 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                      [Fri Apr 26 17:42:38 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                      /var:
                                      1.7G    /var/
                                      1.3G    /var/log
                                      202M    /var/cache
                                      286M    /opt/iobroker/iobroker-data/
                                      127M    /opt/iobroker/iobroker-data/files
                                      57M     /opt/iobroker/iobroker-data/files/javascript.admin
                                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                      13M     /opt/iobroker/iobroker-data/objects.jsonl
                                      8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
                                      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                                      USB-Devices by-id:
                                      /usr/bin/npm            10.5.0
                                      /usr/bin/npx            10.5.0
                                      nodejs:
                                        Version table:
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.13.16
                                      javascript:     7.8.0
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : rasphj                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.discovery.0              : discovery             : rasphj                                   -  enabled
                                      + system.adapter.web.0                    : web                   : rasphj                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                      Adapter    "admin"        : 6.13.16  , installed 6.13.16
                                      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                                      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                                      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                                      Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                                      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                                      Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                                      Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                                      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                      Adapter    "vis"          : 1.5.4    , installed 1.5.4
                                      Adapter    "web"          : 6.2.5    , installed 6.2.5
                                      Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                      Adapter    "ws"           : 2.5.11   , installed 2.5.11
                                      Objects and States
                                      Objects:        3204
                                      States:         2100
                                      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Pending Updates: 0
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       34237      5016/io.sonoff.0
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14734      495/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14726      495/iobroker.js-con
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14717      526/sshd: /usr/sbin
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38806      5930/io.web.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35305      5219/io.admin.0
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          14719      526/sshd: /usr/sbin
                                      tcp6       0      0 :::51989                :::*                    LISTEN      1001       37804      5937/io.nuki-extend
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13799      719/dhcpcd
                                      udp        0      0 0.0.0.0:50156           0.0.0.0:*                           108        14626      388/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       33185      4843/io.wled.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14624      388/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       36491      5530/io.shelly.0
                                      udp6       0      0 :::546                  :::*                                0          13811      719/dhcpcd
                                      udp6       0      0 :::5353                 :::*                                108        14625      388/avahi-daemon: r
                                      udp6       0      0 :::40797                :::*                                108        14627      388/avahi-daemon: r
                                      2024-04-26 18:25:45.539  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:25:49.757  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:25:50.522  - warn: sonoff.0 (5016) Client [EnderPro] has invalid password or username
                                      2024-04-26 18:25:50.682  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:25:55.853  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:25:56.172  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:26:01.008  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:26:02.056  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:26:06.269  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:26:07.670  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:26:11.441  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:26:13.784  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:26:16.328  - warn: sonoff.0 (5016) Client [EnderPro] has invalid password or username
                                      2024-04-26 18:26:16.714  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:26:21.881  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:26:22.508  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:26:27.151  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:26:28.463  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                      2024-04-26 18:26:28.472  - warn: sonoff.0 (5016) Client [shelly1-E8DB84D63938] has invalid password or username
                                      2024-04-26 18:26:28.898  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                                      2024-04-26 18:26:28.943  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                                      2024-04-26 18:26:28.946  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                                      2024-04-26 18:26:28.985  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                                      2024-04-26 18:26:29.004  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                                      2024-04-26 18:26:29.015  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                                        iob diag
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : armhf
                                        CPU threads: 4
                                        Current issues:
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:            99M          0B         99M
                                                 3794 M total memory
                                                  748 M used memory
                                                  817 M active memory
                                                 1949 M free memory
                                                   67 M buffer memory
                                                 1029 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /var:
                                        1.7G    /var/
                                        1.3G    /var/log
                                        202M    /var/cache
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.5.0
                                        /usr/bin/npx            10.5.0
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.13.16
                                        javascript:     7.8.0
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        3204
                                        States:         2100
                                        Pending Updates: 0
                                        Wenn das jetzt alles läuft, Backup ziehen und die ganze Kiste NEUinstallieren.
                                        Diesmal als reines 64Bit-Lite-System im 'Bookworm'-Release.
                                        shelly und sonoff auf dem gleichen Port ist bestimmt auch falsch.
                                          #66
                                          @hans1990
                                          und diesmal nach dem Restore die Finger weg!
                                          jegliche Unterbrechung des rebuilds führt zu einem undefinierten Zustand!!
                                          Das kann eine Stunde dauern
