  4. io Broker lässt sich nicht updaten (Linux)
71 Beiträge 4 Kommentatoren 3.6k Aufrufe 3 Beobachtet
    @hans-jürgen-strudler
    iob add heytech
    hans1990H Offline
    hans1990H Offline
    hans1990
    schrieb am zuletzt editiert von hans1990
    @thomas-braun said in io Broker lässt sich nicht updaten (Linux):
    iob add heytech
    da kam das zurück
    pi@rasphj:~ $ iob add heytech
    NPM version: 10.5.0
    Installing iobroker.heytech@1.0.6... (System call)
    added 4 packages, removed 639 packages, and changed 1 package in 16s
    70 packages are looking for funding
      run `npm fund` for details
    host.rasphj install adapter heytech
    upload [4] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/admin.d.ts admin.d.ts video/mp2t
    upload [3] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/heytech.png heytech.png image/png
    upload [2] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/index_m.html index_m.html text/html
    upload [1] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/style.css style.css text/css
    upload [0] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/words.js words.js application/javascript
    host.rasphj object system.adapter.heytech created/updated
    Update "system.adapter.heytech.0"
    host.rasphj create instance heytech
    host.rasphj object system.adapter.heytech.1.alive created
    host.rasphj object system.adapter.heytech.1.connected created
    host.rasphj object system.adapter.heytech.1.compactMode created
    host.rasphj object system.adapter.heytech.1.cpu created
    host.rasphj object system.adapter.heytech.1.cputime created
    host.rasphj object system.adapter.heytech.1.memHeapUsed created
    host.rasphj object system.adapter.heytech.1.memHeapTotal created
    host.rasphj object system.adapter.heytech.1.memRss created
    host.rasphj object system.adapter.heytech.1.uptime created
    host.rasphj object system.adapter.heytech.1.inputCount created
    host.rasphj object system.adapter.heytech.1.outputCount created
    host.rasphj object system.adapter.heytech.1.eventLoopLag created
    host.rasphj object system.adapter.heytech.1.sigKill created
    host.rasphj object system.adapter.heytech.1.logLevel created
    host.rasphj object system.adapter.heytech.1 created
    hier die Logs dazu:
    2024-04-26 17:46:17.534  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
    2024-04-26 17:46:17.538  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
    2024-04-26 17:46:24.616  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T15_46_18_637Z-debug-0.log
    2024-04-26 17:46:24.617  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
    2024-04-26 17:46:25.653  - info: host.rasphj iobroker npm-install: exit 25
    2024-04-26 17:46:26.655  - error: host.rasphj Cannot download and install adapter "heytech@1.0.5". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    2024-04-26 17:59:32.438  - info: host.rasphj instance system.adapter.heytech.1 started with pid 4420
    2024-04-26 17:59:35.225  - info: heytech.1 (4420) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.heytech, node: v18.20.2, js-controller: 5.0.19
    • hans1990H hans1990
      iob add heytech
      da kam das zurück
      NPM version: 10.5.0
      hier die Logs dazu:
      @hans1990 sagte in io Broker lässt sich nicht updaten (Linux):
      iob del heytech.1
      Und dann nochmal
      iob update
      iob upgrade all
      hans1990H 1 Antwort Letzte Antwort
        iob del heytech.1
        Und dann nochmal
        iob update
        iob upgrade all
        hans1990H Offline
        hans1990H Offline
        hans1990
        iob del heytech.1
        pi@rasphj:~ $ iob del heytech.1
        Delete instance "heytech.1"
        host.rasphj Counted 1 instances of heytech.1
        host.rasphj Counted 14 states of system.adapter.heytech.1
        host.rasphj Counted 14 states (system.adapter.heytech.1.*) from states
        host.rasphj Deleting 15 object(s).
        host.rasphj Deleting 14 state(s).
        iob update
        pi@rasphj:~ $
        iob update
        Used repository: stable
        Adapter    "admin"        : 6.13.16  , installed 5.1.25 [Updatable]
        Adapter    "backitup"     : 2.11.0   , installed 2.2.2  [Updatable]
        Adapter    "discovery"    : 4.4.0    , installed 2.7.3  [Updatable]
        Adapter    "elero-usb-transmitter": 0.5.2, installed 0.5.2
        Adapter    "heytech"      : 1.0.6    , installed 1.0.6
        Adapter    "homee"        : 1.2.0    , installed 1.2.0
        Adapter    "javascript"   : 7.8.0    , installed 5.2.13 [Updatable]
        Controller "js-controller": 5.0.19   , installed 5.0.19
        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
        Adapter    "nuki"         : 1.6.0    , installed 1.5.0  [Updatable]
        Adapter    "nuki-extended": 2.6.5    , installed 2.3.1  [Updatable]
        Adapter    "octoprint"    : 5.1.0    , installed 1.1.1  [Updatable]
        Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
        Adapter    "shelly"       : 6.8.0    , installed 4.0.7  [Updatable]
        Adapter    "shuttercontrol": 1.7.0   , installed 1.2.1  [Updatable]
        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
        Adapter    "sonoff"       : 3.0.3    , installed 2.4.5  [Updatable]
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Adapter    "vis"          : 1.5.4    , installed 1.4.5  [Updatable]
        Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
        Adapter    "web"          : 6.2.5    , installed 3.4.9  [Updatable]
        Adapter    "wled"         : 0.7.2    , installed 0.6.3  [Updatable]
        Ich will alles updaten oder?
          iob del heytech.1
          iob update
          pi@rasphj:~ $
          iob update
          Ja natürlich.
            Ja natürlich.
            hans1990H Offline
            hans1990H Offline
            hans1990
            @Homoran
            DANKE!!! Hat funktioniert. Die Web Oberfläche ist wieder da.
            bei den Adaptern sind aber zwei admins
            wäre admin.1 zu löschen?
              @Homoran
              as I told:
              @homoran sagte in io Broker lässt sich nicht updaten (Linux):
              du hattest zweimal admin auf dem selben port
                @Homoran
                iob del admin.1
                Dann zeig jetzt nochmal die Langfassung vom
                iob diag
                  iob del admin.1
                  iob diag
                  hans1990H Offline
                  hans1990H Offline
                  hans1990
                  iob diag
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                     Static hostname: rasphj
                           Icon name: computer
                    Operating System: Raspbian GNU/Linux 11 (bullseye)
                              Kernel: Linux 6.1.21-v8+
                        Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.1
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : armhf
                  Systemuptime and Load:
                   18:25:22 up 42 min,  1 user,  load average: 0.68, 0.68, 0.67
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Fri 2024-04-26 18:25:22 CEST
                             Universal time: Fri 2024-04-26 16:25:22 UTC
                                   RTC time: n/a
                                  Time zone: Europe/Vienna (CEST, +0200)
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            3.8G        747M        1.9G        0.0K        1.1G        3.0G
                  Swap:            99M          0B         99M
                  Total:          3.9G        747M        2.0G
                           3794 M total memory
                            748 M used memory
                            817 M active memory
                            866 M inactive memory
                           1949 M free memory
                             67 M buffer memory
                           1029 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  /dev/root      ext4       59G  4.8G   52G   9% /
                  devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                  tmpfs          tmpfs     759M  820K  759M   1% /run
                  /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                  [Fri Apr 26 17:42:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:7D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d53cc083-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Fri Apr 26 17:42:36 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Fri Apr 26 17:42:36 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Fri Apr 26 17:42:38 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  TARGET  SOURCE         FSTYPE OPTIONS
                  /       /dev/mmcblk0p2 ext4   rw,noatime
                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                  /var:
                  1.7G    /var/
                  1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
                  1.3G    /var/log
                  202M    /var/cache
                  Archived and active journals take up 1.2G in the file system.
                  /opt/iobroker/backups:
                  24M     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  286M    /opt/iobroker/iobroker-data/
                  127M    /opt/iobroker/iobroker-data/files
                  87M     /opt/iobroker/iobroker-data/history
                  57M     /opt/iobroker/iobroker-data/files/javascript.admin
                  45M     /opt/iobroker/iobroker-data/backup-objects
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                  13M     /opt/iobroker/iobroker-data/objects.jsonl
                  8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
                  7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                  6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                  USB-Devices by-id:
                  find: '/dev/serial/by-id/': No such file or directory
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.20.2
                  /usr/bin/node           v18.20.2
                  /usr/bin/npm            10.5.0
                  /usr/bin/npx            10.5.0
                  /usr/bin/corepack       0.25.2
                  nodejs:
                    Installed: 18.20.2-1nodesource1
                    Candidate: 18.20.2-1nodesource1
                    Version table:
                   *** 18.20.2-1nodesource1 600
                          500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                       18.20.1-1nodesource1 600
                       18.20.0-1nodesource1 600
                       18.19.1-1nodesource1 600
                       18.19.0-1nodesource1 600
                       18.18.2-1nodesource1 600
                       18.18.1-1nodesource1 600
                       18.18.0-1nodesource1 600
                       18.17.1-1nodesource1 600
                       18.17.0-1nodesource1 600
                       18.16.1-1nodesource1 600
                       18.16.0-1nodesource1 600
                       18.15.0-1nodesource1 600
                       18.14.2-1nodesource1 600
                       18.14.1-1nodesource1 600
                       18.14.0-1nodesource1 600
                       18.13.0-1nodesource1 600
                       18.12.0-1nodesource1 600
                       18.11.0-1nodesource1 600
                       18.10.0-1nodesource1 600
                       18.9.1-1nodesource1 600
                       18.9.0-1nodesource1 600
                       18.8.0-1nodesource1 600
                       18.7.0-1nodesource1 600
                       18.6.0-1nodesource1 600
                       18.5.0-1nodesource1 600
                       18.4.0-1nodesource1 600
                       18.3.0-1nodesource1 600
                       18.2.0-1nodesource1 600
                       18.1.0-1nodesource1 600
                       18.0.0-1nodesource1 600
                       12.22.12~dfsg-1~deb11u4 500
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  admin:          6.13.16
                  javascript:     7.8.0
                  Adapters from github:   0
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : rasphj                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.backitup.0               : backitup              : rasphj                                   -  enabled
                  + system.adapter.discovery.0              : discovery             : rasphj                                   -  enabled
                    system.adapter.elero-usb-transmitter.0  : elero-usb-transmitter : rasphj                                   - disabled
                    system.adapter.flot.0                   : flot                  : rasphj                                   -  enabled
                    system.adapter.heytech.0                : heytech               : rasphj                                   - disabled, port: 1002
                  + system.adapter.history.0                : history               : rasphj                                   -  enabled
                    system.adapter.homee.0                  : homee                 : rasphj                                   - disabled
                  + system.adapter.javascript.0             : javascript            : rasphj                                   -  enabled
                    system.adapter.net-tools.0              : net-tools             : rasphj                                   - disabled
                  + system.adapter.nuki-extended.0          : nuki-extended         : rasphj                                   -  enabled
                  + system.adapter.nuki.0                   : nuki                  : rasphj                                   -  enabled
                  + system.adapter.octoprint.0              : octoprint             : rasphj                                   -  enabled
                    system.adapter.ping.0                   : ping                  : rasphj                                   - disabled
                  + system.adapter.rpi2.0                   : rpi2                  : rasphj                                   -  enabled
                  + system.adapter.shelly.0                 : shelly                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                    system.adapter.shuttercontrol.0         : shuttercontrol        : rasphj                                   - disabled
                  + system.adapter.sonoff.0                 : sonoff                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                    system.adapter.synology.0               : synology              : rasphj                                   - disabled, port: 5000
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : rasphj                                   -  enabled
                    system.adapter.vis.0                    : vis                   : rasphj                                   -  enabled
                  + system.adapter.web.0                    : web                   : rasphj                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.wled.0                   : wled                  : rasphj                                   -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Adapter    "admin"        : 6.13.16  , installed 6.13.16
                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                  Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                  Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                  Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                  Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                  Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                  Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                  Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                  Adapter    "vis"          : 1.5.4    , installed 1.5.4
                  Adapter    "web"          : 6.2.5    , installed 6.2.5
                  Adapter    "wled"         : 0.7.2    , installed 0.7.2
                  Adapter    "ws"           : 2.5.11   , installed 2.5.11
                  Objects and States
                  Objects:        3204
                  States:         2100
                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       34237      5016/io.sonoff.0
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14734      495/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14726      495/iobroker.js-con
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14717      526/sshd: /usr/sbin
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38806      5930/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35305      5219/io.admin.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14719      526/sshd: /usr/sbin
                  tcp6       0      0 :::51989                :::*                    LISTEN      1001       37804      5937/io.nuki-extend
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13799      719/dhcpcd
                  udp        0      0 0.0.0.0:50156           0.0.0.0:*                           108        14626      388/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       33185      4843/io.wled.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14624      388/avahi-daemon: r
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       36491      5530/io.shelly.0
                  udp6       0      0 :::546                  :::*                                0          13811      719/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        14625      388/avahi-daemon: r
                  udp6       0      0 :::40797                :::*                                108        14627      388/avahi-daemon: r
                  2024-04-26 18:25:45.539  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:25:49.757  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:25:50.522  - warn: sonoff.0 (5016) Client [EnderPro] has invalid password or username
                  2024-04-26 18:25:50.682  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:25:55.853  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:25:56.172  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:01.008  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:02.056  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:06.269  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:07.670  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:11.441  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:13.784  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:16.328  - warn: sonoff.0 (5016) Client [EnderPro] has invalid password or username
                  2024-04-26 18:26:16.714  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:21.881  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:22.508  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:27.151  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:28.463  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:28.472  - warn: sonoff.0 (5016) Client [shelly1-E8DB84D63938] has invalid password or username
                  2024-04-26 18:26:28.898  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                  2024-04-26 18:26:28.943  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                  2024-04-26 18:26:28.946  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                  2024-04-26 18:26:28.985  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                  2024-04-26 18:26:29.004  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                  2024-04-26 18:26:29.015  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                    iob diag
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : armhf
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:            99M          0B         99M
                             3794 M total memory
                              748 M used memory
                              817 M active memory
                             1949 M free memory
                               67 M buffer memory
                             1029 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    1.7G    /var/
                    1.3G    /var/log
                    202M    /var/cache
                    USB-Devices by-id:
                    /usr/bin/npm            10.5.0
                    /usr/bin/npx            10.5.0
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.13.16
                    javascript:     7.8.0
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        3204
                    States:         2100
                    Pending Updates: 0
                    Wenn das jetzt alles läuft, Backup ziehen und die ganze Kiste NEUinstallieren.
                    Diesmal als reines 64Bit-Lite-System im 'Bookworm'-Release.
                    shelly und sonoff auf dem gleichen Port ist bestimmt auch falsch.
                    HomoranH hans1990H 2 Antworten Letzte Antwort
                      #66
                      @thomas-braun sagte in io Broker lässt sich nicht updaten (Linux):
                      @hans1990
                      und diesmal nach dem Restore die Finger weg!
                      jegliche Unterbrechung des rebuilds führt zu einem undefinierten Zustand!!
                      Das kann eine Stunde dauern
                        Hallo! ich möchte meinen ioBroker updaten, da ich das schon lange nicht mehr gemacht habe.
                        Läuft auf einem pi unter linux.
                        Wenn ich der Anleitung folge bekomme ich einen Error:
                        pi@rasphj:~ $ iob upgrade self
                        Update js-controller from @3.3.21 to @5.0.19
                        NPM version: 6.14.16
                        npm install iobroker.js-controller@5.0.19 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                        npm ERR! code ENOTSUP
                        npm ERR! notsup Unsupported engine for iobroker.js-controller@5.0.19: wanted: {"node":">=16.4.0"} (current: {"node":"12.22.12","npm":"6.14.16"})
                        npm ERR! notsup Not compatible with your version of node/npm: iobroker.js-controller@5.0.19
                        npm ERR! notsup Required: {"node":">=16.4.0"}
                        npm ERR! notsup Actual:   {"npm":"6.14.16","node":"12.22.12"}
                        Ich hatte node auch schon auf 18.2 dann bekam ich die Rückmeldung, dass node zwischen 8 und 13 sein muss.
                        Daher glaube ich dass ich den ioBroker nicht direkt von 3.3.21 auf 5.0.19 updaten kann und ein Zwischenschritt auf Version 4.0.x notwendig ist.
                        Kann ich eine Version z.B. 4.0.0 mit dem Befehl iob upgrade self installieren?
                        lg Hans
                        hans1990H Offline
                        hans1990H Offline
                        hans1990
                        #67
                        Danke an @Homoran @Thomas-Braun
                        Zusammenfassung:
                        folgende Befehle haben in diesem Fall den Erfolg gebracht und das Update gelingen lassen.
                        iob stop
                        iob fix
                        iob start
                        iob diag
                        iob nodejs-update
                        iob upgrade self
                        iob add heytech
                        iob del heytech.1
                        iob update
                        iob upgrade all
                          Zusammenfassung:
                          iob stop
                          iob fix
                          iob start
                          iob diag
                          iob nodejs-update
                          iob upgrade self
                          iob add heytech
                          iob del heytech.1
                          iob update
                          iob upgrade all
                          #68
                          @hans1990
                          Da fehlt aber noch ein
                          iob upgrade self
                          Und lass die Kiste künftig nicht mehr so versumpfen.
                            @hans1990
                            iob upgrade self
                            hans1990H Offline
                            hans1990H Offline
                            hans1990
                            #69
                            ich werde darauf achten 🙄
                              hans1990H Offline
                              hans1990H Offline
                              hans1990
                              #70
                              Das Betriebssystem ist bereits auf der SD Karte:
                              Raspberry Pi OS Lite
                              Release date: March 15th 2024
                              System: 64-bit
                              Kernel version: 6.6
                              Debian version: 12 (bookworm)
                              IO Broker installieren würde ich mit:
                              curl -sLf https://iobroker.net/install.sh | bash -
                              Backup ziehen
                              Gibt es ein HOW TO, dass du für Migration der Einstellungen empfehlen kannst?
                              lg Hans
                                System: 64-bit
                                Kernel version: 6.6
                                Backup ziehen
                                lg Hans
                                #71
                                @hans1990
                                Dann kannst du jetzt dein Backup einspielen. Zum Backitup-Adapter gibt es ausführliche Anleitungen, fall s Fragen sind
