  4. jarvis v3.1.x - just another remarkable vis
1.9k Beiträge 94 Kommentatoren 926.4k Aufrufe 77 Beobachtet
  • M MCU
    @thomas-braun Wäre das ein sauberer Neustart?
    4 Sekunden bis zum Neustart
    .... jede Menge weiterer Log-Einträge zum Neustart
    2024-04-17 20:11:03.023 - info: host.iobrokerPROD instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
    2024-04-17 20:11:03.023 - warn: host.iobrokerPROD instance system.adapter.telegram.0 terminated due to SIGTERM
    2024-04-17 20:11:03.023 - info: host.iobrokerPROD instance system.adapter.telegram.0 terminated with code null ()
    2024-04-17 20:11:03.023 - warn: host.iobrokerPROD instance system.adapter.pushover.0 terminated due to SIGTERM
    2024-04-17 20:11:03.023 - info: host.iobrokerPROD instance system.adapter.pushover.0 terminated with code null ()
    2024-04-17 20:11:03.023 - warn: host.iobrokerPROD instance system.adapter.telegram.1 terminated due to SIGTERM
    2024-04-17 20:11:03.023 - info: host.iobrokerPROD instance system.adapter.telegram.1 terminated with code null ()
    2024-04-17 20:11:03.024 - warn: host.iobrokerPROD instance system.adapter.zigbee.0 terminated due to SIGTERM
    2024-04-17 20:11:03.024 - info: host.iobrokerPROD instance system.adapter.zigbee.0 terminated with code null ()
    2024-04-17 20:11:03.026 - info: host.iobrokerPROD instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
    2024-04-17 20:11:03.026 - info: host.iobrokerPROD instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2024-04-17 20:11:03.027 - info: host.iobrokerPROD instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
    2024-04-17 20:11:03.027 - warn: host.iobrokerPROD instance system.adapter.sonoff.0 terminated due to SIGTERM
    2024-04-17 20:11:03.027 - info: host.iobrokerPROD instance system.adapter.sonoff.0 terminated with code null ()
    2024-04-17 20:11:03.027 - warn: host.iobrokerPROD instance system.adapter.ping.0 terminated due to SIGTERM
    2024-04-17 20:11:03.027 - info: host.iobrokerPROD instance system.adapter.ping.0 terminated with code null ()
    2024-04-17 20:11:03.027 - warn: host.iobrokerPROD instance system.adapter.web.0 terminated due to SIGTERM
    2024-04-17 20:11:03.027 - info: host.iobrokerPROD instance system.adapter.web.0 terminated with code null ()
    2024-04-17 20:11:03.027 - warn: host.iobrokerPROD instance system.adapter.echarts.0 terminated due to SIGTERM
    2024-04-17 20:11:03.027 - info: host.iobrokerPROD instance system.adapter.echarts.0 terminated with code null ()
    2024-04-17 20:11:05.405 - info: meross.0 (361) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-04-17 20:11:05.963 - info: host.iobrokerPROD instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-04-17 20:11:05.963 - info: host.iobrokerPROD All instances are stopped.
    2024-04-17 20:11:06.043 - info: host.iobrokerPROD terminated
    ... NEUSTART
    2024-04-17 20:11:10.156 - info: host.iobrokerPROD iobroker.js-controller version 5.0.19 js-controller starting
    2024-04-17 20:11:10.158 - info: host.iobrokerPROD Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2024-04-17 20:11:10.158 - info: host.iobrokerPROD hostname: iobrokerPROD, node: v18.20.2
    2024-04-17 20:11:10.158 - info: host.iobrokerPROD ip addresses: 192.168.178.150 fe80::10:40ff:fe11:7741
    2024-04-17 20:11:11.108 - info: host.iobrokerPROD connected to Objects and States
    2024-04-17 20:11:11.123 - info: host.iobrokerPROD added notifications configuration of host
    2024-04-17 20:11:11.461 - info: host.iobrokerPROD Delete state "system.host.iobrokerPROD.versions.nodeCurrent"
    2024-04-17 20:11:11.461 - info: host.iobrokerPROD 57 instances found
    2024-04-17 20:11:11.476 - info: host.iobrokerPROD starting 47 instances
    2024-04-17 20:11:11.513 - info: host.iobrokerPROD instance system.adapter.admin.0 started with pid 176
    2024-04-17 20:11:11.555 - info: host.iobrokerPROD Delete state "system.host.iobrokerPROD.versions.nodeNewest"
    2024-04-17 20:11:11.556 - info: host.iobrokerPROD Delete state "system.host.iobrokerPROD.versions.nodeNewestNext"
    2024-04-17 20:11:11.557 - info: host.iobrokerPROD Delete state "system.host.iobrokerPROD.versions.npmCurrent"
    2024-04-17 20:11:11.557 - info: host.iobrokerPROD Delete state "system.host.iobrokerPROD.versions.npmNewest"
    2024-04-17 20:11:11.558 - info: host.iobrokerPROD Delete state "system.host.iobrokerPROD.versions.npmNewestNext"
    2024-04-17 20:11:11.559 - info: host.iobrokerPROD Some obsolete host states deleted.
    2024-04-17 20:11:12.212 - info: admin.0 (176) starting. Version 6.17.3 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.2, js-controller: 5.0.19
    Ich habe es über einen Dateieintrag gemacht.
    Es läuft ein bash-Script welches alle 30 Sekunden den Inhalt prüft.
    Passt der Inhalt wird zuerst iobroker gestoppt und dann neu gestartet.
    Problem man muss in der bash-Datei das Passwort vom User angeben. Da man sonst immer nach dem Passwort gefragt wird. Sicher?
    #1506
    @mcu sagte in jarvis v3.1.x - just another remarkable vis:
    Wie sieht das Skript denn konkret aus?
    Sicherheit ist halt relativ. Du könntest ja z. B. die Rechte an der Datei einschränken. Hab ich z. B. mit der Datei, die die Passwörter für eine smb-Freigabe beinhaltet so eingestellt:
    -rw-r----- 1 iobroker iobroker 38 Oct 19 20:16 /home/iobroker/.smbcredentials
      M Online
      M Online
      MCU
      #1507
      @thomas-braun bash script
      #!/bin/bash
      # Pfad zur Datei, deren Inhalt   berpr  ft werden soll
      datei="/opt/iobroker/iobroker-data/files/0_userdata.0/restart.txt"
      #  ^|berpr  fe den Inhalt der Datei
      if [ -f "$datei" ]; then
          inhalt=$(cat "$datei")
          if [ "$inhalt" = "trigger_reboot" ]; then
              echo "Reboot wird durchgefuehrt..."
              neuer_inhalt="kein Reboot"
              sed -i "1s/.*/$neuer_inhalt/" "$datei"
              iobroker stop
              echo "DEIN PASSWORT" | sudo -S reboot
          else
              echo "Neustart nicht erforderlich. Inhalt der Datei: $inhalt"
          fi
      else
          echo "Datei nicht gefunden: $datei"
      fi
      crontab
      * * * * * bash /opt/iobroker/iobroker-data/files/0_userdata.0/checkFile.sh >> /opt/iobroker/iobroker-data/files/0_userdata.0/checkFile.log 2>&1
      * * * * * sleep 30; bash /opt/iobroker/iobroker-data/files/0_userdata.0/checkFile.sh >> /opt/iobroker/iobroker-data/files/0_userdata.0/checkFile.log 2>&1
      • M MCU
        #!/bin/bash
                iobroker stop
            else
            fi
        else
        fi
        crontab
        #1508
        @mcu
        Müsste gehen. Wobei ich kein Freund von Crontabs bin. Ich würde eher via inotify schauen ob sich die Datei geändert hat und das als Trigger verwenden.
          @mcu
          M Online
          M Online
          MCU
          #1509
          @thomas-braun sagte in jarvis v3.1.x - just another remarkable vis:
          inotify
          Wie überwacht man da die Änderung? Wo muss man es eintragen?
          • M MCU
            inotify
            #1510
            @mcu
            Guckstu Wiki von Schnubbibuntu:
            https://wiki.ubuntuusers.de/inotify/
            • M MCU
              inotify
              #1511
              @mcu
              Andere Alternative: Per systemd
              https://wiki.ubuntuusers.de/systemd/Path_Units/
              Gefällt mir eigentlich sogar noch besser. Da brauchste im javascript nur sowas wie EXEC touch /pfad/zur/ueberwachtendatei/reboot und schaust mit der PathUnit ob reboot angelegt wurde und in der Unit löschst du die Datei wieder und startest die Kiste neu.
                @mcu
                M Online
                M Online
                MCU
                #1512
                @Flowski Habe es nochmal geändert. Jetzt wird erst iob stop und dann sudo reboot ausgeführt.
                https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/system-effektprog./rebootsystem
                F 1 Antwort Letzte Antwort
                • M MCU
                  Flowski
                  #1513
                  @mcu vielen Dank werde ich bei Gelegenheit Mal testen. VG
                    sixum
                    #1514
                    Wie kann man es eigentlich deaktivieren, dass auf dem Smartphone per Doppelklick gezoomt bzw Vollbild genommen wird?
                    • M Online
                      M Online
                      MCU
                      #1515
                      @sixum Welche Version?
                      "Gar nicht", da es versionsabhängig ist.
                      Es gibt aber zurzeit keine fehlerfreie Version mit allen Modulen.
                      Dies hängt davon ab, welche Module man nutzt.
                      Muss man sich selber durchtesten.
                      v3.1.8 bzw v3.1.9-beta.2 sind die "besten" Versionen.
                      v3.2.0-beta.10 -> kein Doppelklick Problem mehr, aber andere siehe Issues
                      • M MCU
                        sixum
                        #1516
                        @mcu habe 3.1.8. Extrem nervig das ganze :D
                        • U Offline
                          U Offline
                          UncleB
                          #1517
                          Kann sein das aktuell bei Jarvis nix mehr passiert, ich hab leider das letzte Update vor 2 Wochen gemacht, seit dem kann ich Jarvis nicht mehr nutzen, die Seite lädt ständig neu..
                          • U UncleB
                            M Online
                            M Online
                            MCU
                            #1518
                            @uncleb Cache löschen.
                            Und Signatur prüfen
                            https://github.com/Zefau/ioBroker.jarvis/issues/2613
                            U 1 Antwort Letzte Antwort
                            • M MCU
                              Und Signatur prüfen
                              U Offline
                              U Offline
                              UncleB
                              #1519
                              @mcu und wie setzt man eine LEERE signature property manuell?
                              • U UncleB
                                M Online
                                M Online
                                MCU
                                #1520
                                @uncleb Auf den Wert klicken und dann nochmal in den Editor klicken und nach der Version
                                die signature einfügen
                                "signature": 1234,
                                • U Offline
                                  U Offline
                                  UncleB
                                  #1521
                                  @mcu said in jarvis v3.1.x - just another remarkable vis:
                                  "signature": 1234,
                                  Auf deinem Video erkenne ich zu wenig, sehe nichtmal wo du hinklickst 😖
                                  • U UncleB
                                    "signature": 1234,
                                    M Online
                                    M Online
                                    MCU
                                    #1522
                                    @uncleb Klick mal auf das Video dann wird es größer.
                                    Ich klicke nach dem Komma hinter Version.
                                    • M MCU
                                      U Offline
                                      U Offline
                                      UncleB
                                      #1523
                                      @mcu ich seh aber nicht auf welchen DP du klickst,
                                      sieht bei mir alles anders aus. Abe rich gebs eh auf für heute.
                                      Danke fürs helfen, ich guck morgen nochmal
                                      • U UncleB
                                        M Online
                                        M Online
                                        MCU
                                        #1524
                                        @uncleb
                                        Auf alle Werte rechts, die keine signature haben.
                                        • M MCU
                                          @uncleb
                                          U Offline
                                          U Offline
                                          UncleB
                                          #1525
                                          @mcu ahh jetz klappts, danke für deine Geduld
